    T113 内核问题 卡在根文件系统处
    • Q
      QIAO0605 LV 3 最后由 编辑
      环境:T113-S3 使用 100_ask sdk 使用串口3作为console SD卡启动 分了8个分区 ,
      boot-resource, env, env-redund, boot,
      rootfs, private, rootfs_data, UDISK
      文件系统使用 squashfs
      另外spi0 处 已经焊上了一个nor flash 但设备树并没有调用它 不知道会不会有影响.🤕
      调试了好些日子了 最后实在没办法了
      问题描述 : **uboot 启动内核后 能显示出sd卡容量 以及各种外设 但卡在启动跟文件系统这块 **
      [2024-05-26 03:43:55] [    4.880538] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts:
      [2024-05-26 03:43:55] [    4.903121] mount_root: switched to extroot
      这一步 不知道是不是与根文件系统有关系 希望论坛大佬帮忙排查一下问题! 感谢
      日志如下
      [2024-05-26 03:43:45] [29]HELLO! BOOT0 is starting!
      [2024-05-26 03:43:45] [32]BOOT0 commit : 88480af-dirty
      [2024-05-26 03:43:45] [35]set pll start
      [2024-05-26 03:43:45] [41]periph0 has been enabled
      [2024-05-26 03:43:45] [44]set pll end
      [2024-05-26 03:43:45] [45][pmu]: bus read error
      [2024-05-26 03:43:45] [48]board init ok
      [2024-05-26 03:43:45] [50]ZQ value = 0x2d
      [2024-05-26 03:43:45] [51]get_pmu_exist() = -1
      [2024-05-26 03:43:45] [54]ddr_efuse_type: 0xa
      [2024-05-26 03:43:45] [56]trefi:7.8ms
      [2024-05-26 03:43:45] [59][AUTO DEBUG] single rank and full DQ!
      [2024-05-26 03:43:45] [63]ddr_efuse_type: 0xa
      [2024-05-26 03:43:45] [65]trefi:7.8ms
      [2024-05-26 03:43:45] [67][AUTO DEBUG] rank 0 row = 13
      [2024-05-26 03:43:45] [70][AUTO DEBUG] rank 0 bank = 8
      [2024-05-26 03:43:45] [73][AUTO DEBUG] rank 0 page size = 2 KB
      [2024-05-26 03:43:45] [77]DRAM BOOT DRIVE INFO: V0.33
      [2024-05-26 03:43:45] [80]DRAM CLK = 936 MHz
      [2024-05-26 03:43:45] [82]DRAM Type = 3 (2:DDR2,3:DDR3)
      [2024-05-26 03:43:45] [86]DRAMC read ODT  off.
      [2024-05-26 03:43:45] [88]DRAM ODT value: 0x42.
      [2024-05-26 03:43:45] [91]ddr_efuse_type: 0xa
      [2024-05-26 03:43:45] [94]DRAM SIZE =128 M
      [2024-05-26 03:43:45] [96]dram_tpr4:0x0
      [2024-05-26 03:43:45] [97]PLL_DDR_CTRL_REG:0xf8004d00
      [2024-05-26 03:43:45] [100]DRAM_CLK_REG:0xc0000000
      [2024-05-26 03:43:45] [103][TIMING DEBUG] MR2= 0x20
      [2024-05-26 03:43:45] [111]DRAM simple test OK.
      [2024-05-26 03:43:45] [113]rtc standby flag is 0x0, super standby flag is 0x0
      [2024-05-26 03:43:45] [118]dram size =128
      [2024-05-26 03:43:45] [121]card no is 0
      [2024-05-26 03:43:45] [123]sdcard 0 line count 4
      [2024-05-26 03:43:45] [125][mmc]: mmc driver ver 2021-05-21 14:47
      [2024-05-26 03:43:45] [134][mmc]: Wrong media type 0x0
      [2024-05-26 03:43:45] [137][mmc]: ***Try SD card 0***
      [2024-05-26 03:43:45] [158][mmc]: HSSDR52/SDR25 4 bit
      [2024-05-26 03:43:45] [161][mmc]: 50000000 Hz
      [2024-05-26 03:43:45] [163][mmc]: 30436 MB
      [2024-05-26 03:43:45] [165][mmc]: ***SD/MMC 0 init OK!!!***
      [2024-05-26 03:43:45] [254]Loading boot-pkg Succeed(index=0).
      [2024-05-26 03:43:45] [257]Entry_name        = u-boot
      [2024-05-26 03:43:45] [264]Entry_name        = optee
      [2024-05-26 03:43:45] [268]Entry_name        = dtb
      [2024-05-26 03:43:45] [271]mmc not para
      [2024-05-26 03:43:45] [273]Jump to second Boot.
      [2024-05-26 03:43:45] M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:11 UTC 2021 arm
      [2024-05-26 03:43:45] U-Boot 2018.05-g24521d6-dirty (May 25 2024 - 05:00:09 +0800) Allwinner Technology
      [2024-05-26 03:43:45] [00.326]CPU:   Allwinner Family
      [2024-05-26 03:43:45] [00.329]Model: sun8iw20
      [2024-05-26 03:43:45] I2C:   FDT ERROR:fdt_set_all_pin:[twi0]-->FDT_ERR_BADPATH
      [2024-05-26 03:43:45] FDT ERROR:fdt_set_all_pin:[twi1]-->FDT_ERR_BADPATH
      [2024-05-26 03:43:45] ready
      [2024-05-26 03:43:45] [00.350]DRAM:  128 MiB
      [2024-05-26 03:43:45] [00.353]Relocation Offset is: 04ec4000
      [2024-05-26 03:43:45] [00.378]secure enable bit: 0
      [2024-05-26 03:43:45] [00.380]smc_tee_inform_fdt failed with: -65526[00.385]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [2024-05-26 03:43:45] [00.391]gic: sec monitor mode
      [2024-05-26 03:43:45] [00.394]flash init start
      [2024-05-26 03:43:45] [00.396]workmode = 0,storage type = 1
      [2024-05-26 03:43:45] [00.400][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [2024-05-26 03:43:45] [00.405][mmc]: get sdc_type fail and use default host:tm1.
      [2024-05-26 03:43:45] [00.411][mmc]: can't find node "mmc0",will add new node
      [2024-05-26 03:43:45] [00.416][mmc]: fdt err returned <no error>
      [2024-05-26 03:43:45] [00.420][mmc]: Using default timing para
      [2024-05-26 03:43:45] [00.423][mmc]: SUNXI SDMMC Controller Version:0x50310
      [2024-05-26 03:43:46] [00.452][mmc]: card_caps:0x3000000a
      [2024-05-26 03:43:46] [00.455][mmc]: host_caps:0x3000003f
      [2024-05-26 03:43:46] [00.460]sunxi flash init ok
      [2024-05-26 03:43:46] [00.462]line:703 init_clocks
      [2024-05-26 03:43:46] [00.465]drv_disp_init
      [2024-05-26 03:43:46] [00.477]drv_disp_init finish
      [2024-05-26 03:43:46] [00.479]boot_gui_init:start
      [2024-05-26 03:43:46] [00.482]set disp.dev2_output_type fail. using defval=0
      [2024-05-26 03:43:46] [00.488]boot_gui_init:finish
      [2024-05-26 03:43:46] partno erro : can't find partition bootloader
      [2024-05-26 03:43:46] 54 bytes read in 1 ms (52.7 KiB/s)
      [2024-05-26 03:43:46] [00.507]bmp_name=bootlogo.bmp size 38454
      [2024-05-26 03:43:46] 38454 bytes read in 3 ms (12.2 MiB/s)
      [2024-05-26 03:43:46] [00.526]Loading Environment from SUNXI_FLASH... OK
      [2024-05-26 03:43:46] [00.556]Item0 (Map) magic is bad
      [2024-05-26 03:43:46] [00.559]the secure storage item0 copy0 magic is bad
      [2024-05-26 03:43:46] [00.575]Item0 (Map) magic is bad
      [2024-05-26 03:43:46] [00.578]the secure storage item0 copy1 magic is bad
      [2024-05-26 03:43:46] [00.582]Item0 (Map) magic is bad
      [2024-05-26 03:43:46] secure storage read widevine fail
      [2024-05-26 03:43:46] [00.588]secure storage read widevine fail with:-1
      [2024-05-26 03:43:46] secure storage read ec_key fail
      [2024-05-26 03:43:46] [00.595]secure storage read ec_key fail with:-1
      [2024-05-26 03:43:46] secure storage read ec_cert1 fail
      [2024-05-26 03:43:46] [00.603]secure storage read ec_cert1 fail with:-1
      [2024-05-26 03:43:46] secure storage read ec_cert2 fail
      [2024-05-26 03:43:46] [00.610]secure storage read ec_cert2 fail with:-1
      [2024-05-26 03:43:46] secure storage read ec_cert3 fail
      [2024-05-26 03:43:46] [00.618]secure storage read ec_cert3 fail with:-1
      [2024-05-26 03:43:46] secure storage read rsa_key fail
      [2024-05-26 03:43:46] [00.625]secure storage read rsa_key fail with:-1
      [2024-05-26 03:43:46] secure storage read rsa_cert1 fail
      [2024-05-26 03:43:46] [00.632]secure storage read rsa_cert1 fail with:-1
      [2024-05-26 03:43:46] secure storage read rsa_cert2 fail
      [2024-05-26 03:43:46] [00.640]secure storage read rsa_cert2 fail with:-1
      [2024-05-26 03:43:46] secure storage read rsa_cert3 fail
      [2024-05-26 03:43:46] [00.648]secure storage read rsa_cert3 fail with:-1
      [2024-05-26 03:43:46] [00.652]usb burn from boot
      [2024-05-26 03:43:46] delay time 0
      [2024-05-26 03:43:46] weak:otg_phy_config
      [2024-05-26 03:43:46] [00.663]usb prepare ok
      [2024-05-26 03:43:47] [01.466]overtime
      [2024-05-26 03:43:47] [01.469]do_burn_from_boot usb : no usb exist
      [2024-05-26 03:43:47] root_partition is rootfs
      [2024-05-26 03:43:47] set root to /dev/mmcblk0p5
      [2024-05-26 03:43:47] [01.478]update part info
      [2024-05-26 03:43:47] [01.481]update bootcmd
      [2024-05-26 03:43:47] [01.484]change working_fdt 0x43e83e70 to 0x43e63e70
      [2024-05-26 03:43:47] disable nand error: FDT_ERR_BADPATH
      [2024-05-26 03:43:47] [01.508]update dts
      [2024-05-26 03:43:47] Hit any key to stop autoboot:  3 [01.660]LCD open finish
      [2024-05-26 03:43:50]  0
      [2024-05-26 03:43:50] [04.651]no vendor_boot partition is found
      [2024-05-26 03:43:50] Android's image name: t113-100ask
      [2024-05-26 03:43:50] [04.661]Starting kernel ...
      [2024-05-26 03:43:50] [04.664][mmc]: MMC Device 2 not found
      [2024-05-26 03:43:50] [04.667][mmc]: mmc 2 not find, so not exit
      [2024-05-26 03:43:50] [    0.000000] Booting Linux on physical CPU 0x0
      [2024-05-26 03:43:50] [    0.000000] Linux version 5.4.61 (qiao@DevelopComputer) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #38 SMP PREEMPT Sat May 25 19:17:21 UTC 2024
      [2024-05-26 03:43:50] [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
      [2024-05-26 03:43:50] [    0.000000] CPU: div instructions available: patching division code
      [2024-05-26 03:43:50] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [2024-05-26 03:43:50] [    0.000000] OF: fdt: Machine model: sun8iw20
      [2024-05-26 03:43:50] [    0.000000] printk: bootconsole [earlycon0] enabled
      [2024-05-26 03:43:50] [    0.000000] Memory policy: Data cache writealloc
      [2024-05-26 03:43:50] [    0.000000] cma: Reserved 8 MiB at 0x47800000
      [2024-05-26 03:43:50] [    0.000000] On node 0 totalpages: 32768
      [2024-05-26 03:43:50] [    0.000000]   Normal zone: 256 pages used for memmap
      [2024-05-26 03:43:50] [    0.000000]   Normal zone: 0 pages reserved
      [2024-05-26 03:43:50] [    0.000000]   Normal zone: 32768 pages, LIFO batch:7
      [2024-05-26 03:43:50] [    0.000000] psci: probing for conduit method from DT.
      [2024-05-26 03:43:50] [    0.000000] psci: PSCIv1.0 detected in firmware.
      [2024-05-26 03:43:50] [    0.000000] psci: Using standard PSCI v0.2 function IDs
      [2024-05-26 03:43:50] [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
      [2024-05-26 03:43:50] [    0.000000] psci: SMC Calling Convention v1.0
      [2024-05-26 03:43:50] [    0.000000] percpu: Embedded 15 pages/cpu s28876 r8192 d24372 u61440
      [2024-05-26 03:43:50] [    0.000000] pcpu-alloc: s28876 r8192 d24372 u61440 alloc=15*4096
      [2024-05-26 03:43:50] [    0.000000] pcpu-alloc: [0] 0 [0] 1
      [2024-05-26 03:43:50] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32512
      [2024-05-26 03:43:50] [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=tty0 console=ttyS3,115200 panic=5 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty(05/25/2024-05:00:09) disp_reserve=921600,0x43eed000 androidboot.dramsize=128
      [2024-05-26 03:43:50] [    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
      [2024-05-26 03:43:50] [    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [2024-05-26 03:43:50] [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [2024-05-26 03:43:50] [    0.000000] Memory: 108752K/131072K available (5120K kernel code, 252K rwdata, 1340K rodata, 1024K init, 1162K bss, 14128K reserved, 8192K cma-reserved)
      [2024-05-26 03:43:50] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
      [2024-05-26 03:43:50] [    0.000000] rcu: Preemptible hierarchical RCU implementation.
      [2024-05-26 03:43:50] [    0.000000]  Tasks RCU enabled.
      [2024-05-26 03:43:50] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [2024-05-26 03:43:50] [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [2024-05-26 03:43:50] [    0.000000] random: get_random_bytes called from start_kernel+0x264/0x3e8 with crng_init=0
      [2024-05-26 03:43:50] [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
      [2024-05-26 03:43:50] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      [2024-05-26 03:43:50] [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [2024-05-26 03:43:50] [    0.008026] Switching to timer-based delay loop, resolution 41ns
      [2024-05-26 03:43:50] [    0.014186] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [2024-05-26 03:43:50] [    0.023961] Console: colour dummy device 80x30
      [2024-05-26 03:43:50] [    0.029118] printk: console [tty0] enabled
      [2024-05-26 03:43:50] [    0.033257] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [2024-05-26 03:43:50] [    0.043649] pid_max: default: 32768 minimum: 301
      [2024-05-26 03:43:50] [    0.048427] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [2024-05-26 03:43:50] [    0.055782] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [2024-05-26 03:43:50] [    0.064121] CPU: Testing write buffer coherency: ok
      [2024-05-26 03:43:50] [    0.069366] /cpus/cpu@0 missing clock-frequency property
      [2024-05-26 03:43:50] [    0.074703] /cpus/cpu@1 missing clock-frequency property
      [2024-05-26 03:43:50] [    0.080066] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [2024-05-26 03:43:50] [    0.086244] Setting up static identity map for 0x40100000 - 0x40100060
      [2024-05-26 03:43:50] [    0.092917] rcu: Hierarchical SRCU implementation.
      [2024-05-26 03:43:50] [    0.098133] smp: Bringing up secondary CPUs ...
      [2024-05-26 03:43:50] [    0.103776] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [2024-05-26 03:43:50] [    0.103898] smp: Brought up 1 node, 2 CPUs
      [2024-05-26 03:43:50] [    0.113760] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [2024-05-26 03:43:50] [    0.119953] CPU: All CPU(s) started in SVC mode.
      [2024-05-26 03:43:50] [    0.125037] devtmpfs: initialized
      [2024-05-26 03:43:50] [    0.139522] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [2024-05-26 03:43:50] [    0.147682] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [2024-05-26 03:43:50] [    0.157592] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [2024-05-26 03:43:50] [    0.164840] pinctrl core: initialized pinctrl subsystem
      [2024-05-26 03:43:50] [    0.172216] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [2024-05-26 03:43:50] [    0.202754] rtc_ccu: sunxi ccu init OK
      [2024-05-26 03:43:50] [    0.208721] ccu: sunxi ccu init OK
      [2024-05-26 03:43:50] [    0.212520] r_ccu: sunxi ccu init OK
      [2024-05-26 03:43:50] [    0.225745] fbcon: Taking over console
      [2024-05-26 03:43:50] [    0.248458] reg-fixed-voltage vdd-cpu: Fixed regulator specified with variable voltages
      [2024-05-26 03:43:50] [    0.256573] reg-fixed-voltage: probe of vdd-cpu failed with error -22
      [2024-05-26 03:43:50] [    0.263438] iommu: Default domain type: Translated
      [2024-05-26 03:43:50] [    0.268526] sunxi iommu: irq = 24
      [2024-05-26 03:43:50] [    0.272675] SCSI subsystem initialized
      [2024-05-26 03:43:50] [    0.276593] usbcore: registered new interface driver usbfs
      [2024-05-26 03:43:50] [    0.282160] usbcore: registered new interface driver hub
      [2024-05-26 03:43:50] [    0.287561] usbcore: registered new device driver usb
      [2024-05-26 03:43:50] [    0.293453] Advanced Linux Sound Architecture Driver Initialized.
      [2024-05-26 03:43:50] [    0.299579] pwm module init!
      [2024-05-26 03:43:50] [    0.303764] g2d 5410000.g2d: Adding to iommu group 0
      [2024-05-26 03:43:51] [    0.309046] G2D: rcq version initialized.major:251
      [2024-05-26 03:43:51] [    0.314617] clocksource: Switched to clocksource arch_sys_counter
      [2024-05-26 03:43:51] [    0.329250] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [2024-05-26 03:43:51] [    0.347448] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [2024-05-26 03:43:51] [    0.358329] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [2024-05-26 03:43:51] [    0.364336] ntfs: driver 2.1.32 [Flags: R/W].
      [2024-05-26 03:43:51] [    0.397150] io scheduler mq-deadline registered
      [2024-05-26 03:43:51] [    0.401723] io scheduler kyber registered
      [2024-05-26 03:43:51] [    0.406981] [DISP]disp_module_init
      [2024-05-26 03:43:51] [    0.410829] disp 5000000.disp: Adding to iommu group 0
      [2024-05-26 03:43:51] [    0.416558] [DISP] disp_init,line:2386:
      [2024-05-26 03:43:51] [    0.416564] smooth display screen:0 type:1 mode:4
      [2024-05-26 03:43:51] [    0.436252] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
      [2024-05-26 03:43:51] [    0.444832] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
      [2024-05-26 03:43:51] [    0.458179] [DISP] disp_init_hdmi,line:1047:
      [2024-05-26 03:43:51] [    0.458182] dont support hdmi
      [2024-05-26 03:43:51] [    0.465782] display_fb_request,fb_id:0
      [2024-05-26 03:43:51] [    0.471741] Freeing logo buffer memory: 900K
      [2024-05-26 03:43:52] [    0.476507] disp_al_manager_apply ouput_type:1
      [2024-05-26 03:43:52] [    0.477586] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [2024-05-26 03:43:52] [    1.764815] Console: switching to colour frame buffer device 60x30
      [2024-05-26 03:43:52] [    1.814146] [DISP]disp_module_init finish
      [2024-05-26 03:43:52] [    1.821933] sunxi_sid_init()551 - insmod ok
      [2024-05-26 03:43:52] [    1.829935] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [2024-05-26 03:43:52] [    1.845965] uart uart3: get regulator failed
      [2024-05-26 03:43:52] [    1.853177] uart uart3: uart3 supply uart not found, using dummy regulator
      [2024-05-26 03:43:52] [    1.866102] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [2024-05-26 03:43:52] [    1.879808] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [2024-05-26 03:43:52]  [    1.893712] printk: console [ttyS3] enabled
      [2024-05-26 03:43:52] [    1.905649] printk: bootconsole [earlycon0] disabled
      [2024-05-26 03:43:52] [    1.919984] misc dump reg init
      [2024-05-26 03:43:52] [    1.927239] dma-buf: Running sanitycheck
      [2024-05-26 03:43:52] [    1.934701] dma-buf: Running dma_fence
      [2024-05-26 03:43:52] [    1.941852] sizeof(dma_fence)=48
      [2024-05-26 03:43:52] [    1.948487] dma-buf: Running dma_fence/sanitycheck
      [2024-05-26 03:43:52] [    1.956809] dma-buf: Running dma_fence/test_signaling
      [2024-05-26 03:43:52] [    1.965337] dma-buf: Running dma_fence/test_add_callback
      [2024-05-26 03:43:52] [    1.974064] dma-buf: Running dma_fence/test_late_add_callback
      [2024-05-26 03:43:52] [    1.985877] dma-buf: Running dma_fence/test_rm_callback
      [2024-05-26 03:43:52] [    1.994564] dma-buf: Running dma_fence/test_late_rm_callback
      [2024-05-26 03:43:52] [    2.006394] dma-buf: Running dma_fence/test_status
      [2024-05-26 03:43:52] [    2.014576] dma-buf: Running dma_fence/test_error
      [2024-05-26 03:43:52] [    2.022572] dma-buf: Running dma_fence/test_wait
      [2024-05-26 03:43:52] [    2.030363] dma-buf: Running dma_fence/test_wait_timeout
      [2024-05-26 03:43:52] [    2.074628] dma-buf: Running dma_fence/test_stub
      [2024-05-26 03:43:52] [    2.082298] dma-buf: Running dma_fence/race_signal_callback
      [2024-05-26 03:43:52] [    2.154646] thread_signal_callback[0] completed 33366 passes, 6447 misses
      [2024-05-26 03:43:52] [    2.167187] thread_signal_callback[1] completed 33352 passes, 6435 misses
      [2024-05-26 03:43:52] [    2.244633] thread_signal_callback[0] completed 40791 passes, 40790 misses
      [2024-05-26 03:43:52] [    2.257376] thread_signal_callback[1] completed 40764 passes, 40762 misses
      [2024-05-26 03:43:52] [    2.270609] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [2024-05-26 03:43:52] [    2.283090] sunxi-ehci: EHCI SUNXI driver
      [2024-05-26 03:43:52] [    2.290619] get ehci0-controller wakeup-source is fail.
      [2024-05-26 03:43:52] [    2.299252] sunxi ehci0-controller don't init wakeup source
      [2024-05-26 03:43:52] [    2.310845] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a5dd80, 0x:c882f000, irq_no:35
      [2024-05-26 03:43:52] [    2.331500] sunxi-ehci 4101000.ehci0-controller: 4101000.ehci0-controller supply hci not found, using dummy regulator
      [2024-05-26 03:43:52] [    2.349822] sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
      [2024-05-26 03:43:53] [    2.363153] sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 1
      [2024-05-26 03:43:53] [    2.379407] sunxi-ehci 4101000.ehci0-controller: irq 53, io mem 0x04101000
      [2024-05-26 03:43:53] [    2.414634] sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
      [2024-05-26 03:43:53] [    2.430099] hub 1-0:1.0: USB hub found
      [2024-05-26 03:43:53] [    2.437891] hub 1-0:1.0: 1 port detected
      [2024-05-26 03:43:53] [    2.446417] get ehci1-controller wakeup-source is fail.
      [2024-05-26 03:43:53] [    2.455867] sunxi ehci1-controller don't init wakeup source
      [2024-05-26 03:43:53] [    2.468830] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0a5e2a0, 0x:c8835000, irq_no:37
      [2024-05-26 03:43:53] [    2.491146] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [2024-05-26 03:43:53] [    2.510222] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [2024-05-26 03:43:53] [    2.524236] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 2
      [2024-05-26 03:43:53] [    2.540991] sunxi-ehci 4200000.ehci1-controller: irq 55, io mem 0x04200000
      [2024-05-26 03:43:53] [    2.584643] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [2024-05-26 03:43:53] [    2.600130] hub 2-0:1.0: USB hub found
      [2024-05-26 03:43:53] [    2.607817] hub 2-0:1.0: 1 port detected
      [2024-05-26 03:43:53] [    2.616146] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [2024-05-26 03:43:53] [    2.629701] sunxi-ohci: OHCI SUNXI driver
      [2024-05-26 03:43:53] [    2.637902] get ohci0-controller wakeup-source is fail.
      [2024-05-26 03:43:53] [    2.647199] sunxi ohci0-controller don't init wakeup source
      [2024-05-26 03:43:53] [    2.659883] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0a5e010
      [2024-05-26 03:43:53] [    2.676242] sunxi-ohci 4101400.ohci0-controller: 4101400.ohci0-controller supply hci not found, using dummy regulator
      [2024-05-26 03:43:53] [    2.695097] sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
      [2024-05-26 03:43:53] [    2.709072] sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 3
      [2024-05-26 03:43:53] [    2.725774] sunxi-ohci 4101400.ohci0-controller: irq 54, io mem 0x04101400
      [2024-05-26 03:43:53] [    2.809443] hub 3-0:1.0: USB hub found
      [2024-05-26 03:43:53] [    2.817077] hub 3-0:1.0: 1 port detected
      [2024-05-26 03:43:53] [    2.825474] get ohci1-controller wakeup-source is fail.
      [2024-05-26 03:43:53] [    2.834775] sunxi ohci1-controller don't init wakeup source
      [2024-05-26 03:43:53] [    2.847430] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0a5e530
      [2024-05-26 03:43:53] [    2.863748] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [2024-05-26 03:43:53] [    2.882580] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [2024-05-26 03:43:53] [    2.896274] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 4
      [2024-05-26 03:43:53] [    2.912678] debugfs: Directory 'sunxi-ohci' with parent 'ohci' already present!
      [2024-05-26 03:43:53] [    2.927676] sunxi-ohci 4200400.ohci1-controller: irq 56, io mem 0x04200400
      [2024-05-26 03:43:53] [    3.009455] hub 4-0:1.0: USB hub found
      [2024-05-26 03:43:53] [    3.017133] hub 4-0:1.0: 1 port detected
      [2024-05-26 03:43:53] [    3.025496] usbcore: registered new interface driver cdc_acm
      [2024-05-26 03:43:53] [    3.038418] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [2024-05-26 03:43:53] [    3.038547] usbcore: registered new interface driver usb-storage
      [2024-05-26 03:43:53] [    3.068918] sunxi-rtc 7090000.rtc: registered as rtc0
      [2024-05-26 03:43:53] [    3.078087] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:43 UTC (43)
      [2024-05-26 03:43:53] [    3.093531] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [2024-05-26 03:43:53] [    3.102543] i2c /dev entries driver
      [2024-05-26 03:43:53] [    3.109796] sunxi cedar version 1.1
      [2024-05-26 03:43:53] [    3.117101] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [2024-05-26 03:43:53] [    3.129789] VE: sunxi_cedar_probe power-domain init!!!
      [2024-05-26 03:43:53] [    3.138830] VE: install start!!!
      [2024-05-26 03:43:53] [    3.150568] VE: cedar-ve the get irq is 39
      [2024-05-26 03:43:53] [    3.163050] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [2024-05-26 03:43:53] [    3.181159] VE: install end!!!
      [2024-05-26 03:43:53] [    3.191737] VE: sunxi_cedar_probe
      [2024-05-26 03:43:53] [    3.199796] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [2024-05-26 03:43:53] [    3.215170] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [2024-05-26 03:43:53] [    3.226817] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [2024-05-26 03:43:53] [    3.238697] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [2024-05-26 03:43:53] [    3.250686] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [2024-05-26 03:43:53] [    3.262667] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [2024-05-26 03:43:53] [    3.274800] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [2024-05-26 03:43:53] [    3.287003] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [2024-05-26 03:43:53] [    3.299331] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [2024-05-26 03:43:54] [    3.312576] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.329868] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [2024-05-26 03:43:54] [    3.356267] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.387047] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
      [2024-05-26 03:43:54] [    3.396424] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.415172] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [2024-05-26 03:43:54] [    3.417718] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.432115] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [2024-05-26 03:43:54] [    3.452922] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.463778] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [2024-05-26 03:43:54] [    3.485495] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.495824] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [2024-05-26 03:43:54] [    3.495831] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [2024-05-26 03:43:54] [    3.541447] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [2024-05-26 03:43:54] [    3.554998] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [2024-05-26 03:43:54] [    3.564045] mmc0: host does not support reading read-only switch, assuming write-enable
      [2024-05-26 03:43:54] [    3.568549] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [2024-05-26 03:43:54] [    3.568554] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [2024-05-26 03:43:54] [    3.568579] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [2024-05-26 03:43:54] [    3.587519] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [2024-05-26 03:43:54] [    3.598916] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.611875] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [2024-05-26 03:43:54] [    3.627571] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [2024-05-26 03:43:54] [    3.646444] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [2024-05-26 03:43:54] [    3.677165] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.683660] mmc0: new high speed SDHC card at address aaaa
      [2024-05-26 03:43:54] [    3.710933] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [2024-05-26 03:43:54] [    3.718239] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
      [2024-05-26 03:43:54] [    3.737029] exFAT: Version 1.3.0
      [2024-05-26 03:43:54] [    3.749608] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [2024-05-26 03:43:54] [    3.764031] usbcore: registered new interface driver snd-usb-audio
      [2024-05-26 03:43:54] [    3.775405]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [2024-05-26 03:43:54] [    3.780814] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [2024-05-26 03:43:54] [    3.793180] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [2024-05-26 03:43:54] [    3.807076] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [2024-05-26 03:43:54] [    3.877814] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.885122] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [2024-05-26 03:43:54] [    3.912303] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [2024-05-26 03:43:54] [    3.912689] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    3.929023] [SNDCODEC][sunxi_card_init][583]:card init finished
      [2024-05-26 03:43:54] [    3.960937] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [2024-05-26 03:43:54] [    3.974486] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [2024-05-26 03:43:54] [    3.988030] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [2024-05-26 03:43:54] [    4.001650] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [2024-05-26 03:43:54] [    4.001677] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [2024-05-26 03:43:54] [    4.033906] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [2024-05-26 03:43:54] [    4.051938] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [2024-05-26 03:43:54] [    4.071076] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [2024-05-26 03:43:54] [    4.085852] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [2024-05-26 03:43:54] [    4.095187] Registering SWP/SWPB emulation handler
      [2024-05-26 03:43:54] [    4.123738] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [2024-05-26 03:43:54] [    4.142432] sunxi-i2c sunxi-i2c0: sunxi-i2c0 supply twi not found, using dummy regulator
      [2024-05-26 03:43:54] [    4.159476] sunxi-i2c sunxi-i2c0: probe success
      [2024-05-26 03:43:54] [    4.168556] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [2024-05-26 03:43:54] [    4.187054] sunxi-i2c sunxi-i2c1: sunxi-i2c1 supply twi not found, using dummy regulator
      [2024-05-26 03:43:54] [    4.204003] sunxi-i2c sunxi-i2c1: probe success
      [2024-05-26 03:43:54] [    4.216326] clk: Not disabling unused clocks
      [2024-05-26 03:43:54] [    4.224696] ALSA device list:
      [2024-05-26 03:43:54] [    4.231448]   #0: audiocodec
      [2024-05-26 03:43:54] [    4.238053] alloc_fd: slot 0 not NULL!
      [2024-05-26 03:43:54] [    4.255681] EXT4-fs (mmcblk0p5): mounted filesystem without journal. Opts: (null)
      [2024-05-26 03:43:54] [    4.270813] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
      [2024-05-26 03:43:54] [    4.279600] random: fast init done
      [2024-05-26 03:43:54] [    4.292312] devtmpfs: mounted
      [2024-05-26 03:43:54] [    4.300792] Freeing unused kernel memory: 1024K
      [2024-05-26 03:43:54] [    4.309211] Run /sbin/init as init process
      [2024-05-26 03:43:55] [    4.371860] init: Console is alive
      [2024-05-26 03:43:55] [    4.379108] init: - preinit -
      [2024-05-26 03:43:55] [    4.395463] procd: Failed to open hotplug socket: Function not implemented
      [2024-05-26 03:43:55] /dev/by-name/UDISK already format by ext4
      [2024-05-26 03:43:55] /dev/by-name/rootfs_data already format by ext4
      [2024-05-26 03:43:55] [    4.568515] mount_root: mounting /dev/root
      [2024-05-26 03:43:55] [    4.576420] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
      [2024-05-26 03:43:55] [    4.585690] mount_root: loading kmods from internal overlay
      [2024-05-26 03:43:55] [    4.667798] block: attempting to load /etc/config/fstab
      [2024-05-26 03:43:55] e2fsck 1.46.4 (18-Aug-2021)
      [2024-05-26 03:43:55] /dev/by-name/UDISK: recovering journal
      [2024-05-26 03:43:55] /dev/by-name/UDISK: clean, 11/1929536 files, 165161/7712727 blocks
      [2024-05-26 03:43:55] [    4.916871] procd: - early -
      [2024-05-26 03:43:55] [    4.923109] procd: Failed to open hotplug socket: Function not implemented
      [2024-05-26 03:43:55] [    4.936548] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
      [2024-05-26 03:43:55] [    4.950793] CPU0: stopping
      [2024-05-26 03:43:55] [    4.956613] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #38
      [2024-05-26 03:43:55] [    4.969011] Hardware name: Generic DT based system
      [2024-05-26 03:43:55] [    4.977357] [<c010de4c>] (unwind_backtrace) from [<c010a5f4>] (show_stack+0x10/0x14)
      [2024-05-26 03:43:55] [    4.991904] [<c010a5f4>] (show_stack) from [<c0527688>] (dump_stack+0x88/0xa4)
      [2024-05-26 03:43:55] [    5.005850] [<c0527688>] (dump_stack) from [<c010c234>] (handle_IPI+0xe4/0x180)
      [2024-05-26 03:43:55] [    5.020059] [<c010c234>] (handle_IPI) from [<c033c13c>] (gic_handle_irq+0x70/0x78)
      [2024-05-26 03:43:55] [    5.034743] [<c033c13c>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [2024-05-26 03:43:55] [    5.049528] Exception stack(0xc0901f40 to 0xc0901f88)
      [2024-05-26 03:43:55] [    5.058473] 1f40: 00001270 c76b7fb4 00000000 c0114740 00000001 c0900000 c0903de8 c0903e24
      [2024-05-26 03:43:55] [    5.074150] 1f60: c0940000 c77ff540 c08210c0 00000000 c0a467d0 c0901f90 c0107f48 c0107f38
      [2024-05-26 03:43:55] [    5.089887] 1f80: 60000013 ffffffff
      [2024-05-26 03:43:55] [    5.097040] [<c01021cc>] (__irq_svc) from [<c0107f38>] (arch_cpu_idle+0x1c/0x38)
      [2024-05-26 03:43:55] [    5.111825] [<c0107f38>] (arch_cpu_idle) from [<c013d3dc>] (do_idle+0xd4/0x128)
      [2024-05-26 03:43:55] [    5.126557] [<c013d3dc>] (do_idle) from [<c013d6c8>] (cpu_startup_entry+0x18/0x20)
      [2024-05-26 03:43:55] [    5.141744] [<c013d6c8>] (cpu_startup_entry) from [<c0800c74>] (start_kernel+0x358/0x3e8)
      [2024-05-26 03:43:55] [    5.157680] Rebooting in 5 seconds..
      kennel 设备树如下:
      /dts-v1/;
      /memreserve/ 0x41900000 0x00100000;
      /* DSP used 1MB */
      /* /memreserve/ 0x42000000 0x00100000; */
      #include "sun8iw20p1.dtsi"
      	model = "sun8iw20";
      	reg_vdd_cpu: vdd-cpu {
      		regulator-name = "vdd_cpu";
      		regulator-always-on;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      	led {
      		compatible = "gpio-leds";
      		led1 {
      			label = "led1";
      			gpios = <&pio PG 13 GPIO_ACTIVE_LOW>;
      			linux,default-trigger = "heartbeat";
      			default-state = "on";
      &cpu0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		allwinner,pull = <1>;
      		function = "sdc0";
      		drive-strength = <30>;
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      		function = "gpio_in";
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		drive-strength = <10>;
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      			function = "sdc1";
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	wlan_pins_a:wlan@0 {
      		pins = "PG11";
      		function = "clk_fanout1";
      	lvds0_pins_a: lvds0@0 {
      		allwinner,pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		allwinner,function = "lvds0";
      		allwinner,pull = <0>;
      	lvds0_pins_b: lvds0@1 {
      		allwinner,muxsel = <7>;
      		pins = "PE2", "PE3";
      		function = "uart0";
      		bias-pull-up;
      		function = "uart1";
      		bias-pull-up;
      		function = "uart2";
      		bias-pull-up;
      	uart3_pins_a: uart3_pins@0 {  /* For t113_evb */
      		pins = "PG8", "PG9";
      		// pins = "PB6", "PB7";
      		function = "uart3";
      		bias-pull-up;
      	uart3_pins_b: uart3_pins@1 {  /* For t113_evb */
      	twi0_pins_a: twi0@0 {
      		pins = "PB2", "PB3";
      		function = "twi0";
      	twi0_pins_b: twi0@1 {
      	twi1_pins_a: twi1@0 {
      		pins = "PE0", "PE1";
      		function = "twi1";
      	twi1_pins_b: twi1@1 {
      	twi2_pins_a: twi2@0 {
      		pins = "PE12", "PE13";
      		function = "twi2";
      	twi2_pins_b: twi2@1 {
      	twi3_pins_a: twi3@0 {
      		/* pins = "PE16", "PE17"; */
      		/* pins = "PG10", "PG11"; */
      		/*pins = "PB6", "PB7";*/
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      	s_cir0_pins_a: s_cir0@0 {
      		pins = "PB1";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir0@1 {
      		pins = "PB1";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      	dmic_pins_a: dmic@0 {
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		pins = "PB29", "PB23", "PB24",
      		       "PB25", "PB26", "PB27", "PB28",
      		       "PB22";
      		function = "i2s0";
      		bias-disable;
      		       "PB22";
      		bias-disable;
      	daudio1_pins_a: daudio1@0 {
      		/* MCLK, LRCK, BCLK */
      		pins = "PG12", "PG13";
      		function = "i2s1";
      		bias-disable;
      	daudio1_pins_b: daudio1@1 {
      		/* DIN0 */
      		pins = "PG14";
      		function = "i2s1_din";
      		bias-disable;
      	daudio1_pins_c: daudio1@2 {
      		/* DOUT0 */
      		pins = "PG15";
      		function = "i2s1_dout";
      		bias-disable;
      	daudio1_pins_d: daudio1_sleep@0 {
      		pins = "PG12", "PG13", "PG14", "PG15";
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		pins = "PB7", "PB6", "PB5";
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2@1 {
      		/* I2S_PIN: DIN0 */
      		pins = "PB3";
      		function = "i2s2_din";
      		bias-disable;
      	daudio2_pins_c: daudio2@2 {
      		/* I2S_PIN: DOUT0 */
      		pins = "PB4";
      		function = "i2s2_dout";
      		bias-disable;
      		pins = "PB7", "PB6", "PB5", "PB4", "PB3";
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PG18";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PG18";
      		bias-disable;
      	gmac0_pins_a: gmac@0 {
      		allwinner,pins = "PE0", "PE1", "PE2", "PE3", "PE4",
      				 "PE5", "PE6", "PE7","PE8", "PE9";
      		allwinner,function = "gmac0";
      		allwinner,muxsel = <8>;
      		allwinner,drive = <1>;
      	gmac0_pins_b: gmac@1 {
      		allwinner,function = "gpio_in";
      		allwinner,muxsel = <0>;
      	spi0_pins_a: spi0@0 {
      		pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
      		function = "spi0";
      	spi0_pins_b: spi0@1 {
      		pins = "PC3";
      		function = "spi0";
      		bias-pull-up;   /* only CS should be pulled up */
      	spi0_pins_c: spi0@2 {
      	spi1_pins_a: spi1@0 {
      		pins = "PB11", "PB10", "PB9","PB8", "PB0"; /*clk mosi miso hold wp*/
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		pins = "PB12";
      		function = "spi1";
      		bias-pull-up;   // only CS should be pulled up
      	spi1_pins_c: spi1@2 {
      		allwinner,pins = "PB0", "PB8", "PB9", "PB10","PB11", "PB12";
      	pwm3_pin_a: pwm3@0 {
      		pins = "PB0";
      		function = "pwm3";
      		bias-pull-up;
      	pwm3_pin_b: pwm3@1 {
      		pins = "PB0";
      	pwm7_pin_a: pwm7@0 {
      		pins = "PD22";
      		function = "pwm7";
      		bias-pull-up;
      	pwm7_pin_b: pwm7@1 {
      		pins = "PD22";
      	ledc_pins_a: ledc@0 {
      		pins = "PF2";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PF2";
      	rgb24_pins_a: rgb24@0 {
      		allwinner,pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      			"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      			"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      		allwinner,pname = "lcdd0", "lcdd1", "lcdd2", "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7", \
      			"lcdd8", "lcdd9", "lcdd10", "lcdd11", "lcdd12", "lcdd13", "lcdd14", "lcdd15", \
      			"lcdd16", "lcdd17", "lcdd18", "lcdd19", "lcdd20", "lcdd21", "lcdd22", "lcdd23", \
      			"lcdclk", "lcdde", "lcdhsync", "lcdvsync";
      		allwinner,function = "lcd0";
      	rgb24_pins_b: rgb24@1 {
      	dsi4lane_pins_a: dsi4lane@0 {
              allwinner,function = "dsi4lane";
              allwinner,muxsel = <4>;
      	dsi4lane_pins_b: dsi4lane@1 {
              allwinner,function = "dsi4lane_suspend";
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      	status = "disabled";
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart2 {
              pinctrl-0 = <&uart2_pins_a>;
              pinctrl-1 = <&uart2_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_b>;
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	no-sdio;
      	no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-power-save-mode;
      	sunxi-dis-signal-vol-sw;
      	mmc-bootpart-noacc;
      	max-frequency = <150000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &sdc0 {
      	bus-width = <4>;
      	//cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
      	/*non-removable;*/
      	broken-cd;
      	/*cd-inverted*/
      	/*data3-detect;*/
      	cd-used-24M;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	/*sunxi-dis-signal-vol-sw;*/
      	ctl-spec-caps = <0x8>;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	/*sunxi-power-save-mode;*/
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      &twi0 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi0_pins_a>;
      	pinctrl-1 = <&twi0_pins_b>;
      	twi_drv_used = <0>;
      	dmas = <&dma 43>, <&dma 43>;
      	dma-names = "tx", "rx";
      	rx8025: rx8025t@32 {
      		compatible = "rx8025t";
      		reg = <0x32>;
      &twi1 {
      	pinctrl-0 = <&twi1_pins_a>;
      	pinctrl-1 = <&twi1_pins_b>;
      	ctp@5d {
      		device_type = "ctp";
      		reg = <0x5d>;
      		ctp_name = "gt9xxnew_ts";
      		ctp_twi_id = <0x1>;
      		ctp_twi_addr = <0x5d>;
      		ctp_screen_max_x = <0x1E0>;
      		ctp_screen_max_y = <0x1E0>;
      		ctp_revert_x_flag = <0x0>;
      		ctp_revert_y_flag = <0x0>;
      		ctp_int_port = <&pio PE 5 GPIO_ACTIVE_HIGH>;
      		ctp_wakeup = <&pio PE 4 GPIO_ACTIVE_HIGH>;
      &twi2 {
      	pinctrl-0 = <&twi2_pins_a>;
      	pinctrl-1 = <&twi2_pins_b>;
      	dmas = <&dma 45>, <&dma 45>;
      &twi3 {
      	pinctrl-0 = <&twi3_pins_a>;
      	pinctrl-1 = <&twi3_pins_b>;
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
      	spi0_cs_bitmap = <1>;
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<80000000>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="disabled";
      &spi1 {
      	pinctrl-1 = <&spi1_pins_c>;
      	spi1_cs_number = <1>;
              spi1_cs_bitmap = <1>;
      	spi_board1@0 {
      		device_type = "spi_board1";
      		compatible = "rohm,dh2228fv";
      		reg = <0x0>;
      		spi-rx-bus-width = <0x4>;
      		spi-tx-bus-width = <0x4>;
      &ledc {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <32>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <450>;
      	t0h_ns = <400>;
      	t0l_ns = <850>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      &s_cir0 {
      	pinctrl-names = "default";
      	pinctrl-0 = <&s_cir0_pins_a>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      &gmac0 {
      	pinctrl-0 = <&gmac0_pins_a>;
      	pinctrl-1 = <&gmac0_pins_b>;
      	phy-mode = "rmii";
      	use_ephy25m = <0>;
      	tx-delay = <3>;
      	rx-delay = <0>;
      	phy-rst = <&pio PE 10 GPIO_ACTIVE_HIGH>;
      &soc {
      	platform@45000004 {
      		reg = <0x0 0x45000004 0x0 0x0>;
      		eraseflag   = <1>;
      		next_work   = <3>;
      		debug_mode  = <8>;
      	target@45000008 {
      		reg = <0x0 0x45000008 0x0 0x0>;
      		boot_clock = <1008>;	/*CPU boot frequency, Unit: MHz*/
      		storage_type = <0xffffffff>; /*boot medium, 0-nand, 1-card0, 2-card2, -1(defualt)auto scan*/
      		burn_key = <0>;		/*1:support burn key; 0:not support burn key*/
      		dragonboard_test = <0>;	/*1:support card boot dragonboard; 0:not support card boot dragonboard*/
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_a>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc2_pins_a>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      		chip_en;
      		power_en;
      		pinctrl-0 = <&wlan_pins_a>;
      		wlan: wlan@0 {
      			clock-names = "32k-fanout1";
      			wlan_busnum    = <0x1>;
      			/*interrupt-parent = <&pio>;
      			wakeup-source;
      		bt: bt@0 {
      			/*bt_power_num = <0x01>;*/
      			/*bt_io_vol = <3300000>;*/
      			/*bt_power_vol = <330000>;*/
      			bt_rst_n      = <&pio PG 15 GPIO_ACTIVE_LOW>;
      			status        = "okay";
      	btlpm: btlpm@0 {
      		uart_index  = <0x1>;
      		bt_wake     = <&pio PG 13 GPIO_ACTIVE_HIGH>;
      		bt_hostwake = <&pio PG 14 GPIO_ACTIVE_HIGH>;
      &vind0 {
      	csi_top = <378000000>;
      	csi_isp = <327000000>;
      	status = "disabled"; /* enable twi and ver1 spi-nand max freq 30M */
      	actuator0: actuator@5809450 {
      		device_type = "actuator0";
      		actuator0_slave = <0x18>;
      		actuator0_af_pwdn = <>;
      	flash0: flash@5809460 {
      		device_type = "flash0";
      		flash0_type = <2>;
      		flash0_en = <>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		flash0_flvdd_vol = <>;
      		device_id = <0>;
      	sensor0: sensor@5809470 {
      		device_type = "sensor0";
      		sensor0_mname = "ov5640";
      		sensor0_twi_cci_id = <2>;
      		sensor0_twi_addr = <0x78>;
      		sensor0_mclk_id = <0>;
      		sensor0_pos = "rear";
      		sensor0_isp_used = <0>;
      		sensor0_fmt = <0>;
      		sensor0_stby_mode = <0>;
      		sensor0_vflip = <0>;
      		sensor0_hflip = <0>;
      		sensor0_iovdd-supply = <>;
      		sensor0_iovdd_vol = <>;
      		sensor0_avdd-supply = <>;
      		sensor0_avdd_vol = <>;
      		sensor0_dvdd-supply = <>;
      		sensor0_dvdd_vol = <>;
      		sensor0_power_en = <>;
      		sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
      		sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
      		sensor0_sm_vs = <>;
      		flash_handle = <&flash0>;
      		act_handle = <&actuator0>;
      		device_id = <0>;
      	sensor1:sensor@5809480 {
      		device_type = "sensor1";
      		sensor1_mname = "ov5647";
      		sensor1_twi_cci_id = <3>;
      		sensor1_twi_addr = <0x6c>;
      		sensor1_mclk_id = <1>;
      		sensor1_pos = "front";
      		sensor1_isp_used = <0>;
      		sensor1_fmt = <0>;
      		sensor1_stby_mode = <0>;
      		sensor1_vflip = <0>;
      		sensor1_hflip = <0>;
      		sensor1_iovdd-supply = <>;
      		sensor1_iovdd_vol = <>;
      		sensor1_avdd-supply = <>;
      		sensor1_avdd_vol = <>;
      		sensor1_dvdd-supply = <>;
      		sensor1_dvdd_vol = <>;
      		sensor1_power_en = <>;
      	vinc0:vinc@5809000 {
      		vinc0_csi_sel = <0>;
      		vinc0_mipi_sel = <0xff>;
      		vinc0_isp_sel = <0>;
      		vinc0_isp_tx_ch = <0>;
      		vinc0_tdm_rx_sel = <0xff>;
      		vinc0_rear_sensor_sel = <0>;
      		vinc0_front_sensor_sel = <0>;
      		vinc0_sensor_list = <0>;
      	vinc1:vinc@5809200 {
      		vinc1_csi_sel = <0>;
      		vinc1_mipi_sel = <0xff>;
      		vinc1_isp_sel = <0>;
      		vinc1_isp_tx_ch = <1>;
      		vinc1_tdm_rx_sel = <0xff>;
      		vinc1_rear_sensor_sel = <0>;
      		vinc1_front_sensor_sel = <0>;
      		vinc1_sensor_list = <0>;
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      &disp {
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      #if 0
      &disp {
      	fb0_width                = <1024>;
      	fb0_height               = <600>;
      	/*VCC-LCD*/
      	/*dc1sw-supply = <&reg_dc1sw>;*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;tv configuration
      ;interface          (interface type,1<->cvbs,2<->YPBPR,4<->SVIDEO)
      ;dac_type           (0<->composite,1<->luma,2<->chroma,3<->reserved,4<->y/green,
      ;                    5<->u/pb/blue,6<->v/pr/red)
      ;dac_src            (dac no,support dac_src0~dac_src3,dac num max is 4)
      ;NOTE:              tv0,tv1 can not use the same dac_src.
      &tv0 {
      	interface       = <1>;
      	dac_type0       = <0>;
      	dac_src0        = <0>;
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_backlight       = <50>;
      	lcd_if              = <3>;
      	lcd_x               = <1024>;
      	lcd_y               = <600>;
      	lcd_width           = <150>;
      	lcd_height          = <94>;
      	lcd_dclk_freq       = <52>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_pol         = <1>;
      	lcd_pwm_max_limit   = <255>;
      	lcd_hbp             = <160>;
      	lcd_ht              = <1344>;
      	lcd_hspw            = <60>;
      	lcd_vbp             = <23>;
      	lcd_vt              = <638>;
      	lcd_vspw            = <10>;
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <0>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <1>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	pinctrl-0 = <&lvds0_pins_a>;
      	pinctrl-1 = <&lvds0_pins_b>;
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_driver_name     = "he0801a068";
      	lcd_if              = <4>;
      	lcd_x               = <800>;
      	lcd_y               = <1280>;
      	lcd_width           = <800>;
      	lcd_height          = <1280>;
      	lcd_dclk_freq       = <78>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_pol         = <1>;
      	lcd_hbp             = <149>;
      	lcd_ht              = <978>;
      	lcd_hspw            = <16>;
      	lcd_vbp             = <7>;
      	lcd_vt              = <1329>;
      	lcd_vspw            = <5>;
      	lcd_dsi_lane        = <4>;
      	lcd_dsi_if          = <0>;
      	lcd_dsi_format      = <0>;
      	lcd_dsi_te          = <0>;
      	lcd_frm             = <0>;
      	lcd_io_phase        = <0>;
      	lcd_gamma_en        = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	smart_color         = <90>;
      	lcd_gpio_0 = <&pio PG 13 GPIO_ACTIVE_HIGH>;
      &lcd0 {
      	/* part 1 */
      	lcd_used            = <1>;
      	lcd_driver_name     = "st7701_86";
      	lcd_backlight	    = <255>;
      	/* part 2 */
      	lcd_if = <0>;
      	lcd_hv_if = <0>;
      	/* part 3 */
      	lcd_x               = <480>;
      	lcd_y               = <480>;
      	lcd_width           = <71>;
      	lcd_height          = <71>;
      	lcd_dclk_freq       = <24>;
      	lcd_hbp             = <20>;
      	lcd_ht              = <526>;
      	lcd_hspw            = <6>;
      	lcd_vbp             = <10>;
      	lcd_vt              = <510>;
      	lcd_vspw            = <4>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_freq        = <5000>;
      	lcd_pwm_pol         = <0>;
      	/* part 5 */
      	lcd_frm = <1>;
      	lcd_io_phase = <0x0000>;
      	lcd_gamma_en = <0>;
      	lcd_cmap_en = <0>;
      	// reset
      	lcd_gpio_0 = <&pio PB 4 GPIO_ACTIVE_HIGH>;
      	// cs
      	lcd_gpio_1 = <&pio PB 7 GPIO_ACTIVE_HIGH>;
      	// sda
      	lcd_gpio_2 = <&pio PB 5 GPIO_ACTIVE_HIGH>;
      	// sck
      	lcd_gpio_3 = <&pio PB 6 GPIO_ACTIVE_HIGH>;
      	/* part 6 */
      	lcd_power = "vcc-lcd";
      	lcd_pin_power = "vcc-pd";
      	pinctrl-0 = <&rgb18_pins_a>;
      	pinctrl-1 = <&rgb18_pins_b>;
      tvd configuration
                             mode,mean enable)
      &tvd {
      	tvd_sw          = <1>;
      	tvd_interface   = <0>;
      	tvd_format      = <0>;
      	tvd_system      = <1>;
      	tvd_row         = <1>;
      	tvd_column      = <1>;
      	tvd_channel0_en = <1>;
      	tvd_channel1_en = <0>;
      	tvd_channel2_en = <0>;
      	tvd_channel3_en = <0>;
      	/*tvd_power0      = "dc1sw"*/
      	/*tvd_power1      = "eldo3"*/
      &tvd0 {
      &hdmi {
      	hdmi_used = <1>;
      	hdmi_power_cnt = <0>;
      	hdmi_hdcp_enable = <1>;
      	hdmi_hdcp22_enable = <0>;
      	hdmi_cec_support = <1>;
      	hdmi_cec_super_standby = <0>;
      	ddc_en_io_ctrl = <0>;
      	power_io_ctrl = <0>;
      /* Audio Driver modules */
      &codec {
      	mic1gain 		= <0x1F>;
      	mic2gain 		= <0x1F>;
      	mic3gain 		= <0x1F>;
      	adcdrc_cfg		= <0x0>;
      	adchpf_cfg		= <0x1>;
      	dacdrc_cfg		= <0x0>;
      	dachpf_cfg		= <0x0>;
      	/* Volume about */
      	digital_vol 	= <0x00>;
      	lineout_vol 	= <0x1a>;
      	headphonegain	= <0x03>;
      	/* Pa enabled about */
      	pa_level 		= <0x01>;
      	pa_pwr_level 	= <0x01>;
      	pa_msleep_time 	= <0x78>;
      	/* gpio-spk	= <&pio PE 11 GPIO_ACTIVE_LOW>; */
      	/* CMA config about */
      	playback_cma	= <128>;
      	capture_cma	= <256>;
      	/* regulator about */
      &sndcodec {
      	hp_detect_case	= <0x00>;
      	jack_enable		= <0x01>;
      &dummy_cpudai {
      	status			= "okay";
      &dmic {
      &dmic_codec {
      &sounddmic {
       * tdm_config		0 --> pcm
       *			1 --> i2s
       * mclk_div		0 --> not output
       *			1 --> HDMI audio type
      &daudio0 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tdm_config 	= <0x01>;
      	sign_extend 	= <0x00>;
      	msb_lsb_first 	= <0x00>;
      	pcm_lrck_period = <0x80>;
      	slot_width_select = <0x20>;
      	pinctrl_used	= <0x0>;
      &sounddaudio0 {
      		/* sound-dai = <&ac108>; */
      &daudio1 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	pinctrl-0       = <&daudio1_pins_a &daudio1_pins_b &daudio1_pins_c>;
      	pinctrl-1       = <&daudio1_pins_d>;
      	pinctrl_used	= <0x1>;
      &sounddaudio1 {
      &daudio2 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      &hdmiaudio {
      &sounddaudio2 {
      &spdif {
      &soundspdif {
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x1>;
      	usb_detect_type = <0x0>;
      	//usb_detect_mode = <0>;
      	//usb_id_gpio = <&pio PB 6 GPIO_ACTIVE_HIGH>;
      	//enable-active-high;
      	//usb_det_vbus_gpio = <&pio PB 2 GPIO_ACTIVE_HIGH>;
      	usb_wakeup_suspend = <0>;
      	usb_serial_unique = <0>;
      	rndis_wceis = <1>;
      &ehci0 {
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
      	usb_port_type = <0x01>;
      	sb_detect_type = <0x1>;
      	usb_regulator_io = "nocare";
      &ehci1 {
      &ohci1 {
      &pwm3 {
      	pinctrl-0 = <&pwm3_pin_a>;
      	pinctrl-1 = <&pwm3_pin_b>;
      &pwm7 {
      	pinctrl-0 = <&pwm7_pin_a>;
      	pinctrl-1 = <&pwm7_pin_b>;
      &gpadc {
      	channel_num = <1>;
      	channel_select = <0x1>;
      	channel_data_select = <0>;
      	channel_compare_select = <0x1>;
      	channel_cld_select = <0x1>;
      	channel_chd_select = <0>;
      	key_cnt = <5>;
      	key0_vol = <210>;
      	key0_val = <115>;
      	key1_vol = <410>;
      	key1_val = <114>;
      	key2_vol = <590>;
      	key2_val = <119>;
      	key3_vol = <750>;
      	key3_val = <373>;
      	key4_vol = <880>;
      	key4_val = <28>;
      &rtp {
      	allwinner,ts-attached;
