    编译Tiny 4.0镜像给v851se启动卡死在DRAM
      lmmuyu LV 4 最后由 q1215200171 编辑
      [278][pmu]: bus read error
      [280]set pll start
      [282]periph0 has been enabled
      [285]set pll end
      [287]board init ok
      [289]DRAM use internal ZQ!!
      [292]ZQ value = 0x2e
      [294]chip id check OK
      [296]POWER SETTING ERROR!
      [299]trefi:7.8ms
      [301][AUTO DEBUG] single rank and full DQ!
      [305]trefi:7.8ms
      [307][AUTO DEBUG] rank 0 row = 13
      [311][AUTO DEBUG] rank 0 bank = 4
      [314][AUTO DEBUG] rank 0 page size = 2 KB
      [318]DRAM BOOT DRIVE INFO: V0.16
      [321]DRAM CLK = 528 MHz
      [324]DRAM Type = 2 (2:DDR2,3:DDR3)
      [327]DRAMC read ODT  off.
      [330]DRAM ODT off.
      [332]DRAM SIZE =64 M
      [334]dram_tpr4:0x0
      [341]DRAM simple test OK.
      [343]rtc standby flag is 0x0, super standby flag is 0x0
      [349]dram size =64
      [351]audio:avcc calibration
      [354]card no is 0
      [355]sdcard 0 line count 4
      [358][mmc]: mmc driver ver 2022-10-25 19:07
      [367][mmc]: Wrong media type 0x0
      [370][mmc]: ***Try SD card 0***
      [391][mmc]: HSSDR52/SDR25 4 bit
      [394][mmc]: 50000000 Hz
      [396][mmc]: 30436 MB
      [398][mmc]: ***SD/MMC 0 init OK!!!***
      [485]Loading boot-pkg Succeed(index=0).
      [489]Entry_name        = optee
      [492]Entry_name        = u-boot
      [501]Entry_name        = dtb
      [504]mmc not para
      [506]Jump to second Boot.
      E/TC:0 0 platform_standby_fdt_parse:133 no pmu node
      E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      U-Boot 2018.07-gb807adc-dirty (May 27 2024 - 23:20:22 +0800) Allwinner Technology
      [00.584]CPU:   Allwinner Family
      [00.587]Model: sun8iw21
      I2C:   [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
      ready
      [00.647]DRAM:
