    D1S上面如何跑melis?
    5
    7
    6437
    • G
      geniusgogo LV 4 最后由 编辑
      前天经过大佬指点已经顺利的将melis跑在D1上了。
      现在又切换到D1S上来跑,发现遇到类似问题,跑起来就挂了。
      根据当时D1的修改配置方法,在F133的project配置里已经是类似D1上面的配置修改了,但是不知道为啥,还会起来就挂。
      下面是启动日志:
      [142]HELLO! BOOT0 is starting!
      [144]BOOT0 commit : 889f614
      sbi2ekernel
      |                   /'\_/`\       (_ )  _                       /'_  )    /'_ `\   /' _`\                     |
      |                   |     |   __   | | (_)  ___  ______  _   _ (_)_) |   ( (_) |   | ( ) |                    |
      |                   | (_) | /'__`\ | | | |/',__)(______)( ) ( ) _(_ <     \__, |   | | | |                    |
      |                   | | | |(  ___/ | | | |\__, \        | \_/ |( )_) | _     | | _ | (_) |                    |
      |                   (_) (_)`\____)(___)(_)(____/        `\___/'`\____)(_)    (_)(_)`\___/'                    |
      |version : V3.9.0        |
      |commitid: 976499a346a3d5d6d80047f3844d1d5c3e37ac55                                                           |
      |sunxiver: 30800        |
      |timever : Thu, 04 Nov 2021 20:14:43 +0800        |
      |compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104)                                           |
      |optimal : -Os -g -gdwarf-2 -gstrict-dwarf        |
      |linker  : GNU ld (GNU Binutils) 2.32        |
      |newlibc : 3.0.0        |
      |author  : zhouji        |
      [DBG]: [__mount_parts:0273]:                                classname=DMS
      [DBG]: [__mount_parts:0274]:                                devname=dms01
      [DBG]: [__mount_parts:0301]:                                find last lun.
      [DBG]: [__mount_parts:0331]:                                nPart = 1.
      [DBG]: [__mount_parts:0460]:                                dmsPart: "DMS\dms010" is linked to symbel "B".
      [ERR]: [esFSYS_pread:0318]:                                 fs fatal err
      [DBG]: [esFSYS_mntfs:0317]:                                 devfs,mount on B.
      [DBG]: [kservice_maintask:0834]:                            partition [B] plug in..
      [DBG]: [__mount_parts:0273]:                                classname=DISK
      [DBG]: [__mount_parts:0274]:                                devname=RAMDISK
      [DBG]: [__mount_parts:0460]:                                rawpart: "DISK\RAMDISK0" is linked to symbel "C".
      [ERR]: [esFSYS_mntfs:0298]:                                 identify the filesystem failure.
      [ERR]: [޳cheduler startup
      [DBG]: [__mount_parts:0274]:                                devname=ROOTFS
      [DBG]: [__mount_parts:0460]:                                rawpart: "DISK\ROOTFS0" is linked to symbel "D".
      [DBG]: [esFSYS_mntfs:0317]:                                 minfs,mount on D.
      [DBG]: [kservice_maintask:0834]:                            partition [D] plug in..
      [DBG]: [melis_udisk_part_check:0553]:                       melis_udisk_part_check 553 copy udisk_buff
      [DBG]: [__mount_parts:0274]:                                devname=UDISK
      [DBG]: [__mount_parts:0423]:                                rawpart: "DISK\UDISK0" is linked to symbel "E".
      [ERR]: [__mount_parts:0501]:                                mount E failure.
      SDC:hal_sdc_create host:0x401b65d8 id:0
      [ERR] SDC:name sdc0_d1,port 6,port_num 0,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name sdc0_d0,port 6,port_num 1,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name sdc0_clk,port 6,port_num 2,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name sdc0_cmd,port 6,port_num 3,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name sdc0_d3,port 6,port_num 4,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name sdc0_d2,port 6,port_num 5,mul_sel 2, pull 1, drv_level 1
      SDC:Not implement __mci_restore_io,793
      SDC:Not imp hal_sdc_init,2206
      SDC:hal_sdc_init,2239 no imp
      SDC:hal_sdc_init,2248 no imp
      SDC:SDC Host Capability:0x3820f Ocr avail:0x3f0000
      SDC:Not implement __mci_hold_io,778
      SDC:SDC cd_mode:2 present_val:0
      SDC:SDC id:0 dma_use:1 present:0
       driver version SD/MMC/SDIO Host Controller Driver(v0.28 2021-08-24 16:50) init ok.
      host_id =0!
      [ERR]: [hal_ths_init:0094]:                                 0x2009404, 0x2009400, 0x2009430, 0x2009408
      key name:thermal_sensor key size:64 key offset:20
      thermal_sensor:
      42 01 bb 98 0e b0 9d 01
      the cir_master_init success
      phy_vbase : 0x4200800, usbc_no : 1, efuse : 0x19db00e
      [usb_new_phy_print][79] reg[DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init!
       0x1c : 0x4
      [usb_new_phy_print][80] reg [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init!
      0x30 : 0xcb
      [usb_new_phy_print][81] reg 0x60 : 0x22b8
      [usb_new_phy_print][82] reg 0x40 : 0x8c
      [usb_new_phy_print][79] reg 0x1c : 0x0
      [usb_new_phy_print][80] reg 0x30 : 0x18b
      [usb_new_phy_print][82] reg 0x40 : 0x7c
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\slib.mod.
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\display.mod.
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\mixture.mod.
      [DBG]: [layer_request:0689]:                                requested: ch:0, id:0   disp_mgr.req_layer_cnt = 1
      [DBG]: [mod2drv_layerinfo:0366]:                            lbc_mode = 0
      [ERR]: [open_lcd_backlight:0610]:                           get backlight err,default to 100
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\charset.mod.
      msh />Execute startup script begin..............
      	 install mod para num [2]: insmod d:\mod\orange.mod
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\orange.mod.
      Mod:d:\mod\orange.mod Installed!, mod id=120
      	 install mod para num [2]: insmod d:\apps\desktop.mod
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\apps\desktop.mod.
      [DBG]: [DESKTOP_MOpen:0078]:                                DESKTOP_MOpen.
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\apps\init.axf.
      Mod:d:\apps\desktop.mod Installed!, mod id=127
      ...............Execute startup script end
      [DBG]: [msg_srv_init_key_channel:0150]:                     emit_ctr.h_keyGraber=0x40d6d1a0
      [DBG]: [msg_srv_init_key_channel:0161]:                     LdevID=0
      [DBG]: [application_init_process:0836]:                     &           application_init_process enter!             &
      dsk_reg_read_config_file 571 e:\setting.bin eLIBs_fopen fail
      dsk_reg_init_para 797 config not ok, format e:
      [DBG]: [esFSYS_mntfs:0317]:                                 fat,mount on E.
      [DBG]: [kservice_maintask:0834]:                            partition [E] plug in..
      [DBG]: [application_init_process:0854]:                     application_init_process 854 before live_init
      [DBG]: [live_init:0040]:                                    ~~~~~~~~~~~~~~before dsk_set_isn_charset~~~~~~~~~~~
      [DBG]: [alsa_open_pcm:0218]:                                open pcm! card:[audiocodec], pcmFlag:[1](0-cap;1-play)
      [SND_ERR][ksnd_pcm_prepare:2005]unsupport state transform.
      [DBG]: [dsk_display_set_lcd_brightness:0297]:               setting lcd_bright=176
      [DBG]: [application_init_process:0862]:                     application_init_process 862 before gscene_bgd_init
      [DBG]: [gscene_bgd_is_file_exist:0620]:                     file is exist:d:\res\bg_default0.jpg
      [DBG]: [gscene_bgd_init:0130]:                              bgd_com->screen_size.width = 800  bgd_com->screen_size.height = 480  ftype = 1
      [DBG]: [application_init_process:0883]:                     .start device monitor .......................................
      [DBG]: [application_init_process:0891]:                     application_init_process 891 before init_mainwin_create
      [DBG]: [dsk_display_set_lcd_brightness:0297]:               setting lcd_bright=192
      [DBG]: [__hbar_layer_create:0093]:                          hbar fb 800 46 gui_dir=0
      [DBG]: [__hbar_layer_create:0094]:                          hbar src 0 0 800 46
      [DBG]: [__hbar_layer_create:0095]:                          hbar scn 0 0 800 46
      [DBG]: [reset_headbar_data:0273]:                           xxxxxx para->data.volume = 30
      [DBG]: [reset_headbar_data:0277]:                           xxxxxx bright = 11
      [ERR]: [esPINS_ReadPinData:0640]:                           pin handle is invalid!
      [DBG]: [application_init_process:0897]:                     application_init_process 897 before _process_init
      [DBG]: [applet_info_manager_load_dir:0307]:                 find dir file d:\apps\phy_vbase : 0x4101800, usbc_no : 0, efuse : 0x19db00e
      desktop\app_root.desktop!
      [DBG]: [applet_info_manager_load_file:0267]:                filename = d:\apps\desktop\app_root.desktop len=124
      [DBG]: [__activity_load_common:0395]:                       load application application://app_root.
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\apps\app_root.axf.
      card_detect removed sdmmc_test->card_id=0
      [WRN] SD:mmc_card_open card not exit! id:0
      card open fail
      [DBG]: [app_home_create:0657]:                              ********  enter multi screen home application  **************
      [DBG]: [gscene_bgd_set_status_show:0170]:                   bkpic: d:\res\bg_default0.jpg.
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\vcoder.mod.
      [ERR]: [Mod_Display_MIoctrl:1771]:                          no this CMD in display mod
      [DBG]: [dsktop_scene_get_cur_app:0664]:                     g_last_desk_app_index:0
      [DBG]: [desktop_scene_create:0582]:                         width = 800, height= 480
      [DBG]: [desktop_scene_create:0587]:                         cur_desk_app_index:0
      [DBG]: [GUI_LogicLayerRequest:0527]:
        src.w = 800   src.h = 480
      [DBG]: [layer_request:0689]:                                requested: ch:1, id:0   disp_mgr.req_layer_cnt = 1
        src.w = 800   src.h = 46
      [DBG]: [layer_request:0689]:                                requested: ch:1, id:1   disp_mgr.req_layer_cnt = 2
      [DBG]: [app_root_wincreate:4387]:                           root win = 40eff8f8
      [DBG]: [application_init_process:0918]:                     application_init_process 918 before GUI_GetMessageEx
      S 1 条回复 最后回复 回复 引用 分享 0
      • N
        nancheng LV 2 最后由 编辑
        melis源码哪里搞呀
        G 1 条回复 最后回复 回复 引用 分享 0
        • G
          geniusgogo LV 4 @nancheng 最后由 编辑
          @nancheng 得问全志授权要
          N 1 条回复 最后回复 回复 引用 分享 0
          • N
            nancheng LV 2 @geniusgogo 最后由 编辑
            @geniusgogo 全志授权怎么整啊,我看官网有个什么NDA认证,但是那是针对公司的,,个人想弄,有办法吗
            • R
              ricky LV 6 最后由 编辑
              买个D1S的开发板就可以拿到melis了
              W 1 条回复 最后回复 回复 引用 分享 0
                weishg LV 1 @ricky 最后由 编辑
                @ricky 开发板都是配linux系统的,有没有支持melis的开发板推荐
                  soso90 LV 7 @geniusgogo 最后由 编辑
                  @geniusgogo melis默认支持的屏幕是什么屏幕,还有触摸支持是啥芯片。刚看到这个代码,还没发现这部分~~
