    使用tina linux镜像文件烧录emmc一直失败,麻烦大佬帮看看是什么原因
    • K
      kveao LV 3 最后由 编辑
      以下是串口部分提示信息
      [11:43:44.921]Rx:
      [ 108.106618] random: crng init done
      [11:43:49.571]Rx:
      [280]HELLO! BOOT0 is starting!
      [283]BOOT0 commit : 97444f5
      [285]set pll start
      [288]periph0 has been enabled
      [291]set pll end
      [293]board init ok
      [295]rtc[3] value = 0xf6f65006
      [298]the chip id is 0x3
      [300]the chip id
      [11:43:49.594]Rx:
      is 0x3
      [302]the chip id is 0x3
      [305]the chip id is 0x3
      [307]the chip id is 0x3
      [309]chip id check OK
      [312][AUTO DEBUG] two rank and full DQ!
      [316][AUTO DEBUG] DDR3 try success
      [320][AUTO DEBUG] single rank and full DQ!
      [325][AUTO DEBUG] rank 0 row
      [11:43:49.618]Rx:
      = 14
      [328][AUTO DEBUG] rank 0 bank = 8
      [332][AUTO DEBUG] rank 0 page size = 2 KB
      [336]DRAM BOOT DRIVE INFO: V0.171
      [339]DRAM Type = 3 (2:DDR2,3:DDR3)
      [342]DRAMC read ODT off.
      [345]DRAM ODT off.
      [348]DRAM CLK = 774
      [11:43:49.641]Rx:
      MHz
      [350]DRAM SIZE =256 M
      [355]DRAM simple test OK.
      [358]dram size =256
      [361]card no is 0
      [362]sdcard 0 line count 4
      [365][mmc]: mmc driver ver 2020-07-22 11:09
      [11:43:49.666]Rx:
      [375][mmc]: Wrong media type 0x0
      [378][mmc]: Try SD card 0
      [382][mmc]: mmc 0 cmd 8 timeout, err 100
      [386][mmc]: mmc 0 cmd 8 err 100
      [389][mmc]: mmc 0 send if cond failed
      [394][mmc]: mmc 0 cmd 55 timeout, err 100
      [11:43:49.689]Rx:
      [398][mmc]: mmc 0 cmd 55 err 100
      [401][mmc]: mmc 0 send app cmd failed
      [405][mmc]: Try MMC card 0
      [11:43:49.720]Rx:
      [429][mmc]: RMCA OK!
      [431][mmc]: force 25m
      [433][mmc]: mmc 0 bias 0
      [436][mmc]: MMC 5.1
      [438][mmc]: HSSDR52/SDR25 4 bit
      [442][mmc]: 25000000 Hz
      [444][mmc]: 7456 MB
      [446][mmc]: SD/MMC 0 init OK!!!
      [11:43:49.835]Rx:
      [544]Loading boot-pkg Succeed(index=0).
      [548]Entry_name = u-boot
      [554]Entry_name = monitor
      [558]Entry_name = dtb
      [561]tunning data addr:0x430003e
      [11:43:49.856]Rx:
      8
      [565]Jump to second Boot.
      NOTICE: BL3-1: v1.0(debug):3eba4b6
      NOTICE: BL3-1: Built : 10:18:25, 2020-05-21
      NOTICE: BL3-1 commit: 8
      ERROR: Error initializing runtime service tspd_fast
      NOTICE: BL3-1: Prepa
