    请问 D1/D1s有像F1C那种硬件游标(HWC)吗?可以用来做鼠标显示
      memory LV 7 最后由 编辑
      参考:基于RTThread的F1C100s开发(带boot启动+硬件多图层+硬件游标+LVGL+SDIO)
      https://whycan.com/t_3958.html
        memory LV 7 最后由 编辑
        https://www.kernel.org/doc/Documentation/devicetree/bindings/display/sunxi/sun4i-drm.txt
        be0: display-backend@1e60000 {
        	compatible = "allwinner,sun5i-a13-display-backend";
        	reg = <0x01e60000 0x10000>;
        	interrupts = <47>;
        	clocks = <&ahb_gates 44>, <&de_be_clk>,
        		 <&dram_gates 26>;
        	clock-names = "ahb", "mod",
        		      "ram";
        	resets = <&de_be_clk>;
        	ports {
        		#address-cells = <1>;
        		#size-cells = <0>;
        		be0_in: port@0 {
        			#size-cells = <0>;
        			reg = <0>;
        			be0_in_fe0: endpoint@0 {
        				reg = <0>;
        				remote-endpoint = <&fe0_out_be0>;
        		be0_out: port@1 {
        			#size-cells = <0>;
        			reg = <1>;
        			be0_out_tcon0: endpoint@0 {
        				reg = <0>;
        				remote-endpoint = <&tcon0_in_be0>;
