    D1s F133千兆以太网rgmii连接RTL8211F调试不通
    d1s f133 rgmii 以太网 千兆
      Lts52341314 LV 5 最后由 编辑
      D1s F133千兆以太网rgmii连接RTL8211F调试不通,有大神调试过吗
      [205]HELLO! BOOT0 is starting!
      [208]BOOT0 commit : 88480af
      [210]set pll start
      [212]fix vccio detect value:0xc0
      [215]periph0 has been enabled
      [219]set pll end
      [220][pmu]: bus read error
      [223]board init ok
      [224]ZQ value = 0x30
      [226]get_pmu_exist() = -1
      [229]DRAM BOOT DRIVE INFO: V0.33
      [232]DRAM CLK = 528 MHz
      [234]DRAM Type = 2 (2:DDR2,3:DDR3)
      [237]DRAMC read ODT  off.
      [240]DRAM ODT off.
      [242]ddr_efuse_type: 0xa
      [244]DRAM SIZE =64 M
      [246]dram_tpr4:0x0
      [248]PLL_DDR_CTRL_REG:0xf8002b00
      [251]DRAM_CLK_REG:0xc0000000
      [254][TIMING DEBUG] MR2= 0x0
      [258]DRAM simple test OK.
      [261]dram size =64
      [262]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [267]block from 8 to 32
      [347]Check is correct.
      [349]dma 0x301a8 int is not used yet
      [353]dma 0x301a8 int is free, you do not need to free it again
      [358]Entry_name        = opensbi
      [362]Entry_name        = u-boot
      [365]Entry_name        = dtb
      U-Boot 2018.05-g24521d6-dirty (Oct 24 2023 - 17:39:41 +0800) Allwinner Technology
      [00.378]DRAM:  64 MiB
      [00.380]Relocation Offset is: 01ee7000
      [00.385]secure enable bit: 0
      [00.387]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.393]flash init start
      [00.396]workmode = 0,storage type = 0
      [BCC] 0x4025038 = 0x10000000, [DMA] 0x4025088 = 0x000000e5
      [00.443]sunxi-spinand-phy: not detect any munufacture from id table
      [00.450]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.455]sunxi-spinand-phy: get phy info from fdt fail
      defaults:
      mtdids  : nand0=nand
      [00.787]ubi0: attaching mtd4
      [01.180]ubi0: scanning is finished
      [01.190]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [01.195]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [01.201]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [01.207]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [01.214]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [01.219]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [01.226]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [01.234]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [01.242]sunxi flash init ok
      [01.245]line:703 init_clocks
      [01.248]drv_disp_init
      [01.266]unable to map hdmi registers
      [01.269]drv_disp_init finish
      [01.272]boot_gui_init:start
      [01.275]set disp.dev2_output_type fail. using defval=0
      ili9xxx panel init
      ili9xxx panel id 00000000
      [01.427]boot_gui_init:finish
      54 bytes read in 0 ms
      [01.656]bmp_name=bootlogo.bmp size 460854
      460854 bytes read in 45 ms (9.8 MiB/s)
      [01.738]LCD open finish
      [01.916]Loading Environment from SUNXI_FLASH... OK
      [01.950]out of usb burn from boot: not need burn key
      [01.955]Item0 (Map) magic is bad
      [02.002]update bootcmd
      [02.024]change working_fdt 0x42aa6da0 to 0x42a86da0
      [02.053]update dts
      noncached_alloc(): addr = 0x42b1acc0
      noncached_alloc(): addr = 0x42b1ad00
      noncached_alloc(): addr = 0x42b1ad40
      noncached_alloc(): addr = 0x42b1b580
      FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
      set pin for sunxi_geth error
      geth_sys_init fail!
      [02.077]Board Net Initialization Failed
      [02.081]No ethernet found.
      [03.831]no vendor_boot partition is found
      Android's image name: d1s-hengzhu
      Detect comp none
      [03.848]
      Starting kernel ...
      ** 6 printk messages dropped **
        node   0: [mem 0x0000000040000000-0x0000000043ffffff]
      On node 0 totalpages: 16384
        DMA32 zone: 0 pages reserved
      elf_hwcap is 0x20112d
      pcpu-alloc: [0] 0
      Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500400 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=ext4 init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:recovery@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d6-dirty(10/24/
      Sorting __ex_table...
      Memory: 56000K/65536K available (4756K kernel code, 420K rwdata, 1825K rodata, 152K init, 233K bss, 9536K reserved, 0K cma-reserved)
      SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      rcu: Preemptible hierarchical RCU implementation.
              Tasks RCU enabled.
      rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      devtmpfs: initialized
      random: get_random_u32 called from bucket_table_alloc.isra.27+0x10a/0x12c with crng_init=0
      clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      NET: Registered protocol family 16
      cpuidle: using governor menu
      rtc_ccu: sunxi ccu init OK
      clock: sunxi ccu init OK
      sunxi iommu: irq = 4
      SCSI subsystem initialized
      videodev: Linux video capture interface: v2.00
      Advanced Linux Sound Architecture Driver Initialized.
      nfc: nfc_init: NFC Core ver 0.1
      NET: Registered protocol family 39
      pwm module init!
      G2D: rcq version initialized.major:252
      sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      NET: Registered protocol family 2
      tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP: Hash tables configured (established 512 bind 512)
      UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
      sunxi_spi_resource_get()2189 - Failed to get sample mode
      sunxi_spi_resource_get()2194 - Failed to get sample delay
      sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
      sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
      io scheduler kyber registered
      [DISP]disp_module_init
      [DISP] parser_disp_init_para,line:1430:
      of_property_read fb0_width fail
      [DISP] disp_init,line:2386:
      [DISP] disp_init_hdmi,line:1047:
      dont support hdmi
      display_fb_request,fb_id:0
      Freeing logo buffer memory: 600K
      [DISP] lcd_clk_config,line:744:
      disp 0, clk: pll(144000000),clk(144000000),dclk(24000000) dsi_rate(144000000)
           clk real:pll(288000000),clk(288000000),dclk(24000000) dsi_rate(0)
      sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [DISP]disp_module_init finish
      sunxi_sid_init()556 - insmod ok
      uart uart1: get regulator failed
      uart uart1: uart1 supply uart not found, using dummy regulator
      uart1: ttyS0 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
      sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      printk: console [ttyS0] enabled
      uart uart3: get regulator failed
      uart uart3: uart3 supply uart not found, using dummy regulator
      uart3: ttyS1 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
      uart uart4: get regulator failed
      uart uart4: uart4 supply uart not found, using dummy regulator
      uart4: ttyS2 at MMIO 0x2501000 (irq = 22, base_baud = 1500000) is a SUNXI
      uart uart5: get regulator failed
      uart uart5: uart5 supply uart not found, using dummy regulator
      uart5: ttyS3 at MMIO 0x2501400 (irq = 23, base_baud = 1500000) is a SUNXI
      misc dump reg init
      sun8iw20-pinctrl 2000000.pinctrl: missing pins property in node wlan
      sunxi-rfkill: probe of soc@3000000:rfkill@0 failed with error -22
      nfcsim 0.2 initialized
      sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
      sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      sunxi-spinand-phy: not detect munufacture from fdt
      sunxi-spinand-phy: detect munufacture from id table: Mxic
      sunxi-spinand-phy: detect spinand id: ff0326c2 ffffffff
      sunxi-spinand-phy: ========== arch info ==========
      sunxi-spinand-phy: Model:               MX35LF2GE4AD
      sunxi-spinand-phy: Munufacture:         Mxic
      sunxi-spinand-phy: DieCntPerChip:       1
      sunxi-spinand-phy: BlkCntPerDie:        2048
      sunxi-spinand-phy: PageCntPerBlk:       64
      sunxi-spinand-phy: SectCntPerPage:      4
      sunxi-spinand-phy: OobSizePerPage:      64
      sunxi-spinand-phy: BadBlockFlag:        0x1
      sunxi-spinand-phy: OperationOpt:        0x7
      sunxi-spinand-phy: MaxEraseTimes:       65000
      sunxi-spinand-phy: EccFlag:             0x2
      sunxi-spinand-phy: EccType:             8
      sunxi-spinand-phy: EccProtectedType:    3
      sunxi-spinand-phy: ========================================
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== physical info ==========
      sunxi-spinand-phy: TotalSize:    256 M
      sunxi-spinand-phy: SectorSize:   512 B
      sunxi-spinand-phy: PageSize:     2 K
      sunxi-spinand-phy: BlockSize:    128 K
      sunxi-spinand-phy: OOBSize:      64 B
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== logical info ==========
      sunxi-spinand-phy: PageSize:     4 K
      sunxi-spinand-phy: BlockSize:    256 K
      sunxi-spinand-phy: OOBSize:      128 B
      sunxi-spinand-phy: MX35LF2GE4AD reset rx bit width to 1
      sunxi-spinand-phy: MX35LF2GE4AD reset tx bit width to 1
      sunxi-spinand-phy: block lock register: 0x00
      sunxi-spinand-phy: feature register: 0x11
      sunxi-spinand-phy: sunxi physic nand init end
      Creating 4 MTD partitions on "sunxi_mtd_nand":
      0x000000000000-0x000000100000 : "boot0"
      0x000000100000-0x000000500000 : "uboot"
      random: fast init done
      0x000000500000-0x000000600000 : "secure_storage"
      0x000000600000-0x000010000000 : "sys"
      random: crng init done
      ephy_init
      ephy_init done
      libphy: Fixed MDIO Bus: probed
      sunxi gmac driver's version: 1.0.0
      gmac-power0: NULL
      gmac-power1: NULL
      gmac-power2: NULL
      Failed to alloc md5
      eth0: Use random mac address
      sunxi-ehci: EHCI SUNXI driver
      [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000726d00, 0x:ffffffd004077000, irq_no:31
      hub 1-0:1.0: USB hub found
      hub 1-0:1.0: 1 port detected
      sunxi-ohci: OHCI SUNXI driver
      [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0007270c8
      hub 2-0:1.0: USB hub found
      hub 2-0:1.0: 1 port detected
      sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:06 UTC (6)
      i2c /dev entries driver
      uvcvideo: Unable to create debugfs directory
      usbcore: registered new interface driver uvcvideo
      USB Video Class driver (1.1.1)
      sunxi cedar version 1.1
      VE: install start!!!
      VE: cedar-ve the get irq is 6
      VE: install end!!!
      VE: sunxi_cedar_probe
      sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      sunxi-mmc 4020000.sdmmc: Got CD GPIO
      sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      ashmem: initialized
      exFAT: Version 1.3.0
      [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      Segment Routing with IPv6
      [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      NET: Registered protocol family 15
      sunxi-i2c sunxi-i2c1: sunxi-i2c1 supply twi not found, using dummy regulator
      pcf857x 1-0020: probed
      sunxi-i2c sunxi-i2c1: probe success
      sun8iw20-pinctrl 2000000.pinctrl: pin PB3 already requested by 2501000.uart; cannot claim for 2000000.pinctrl:35
      sun8iw20-pinctrl 2000000.pinctrl: pin-35 (2000000.pinctrl:35) status -22
      reg-fixed-voltage: probe of usb1-vbus failed with error -22
      ubi0: attaching mtd3
      ubi0: attached mtd3 (name "sys", size 250 MiB)
      ubi0: good PEBs: 1000, bad PEBs: 0, corrupted PEBs: 0
      ubi0: available PEBs: 16, total reserved PEBs: 984, PEBs reserved for bad PEB handling: 20
      ubi0: background thread "ubi_bgt0d" started, PID 66
      block ubiblock0_5: created from ubi0:5(rootfs)
      get id is fail, -84
      ft5x06 driver init
      get ctp_power is fail, -22
      get ctp_power_ldo_vol is fail, -22
      sunxi_ctp_startup: ctp_power_io is invalid.
      get ctp_gesture_wakeup fail, no gesture wakeup
      i2c 1-0038: 1-0038 supply ctp not found, using dummy regulator
      info.ctp_used:1
      info.twi_id:1
      info.screen_max_x:320
      info.screen_max_y:480
      info.revert_x_flag:1
      info.revert_y_flag:1
      info.exchange_x_y_flag:0
      info.irq_gpio_number:38
      info.wakeup_gpio_number:33
      ft5x06 1-0038: probe for ft5x06 i2c
      sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
      sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x38)
      ft5x06 1-0038: touchscreen probe failed
      ft5x06: probe of 1-0038 failed with error -22
      of_find_compatible_node allwinner,sunxi-ac200 fail
      ALSA device list:
        #0: audiocodec
      alloc_fd: slot 0 not NULL!
      EXT4-fs (ubiblock0_5): mounted filesystem without journal. Opts: (null)
      VFS: Mounted root (ext4 filesystem) readonly on device 254:0.
      devtmpfs: mounted
      Freeing unused kernel memory: 152K
      This architecture does not have kernel memory protection.
      Run /pseudo_init as init process
      UBIFS (ubi0:7): Mounting in unauthenticated mode
      UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 97
      insmod_device_driver
      sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      device_chose finished 139!
      UBIFS (ubi0:7): recovery needed
      UBIFS (ubi0:7): recovery completed
      UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
      UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      UBIFS (ubi0:7): FS size: 3096576 bytes (2 MiB, 12 LEBs), journal size 1806337 bytes (1 MiB, 5 LEBs)
      UBIFS (ubi0:7): reserved for root: 146258 bytes (142 KiB)
      UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID D64EA74A-5A71-4CEC-85D0-810E4EB3903C, small LPT model
      skip mount overlayfs as now rootfs not squashfs
      blk_update_request: I/O error, dev ubiblock0_5, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
      Buffer I/O error on dev ubiblock0_5, logical block 0, lost sync page write
      EXT4-fs (ubiblock0_5): I/O error while writing superblock
      mount: mounting /dev/root on / failed: Input/output error
      UBIFS (ubi0:8): Mounting in unauthenticated mode
      UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 118
      UBIFS (ubi0:8): recovery needed
      UBIFS (ubi0:8): recovery completed
      UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
      UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      UBIFS (ubi0:8): FS size: 147861504 bytes (141 MiB, 573 LEBs), journal size 7483392 bytes (7 MiB, 29 LEBs)
      UBIFS (ubi0:8): reserved for root: 4952683 bytes (4836 KiB)
      UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID 5C2165F7-75E4-47ED-81BE-0EA993DBACD0, small LPT model
      usbcore: registered new interface driver usb-storage
      sunxi_gpadc_init,2151, success
      sunxi_gpadc_setup: get channel scan data failed
      input: sunxi-gpadc0 as /devices/virtual/input/input2
      ======== XRADIO WIFI OPEN ========
      [XRADIO_ERR] debugfs isnot initialized
      [XRADIO] Driver Label:XR_V02.25.82   Jul 31 2024 10:23:18
      [XRADIO] Allocated hw_priv @ 00000000731bc574
      [XRADIO] Detect SDIO card 0
      [XRADIO] Remove SDIO card 0
      [SBUS_ERR] sdio probe timeout!
      [XRADIO_ERR] sbus_sdio_init failed
      xradio_core_init failed (-110)!
      [XRADIO] Allocated hw_priv @ 00000000573b6158
      insmod: can't insert '/lib/modules/5.4.61/xr819s.ko': Connection timed out
      ------run rc.final file-----
      Starting logging: OK
      Set gpio pins
      mkdir: can't create directory '/dev/pts': File exists
      mkdir: can't create directory '/dev/shm': File exists
      read-only file system detected...done
      Set audio
        : values=on
      Starting network: Successfully initialized wpa_supplicant
      Starting telnetd: OK
      start hengzhu locker
      ------run profile file-----
      root@TinaLinux:/# swu_param: ####
      swu_software: ####
      swu_mode: ####
      wh=320x480, vwh=320x480, bpp=32, rotated=1
      Database tables Doors
      Database tables sqlite_sequence
      Ini Unable to open file: /data/settings.ini
      Transceiver set parameter done
      Transceiver open /dev/ttyS1 success
      Serial set parameter done
      root@TinaLinux:/#
      root@TinaLinux:/#
      root@TinaLinux:/#
      root@TinaLinux:/#
      root@TinaLinux:/#
      root@TinaLinux:/# ifconfig eth0
      eth0      Link encap:Ethernet  HWaddr 72:21:D3:16:BB:E0
                BROADCAST MULTICAST  MTU:1500  Metric:1
                collisions:0 txqueuelen:1000
                Interrupt:62
      root@TinaLinux:/#
      root@TinaLinux:/#
      root@TinaLinux:/# ifconfig eth0 192.168.1.203 netmask 255.255.255.0
      libphy: 4500000.eth: probed
      RTL8211F Gigabit Ethernet 4500000.eth-0:00: rtl8211f_config_init
      RTL8211F Gigabit Ethernet 4500000.eth-0:00: rtl821x_read_page
      RTL8211F Gigabit Ethernet 4500000.eth-0:00: rtl821x_write_page
      sunxi-gmac 4500000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (4500000.eth-0:00)
      root@TinaLinux:/#
      root@TinaLinux:/#
      root@TinaLinux:/# sunxi-gmac 4500000.eth eth0: Link is Up - 1Gbps/Full - flow control off
      IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      root@TinaLinux:/#
      root@TinaLinux:/#
                inet addr:192.168.1.203  Bcast:192.168.1.255  Mask:255.255.255.0
                inet6 addr: fe80::7021:d3ff:fe16:bbe0/64 Scope:Link
                RX packets:28 errors:6 dropped:0 overruns:0 frame:0
                TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
                RX bytes:2280 (2.2 KiB)  TX bytes:586 (586.0 B)
                Interrupt:62
      root@TinaLinux:/#
