    t113-s3更换spi nand flash芯片烧录报错?
      yyyyppppp LV 5 最后由 编辑
      之前板子用的MX35LF1GE4AB 的spi nand flash 128MB,现在更换为FM25S01BI3 256MB 。
      在lichee/linux-5.4/drivers/mtd/awnand/spinand/physic/id.c中 添加了芯片信息。```
      236 { /FM25S01BI3-DND-A-G3/
      237 .Model = "FM25S01BI3",
      238 .NandID = {0xa1, 0xd4, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff},
      239 .DieCntPerChip = 1,
      240 .SectCntPerPage = 4,
      241 .PageCntPerBlk = 64,
      242 .BlkCntPerDie = 2048,
      243 .OobSizePerPage = 64,
      244 .OperationOpt = SPINAND_QUAD_READ | SPINAND_QUAD_PROGRAM |
      245 SPINAND_DUAL_READ | SPINAND_QUAD_NO_NEED_ENABLE,
      246 .MaxEraseTimes = 65000,
      247 .EccType = BIT2_LIMIT1_ERR2,
      248 .EccProtectedType = SIZE16_OFF0_LEN16,
      249 .BadBlockFlag = BAD_BLK_FLAG_FIRST_2_PAGE,
      250 },
      之后用PhoenixSuit.exe工具烧录 报错误 错误信息如下:
      [02.984]CPU:   Allwinner Family
      [02.987]Model: sun8iw20
      ready
      [03.009]DRAM:  128 MiB
      [03.012]Relocation Offset is: 04ede000
      [03.034]secure enable bit: 0
      [03.037]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [03.043]gic: normal mode
      [03.045]flash init start
      [03.048]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [03.055][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [03.062][mmc]: Is not Boot mode!
      [03.065][mmc]: SUNXI SDMMC Controller Version:0x50310
      [03.076][mmc]: ************Try SD card 2************
      [03.081][mmc]: mmc 2 cmd timeout 100 status 100
      [03.085][mmc]: smc 2 err, cmd 8,  RTO
      [03.089][mmc]: mmc 2 close bus gating and reset
      [03.094][mmc]: mmc 2 cmd timeout 100 status 100
      [03.098][mmc]: smc 2 err, cmd 55,  RTO
      [03.101][mmc]: mmc 2 close bus gating and reset
      [03.106][mmc]: ************Try MMC card 2************
      [03.115][mmc]: mmc 2 cmd timeout 100 status 100
      [03.119][mmc]: smc 2 err, cmd 1,  RTO
      [03.122][mmc]: mmc 2 close bus gating and reset
      [03.126][mmc]: Card did not respond to voltage select!
      [03.131][mmc]: ************SD/MMC 2 init error!************
      [03.136][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [03.143]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [03.149]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [03.157]sunxi-spinand-phy: request spi0 gpio ok
      [03.161]sunxi-spinand-phy: request general tx dma channel ok!
      [03.166]sunxi-spinand-phy: request general rx dma channel ok!
      [03.172]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [03.176]sunxi-spinand-phy: init spic0 clk ok
      [03.222]sunxi-spinand-phy: not detect any munufacture from id table
      [03.228]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [03.233]sunxi-spinand-phy: get phy info from fdt fail
      [03.238]sunxi-spinand-phy: not detect munufacture from fdt
      [03.243]sunxi-spinand-phy: detect munufacture from id table: FM
      [03.249]sunxi-spinand-phy: detect spinand id: ffffd4a1 ffffffff
      [03.254]sunxi-spinand-phy: ========== arch info ==========
      [03.259]sunxi-spinand-phy: Model:               FM25S01BI3
      [03.265]sunxi-spinand-phy: Munufacture:         FM
      [03.269]sunxi-spinand-phy: DieCntPerChip:       1
      [03.274]sunxi-spinand-phy: BlkCntPerDie:        2048
      [03.278]sunxi-spinand-phy: PageCntPerBlk:       64
      [03.283]sunxi-spinand-phy: SectCntPerPage:      4
      [03.287]sunxi-spinand-phy: OobSizePerPage:      64
      [03.292]sunxi-spinand-phy: BadBlockFlag:        0x1
      [03.296]sunxi-spinand-phy: OperationOpt:        0xf
      [03.301]sunxi-spinand-phy: MaxEraseTimes:       65000
      [03.306]sunxi-spinand-phy: EccFlag:             0x0
      [03.310]sunxi-spinand-phy: EccType:             2
      [03.315]sunxi-spinand-phy: EccProtectedType:    1
      [03.319]sunxi-spinand-phy: ========================================
      [03.325]sunxi-spinand-phy:
      [03.328]sunxi-spinand-phy: ========== physical info ==========
      [03.333]sunxi-spinand-phy: TotalSize:    256 M
      [03.337]sunxi-spinand-phy: SectorSize:   512 B
      [03.341]sunxi-spinand-phy: PageSize:     2 K
      [03.345]sunxi-spinand-phy: BlockSize:    128 K
      [03.350]sunxi-spinand-phy: OOBSize:      64 B
      [03.354]sunxi-spinand-phy: ========================================
      [03.360]sunxi-spinand-phy:
      [03.362]sunxi-spinand-phy: ========== logical info ==========
      [03.368]sunxi-spinand-phy: TotalSize:    256 M
      [03.372]sunxi-spinand-phy: SectorSize:   512 B
      [03.376]sunxi-spinand-phy: PageSize:     4 K
      [03.380]sunxi-spinand-phy: BlockSize:    256 K
      [03.384]sunxi-spinand-phy: OOBSize:      128 B
      [03.388]sunxi-spinand-phy: ========================================
      [03.395]sunxi-spinand-phy: FM25S01BI3 reset rx bit width to 1
      [03.400]sunxi-spinand-phy: FM25S01BI3 reset tx bit width to 1
      [03.405]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [03.410]sunxi-spinand-phy: block lock register: 0x00
      [03.415]sunxi-spinand-phy: feature register: 0x10
      [03.419]sunxi-spinand-phy: sunxi physic nand init end
      [03.424]Loading Environment from SUNXI_FLASH... OK
      [03.428]try to burn key
      [03.431]out of usb burn from boot: not need burn key
      sunxi work mode=0x10
      run usb efex
      buf queue page size = 16384
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x2
      set address 0x2 ok
      set address 0x2
      set address 0x2 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      SUNXI_EFEX_EXT4_UBIFS_TAG & do nothing
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 6
      part[0] classname :DISK
      part[0] addrlo    :0x8000
      part[0] lenlo     :0x1a00
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x9a00
      part[1] lenlo     :0x1f8
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x9bf8
      part[2] lenlo     :0x1f8
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x9df0
      part[3] lenlo     :0x2000
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0xbdf0
      part[4] lenlo     :0x2d400
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :UDISK
      part[5] classname :DISK
      part[5] addrlo    :0x391f0
      part[5] lenlo     :0x0
      part[5] user_type :0
      part[5] keydata   :0
      part[5] ro        :0
      total part: 7
      mbr 0, 8000, 8000
      boot-resource 1, 1a00, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 2000, 8000
      rootfs 5, 2d400, 8000
      UDISK 6, 0, 0
      [06.731]erase blk 0 to blk 32
      need erase flash: 18
      [06.793]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      defaults:
      mtdids  : nand0=nand
      [06.844]MTD info (4)
      [06.846]pagesize: 0x1000
      [06.848]blksize: 0x40000
      [06.850]num  offset     bytes      name
      [06.854]0    0x00000000 0x00100000 boot0
      [06.857]1    0x00100000 0x00300000 uboot
      [06.861]2    0x00400000 0x00100000 secure_storage
      [06.865]3    0x00500000 0x0fb00000 sys
      [06.869]ubi attach the last part of mtd device: NO.3
      [07.057]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.061]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.066]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.071]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.075]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.080]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.084]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.089]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.094]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.098]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.103]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.107]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.112]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.117]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.121]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.126]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.130]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.135]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.139]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.144]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.149]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.153]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.158]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.162]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.167]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.172]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.176]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.181]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      [07.185]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
      请问各位大佬如何解决!!!!!!
        a06041114 LV 5 @yyyyppppp 最后由 编辑
        @yyyyppppp
        作者,你这个问题解决了没,能说下如何改的嘛
