    v851se切换spinand文件系统起不来Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
    4197
      away123456 LV 4 最后由 编辑
      [10342]fes begin commit:2a3ec52022
      [10345]set pll start
      [10347]periph0 has been enabled
      [10350]set pll end
      [10410][pmu]: bus read error
      [10413]board init ok
      [10415]beign to init dram
      [10417]DRAM use internal ZQ!!
      [10420]ZQ value = 0x30
      [10422]chip id check OK
      [10424]POWER SETTING ERROR!
      [10427]trefi:7.8ms
      [10430][AUTO DEBUG] single rank and full DQ!
      [10434]trefi:7.8ms
      [10436][AUTO DEBUG] rank 0 row = 13
      [10439][AUTO DEBUG] rank 0 bank = 4
      [10443][AUTO DEBUG] rank 0 page size = 2 KB
      [10447]DRAM BOOT DRIVE INFO: V0.16
      [10450]DRAM CLK = 528 MHz
      [10452]DRAM Type = 2 (2:DDR2,3:DDR3)
      [10456]DRAMC read ODT  off.
      [10459]DRAM ODT off.
      [10461]DRAM SIZE =64 M
      [10463]dram_tpr4:0x0
      [10467]DRAM simple test OK.
      [10470]rtc standby flag is 0x0, super standby flag is 0x0
      [10475]init dram ok
      U-Boot 2018.05-g3a34d5f-dirty (Nov 11 2024 - 08:21:33 -0800) Allwinner Technology
      [11.958]CPU:   Allwinner Family
      [11.961]Model: sun8iw21
      I2C:   [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
      ready
      [12.021]DRAM:  64 MiB
      [12.024]Relocation Offset is: 01eef000
      [12.053]secure enable bit: 0
      [I2C-ERROR]:twi_stop() 339 STOP can't sendout!
      [12.060]pmu_axp2101_probe pmic_bus_read fail
      [12.064]PMU: no found
      [12.070]bmu_axp2101_probe pmic_bus_read fail
      [12.074]BMU: no found
      [12.076]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [12.082]gic: normal mode
      sunxi flash map init
      [12.086]flash init start xxx
      [12.089]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [12.097][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [12.102][mmc]: get sdc_type fail and use default host:tm4.
      [12.109][mmc]: Is not Boot mode!
      [12.112][mmc]: SUNXI SDMMC Controller Version:0x50400
      [12.123][mmc]: ************Try SD card 2************
      [12.128][mmc]: mmc 2 cmd timeout 100 status 100
      [12.132][mmc]: smc 2 err, cmd 8,  RTO
      [12.136][mmc]: mmc 2 close bus gating and reset
      [12.141][mmc]: mmc 2 cmd timeout 100 status 100
      [12.145][mmc]: smc 2 err, cmd 55,  RTO
      [12.148][mmc]: mmc 2 close bus gating and reset
      [12.153][mmc]: ************Try MMC card 2************
      [12.161][mmc]: mmc 2 cmd timeout 100 status 100
      [12.166][mmc]: smc 2 err, cmd 1,  RTO
      [12.169][mmc]: mmc 2 close bus gating and reset
      [12.173][mmc]: Card did not respond to voltage select!
      [12.178][mmc]: ************SD/MMC 2 init error!************
      [12.183][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [12.190]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
      [12.196]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
      [12.204]sunxi-spinand-phy: request spi0 gpio ok
      [12.208]sunxi-spinand-phy: request general tx dma channel ok!
      [12.214]sunxi-spinand-phy: request general rx dma channel ok!
      [12.219]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [12.224]sunxi-spinand-phy: init spic0 clk ok
      [12.228]sunxi-spinand-phy: detect munufacture from id table: Mxic
      [12.233]sunxi-spinand-phy: detect spinand id: ff0326c2 ffffffff
      [12.239]sunxi-spinand-phy: ========== arch info ==========
      [12.244]sunxi-spinand-phy: Model:               MX35LF2GE4AD
      [12.250]sunxi-spinand-phy: Munufacture:         Mxic
      [12.254]sunxi-spinand-phy: DieCntPerChip:       1
      [12.259]sunxi-spinand-phy: BlkCntPerDie:        2048
      [12.263]sunxi-spinand-phy: PageCntPerBlk:       64
      [12.268]sunxi-spinand-phy: SectCntPerPage:      4
      [12.272]sunxi-spinand-phy: OobSizePerPage:      64
      [12.277]sunxi-spinand-phy: BadBlockFlag:        0x1
      [12.281]sunxi-spinand-phy: OperationOpt:        0x7
      [12.286]sunxi-spinand-phy: MaxEraseTimes:       65000
      [12.291]sunxi-spinand-phy: EccFlag:             0x2
      [12.295]sunxi-spinand-phy: EccType:             8
      [12.300]sunxi-spinand-phy: EccProtectedType:    3
      [12.304]sunxi-spinand-phy: ========================================
      [12.310]sunxi-spinand-phy:
      [12.313]sunxi-spinand-phy: ========== physical info ==========
      [12.318]sunxi-spinand-phy: TotalSize:    256 M
      [12.322]sunxi-spinand-phy: SectorSize:   512 B
      [12.327]sunxi-spinand-phy: PageSize:     2 K
      [12.330]sunxi-spinand-phy: BlockSize:    128 K
      [12.335]sunxi-spinand-phy: OOBSize:      64 B
      [12.339]sunxi-spinand-phy: ========================================
      [12.345]sunxi-spinand-phy:
      [12.347]sunxi-spinand-phy: ========== logical info ==========
      [12.353]sunxi-spinand-phy: TotalSize:    256 M
      [12.357]sunxi-spinand-phy: SectorSize:   512 B
      [12.361]sunxi-spinand-phy: PageSize:     4 K
      [12.365]sunxi-spinand-phy: BlockSize:    256 K
      [12.369]sunxi-spinand-phy: OOBSize:      128 B
      [12.373]sunxi-spinand-phy: ========================================
      [12.380]sunxi-spinand-phy: MX35LF2GE4AD reset rx bit width to 1
      [12.385]sunxi-spinand-phy: MX35LF2GE4AD reset tx bit width to 1
      [12.391]sunxi-spinand-phy: block lock register: 0x00
      [12.396]sunxi-spinand-phy: feature register: 0x11
      [12.400]sunxi-spinand-phy: sunxi physic nand init end
      [12.822]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [14.056]sunxi-spinand-phy: Sample mode:1  min_delay:4160 max_delay:14120 right_delay:19)
      [14.219]line:724 init_clocks
      [14.222]init_clocks:finish
      [14.225]Loading Environment from SUNXI_FLASH... OK
      [14.229]try to burn key
      [14.232]out of usb burn from boot: not need burn key
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x9
      set address 0x9 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 6
      part[0] name      :boot-res
      part[0] classname :DISK
      part[0] addrlo    :0x2000
      part[0] lenlo     :0x400
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x2400
      part[1] lenlo     :0x200
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :boot
      part[2] classname :DISK
      part[2] addrlo    :0x2600
      part[2] lenlo     :0x5710
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :rootfs
      part[3] classname :DISK
      part[3] addrlo    :0x7d10
      part[3] lenlo     :0x1e910
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs_data
      part[4] classname :DISK
      part[4] addrlo    :0x26620
      part[4] lenlo     :0x19000
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :UDISK
      part[5] classname :DISK
      part[5] addrlo    :0x3f620
      part[5] lenlo     :0x0
      part[5] user_type :33024
      part[5] keydata   :0
      part[5] ro        :0
      total part: 7
      mbr 0, 2000, 8000
      boot-res 1, 400, 8000
      env 2, 200, 8000
      boot 3, 5710, 8000
      rootfs 4, 1e910, 8000
      rootfs_data 5, 19000, 8000
      UDISK 6, 0, 8100
      [17.227]erase blk 0 to blk 32
      [17.230]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.234]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.241]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.246]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.253]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.257]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.264]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.269]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.276]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.280]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.287]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.292]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.299]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      [17.303]sunxi-spinand-phy: [SPINAND]: ecc error 0xf
      need erase flash: 18
      [17.376]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      defaults:
      mtdids  : nand0=nand
      [17.427]MTD info (4)
      [17.429]pagesize: 0x1000
      [17.431]blksize: 0x40000
      [17.433]num  offset     bytes      name
      [17.437]0    0x00000000 0x00100000 boot0
      [17.440]1    0x00100000 0x00300000 uboot
      [17.444]2    0x00400000 0x00100000 secure_storage
      [17.449]3    0x00500000 0x0fb00000 sys
      [17.452]ubi attach the last part of mtd device: NO.3
      [17.756]ubi0: attaching mtd4
      [18.228]ubi0: scanning is finished
      [18.239]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [18.243]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [18.250]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [18.256]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [18.262]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [18.268]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [18.274]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [18.282]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [18.291]erase blk 0 to blk 32
      [18.349]erase blk 40 to blk 2048
      [22.339]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
      [22.347]Item0 (Map) magic is bad
      [22.350]the secure storage map is empty
      [22.447]sunxi-spinand: write secure storage itme 0 ok
      [22.452]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      force mbr
      defaults:
      mtdids  : nand0=nand
      [22.500]MTD info (4)
      [22.502]pagesize: 0x1000
      [22.504]blksize: 0x40000
      [22.506]num  offset     bytes      name
      [22.510]0    0x00000000 0x00100000 boot0
      [22.514]1    0x00100000 0x00300000 uboot
      [22.517]2    0x00400000 0x00100000 secure_storage
      [22.522]3    0x00500000 0x0fb00000 sys
      [22.525]MBR info (unalign):
      [22.528]partno   addr       sects      type       name
      [22.532]0        0x00000000 0x00002000 0x00000001 mbr
      [22.537]1        0x00002000 0x00000400 0x00008000 boot-res
      [22.542]2        0x00002400 0x00000200 0x00008000 env
      [22.547]3        0x00002600 0x00005710 0x00008000 boot
      [22.552]4        0x00007d10 0x0001e910 0x00008000 rootfs
      [22.557]5        0x00026620 0x00019000 0x00008000 rootfs_data
      [22.563]6        0x0003f620 0x00000000 0x00008100 UDISK
      [22.567]ubi attach the last part of mtd device: NO.3
      [22.572]MBR info (align):
      [22.574]partno   addr       sects      type       name
      [22.579]0        0x00002800 0x00002178 0x00000001 mbr
      [22.584]1        0x00004978 0x000005e8 0x00008000 boot-res
      [22.589]2        0x00004f60 0x000003f0 0x00008000 env
      [22.594]3        0x00005350 0x00005898 0x00008000 boot
      [22.599]4        0x0000abe8 0x0001ea38 0x00008000 rootfs
      [22.604]5        0x00029620 0x000191a0 0x00008000 rootfs_data
      [22.609]6        0x000427c0 0x00000000 0x00008100 UDISK
      [22.614]ubi attach the last part of mtd device: NO.3
      [22.619]ubi attatch mtd, name: sys
      [22.622]ubi0: detaching mtd4
      [22.625]ubi0: mtd4 is detached
      [22.628]ubi0: attaching mtd4
      [22.865]ubi0: scanning is finished
      [22.868]ubi0: empty MTD device detected
      [22.895]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [22.899]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [22.905]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [22.912]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [22.918]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [22.923]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [22.930]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [22.938]ubi0: available PEBs: 960, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40
      Creating static volume mbr of size 4386816
      Creating dynamic volume boot-res of size 774144
      Creating dynamic volume env of size 516096
      Creating dynamic volume boot of size 11612160
      Creating dynamic volume rootfs of size 64253952
      Creating dynamic volume rootfs_data of size 52641792
      No size specified -> Using max size (113541120)
      [27.162]reset last volume size to 0x36240
      Creating dynamic volume UDISK of size 113541120
      [27.195]existed volume UDISK size is 221760(sects) , inside ubi part size is 0(sects),existed volume size to update inside ubi part size
      [27.207]existed volume UDISK size is 221760(sects) , inside ubi part size is 0(sects),existed volume size to update inside ubi part size
      [27.243]fill gap start: volume mbr sects 0x1f80
      [28.783]fill gap end: volume mbr
      [28.786]update partition map
      [28.788]logical area info: 960 258048 last_lba: 483839
      [28.801]logical area info: 960 258048 last_lba: 483839
      [28.813]logical area info: 960 258048 last_lba: 483839
      [28.826]logical area info: 960 258048 last_lba: 483839
      [28.838]logical area info: 960 258048 last_lba: 483839
      [28.850]logical area info: 960 258048 last_lba: 483839
      [28.863]logical area info: 960 258048 last_lba: 483839
      [28.875]logical area info: 960 258048 last_lba: 483839
      [28.888]logical area info: 960 258048 last_lba: 483839
      [28.900]logical area info: 960 258048 last_lba: 483839
      [28.912]logical area info: 960 258048 last_lba: 483839
      [28.925]logical area info: 960 258048 last_lba: 483839
      [28.937]logical area info: 960 258048 last_lba: 483839
      [28.949]logical area info: 960 258048 last_lba: 483839
      [28.962]logical area info: 960 258048 last_lba: 483839
      [28.974]logical area info: 960 258048 last_lba: 483839
      [28.987]logical area info: 960 258048 last_lba: 483839
      [28.999]logical area info: 960 258048 last_lba: 483839
      [29.011]logical area info: 960 258048 last_lba: 483839
      [29.024]logical area info: 960 258048 last_lba: 483839
      [29.036]logical area info: 960 258048 last_lba: 483839
      [29.048]logical area info: 960 258048 last_lba: 483839
      [29.088]fill gap start: volume boot-res sects 0x360
      [29.184]fill gap end: volume boot-res
      FEX_CMD_fes_verify_value, start 0x2000, size high 0x0:low 0x14000
      [29.239]fill gap start: volume env sects 0x100
      [29.333]fill gap end: volume env
      FEX_CMD_fes_verify_value, start 0x2400, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0x12e446f8
      [31.557]fill gap start: volume boot sects 0x1b98
      [31.679]fill gap end: volume boot
      FEX_CMD_fes_verify_value, start 0x2600, size high 0x0:low 0x76f000
      FEX_CMD_fes_verify_value 0xbdbf9631
      [41.076]fill gap start: volume rootfs sects 0x10110
      [41.442]fill gap end: volume rootfs
      FEX_CMD_fes_verify_value, start 0x7d10, size high 0x0:low 0x1d00000
      FEX_CMD_fes_verify_value 0x77474c0a
      bootfile_mode=4
      SUNXI_EFEX_BOOT1_TAG
      boot1 size = 0xe8000, max size = 0x200000
      uboot size = 0xe8000
      storage type = 0
      [45.050]uboot blk range [8-32)
      [45.052]download uboot to block 8 (8 blocks) len 928K
      [45.306]download uboot to block 16 (8 blocks) len 928K
      [45.559]download uboot to block 24 (8 blocks) len 928K
      bootfile_mode=4
      SUNXI_EFEX_BOOT0_TAG
      boot0 size = 0xa000
      dram para[0] = 210
      dram para[1] = 2
      dram para[2] = 7b7bf9
      dram para[3] = 0
      dram para[4] = d2
      dram para[5] = 400000
      dram para[6] = e73
      dram para[7] = 2
      dram para[8] = 0
      dram para[9] = 0
      dram para[10] = 471992
      dram para[11] = 131a10c
      dram para[12] = 57041
      dram para[13] = b4787896
      dram para[14] = 0
      dram para[15] = 48484848
      dram para[16] = 48
      dram para[17] = 1621121e
      dram para[18] = 0
      dram para[19] = 0
      dram para[20] = 0
      dram para[21] = 22
      dram para[22] = 77
      dram para[23] = b4006103
      dram para[24] = 0
      dram para[25] = 0
      dram para[26] = 0
      dram para[27] = 0
      dram para[28] = 0
      dram para[29] = 0
      dram para[30] = 0
      dram para[31] = 0
      storage type = 0
      [45.883]download boot0 to block 0 len 40K
      [45.899]download boot0 to block 1 len 40K
      [45.914]download boot0 to block 2 len 40K
      [45.930]download boot0 to block 3 len 40K
      [45.945]download boot0 to block 4 len 40K
      [45.960]download boot0 to block 5 len 40K
      [45.976]download boot0 to block 6 len 40K
      [45.991]download boot0 to block 7 len 40K
      sunxi_efex_next_action=2
      exit usb
      next work 2
      ?[22]HELLO! BOOT0 is starting!T
      [25]BOOT0 commit : 2a3ec52022
      [28]set pll start
      [30]periph0 has been enabled
      [32]set pll end
      [108][pmu]: bus read error
      [111]board init ok
      [113]DRAM use internal ZQ!!
      [115]ZQ value = 0x30
      [117]chip id check OK
      [119]POWER SETTING ERROR!
      [122]DRAM BOOT DRIVE INFO: V0.16
      [125]DRAM CLK = 528 MHz
      [127]DRAM Type = 2 (2:DDR2,3:DDR3)
      [131]DRAMC read ODT  off.
      [133]DRAM ODT off.
      [136]DRAM SIZE =64 M
      [138]dram_tpr4:0x0
      [145]DRAM simple test OK.
      [147]rtc standby flag is 0x0, super standby flag is 0x0
      [152]dram size =64
      [155]audio:avcc calibration
      [158]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [163]block from 8 to 32
      [496]Check is correct.
      [498]Entry_name        = optee
      [501]Entry_name        = u-boot
      [509]Entry_name        = dtb
      [512]Jump to second Boot.
      E/TC:0 0 platform_standby_fdt_parse:133 no pmu node
      E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      [00.590]CPU:   Allwinner Family
      [00.593]Model: sun8iw21
      ready
      [00.653]DRAM:  64 MiB
      [00.656]Relocation Offset is: 01eef000
      [00.685]secure enable bit: 0
      [00.699]smc_tee_inform_fdt failed with: ffff0000
      [00.709]pmu_axp2101_probe pmic_bus_read fail
      [00.718]bmu_axp2101_probe pmic_bus_read fail
      [00.722]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.728]gic: sec monitor mode
      [00.733]flash init start xxx
      [00.735]workmode = 0,storage type = 0
      [00.743]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:19
      defaults:
      mtdids  : nand0=nand
      [01.089]ubi0: attaching mtd4
      [01.561]ubi0: scanning is finished
      [01.571]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [01.576]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [01.582]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [01.588]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [01.595]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [01.600]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [01.607]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [01.615]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [01.623]sunxi flash init ok
      [01.626]line:724 init_clocks
      [01.794]Loading Environment from SUNXI_FLASH... backup env check CRC fail
      Now update backup env
      Saving Environment to SUNXI_FLASH... Writing to env...
      OK
      OK
      [01.965]Item0 (Map) magic is bad
      [01.968]out of usb burn from boot: not need burn key
      [01.997]update bootcmd
      [02.022]change working_fdt 0x42aaee70 to 0x42a8ee70
      disable nand error: FDT_ERR_NOTFOUND
      [02.037]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [02.042]update dts
      input addr exceed dram scope
      [03.977]no vendor_boot partition is found
      [04.038]Starting kernel ...
      [    0.000000] Linux version 4.9.191 (vmuser@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #8 PREEMPT Wed Nov 13 08:16:42 PST 2024
      [    0.000000] OF: fdt:Machine model: sun8iw21
      [    0.000000] Memory policy: Data cache writeback
      [    0.000000] free_area_init_node: node 0, pgdat c0a430f8, node_mem_map c3f78000
      [    0.000000]   Normal zone: 128 pages used for memmap
      [    0.000000]   Normal zone: 16384 pages, LIFO batch:3
      [    0.000000] CPU: All CPU(s) started in SVC mode.
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
      [    0.000000] Kernel command line: ubi.mtd=sys earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_4 rootfstype=ubifs, rw init=/init partitions=mbr@ubi0_0:boot-res@ubi0_1:env@ubi0_2:boot@ubi0_3:rootfs@ubi0_4:rootfs_data@ubi0_5:UDISK@ubi0_6: cma= snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw21p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g3a34d5f-dirty(11/11/2024-08:21:33) mbr_offset=1032192 bootreason=button aw-ubi-spinand.ubootblks=24 androidboot.dramsize=64
      [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
      [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Memory: 54784K/65536K available (6144K kernel code, 272K rwdata, 1404K rodata, 1024K init, 150K bss, 10752K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
      [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
      [    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
      [    0.000000]       .data : 0xc0a00000 - 0xc0a44138   ( 273 kB)
      [    0.000000]        .bss : 0xc0a44138 - 0xc0a69a48   ( 151 kB)
      [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000020] Switching to timer-based delay loop, resolution 41ns
      [    0.000200] Console: colour dummy device 80x30
      [    0.000232] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000246] pid_max: default: 32768 minimum: 301
      [    0.000443] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000456] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.001034] CPU: Testing write buffer coherency: ok
      [    0.001663] Setting up static identity map for 0x40100000 - 0x40100058
      [    0.003412] devtmpfs: initialized
      [    0.034801] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.035380] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.035412] futex hash table entries: 256 (order: -1, 3072 bytes)
      [    0.035560] atomic64_test: passed
      [    0.035573] pinctrl core: initialized pinctrl subsystem
      [    0.036747] NET: Registered protocol family 16
      [    0.037517] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.038867] dump_class_init,857, success
      [    0.059409] cpuidle: using governor menu
      [    0.060768] platform 2010000.iommu: iova_base: 0x48400000
      [    0.061356] sunxi iommu: irq = 22
      [    0.082173] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
      [    0.085184] iommu: Adding device npu to group 0
      [    0.087241] iommu: Adding device 1c0e000.ve to group 0
      [    0.100226] iommu: Adding device 5410000.g2d to group 0
      [    0.101098] iommu: Adding device 5000000.disp to group 0
      [    0.113039] iommu: Adding device 5908000.tdm to group 0
      [    0.114003] iommu: Adding device 5900000.isp to group 0
      [    0.115021] iommu: Adding device 58ffffc.isp to group 0
      [    0.115889] iommu: Adding device 58ffff8.isp to group 0
      [    0.116592] iommu: Adding device 58ffff4.isp to group 0
      [    0.117050] iommu: Adding device 5800800.vind:isp@4 to group 0
      [    0.117942] iommu: Adding device 5910000.scaler to group 0
      [    0.118596] iommu: Adding device 590fffc.scaler to group 0
      [    0.119279] iommu: Adding device 590fff8.scaler to group 0
      [    0.120204] iommu: Adding device 590fff4.scaler to group 0
      [    0.121105] iommu: Adding device 5910400.scaler to group 0
      [    0.121764] iommu: Adding device 59103fc.scaler to group 0
      [    0.122377] iommu: Adding device 59103f8.scaler to group 0
      [    0.122864] iommu: Adding device 59103f4.scaler to group 0
      [    0.123755] iommu: Adding device 5910800.scaler to group 0
      [    0.124407] iommu: Adding device 59107fc.scaler to group 0
      [    0.125095] iommu: Adding device 59107f8.scaler to group 0
      [    0.125703] iommu: Adding device 59107f4.scaler to group 0
      [    0.126592] iommu: Adding device 5910c00.scaler to group 0
      [    0.127243] iommu: Adding device 5910bfc.scaler to group 0
      [    0.127733] iommu: Adding device 5910bf8.scaler to group 0
      [    0.128340] iommu: Adding device 5910bf4.scaler to group 0
      [    0.129650] iommu: Adding device vinc0 to group 0
      [    0.130878] iommu: Adding device vinc4 to group 0
      [    0.131759] iommu: Adding device vinc8 to group 0
      [    0.132494] iommu: Adding device vinc12 to group 0
      [    0.182206] pwm module init!
      [    0.186845] sunxi-pm debug v3.10
      [    0.187890] SCSI subsystem initialized
      [    0.188256] usbcore: registered new interface driver usbfs
      [    0.188348] usbcore: registered new interface driver hub
      [    0.192300] usbcore: registered new device driver usb
      [    0.192664] sunxi_i2c_adap_init()2754 - init
      [    0.192895] sun8iw21p1-pinctrl pio: expect_func as:twi6, but muxsel(4) is func:twi3
      [    0.192912] sun8iw21p1-pinctrl pio: expect_func as:twi6, but muxsel(4) is func:twi3
      [    0.193249] sunxi_i2c_probe()2449 - [i2c3] twi_drv_used = 0
      [    0.193266] sunxi_i2c_probe()2456 - [i2c3] twi_pkt_interval = 0
      [    0.193336] twi_regulator_request()653 - [i2c3] regulator not found(isn't configured in dts)!
      [    0.193347] twi_request_gpio()469 - [i2c3] init name: (null)
      [    0.194383] media: Linux media interface: v0.10
      [    0.194567] Linux video capture interface: v2.00
      [    0.196686] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.197886] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.198939] Advanced Linux Sound Architecture Driver Initialized.
      [    0.199942] Bluetooth: Core ver 2.22
      [    0.200412] NET: Registered protocol family 31
      [    0.200428] Bluetooth: HCI device and connection manager initialized
      [    0.200454] Bluetooth: HCI socket layer initialized
      [    0.200469] Bluetooth: L2CAP socket layer initialized
      [    0.200543] Bluetooth: SCO socket layer initialized
      [    0.203896] G2D: rcq version initialized.major:251
      [    0.205216] clocksource: Switched to clocksource arch_sys_counter
      [    0.237762] get androidboot.mode fail
      [    0.239967] NET: Registered protocol family 2
      [    0.255592] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.255613] TCP bind hash table entries: 16 (order: -6, 64 bytes)
      [    0.255623] TCP: Hash tables configured (established 16 bind 16)
      [    0.255702] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [    0.255725] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [    0.255969] NET: Registered protocol family 1
      [    0.256297] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC0
      [    0.256319] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC1
      [    0.256334] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC2
      [    0.256350] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC3
      [    0.256364] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC4
      [    0.256379] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC5
      [    0.256614] sunxi_spi_probe()2250 - [spi0] SPI DBI INTERFACE
      [    0.256629] sunxi_spi_probe()2259 - [spi0] SPI MASTER MODE
      [    0.256707] sunxi_spi_resource_get()1917 - sample_mode:1 sample_delay:19
      [    0.256731] spi0 supply spi not found, using dummy regulator
      [    0.256828] sunxi_spi_request_gpio()1883 - [spi0] Pinctrl init spi0
      [    0.256922] sunxi_spi_clk_init()1954 - [spi0] mclk 100000000
      [    0.258111] sunxi_spi_probe()2339 - [spi0]: driver probe succeed, base c486a000, irq 294
      [    0.262420] workingset: timestamp_bits=29 max_order=14 bucket_order=0
      [    0.279673] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.280308] jffs2: version 2.2. (NAND) (SUMMARY)  ? 2001-2006 Red Hat, Inc.
      [    0.282840] io scheduler noop registered
      [    0.282861] io scheduler deadline registered
      [    0.283174] io scheduler cfq registered (default)
      [    0.287517] uart0 supply uart not found, using dummy regulator
      [    0.287782] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
      [    0.287817] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
      [    1.315293] console [ttyS0] enabled
      [    1.320671] misc dump reg init
      [    1.324848] npu[1][1] vipcore, platform driver device=0xc39efe10
      [    1.331945] npu[1][1] vipcore irq number is 290.
      [    1.337197] gckvip_drv_adjust_param 232 SUCCESS
      [    1.342318] the freq of pll_npux4 clk is fixed
      [    1.347426] Want set pclk rate(348000000) support(1392000000) real(1392000000)
      [    1.355565] Want set mclk rate(348000000) support(348000000) real(348000000)
      [    1.363493] npu[1][1] This device support 64bits DMA
      [    1.369642] npu[1][1] core_0, request irqline=290, name=vipcore_0
      [    1.376784] npu[1][1] =======vipcore parameter=====
      [    1.382246] npu[1][1] registerMemBase     0x03050000,
      [    1.388068] npu[1][1] registerMemSize     0x00020000,
      [    1.393815] npu[1][1] irqLine             0x00000122,
      [    1.399597] npu[1][1] contiguousSize      0x02000000
      [    1.405150] npu[1][1] contiguousBase      0x30000000
      [    1.410780] npu[1][1] vipContiguousBase   0x0
      [    1.415688] npu[1][1] drvType             0x00000000
      [    1.421238] npu[1][1] AXISramSize         0x00000000
      [    1.426815] npu[1][1] AXISramBaseAddress  0x00000000
      [    1.432364] npu[1][1] VIPSramSize         0x00020000
      [    1.437930] npu[1][1] VIPSramBaseAddress  0x00400000
      [    1.443481] npu[1][1] sysHeapSize         0x00200000
      [    1.449044] npu[1][1] ===============================
      [    1.454779] npu[1][1] VIPLite driver version 1.8.0.0-AW-2022-04-21
      [    1.462924] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
      [    1.469436] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (-1)
      [    1.476135] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
      [    1.483439] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
      [    1.490798] sunxi-wlan soc@03000000:wlan@0: request pincrtl handle for device [soc@03000000:wlan@0] failed
      [    1.501739] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=134  mul-sel=1  pull=1  drv_level=2  data=0
      [    1.512335] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
      [    1.519414] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=135  mul-sel=14  pull=1  drv_level=2  data=0
      [    1.530448] sunxi-wlan soc@03000000:wlan@0: clk_name ()
      [    1.538532] libphy: Fixed MDIO Bus: probed
      [    1.544751] sunxi gmac driver's version: 2.0.2
      [    1.552181] Failed to alloc md5
      [    1.555820] eth0: Use random mac address
      [    1.560657] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.568748] get ehci0-controller, regulator_io is no nocare
      [    1.574991] get ehci0-controller wakeup-source is fail.
      [    1.581115] sunxi ehci0-controller don't init wakeup source
      [    1.587488] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a5daf0, 0x:c4872000, irq_no:130
      [    1.599593] [sunxi-ehci0]: Not init ehci0
      [    1.604554] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.612094] get ohci0-controller, regulator_io is no nocare
      [    1.618421] get ohci0-controller wakeup-source is fail.
      [    1.624437] sunxi ohci0-controller don't init wakeup source
      [    1.630849] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a5dd14
      [    1.640567] [sunxi-ohci0]: Not init ohci0
      [    1.645790] usbcore: registered new interface driver uas
      [    1.652156] usbcore: registered new interface driver usb-storage
      [    1.659174] usbcore: registered new interface driver ums-alauda
      [    1.666141] usbcore: registered new interface driver ums-cypress
      [    1.673166] usbcore: registered new interface driver ums-datafab
      [    1.680224] usbcore: registered new interface driver ums_eneub6250
      [    1.687551] usbcore: registered new interface driver ums-freecom
      [    1.694559] usbcore: registered new interface driver ums-isd200
      [    1.701450] usbcore: registered new interface driver ums-jumpshot
      [    1.708606] usbcore: registered new interface driver ums-karma
      [    1.715526] usbcore: registered new interface driver ums-onetouch
      [    1.722674] usbcore: registered new interface driver ums-realtek
      [    1.729682] usbcore: registered new interface driver ums-sddr09
      [    1.736644] usbcore: registered new interface driver ums-sddr55
      [    1.743558] usbcore: registered new interface driver ums-usbat
      [    1.750341] usb_serial_number:20080411
      [    1.755652] sunxi_gpadc_init,1949, success
      [    1.760678] sunxi_gpadc_setup: get channel scan data failed
      [    1.768529] input: sunxi-gpadc0 as /devices/virtual/input/input0
      [    1.777850] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.784740] sunxi-rtc rtc: RTC enabled
      [    1.789371] fix to cold boot, save boot reason
      [    1.794778] i2c /dev entries driver
      [    1.799819] usbcore: registered new interface driver uvcvideo
      [    1.806662] USB Video Class driver (1.1.1)
      [    1.811262] sunxi cedar version 0.1
      [    1.815417] VE: install start!!!
      [    1.815417]
      [    1.820845] VE: cedar-ve the get irq is 291
      [    1.825746] VE: regs_csi = c48ab000
      [    1.830352] VE: ve_debug_proc_info:c0a61300, data:c3bd8000, lock:c0a61388, flag: 1
      [    1.830352]
      [    1.840842] VE: install end!!!
      [    1.840842]
      [    1.846476] google_vp9: sunxi google vp9 version 0.1
      [    1.854931] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.864739] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
      [    1.872369] Bluetooth: HCI UART protocol H4 registered
      [    1.878256] Bluetooth: HCI H4 protocol initialized
      [    1.883870] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
      [    1.891724] bt_fdi debugfs_init
      [    1.897399] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 900000 KHz
      [    1.935321] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 912000 KHz
      [    1.945642] cpuidle: enable-method property 'psci' found operations
      [    1.955637] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    1.964613] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
      [    1.970250] sunxi-mmc sdc0: No vmmc regulator found
      [    1.975861] sunxi-mmc sdc0: No vqmmc regulator found
      [    1.981422] sunxi-mmc sdc0: No vdmmc regulator found
      [    1.987072] sunxi-mmc sdc0: No vd33sw regulator found
      [    1.992731] sunxi-mmc sdc0: No vd18sw regulator found
      [    1.998426] sunxi-mmc sdc0: No vq33sw regulator found
      [    2.004082] sunxi-mmc sdc0: No vq18sw regulator found
      [    2.010401] sunxi-mmc sdc0: set host busy
      [    2.015006] sunxi-mmc sdc0: Got CD GPIO
      [    2.019880] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.203044] random: fast init done
      [    2.275310] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
      [    2.305277] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.345480] sunxi-mmc sdc0: detmode:gpio irq
      [    2.350548] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.360066] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.369448] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.378820] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.388187] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.397550] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.407228] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    2.416208] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
      [    2.421522] sunxi-mmc sdc1: No vmmc regulator found
      [    2.427025] sunxi-mmc sdc1: No vqmmc regulator found
      [    2.432585] sunxi-mmc sdc1: No vdmmc regulator found
      [    2.438160] sunxi-mmc sdc1: No vd33sw regulator found
      [    2.443816] sunxi-mmc sdc1: No vd18sw regulator found
      [    2.449486] sunxi-mmc sdc1: No vq33sw regulator found
      [    2.455142] sunxi-mmc sdc1: No vq18sw regulator found
      [    2.461433] sunxi-mmc sdc1: set host busy
      [    2.466070] mmc:failed to get gpios
      [    2.470384] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.480844] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.515260] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.555306] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.565593] sunxi-mmc sdc1: detmode:manually by software
      [    2.567176] usbcore: registered new interface driver usbhid
      [    2.567180] usbhid: USB HID core driver
      [    2.567276] fbtft_of_value: buswidth = 8
      [    2.567282] fbtft_of_value: debug = 0
      [    2.567286] fbtft_of_value: rotate = 0
      [    2.567289] fbtft_of_value: fps = 60
      [    2.646101] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.652882] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.658909] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.687732] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.717118] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.723789] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.730483] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.737163] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.743023] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.766306] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.785293] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.815232] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.866316] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.873351] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.879334] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.907825] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.937374] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.944312] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.951276] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.958247] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.964113] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.986299] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.005335] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    3.035226] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.086847] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.094418] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.100400] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.128050] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.157953] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.165424] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.172888] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.180368] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.186250] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.206325] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.235314] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    3.265229] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.318449] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.327613] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.333574] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.358816] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.379226] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.388510] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.397690] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.405693] Console: switching to colour frame buffer device 30x30
      [    3.413281] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.413347] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.431401] graphics fb0: fb_st7789v frame buffer, 240x240, 112 KiB video memory, 4 KiB DMA buffer memory, fps=100, spi0.0 at 100 MHz
      [    3.454628] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
      [    3.466670] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
      [    3.480966] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
      [    3.495974] NET: Registered protocol family 10
      [    3.503283] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    3.511567] NET: Registered protocol family 17
      [    3.517071] NET: Registered protocol family 15
      [    3.522216] Bluetooth: RFCOMM TTY layer initialized
      [    3.527882] Bluetooth: RFCOMM socket layer initialized
      [    3.533666] Bluetooth: RFCOMM ver 1.11
      [    3.539306] Registering SWP/SWPB emulation handler
      [    3.555025] UBI error: cannot open mtd sys, error -2get det_vbus is fail, 84
      [    3.563897] get id is fail, 84
      [    3.568781] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:53 UTC (53)
      [    3.578425] clk: Not disabling unused clocks
      [    3.583238] ALSA device list:
      [    3.586705]   #0: audiocodec
      [    3.589932]   #1: snddaudio0
      [    3.593624] List of all partitions:
      [    3.597655] No filesystem could mount root, tried:  ubifs
      [    3.603736] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    3.612985] CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.191 #8
      [    3.619502] Hardware name: sun8iw21
      [    3.623432] [<c010d5a0>] (unwind_backtrace) from [<c010a694>] (show_stack+0x10/0x14)
      [    3.632098] [<c010a694>] (show_stack) from [<c017050c>] (panic+0xac/0x2b8)
      [    3.639793] [<c017050c>] (panic) from [<c09012cc>] (mount_block_root+0x258/0x300)
      [    3.648165] [<c09012cc>] (mount_block_root) from [<c0901500>] (prepare_namespace+0x118/0x178)
      [    3.657702] [<c0901500>] (prepare_namespace) from [<c0900eb4>] (kernel_init_freeable+0x144/0x178)
      [    3.667627] [<c0900eb4>] (kernel_init_freeable) from [<c066134c>] (kernel_init+0x8/0x118)
      [    3.676783] [<c066134c>] (kernel_init) from [<c0106e08>] (ret_from_fork+0x14/0x2c)
      [    3.685257] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    3.695366] sunxi dump enabled
      [    3.698774] dump regs done
      [    3.701828] flush cache done
      [    3.705061] crashdump enter
      v851se切换spinand文件系统起不来Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0),求助!!!
        away123456 LV 4 最后由 away123456 编辑
        spinand容量是256M的,nand id也都没问题
        W 1 条回复 最后回复 回复 引用 分享 0
          wyljkl LV 7 @away123456 最后由 编辑
          @away123456 内核部分spinand没有识别出来,你自己看下内核部分的配置
          A 3 条回复 最后回复 回复 引用 分享 0
            away123456 LV 4 @wyljkl 最后由 编辑
            @wyljkl 兄弟你好,内核就是按照论坛里面设置的呀
            还需要额外设置其他的嘛,求助~
              spinand勾选了这个
                @wyljkl 请问下面的要勾选么,我看到有个allwinnersoc的nand,之前是只勾选了sunxi-nand
