    T113s4的boot0启动异常
      c18842780426 LV 3 最后由 xiaowenge 编辑
      [28]HELLO! lidf===BOOT0 is starting!
      [32]BOOT0 commit : 41ad3d9-dirty
      [35]set pll start
      [41]periph0 has been enabled
      [44]set pll end
      [45][pmu]: bus read error
      [48]board init ok
      [50]enable_jtag
      [51]ZQ value = 0x2f
      [53]get_pmu_exist() = -1
      [55]DRAM BOOT DRIVE INFO: V0.34
      [58]DRAM CLK = 792 MHz
      [61]DRAM Type = 3 (2:DDR2,3:DDR3)
      [64]DRAMC read ODT  off.
      [66]DRAM ODT value: 0x42.
      [69]ddr_efuse_type: 0xa
      [72]DRAM SIZE = 256 MB
      [79]DRAM simple test OK.
      [81]rtc standby flag is 0x0, super standby flag is 0x0
      [86]dram size =256
      [89]card no is 2
      [90]sdcard 2 line count 4
      [93][mmc]: mmc driver ver 2021-05-21 14:47
      [102][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [108][mmc]: ***Try MMC card 2***
      [131][mmc]: RMCA OK!
      [133][mmc]: mmc 2 bias 0
      [136][mmc]: MMC 5.1
      [138][mmc]: HSSDR52/SDR25 4 bit
      [141][mmc]: 50000000 Hz
      [143][mmc]: 7396 MB
      [145][mmc]: ***SD/MMC 2 init OK!!!***
      [35]set pll start
      [44]set pll end
      [48]board init ok
      [50]enable_jtag
      [51]ZQ value = 0x2f
      [86]dram size =256
      [89]card no is 2
      [132][mmc]: mmc 2 bias 0
      [136][mmc]: MMC 5.1
      [143][mmc]: 7396 MB
      [145][mmc]: ***SD/MMC 2 init OK!!!****
        c18842780426 LV 3 @c18842780426 最后由 编辑
        就是一直在boot0这里循环,我看boot0初始化也没有错误,就是不加载uboot,有大佬知道怎么解决吗
