    F133进不了系统
    8589
      ccl_550427288 LV 3 最后由 whycan 编辑
      求大神们帮忙分析一下,进不了系统。
      [74]HELLO! BOOT0 is starting!
      [77]BOOT0 commit : 27369ab
      [79]set pll start
      [81]periph0 has been enabled
      [84]set pll end
      [86][pmu]: bus read error
      [88]board init ok
      [90]ZQ value = 0x2f***********
      [93]get_pmu_exist() = -1
      [95]ddr_efuse_type: 0xa
      [98][AUTO DEBUG] single rank and full DQ!
      [102]ddr_efuse_type: 0xa
      [105][AUTO DEBUG] rank 0 row = 13
      [108][AUTO DEBUG] rank 0 bank = 4
      [111][AUTO DEBUG] rank 0 page size = 2 KB
      [115]DRAM BOOT DRIVE INFO: V0.24
      [118]DRAM CLK = 528 MHz
      [120]DRAM Type = 2 (2:DDR2,3:DDR3)
      [123]DRAMC read ODT  off.
      [126]DRAM ODT off.
      [128]ddr_efuse_type: 0xa
      [130]DRAM SIZE =64 M
      [134]DRAM simple test OK.
      [136]dram size =64
      [138]card no is 0
      [140]sdcard 0 line count 4
      [142][mmc]: mmc driver ver 2021-04-2 16:45
      [152][mmc]: Wrong media type 0x0
      [155][mmc]: ***Try SD card 0***
      [163][mmc]: HSSDR52/SDR25 4 bit
      [166][mmc]: 50000000 Hz
      [168][mmc]: 14760 MB
      [170][mmc]: ***SD/MMC 0 init OK!!!***
      [218]Loading boot-pkg Succeed(index=0).
      [222]Entry_name        = opensbi
      [225]Entry_name        = u-boot
      [229]Entry_name        = dtb
      [232]mmc not para
      [233]Jump to second Boot.
      OpenSBI v0.6
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,
      U-Boot 2018.05-g0a88ac9 (Apr 30 2021 - 11:23:28 +0000) Allwinner Technology
      [00.316]DRAM:  64 MiB
      [00.318]Relocation Offset is: 01ef0000
      [00.323]secure enable bit: 0
      [00.325]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.331]flash init start
      [00.334]workmode = 0,storage type = 1
      [00.337][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
      [00.343][mmc]: get sdc_type fail and use default host:tm1.
      [00.349][mmc]: can't find node "mmc0",will add new node
      [00.354][mmc]: fdt err returned <no error>
      [00.358][mmc]: Using default timing para
      [00.361][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.379][mmc]: card_caps:0x3000000a
      [00.382][mmc]: host_caps:0x3000003f
      [00.385]sunxi flash init ok
      [00.388]line:714 init_clocks
      __clk_init: clk pll_periph0x2 already initialized
      register fix_factor clk error
      [00.398]drv_disp_init
      fdt_getprop_u32 s_pwm.pwm-base fail
      [00.414]drv_disp_init finish
      [00.416]boot_gui_init:start
      [00.419]set disp.dev2_output_type fail. using defval=0
      [00.425]boot_gui_init:finish
      54 bytes read in 2 ms (26.4 KiB/s)
      [00.454]bmp_name=bootlogo.bmp size 307254
      307254 bytes read in 15 ms (19.5 MiB/s)
      no support big size bmp[240x320] on fb[480x272]
      [00.483]show bmp on fb failed !-1
      [00.500]Loading Environment from SUNXI_FLASH... OK
      [00.519]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.530]update part info
      [00.534]update bootcmd
      [00.538]change working_fdt 0x42aafda8 to 0x42a8fda8
      [00.558]update dts
      [00.605]LCD open finish
      Android's image name: d1-f133evb1_rgb8
      [00.981]
      Starting kernel ...
      [00.983][mmc]: MMC Device 2 not found
      [00.987][mmc]: mmc 2 not find, so not exit
      [    0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
      [    0.000000] Linux version 5.4.61 (allwinner@allwinner-VirtualBox) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #6 PREEMPT Tue Nov 23 13:19:29 UTC 2021
      [    0.000000] cma: Reserved 8 MiB at 0x0000000043800000
      [    0.000000] Zone ranges:
      [    0.000000]   DMA32    [mem 0x0000000040200000-0x0000000043ffffff]
      [    0.000000]   node   0: [mem 0x0000000040200000-0x0000000043ffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x0000000043ffffff]
      [    0.000000] On node 0 totalpages: 15872
      [    0.000000]   DMA32 zone: 217 pages used for memmap
      [    0.000000]   DMA32 zone: 15872 pages, LIFO batch:3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15655
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g0a88ac9(04/30/2021-11:23:28) mbr_offset=15
      [    0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.000000] Memory: 43212K/63488K available (6068K kernel code, 663K rwdata, 2093K rodata, 192K init, 254K bss, 12084K reserved, 8192K cma-reserved)
      [    0.000000] 	Tasks RCU enabled.
      [    0.000007] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000029] riscv_timer_clockevent depends on broadcast, but no broadcast function available
      [    0.000367] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.001006] Console: colour dummy device 80x25
      [    0.001052] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.001070] pid_max: default: 32768 minimum: 301
      [    0.001283] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.001302] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.003312] ASID allocator initialised with 65536 entries
      [    0.003514] rcu: Hierarchical SRCU implementation.
      [    0.004241] devtmpfs: initialized
      [    0.022451] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
      [    0.023426] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.023460] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
      [    0.024001] pinctrl core: initialized pinctrl subsystem
      [    0.025513] NET: Registered protocol family 16
      [    0.027514] DMA: preallocated 256 KiB pool for atomic allocations
      [    0.028240] cpuidle: using governor menu
      [    0.070741] rtc_ccu: sunxi ccu init OK
      [    0.078973] clock: sunxi ccu init OK
      [    0.080000] clock: sunxi ccu init OK
      [    0.115475] iommu: Default domain type: Translated
      [    0.115672] sunxi iommu: irq = 4
      [    0.116919] SCSI subsystem initialized
      [    0.117300] usbcore: registered new interface driver usbfs
      [    0.117395] usbcore: registered new interface driver hub
      [    0.117512] usbcore: registered new device driver usb
      [    0.117734] mc: Linux media interface: v0.10
      [    0.117803] videodev: Linux video capture interface: v2.00
      [    0.119053] sunxi-msgbox-amp 3003000.msgbox: invalid resource
      [    0.119833] Advanced Linux Sound Architecture Driver Initialized.
      [    0.120607] Bluetooth: Core ver 2.22
      [    0.120704] NET: Registered protocol family 31
      [    0.120716] Bluetooth: HCI device and connection manager initialized
      [    0.120744] Bluetooth: HCI socket layer initialized
      [    0.120760] Bluetooth: L2CAP socket layer initialized
      [    0.120803] Bluetooth: SCO socket layer initialized
      [    0.121122] pwm module init!
      [    0.122759] g2d 5410000.g2d: Adding to iommu group 0
      [    0.123312] G2D: rcq version initialized.major:250
      [    0.124776] clocksource: Switched to clocksource riscv_clocksource
      [    0.137932] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.156603] thermal_sys: Registered thermal governor 'step_wise'
      [    0.156609] thermal_sys: Registered thermal governor 'user_space'
      [    0.157200] NET: Registered protocol family 2
      [    0.158093] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.158147] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.158168] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.158183] TCP: Hash tables configured (established 512 bind 512)
      [    0.158356] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.158404] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.158687] NET: Registered protocol family 1
      [    0.161422] Initialise system trusted keyrings
      [    0.161738] workingset: timestamp_bits=62 max_order=14 bucket_order=0
      [    0.169549] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.190004] Key type asymmetric registered
      [    0.190023] Asymmetric key parser 'x509' registered
      [    0.190050] io scheduler mq-deadline registered
      [    0.190060] io scheduler kyber registered
      [    0.190082] atomic64_test: passed
      [    0.191415] [DISP]disp_module_init
      [    0.192093] disp 5000000.disp: Adding to iommu group 0
      [    0.192743] [DISP] disp_init,line:2385:
      [    0.192750] smooth display screen:0 type:1 mode:4
      [    0.220917] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
      [    0.221186] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
      [    0.233514] [DISP] disp_sys_pwm_request,line:442:
      [    0.233521] disp_sys_pwm_request pwm 8 fail! -517
      [    0.233538] [DISP] disp_sys_pwm_config,line:509:
      [    0.233541] disp_sys_pwm_Config, handle is NULL!
      [    0.234200] display_fb_request,fb_id:0
      [    0.250393] disp_al_manager_apply ouput_type:1
      [    0.250539] [DISP] lcd_clk_config,line:731:
      [    0.250553] disp 0, clk: pll(198000000),clk(198000000),dclk(33000000) dsi_rate(198000000)
      [    0.250553]      clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
      [    0.250611] [DISP] disp_sys_gpio_request,line:276:
      [    0.250618] disp_sys_gpio_request failed, gpio_name=lcd_bl_en, gpio=123, value=0, ret=-517
      [    0.250633] [DISP] disp_sys_pwm_request,line:442:
      [    0.250637] disp_sys_pwm_request pwm 8 fail! -517
      [    0.251244] [DISP]disp_module_init finish
      [    0.252145] sunxi_sid_init()506 - insmod ok
      [    0.260583] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    0.261311] uart uart0: get regulator failed
      [    0.261345] uart uart0: uart0 supply uart not found, using dummy regulator
      [    0.261737] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
      [    0.261770] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [    1.067736] printk: console [ttyS0] enabled
      [    1.073671] misc dump reg init
      [    1.079686] libphy: Fixed MDIO Bus: probed
      [    1.084301] CAN device driver interface
      [    1.089001] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.096392] sunxi-ehci: EHCI SUNXI driver
      [    1.101342] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.108374] sunxi-ohci: OHCI SUNXI driver
      [    1.113626] usbcore: registered new interface driver uas
      [    1.119799] usbcore: registered new interface driver usb-storage
      [    1.126722] usbcore: registered new interface driver ums-alauda
      [    1.133414] usbcore: registered new interface driver ums-cypress
      [    1.140305] usbcore: registered new interface driver ums-datafab
      [    1.147140] usbcore: registered new interface driver ums_eneub6250
      [    1.154140] usbcore: registered new interface driver ums-freecom
      [    1.161052] usbcore: registered new interface driver ums-isd200
      [    1.167787] usbcore: registered new interface driver ums-jumpshot
      [    1.174688] usbcore: registered new interface driver ums-karma
      [    1.181346] usbcore: registered new interface driver ums-onetouch
      [    1.188349] usbcore: registered new interface driver ums-realtek
      [    1.195184] usbcore: registered new interface driver ums-sddr09
      [    1.201896] usbcore: registered new interface driver ums-sddr55
      [    1.208683] usbcore: registered new interface driver ums-usbat
      [    1.216090] sunxi_gpadc_init,1968, success
      [    1.221469] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    1.233887] sunxi-rtc 7090000.rtc: registered as rtc0
      [    1.239691] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
      [    1.248651] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    1.254524] i2c /dev entries driver
      [    1.258589] IR NEC protocol handler initialized
      [    1.264336] sunxi cedar version 1.1
      [    1.268633] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    1.274944] VE: install start!!!
      [    1.274944]
      [    1.280537] VE: cedar-ve the get irq is 6
      [    1.280537]
      [    1.286961] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
      [    1.286961]
      [    1.298615] VE: install end!!!
      [    1.298615]
      [    1.305203] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.314367] Bluetooth: HCI UART driver ver 2.3
      [    1.319385] Bluetooth: HCI UART protocol H4 registered
      [    1.325202] Bluetooth: HCI UART protocol BCSP registered
      [    1.331132] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    1.341250] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
      [    1.351331] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    1.357613] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    1.363929] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    1.370412] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    1.376855] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    1.383380] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    1.389920] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    1.396483] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    1.403542] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    1.409089] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    1.415907] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.427121] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    1.447254] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.471758] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    1.477519] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.490412] usbcore: registered new interface driver usbhid
      [    1.496858] usbhid: USB HID core driver
      [    1.502900] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.514886] usbcore: registered new interface driver snd-usb-audio
      [    1.525123] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    1.536667] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    1.548124] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.560966] sun8iw20-pinctrl 2000000.pinctrl: pin PE17 already requested by 2031000.dmic; cannot claim for 2032000.daudio
      [    1.573437] sun8iw20-pinctrl 2000000.pinctrl: pin-145 (2032000.daudio) status -22
      [    1.581912] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 145 (PE17) from group PE17  on device 2000000.pinctrl
      [    1.594243] sunxi-daudio 2032000.daudio: Error applying setting, reverse things back
      [    1.602966] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.614633] sunxi-daudio: probe of 2032000.daudio failed with error -22
      [    1.622830] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    1.634541] sunxi-daudio 2033000.daudio: regulator missing or invalid
      [    1.642543] sunxi-daudio 2034000.daudio: regulator missing or invalid
      [    1.650790] [AUDIOCODEC][sunxi_codec_parse_params][2094]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    1.650790]
      [    1.668015] [AUDIOCODEC][sunxi_codec_parse_params][2130]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    1.679635] [AUDIOCODEC][sunxi_internal_codec_probe][2266]:codec probe finished
      [    1.689551] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
      [    1.695450] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    1.705355] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    1.713776] mmc0: host does not support reading read-only switch, assuming write-enable
      [    1.724068] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    1.735655] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    1.747165] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    1.759554] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished
      [    1.767985] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
      [    1.779604] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    1.791639] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    1.803538] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
      [    1.815860] NET: Registered protocol family 10
      [    1.821729] mmc0: new high speed SDHC card at address 1234
      [    1.829169] Segment Routing with IPv6
      [    1.833522] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    1.841307] mmcblk0: mmc0:1234 SA16G 14.4 GiB
      [    1.850304] NET: Registered protocol family 17
      [    1.855786] can: controller area network core (rev 20170425 abi 9)
      [    1.862894]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    1.868003] NET: Registered protocol family 29
      [    1.872974] can: raw protocol (rev 20170425)
      [    1.880932] can: broadcast manager protocol (rev 20170425 t)
      [    1.887365] can: netlink gateway (rev 20190810) max_hops=1
      [    1.893898] Bluetooth: RFCOMM TTY layer initialized
      [    1.899589] Bluetooth: RFCOMM socket layer initialized
      [    1.905475] Bluetooth: RFCOMM ver 1.11
      [    1.910864] Loading compiled-in X.509 certificates
      [    1.919108] HDMI 2.0 driver init start!
      [    1.923438] boot_hdmi=false
      [    1.926709] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [    1.933855] HDMI2.0 module init end
      [    1.962796] sun8iw20-pinctrl 2000000.pinctrl: pin PE17 already requested by 2031000.dmic; cannot claim for 2032000.daudio
      [    1.975171] sun8iw20-pinctrl 2000000.pinctrl: pin-145 (2032000.daudio) status -22
      [    1.983553] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 145 (PE17) from group PE17  on device 2000000.pinctrl
      [    1.995854] sunxi-daudio 2032000.daudio: Error applying setting, reverse things back
      [    2.004563] sunxi-daudio: probe of 2032000.daudio failed with error -22
      [    2.015870] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
      [    2.026489] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
      [    2.037230] sunxi-audio-card 20330a0.sounddaudio1: use dummy codec for simple card.
      [    2.046148] debugfs: Directory '2033000.daudio' with parent 'snddaudio1' already present!
      [    2.057588] sunxi-audio-card 20330a0.sounddaudio1: snd-soc-dummy-dai <-> 2033000.daudio mapping ok
      [    2.069277] get ehci0-controller wakeup-source is fail.
      [    2.075347] sunxi ehci0-controller don't init wakeup source
      [    2.081575] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0008fbb58, 0x:ffffffd0040f9000, irq_no:2e
      [    2.095157] [sunxi-ehci0]: Not init ehci0
      [    2.100205] get ohci0-controller wakeup-source is fail.
      [    2.106272] sunxi ohci0-controller don't init wakeup source
      [    2.112533] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0008fc698
      [    2.123013] [sunxi-ohci0]: Not init ohci0
      [    2.128093] get ehci1-controller wakeup-source is fail.
      [    2.134074] sunxi ehci1-controller don't init wakeup source
      [    2.140383] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0008fbf18, 0x:ffffffd004a69000, irq_no:31
      [    2.155474] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    2.162710] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    2.172663] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
      [    2.204829] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    2.213787] hub 1-0:1.0: USB hub found
      [    2.218141] hub 1-0:1.0: 1 port detected
      [    2.223738] get ohci1-controller wakeup-source is fail.
      [    2.229797] sunxi ohci1-controller don't init wakeup source
      [    2.236163] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0008fca58
      [    2.246974] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    2.254199] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    2.264124] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
      [    2.339946] hub 2-0:1.0: USB hub found
      [    2.344209] hub 2-0:1.0: 1 port detected
      [    2.352722] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    2.364422] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    2.372116] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    2.381896] clk: Not disabling unused clocks
      [    2.386809] ALSA device list:
      [    2.390125]   #0: audiocodec
      [    2.393332]   #1: snddmic
      [    2.396402] cfg80211: failed to load regulatory.db
      [    2.401850]   #2: snddaudio1
      [    2.405168] alloc_fd: slot 0 not NULL!
      [    2.416601] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    2.428676] devtmpfs: mounted
      [    2.432269] Freeing unused kernel memory: 192K
      [    2.437391] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:1
      [    2.445475] This architecture does not have kernel memory protection.
      [    2.452663] Run /sbin/init as init process
      [    2.628427] random: fast init done
      [    3.127749] init: Console is alive
      [    3.131901] init: - watchdog -
      [    3.135667] init: - preinit -
      [    4.007201] random: procd: uninitialized urandom read (4 bytes read)
      formating /dev/by-name/UDISK to ext4
      /etc/preinit: line 1: mkfs.ext4: not found
      [    4.279987] mount_root: mounting /dev/root
      [    4.287901] mount_root: loading kmods from internal overlay
      [    4.404185] block: attempting to load /etc/config/fstab
      [    4.432745] block: extroot: device not present, retrying in 5 seconds
      [    5.704817] hdmi_hpd_sys_config_release
      [    6.044811]
      [    6.044811] insmod_device_driver
      [    6.044811]
      [    9.511766] block: extroot: cannot find device UDISK
      [    9.532415] procd: - early -
      [    9.535953] procd: - watchdog -
      [    9.665708] random: procd: uninitialized urandom read (4 bytes read)
      [    9.936050] procd: - watchdog -
      [    9.939931] procd: - ubus -
      [    9.943961] procd (1): /proc/109/oom_adj is deprecated, please use /proc/109/oom_score_adj instead.
      [   10.035262] random: ubusd: uninitialized urandom read (4 bytes read)
      [   10.245421] random: ubusd: uninitialized urandom read (4 bytes read)
      [   10.296144] procd: - init -
      [   11.872754] fuse: init (API version 7.31)
      [   12.151895] file system registered
      [   12.331900] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [   12.425344] usbcore: registered new interface driver uvcvideo
      [   12.474886] USB Video Class driver (1.1.1)
      [   13.004424] read descriptors
      [   13.039562] read strings
      [   17.635835] ======== XRADIO WIFI OPEN ========
      [   17.650781] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
      [   17.667359] [XRADIO] Allocated hw_priv @ (____ptrval____)
      [   17.689507] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
      [   17.709994] Oops [#1]
      [   17.712532] Modules linked in: xr829(+) iptable_filter ipt_REJECT uvcvideo videobuf2_vmalloc videobuf2_memops fuse
      [   17.724095] CPU: 0 PID: 172 Comm: kmodloader Not tainted 5.4.61 #6
      [   17.730986] sepc: ffffffe000319158 ra : ffffffe000319288 sp : ffffffe00123ba80
      [   17.739036]  gp : ffffffe0008ce8f0 tp : ffffffe00303d600 t0 : ffffffe00127b408
      [   17.747086]  t1 : 0000000000000000 t2 : 0000000000000000 s0 : ffffffe00123bab0
      [   17.755135]  s1 : 0000000000000001 a0 : 0000000000000001 a1 : 0000000000000000
      [   17.763185]  a2 : 0000000000000001 a3 : ffffffe00127b408 a4 : 0000000000000000
      [   17.771235]  a5 : 0000000000000004 a6 : 00000000000101f1 a7 : ffffffe0031df000
      [   17.779285]  s2 : ffffffe000882f10 s3 : ffffffe000882f10 s4 : ffffffe00127a668
      [   17.787334]  s5 : ffffffdf80a04e08 s6 : 0000000000000003 s7 : 0000000000000001
      [   17.795384]  s8 : 0000000000000100 s9 : 0000000000000013 s10: ffffffe000080496
      [   17.803433]  s11: ffffffdf80a16590 t3 : 0000000000000000 t4 : 0000000043840000
      [   17.811482]  t5 : 0000000043840010 t6 : 0000000000000000
      [   17.817401] sstatus: 0000000200000120 sbadaddr: 0000000000000000 scause: 000000000000000d
      [   17.830241] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [   18.044900] ---[ end trace 1a4935efe55ef2ac ]---
      [   22.905536] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
        简单修改 哪吒d1 tina sdk 的 sys_config.fex 和 board.dts,让D1s先把Linux跑起来。
        https://bbs.aw-ol.com/topic/384
        烧这里面的固件试一试
          ccl_550427288 LV 3 @whycan 最后由 编辑
          @whycan 大佬,刷了还是进不了。
          [288]HELLO! BOOT0 is starting!
          [290]BOOT0 commit : 27369ab
          [293]set pll start
          [295]periph0 has been enabled
          [298]set pll end
          [299][pmu]: bus read error
          [302]board init ok
          [304]ZQ value = 0x2f***********
          [307]get_pmu_exist() = -1
          [309]ddr_efuse_type: 0xa
          [312][AUTO DEBUG] single rank and full DQ!
          [316]ddr_efuse_type: 0xa
          [319][AUTO DEBUG] rank 0 row = 13
          [322][AUTO DEBUG] rank 0 bank = 4
          [325][AUTO DEBUG] rank 0 page size = 2 KB
          [329]DRAM BOOT DRIVE INFO: V0.24
          [332]DRAM CLK = 528 MHz
          [334]DRAM Type = 2 (2:DDR2,3:DDR3)
          [338]DRAMC read ODT  off.
          [340]DRAM ODT off.
          [342]ddr_efuse_type: 0xa
          [345]DRAM SIZE =64 M
          [348]DRAM simple test OK.
          [351]dram size =64
          [353]card no is 0
          [354]sdcard 0 line count 4
          [357][mmc]: mmc driver ver 2021-04-2 16:45
          [366][mmc]: Wrong media type 0x0
          [369][mmc]: ***Try SD card 0***
          [379][mmc]: HSSDR52/SDR25 4 bit
          [382][mmc]: 50000000 Hz
          [384][mmc]: 476 MB
          [386][mmc]: ***SD/MMC 0 init OK!!!***
          [440]Loading boot-pkg Succeed(index=0).
          [444]Entry_name        = opensbi
          [447]Entry_name        = u-boot
          [451]Entry_name        = dtb
          [454]mmc not para
          [455]Jump to second Boot.
          OpenSBI v0.6
                  |_|
          Current Hart           : 0
          PMP3    : 0x0000000000020000-0x0000000000027fff (A,
          U-Boot 2018.05-g0a88ac9-dirty (Sep 02 2021 - 15:47:05 +0800) Allwinner Technology
          [00.539]DRAM:  64 MiB
          [00.541]Relocation Offset is: 01ef0000
          [00.545]secure enable bit: 0
          [00.548]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          [00.554]flash init start
          [00.556]workmode = 0,storage type = 1
          [00.560][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
          [00.566][mmc]: get sdc_type fail and use default host:tm1.
          [00.572][mmc]: can't find node "mmc0",will add new node
          [00.577][mmc]: fdt err returned <no error>
          [00.580][mmc]: Using default timing para
          [00.584][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.603][mmc]: card_caps:0x3000000a
          [00.606][mmc]: host_caps:0x3000003f
          [00.610]sunxi flash init ok
          [00.612]line:714 init_clocks
          [00.622]drv_disp_init
          request pwm success, pwm2:pwm2:0x2000c00.
          [00.639]drv_disp_init finish
          [00.642]boot_gui_init:start
          [00.645]set disp.dev2_output_type fail. using defval=0
          [00.836]boot_gui_init:finish
          sunxi_partition_get_partno_byname: try part 1, ret = 0
          sunxi_partition_get_partno_byname: try part 2, ret = 0
          sunxi_partition_get_partno_byname: try part 3, ret = 0
          sunxi_partition_get_partno_byname: try part 4, ret = 0
          sunxi_partition_get_partno_byname: try part 5, ret = 0
          sunxi_partition_get_partno_byname: try part 6, ret = 0
          sunxi_partition_get_partno_byname: try part 7, ret = 0
          sunxi_partition_get_partno_byname: try part 8, ret = 0
          sunxi_partition_get_partno_byname: try part 9, ret = -1
          [01.244]bmp_name=bootlogo.bmp s[01.248]LCD open finish
          ize 307254
          307254 bytes read in 31 ms (9.5 MiB/s)
          [01.298]Loading Environment from SUNXI_FLASH... OK
          [01.319]out of usb burn from boot: not need burn key
          [01.329]update part info
          [01.332]update bootcmd
          [01.336]change working_fdt 0x42aafda8 to 0x42a8fda8
          [01.357]update dts
          Android's image name: d1-nezha
          [01.843]
          Starting kernel ...
          [01.846][mmc]: MMC Device 2 not found
          [01.849][mmc]: mmc 2 not find, so not exit
          [    0.000000] Linux version 5.4.61 (cube@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #44 PREEMPT Thu Sep 2 09:24:07 UTC 2021
          [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g0a88ac9-dirty(09/02/2021-15:47:05) mbr_off
          [    0.000000] Memory: 42216K/63488K available (6067K kernel code, 663K rwdata, 2093K rodata, 192K init, 254K bss, 13080K reserved, 8192K cma-reserved)
          [    0.000373] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
          [    0.001018] Console: colour dummy device 80x25
          [    0.001063] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
          [    0.001083] pid_max: default: 32768 minimum: 301
          [    0.001296] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
          [    0.001317] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
          [    0.003384] ASID allocator initialised with 65536 entries
          [    0.003589] rcu: Hierarchical SRCU implementation.
          [    0.004333] devtmpfs: initialized
          [    0.022831] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
          [    0.023804] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [    0.023840] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
          [    0.024412] pinctrl core: initialized pinctrl subsystem
          [    0.025952] NET: Registered protocol family 16
          [    0.028014] DMA: preallocated 256 KiB pool for atomic allocations
          [    0.028764] cpuidle: using governor menu
          [    0.074788] rtc_ccu: sunxi ccu init OK
          [    0.082772] clock: sunxi ccu init OK
          [    0.083930] clock: sunxi ccu init OK
          [    0.125032] iommu: Default domain type: Translated
          [    0.125232] sunxi iommu: irq = 4
          [    0.126543] SCSI subsystem initialized
          [    0.126944] usbcore: registered new interface driver usbfs
          [    0.127036] usbcore: registered new interface driver hub
          [    0.127158] usbcore: registered new device driver usb
          [    0.127365] mc: Linux media interface: v0.10
          [    0.127470] videodev: Linux video capture interface: v2.00
          [    0.128775] sunxi-msgbox-amp 3003000.msgbox: invalid resource
          [    0.129546] Advanced Linux Sound Architecture Driver Initialized.
          [    0.130215] Bluetooth: Core ver 2.22
          [    0.130310] NET: Registered protocol family 31
          [    0.130322] Bluetooth: HCI device and connection manager initialized
          [    0.130351] Bluetooth: HCI socket layer initialized
          [    0.130369] Bluetooth: L2CAP socket layer initialized
          [    0.130412] Bluetooth: SCO socket layer initialized
          [    0.130878] pwm module init!
          [    0.132616] g2d 5410000.g2d: Adding to iommu group 0
          [    0.133206] G2D: rcq version initialized.major:250
          [    0.134002] input: sunxi-keyboard as /devices/virtual/input/input0
          [    0.135569] clocksource: Switched to clocksource riscv_clocksource
          [    0.149289] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
          [    0.167871] thermal_sys: Registered thermal governor 'step_wise'
          [    0.167878] thermal_sys: Registered thermal governor 'user_space'
          [    0.168480] NET: Registered protocol family 2
          [    0.169390] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
          [    0.169442] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
          [    0.169463] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
          [    0.169479] TCP: Hash tables configured (established 512 bind 512)
          [    0.169669] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
          [    0.169716] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
          [    0.169988] NET: Registered protocol family 1
          [    0.172865] Initialise system trusted keyrings
          [    0.173178] workingset: timest!mp_bits=62 max_order=14 bucket_order=0
          [    0.181157] squashfs: version 4.0 (2009/01/31) Phillip Lougher
          [    0.202013] Key type asymmetric registered
          [    0.202032] Asymmetric key parser 'x509' registered
          [    0.202060] io scheduler mq-deadline registered
          [    0.202070] io scheduler kyber registered
          [    0.202093] atomic64_test: passed
          [    0.203515] [DISP]disp_module_init
          [    0.204167] disp 5000000.disp: Adding to iommu group 0
          [    0.204833] [DISP] disp_init,line:2385:
          [    0.204839] smooth display screen:0 type:1 mode:4
          [    0.247153] display_fb_request,fb_id:0
          [    0.262851] disp_al_manager_apply ouput_type:1
          [    0.263034] [DISP] lcd_clk_config,line:731:
          [    0.263049] disp 0, clk: pll(816000000),clk(816000000),dclk(34000000) dsi_rate(34000000)
          [    0.263049]      clk real:pll(816000000),clk(816000000),dclk(204000000) dsi_rate(150000000)
          [    0.263466] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
          [    0.264509] [DISP]disp_module_init finish
          [    0.265530] sunxi_sid_init()506 - insmod ok
          [    0.266304] pwm-regulator: supplied by regulator-dummy
          [    0.274632] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
          [    0.275118] uart uart0: get regulator failed
          [    0.275150] uart uart0: uart0 supply uart not found, using dummy regulator
          [    0.275536] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
          [    0.275633] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
          [    1.037271] printk: console [ttyS0] enabled
          [    1.042898] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
          [    1.054429] uart uart1: get regulator failed
          [    1.059272] uart uart1: uart1 supply uart not found, using dummy regulator
          [    1.067348] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
          [    1.077386] misc dump reg init
          [    1.081727] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
          [    1.088992] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
          [    1.096628] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
          [    1.103920] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
          [    1.111342] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
          [    1.117883] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
          [    1.124797] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
          [    1.132532] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
          [    1.140414] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
          [    1.148559] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
          [    1.156252] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
          [    1.162979] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
          [    1.170540] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
          [    1.178953] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
          [    1.186647] [ADDR_MGT] addr_mgt_probe: success.
          [    1.193182] libphy: Fixed MDIO Bus: probed
          [    1.197865] CAN device driver interface
          [    1.202524] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
          [    1.209864] sunxi-ehci: EHCI SUNXI driver
          [    1.214953] get ehci1-controller wakeup-source is fail.
          [    1.221001] sunxi ehci1-controller don't init wakeup source
          [    1.227277] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0008fbf20, 0x:ffffffd004078000, irq_no:31
          [    1.240823] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
          [    1.253424] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
          [    1.260708] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
          [    1.270610] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
          [    1.305613] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
          [    1.314506] hub 1-0:1.0: USB hub found
          [    1.318842] hub 1-0:1.0: 1 port detected
          [    1.324172] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
          [    1.331200] sunxi-ohci: OHCI SUNXI driver
          [    1.336349] get ohci1-controller wakeup-source is fail.
          [    1.342306] sunxi ohci1-controller don't init wakeup source
          [    1.348585] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0008fca60
          [    1.359030] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
          [    1.371570] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
          [    1.378846] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
          [    1.388686] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
          [    1.470670] hub 2-0:1.0: USB hub found
          [    1.474922] hub 2-0:1.0: 1 port detected
          [    1.480642] usbcore: registered new interface driver uas
          [    1.486849] usbcore: registered new interface driver usb-storage
          [    1.493623] usbcore: registered new interface driver ums-alauda
          [    1.500428] usbcore: registered new interface driver ums-cypress
          [    1.507271] usbcore: registered new interface driver ums-datafab
          [    1.514061] usbcore: registered new interface driver ums_eneub6250
          [    1.521091] usbcore: registered new interface driver ums-freecom
          [    1.527927] usbcore: registered new interface driver ums-isd200
          [    1.534602] usbcore: registered new interface driver ums-jumpshot
          [    1.541531] usbcore: registered new interface driver ums-karma
          [    1.548171] usbcore: registered new interface driver ums-onetouch
          [    1.555081] usbcore: registered new interface driver ums-realtek
          [    1.561914] usbcore: registered new interface driver ums-sddr09
          [    1.568653] usbcore: registered new interface driver ums-sddr55
          [    1.575325] usbcore: registered new interface driver ums-usbat
          [    1.583091] sunxi_gpadc_init,1968, success
          [    1.588726] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
          [    1.601111] sunxi-rtc 7090000.rtc: registered as rtc0
          [    1.606957] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:03 UTC (3)
          [    1.615858] sunxi-rtc 7090000.rtc: sunxi rtc probed
          [    1.621734] i2c /dev entries driver
          [    1.625809] IR NEC protocol handler initialized
          [    1.631612] sunxi cedar version 1.1
          [    1.635883] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
          [    1.642132] VE: install start!!!
          [    1.642132]
          [    1.647724] VE: cedar-ve the get irq is 6
          [    1.647724]
          [    1.654120] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
          [    1.654120]
          [    1.665721] VE: install end!!!
          [    1.665721]
          [    1.672302] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
          [    1.681539] Bluetooth: HCI UART driver ver 2.3
          [    1.686547] Bluetooth: HCI UART protocol H4 registered
          [    1.692277] Bluetooth: HCI UART protocol BCSP registered
          [    1.698229] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
          [    1.705539] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
          [    1.711989] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
          [    1.718576] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
          [    1.718576]
          [    1.727253] [XR_BT_LPM] bluesleep_probe: uart_index(1)
          [    1.736326] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
          [    1.746340] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
          [    1.752518] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
          [    1.758881] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
          [    1.765289] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
          [    1.771726] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
          [    1.778260] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
          [    1.784764] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
          [    1.791294] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
          [    1.798357] sunxi-mmc 4020000.sdmmc: Got CD GPIO
          [    1.803839] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
          [    1.810566] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    1.821723] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
          [    1.841876] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    1.866331] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
          [    1.872009] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    1.884323] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
          [    1.894345] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
          [    1.900694] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
          [    1.907081] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
          [    1.913537] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
          [    1.919997] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    1.931577] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
          [    1.938118] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
          [    1.944622] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
          [    1.951260] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
          [    1.957861] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
          [    1.967339] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    1.979494] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    1.990688] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [    1.999627] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.011230] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.035546] sunxi-mmc 4021000.sdmmc: detmode:manually by software
          [    2.043261] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [    2.050703] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
          [    2.061713] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [    2.068644] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.080555] sunxi_led_probe()1715 - start
          [    2.085296] sunxi_get_str_of_property()1560 - failed to get the string of propname led_regulator!
          [    2.095343] sunxi_register_led_classdev()1448 - led_classdev start
          [    2.103665] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    2.115310] mmc0: host does not support reading read-only switch, assuming write-enable
          [    2.127948] sunxi_led_probe()1820 - finish
          [    2.133278] usbcore: registered new interface driver usbhid
          [    2.139721] usbhid: USB HID core driver
          [    2.144081] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    2.156425] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.163986] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.170889] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [    2.182552] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.189745] usbcore: registered new interface driver snd-usb-audio
          [    2.196670] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    2.203476] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          [    2.217796] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
          [    2.229060] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
          [    2.242199] sunxi-daudio 2034000.daudio: regulator missing or invalid
          [    2.250727] [AUDIOCODEC][sunxi_codec_parse_params][2094]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
          [    2.250727]
          [    2.268009] mmc0: new high speed SD card at address 2165
          [    2.275377] mmcblk0: mmc0:2165 APPSD 476 MiB
          [    2.282875] [AUDIOCODEC][sunxi_codec_parse_params][2130]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
          [    2.295001] [AUDIOCODEC][sunxi_internal_codec_probe][2266]:codec probe finished
          [    2.303405]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
          [    2.309735] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
          [    2.315423] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
          [    2.328418] [SNDCODEC][sunxi_card_init][583]:card init finished
          [    2.337850] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
          [    2.349255] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
          [    2.361482] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished
          [    2.369848] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
          [    2.378386] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
          [    2.387498] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
          [    2.399114] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
          [    2.411305] NET: Registered protocol family 10
          [    2.417813] Segment Routing with IPv6
          [    2.422115] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
          [    2.429727] NET: Registered protocol family 17
          [    2.434765] can: controller area network core (rev 20170425 abi 9)
          [    2.441881] NET: Registered protocol family 29
          [    2.446925] can: raw protocol (rev 20170425)
          [    2.451690] can: broadcast manager protocol (rev 20170425 t)
          [    2.458054] can: netlink gateway (rev 20190810) max_hops=1
          [    2.464550] Bluetooth: RFCOMM TTY layer initialized
          [    2.470131] Bluetooth: RFCOMM socket layer initialized
          [    2.475932] Bluetooth: RFCOMM ver 1.11
          [    2.481225] Loading compiled-in X.509 certificates
          [    2.489404] HDMI 2.0 driver init start!
          [    2.493703] boot_hdmi=false
          [    2.497008] ERROR: pinctrl_get for HDMI2.0 DDC fail
          [    2.504127] HDMI2.0 module init end
          [    2.531610] twi twi2: twi2 supply twi not found, using dummy regulator
          [    2.574119] twi_stop()478 - [i2c2] STOP can't sendout!
          [    2.579856] sunxi_i2c_core_process()1632 - [i2c2] STOP failed!
          [    2.586450] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x48, dev addr: 0x38)
          [    2.595840] pcf857x: probe of 2-0038 failed with error -70
          [    2.602013] sunxi_i2c_probe()2262 - [i2c2] probe success
          [    2.612806] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
          [    2.623365] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
          [    2.633946] debugfs: Directory '2034000.daudio' with parent 'sndhdmi' already present!
          [    2.644981] sunxi-audio-card 20340a0.sounddaudio2: 20340a4.hdmiaudio <-> 2034000.daudio mapping ok
          [    2.656626] get ehci0-controller wakeup-source is fail.
          [    2.662580] sunxi ehci0-controller don't init wakeup source
          [    2.668888] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0008fbb60, 0x:ffffffd0040fc000, irq_no:2e
          [    2.682428] [sunxi-ehci0]: Not init ehci0
          [    2.687487] get ohci0-controller wakeup-source is fail.
          [    2.693453] sunxi ohci0-controller don't init wakeup source
          [    2.699732] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0008fc6a0
          [    2.710166] [sunxi-ohci0]: Not init ohci0
          [    2.717262] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [    2.728454] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [    2.736123] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
          [    2.745835] clk: Not disabling unused clocks
          [    2.750609] ALSA device list:
          [    2.753915]   #0: audiocodec
          [    2.757278] cfg80211: failed to load regulatory.db
          [    2.762719]   #1: snddmic
          [    2.765754]   #2: sndhdmi
          [    2.768688] alloc_fd: slot 0 not NULL!
          [    2.781290] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
          [    2.792319] devtmpfs: mounted
          [    2.795975] Freeing unused kernel memory: 192K
          [    2.800954] This architecture does not have kernel memory protection.
          [    2.808271] Run /sbin/init as init process
          [    3.073979] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:1
          [    3.482284] init: Console is alive
          [    3.486573] init: - watchdog -
          [    3.490162] init: - preinit -
          [    3.783009] random: procd: uninitialized urandom read (4 bytes read)
          [    4.637337] mount_root: mounting /dev/root
          [    4.643026] mount_root: loading kmods from internal overlay
          [    4.763561] block: attempting to load /etc/config/fstab
          [    4.791862] block: extroot: device not present, retrying in 5 seconds
          [    4.805643]
          [    4.805643] insmod_host_driver
          [    4.805643]
          [    4.812350] [ehci0-controller]: sunxi_usb_enable_ehci
          [    4.818082] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0008fbb60, 0x:ffffffd0040fc000, irq_no:2e
          [    4.833297] sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
          [    4.840628] sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 3
          [    4.850570] sunxi-ehci 4101000.ehci0-controller: irq 46, io mem 0x04101000
          [    4.885603] sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
          [    4.894915] hub 3-0:1.0: USB hub found
          [    4.899270] hub 3-0:1.0: 1 port detected
          [    4.904743] [ohci0-controller]: sunxi_usb_enable_ohci
          [    4.910501] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0008fc6a0
          [    4.921524] sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
          [    4.928812] sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 4
          [    4.938571] debugfs: Directory 'sunxi-ohci' with parent 'ohci' already present!
          [    4.946823] sunxi-ohci 4101400.ohci0-controller: irq 47, io mem 0x04101400
          [    5.021066] hub 4-0:1.0: USB hub found
          [    5.025319] hub 4-0:1.0: 1 port detected
          [    6.345599] hdmi_hpd_sys_config_release
          [    9.872367] block: extroot: cannot find device UDISK
          [    9.892596] procd: - early -
          [    9.896206] procd: - watchdog -
          [    9.985054] random: procd: uninitialized urandom read (4 bytes read)
          [   10.359269] procd: - watchdog -
          [   10.363136] procd: - ubus -
          [   10.368651] procd (1): /proc/112/oom_adj is deprecated, please use /proc/112/oom_score_adj instead.
          [   10.454188] random: ubusd: uninitialized urandom read (4 bytes read)
          [   10.685775] random: ubusd: uninitialized urandom read (4 bytes read)
          [   10.733129] procd: - init -
          [   12.236083] fuse: init (API version 7.31)
          [   12.606077] file system registered
          [   12.736115] usbcore: registered new interface driver uvcvideo
          [   12.742531] USB Video Class driver (1.1.1)
          [   12.748442] configfs-gadget 4100000.udc-controller: failed to start g1: -19
          [   13.345775] read descriptors
          [   13.364445] read strings
          [   17.610659] ======== XRADIO WIFI OPEN ========
          [   17.622976] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
          [   17.636683] [XRADIO] Allocated hw_priv @ (____ptrval____)
          [   17.660805] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
          [   17.696799] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
          [   17.894708] random: fast init done
          [   18.227612] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   18.238857] [XRADIO] Detect SDIO card 1
          [   18.265805] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [   18.305682] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   18.349139] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   18.356891] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   18.363754] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   18.392392] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   18.422021] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   18.429669] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   18.437341] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   18.444960] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   18.451826] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          [   20.325752] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
          [   20.433354] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   20.444534] [XRADIO] Remove SDIO card 1
          [   20.454807] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [   20.466686] [SBUS_ERR] sdio probe timeout!
          [   20.471362] [XRADIO_ERR] sbus_sdio_init failed
          [   20.477947] xradio_core_init failed (-110)!
          [   20.482721] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   20.516464] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   20.524134] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   20.531169] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   20.546626] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   20.564859] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   20.572493] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   20.580124] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   20.587596] xt_time: kernel timezone is -0000
          [   20.592486] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   20.599323] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          [   20.624500] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
          [   22.094619] ======== XRADIO WIFI OPEN ========
          [   22.100334] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
          [   22.107276] [XRADIO] Allocated hw_priv @ (____ptrval____)
          [   22.118559] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
          [   22.140276] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
          [   22.354501] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   22.365754] [XRADIO] Detect SDIO card 1
          [   22.375727] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [   22.398878] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   22.421697] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   22.429446] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   22.436347] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   22.451215] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   22.465062] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   22.472768] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   22.480576] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   22.488579] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   22.495373] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          [   24.405750] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
          [   24.513265] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   24.524490] [XRADIO] Remove SDIO card 1
          [   24.534779] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [   24.546631] [SBUS_ERR] sdio probe timeout!
          [   24.551282] [XRADIO_ERR] sbus_sdio_init failed
          [   24.557841] xradio_core_init failed (-110)!
          [   24.562616] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   24.596461] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   24.604133] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [   24.611210] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   24.626610] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   24.643801] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   24.651437] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   24.659071] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   24.666752] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [   24.673534] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          [   27.677614] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
            是卡启动吗?换一张卡试一试
              @whycan 换了3张卡了,但很奇怪屏幕有显示,但是进不了系统。
              ![SD卡设置](1.png 截图)
              [292]HELLO! BOOT0 is starting!
              [295]BOOT0 commit : 27369ab
              [297]set pll start
              [299]periph0 has been enabled
              [302]set pll end
              [304][pmu]: bus read error
              [306]board init ok
              [308]ZQ value = 0x2f***********
              [311]get_pmu_exist() = -1
              [314]ddr_efuse_type: 0xa
              [316][AUTO DEBUG] single rank and full DQ!
              [320]ddr_efuse_type: 0xa
              [323][AUTO DEBUG] rank 0 row = 13
              [326][AUTO DEBUG] rank 0 bank = 4
              [330][AUTO DEBUG] rank 0 page size = 2 KB
              [333]DRAM BOOT DRIVE INFO: V0.24
              [336]DRAM CLK = 528 MHz
              [339]DRAM Type = 2 (2:DDR2,3:DDR3)
              [342]DRAMC read ODT  off.
              [344]DRAM ODT off.
              [346]ddr_efuse_type: 0xa
              [349]DRAM SIZE =64 M
              [353]DRAM simple test OK.
              [355]dram size =64
              [357]card no is 0
              [359]sdcard 0 line count 4
              [361][mmc]: mmc driver ver 2021-04-2 16:45
              [370][mmc]: Wrong media type 0x0
              [373][mmc]: ***Try SD card 0***
              [384][mmc]: HSSDR52/SDR25 4 bit
              [387][mmc]: 50000000 Hz
              [389][mmc]: 476 MB
              [391][mmc]: ***SD/MMC 0 init OK!!!***
              [445]Loading boot-pkg Succeed(index=0).
              [449]Entry_name        = opensbi
              [452]Entry_name        = u-boot
              [456]Entry_name        = dtb
              [458]mmc not para
              [460]Jump to second Boot.
              OpenSBI v0.6
                      |_|
              Current Hart           : 0
              U-Boot 2018.05-g0a88ac9-dirty (Sep 03 2021 - 21:30:18 +0800) Allwinner Technology
              [00.543]DRAM:  64 MiB
              [00.545]Relocation Offset is: 01ef0000
              [00.550]secure enable bit: 0
              [00.552]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
              [00.558]flash init start
              [00.561]workmode = 0,storage type = 1
              [00.564][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
              [00.570][mmc]: get sdc_type fail and use default host:tm1.
              [00.576][mmc]: can't find node "mmc0",will add new node
              [00.581][mmc]: fdt err returned <no error>
              [00.585][mmc]: Using default timing para
              [00.588][mmc]: SUNXI SDMMC Controller Version:0x50310
              [00.607][mmc]: card_caps:0x3000000a
              [00.611][mmc]: host_caps:0x3000003f
              [00.614]sunxi flash init ok
              [00.616]line:714 init_clocks
              [00.627]drv_disp_init
              [00.642]drv_disp_init finish
              [00.645]boot_gui_init:start
              [00.648]set disp.dev2_output_type fail. using defval=0
              [00.654]boot_gui_init:finish
              [00.721]bmp_name=bootlogo.bmp size 307254
              307254 bytes read in 16 ms (18.3 MiB/s)
              [00.758]Loading Environment from SUNXI_FLASH... OK
              [00.779]out of usb burn from boot: not need burn key
              [00.789]update part info
              [00.792]update bootcmd
              [00.795]change working_fdt 0x42aafda8 to 0x42a8fda8
              [00.816]update dts
              [00.834]LCD open finish
              [01.302]
              Starting kernel ...
              [01.305][mmc]: MMC Device 2 not found
              [01.308][mmc]: mmc 2 not find, so not exit
              [    0.000000] Linux version 5.4.61 (cube@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #60 PREEMPT Fri Sep 3 23:03:41 UTC 2021
              [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g0a88ac9-dirty(09/03/2021-21:30:18) mbr_off
              [    0.000000] Memory: 42224K/63488K available (6067K kernel code, 663K rwdata, 2093K rodata, 192K init, 254K bss, 13072K reserved, 8192K cma-reserved)
              [    0.000377] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
              [    0.001016] Console: colour dummy device 80x25
              [    0.001062] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
              [    0.001082] pid_max: default: 32768 minimum: 301
              [    0.001299] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
              [    0.001320] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
              [    0.003408] ASID allocator initialised with 65536 entries
              [    0.003613] rcu: Hierarchical SRCU implementation.
              [    0.004367] devtmpfs: initialized
              [    0.022389] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
              [    0.023360] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
              [    0.023399] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
              [    0.023970] pinctrl core: initialized pinctrl subsystem
              [    0.025509] NET: Registered protocol family 16
              [    0.027583] DMA: preallocated 256 KiB pool for atomic allocations
              [    0.028339] cpuidle: using governor menu
              [    0.061533] rtc_ccu: sunxi ccu init OK
              [    0.069736] clock: sunxi ccu init OK
              [    0.070943] clock: sunxi ccu init OK
              [    0.114418] iommu: Default domain type: Translated
              [    0.114628] sunxi iommu: irq = 4
              [    0.115825] SCSI subsystem initialized
              [    0.116214] usbcore: registered new interface driver usbfs
              [    0.116316] usbcore: registered new interface driver hub
              [    0.116459] usbcore: registered new device driver usb
              [    0.116687] mc: Linux media interface: v0.10
              [    0.116756] videodev: Linux video capture interface: v2.00
              [    0.118012] sunxi-msgbox-amp 3003000.msgbox: invalid resource
              [    0.118776] Advanced Linux Sound Architecture Driver Initialized.
              [    0.119486] Bluetooth: Core ver 2.22
              [    0.119587] NET: Registered protocol family 31
              [    0.119600] Bluetooth: HCI device and connection manager initialized
              [    0.119629] Bluetooth: HCI socket layer initialized
              [    0.119646] Bluetooth: L2CAP socket layer initialized
              [    0.119690] Bluetooth: SCO socket layer initialized
              [    0.120041] pwm module init!
              [    0.121663] g2d 5410000.g2d: Adding to iommu group 0
              [    0.122195] G2D: rcq version initialized.major:250
              [    0.123538] clocksource: Switched to clocksource riscv_clocksource
              [    0.137072] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
              [    0.155746] thermal_sys: Registered thermal governor 'step_wise'
              [    0.155753] thermal_sys: Registered thermal governor 'user_space'
              [    0.156328] NET: Registered protocol family 2
              [    0.157253] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
              [    0.157304] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
              [    0.157328] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
              [    0.157343] TCP: Hash tables configured (established 512 bind 512)
              [    0.157525] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
              [    0.157573] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
              [    0.157837] NET: Registered protocol family 1
              [    0.160534] Initialise system trusted keyrings
              [    0.160857] workingset: timestamp_bits=62 max_order=14 bucket_order=0
              [    0.168695] squashfs: version 4.0 (2009/01/31) Phillip Lougher
              [    0.189371] Key type asymmetric registered
              [    0.189389] Asymmetric key parser 'x509' registered
              [    0.189417] io scheduler mq-deadline registered
              [    0.189428] io scheduler kyber registered
              [    0.189451] atomic64_test: passed
              [    0.190750] [DISP]disp_module_init
              [    0.191343] disp 5000000.disp: Adding to iommu group 0
              [    0.192002] [DISP] disp_init,line:2385:
              [    0.192008] smooth display screen:0 type:1 mode:4
              [    0.221195] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
              [    0.221488] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
              [    0.234739] [DISP] disp_sys_pwm_request,line:442:
              [    0.234746] disp_sys_pwm_request pwm 8 fail! -517
              [    0.234762] [DISP] disp_sys_pwm_config,line:509:
              [    0.234766] disp_sys_pwm_Config, handle is NULL!
              [    0.235482] display_fb_request,fb_id:0
              [    0.251631] disp_al_manager_apply ouput_type:1
              [    0.251776] [DISP] lcd_clk_config,line:731:
              [    0.251791] disp 0, clk: pll(198000000),clk(198000000),dclk(33000000) dsi_rate(198000000)
              [    0.251791]      clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
              [    0.251852] [DISP] disp_sys_gpio_request,line:276:
              [    0.251858] disp_sys_gpio_request failed, gpio_name=lcd_bl_en, gpio=123, value=0, ret=-517
              [    0.251873] [DISP] disp_sys_pwm_request,line:442:
              [    0.251878] disp_sys_pwm_request pwm 8 fail! -517
              [    0.252461] [DISP]disp_module_init finish
              [    0.253313] sunxi_sid_init()506 - insmod ok
              [    0.261731] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
              [    0.262367] uart uart0: get regulator failed
              [    0.262400] uart uart0: uart0 supply uart not found, using dummy regulator
              [    0.262824] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
              [    0.262856] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
              [    1.066960] printk: console [ttyS0] enabled
              [    1.072806] misc dump reg init
              [    1.078664] libphy: Fixed MDIO Bus: probed
              [    1.083284] CAN device driver interface
              [    1.087966] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
              [    1.095395] sunxi-ehci: EHCI SUNXI driver
              [    1.100413] get ehci0-controller wakeup-source is fail.
              [    1.106505] sunxi ehci0-controller don't init wakeup source
              [    1.112731] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0008fbb60, 0x:ffffffd00406e000, irq_no:2e
              [    1.126305] [sunxi-ehci0]: Not init ehci0
              [    1.131057] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
              [    1.138093] sunxi-ohci: OHCI SUNXI driver
              [    1.143096] get ohci0-controller wakeup-source is fail.
              [    1.149155] sunxi ohci0-controller don't init wakeup source
              [    1.155427] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0008fc6a0
              [    1.165886] [sunxi-ohci0]: Not init ohci0
              [    1.170943] usbcore: registered new interface driver uas
              [    1.177126] usbcore: registered new interface driver usb-storage
              [    1.184025] usbcore: registered new interface driver ums-alauda
              [    1.190691] usbcore: registered new interface driver ums-cypress
              [    1.197602] usbcore: registered new interface driver ums-datafab
              [    1.204437] usbcore: registered new interface driver ums_eneub6250
              [    1.211466] usbcore: registered new interface driver ums-freecom
              [    1.218360] usbcore: registered new interface driver ums-isd200
              [    1.225095] usbcore: registered new interface driver ums-jumpshot
              [    1.232008] usbcore: registered new interface driver ums-karma
              [    1.238656] usbcore: registered new interface driver ums-onetouch
              [    1.245664] usbcore: registered new interface driver ums-realtek
              [    1.252517] usbcore: registered new interface driver ums-sddr09
              [    1.259282] usbcore: registered new interface driver ums-sddr55
              [    1.266085] usbcore: registered new interface driver ums-usbat
              [    1.273366] sunxi_gpadc_init,1968, success
              [    1.278828] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
              [    1.291254] sunxi-rtc 7090000.rtc: registered as rtc0
              [    1.297060] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
              [    1.306058] sunxi-rtc 7090000.rtc: sunxi rtc probed
              [    1.311885] i2c /dev entries driver
              [    1.315968] IR NEC protocol handler initialized
              [    1.321713] sunxi cedar version 1.1
              [    1.325944] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
              [    1.332189] VE: install start!!!
              [    1.332189]
              [    1.337842] VE: cedar-ve the get irq is 6
              [    1.337842]
              [    1.344242] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
              [    1.344242]
              [    1.355895] VE: install end!!!
              [    1.355895]
              [    1.362392] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
              [    1.371584] Bluetooth: HCI UART driver ver 2.3
              [    1.376594] Bluetooth: HCI UART protocol H4 registered
              [    1.382351] Bluetooth: HCI UART protocol BCSP registered
              [    1.388310] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
              [    1.398149] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
              [    1.408230] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
              [    1.414505] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
              [    1.420822] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
              [    1.427313] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
              [    1.433753] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
              [    1.440279] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
              [    1.446819] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
              [    1.453345] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
              [    1.460481] sunxi-mmc 4020000.sdmmc: Got CD GPIO
              [    1.466023] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
              [    1.472776] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    1.484002] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
              [    1.504138] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    1.528650] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
              [    1.534414] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    1.547204] usbcore: registered new interface driver usbhid
              [    1.553459] usbhid: USB HID core driver
              [    1.559779] usbcore: registered new interface driver snd-usb-audio
              [    1.566792] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    1.581740] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
              [    1.593624] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
              [    1.605186] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    1.617781] NET: Registered protocol family 10
              [    1.624382] Segment Routing with IPv6
              [    1.628674] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
              [    1.636714] NET: Registered protocol family 17
              [    1.641824] can: controller area network core (rev 20170425 abi 9)
              [    1.649044] NET: Registered protocol family 29
              [    1.654083] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    1.665732] can: raw protocol (rev 20170425)
              [    1.670522] can: broadcast manager protocol (rev 20170425 t)
              [    1.677018] can: netlink gateway (rev 20190810) max_hops=1
              [    1.683707] Bluetooth: RFCOMM TTY layer initialized
              [    1.689279] Bluetooth: RFCOMM socket layer initialized
              [    1.695185] Bluetooth: RFCOMM ver 1.11
              [    1.700419] Loading compiled-in X.509 certificates
              [    1.709168] HDMI 2.0 driver init start!
              [    1.713678] boot_hdmi=false
              [    1.716928] ERROR: pinctrl_get for HDMI2.0 DDC fail
              [    1.724202] HDMI2.0 module init end
              [    1.733651] mmc0: host does not support reading read-only switch, assuming write-enable
              [    1.744437] sunxi-mmc 4020000.sdmmc: sdc set ios:blk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
              [    1.771909] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
              [    1.788349] get usb_detect_mode is fail, -22
              [    1.793120] get det_vbus is fail, -84
              [    1.797343] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
              [    1.809095] get id is fail, -84
              [    1.812871] mmc0: new high speed SD card at address 2165
              [    1.820149] cfg80211: Loading compiled-in X.509 certificates for regulatory database
              [    1.830454] mmcblk0: mmc0:2165 APPSD 476 MiB
              [    1.841007] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
              [    1.848987] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
              [    1.859026] clk: Not disabling unused clocks
              [    1.864138]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
              [    1.869283] ALSA device list:
              [    1.872603]   No soundcards found.
              [    1.876568] cfg80211: failed to load regulatory.db
              [    1.885081] alloc_fd: slot 0 not NULL!
              [    1.898414] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
              [    1.909898] devtmpfs: mounted
              [    1.913451] Freeing unused kernel memory: 192K
              [    1.918630] This architecture does not have kernel memory protection.
              [    1.925953] Run /sbin/init as init process
              [    2.498323] random: fast init done
              [    2.601168] init: Console is alive
              [    2.605520] init: - watchdog -
              [    2.609131] init: - preinit -
              [    2.858650] random: procd: uninitialized urandom read (4 bytes read)
              [    3.775346] mount_root: mounting /dev/root
              [    3.781106] mount_root: loading kmods from internal overlay
              [    3.903325] block: attempting to load /etc/config/fstab
              [    3.932039] block: extroot: device not present, retrying in 5 seconds
              [    5.563577] hdmi_hpd_sys_config_release
              [    9.013933] block: extroot: cannot find device UDISK
              [    9.033416] procd: - early -
              [    9.037897] procd: - watchdog -
              [    9.079925] random: procd: uninitialized urandom read (4 bytes read)
              [    9.411168] procd: - watchdog -
              [    9.424080] procd: - ubus -
              [    9.428060] procd (1): /proc/107/oom_adj is deprecated, please use /proc/107/oom_score_adj instead.
              [    9.513906] random: ubusd: uninitialized urandom read (4 bytes read)
              [    9.723779] random: ubusd: uninitialized urandom read (4 bytes read)
              [    9.774928] procd: - init -
              [   11.464206] fuse: init (API version 7.31)
              [   11.867475] file system registered
              [   11.887515] usbcore: registered new interface driver uvcvideo
              [   11.915704] USB Video Class driver (1.1.1)
              [   12.099732] configfs-gadget 4100000.udc-controller: failed to start g1: -19
              [   12.675667] read descriptors
              [   12.678938] read strings
              [   16.785377] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
              [   16.894103] ======== XRADIO WIFI OPEN ========
              [   16.902749] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
              [   16.910506] [XRADIO] Allocated hw_priv @ (____ptrval____)
              [   16.916864] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
              [   16.927415] Oops [#1]
              [   16.929954] Modules linked in: xr829(+) iptable_filter ipt_REJECT uvcvideo videobuf2_vmalloc videobuf2_memops fuse
              [   16.941520] CPU: 0 PID: 174 Comm: kmodloader Not tainted 5.4.61 #60
              [   16.948505] sepc: ffffffe0003190ce ra : ffffffe0003191fe sp : ffffffe000a0fa80
              [   16.956556]  gp : ffffffe0008ce8f0 tp : ffffffe00301cb40 t0 : ffffffe000a77408
              [   16.964606]  t1 : 0000000000000000 t2 : 0000000000000000 s0 : ffffffe000a0fab0
              [   16.972655]  s1 : 0000000000000001 a0 : 0000000000000001 a1 : 0000000000000000
              [   16.980705]  a2 : 0000000000000001 a3 : ffffffe000a77408 a4 : 0000000000000000
              [   16.988755]  a5 : 0000000000000004 a6 : 00000000000100cf a7 : 0000000000000200
              [   16.996805]  s2 : ffffffe000882f10 s3 : ffffffe000882f10 s4 : ffffffe000a76668
              [   17.004855]  s5 : ffffffdf80a04e08 s6 : 0000000000000003 s7 : 0000000000000001
              [   17.012905]  s8 : 0000000000000100 s9 : 0000000000000013 s10: ffffffe000080496
              [   17.020955]  s11: ffffffdf80a16590 t3 : ffffffe00002b2b8 t4 : 0000000000000101
              [   17.029003]  t5 : 0000000000000100 t6 : 0000000000040000
              [   17.034923] sstatus: 0000000200000120 sbadaddr: 0000000000000000 scause: 000000000000000d
              [   17.044962] ---[ end trace a5475755f3688b80 ]---
              [  145.986626] random: crng init done
              [  145.990431] random: 6 urandom warning(s) missed due to ratelimiting
              一直卡在这里。
              • mangogeek
                mangogeek LV 8 @ccl_550427288 最后由 编辑
                @ccl_550427288 敲个回车试试?
                C 2 条回复 最后回复 回复 引用 分享 0
                  ccl_550427288 LV 3 @mangogeek 最后由 编辑
                  @mangogeek 试了都没反应!换了板也是一样。
                  ![替代文字](2.png 图片地址)
                  原理图
                      怀疑你的串口线只能收,不能发,检查硬件连接和串口线,或者换个usb转ttl模块。
                        @whycan 感谢大神,确实是串口问题!
