    F133 RTSCTS LINE
    H/F/TV Series
    5382
    • E
      emresensoy LV 3 最后由 编辑
      Hi. I couldn't activate the RTS and CTS lines on the Mango pi sparrow F133 board. If I activate RTSCTS from the termios properties in the program (attr.c_cflag |= CRTSCTS;), it doesn't send data from the Tx line either.
      If I deactivate RTSCTS (attr.c_cflag &= ~CRTSCTS;), it sends data but doesn't make the RTS line 0.
      I'm watching the lines with a logic analyzer. I see that the CTS line is 0. But RTS doesn't change at all.
      What am I missing?
      board.dts
      &uart1 {
      	uart-has-rtscts;
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      sun8iw20p1.dtsi
      code		uart1: uart@2500400 {
      			device_type = "uart1";
      			reg = <0x0 0x02500400 0x0 0x400>;
      			sunxi,uart-fifosize = <256>;
      			clocks = <&ccu CLK_BUS_UART1>;
      			clock-names = "uart1";
      			uart1_port = <1>;
      			uart1_type = <4>;
      			status = "okay";_text
      code
      #include <stdlib.h>
      #include <termios.h>
      #include <unistd.h>
      #include <sys/ioctl.h>
      #include <sys/types.h>
      #include <sys/stat.h>
      #include <fcntl.h>
      static struct termios oldterminfo;
      void closeserial(int fd)
          tcsetattr(fd, TCSANOW, &oldterminfo);
          if (close(fd) < 0)
              perror("closeserial()");
      int openserial(char *devicename)
          int fd;
          struct termios attr;
          if ((fd = open(devicename, O_RDWR)) == -1) {
              perror("openserial(): open()");
          if (tcgetattr(fd, &oldterminfo) == -1) {
              perror("openserial(): tcgetattr()");
          attr = oldterminfo;
          attr.c_cflag |= B19200 | CRTSCTS | CLOCAL | CS7 | CSTOPB | PARENB;
          attr.c_cflag &=  ~PARODD;
          //attr.c_cflag &= ~CRTSCTS;
          attr.c_oflag = 0;
          if (tcflush(fd, TCIOFLUSH) == -1) {
              perror("openserial(): tcflush()");
          if (tcsetattr(fd, TCSANOW, &attr) == -1) {
              perror("initserial(): tcsetattr()");
          return fd;
      int setRTS(int fd, int level)
          int status;
          if (ioctl(fd, TIOCMGET, &status) == -1) {
              perror("setRTS(): TIOCMGET");
          if (level)
              status |= TIOCM_RTS;
              status &= ~TIOCM_RTS;
          if (ioctl(fd, TIOCMSET, &status) == -1) {
              perror("setRTS(): TIOCMSET");
          return 1;
      int main()
        unsigned char msg1[] = { 'G','0','1', '\r', '\n' };
        unsigned char msg0[] = { 'G','0','0', '\r', '\n' };
          int fd;
          char *serialdev = "/dev/ttyS1";
          fd = openserial(serialdev);
          if (!fd) {
              fprintf(stderr, "Error while initializing %s.\n", serialdev);
              return 1;
          setRTS(fd, 0);
          write(fd, &msg1, sizeof(msg1));
          printf("1\r\n");
          sleep(1);       /* pause 1 second */
          setRTS(fd, 1);
          write(fd, &msg0, sizeof(msg0));
          printf("0\r\n");
          closeserial(fd);
      KunYi 1 条回复 最后回复 回复 引用 分享 0
      • KunYi
        KunYi LV 8 @emresensoy 最后由 编辑
        @emresensoy
        check device tree first, check uart1_pins_a with RTS/CTS pin control
        E 2 条回复 最后回复 回复 引用 分享 0
        • E
          emresensoy LV 3 @KunYi 最后由 编辑
          • E
            @kunyi
            Thank you for your answer,
            I am attaching board.dts file's relevant section, there is PG6 to PG9, Rx Tx RTS and CTS lines,
            		function = "uart1";
            		drive-strength = <10>;
            		bias-pull-up;
            		function = "gpio_in";
            • KunYi
              KunYi LV 8 最后由 编辑
              Okay, Maybe you can try the below code
              #include <fcntl.h>
              #include <errno.h>
              #include <unistd.h>
              #include <linux/serial.h>
              #include <string.h>
              int main(int argc, char *argv[]) {
                  // Open serial port ttyS1
                  const char *device = "/dev/ttyS1";
                  int fd = open(device, O_RDWR | O_NOCTTY);
                  if (fd < 0) {
                      perror("Error opening serial port");
                      return -1;
                  // Get the current serial port settings
                  struct termios tty;
                  if (tcgetattr(fd, &tty) < 0) {
                      perror("Error getting port attributes");
                      close(fd);
                      return -1;
                  // Configure the serial port settings
                  // Clear all settings first
                  tty.c_cflag = 0;
                  tty.c_iflag = 0;
                  // Enable receiver, ignore modem control lines
                  tty.c_cflag |= CREAD | CLOCAL;
                  // Enable hardware flow control (RTS/CTS)
                  tty.c_cflag |= CRTSCTS;
                  // Set baud rate to 19200
                  cfsetispeed(&tty, B19200);
                  cfsetospeed(&tty, B19200);
                  // Set 7 bits per byte
                  tty.c_cflag |= CS7;
                  // Enable even parity bit,  without PARODD
                  tty.c_cflag |= PARENB;
                  // Set 2 stop bits
                  tty.c_cflag |= CSTOPB;
                  // Apply the new settings
                  if (tcsetattr(fd, TCSANOW, &tty) < 0) {
                      perror("Error setting port attributes");
                      close(fd);
                      return -1;
                  printf("Serial port configured successfully\n");
                  printf("Port configuration:\n");
                  printf("- Device: %s\n", device);
                  printf("- Baud rate: 19200\n");
                  printf("- Data bits: 7\n");
                  printf("- Parity: Even\n");
                  printf("- Stop bits: 2\n");
                  printf("- Flow control: RTS/CTS\n");
                  // Test string to send
                  const char *test_string = "Hello! This is UART1\n";
                  ssize_t bytes_written = write(fd, test_string, strlen(test_string));
                  if (bytes_written < 0) {
                      perror("Error writing to serial port");
                  } else {
                      printf("\nSent %zd bytes: %s", bytes_written, test_string);
                  // Keep the port open briefly to ensure transmission
                  sleep(1);
                  // Close the serial port
                  close(fd);
              • E
                This is the output of your code, when the flow control enabled, there is no UART1 output even if CTS=0,![替代文字](d223a650-c366-4acc-a85d-17cd9d29a96d-image.png 图片地址)
                if I disable CRTSCTS flow control, it pushes data to UART1 but no RTS![替代文字](e449572b-506e-4dbe-89c7-d3a1b27bf10b-image.png 图片地址)
                • E
                  SOLVED,
                  I used a device to sniff UART between F133 and slave device,
                  Its RTS CTS line corrupted, so I removed it and everything ok now,
                  thanks for your kind help
