    TinyVision LCD 无法显示
    • cabritexy
      cabritexy LV 3 最后由 编辑
      韦东山的TinyVision LCD-fb0无显示
      编译环境
      • 系统:Ubuntu 18.04
      • V853的官方SDK:
        repo init -u https://sdk.aw-ol.com/git_repo/V853Tina_Open/manifest.git -b master -m tina-v853-open.xml
      • BSP:
        https://github.com/YuzukiHD/TinyVision/releases/download/tina.0.0.2/tina-bsp-tinyvision.tar.gz
      • 按官方提供教程修改设备树、fbtft-core.c、fb_st7735V.c,并开启内核对应项
      LCD显示失败
      • 驱动可以正常挂载
      [    2.471777] fbtft_of_value: buswidth = 8
      [    2.471783] fbtft_of_value: debug = 1
      [    2.471787] fbtft_of_value: rotate = 0
      [    2.471791] fbtft_of_value: fps = 30
      [    2.472055] fb_st7789v spi0.0: fbtft_request_one_gpio: 'reset' = GPIO69
      [    2.472085] fb_st7789v spi0.0: fbtft_request_one_gpio: 'dc' = GPIO68
      [    2.472118]   >>> Initializing ST7789V!
      [    2.795038]           >>> ST7789V Initialization Step1
      [    2.891084]           >>> ST7789V Initialization Step2
      [    2.901859]           >>> ST7789V Initialization Step3
      [    2.905311]           >>> ST7789V Initialization Step4
      [    2.997770]           >>> ST7789V Initialization Step5
      [    3.364106]   >>> ST7789V Initialization Done!
      • 进系统后,ls /dev | grep fb 显示有 fb0存在
      • 使用 cat /dev/random > /dev/fb0 直接卡死无响应
      • 交叉编译如下 Framebuffer 测试代码,运行
      #include <linux/fb.h>
      #include <sys/types.h>
      #include <sys/stat.h>
      #include <fcntl.h>
      #include <sys/mman.h>
      typedef unsigned short color_t;    /* 565的屏 */
      #define BLUE    0x001F  /* 蓝色 */
      #define GREEN   0x07E0  /* 绿色 */
      #define RED     0xF800  /* 红色 */
      static struct fb_var_screeninfo __g_vinfo;    /* 显示信息 */
      static color_t *__gp_frame;                   /* 虚拟屏幕首地址 */
      int framebuffer_init (void)
          int fd = 0;
          fd = open("/dev/fb0", O_RDWR);
          if (fd == -1) {
              perror("fail to open /dev/fb0\n");
              return -1;
          ioctl(fd, FBIOGET_VSCREENINFO, &__g_vinfo);                   /* 获取显示信息 */
          printf("bits_per_pixel = %d\n", __g_vinfo.bits_per_pixel);    /* 一个像素点对应的位数,如果值为16则为565格式输出,如果值为32则为888格式输出 */
          printf("xres_virtual = %d\n", __g_vinfo.xres_virtual);        /* 虚拟x轴像素点数 */
          printf("yres_virtual = %d\n", __g_vinfo.yres_virtual);        /* 虚拟y轴像素点数 */
          printf("xres = %d\n", __g_vinfo.xres);                        /* x轴像素点数 */
          printf("yres = %d\n", __g_vinfo.yres);                        /* y轴像素点数 */
          __gp_frame = mmap(NULL,                              /* 映射区的开始地址,为NULL表示由系统决定映射区的起始地址 */
                            __g_vinfo.xres_virtual * __g_vinfo.yres_virtual * __g_vinfo.bits_per_pixel / 8,    /* 映射区大小 */
                            PROT_WRITE | PROT_READ,            /* 内存保护标志(可读可写) */
                            MAP_SHARED,                        /* 映射对象类型(与其他进程共享) */
                            fd,                                /* 有效的文件描述符 */
                            0);                                /* 被映射内容的偏移量 */
          if (__gp_frame == NULL) {
              perror("fail to mmap\n");
              return -1;
       * \brief 填充整屏
      void full_screen (color_t color)
          int i;
          color_t *p = __gp_frame;
          for (i = 0; i < __g_vinfo.xres_virtual * __g_vinfo.yres_virtual; i++) {
              *p++ = color;
      int main(int argc, const char *argv[])
          if (framebuffer_init()) {
              printf("framebuffer_init failed\n");
          while (1) {
              full_screen(RED);       /* 填充红色 */
              sleep(1);
              full_screen(GREEN);     /* 填充绿色 */
              sleep(1);
              full_screen(BLUE);      /* 填充蓝色 */
              sleep(1);
      • 显示如下信息,屏幕无信息刷新
        awwwwa LV 8 最后由 编辑
        屏幕是什么情况,背光,花屏,白屏,初始化是否写入
        cabritexy 1 条回复 最后回复 回复 引用 分享 0
        • cabritexy
          cabritexy LV 3 @awwwwa 最后由 编辑
          @awwwwa 屏幕背光常亮; cat /dev/random > /dev/fb0 时屏幕无反应
