    T113S3 I2C异常
    4205
      lztmfx LV 5 最后由 编辑
      root@TinaLinux:/# i2cdetect -y 0
      0 1 2 3 4 5 6 7 8 9 a b c d e f[ 225.484348] sunxi-i2c sunxi-i2c0: runtime resume finish
      00: [ 225.494594] sunxi-i2c sunxi-i2c0: engine-mode: start signal xfered
      [ 225.494608] sunxi-i2c sunxi-i2c0: engine-mode: [slave address:(0x3),irq state:(0x8)]
      [ 225.511400] sunxi-i2c sunxi-i2c0: engine-mode: 7bits+r/w = 0x6 xfered
      [ 225.518624] sunxi-i2c sunxi-i2c0: engine-mode: data 0x6 xfered
      [ 230.529514] sunxi-i2c sunxi-i2c0: engine-mode: xfer timeout(dev addr:0x3)
      [ 230.529546] sunxi-i2c sunxi-i2c0: runtime suspend finish
      [ 230.537143] 0x02502000: 00000000 00000000 00000000 00000000
      [ 230.549452] 0x02502010: 00000000 00000000 00000000 00000000
      -- [ 230.555922] sunxi-i2c sunxi-i2c0: runtime resume finish
      [ 230.562028] sunxi-i2c sunxi-i2c0: engine-mode: start signal xfered
      [ 235.569499] sunxi-i2c sunxi-i2c0: engine-mode: xfer timeout(dev addr:0x4)
      [ 235.569529] sunxi-i2c sunxi-i2c0: runtime suspend finish
      [ 235.577115] 0x02502000: 00000000 00000000 00000000 00000000
      [ 235.577121] 0x02502010: 00000000 00000000 00000000 00000000
      -- [ 235.595857] sunxi-i2c sunxi-i2c0: runtime resume finish
      [ 235.601971] sunxi-i2c sunxi-i2c0: engine-mode: start signal xfered
      ^C[ 240.609525] sunxi-i2c sunxi-i2c0: engine-mode: xfer timeout(dev addr:0x5)
      [ 240.609543] sunxi-i2c sunxi-i2c0: runtime suspend finish
      [ 240.617154] 0x02502000: 00000000 00000000 00000000 00000000
      [ 240.629478] 0x02502010: 00000000 00000000 00000000 00000000
      root@TinaLinux:/# i2cdetect -l
      i2c-0 i2c sunxi-i2c0 I2C adapter
      换了其他没有挂任何设备的I2C也是一样的报错,是不是kernel什么地方配置不对啊?和开源的好几个项目都对比过config配置了,不知道怎么排查了
      Z 1 条回复 最后回复 回复 引用 分享 0
        z2500abc LV 5 @lztmfx 最后由 编辑
        @lztmfx 是不是 设备树配置有问题啊,先检查下设备树的配置了
          awwwwa LV 8 最后由 编辑
          engine-mode开了,配置 下twi_drv_used = <1>;
          L 1 条回复 最后回复 回复 引用 分享 1
            lztmfx LV 5 最后由 编辑
            @z2500abc 闹乌龙了,SCL和旁边的PWM引脚连锡了,另外正常的哪路TWI也会打印许多信息,我直接把kernel 的log等级改成3就不打印这么多了
              lztmfx LV 5 @awwwwa 最后由 编辑
              @awwwwa twi_drv_used 是做什么的?以前没看到过,我试试看,我后来把kernel log等级改成3就不打印这么多了
              A Z 2 条回复 最后回复 回复 引用 分享 0
                awwwwa LV 8 @lztmfx 最后由 编辑
                @lztmfx 是否使用DMA
                  @lztmfx DMA功能的
