    implicit declaration of function 'lzma_decode'
      zhanweixin LV 5 最后由 编辑
      在V821_SDK_V1.1里,采用NOR Flash为介质,当适配SPI LCD,编译时发生如下错误
      /data/V821/V821_SDK_V1.1/kernel/linux-5.4-ansc/bsp/modules/gpu/Makefile:72: neither CONFIG_ARM nor CONFIG_ARM64 is found in .config, unsupport
      2 sun300iw1p1,/data/V821/V821_SDK_V1.1/kernel/linux-5.4-ansc, /data/V821/V821_SDK_V1.1/out/v821/kernel/build
        CC      drivers/video/backlight/backlight.o
        AR      drivers/video/backlight/built-in.a
        CC      bsp/drivers/video/sunxi/lcd_fb/dev_lcd_fb.o
        CC      bsp/drivers/video/sunxi/lcd_fb/disp_lcd.o
        CC      bsp/drivers/video/sunxi/lcd_fb/dev_fb.o
        CC      bsp/drivers/video/sunxi/lcd_fb/logo.o
      /data/V821/V821_SDK_V1.1/kernel/linux-5.4-ansc/bsp/drivers/video/sunxi/lcd_fb/logo.c: In function 'Fb_map_kernel_logo':
      /data/V821/V821_SDK_V1.1/kernel/linux-5.4-ansc/bsp/drivers/video/sunxi/lcd_fb/logo.c:228:10: error: implicit declaration of function 'lzma_decode' [-Werror=implicit-function-declaration]
        228 |   return lzma_decode(paddr, info);
      通过阅读BSP相关代码,发现在/bsp/drivers/video/sunxi/disp2/disp/dev_fb.c实现lzma_decode函数
      #if IS_ENABLED(CONFIG_DECOMPRESS_LZMA)
      int lzma_decode(uintptr_t paddr, struct fb_info *info)
      	void *vaddr = NULL;
      	long pos = 0;
      	unsigned char *out = NULL;
      	int ret = -1, i = 0;
      	struct lzma_header lzma_head;
      通过在make kernel_menuconfig里搜索CONFIG_DECOMPRESS_LZMA也已配置为Y,但为何还会发生这个现象呢?
      │ Symbol: DECOMPRESS_LZMA [=y]        │
        │ Type  : tristate        │
        │   Defined at lib/Kconfig:316        │
        │   Selected by [y]:        │
        │   - RD_LZMA [=y] && BLK_DEV_INITRD [=y]        │
        │   - AW_DISP2_FB_DECOMPRESS_LZMA [=y] && FB [=y] && AW_DISP2 [=y]        │
        │   - AW_REMOTEPROC_USE_UNLZMA [=y] && AW_BSP [=y] && AW_REMOTEPROC [=y] && AW_REMOTEPROC_DECOMPRESS_FW [=y]                                         │
        │ Symbol: AW_DISP2_FB_DECOMPRESS_LZMA [=y]        │
        │ Type  : bool        │
        │ Prompt: Framebuffer show bootlogo from lzma file        │
        │   Location:        │
        │     -> Allwinner BSP        │
        │       -> Device Drivers        │
        │ (1)     -> Video Drivers        │
        │   Defined at bsp/drivers/video/sunxi/Kconfig:59        │
        │   Depends on: FB [=y] && AW_DISP2 [=y]        │
        │   Selects: DECOMPRESS_LZMA [=y]        │
        awwwwa LV 8 最后由 编辑
        ca09e45.diff
          完美解决,万分感谢!!!
