    v821的udc 出错,dma初始化失败,gadget切换功能有问题
    3191
    • Q
      quanzhi111 LV 5 最后由 xiaowenge 编辑
      root@(none):/# dmesg | grep udc
      [    0.100478] sunxi_usb_udc 44100000.udc-controller: sunxi:sunxi_usb_udc UDC Inner DMA Feature - wordaddr: -1, extend: disabled
      [    0.100950] sunxi:sunxi_usb_udc:[INFO]: write to rise data: 0x0
      [    0.101028] sunxi:sunxi_usb_udc:[INFO]: write to trancevie data: 0xb
      [    0.101036] sunxi:sunxi_usb_udc:[INFO]: write to preemphasis data: 0x2
      [    0.101049] sunxi:sunxi_usb_udc:[INFO]: write to resistance data: 0x8
      [    0.101123] sunxi_usb_udc 44100000.udc-controller: 44100000.udc-controller supply udc not found, using dummy regulator
      [    5.507731] udc 44100000.udc-controller: failed to start g1: -19
      root@(none):/#
        awwwwa LV 8 最后由 编辑
        bsp/drivers/usb/sunxi_usb/udc/sunxi_udc.c
        unsigned static int g_dma_enable = 0;
        Q 2 条回复 最后回复 回复 引用 分享 0
        • Q
          quanzhi111 LV 5 @awwwwa 最后由 编辑
          @awwwwa 改了后打印还是一样的错误??大神后面怎么解决的?
          • Q
            @awwwwa 感谢大神!可以识别到tf卡了,再次感谢!😬
