    v821无法烧录nor flash
    3205
    • I
      indream LV 5 最后由 编辑
      [520]set pll start
      [522]set pll end
      [524]board init ok: use hosc 40M
      [527]beign to init dram
      [531]DRAM use internal ZQ!!
      [534]ZQ value = 0x2f
      [536][AUTO DEBUG] single rank and full DQ!
      [541][AUTO DEBUG] rank 0 row = 13
      [544][AUTO DEBUG] rank 0 bank = 4
      [547][AUTO DEBUG] rank 0 page size = 2 KB
      [551]DRAM BOOT DRIVE INFO: V1.00
      [554]DRAM CLK = 520 MHz
      [556]DRAM Type = 2 (2:DDR2,3:DDR3)
      [559]DRAMC read ODT off.
      [562]DRAM ODT off.
      [564]trefi: 7.8us
      [566]DRAM Size = 64 MB
      [579]DRAM simple test OK.
      [581]init dram ok
      U-Boot 2018.07 (May 04 2025 - 23:00:00 +0800) Allwinner Technology
      [02.095]DRAM:  64 MiB
      [02.133]Relocation Offset is: 01f29000, reloc addr is: 83f29000
      [02.363]secure enable bit: 0
      [02.376]CPU=614 MHz,PERI=3072 Mhz,AHB=192 Mhz, APB=96Mhz
      [02.384]sunxi flash map init
      SPI ALL:   ready
      [02.536]init_clocks:finish
      [02.539]flash init start
      [02.541]workmode = 16,storage type = 0
      sunxi_get_spif_mode()227 - get dtr_mode_enable fail -13
      sunxi_get_spif_mode()236 - get io_mode_enable fail -13
      [03.064]spif sunxi_slave->max_hz:100000000
      [44.439]flash operation timed out
      换了一块新的nor flash, 能烧一次,断电后第二次又变成这样。
        awwwwa LV 8 最后由 编辑
        flash 无响应,物料型号是否是在物料表中的支持型号?另外可以尝试降频等操作
        I 1 条回复 最后回复 回复 引用 分享 0
        • I
          indream LV 5 @awwwwa 最后由 编辑
          @awwwwa 用的PY25Q256HA,32MB。
            awwwwa LV 8 @indream 最后由 编辑
            @indream 查看 https://docs.aw-ol.com/docs/soc/v821/sys_module/spi_nor
            进行降频,降线测试
            • I
              @awwwwa 应该是flash坏了,4个flash坏了3个。第4个成功烧录😢
