    T113开发板启动时卡住了,并且无法重新烧录
      JH008 LV 3 最后由 编辑
      各位大佬,请教下,
      我的T113开发板开机后,输出以下log,然后卡住了,没有反应
      [2025-06-10 17:56:30] [29]HELLO! BOOT0 is starting!
      [2025-06-10 17:56:30] [31]BOOT0 commit : 2386bdb825
      [2025-06-10 17:56:30] [34]set pll start
      [2025-06-10 17:56:30] [36]fix vccio detect value:0xc0
      [2025-06-10 17:56:30] [43]periph0 has been enabled
      [2025-06-10 17:56:30] [46]set pll end
      [2025-06-10 17:56:30] [48][pmu]: bus read error
      [2025-06-10 17:56:30] [50]board init ok
      [2025-06-10 17:56:30] [52]enable_jtag
      [2025-06-10 17:56:30] [54]ZQ value = 0x2f
      [2025-06-10 17:56:30] [55]get_pmu_exist() = -1
      [2025-06-10 17:56:30] [58]DRAM BOOT DRIVE INFO: V0.34
      [2025-06-10 17:56:30] [61]DRAM CLK = 792 MHz
      [2025-06-10 17:56:30] [63]DRAM Type = 3 (2:DDR2,3:DDR3)
      [2025-06-10 17:56:30] [66]DRAMC read ODT off.
      [2025-06-10 17:56:30] [68]DRAM ODT value: 0x42.
      [2025-06-10 17:56:30] [71]ddr_efuse_type: 0xa
      [2025-06-10 17:56:30] [102]HELLO! BOOT0 is starting!
      [2025-06-10 17:56:30] [105]BOOT0 commit : 2386bdb825
      [2025-06-10 17:56:30] [108]set pll start
      [2025-06-10 17:56:30] [114]periph0 has been enabled
      [2025-06-10 17:56:30] [117]set pll end
      [2025-06-10 17:56:30] [118][pmu]: bus read error
      [2025-06-10 17:56:30] [121]board init ok
      [2025-06-10 17:56:30] [123]enable_jtag
      [2025-06-10 17:56:30] [125]ZQ value = 0x2f
      [2025-06-10 17:56:30] [126]get_pmu_exist() = -1
      [2025-06-10 17:56:30] [129]DRAM BOOT DRIVE INFO: V0.34
      [2025-06-10 17:56:30] [132]DRAM CLK = 792 MHz
      [2025-06-10 17:56:30] [134]DRAM Type = 3 (2:DDR2,3:DDR3)
      [2025-06-10 17:56:30] [137]DRAMC read ODT off.
      [2025-06-10 17:56:30] [140]DRAM ODT value: 0x42.
      [2025-06-10 17:56:30] [143]ddr_efuse_type: 0xa
      [2025-06-10 17:56:30] [146]DRAM SIZE = 128 MB
      [2025-06-10 17:59:45] [33]HELLO! BOOT0 is starting!
      [2025-06-10 17:59:45] [36]BOOT0 commit : 2c94b33
      [2025-06-10 17:59:45] [39]set pll start
      [2025-06-10 17:59:45] [44]periph0 has been enabled
      [2025-06-10 17:59:45] [47]set pll end
      [2025-06-10 17:59:45] [49][pmu]: bus read error
      [2025-06-10 17:59:45] [51]board init ok
      [2025-06-10 17:59:45] [53]enable_jtag
      [2025-06-10 17:59:45] [55]ZQ value = 0x2f***********
      [2025-06-10 17:59:45] [58]get_pmu_exist() = -1
      [2025-06-10 17:59:45] [61]ddr_efuse_type: 0xa
      [2025-06-10 17:59:45] [64][AUTO DEBUG] single rank and full DQ!
      [2025-06-10 17:59:45] [68]ddr_efuse_type: 0xa
      [2025-06-10 17:59:49] [29]HELLO! BOOT0 is starting!
      [2025-06-10 17:59:49] [32]BOOT0 commit : 2c94b33
      [2025-06-10 17:59:49] [34]set pll start
      [2025-06-10 17:59:49] [40]periph0 has been enabled
      [2025-06-10 17:59:49] [43]set pll end
      [2025-06-10 17:59:49] [45][pmu]: bus read error
      [2025-06-10 17:59:49] [47]board init ok
      [2025-06-10 17:59:49] [49]enable_jtag
      [2025-06-10 17:59:49] [51]ZQ value = 0x2f***********
      [2025-06-10 17:59:49] [54]get_pmu_exist() = -1
      [2025-06-10 17:59:49] [56]ddr_efuse_type: 0xa
      然后复位板子,串口也没有log输出,也无法用USB烧录。
      请问下有无其他办法让这块板子起来或者进入强制烧录模式,重新烧录镜像?
      W 1 条回复 最后回复 回复 引用 分享 0
        wyljkl LV 7 @JH008 最后由 编辑
        @jh008 短接flash重新上电就可以强制烧录
