    T113S3 主线内核 如何使能EMAC 25MHz时钟
    3697
    • B
      breaktime1903 LV 2 最后由 编辑
      内核版本是6.12.35
      内核日志如下:
      [ 0.264623] dwmac-sun8i 4500000.ethernet: IRQ eth_wake_irq not found
      [ 0.268356] ehci-platform 4200000.usb: irq 36, io mem 0x04200000
      [ 0.272992] dwmac-sun8i 4500000.ethernet: IRQ eth_lpi not found
      [ 0.273002] dwmac-sun8i 4500000.ethernet: IRQ sfty not found
      [ 0.273382] dwmac-sun8i 4500000.ethernet: PTP uses main clock
      [ 0.275620] hub 2-0:1.0: 1 port detected
      [ 0.281819] dwmac-sun8i 4500000.ethernet: Current syscon value is not the default 58000 (expect 0)
      [ 0.303961] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
      [ 0.314219] dwmac-sun8i 4500000.ethernet: No HW DMA feature register supported
      [ 0.319352] hub 1-0:1.0: USB hub found
      [ 0.323451] dwmac-sun8i 4500000.ethernet: RX Checksum Offload Engine supported
      [ 0.329956] hub 1-0:1.0: 1 port detected
      [ 0.339431] dwmac-sun8i 4500000.ethernet: COE Type 2
      [ 0.623933] usb 1-1: new high-speed USB device number 2 using ehci-platform
      [ 0.629268] dwmac-sun8i 4500000.ethernet: TX Checksum insertion supported
      [ 0.815287] hub 1-1:1.0: USB hub found
      [ 0.819142] dwmac-sun8i 4500000.ethernet: Normal descriptors
      [ 0.827001] hub 1-1:1.0: 4 ports detected
      [ 0.835403] dwmac-sun8i 4500000.ethernet: Chain mode enabled
      [ 1.263936] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
      [ 1.537277] dwmac-sun8i 4500000.ethernet: EMAC reset timeout
      [ 1.542964] dwmac-sun8i 4500000.ethernet eth0: stmmac_dvr_remove: removing driver
      [ 1.584892] dwmac-sun8i 4500000.ethernet: probe with driver dwmac-sun8i failed with error -110
      设备树配置如下:
      &emac {
      pinctrl-0 = <&rmii_pg_clk25m_pins>;
      pinctrl-names = "default";
      phy-mode = "rmii";
      phy-handle = <&ip101gr>;
      phy-supply = <&reg_3v3>;
      clocks = <&ccu CLK_BUS_EMAC>,<&ccu CLK_EMAC_25M>;
      clock-names = "stmmaceth","ephy25m";
      use_ephy25m = <1>;
      &mdio{
      reset-assert-us = <10000>;
      reset-post-delay-us = <150000>;
      reset-deassert-us = <150000>;
      reset-gpios = <&pio 6 6 GPIO_ACTIVE_LOW>; /* PG6 */
      ip101gr: ethernet-phy@0 {
      // compatible = "ethernet-phy-ieee802.3-c22";
      // compatible = "ethernet-phy-id001c.c816";
      compatible = "ethernet-phy-id0243.0c54","ethernet-phy-ieee802.3-c22";
      reg = <0>;
      现在的问题是我没办法识别出PHY,而且用示波器去看EPHY-25M引脚也没有时钟输出,问一下主线内核该怎么开启内部时钟输出?
        awwwwa LV 8 最后由 编辑
        主线内核需要IRC去问一下主线的实现,https://linux-sunxi.org/IRC
          shine1258 LV 3 最后由 编辑
          参照这个补丁修改对应的phy驱动:
          https://lore.kernel.org/netdev/20230605154010.49611-2-detlev.casanova@collabora.com/T/#u
          然后在设备树phy节点添加 clocks = <&ccu CLK_EMAC_25M>;
            shine1258 LV 3 最后由 asf66 编辑
            我对icplus的修改(内核版本6.12.0):
            diff --git a/drivers/net/phy/icplus.c b/drivers/net/phy/icplus.c
            index a00a667454a9..411ca8fbb30e 100644
            --- a/drivers/net/phy/icplus.c
            +++ b/drivers/net/phy/icplus.c
            @@ -21,6 +21,7 @@
             #include <linux/ethtool.h>
             #include <linux/phy.h>
             #include <linux/property.h>
            +#include <linux/clk.h>
             #include <asm/io.h>
             #include <asm/irq.h>
            @@ -89,6 +90,7 @@ static struct ip101g_hw_stat ip101g_hw_stats[] = {
             struct ip101a_g_phy_priv {
             	enum ip101gr_sel_intr32 sel_intr32;
             	u64 stats[ARRAY_SIZE(ip101g_hw_stats)];
            +	struct clk *clk;
             static int ip175c_config_init(struct phy_device *phydev)
            @@ -210,6 +212,11 @@ static int ip101a_g_probe(struct phy_device *phydev)
             	if (!priv)
             		return -ENOMEM;
            +	priv->clk = devm_clk_get_optional_enabled(dev, NULL);
            +	if (IS_ERR(priv->clk))
            +		return dev_err_probe(dev, PTR_ERR(priv->clk),
            +				     "failed to get phy clock\n");
             	/* Both functions (RX error and interrupt status) are sharing the same
             	 * pin on the 32-pin IP101GR, so this is an exclusive choice.
            @@ -571,6 +578,33 @@ static void ip101g_get_stats(struct phy_device *phydev,
             		data[i] = ip101g_get_stat(phydev, i);
            +static int ip101a_g_suspend(struct phy_device *phydev)
            +	struct ip101a_g_phy_priv *priv = phydev->priv;
            +	int ret = 0;
            +	if (!phydev->wol_enabled) {
            +		ret = genphy_suspend(phydev);
            +		if (ret)
            +			return ret;
            +		clk_disable_unprepare(priv->clk);
            +	return ret;
            +static int ip101a_g_resume(struct phy_device *phydev)
            ++		clk_prepare_enable(priv->clk);
            +	return genphy_resume(phydev);
             static struct phy_driver icplus_driver[] = {
             	PHY_ID_MATCH_MODEL(IP175C_PHY_ID),
            @@ -601,8 +635,9 @@ static struct phy_driver icplus_driver[] = {
             	.config_aneg	= ip101a_g_config_aneg,
             	.read_status	= ip101a_g_read_status,
             	.soft_reset	= genphy_soft_reset,
            -	.suspend	= genphy_suspend,
            -	.resume		= genphy_resume,
            +	.suspend	= ip101a_g_suspend,
            +	.resume		= ip101a_g_resume,
            +	.flags		= PHY_ALWAYS_CALL_SUSPEND,
             	.name		= "ICPlus IP101G",
             	.match_phy_device = ip101g_match_phy_device,
            @@ -618,8 +653,9 @@ static struct phy_driver icplus_driver[] = {
             	.get_sset_count = ip101g_get_sset_count,
             	.get_strings	= ip101g_get_strings,
             	.get_stats	= ip101g_get_stats,
             module_phy_driver(icplus_driver);
            &emac {
            	pinctrl-0 = <&rmii_pg_pins>;
            	phy-mode = "rmii";
            	phy-handle = <&phy1>;
            	phy-supply = <&reg_vcc3v3>;
            &mdio {
            	phy1: ethernet-phy@1 {
            		reg = <1>;
            		reset-assert-us = <5000>;
            		reset-deassert-us = <5000>;
