    v821 sample_smartIPC_demo无法正常运行
    7
    3933
    • Q
      QY157 LV 4 最后由 q1215200171 编辑
      日志如下:
      root@(none):/mnt/extsd# ./sample_smartIPC_demo -path sample_smartIPC_demo.conf
      I0101 01:00:50.172865   274 sample_smartIPC_demo.c:104] <ParseCmdLine> path:[./sample_smartIPC_demo], arg number is [3]
      I0101 01:00:50.187725   274 confparser.c:60] <createConfParser> load conf file sample_smartIPC_demo.conf ok!
      I0101 01:00:50.188644   274 sample_smartIPC_demo.c:684] <loadSampleConfig> audio test enable 0, capture 1-16000-16-1-1-1-1-/mnt/extsd/capture_, playback 1-80-/mnt/extsd/test.wav
      I0101 01:00:50.189453   274 sample_smartIPC_demo.c:779] <loadSampleConfig> H.264
      I0101 01:00:50.190427   274 sample_smartIPC_demo.c:879] <loadSampleConfig> motiondetect param: {mJudgeMotionNum:20, mMotionPdetThres:0.400000, mMotionDynamicThres:0.500000}
      I0101 01:00:50.191038   274 sample_smartIPC_demo.c:937] <loadSampleConfig> H.264
      I0101 01:00:50.191647   274 sample_smartIPC_demo.c:1005] <loadSampleConfig> mSub2nd take picture 0 interval 10 file /mnt/extsd/sub_2nd_pic cnt 10
      I0101 01:00:50.192522   274 sample_smartIPC_demo.c:1071] <loadSampleConfig> H.264
      I0101 01:00:50.193194   274 sample_smartIPC_demo.c:1139] <loadSampleConfig> three2nd take picture 0 interval 10 file /mnt/extsd/three_2nd_pic cnt 10
      I0101 01:00:50.194039   274 sample_smartIPC_demo.c:1205] <loadSampleConfig> H.264
      I0101 01:00:50.194751   274 sample_smartIPC_demo.c:1273] <loadSampleConfig> four2nd take picture 0 interval 10 file /mnt/extsd/four_2nd_pic cnt 10
      I0101 01:00:50.195152   274 sample_smartIPC_demo.c:1285] <loadSampleConfig> MainEn:1, Main2ndEn:0, SubEn:0, Sub2ndEn:0, IspAndVeLinkageEn:1, AdaptEn:1, LensMoveMaxQp:40, WbYuvEn:0, TestDuration:0
      I0101 01:00:50.195819   274 sample_smartIPC_demo.c:1304] <loadSampleConfig> MultiSensorOnlineEnable:0
      Committed_AS:       4360 kB
      I0101 01:00:50.210305   274 mpi_sys.c:854] <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      I0101 01:00:50.213994   274 mpi_sys.c:1505] <AW_MPI_SYS_Init> ISP init
      I0101 01:00:50.215011   274 isp_version.h:32] <isp_version_info> [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP603
      branch: libisp-dev
      commit: 85909eef135a0108ea1214df4886d6c741a71c39
      date  : Tue May 27 18:59:00 2025 +0800
      author: <mayifei@allwinnertech.co[ 3649.151127] sunxi:disp:[WARN]: [DE]: (0,2,0) fail
      m>
      ----------------------------[ 3649.151888] sunxi:disp:[WARN]: [DE]: get layer(0,2,0) fail
      I0101 01:00:50.215322   274 mpi_sys.c:1507] <AW_MPI_SYS_Init> ISP init done
      I0101 01:00:50.216050   274 hwdisplay.c:84] <hw_display_init>
      I0101 01:00:50.216321   274 hwdisplay.c:1020] <hwd_init> (hwd_init 1020)
      I0101 01:00:50.218615   274 hwdisplay.c:1071] <hwd_init> ret[0][2,0]ch[2]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
      I0101 01:00:50.238796   274 audio_hw.c:198] <MakeAllMixerElemsAvailable> pcm open and close, all MixerElems maybe exist.
      I0101 01:00:50.239120   274 alsa_interface.c:736] <alsaOpenMixer> open mixer:hw:0
      I0101 01:00:50.241465   274 alsa_interface.c:792] <alsaOpenMixer> set playback vol_val to value: 27, mppValue:87
      I0101 01:00:50.241841   274 alsa_interface.c:805] <alsaOpenMixer> set playback soft_vol val to value: 130, mppValue:0
      I0101 01:00:50.242093   274 alsa_interface.c:736] <alsaOpenMixer> open mixer:hw:1
      I0101 01:00:50.243814   274 sample_smartIPC_demo.c:2028] <configMainStream> main vipp0 ve_online_en:0, dma_buf_num:0, venc ch0 OnlineEnable:0, OnlineShareBufNum:0
      I0101 01:00:50.244122   274 sample_smartIPC_demo.c:2074] <co[ 3649.179690] sunxi:vin:[INFO]: video0 open
      nfigMainStream> main vipp0 tdm_speed_down_en:0
      I0101 01:00:50.244342   274 sample_smartIPC_demo.c:2094] <configMainStream> main EncppSharpAttenCoefPer: 100%
      I0101 01:00:50.244854   274 sample_smartIPC_demo.c:2106] <configMainStream> main vbvThreshSize: 1[ 3649.181800] sunxi:vin:[INFO]: [gc2083_mipi]PWR_ON!!!
      31070, vbvBufSize: 655358
      I0101 01:00:50.245204   274 video.c:138] <video_init> [ISP]video device name is vin_video0
      I0101 01:00:50.246112   274 isp_dev.c:588] <isp_video_open> [ISP]open video device[0], detect isp0 success!
      I0101 01:00:50.248623   279 mpi_sys.c:1085] <MonitorEnvVarThread> detect user environment:
      I0101 01:00:50.248933   279 mpi_sys.c:1086] <MonitorEnvVarThread> /tmp/mpp_log_level
      I0101 01:00:50.249121   279 mpi_sys.c:1087] <MonitorEnvVarThread> /tmp/mpp_venc_sei_config_param
      I0101 01:00:50.281463   274 vide[ 3649.215930] sunxi:vin:[INFO]: ve_online close
      o.c:209] <video_set_fmt> [ISP]video0 fd[9] ve_online_en=0, dma_buf_num=0
      I0101 01:00:50.284276   274 isp_dev.c:408] <isp_tdm_open> [ISP]tdm_rx device name is sunxi_tdm_rx.0
      W0101 01:00:50.284738   274 isp_dev.c:454] <isp_dev_open> [ISP_WARN]ISP0 maybe online mode, ignore tdm open failed.
      I0101 01:00:50.285208   274 isp_dev.c:480] <isp_dev_open> [ISP]open isp device[0] success!
      I0101 01:00:50.291840   274 isp_helper.c:164] <isp_ctx_save_init> [ISP]get isp_ctx from /mnt/extsd/isp0_1920_1080_15_0_gc2083_mipi_ctx_saved.bin success!!!
      I0101 01:00:50.292305   274 isp_ini_parse.c:1611] <parser_ini_info> [ISP]prefer isp config: [gc2083_mipi], 1920x1080, 15, 0, 0
      W0101 01:00:50.292836   274 isp_ini_parse.c:1628] <parser_ini_info> [ISP_WARN]cannot find gc2083_mipi_1920_1080_15_0_0 isp config, use gc2083_mipi_1920_1088_15_0_0 -> [gc2083_mipi_isp603_20241205_171656_final_rgb_suit]
      [ISP]read restrict mark_id is 0x6c00
      I0101 01:00:50.303422   274 isp.c:1718] <isp_run> [ISP]create isp0 server thread!
      W0101 01:00:50.304517   274 isp.c:3861] <isp_set_algo_freq_div> [ISP_WARN]div_ratio  = 0, the vaild ratio is [1,10]!
      I0101 01:00:50.305002   278 videoInputHw.c:5244] <VideoInputHw_CapThread> isp[0] sensor info size:1920x1080, user set size:1280x720
      I0101 01:00:50.309040   278 videoInputHw.c:5295] <VideoInputHw_CapThread> EnableVipp[0]: vfmt.bufs:3, online:0
      I0101 01:00:50.309456   278 video.c:708] <video_queue_buffer> [ISP]buffer 0 plane 0x82000000 DMABUF fd is 14
      I0101 01:00:50.309758   278 video.c:708] <video_queue_buffer> [ISP]buffer 1 plane 0x8208d000 DMABUF fd is 15
      I0101 01:00:50.310027   278 video.c:708] <video_queue_buffer> [ISP]buffer 2 plane 0x8211a000 DMABUF fd is 16
      I0101 01:00:50.310240   278 videoInputHw.c:5305] <VideoInputHw_CapThread> pVipp[0]->mstAttr.large_dma_merge_en = 0
      I0101 01:00:50.310735   282 TDMRawProcessForTools.c:591] <SaveTdmRawDataThread> pRawInfo->flagpath is /tmp/isp0_1920_1080_15_0/raw/raw_flag
      I0101 01:00:50.327197   274 videoInputHw.c:1054] <videoInputHw_ChnEnable> receive enable vipp[0] reply: 0x0!
      INFO   : cedarc <cdc_log_set_level:78>: Set log level to 5 from /etc/cedarc.conf
      [ 3649.264978] sunxi:VE:[INFO]: 469 enable_cedar_hw_clk_module(): execute set_vcu_en_regmode_to1_to0
      [ 3649.265028] sunxi:VE:[INFO]: 1264 ioctl_platform(): IOCTL_SET_CSI_IRQ_FUNC
      [ 3649.267075] sunxi:VE:[INFO]: 469 enable_cedar_hw_clk_module(): execute set_vcu_en_regmode_to1_to0
      I0101 01:00:50.334574   284 VideoEnc_Component.c:1311] <CedarvEncInit> VencChn[0] set VbrOptEn 1
      I0101 01:00:50.334929   284 VideoEnc_Component.c:1333] <CedarvEncInit> VencChn[0] set ProductCase mode: 0
      I0101 01:00:50.335448   274 sample_smartIPC_demo.c:5744] <prepare> VencChn[0] use the default venc params for product mode 0
      I0101 01:00:50.335743   274 sample_smartIPC_demo.c:5762] <prepare> VencChn[0] ispVeLink:1-1-0
      I0101 01:00:50.335977   274 sample_smartIPC_demo.c:5541] <setRegionDetectLink> VencChn[0] region_link_en: 0 -> 1
      I0101 01:00:50.336171   274 sample_smartIPC_demo.c:5546] <setRegionDetectLink> VencChn[0] tex_detect_en: 0 -> 1
      I0101 01:00:50.336347   274 sample_smartIPC_demo.c:5551] <setRegionDetectLink> VencChn[0] motion_detect_en: 0 -> 1
      I0101 01:00:50.336765   274 sam[ 3649.267142] sunxi:VE:[INFO]: 469 enable_cedar_hw_clk_module(): execute set_vcu_en_regmode_to1_to0
      ple_common_venc.c:307] <setRcVbrOptParam> VencChn[0] change RcPriority 0 -> 3
      I0101 01:00:50.337007   274 sample_common_venc.c:296] <setVencLensMovingMaxQp> VeChn[0] set LensMovingMaxQp 40
      I0101 01:00:50.337219   274 VideoEnc_Component.c:6540] <VideoEncSetLensMovingMaxQp> VencChn[0] set LensMovingMaxQp:40
      I0101 01:00:50.337469   274 VideoEnc_Component.c:7956] <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
      I0101 01:00:50.337669   274 sample_smartIPC_demo.c:5786] <prepare> mainStream vipp:0 viChn:0 veChn:0
      I0101 01:00:50.338237   274 VideoEnc_Component.c:993] <setVbvBufferConfig> bitrate: 1024 Kbps, set encode vbv size [655360]bytes, frame length threshold [131070]bytes
      I0101 01:00:50.338625   274 VideoEnc_Component.c:2474] <CedarvVideoEncInit> VencChn[0] Online Mode=1,Chn=0,BufNum=0,OnlineEnFlag=0,sensorID=0,bkID=0,VcuOn=1,MultiSensorOnlineEn=0
      I0101 01:00:50.341493   286 sample_smartIPC_demo.c:5365] <MsgQueueThread> msg queue thread start run!
      WARNING: cedarc <resetEncoderVcu:887>: reset vcu and encoder
      I0101 01:00:50.377128   289 record.c:341] <record_set_config> record[0] requestKeyFrame[0x2a2c8]
      I0101 01:00:50.377526   289 record.c:343] <record_set_config> record[0] valid[1] VeChn[0] handler[0] max file cnt[10], max file duration[60000000] file path[/mnt/extsd/mainStream]
      I0101 01:00:50.378167   289 sample_smartIPC_demo.c:4638] <getVencStreamThread> VencChn[0] stream_buf:0xb74d3020, size=138240
      E0101 01:00:50.533507   281 isp_dev.c:274] <isp_stat_process_buffer> [ISP_ERR]AEWB: stats error, skipping buffer.
      I0101 01:00:50.575969   289 record.c:432] <record_send_data> record[0] output file path[/mnt/extsd/mainStream_0.raw]
      I0101 01:00:50.590434   289 record.c:220] <openFile> record[0] open file[/mnt/extsd/mainStream_0.raw] success!
      I0101 01:00:50.590784   289 record.c:439] <record_send_data> record[0] first frame
      I0101 01:00:50.591035   289 record.c:476] <record_send_data> record[0] got I frame
      W0101 01:00:50.600942   281 isp_dev.c:1093] <isp_sensor_get_flip> [ISP_WARN]gc2083_mipi get sensor_flip failed: Invalid argument (22).
      I0101 01:00:51.329550   285 VideoEnc_Component.c:9926] <SEIThread> veChn[0] offline sei get ispDev[0] from vipp[0]
        awwwwa LV 8 最后由 编辑
        为啥说无法正常运行,这不是码流都已经编码保存了
        Q 1 条回复 最后回复 回复 引用 分享 0
        • Q
          QY157 LV 4 @awwwwa 最后由 编辑
          @awwwwa 现在rtsp不正常, 无法打开rtsp视频
          M 1 条回复 最后回复 回复 引用 分享 0
            momoyu LV 5 @QY157 最后由 编辑
            @qy157 检查一下你sample_smartIPC_demo.conf的配置?
            • Q
              QY157 LV 4 @momoyu 最后由 编辑
              @momoyu 如果正常启动的话 应该会打印出rtsp的地址, 我看了源码 应该会展示出来,现在好像没有运行到rtsp server 的启动的日志那里
              W 1 条回复 最后回复 回复 引用 分享 0
                wowx LV 3 @QY157 最后由 编辑
                @qy157 打印没有看到rtsp地址,那可能是你conf的rtsp选项设置成了-1,改成0即可
                • Q
                  QY157 LV 4 @winner_fornm 最后由 编辑
                  @winner_fornm
                  main_enable = 1 #0:disable main stream, 1:enable main stream
                  main_rtsp_id = 0 #-1:disable main rtsp
                  是这些吗? 只要保证主码流有不就行吗?
