    T507怎么修改boot0里面的DRAM配置?
      yozad LV 3 最后由 编辑
      因为买的飞x家的开发板,但是他们家的uboot是不开源的,所以想着从全志的公版SDK中的u-boot-2018试着将uboot驱动起来替换掉他家的uboot。
      核心板用的是江波龙的EMMC(8G)和力积的A3T4GF40BBF(四片,共2GB)。
      烧飞x的固件,boot0日志如下:
      [87]HELLO! BOOT0 is starting!
      [90]BOOT0 commit : 75fd24e
      [93]set pll start
      [95]periph0 has been enabled
      [98]set pll end
      [101]PMU: AXP858
      [106]dram return write ok
      [108]board init ok
      [110]debug:rtc h-m-s value:0x32325
      [114]DRAM BOOT DRIVE INFO: V0.648
      [117]the chip id is 0x7c00
      [120]chip id check OK
      [123]DRAM_VCC set to 1500 mv
      [126]DRAM CLK =672 MHZ
      [128]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [137]Actual DRAM SIZE =2048 M
      [140]DRAM SIZE =2048 MBytes, para1 = 30fa, para2 = 8001000, dram_tpr13 = 6041
      [153]DRAM simple test OK.
      [155]rtc standby flag is 0x0, super standby flag is 0x0
      [161]dram size =2048
      [164]Use rtc to store dram tuning para
      [168]card no is 2
      [169]sdcard 2 line count 8
      [172][mmc]: mmc driver ver 2020-07-21-202106151039
      [183][mmc]: Wrong media type 0x0, but host is sdc2, try mmc first
      [189][mmc]: Try MMC card 2
      [213][mmc]: RMCA OK!
      [215][mmc]: bias 4
      [219][mmc]: MMC 5.1
      [221][mmc]: HSSDR52/SDR25 8 bit
      [224][mmc]: 50000000 Hz
      [227][mmc]: 7456 MB
      [229][mmc]: SD/MMC 2 init OK!!!
      [263]Loading boot-pkg Succeed(index=0).
      [266]Entry_name = u-boot
      [276]Entry_name = monitor
      [280]Entry_name = dtb
      [283]tunning data addr:0x4a0003e8
      [287]Jump to second Boot.
      NOTICE: BL3-1: v1.0(debug):be96482
      NOTICE: BL3-1: Built : 18:32:32, 2021-04-21
      NOTICE: BL3-1 commit: 8
      NOTICE: cpuidle init version V2.0
      ERROR: Error initializing runtime service tspd_fast
      NOTICE: BL3-1: Preparing for EL3 exit to normal world
      NOTICE: BL3-1: Next image address = 0x4a000000
      ▒OTICE: BL3-1: Next image spsr = 0x1d3
      U-Boot 2018.05 (Jul 25 2024 - 12:28:34 +0800) Allwinner Technology
      现在直接烧写evb板子的固件,日志如下:
      [118]HELLO! BOOT0 is starting!
      [121]BOOT0 commit : c52ec7a
      [124]set pll start
      [127]periph0 has been enabled
      [130]set pll end
      [132]PMU: AXP858
      [142]vaild para:1 select dram para0
      [146]board init ok
      [148]DRAM BOOT DRIVE INFO: V0.651
      [151]the chip id is 0x7c00
      [154]chip id check OK
      [156]DRAM_VCC set to 1500 mv
      [159]DRAM CLK =672 MHZ
      [162]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [170]Actual DRAM SIZE =128 M
      [173]DRAM SIZE =128 MBytes, para1 = 20f7, para2 = 801000, dram_tpr13 = 6041
      [186]DRAM simple test OK.
      [189]rtc standby flag is 0x0, super standby flag is 0x0
      [194]dram size =128
      [197]Use rtc to store dram tuning para
      [201]card no is 2
      [203]sdcard 2 line count 8
      [206][mmc]: mmc driver ver 2020-07-21-202106151039
      [216][mmc]: Wrong media type 0x0, but host is sdc2, try mmc first
      [222][mmc]: Try MMC card 2
      [247][mmc]: RMCA OK!
      [249][mmc]: bias 4
      [253][mmc]: MMC 5.1
      [255][mmc]: HSSDR52/SDR25 8 bit
      [258][mmc]: 50000000 Hz
      [260][mmc]: 7456 MB
      [262][mmc]: SD/MMC 2 init OK!!!
      [294]Loading boot-pkg Succeed(index=0).
      [298]Entry_name = u-boot
      [307]Entry_name = monitor
      [311]Entry_name = dtb
      [315]tunning data addr:0x4a0003e8
      [318]Jump to second Boot.
      NOTICE: BL3-1: v1.0(debug):f0130ea
      NOTICE: BL3-1: Built : 10:23:13, 2022-04-14
      从日志可以看出,evb的固件DRAM SIZE识别到的有问题,所以刷机之后无法启动。
      请教各位大神,这个要怎么修改呢?
