    A133无25M时钟输出
      lijianwei652 LV 2 最后由 编辑
      A133+RTL8211F方案,RTL8211 25M采用外部时钟,由A133的PH13(EPHY0_25)提供,用户将产品摔坏后返厂修复,发现PH13无25M时钟输出,以至于RTL8211不断复位,网口起不来。日志如下:
      [ OK ] Started Regular background program processing daemon.
      [ OK ] Started D-Bus System Message Bus.
      [ OK ] Started Save initial kernel messages after boot.
      Starting Remove Stale Onli…t4 Metadata Check Snapshots...
      [ OK ] Started ifup for eth0.
      Starting Initialize hardware monitoring sensors...
      Starting LSB: Load kernel …d to enable cpufreq scaling...
      Starting Dispatcher daemon for systemd-networkd...
      Starting Raise network interfaces...
      [ OK ] Started ntp-systemd-netif.service.
      Starting System Logging Service...
      Starting Login Service...
      Starting xinit custom service...
      [ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
      [ OK ] Finished Save/Restore Sound Card State.
      [ OK ] Finished Initialize hardware monitoring sensors.
      [ 94.891850] sunxi-gmac gmac0 eth0: No PHY found!
      [ OK ] Reached target Sound Card.
      [ OK ] Started System Logging Service.
      [ 94.971602] PVR_K: 1837: Read BVNC 22.102.54.38 from HW device registers
      [ 94.979320] PVR_K: 1837: RGX Device registered with BVNC 22.102.54.38
      [ OK ] Finished xinit custom service.
      [ OK ] Started LSB: Load kernel m…ded to enable cpufreq scaling.
      Starting LSB: set CPUFreq kernel parameters...
      [ OK ] Started Login Service.
      [ OK ] Started LSB: set CPUFreq kernel parameters.
      [FAILED] Failed to start Raise network interfaces.
      See 'systemctl status networking.service' for details.
      [ OK ] Reached target Network.
      [ OK ] Reached target Network is Online.
      Starting 360safe security monitoring service...
      [ OK ] Started AlphaDog Activation Startup Service.
      Starting dnsmasq - A light…DHCP and caching DNS server...
      [ OK ] Started Feed PMU Watchdog Service.
      Starting LSB: Brings up/down network automatically...
      Starting /etc/rc.local Compatibility...
      [ 95.329714] rc.local[1986]: use /etc/last_shutdown_time
      Starting OpenBSD Secure Shell server...
      [ 95.353968] rc.local[1990]: Sun 02 Mar 2025 09:55:01 PM CST
      Starting Permit User Sessions...
      [ 95.382056] rc.local[1986]: rc.local enter at 2025-03-02 21:55:01
      [ 95.409135] rc.local[1986]: modules install
      Starting LSB: HPA's tftp server...
      [ OK ] Started 360safe security monitoring service.
      [ OK ] Finished Permit User Sessions.
      [ OK ] Started OpenBSD Secure Shell server.
      [ OK ] Started LSB: HPA's tftp server.
      Starting Daily apt download activities...
      Starting Online ext4 Metad…a Check for All Filesystems...
      Starting Disca[ 95.668324] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x37)
      rd unused bl…filesystems from [ 95.678666] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x37)
      /etc/fstab...
      [ 95.696829] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x37)
      Starting Message of the Day...
      [ 95.719932] sunxi-gmac gmac0 eth0: No PHY found!
      Starting Rotate log files...
      [ OK ] Finished Online ext4 Metadata Check for All Filesystems.
      [ OK ] Finished Message of the Day.
      [ 95.859877] sunxi-gmac gmac0 eth0: No PHY found!
      [ 95.925180] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x37)
      [ 95.936052] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x37)
      [ 95.945964] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x37)
      [ 95.987873] sunxi-gmac gmac0 eth0: No PHY found!
      [ OK ] Finished Rotate log files.
      [ OK ] Started Dispatcher daemon for systemd-networkd.
      [ 96.123859] sunxi-gmac gmac0 eth0: No PHY found!
