    V3s 驱动 RTL8723DS 蓝牙,出了这个问题,请问怎么解决呢?
    rtl8723ds 蓝牙
    6438
      memory LV 7 最后由 whycan 编辑
      https://www.cnblogs.com/tid-think/p/13100009.html
      正常用 rtk_hciattach 是这样的:
      root@airfly:/# rtk_hciattach -n -s 115200 /dev/ttyS1 rtk_h5 &
      root@airfly:/# Realtek Bluetooth init uart with init speed:115200, type:HCI UART H5
      Realtek Bluetooth :Realtek hciattach version 3.1.0099684.20181218-163903
      Realtek Bluetooth :Use epoll
      Realtek Bluetooth :[SYNC] Get SYNC Resp Pkt
      Realtek Bluetooth :[CONFIG] Get SYNC pkt
      Realtek Bluetooth :[CONFIG] Get CONFG pkt
      Realtek Bluetooth :[CONFIG] Get CONFG resp pkt
      Realtek Bluetooth :dic is 1, cfg field 0x14
      Realtek Bluetooth :H5 init finished
      Realtek Bluetooth :Realtek H5 IC
      Realtek Bluetooth :Receive cmd complete event of command: 1001
      Realtek Bluetooth :HCI Version 0x08
      Realtek Bluetooth :HCI Revision 0x000c
      Realtek Bluetooth :LMP Subversion 0x8821
      Realtek Bluetooth :Receive cmd complete event of command: fc6d
      Realtek Bluetooth :Read ROM version 01
      Realtek Bluetooth :EVersion 1
      Realtek Bluetooth :IC: RTL8821CS
      Realtek Bluetooth :Firmware/config: rtl8821cs_fw, rtl8821cs_config
      Realtek Bluetooth :Couldnt access customer BT MAC file /opt/bdaddr
      Realtek Bluetooth :Couldnt open extra config /opt/rtk_btconfig.txt, No such file or directory
      Realtek Bluetooth :Original Cfg len 25
      Realtek Bluetooth :Config baudrate: 04928002
      Realtek Bluetooth :uart flow ctrl: 0
      Realtek Bluetooth :55 ab 23 87 13 00 0c 00 10 02 80 92 04 50 c5 ea
      Realtek Bluetooth :19 e1 1b fd af 5b 01 a4 0b
      Realtek Bluetooth :Cfg length 25
      Realtek Bluetooth :Vendor baud from Config file: 04928002
      Realtek Bluetooth :Load FW /lib/firmware/rtlbt/rtl8821cs_fw OK, size 40448
      Realtek Bluetooth :rtb_get_fw_project_id: opcode 0, len 1, data 10
      Realtek Bluetooth :FW version 0xaa7b2a21, Patch num 2
      Realtek Bluetooth :Chip id 0x0001
      Realtek Bluetooth :Chip id 0x0002
      Realtek Bluetooth :Patch length 0x6078
      Realtek Bluetooth :Start offset 0x00003d40
      Realtek Bluetooth :Svn version:    20445
      Realtek Bluetooth :Coexistence: BTCOEX_20180125-2828
      Realtek Bluetooth :FW  exists, Config file  exists
      Realtek Bluetooth :Total len 24721 for fwc
      Realtek Bluetooth :baudrate in change speed command: 0x02 0x80 0x92 0x04
      Realtek Bluetooth :Receive cmd complete event of command: fc17
      Realtek Bluetooth :Received cc of vendor change baud
      Realtek Bluetooth :Final speed 1500000
      Realtek Bluetooth :end_idx: 98, lp_len: 25, additional pkts: 1
      Realtek Bluetooth :Start downloading...
      Realtek Bluetooth :Last packet 227
      Realtek Bluetooth :Send last pkt
      Realtek Bluetooth :Disable host hw flow control
      Realtek Bluetooth :h5_hci_reset: Issue hci reset cmd
      Realtek Bluetooth :Receive cmd complete event of command: 0c03
      Realtek Bluetooth :Received cc of hci reset cmd
      Realtek Bluetooth :Init Process finished
      Realtek Bluetooth post process
      Device setup complete
      可是我的是这样的:
      Realtek Bluetooth :Realtek Bluetooth init uart with init speed:115200, type:HCI UART H5
      Realtek Bluetooth :Realtek hciattach ve[   32.487000] vcc3v0: disabling
      rsion 3.1.8905594.20200602-140152
      Realtek Bluetooth :Use epo[   32.491457] vcc5v0: disabling
      ll
      Realtek Bluetooth :HCI Revision 0x000d
      Realtek Bluetooth :LMP Subversion 0x8723
      Realtek Bluetooth :Read ROM version 02
      Realtek Bluetooth :EVersion 2
      Realtek Bluetooth :IC: RTL8723DS
      Realtek Bluetooth :Firmware/config: rtl8723d_fw, rtl8723d_config
      Realtek Bluetooth :Origin cfg len 10
      Realtek Bluetooth :55 ab 23 87 04 00 d9 00 01 0f
      Realtek Bluetooth :Vendor baud from Config file: 00000000
      Realtek Bluetooth :New cfg len 10
      Realtek Bluetooth :Load FW /lib/firmware/rtlbt/rtl8723d_fw OK, size 52080
      Realtek Bluetooth :rtb_get_fw_project_id: opcode 0, len 1, data 9
      Realtek Bluetooth :FW version 0x828a96f1, Patch num 3
      Realtek Bluetooth :Chip id 0x0003
      Realtek Bluetooth :Patch length 0x81e8
      Realtek Bluetooth :Start offset 0x00004940
      Realtek Bluetooth :Svn version:    22030
      Realtek Bluetooth :Coexistence: BTCOEX_20190509-2f2f
      Realtek Bluetooth :Total len 33266 for fwc
      Realtek Bluetooth :No baud from Config file, set baudrate: 115200, 0x0252c014
      Realtek Bluetooth :end_idx: 132, lp_len: 2, additional pkts: 0
      Realtek Bluetooth WARN: Patch pkt trans timeout, re-trans
      Realtek Bluetooth ERROR: h5_download_patch: Retransmission exhausts
        memory LV 7 最后由 编辑
        # rtk_hciattach_2  -n -s 115200 /dev/ttyS1 rtk_h5
        Realtek Bluetooth :Origin cfg len 48
        Realtek Bluetooth :55 ab 23 87 2a 00 0c 00 10 02 80 92 04 50 c5 ea
        Realtek Bluetooth :19 e1 1b fd af 5f 01 a4 0b d9 00 01 0f e4 00 01
        Realtek Bluetooth :08 f3 00 01 0c f4 00 08 01 00 01 90 00 00 09 04
        Realtek Bluetooth :uart flow ctrl: 1
        Realtek Bluetooth :New cfg len 48
        Realtek Bluetooth :Load FW /lib/firmware/rtlbt/rtl8723d_fw OK, size 52096
        Realtek Bluetooth :FW version 0xaa7add92, Patch num 3
        Realtek Bluetooth :Patch length 0x81b8
        Realtek Bluetooth :Start offset 0x00004980
        Realtek Bluetooth :Svn version:    20318
        Realtek Bluetooth :Coexistence: BTCOEX_20180125-2323
        Realtek Bluetooth :Total len 33256 for fwc
        Realtek Bluetooth :end_idx: 131, lp_len: 244, additional pkts: 0
        Realtek Bluetooth :Enable host hw flow control
        [   43.857766] Bluetooth: HCI UART driver ver 2.3
        [   43.862265] Bluetooth: HCI UART protocol H4 registered
        [   43.867623] Bluetooth: HCI UART protocol BCSP registered
        [   43.873240] Bluetooth: HCI UART protocol LL registered
        [   43.878465] Bluetooth: HCI UART protocol ATH3K registered
        [   43.883983] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [   43.890604] Bluetooth: HCI UART protocol Intel registered
        [   43.896317] Bluetooth: HCI UART protocol Broadcom registered
        [   43.902191] Bluetooth: HCI UART protocol QCA registered
        [   43.907516] Bluetooth: HCI UART protocol AG6XX registered
        [   43.913019] Bluetooth: HCI UART protocol Marvell registered
        Realtek Bluetooth :Realtek Bluetooth post process
        Realtek Bluetooth :Device setup complete
        搞定, 从全志的D1哪吒 SDK扣 固件和 rtk_attach出来就完事了!
          memory LV 7 最后由 编辑
          rtk_hciattach 编译:
          cd /opt/D1/tina_d1_open/package/utils/rtk_hciattach/src
          CC=/opt/v3s/dreamer_v1/output/host/bin/arm-linux-gnueabihf-gcc make
          固件位置:
          /opt/D1/tina_d1_open/package/firmware/linux-firmware/rtl8723ds
          复制到文件系统位置:
          lib/firmware/rtlbt/
          • U
            ubuntu LV 7 最后由 whycan 编辑
            Realtek Bluetooth ERROR: Can't set line discipline 22, Invalid argument
            Realtek Bluetooth ERROR: Can't initialize device 22, Invalid argument
            为什么我的V3s Linux3.4 初始化8723DS蓝牙会出这个错误?
            M 1 条回复 最后回复 回复 引用 分享 0
              memory LV 7 @ubuntu 最后由 编辑
              @ubuntu
              这个错误可以不用理,直接怼个 btstack 就能用了。
                memory LV 7 最后由 编辑
                看我的,V3s 8723DS 跑 a2dp_sink_demo,完全OK
