    【飞凌嵌入式T153开发板+OK153-S开发板开箱篇】
    • G
      guochongxin LV 3 最后由 编辑
      最近,收到飞凌嵌入式和全志在线的开发板试用活动板卡:OK153-S,我们做了一些简单的使用记录。
      一、开箱照
      下面是两张开箱照:
      整体包装还是挺不错的,包含了如下物件:
      二、开发板基本配置
      我们这次拿到的开发板OK153-S,使用的SOC是全志T153MX-BCX,搭配了512MB DDR3L和8GB eMMC配置。关于全志T153这款SOC,有如下几种配置对照表:
      该款SOC的系统框图如下:
      三、上电体验
      我们将开发板接上适配器上电,并将板卡的电源开关切到开状态,同时接上调试串口(位于TF卡槽与IR头之间的Type-C口),其与电脑相连,电脑会识别为两个串口设备(使用了USB转双UART芯片CH342,将SOC的Debug Serial port接到其中一路了),我们使用第一路,配置波特率为115200,对板卡上电后,开发板烧录的固件在启动后,调试串口有如下打印信息输出:
      [242]HELLO! BOOT0 is starting!
      [244]BOOT0 commit : {06543bc6-dirty}
      [249][pmu]: bus read error
      [252]set pll start
      [253]set pll end
      [255]vaild para:1  select dram para0
      [258]ic board init ok
      [260]card no is 2
      [262]sdcard 2 line count 8
      [265][mmc]: mmc driver ver 2025-03-10 09:47
      [274][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [280][mmc]: ***Try MMC card 2***
      [303][mmc]: RMCA OK!
      [307][mmc]: MMC 5.1
      [309][mmc]: HSSDR52/SDR25 8 bit
      [312][mmc]: 50000000 Hz
      [314][mmc]: 8456 MB
      [316][mmc]: ***SD/MMC 2 init OK!!!***
      [321]DRAM BOOT DRIVE INFO: V0.16
      [324]DRAM use external ZQ
      [326]DRAM CLK = 933 MHz
      [328]DRAM Type = 3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [359] Rank0 Dbyte0 delay =  0x0
      [362] Rank0 Dbyte0 phy delay =  0x0
      [365] Rank0 Dbyte1 delay =  0x0
      [368] Rank0 Dbyte1 phy delay =  0x0
      [373] Rank0 Dbyte0 delay =  0x48
      [376] Rank0 Dbyte0 phy delay =  0x48
      [379] Rank0 Dbyte1 delay =  0x45
      [382] Rank0 Dbyte1 phy delay =  0x45
      [385]DRAM SIZE = 512 MBytes, para1 = 30fa, para2 = 2000001, dram_tpr13 = 8007071
      [396]DRAM simple test OK.
      [398]dram size = 512
      [492]Loading boot-pkg Succeed(index=0).
      [496]Entry_name        = u-boot
      [506]Entry_name        = optee
      [510]tunning data addr:0x435003e8
      [513]Jump to OPTEE: optee_base = 0x42900000, uboot_base = 0x43500000
      M/TC: OP-TEE version: e9d62ab8 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jun 27 02:37:21 UTC 2025 arm
      M/TC: OP-TEE 32bit
      [00.725]ns16550_serial serial@2600000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
      U-Boot 2023.04-rc4-gf6c9ec46 (Sep 19 2025 - 12:37:26 +0800) Allwinner Technology
      U-Boot bsp-gfd75eab (Sep 19 2025 - 12:37:26 +0800) Allwinner Technology
      14/40 CPU:   SUNXI Family
      Model: sun8iw22
      DRAM:  512 MiB
      Working FDT set to 5d640bf0
      E/TC:0   fdt_getprop_u32:364 prop trace_level not found
      [00.832][mmc]: mmc driver ver uboot2023:2025-04-02 14:45:00
      [00.839][mmc]: get sdc_type fail and use default host:tm4.
      [00.845][mmc]: SUNXI SDMMC Controller Version:0x50530
      [00.852][mmc]: 200 MHz...
      [00.854][mmc]: sample: 17 - 147(ps)
      [00.858][mmc]: ds: 17 - 147(ps)
      [00.860]set_sunxi_flash_curdev...45:cur_sunxi_flash :mmc@04022000.sunxi_flash
      SUNXI SD/MMC: 0
      Core:  155 devices, 27 uclasses, devicetree: separate
      WDT:   Not starting watchdog@0x02050000
      MMC:   [00.890][mmc]: mmc 2 cmd timeout 100 status 100
      [00.894][mmc]: smc 2 err, cmd 8,  RTO
      [00.897][mmc]: mmc 2 close bus gating and reset
      [00.902][mmc]: give up reinit
      [00.905][mmc]: mmc 2 cmd timeout 100 status 100
      [00.909][mmc]: smc 2 err, cmd 55,  RTO
      [00.913][mmc]: mmc 2 close bus gating and reset
      [00.917][mmc]: give up reinit
      [00.940][mmc]: Best spd md: 4-HS400, freq: 4-150000000, Bus width: 8
      In:    serial
      Out:   serial
      Err:   serial
      [00.959]skip update boot_param
      get 50 probe success
      FORLINX: auth pass!
      Writing to env...
      Net:   [00.984]No ethernet found.
      [01.007]Fail to get reset clk for rst_bus_de_sys
      [01.011]Fail to get de's irq!
      [01.029]failed to request regulator(power0-supply): -2
      [01.034]failed to request regulator(power1-supply): -2
      [01.039]failed to request regulator(power2-supply): -2
      [01.044]failed to request enable0-gpios GPIO: -2
      [01.048]failed to request enable1-gpios GPIO: -2
      [01.052]failed to request enable2-gpios GPIO: -2
      [01.057]failed to request reset GPIO: -2
      [01.060]panel_lvds_probe: Cannot get backlight: -19
      [01.067]Using display timing dts
      lvds0@0002000:  detailed mode clock 72000 kHz, flags[5]
          H: 1280 1420 1430 1440
          V: 0800 0802 0822 0823
      bus_format: 1011
      2160122 bytes read in 10 ms (206 MiB/s)
      [01.109]no free wb active signal slot
      Working FDT set to 42000000
      ret 0
      [01.391]The storage not support sample function
      [01.406]Item0 (Map) magic is bad
      [01.409]the secure storage item0 copy0 magic is bad
      [01.413]Item0 (Map) magic is bad
      [01.416]the secure storage item0 copy1 magic is bad
      [01.421]Item0 (Map) magic is bad
      Hit any key to stop autoboot (Spacebar):  0
      SUNXI AMP: sunxi amp cpu on finish
      ## Booting Android Image at 0x40007800 ...
      Kernel load addr 0x40008000 size 7348 KiB
      ## Flattened Device Tree blob at 42000000
         Booting using the fdt blob at 0x42000000
         XIP Kernel Image
         Using Device Tree in place at 42000000, end 42042fff
      [02.845]can`t not get hyper image base in /chosen/hyper
      [    0.000000] Linux version 5.10.198 (root@ece33336930b) (arm-linux-gnueabihf-gcc (GCC) 11.3.1 20220604 [releases/gcc-11 revision 591c0f4b92548e3ae2e8173f4f93984b1c7f62bb], GNU ld (Linaro_Binutils-2022.06) 2.37.20220122) #1 SMP PREEMPT Fri Sep 19 11:26:51 CST 2025
      [    0.000000] OF: fdt: Machine model: sun8iw22
      [    0.000000] OF: reserved mem: OVERLAP DETECTED!
      [    0.000000] arm_rtos_mem_fw@44000000 (0x44000000--0x44200000) overlaps with e907_mem_fw@44000000 (0x44000000--0x44200000)
      [    0.000000] AW BSP version: 4483a49eab, 2025-09-11 13:12:43 +0800
      [    0.002674] /cpus/cpu@0 missing clock-frequency property
      [    0.002737] /cpus/cpu@1 missing clock-frequency property
      [    0.007654] /cpus/cpu@2 missing clock-frequency property
      [    0.012990] /cpus/cpu@3 missing clock-frequency property
      [    0.094259] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
      [    0.101333] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
      [    0.108394] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
      [    0.140243] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: base is 0, num is 8
      [    0.141810] sunxi:pwmcs-20b0000.pwmcs1:[ERR]: base is 8, num is 8
      [    0.299069] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: manual set ocr
      [    0.334876] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: manual set ocr
      [    0.369726] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: manual set ocr
      [    0.396630] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
      [    0.397467] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
      [    0.400704] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    0.400711] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    0.400716] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    0.400721] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    0.662051] mdio_bus stmmac-0: MDIO device at address 1 is missing.
      [    0.744448] sunxi:irrx-2083000.irrx:[ERR]: sunxi_irrx_resource_get: get ir protocol failed
      [    0.804923] sunxi:sunxi_sid:[ERR]: Fail to read 'dvfs2_ori' in dts
      [    0.823737] sunxi-can 453c800.can0: can sys reset deasserted
      [    0.857182] sunxi:twi-2513000.twi3:[ERR]: drv-mode: Timeout when sending 9th SCL clk
      [    0.865834] sunxi:twi-2513000.twi3:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
      [    0.875237] sunxi:twi-2513000.twi3:[ERR]: drv-mode: xfer failed (dev addr:0x51)
      [    0.883431] rtc-pcf8563 3-0051: pcf8563_write_block_data: err=-22 addr=0e, data=03
      [    0.891894] rtc-pcf8563 3-0051: pcf8563_probe: write error
      [    1.019619] sunxi:twi-2513000.twi3:[ERR]: drv-mode: Timeout when sending 9th SCL clk
      [    1.028269] sunxi:twi-2513000.twi3:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
      [    1.037617] sunxi:twi-2513000.twi3:[ERR]: drv-mode: xfer failed (dev addr:0x14)
      [    1.045793] Goodix-TS 3-0014: i2c test failed attempt 1: -22
      [    1.089620] sunxi:twi-2513000.twi3:[ERR]: drv-mode: Timeout when sending 9th SCL clk
      [    1.098262] sunxi:twi-2513000.twi3:[ERR]: drv mode: TWI BUS error state is drv:0x1 eng:0x20
      [    1.107593] sunxi:twi-2513000.twi3:[ERR]: drv-mode: xfer failed (dev addr:0x14)
      [    1.115766] Goodix-TS 3-0014: i2c test failed attempt 2: -22
      [    1.159578] Goodix-TS 3-0014: I2C communication failure: -22
      [    1.180121] debugfs: Directory 'soc@3000000:codec_plat' with parent 'audiocodec' already present!
      [    1.193033] debugfs: Directory '2033000.i2s1_plat' with parent 'sndi2s1' already present!
      [    1.406714] sunxi-rfkill soc@3000000:rfkill: get gpio chip_en failed
      [    1.413871] sunxi-rfkill soc@3000000:rfkill: get gpio power_en failed
      [    1.421342] sunxi-rfkill soc@3000000:rfkill: get gpio wlan_regon failed
      Starting syslogd: OK
      Starting klogd: OK
      Running sysctl: OK
      Populating /dev using udev: [    1.710766] udevd[151]: specified group 'input' unknown
      [    1.717223] udevd[151]: specified group 'kvm' unknown
      [    1.734400] udevd[151]: specified group 'xenomai' unknown
      done
      Initializing random number generator: OK
      Saving random seed: OK
      Starting system message bus: dbus[264]: Unknown username "pulse" in message bus configuration file
      done
      Starting iptables: OK
      wlan0     Link encap:Ethernet  HWaddr 78:BE:81:20:30:4E
      Realtek Bluetooth :Realtek Bluetooth init uart with init speed:115200, type:HCI UART H5
      Realtek Bluetooth :Realtek hciattach version 3.1.8c8cc93.20230801-094614
      Realtek Bluetooth :Use epoll
      Realtek Bluetooth :[SYNC] Get SYNC Resp Pkt
      Realtek Bluetooth :[CONFIG] Get SYNC pkt
      Realtek Bluetooth :[CONFIG] Get CONFG pkt
      Realtek Bluetooth :[CONFIG] Get CONFG resp pkt
      Realtek Bluetooth :dic is 1, cfg field 0x14
      Realtek Bluetooth :H5 init finished
      Realtek Bluetooth :Realtek H5 IC
      Starting network: Realtek Bluetooth :Receive cmd complete event of command: fc61
      Realtek Bluetooth :LMP Subversion 0xbeef
      Realtek Bluetooth :Receive cmd complete event of command: 1001
      Realtek Bluetooth :HCI Version 0x08
      Realtek Bluetooth :HCI Revision 0x000c
      Realtek Bluetooth :LMP Subversion 0x8821
      bluetoothd[274]: Bluetooth daemon 5.54
      Realtek Bluetooth :Receive cmd complete event of command: fc6d
      Realtek Bluetooth :Read ROM version 01
      Realtek Bluetooth :EVersion 1
      Realtek Bluetooth :IC: RTL8821CS
      Realtek Bluetooth :Firmware/config: rtl8821c_fw, rtl8821c_config
      Realtek Bluetooth :Couldnt open extra config /opt/rtk_btconfig.txt, No such file or directory
      Realtek Bluetooth :Couldnt open BT MAC file /opt/bdaddr, No such file or directory
      Realtek Bluetooth :Origin cfg len 41
      Realtek Bluetooth :55 ab 23 87 23 00 0c 00 10 02 80 92 04 50 c5 ea
      Realtek Bluetooth :19 e1 1b fd af 5f 01 a4 0b d9 00 01 0f e4 00 01
      Realtek Bluetooth :08 8d 00 01 fa 8f 00 01 bf
      Realtek Bluetooth :Config baudrate: 04928002
      Realtek Bluetooth :uart flow ctrl: 1
      Realtek Bluetooth :Vendor baud from Config file: 04928002
      Realtek Bluetooth :New cfg len 41
      Realtek Bluetooth :Load FW /lib/firmware/rtlbt/rtl8821c_fw OK, size 54892
      Realtek Bluetooth :rtb_get_fw_project_id: opcode 0, len 1, data 10
      Realtek Bluetooth :FW version 0x0bc6d607, Patch num 2
      Realtek Bluetooth :Chip id 0x0001
      Realtek Bluetooth :Chip id 0x0002
      Realtek Bluetooth :Patch length 0x8964
      Realtek Bluetooth :Start offset 0x00004cc0
      Realtek Bluetooth :Svn version: 199569780
      Realtek Bluetooth :Coexistence: BTCOEX_20220309-5b5b
      Realtek Bluetooth :FW  exists, Config file  exists
      Realtek Bluetooth :Total len 35213 for fwc
      Realtek [    3.797602] udevd[152]: specified group 'input' unknown
      Bluetooth :baudrate in change sp[    3.806188] udevd[152]: specified group 'kvm' unknown
      eed command: 0x02 0x80 0x92 0x04
      bluetoothd[274]: Starting SDP server
      bluetoothd[274]: Failed [    3.819123] udevd[152]: specified group 'xenomai' unknown
      to init battery plugin
      Realtek Bluetooth :Receive cmd complete event of command: fc17
      Realtek Bluetooth :Received cc of vendor change baud
      bluetoothd[274]: Bluetooth management interface 1.18 initialized
      Realtek Bluetooth :Final speed 1500000
      Realtek Bluetooth :end_idx: 139, lp_len: 185, additional pkts: 7
      Realtek Bluetooth :Start downloading...
      OK
      starting weston... done.
      Starting matrix-browser: Date: 2025-12-29 CST
      [05:14:45.601] weston 10.0.0
                     https://wayland.freedesktop.org
                     Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
                     Build: 10.0.0
      [05:14:45.601] Command line: /usr/bin/weston --backend=drm-backend.so --tty=1 --use-pixman
      [05:14:45.601] OS: Linux, 5.10.198, #1 SMP PREEMPT Fri Sep 19 11:26:51 CST 2025, armv7l
      [05:14:45.601] Flight recorder: enabled
      [05:14:45.601] warning: XDG_RUNTIME_DIR "/var/run" is not configured
      correctly.  Unix access mode must be 0700 (current mode is 0755),
      and must be owned by the user UID 0 (current owner is UID 0).
      Refer to your distribution on how to get it, or
      http://www.freedesktop.org/wiki/Specifications/basedir-spec
      on how to implement it.
      [05:14:45.603] Using config file '/etc/xdg/weston/weston.ini'
      [05:14:45.603] Output repaint window is -1 ms maximum.
      [05:14:45.604] Loading module '/usr/lib/libweston-10/drm-backend.so'
      [05:14:45.606] initializing drm backend
      [05:14:45.606] Trying weston_launch launcher...
      [05:14:45.606] could not get launcher fd from env
      [05:14:45.606] Trying direct launcher...
      [05:14:45.608] using /dev/dri/card0
      [05:14:45.608] DRM: supports atomic modesetting
      [05:14:45.608] DRM: supports GBM modifiers
      [05:14:45.608] DRM: supports picture aspect ratio
      [05:14:45.608] couldn't fstat launcher tty: Bad file descriptor
      [05:14:45.627] event0  - sunxi_ir_recv: is tagged by udev as: Keyboard Pointingstick Joystick
      [05:14:45.628] event0  - sunxi_ir_recv: device is a pointer
      [05:14:45.628] event0  - sunxi_ir_recv: device is a keyboard
      [05:14:45.629] event1  - sunxi-gpadc2/channel0/input0: not tagged as supported input device
      Realtek Bluetooth :Send additional packet 13
      Realtek Bluetooth :Send additional packet 14
      Realtek Bluetooth :Send additional packet 15
      Realtek Bluetooth :Send additional packet 16
      Realtek Bluetooth :Send additional packet 17
      Realtek Bluetooth :Send additional packet 18
      Realtek Bluetooth :Last packet 147
      Realtek Bluetooth :Send last pkt
      Realtek Bluetooth :Enable host hw flow control
      [05:14:45.729] event1  - not using input device '/dev/input/event1'
      [05:14:45.731] event2  - sunxi-gpadc2/channel1/input0: not tagged as supported input device
      [05:14:45.829] event2  - not using input device '/dev/input/event2'
      [05:14:45.831] event3  - sunxi-gpadc2/channel2/input0: not tagged as supported input device
      [05:14:45.929] event3  - not using input device '/dev/input/event3'
      [05:14:45.931] event4  - sunxi-gpadc2/channel3/input0: not tagged as supported input device
      [05:14:46.009] event4  - not using input device '/dev/input/event4'
      [05:14:46.011] event6  - audiocodec Headphones: is tagged by udev as: Keyboard Switch
      [05:14:46.011] event6  - audiocodec Headphones: device is a keyboard
      [05:14:46.013] event5  - soc@3000000:gpio-keys: is tagged by udev as: Keyboard
      [05:14:46.013] event5  - soc@3000000:gpio-keys: device is a keyboard
      Realtek Bluetooth :h5_hci_reset: Issue hci reset cmd
      Realtek Bluetooth :Receive cmd complete event of command: 0c03
      Realtek Bluetooth :Received cc of hci reset cmd
      Realtek Bluetooth :Init Process finished
      Realtek Bluetooth :Realtek Bluetooth post process
      Realtek Bluetooth :Device setup complete
      [05:14:46.062] libinput: configuring device "sunxi_ir_recv".
      [05:14:46.062] libinput: configuring device "audiocodec Headphones".
      [05:14:46.062] libinput: configuring device "soc@3000000:gpio-keys".
      [05:14:46.064] DRM: head 'LVDS-1' updated, connector 115 is connected, EDID make 'unknown', model 'unknown', serial 'unknown'
      [05:14:46.065] DRM: head 'LVDS-1' found, connector 115 is connected, EDID make 'unknown', model 'unknown', serial 'unknown'
      [05:14:46.065] Registered plugin API 'weston_drm_output_api_v1' of size 12
      [05:14:46.065] Color manager: no-op
      [05:14:46.065] Output 'LVDS-1' using color profile: built-in default sRGB SDR profile
      [05:14:46.071] DRM: output LVDS-1 uses shadow framebuffer.
      [05:14:46.071] Output LVDS-1 (crtc 100) video modes:
                     1280x800@60.8, preferred, current, 72.0 MHz
      [05:14:46.071] associating input device event0 with output LVDS-1 (none by udev)
      [05:14:46.071] associating input device event6 with output LVDS-1 (none by udev)
      [05:14:46.071] associating input device event5 with output LVDS-1 (none by udev)
      [05:14:46.071] Output 'LVDS-1' enabled with head(s) LVDS-1
      [05:14:46.072] Compositor capabilities:
                     arbitrary surface rotation: yes
                     screen capture uses y-flip: no
                     cursor planes: yes
                     arbitrary resolutions: no
                     view mask clipping: yes
                     explicit sync: no
                     color operations: no
                     presentation clock: CLOCK_MONOTONIC, id 1
                     presentation clock resolution: 0.000000001 s
      [05:14:46.073] Loading module '/usr/lib/weston/desktop-shell.so'
      [05:14:46.075] launching '/usr/libexec/weston-keyboard'
      [05:14:46.077] Note: support for the deprecated wl_shell interface is disabled. If a legacy client still needs it, it can be re-enabled by passing -Ddeprecated-wl-shell=true to Meson when building Weston.
      [05:14:46.077] launching '/usr/libexec/weston-desktop-shell'
      OK
      could not load cursor 'dnd-move'
      could not load cursor 'dnd-copy'
      could not load cursor 'dnd-none'
      usb0 current mode:
      Starting adb: OK
      init adb main
      Handling main()
      Starting lighttpd: OK
      Starting sshd: OK
      /dev/by-name/UDISK already format
      Starting vsftpd: OK
      boot total use 9498 ms
      root@OKT153:/# swu_param: ####
      swu_software: ####
      swu_mode: ####
      root@OKT153:/#
      root@OKT153:/#
      至此,飞凌OK153-S开发板的开箱体验结束,接下来还有关于该开发板的进一步体验会整理出来跟大家分享。同时,也请大家关注我们的微信公众号(X的嵌入式AI),二维码如下:
