    全志A13刷机资料
    A Series
    • Minuhy
      Minuhy LV 2 最后由 编辑
      各位大佬好,我在13年前读初中的时候拿到了一台全志A13的平板,当时第一次接触安卓,后面搞了Root权限,看到可以删除系统软件,想着反正可以还原,试试删除“Android系统”APP会怎样,结果直接变砖了。现在通过串口进入了Uboot,想尝试刷机,但是一直找不到对应的资料……,希望有资料的大佬能提供一下,谢谢!
      下面是相关的信息:
      从UBoot中读取到的System分区里的构建信息,build.prop
      # begin build properties
      # autogenerated by buildinfo.sh
      ro.build.id=IMM76D
      ro.build.display.id=nuclear_evb-eng 4.0.4 IMM76D 20120712 test-keys
      ro.build.version.incremental=20120712
      ro.build.version.sdk=15
      ro.build.version.codename=REL
      ro.build.version.release=4.0.4
      ro.build.date=Thu Jul 12 12:41:11 CST 2012
      ro.build.date.utc=1342068071
      ro.build.type=eng
      ro.build.user=liuzhi
      ro.build.host=software
      ro.build.tags=test-keys
      ro.product.model=KB702
      ro.product.brand=softwinners
      ro.product.name=nuclear_evb
      ro.product.device=nuclear-evb
      ro.product.board=nuclear
      ro.product.cpu.abi=armeabi-v7a
      ro.product.cpu.abi2=armeabi
      ro.product.manufacturer=unknown
      ro.product.locale.language=en
      ro.product.locale.region=US
      ro.wifi.channels=
      ro.board.platform=exDroid
      # ro.build.product is obsolete; use ro.product.device
      ro.build.product=nuclear-evb
      # Do not try to parse ro.build.description or .fingerprint
      ro.build.description=nuclear_evb-eng 4.0.4 IMM76D 20120712 test-keys
      ro.build.fingerprint=softwinners/nuclear_evb/nuclear-evb:4.0.4/IMM76D/20120712:eng/test-keys
      ro.build.characteristics=tablet
      # end build properties
      # ADDITIONAL_BUILD_PROPERTIES
      ro.com.android.dateformat=MM-dd-yyyy
      ro.config.ringtone=Ring_Synth_04.ogg
      ro.config.notification_sound=pixiedust.ogg
      ro.config.alarm_alert=Alarm_Classic.ogg
      dalvik.vm.heapsize=48m
      ro.kernel.android.checkjni=0
      persist.sys.timezone=Asia/Shanghai
      persist.sys.language=zh
      persist.sys.country=CN
      wifi.interface=wlan0
      wifi.supplicant_scan_interval=15
      debug.egl.hw=1
      ro.opengles.version=131072
      persist.sys.strictmode.visual=0
      persist.sys.strictmode.disable=1
      hwui.render_dirty_regions=false
      persist.sys.usb.config=mass_storage,adb
      ro.property.tabletUI=true
      ro.udisk.lable=MID
      ro.product.firmware=1.4rc3
      ro.setupwizard.mode=OPTIONAL
      net.bt.name=Android
      dalvik.vm.stack-trace-file=/data/anr/traces.txt
      硬件信息:
      SOC:全志A13
      NAND:MT29F32G08CBACA
      内存卡接口:存在
      USB接口:存在
      启动信息:
      HELLO! BOOT0 is starting!
      boot0 version : 1.3.0
      dram size =512
      Succeed in opening nand flash.
      Succeed in reading Boot1 file head.
      The size of Boot1 is 0x00036000.
      The file stored in 0X00000000 of block 2 is perfect.
      Check is correct.
      Ready to disable icache.
      Succeed in loading Boot1.
      Jump to Boot1.
      [       0.127] boot1 version : 1.3.1c
      [       0.127] pmu type = 3
      [       0.128] bat vol = 3678
      [       0.155] axi:ahb:apb=3:2:2
      [       0.155] set dcdc2=1400, clock=1008 successed
      [       0.157] key
      [       0.170] no key found
      [       0.170] flash init start
      [       0.186] flash init finish
      [       0.188] fs init ok
      [       0.188] fattype FAT16
      [       0.189] fs mount ok
      [       0.194] script finish
      [       0.195] power finish
      [       0.201] BootMain start
      [       0.201] 0
      [       0.218] init to usb pc
      [       0.232] startup status = 1
      [       0.232] key value = 1
      [       0.233] recovery key high 6, low 4
      [       0.236] unable to find fastboot_key key_max value
      [       0.243] test for multi os boot with display
      [       0.864] show pic finish
      [       0.864] load kernel start
      [       0.880] load kernel successed
      [       0.880] star
      U-Boot 2011.09-rc1-svn22 (Jul 12 2012 - 12:34:39) Allwinner Technology
      CPU:   SUNXI Family
      Board: A13-EVB
      DRAM:  512 MiB
      NAND:  3800 MiB
      In:    serial
      Out:   serial
      Err:   serial
      --------fastboot partitions--------
      -total partitions:9-
      -name-        -start-       -size-
      bootloader  : 1000000       1000000
      env         : 2000000       1000000
      boot        : 3000000       2000000
      system      : 5000000       10000000
      data        : 15000000      20000000
      misc        : 35000000      1000000
      recovery    : 36000000      2000000
      cache       : 38000000      10000000
      UDISK       : 48000000      a5800000
      UBOOT 环境变量:
      sunxi#printenv
      boot_fastboot=fastboot
      boot_normal=nand read 40007800 boot;boota 40007800
      boot_recovery=nand read 40007800 recovery;boota 40007800
      bootcmd=run setargs boot_normal
      bootdelay=1
      console=ttyS0,115200
      fastboot_key_value_max=0x8
      fastboot_key_value_min=0x2
      init=/init
      loglevel=8
      mmc_root=/dev/mmcblk0p4
      nand_root=/dev/nandc
      recovery_key_value_max=0x13
      recovery_key_value_min=0x10
      setargs=setenv bootargs console=${console} root=${nand_root} init=${init} loglevel=${loglevel}
      stderr=serial
      stdin=serial
      stdout=serial
      内核启动日志:
      Starting kernel ...
      DRAM: 512[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387f
      [    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [    0.000000] Machine: sun5i
      [    0.000000] Memory policy: ECC disabled, Data cache writeback
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113664
      [    0.000000] ram_console: buffer   (null), invalid size 0, datasize 4294967284
      [    0.040000] try to parse apb frequency from script faild!
      [    0.040000] SOFTWINNER DMA Driver, (c) 2003-2004,2006 Simtec Electronics
      [    0.040000] Init eGon pin module V2.0
      [    0.050000] [usb_manager]: CONFIG_USB_SW_SUN5I_USB0_OTG
      [    0.050000] [sw_hcd0]: usb host driver initialize........
      [    0.050000] [sw_hcd0]: open_usb_clock
      [    0.060000] [hcd0]: open, 0x60(0xc061), 0xcc(0x101)
      [    0.060000] [sw_hcd0]: host_init_state = 0
      [    0.060000] [sw_hcd0]: platform is usb host
      [    0.060000] [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 38
      [    0.060000] wrn: hcd is not enable, need not start hcd
      [    0.060000] [sw_hcd0]: sw_usb_host0_disable start
      [    0.060000] -------sw_hcd0_soft_disconnect---------
      [    0.060000] [sw_hcd_host0]: Set USB Power OFF
      [    0.060000] wrn: hcd is not enable, need not stop hcd
      [    0.060000] [sw_hcd0]: close_usb_clock
      [    0.060000] [hcd0]: close, 0x60(0xc060), 0xcc(0x0)
      [    0.060000] [sw_hcd0]: sw_usb_host0_disable end
      [    0.060000] [sw_udc]: udc_init: version 20080411
      [    0.110000] [pm]aw_pm_init!
      [    0.120000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.280000] [NAND]nand driver, init.
      [    0.280000] [NAND] nand gpio_request
      [    0.290000] [NAND] nand driver version: 0x2 0x9
      [    0.290000] nand interrupte register ok
      [    0.290000] ret of NFC_ChangMode is 0
      [    0.300000] dma_hdle  is 0
      [    0.300000] dma_hdle  is 10000008
      [    0.320000] The 0 disk name = bootloader, class name = DISK, disk size = 32768
      [    0.330000] The 1 disk name = env, class name = DISK, disk size = 32768
      [    0.340000] The 2 disk name = boot, class name = DISK, disk size = 65536
      [    0.340000] The 3 disk name = system, class name = DISK, disk size = 524288
      [    0.350000] The 4 disk name = data, class name = DISK, disk size = 1048576
      [    0.360000] The 5 disk name = misc, class name = DISK, disk size = 32768
      [    0.360000] The 6 disk name = recovery, class name = DISK, disk size = 65536
      [    0.370000] The 7 disk name = cache, class name = DISK, disk size = 524288
      [    0.380000] The 8 disk name = UDISK, class name = DISK, disk size = 5423104
      [    0.390000] The 8 disk size = 5423104
      [    0.390000] part total count = 9
      [    0.600000] [NAND]nand driver, ok.
      [    0.600000] drivers/spi/spi_sunxi.c(L2114) sw spi init fetch spi0 uning configuration failed
      [    0.610000] drivers/spi/spi_sunxi.c(L2005) Get spi devices number failed
      [    0.620000] drivers/spi/spi_sunxi.c(L2124) register spi devices board info failed
      [    0.630000] cannot find any using configuration for all spi controllers!
      [    0.640000] ------print_msc_config-----
      [    0.640000] vendor_id             = 0x18d1
      [    0.640000] mass_storage_id       = 0x1
      [    0.650000] adb_id                = 0x2
      [    0.650000] usb_manufacturer_name = USB Developer
      [    0.660000] usb_product_name      = Android
      [    0.660000] usb_serial_number     = 20080411
      [    0.670000] msc_vendor_name       = USB 2.0
      [    0.670000] msc_product_name      = USB Flash Driver
      [    0.680000] msc_release           = 100
      [    0.680000] luns                  = 2
      [    0.680000] ---------------------------
      [    0.690000] [sw_udc]: [sw_usb_udc]: binding gadget driver 'android_usb'
      [    0.690000] [sw_udc]: alloc request: ep(0xc08c1ec0, ep0, 64), req(0xdf01e740)
      [    0.700000] WRN:L2694(drivers/usb/sun5i_usb/udc/sw_udc.c):ERR: usb device is not active
      [    0.710000] [sw_udc]: sw_udc_pullup, is_on = 0
      [    0.710000] WRN:L2729(drivers/usb/sun5i_usb/udc/sw_udc.c):ERR: usb device is not active
      [    0.720000] lun name: lun
      [    0.720000] lun name: lun1
      [    0.730000] Gadget Android: controller 'sw_usb_udc' not recognized
      [    0.730000] WRN:L2694(drivers/usb/sun5i_usb/udc/sw_udc.c):ERR: usb device is not active
      [    0.740000] ==register_early_suspend =
      [    0.750000] !!! base_Addr = 0xe08ecc00
      [    0.750000] config i2c gpio with gpio_config api
      [    0.760000] twi0, apb clock = 24000000
      [    0.760000] [AXP]axp driver uning configuration failed(324)
      [    0.770000] [AXP]power_start = 0
      [    0.770000] rtc_detect,line:197
      [    0.770000] **********start************
      [    0.780000] 0x40
      [    0.780000] 0xf8
      [    0.780000] 0x28
      [    0.780000] 0x0
      [    0.780000] 0x0
      [    0.790000] **********end************
      [    0.790000] !!! base_Addr = 0xe08ee000
      [    0.790000] twi1, apb clock = 24000000
      [    0.800000] pcf8563 1-0051: retrieved date/time is not valid.
      [    0.810000] pcf8563 1-0051: retrieved date/time is not valid.
      [    0.810000] rtc (null): alarm rollover not handled
      [    0.820000] **********start************
      [    0.820000] 0x40
      [    0.830000] 0xf8
      [    0.830000] 0x58
      [    0.830000] 0x0
      [    0.830000] 0x0
      [    0.830000] **********end************
      [    0.840000] !!! base_Addr = 0xe08f0400
      [    0.840000] twi2, apb clock = 24000000
      [    0.850000] rtc_detect,line:197
      [    0.850000] **********start************
      [    0.850000] 0x40
      [    0.850000] 0xf8
      [    0.860000] 0x58
      [    0.860000] 0x0
      [    0.860000] 0x0
      [    0.860000] **********end************
      [    0.870000] [pa_drv] start!!!
      [    0.870000] [pa_drv] init end!!!
      [    0.880000] pmu_pekoff_time = 6000
      [    0.890000] pmu_pekoff_en = 1
      [    0.890000] pmu_peklong_time = 1500
      [    0.890000] pmu_pekon_time = 1000
      [    0.900000] pmu_pwrok_time = 64
      [    0.900000] pmu_pwrnoe_time = 2000
      [    0.900000] pmu_intotp_en = 1
      [    0.910000] [AXP]POWER20_OFF_CTL:1908-->0x42
      [    0.910000] POWER20_PEK_SET:1925-->0x9d
      [    0.920000] POWER20_PEK_SET:1936-->0x9d
      [    0.920000] POWER20_PEK_SET:1945-->0x9d
      [    0.920000] POWER20_PEK_SET:1956-->0x9d
      [    0.930000] POWER20_PEK_SET:1968-->0x9d
      [    0.930000] POWER20_HOTOVER_CTL:1977-->0x25
      [    0.940000] [AXP]last_rest_vol = 0, now_rest_vol     = 31
      [    0.950000] [AXP]charger->rest_vol = 31
      [    0.950000] [mmc_pm]: no sdio card used in configuration
      [    0.960000] [mmc]: sunximmc_init
      [    0.960000] [mmc]: sunxi mmc controller using config : 0x1
      [    0.970000] [mmc]: sunxi-mmc.0: pdev->name: sunxi-mmc, pdev->id: 0
      [    0.970000] [mmc]: mmc 0 power off !!
      [    0.980000] [mmc]: mmc0 Probe: base:0xe08f2000 irq:32 dma:0 pdes:0xdf060000, ret 0.
      [    0.990000] enter sun5i Audio codec!!!
      [    0.990000] sun5i Audio codec successfully loaded..
      [    1.000000] dram_sysdev_init finished!
      [    1.010000] [LCD] lcd_module_init
      [    1.580000] regulator_init_complete: axp20_buck3: incomplete constraints, leaving on
      [    1.590000] regulator_init_complete: axp20_buck2: incomplete constraints, leaving on
      [    1.590000] regulator_init_complete: axp20_ldo4: incomplete constraints, leaving on
      [    1.600000] regulator_init_complete: axp20_ldo3: incomplete constraints, leaving on
      [    1.610000] regulator_init_complete: axp20_ldo2: incomplete constraints, leaving on
      [    1.620000] [sw-ehci1]: probe, pdev->name: sw-ehci, pdev->id: 1, sw_ehci: 0xc098865c
      [    1.630000] [sw-ehci1]: open clock
      [    1.650000] usb_passby en=1,passly=0
      [    1.650000] hci_port_configure en=1,config_cnt=0
      [    1.680000] ehci_irq: port change detect
      [    1.680000] [sw-ehci1]: sw_usb_disable_ehci
      [    1.680000] [sw-ehci1]: remove, pdev->name: sw-ehci, pdev->id: 1, sw_ehci: 0xc098865c
      [    1.690000] hci_port_configure en=0,config_cnt=1
      [    1.700000] usb_passby en=0,passly=1
      [    1.700000] [sw-ehci1]: close clock
      [    1.700000] [sw-ohci1]: probe, pdev->name: sw-ohci, pdev->id: 1, sw_ohci: 0xc0988770
      [    1.710000] [sw-ohci1]: open clock
      [    1.740000] hci_port_configure en=1,config_cnt=0
      [    1.740000] usb_passby en=1,passly=0
      [    1.800000] [sw-ohci1]: sw_usb_disable_ohci
      [    1.800000] [sw-ohci1]: remove, pdev->name: sw-ohci, pdev->id: 1, sw_ohci: 0xc0988770
      [    1.810000] usb_passby en=0,passly=1
      [    1.820000] hci_port_configure en=0,config_cnt=1
      [    1.820000] [sw-ohci1]: close clock
      [    1.830000] pcf8563 1-0051: retrieved date/time is not valid.
      [    1.830000] pcf8563 1-0051: hctosys: invalid date/time
      [    1.890000] init: width = 800
      [    1.890000] init: height = 480
      [    1.900000] init: s.st_size = 1536000
      [    1.980000] [mmc]: mmc 0 detect change, present 1
      [    2.160000] init: do_umount: /data
      [    2.280000] [mmc]: mmc 0 power on !!
      [    2.320000] [mmc]: sdxc_request_done(L1114): smc 0 err, cmd 52,  RTO !!
      [    2.330000] [mmc]: sdxc_request_done(L1114): smc 0 err, cmd 5,  RTO !!
      [    2.340000] [mmc]: sdxc_request_done(L1114): smc 0 err, cmd 5,  RTO !!
      [    2.350000] [mmc]: sdxc_request_done(L1114): smc 0 err, cmd 5,  RTO !!
      [    2.360000] [mmc]: sdxc_request_done(L1114): smc 0 err, cmd 5,  RTO !!
      [    2.550000] init: do_umount: /cache
      [    2.600000] init: dont need format /dev/block/nandi
      [    2.850000] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
      [    2.880000] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
      [    2.970000] script parser fetch err.
      [    2.970000] ctp_init_platform_resource: tp_reset request gpio fail!
      [    3.090000] [i2c1] incomplete xfer (0x20)
      [    3.240000] <<-GTP-INFO->>[1741]GTP driver install.
      [    3.240000] ctp_fetch_sysconfig_para.
      [    3.250000] ctp_fetch_sysconfig_para: after: ctp_twi_addr is 0x5d, dirty_addr_buf: 0x5d. dirty_addr_buf[1]: 0xfffe
      [    3.260000] ctp_fetch_sysconfig_para: ctp_twi_id is 1.
      [    3.260000] goodix_ts_init: after fetch_sysconfig_para:  normal_i2c: 0x5d. normal_i2c[1]: 0xfffe
      [    3.270000] ctp_wakeup.
      [    3.280000] [i2c1] incomplete xfer (0x20)
      [    3.770000] <<-GTP-INFO->>[1445]GTP Driver Version:V1.2<2012/06/08>
      [    3.770000] <<-GTP-INFO->>[1446]GTP Driver build@12:31:55,Jul 12 2012
      [    3.780000] <<-GTP-INFO->>[1447]GTP I2C address:0x5d
      [    3.790000] [i2c1] incomplete xfer (0x20)
      [    3.800000] [i2c1] incomplete xfer (0x20)
      [    3.810000] [i2c1] incomplete xfer (0x20)
      [    3.820000] [i2c1] incomplete xfer (0x20)
      [    3.830000] [i2c1] incomplete xfer (0x20)
      [    3.840000] [i2c1] incomplete xfer (0x20)
      [    3.850000] [i2c1] incomplete xfer (0x20)
      [    3.860000] [i2c1] incomplete xfer (0x20)
      [    3.900000] [i2c1] incomplete xfer (0x20)
      [    3.950000] [i2c1] incomplete xfer (0x20)
      [    4.000000] [i2c1] incomplete xfer (0x20)
      [    4.040000] [i2c1] incomplete xfer (0x20)
      [    4.070000] [i2c1] incomplete xfer (0x20)
      [    4.100000] [i2c1] incomplete xfer (0x20)
      [    4.110000] [i2c1] incomplete xfer (0x20)
      [    4.120000] [i2c1] incomplete xfer (0x20)
      [    4.130000] [i2c1] incomplete xfer (0x20)
      [    4.150000] [i2c1] incomplete xfer (0x20)
      [    4.190000] [i2c1] incomplete xfer (0x20)
      [    4.240000] [i2c1] incomplete xfer (0x20)
      [    4.290000] <<-GTP-ERROR->>[1158]Send config error. ret = -70
      [    4.310000] [i2c1] incomplete xfer (0x20)
      [    4.330000] [i2c1] incomplete xfer (0x20)
      [    4.370000] <<-GTP-ERROR->>[1247]GTP i2c test failed time 1.
      [    4.390000] [i2c1] incomplete xfer (0x20)
      [    4.410000] [i2c1] incomplete xfer (0x20)
      [    4.430000] <<-GTP-ERROR->>[1247]GTP i2c test failed time 2.
      [    4.450000] [i2c1] incomplete xfer (0x20)
      [    4.460000] [i2c1] incomplete xfer (0x20)
      [    4.470000] <<-GTP-ERROR->>[1247]GTP i2c test failed time 3.
      [    4.490000] [i2c1] incomplete xfer (0x20)
      [    4.500000] [i2c1] incomplete xfer (0x20)
      [    4.510000] [i2c1] incomplete xfer (0x20)
      [    4.510000] <<-GTP-ERROR->>[1247]GTP i2c test failed time 4.
      [    4.540000] [i2c1] incomplete xfer (0x20)
      [    4.550000] [i2c1] incomplete xfer (0x20)
      [    4.560000] <<-GTP-ERROR->>[1247]GTP i2c test failed time 5.
      [    4.580000] <<-GTP-ERROR->>[1500]I2C communication ERROR!
      [    4.580000] <<-GTP-INFO->>[1577]GTP driver is removing...
      [    4.590000] =======ctp_free_platform_resource=========.
      [    4.590000] gt811: probe of 1-005d failed with error -12
      [    4.600000] init: untracked pid 82 exited
      [    4.640000] ctp_wakeup:
      [    4.650000] [i2c1] incomplete xfer (0x20)
      [    4.730000] ctp_detect:
      [    4.750000] ctp_detect:
      [    4.750000] ssd253x_ts_probe:
      [    4.850000] [i2c1] incomplete xfer (0x20)
      [    5.200000] SSL Touchscreen I2C Address: 0x48
      [    5.210000] [i2c1] incomplete xfer (0x20)
      [    5.220000] [i2c1] incomplete xfer (0x20)
      [    5.220000] SSL Touchscreen Device ID  : 0xFFFF
      [    5.230000] SSL Touchscreen Version ID : 0xFFFF
      [    5.230000] ctp_detect:
      [    5.250000] ========gsensor_fetch_sysconfig_para===================
      [    5.260000] gsensor_fetch_sysconfig_para: after: gsensor_twi_addr is 0x18, dirty_addr_buf: 0x18. dirty_addr_buf[1]: 0xfffe
      [    5.270000] gsensor_fetch_sysconfig_para: twi_id is 1.
      [    5.270000] BMA250_init: after fetch_sysconfig_para:  normal_i2c: 0x18. normal_i2c[1]: 0xfffe
      [    5.330000] UMP: UMP device driver 22 loaded
      [    5.480000] Mali: mali--2244-rel0!
      [    5.490000] Mali: Mali device driver r2p4-02rel0-r22 loaded
      [    5.520000] [cedar dev]: install start!!!
      [    5.530000] [cedar dev]: install end!!!
      [    6.030000] android_usb: already disabled
      [    6.030000] ep_matches, wrn: endpoint already claimed, ep(0xc08c1f00, 0xdf022200, ep1-bulk)
      [    6.040000] ep_matches, wrn: endpoint already claimed, ep(0xc08c1f00, 0xdf022200, ep1-bulk)
      [    6.050000] ep_matches, wrn: endpoint already claimed, ep(0xc08c1f40, 0xdf022200, ep2-bulk)
      [    6.060000] ep_matches, wrn: endpoint already claimed, ep(0xc08c1f00, 0xdf022200, ep1-bulk)
      [    6.070000] ep_matches, wrn: endpoint already claimed, ep(0xc08c1f40, 0xdf022200, ep2-bulk)
      [    6.070000] ep_matches, wrn: endpoint already claimed, ep(0xc08c1f80, 0xdf01d380, ep3-bulk)
      [    6.080000] [sw_udc]: alloc request: ep(0xc08c1fc0, ep4-bulk, 512), req(0xdf38f240)
      [    6.090000] [sw_udc]: alloc request: ep(0xc08c1f80, ep3-bulk, 512), req(0xdf38f280)
      [    6.100000] [sw_udc]: alloc request: ep(0xc08c1f80, ep3-bulk, 512), req(0xdf38f2c0)
      [    6.110000] [sw_udc]: alloc request: ep(0xc08c1f80, ep3-bulk, 512), req(0xdf38f300)
      [    6.110000] [sw_udc]: alloc request: ep(0xc08c1f80, ep3-bulk, 512), req(0xdf38f340)
      [    6.120000] [sw_udc]: sw_udc_pullup, is_on = 1
      [    6.130000] WRN:L2729(drivers/usb/sun5i_usb/udc/sw_udc.c):ERR: usb device is not active
      [    7.100000] init: untracked pid 79 exited
      [    7.100000] init: untracked pid 84 exited
      [   10.180000] init: untracked pid 134 exited
      [   10.200000] init: untracked pid 135 exited
      [   10.960000] [AXP]init charger->rest_vol = 14
      [   10.960000] battery vol change: 31->14
      [   14.860000] init: untracked pid 176 exited
      [   14.880000] init: untracked pid 175 exited
      [   20.560000] init: untracked pid 204 exited
      [   20.560000] init: untracked pid 205 exited
      [   21.000000] battery vol change: 14->13
      [   25.220000] init: untracked pid 231 exited
      [   25.220000] init: untracked pid 232 exited
      [   29.910000] init: untracked pid 258 exited
      [   29.930000] init: untracked pid 259 exited
      [   35.580000] init: untracked pid 285 exited
      [   35.620000] init: untracked pid 286 exited
      [   40.280000] init: untracked pid 312 exited
      [   40.310000] init: untracked pid 313 exited
      [   44.990000] init: untracked pid 339 exited
      [   44.990000] init: untracked pid 340 exited
      谢谢~
      • K
        Killy.THI LV 2 最后由 编辑
        Uboot还能用,可以先试试dump出完整固件。不太清楚你的目的是什么,如果系统坏的很严重估计重新编译还好一点,网上只找到了个这个
        https://whycan.com/t_11572.html
        或许有一定参考价值
