    V821烧录错误Error!!!: Wait for Fes Device Timeout...
    • N
      nikola LV 4 最后由 编辑
      ubuntu使用phoenixsuit烧录出现问题Wait for Fes Device Timeout:日志如下Dev Plugin The Device Path is: /dev/aw_efex0
      Begin Burn the image!
      0%Register./luaBase.dll l_RegAllFun Sucess!
      Register./luaeFex.dll l_RegAllFun Sucess!
      Register./luadec.dll l_RegAllFun Sucess!
      IMAGEWTY
      ItemTableSize = 1048576
      Closing image now!
      Clos image OK!
      [TL_MSG]:--------------Init Called------------------
      workDir /home/ageek/Bin/phoenixsuit/phoenixsuit
      ImgLenHigh 0
      ImgLenLow 15341568
      Mode 8
      hWnd 0
      imgFilePath /home/ageek/v821_sdk/tina-v821/out/v821l2-wxx_linux_perf2b_uart0_nor.img
      [TL_MSG]:Mode = 8, ImgLenHigh=0, ImgLenLow = ea1800, imgFilePath = /home/ageek/v821_sdk/tina-v821/out/v821l2-wxx_linux_perf2b_uart0_nor.img
      <TL_ERRCODE>Err: usbtool.lua_577>:func ToolErrCodeCBack is not registered yet!
      <TL_IMG>Err:usbtool.lua_624>:usbtool.lua/func[Tools_Img], Fail to get ui callBack fun
      IMAGEWTY
      [TL_MSG]:Tools Open Img
      [TL_MSG]:---fun end---
      [TL_MSG]:plugin create by allwinner, version : V1.0.4, last fix author : AWA1746, fix time : 27.11.2024
      [TL_MSG]:--------------entry-fel2fes Called-----------
      felDevName /dev/aw_efex0
      [TL_MSG]:Hi, I'm fel, dev=/dev/aw_efex0
      [TL_FEX_DEV]Errusbtool.lua_870>:usbtool.lua/func[Tools_Fex_Dev], Fail to get ui callBack fun
      [TL_MSG]:func[entry_fel2fes] To down and Run fes1 (init dram)
      [TL_MSG]:fes1 down file length = 0x43e0
      [TL_MSG]:fes1 down addr = 0x2008000, retAddr =0x2008340
      [TL_FEX_DEV]:DOWN fes1 addr=0x2008000, len=17376
      [TL_FEX_DEV]:call FelUpData function
      [TL_FEX_DEV]:fel UP addr=0x2008340, len=136
      [TL_MSG]:SYS_PARA_LOG read = 0x4d415244
      [TL_MSG]:dram paras[0]: 0x208
      [TL_MSG]:dram paras[1]: 0x2
      [TL_MSG]:dram paras[2]: 0x7b7bf9
      [TL_MSG]:dram paras[3]: 0x0
      [TL_MSG]:dram paras[4]: 0xd2
      [TL_MSG]:dram paras[5]: 0x400000
      [TL_MSG]:dram paras[6]: 0xe73
      [TL_MSG]:dram paras[7]: 0x2
      [TL_MSG]:dram paras[8]: 0x0
      [TL_MSG]:dram paras[9]: 0x0
      [TL_MSG]:dram paras[10]: 0x469991
      [TL_MSG]:dram paras[11]: 0x131a10c
      [TL_MSG]:dram paras[12]: 0x56040
      [TL_MSG]:dram paras[13]: 0xb4787896
      [TL_MSG]:dram paras[14]: 0x0
      [TL_MSG]:dram paras[15]: 0x48484848
      [TL_MSG]:dram paras[16]: 0x48
      [TL_MSG]:dram paras[17]: 0x1621121e
      [TL_MSG]:dram paras[18]: 0x0
      [TL_MSG]:dram paras[19]: 0x0
      [TL_MSG]:dram paras[20]: 0x0
      [TL_MSG]:dram paras[21]: 0x0
      [TL_MSG]:dram paras[22]: 0x0
      [TL_MSG]:dram paras[23]: 0x34006101
      [TL_MSG]:dram paras[24]: 0x0
      [TL_MSG]:dram paras[25]: 0x0
      [TL_MSG]:dram paras[26]: 0x0
      [TL_MSG]:dram paras[27]: 0x0
      [TL_MSG]:dram paras[28]: 0x0
      [TL_MSG]:dram paras[29]: 0x0
      [TL_MSG]:dram paras[30]: 0x0
      [TL_MSG]:dram paras[31]: 0x0
      [TL_MSG]:func[entry_fel2fes] To down and Run uboot
      [TL_MSG]:u-boot down addr = 0x82000000, length=0xa4000
      [TL_MSG]:workmode = 0x10
      [TL_FEX_DEV]:DOWN fes1 addr=0x82000000, len=671744
      [TL_MSG]:dtb down addr = 0x82200000, length=0x12800
      <TL_ERR>:usbtool.lua_2180>:is_dtb_noexist is false
      [TL_FEX_DEV]:DOWN fes1 addr=0x82200000, len=75776
      [TL_MSG]:sysconfig down addr = 0x82300000
      [TL_FEX_DEV]:DOWN fes1 addr=0x82300000, len=4096
      [TL_MSG]:[fel] entry_fel2fes(): ---fun end---
      Fel Thread Finished!
      [TL_MSG]:---------------Exit Called-----------------
      Closing image now!
      Clos image OK!
      [TL_MSG]:Tools Close Img ...
      [TL_MSG]:function: Exit(): ---fun end---
        momoyu LV 5 最后由 编辑
        板子的串口输出信息呢? 没用过linux的烧录工具,只用过window的。😏
        N 1 条回复 最后回复 回复 引用 分享 0
        • N
          nikola LV 4 @momoyu 最后由 编辑
          @momoyu 在 V821烧录错误Error!!!: Wait for Fes Device Timeout... 中说:
          解决了我板子是NAND Flash烧了norflash的镜像所以出问题了,镜像改回NAND flash版本的可以正常在ubuntu下命令行直接烧录。
