    【XR806开发板试用】socket客户端与虚拟机服务器通信交互测试以及终端交互
    4663
    • O
      小昭debug LV 2 最后由 编辑
      XR806 客户端准备工作。
      1、连接wifi
      2、创建socket连接服务器。
      3、创建终端接收数据线程。
      wifi_connect.c
      #include <string.h>
      #include "wifi_device.h"
      #include "wifi_hotspot.h"
      #include "kernel/os/os.h"
      int wifi_device_connect(const char *ssid, const char *psk_key)
        const char *ssid_want_connect = ssid;
        const char *psk = psk_key;
        printf("\r\n=========== Connect Test Start ===========\r\n");
        if (WIFI_SUCCESS != EnableWifi()) {
          printf("Error: EnableWifi fail.\r\n");
          return -1;
        printf("EnableWifi Success.\r\n");
        if (WIFI_STA_ACTIVE == IsWifiActive())
          printf("Wifi is active.\r\n");
        OS_Sleep(1);
        if (WIFI_SUCCESS != Scan()) {
          printf("Error: Scan fail.\r\n");
          return -1;
        printf("Wifi Scan Success.\r\n");
        OS_Sleep(1);
        WifiScanInfo scan_results[30];
        unsigned int scan_num = 30;
        if (WIFI_SUCCESS != GetScanInfoList(scan_results, &scan_num)) {
          printf("Error: GetScanInfoList fail.\r\n");
          return -1;
        WifiDeviceConfig config = { 0 };
        int netId = 0;
        int i;
        for (i = 0; i < scan_num; i++) {
          if (0 == strcmp(scan_results[i].ssid, ssid_want_connect)) {
            memcpy(config.ssid, scan_results[i].ssid,
                   WIFI_MAX_SSID_LEN);
            memcpy(config.bssid, scan_results[i].bssid,
                   WIFI_MAC_LEN);
            config.securityType = scan_results[i].securityType;
            config.freq = scan_results[i].frequency;
            break;
        if (i >= scan_num) {
          printf("Error: No found ssid in scan_results\r\n");
          return -1;
        printf("GetScanInfoList Success.\r\n");
        if (WIFI_SUCCESS != AddDeviceConfig(&config, &netId)) {
          printf("Error: AddDeviceConfig Fail\r\n");
          return -1;
        printf("AddDeviceConfig Success.\r\n");
        if (WIFI_SUCCESS != ConnectTo(netId)) {
          printf("Error: ConnectTo Fail\r\n");
          return -1;
        printf("ConnectTo Success\r\n");
        OS_Sleep(3);
        WifiLinkedInfo get_linked_res;
        if (WIFI_SUCCESS != GetLinkedInfo(&get_linked_res)) {
          printf("Error: GetLinkedInfo Fail\r\n");
          return -1;
        printf("GetLinkedInfo Success.\r\n");
        printf("ssid: %s\r\n", get_linked_res.ssid);
        printf("bssid: ");
        for (int j = 0; j < WIFI_MAC_LEN; j++) {
          printf("%02X", get_linked_res.bssid[j]);
        printf("\r\n");
        printf("rssi: %d\r\n", get_linked_res.rssi);
        unsigned char get_mac_res[WIFI_MAC_LEN];
        if (WIFI_SUCCESS != GetDeviceMacAddress(get_mac_res)) {
          printf("Error: GetDeviceMacAddress Fail\r\n");
          return -1;
        printf("GetDeviceMacAddress Success.\r\n");
        for (int j = 0; j < WIFI_MAC_LEN - 1; j++) {
          printf("%02X:", get_mac_res[j]);
        printf("%02X\r\n", get_mac_res[WIFI_MAC_LEN - 1]);
      tcp_socket.c
      创建发送(send_task)和接收线程(read_task)。
      #include <stdlib.h>
      #include <string.h>
      #include "lwip/sockets.h"
      #include "ohos_init.h"
      int _PROT_  = 6666;
      char _TCP_SERVER_IP[] = "192.168.1.109";
      int sock;
      int ret;
      struct sockaddr_in server_addr;
      char send_buffer[50] = "Hello RX806 Open_Harmany!\r\n";
      char recv_buffer[50];
      extern OS_Semaphore_t tcp_wd;
      static OS_Thread_t send_thread;
      static OS_Thread_t read_thread;
      void send_task(void *argv){
          while(1){
              if(OS_SemaphoreWait(&tcp_wd,OS_WAIT_FOREVER)==OS_OK)
              printf("OS_SemaphoreWait\r\n");
              if((ret = send(sock,send_buffer,strlen(send_buffer),0)) == -1){
                  printf("send_error\r\n");
              bzero(&send_buffer,sizeof(send_buffer));
              OS_MSleep(50);
      void read_task(void *argv){
          while(1){
              if((ret = recv(sock,recv_buffer,sizeof(recv_buffer),0)) != -1){
                  printf("recv:\r\n%s,ret=%d\r\n",recv_buffer,ret);
                  bzero(&recv_buffer,sizeof(recv_buffer));
              }else{
                  printf("recv_error\r\n");
              OS_MSleep(1000);
      int tcp_demo_test(){
          if((sock = socket(AF_INET, SOCK_STREAM, 0)) < 0)
              printf("socket_error\r\n");
              return -1;
          server_addr.sin_family = AF_INET;
          server_addr.sin_port = htons(_PROT_);
          server_addr.sin_addr.s_addr = inet_addr(_TCP_SERVER_IP);
          if(connect(sock, (struct sockaddr *)&server_addr, sizeof(server_addr)) < 0)
              printf("connect_error\r\n");
              return -1;
          printf("connect_server_success\r\n");
          if (OS_ThreadCreate(&send_thread, "send_task", send_task, NULL,
                6, 2 * 1024) != OS_OK) {
          printf("[ERR] send_task Failed\n");
          printf(" send_task \n");
          if (OS_ThreadCreate(&read_thread, "read_task", read_task, NULL,
          printf("[ERR] read_task Failed\n");
          printf(" read_task \n");
      main.c
      void consol_task(void *argv){
          int ret;
          char uart_buffer[UART_RECEIVE_DATALEN];
          IoTFlashInit();
          while(1){
          /*读取串口接收到的数据*/
              ret = IoTUartRead(0, uart_buffer, UART_RECEIVE_DATALEN);
              if(ret!=0){
              /*指令*/
                  if(strncmp(uart_buffer,"IP:",3)==0)
                      // if(uart_buffer[3] == '?')
                      // }else{
                      //     printf("IP:%s\r\n",uart_buffer+3);
                  /*从服务器获得当前时间*/
                  else if(strncmp(uart_buffer,"time:",5)==0)
                      printf("time:%s\r\n",uart_buffer+5);
                      memcpy(send_buffer,uart_buffer,strlen(uart_buffer));
                      if(OS_SemaphoreRelease(&tcp_wd)!=OS_OK){
                          printf("OS_SemaphoreRelease_error\r\n");
                  /*发送数据到服务器*/
                  else if(strncmp(uart_buffer,"send:",5)==0)
                      printf("send:%s\r\n",uart_buffer+5);
                      memcpy(send_buffer,uart_buffer+5,strlen(uart_buffer)-5);
                  /* wifi SSID以及PSK重置 并复位连接
                    指令格式: wifi:@:@SSID@:@PSK
                  else if(strncmp(uart_buffer,"wifi:",5)==0){
                      if(uart_buffer[5] == '?'){//wifi:? 回复当前
                          printf("connect_wifi_ssid:%s,connect_wifi_psk:%s\r\n",connect_wifi_ssid,connect_wifi_psk);
                      }else{
                              bzero(connect_wifi_psk,sizeof(connect_wifi_psk));
                              bzero(connect_wifi_ssid,sizeof(connect_wifi_ssid));
                              printf("DisableWifi Success\n");
                              Find_string((char*)uart_buffer,"@:@","@:@",connect_wifi_ssid);
                              strcpy(connect_wifi_psk,strstr(strstr(uart_buffer, "@:@")+3,"@:@")+3);
                              printf("reconnect_wifi_ssid:%s,connect_wifi_psk:%s\r\n",connect_wifi_ssid,connect_wifi_psk);
                              if(OS_SemaphoreRelease(&wifi_reconnect)!=OS_OK){
                                  printf("OS_SemaphoreRelease_wifi_reconnect_error\r\n");
                              /*wifi wifi SSID以及PSK存储到ROM*/
                              IotFlash_write(0x100000 ,connect_wifi_ssid,strlen(connect_wifi_ssid)+1);
                              IotFlash_write(0x100000 + 0x4000,connect_wifi_psk,strlen(connect_wifi_psk)+1);
                              /*重启*/
                              RebootDevice(0);
                              printf("reboot_reset_wifi\r\n");
                  }else{
                      printf("command error,please again! \r\n%s\n",uart_buffer);
                  bzero(uart_buffer,sizeof(uart_buffer));
              OS_MSleep(10);
      注意:如果自己定义使用UART0接收数据时,需要注释原有的终端接收#"adapter/console:app_console",
      效果:
      TCP数据通信:
      串口助手发送:time:? 接收获取当前的时间:now datetime: 2021-12-24 23:19:55,ret=33
      串口助手发送:send:hello_XR806_OPEHARMANY! 服务端接收到:hello_XR806_OPEHARMANY!
      服务端发送:hello world! 客户端接收:hello world!,ret=12
      wifi的SSID和PSK获取以及重启
      发送wifi:? 获取此时连接wifi的SSID和PSK
      发送wifi:@:@hello@:@89898989 连接SSID为hello的新wifi
      以上具体代码以及服务端代码已经上传到 gitee
      补充:
      1、每个工程下都有对应的BUILD.gn文件(业务),用来告诉编译器工程需要用到的头文件的路径;同样的,该工程外也有一个BUILD.gn文件(模块),用来告诉编译器你要编译哪个工程;该目录外还有一个BUILD.gn文件(模块),作用也是大同小异。
      2、每个人工程下static_library的命名必须以app_的前缀命名。
      出现的问题:
      1、hb build -f 没有反应
      需要安装对应的工具,执行 python3 -m pip install --user ohos-build (首先你得有python3的环境)
      相关环境配置
      2、使用git时,出现以下错误
      error: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none·
      说明证书校验有问题。执行export GIT_SSL_NO_VERIFY=1 可以解决
      3、烧写程序一直失败。可以尝试 设置 ,勾上红色花圈部分。
      4、当XR806处于连接wifi时,尝试断开wifi,连接(不是断电重启)其他wifi,此时就要重新设置SSID和PSK并初始化wifi,但是一直连接不上,我猜测传入到底层SSID和PSK值是常量,无法被修改,后面我就没往底层深究。为了实现这个功能,我利用了内部ROM空间,将SSID和PSK值存入到ROM中(掉电不丢失),再进行软件复位,通过串口输入SSID和PSK,就能成功连接到对应wifi。
      如有误,请微信群联系我,谢谢!
      W 1 条回复 最后回复 回复 引用 分享 0
      • O
        小昭debug LV 2 最后由 编辑
        @one_piece 在 【XR806开发板试用】socket客户端与虚拟机服务器通信交互测试以及终端交互 中说:
        Z 1 条回复 最后回复 回复 引用 分享 0
          zhugx LV 5 @one_piece 最后由 编辑
          @one_piece 写的太好了,这篇文章是干货,还望分享更多的干货
            wubenlei LV 1 @one_piece 最后由 编辑
            @one_piece 重连新的WIFI不需要重启,调用wlan_sta_disable() 、wlan_sta_config(ssid, ssid_len, psk, flag)、wlan_sta_enable(),改成想要的ssid与psk即可。
