    【XR806开发板试用】2、UDP控制的呼吸灯.
      zthzz LV 3 最后由 编辑
      【XR806开发板试用】1、UDP通信测试
      上篇文章测试了XR806的UDP通信.
      控制PWM控制相关的函数在device/xradio/xr806/adapter/hals/iot_hardware/wifiiot_lite文件夹下的iot_pwm.c 相关函数一共有一下四个.
          //port 指定输出引脚
          //duty 指定输出PWM占空比 范围1-99
          //freq 指定PWM输出频率
          unsigned int IoTPwmInit(unsigned int port);
          unsigned int IoTPwmDeinit(unsigned int port);
          unsigned int IoTPwmStart(unsigned int port, unsigned short duty,unsigned int freq);
          unsigned int IoTPwmStop(unsigned int port);
      驱动控制代码
          #include "iot_pwm.h"
          #define pwm_channl1         0U
          #define pwm_channl2         1U
          #define pwm_channl3         2U
          #define pwm_channl4         3U
          void udp_echoserver_init(void)
          //略
          //在udp初始化结束后初始化PWM输出引脚.
                  IoTPwmInit(pwm_channl1);
                  IoTPwmInit(pwm_channl2);
                  IoTPwmInit(pwm_channl3);
                  IoTPwmInit(pwm_channl4);
          void udp_echoserver_receive_callback(void *arg, struct udp_pcb *upcb,struct pbuf *p, const ip_addr_t *addr, u16_t port)
              udp_connect(upcb, addr, UDP_CLIENT_PORT);
              udp_send(upcb, p);
              udpReceiveCallback(p->payload, p->len);        //recave call
              udp_disconnect(upcb);
              pbuf_free(p);
          //udp接收回调函数中根据接收到的数据控制PWM占空比.
          void udpReceiveCallback(char *p, int len)        //recave call
              if(len<42+5)
                  return;
              p+=42;
              //p[0]留作开关量控制.
              if(p[1]<5||p[1]>99)
                  IoTPwmStop(pwm_channl1);
                  IoTPwmStart(pwm_channl1, p[1], 2000);
              if(p[2]<5||p[2]>99)
                  IoTPwmStop(pwm_channl2);
                  IoTPwmStart(pwm_channl2, p[2], 2000);
              if(p[3]<5||p[3]>99)
                  IoTPwmStop(pwm_channl3);
                  IoTPwmStart(pwm_channl3, p[3], 2000);
              if(p[4]<5||p[4]>99)
                  IoTPwmStop(pwm_channl4);
                  IoTPwmStart(pwm_channl4, p[4], 2000);
      W 1 条回复 最后回复 回复 引用 分享 0
        wlb965 LV 3 @zthzz 最后由 编辑
        @zthzz
        使用udp相关的头文件的时候发现了一堆找不到路径的问题,我是在/demo/hello_demo 文件夹下敲的代码,而用到的文件是在net/lwip-1.4.1/lwip 文件夹里,应该可以通过修改Makefile文件达到但是,小白不会。🤦
