    SIPEED Lichee RV DOCK 全志D1开发板
    sipeed lichee rv dock d1
    13
    8600
      memory LV 7 最后由 whycan 编辑
      购买地址: https://item.taobao.com/item.htm?id=666274331852
      资料下载地址: https://dl.sipeed.com/shareURL/LICHEE/D1/Lichee_RV-Dock
      WIKI: https://wiki.sipeed.com/hardware/zh/lichee/RV/Dock.html
        memory LV 7 最后由 编辑
        规格书中文版: Sipeed Lichee RV DOCK 规格书 V1.0.pdf
        规格书英文版: Sipeed Lichee RV DOCK Datasheet V1.0.pdf
          memory LV 7 最后由 编辑
            源码补丁包下载: d1_hdmionly_ucgi_demo_whycanpi_patch_src_20220110.tgz
            全志官方格式TF卡固件下载: tina_d1-hdmionly_ucgui_demo_uart0_20220110.img.7z
            开机运行ucgui demo
            先执行: source build/envsetup.sh
            再执行: lunch d1_hdmionly-tina
            然后执行: make
            接着执行: pack
            就会生成: out/d1-hdmionly/tina_d1-hdmionly_uart0.img
            R 1 条回复 最后回复 回复 引用 分享 0
              memory LV 7 最后由 编辑
              X 1 条回复 最后回复 回复 引用 分享 0
                memory LV 7 最后由 编辑
                55寸的 电子表你见过吗?
                • R
                  Readme0 LV 5 @memory 最后由 编辑
                  @memory
                  make编译会报错,猜测和环境相关(我的ubuntu是20.04)
                  编译报错1:
                  gdbusauth.c:1298:11: error: '%s' directive argument is null [-Werror=format-overflow=]
                   1298 |           debug_print ("SERVER: WaitingForBegin, read '%s'", line);
                  gdbusmessage.c: In function 'g_dbus_message_to_blob':
                  gdbusmessage.c:2698:30: error: '%s' directive argument is null [-Werror=format-overflow=]
                   2698 |       tupled_signature_str = g_strdup_printf ("(%s)", signature_str);
                  解决:
                  在前面手动加上条件判断就好了:if(line != NULL)、if(signature_str!= NULL),或者直接屏蔽该行
                  编译报错2:
                  gawk: ./mkerrcodes.awk:88: warning: regexp escape sequence `\#' is not a known regexp operator
                  rm _mkerrcodes.h
                  cc -I. -I. -o mkerrcodes ./mkerrcodes.c
                  ./mkerrcodes | gawk -f ./mkerrcodes2.awk >code-from-errno.h
                  gawk: ./mkerrcodes2.awk:94: warning: regexp escape sequence `\#' is not a known regexp operator
                  gawk -f ./mkstrtable.awk -v textidx=2 -v nogettext=1 \
                  	./err-sources.h.in >err-sources-sym.h
                  gawk: ./mkstrtable.awk:113: warning: regexp escape sequence `\#' is not a known regexp operator
                  	./err-codes.h.in >err-codes-sym.h
                  	-v prefix=GPG_ERR_ -v namespace=errnos_ \
                  	./errnos.in >errnos-sym.h
                  gawk: fatal: cannot use gawk builtin `namespace' as variable name
                  make[6]: *** [Makefile:1324: errnos-sym.h] Error 2
                  解决:逐一将"sub (/#.+/, “”);",改为:“sub (/#.+/, “”);”,也就是说最新的gawk能够识别到’#'号不需要使用转义字符(‘\‘)的帮助。另外将“namespce”改为“pkg_namespace”:
                  cd d1-tina-sdk/out/d1-hdmionly/compile_dir/target/libgpg-error-1.27
                  grep -rn "sub (/\#*" ./
                  grep -rn "namespace" ./
                  tigger 1 条回复 最后回复 回复 引用 分享 1
                  • tigger
                    tigger LV 7 @Readme0 最后由 编辑
                    @readme0
                    HDMI有反应了吗?
                      运行下面的命令行,显示切换到 HDMI :
                      cd /sys/kernel/debug/dispdbg
                      echo disp0 > name; echo switch1 > command; echo 4 10 0 0 0x4 0x101 0 0 0 8 > param; echo 1 > start;
                      查看disp信息:
                      # cat /sys/class/disp/disp/attr/sys
                      screen 0:
                      de_rate 300000000 hz, ref_fps:60
                      mgr0: 1920x1080 fmt[rgb] cs[0x101] range[limit] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
                              hdmi output mode(10)    fps:60.6        1920x1080
                              err:1   skip:217        irq:351130      vsync:0 vsync_skip:0
                      BUF    enable ch[0] lyr[0] z[0] prem[N] a[pixel   0] fmt[ 77] fb[1280, 736; 640, 368; 640, 368] crop[   0,   0,1280, 720] frame[   0,   0,1920,1080] addr[fe000000,fe0e6000,fe11f800] flags[0x       0] trd[0,0]
                      depth[ 0]
                      BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 800, 480; 800, 480; 800, 480] crop[   0,   0, 800, 480] frame[   0,   0, 800, 480] addr[ffc00000,       0,       0] flags[0x       0] trd[0,0]
                      depth[ 0]
                      查看声卡:
                      # cat /proc/asound/cards
                       0 [audiocodec     ]: audiocodec - audiocodec
                                            audiocodec
                       1 [snddmic        ]: snddmic - snddmic
                                            snddmic
                       2 [sndhdmi        ]: sndhdmi - sndhdmi
                                            sndhdmi
                      噪声从HDMI显示屏输出:
                      aplay -D hw:sndhdmi -f S16_LE -c 2 -r 48000 /dev/urandom
                      播放视频:
                      tplayerdemo /tmp/x.mp4
                      • R
                        Readme0 LV 5 最后由 编辑
                        请问这个补丁包支持Tina 2.0 sdk吗?感谢。
                        M 1 条回复 最后回复 回复 引用 分享 1
                          memory LV 7 @Readme0 最后由 编辑
                          @readme0
                          可能不支持。请稍等,我晚些改一个for v2.0 的patch发上来。
                          • X
                            XYF123 LV 2 @memory 最后由 编辑
                            @memory 你好这个显示时钟的代码能发一下吗
                            • X
                              @memory 代码能发一下吗
