    D1s RTL8723DS wlan1 作为wifi热点
    d1s rtl8723ds wifi热点 hostapd
      memory LV 7 最后由 编辑
      ① 设置 wlan1 地址:
      ifconfig wlan1 192.168.5.1
      ② /etc/wifi/hostapd.conf 里面的 wlan0 改为 wlan1
      interface=wlan1
      driver=nl80211
      ssid=aw_ap001
      channel=6
      hw_mode=g
      ignore_broadcast_ssid=0
      auth_algs=1
      wpa=3
      wpa_passphrase=12345678
      wpa_key_mgmt=WPA-PSK
      wpa_pairwise=TKIP
      rsn_pairwise=CCMP
      ③ 执行hostapd:
      hostapd -B /etc/wifi/hostapd.conf
      ④ /etc/dnsmasq.conf 里面的 wlan0 改为 wlan1:
      # Change the following lines if you want dnsmasq to serve SRV
      # records.
      # You may add multiple srv-host lines.
      # The fields are <name>,<target>,<port>,<priority>,<weight>
      # A SRV record sending LDAP for the example.com domain to
      # ldapserver.example.com port 289
      #srv-host=_ldap._tcp.example.com,ldapserver.example.com,389
      # Two SRV records for LDAP, each with different priorities
      #srv-host=_ldap._tcp.example.com,ldapserver.example.com,389,1
      #srv-host=_ldap._tcp.example.com,ldapserver.example.com,389,2
      # A SRV record indicating that there is no LDAP server for the domain
      # example.com
      # The following line shows how to make dnsmasq serve an arbitrary PTR
      # record. This is useful for DNS-SD.
      #ptr-record=_http._tcp.dns-sd-services,"New Employee Page._http._tcp.dns-sd-services"
      # Change the following lines to enable dnsmasq to serve TXT records.
      # These are used for things like SPF and zeroconf.
      # The fields are <name>,<text>,<text>...
      #Example SPF.
      #txt-record=example.com,"v=spf1 a -all"
      #Example zeroconf
      #txt-record=_http._tcp.example.com,name=value,paper=A4
      # Provide an alias for a "local" DNS name. Note that this _only_ works
      # for targets which are names from DHCP or /etc/hosts. Give host
      # "bert" another name, bertrand
      # The fields are <cname>,<target>
      #cname=bertand,bert
      resolv-file=/etc/resolv.dnsmasq.conf
      strict-order
      cache-size=102400
      interface=wlan1
      min-cache-ttl=3600
      dhcp-range=192.168.5.2,192.168.5.255
      all-servers
      dhcp-sequential-ip
      ⑤ 执行 dnsmasq:
      /etc/init.d/dnsmasq restart
      ⑥ 现在手机wifi可以连接此热点了!
      参考: D1 LicheeRV Dock 移植RTL8723DS驱动
      https://bbs.aw-ol.com/topic/994/share/6
        memory LV 7 最后由 编辑
        • Q
          qichongjin LV 2 最后由 编辑
          r329 只有wlan0 网卡RTK8189FTV ,配置后有热点了,但是手机始终连不上知道是哪里原因吗?
