Yuzuki Lizard V851S 开发板 WIFI 功能异常
没查出是什么原因,有哪位大神可以帮忙看看是什么问题?
源码来源:github docker [https://github.com/YuzukiHD/Yuzukilizard]
问题现象:使用未经修改的 SDK 编译出来的固件,无法正常扫描 SSID 和连接 WIFI。
已经排查:
- 确认有识别到 XR829。
- 确认有成功下载 firmware。
- 确认所选的配置是 40M,且 GPIO 配置正确。
- 使用 iw 和 wifi -s 都不能正常扫描 ssid。
- 使用 ifconfig waln0 可以正常的 up、down。
问题日志:以下是内核启动 WIFI 时的日志输出:
[ 5.782165] ======== XRADIO WIFI OPEN ======== [ 5.787181] [XRADIO] Driver Label:XR_V02.16.91 _HT40_01.33 Feb 17 2024 10:35:49 [ 5.795746] [XRADIO] Allocated hw_priv @ c37c6c80 [ 5.801281] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf! [ 5.810623] sunxi-wlan soc@03000000:wlan@0: bus_index: 1 [ 5.926666] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B [ 5.936923] [XRADIO] Detect SDIO card 1 [ 5.951799] sunxi-mmc sdc1: no vqmmc,Check if there is regulator [ 5.979134] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 6.019771] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 6.034411] open /dev/mtd1 failed,ret=-6 [ 6.034423] remoteproc0: Can't finded boot_package head [ 6.034428] remoteproc0: sunxi_request_firmwarefailed,ret=-19 [ 6.054089] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B [ 6.075296] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B [ 6.086091] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B [ 6.097147] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B [ 6.108870] mmc1: new high speed SDIO card at address 0001 [ 6.115965] [SBUS] XRadio Device:sdio clk=50000000 [ 6.123030] [XRADIO] XRADIO_HW_REV 1.0 detected. [ 6.179491] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000. [ 6.215546] [XRADIO] Bootloader complete [ 6.324725] [XRADIO] Firmware completed. [ 6.330654] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09 [ 6.348111] [XRADIO] Firmware Startup Done. [ 6.353158] [XRADIO_WRN] enable Multi-Rx! [ 6.370051] ieee80211 phy0: Failed to initialize wep: -2 [ 6.376126] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 6.472871] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL! [ 6.483380] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL! [ 6.493411] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL! [ 6.503160] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL! [ 6.583658] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 6.593242] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 6.602769] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 6.612213] [VIN_DEV_I2C]gc2053_mipi sensor read retry = 2 [ 6.819401] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 6.828941] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 6.838493] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 6.847865] [VIN_DEV_I2C]gc2053_mipi sensor read retry = 2 [ 7.074215] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 7.083765] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 7.093316] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 7.102687] [VIN_DEV_I2C]gc2053_mipi sensor read retry = 2 [ 7.309327] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 7.318844] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 7.328392] sunxi_i2c_do_xfer()1974 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x37) [ 7.337775] [VIN_DEV_I2C]gc2053_mipi sensor read retry = 2 [ 7.343932] [gc2053_mipi] error, chip found is not an target chip. [ 7.363360] [VIN_ERR]registering gc2053_mipi, No such device! [ 7.603549] udevd[893]: could not create /tmp/run/udev: No such file or directory [ 8.251755] file system registered [ 8.269359] configfs-gadget 4100000.udc-controller: failed to start g1: -19 [ 8.381933] read descriptors [ 8.385211] read strings [ 8.543205] sunxi_set_cur_vol_work()482 WARN: get power supply failed [ 8.630668] android_work: sent uevent USB_STATE=CONNECTED [ 8.814319] configfs-gadget gadget: high-speed config #1: c [ 8.820726] android_work: sent uevent USB_STATE=CONFIGURED [ 11.049029] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=54:0d:42:ee:1a:22 [ 11.057317] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=54:0d:42:ee:1a:22 [ 11.070863] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined. [ 11.089296] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
在使用扫描的时候,会出现如下问题:
root@TinaLinux:/# iw wlan0 scan scan aborted! [ 374.889081] [SCAN_WRN] Timeout waiting for scan complete notification. [ 374.896412] [SCAN_WRN] xradio_scan_timeout:scan timeout cnt=1 [ 374.902934] [SCAN_ERR] Scan failed (-110). [ 375.902951] [WSM_ERR] [FW-DEBUG] DbgId = 4 [ 375.907562] [WSM_ERR] [FW-DEBUG] 0x000F4242
从日志信息来看,通信和下载 WIFI 固件都没有问题,也尝试过使用 wifi -o sta 之后再 wifi -s,也不行。
[ 374.889081] [SCAN_WRN] Timeout waiting for scan complete notification. [ 374.896412] [SCAN_WRN] xradio_scan_timeout:scan timeout cnt=1 [ 374.902934] [SCAN_ERR] Scan failed (-110). [ 375.902951] [WSM_ERR] [FW-DEBUG] DbgId = 4 [ 375.907562] [WSM_ERR] [FW-DEBUG] 0x000F4242 [ 375.912376] [SCAN_WRN] Scan timeout already occured. Don't cancel work [ 730.729141] [SCAN_WRN] Timeout waiting for scan complete notification. [ 730.736667] [SCAN_WRN] xradio_scan_timeout:scan timeout cnt=2 [ 730.743224] [SCAN_ERR] Scan failed (-110). [ 731.743199] [WSM_ERR] [FW-DEBUG] DbgId = 4 [ 731.747803] [WSM_ERR] [FW-DEBUG] 0x000F4241
@dream 尝试解决办法3,获取最新的BSP补丁包。参考链接:https://forums.100ask.net/t/topic/5664
@null037 答非所问。
@null037 解决了,结合论坛的 SDK 以及 github 的 SDK,补充缺失的文件就行了。
