    T113 tina 使用spi nand flash启动报Kernel panic
    4
    32
    13156
      wxgd2017 LV 5 最后由 YuzukiTsuru 编辑
      [    2.610043] hub 1-0:1.0: USB hub found
      [    2.614291] hub 1-0:1.0: 1 port detected
      [    2.619509] get ohci1-controller wakeup-source is fail.
      [    2.625476] sunxi ohci1-controller don't init wakeup source
      [    2.631696] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c79f60
      [    2.641599] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    2.653841] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    2.661048] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    2.670795] sunxi-ohci 4200400.ohci1-controller: irq 63, io mem 0x04200400
      [    2.746265] hub 2-0:1.0: USB hub found
      [    2.750480] hub 2-0:1.0: 1 port detected
      [    2.757313] sun8iw20-pinctrl pio: pin PB6 already requested by 2502c00.twi; cannot claim for pio:38
      [    2.767455] sun8iw20-pinctrl pio: pin-38 (pio:38) status -22
      [    2.773766] ERR: id gpio_request failed
      [    2.780248] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    2.791454] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    2.798874] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    2.801430] clk: Not disabling unused clocks
      [    2.808508] cfg80211: failed to load regulatory.db
      [    2.813270] ALSA device list:
      [    2.821983]   #0: audiocodec
      [    2.825206] alloc_fd: slot 0 not NULL!
      [    2.829766] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
      [    2.838448] Please append a correct "root=" boot option; here are the available partitions:
      [    2.847858] 1f00            1024 mtdblock0
      [    2.847861]  (driver?)
      [    2.855167] 1f01            3072 mtdblock1
      [    2.855170]  (driver?)
      [    2.862491] 1f02            1024 mtdblock2
      [    2.862494]  (driver?)
      [    2.869769] 1f03          125952 mtdblock3
      [    2.869771]  (driver?)
      [    2.877086] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    2.886285] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #3
      [    2.892866] Hardware name: Generic DT based system
      [    2.898217] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
      [    2.906837] [<c010a870>] (show_stack) from [<c07946e0>] (dump_stack+0x7c/0x98)
      [    2.914878] [<c07946e0>] (dump_stack) from [<c011956c>] (panic+0x104/0x3d8)
      [    2.922631] [<c011956c>] (panic) from [<c0b01270>] (mount_block_root+0x254/0x2fc)
      [    2.930963] [<c0b01270>] (mount_block_root) from [<c0b014d0>] (prepare_namespace+0x138/0x178)
      [    2.940451] [<c0b014d0>] (prepare_namespace) from [<c07a8be0>] (kernel_init+0x8/0x10c)
      [    2.949266] [<c07a8be0>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [    2.957683] Exception stack(0xc7825fb0 to 0xc7825ff8)
      [    2.963301] 5fa0:                                     00000000 00000000 00000000 00000000
      [    2.972399] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    2.981497] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [    2.988861] CPU1: stopping
      [    2.991872] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #3
      [    2.998454] Hardware name: Generic DT based system
      [    3.003791] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
      [    3.012410] [<c010a870>] (show_stack) from [<c07946e0>] (dump_stack+0x7c/0x98)
      [    3.020448] [<c07946e0>] (dump_stack) from [<c010c648>] (handle_IPI+0xcc/0x168)
      [    3.028587] [<c010c648>] (handle_IPI) from [<c03629a4>] (gic_handle_irq+0x70/0x78)
      [    3.037014] [<c03629a4>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [    3.045337] Exception stack(0xc7865f80 to 0xc7865fc8)
      [    3.050958] 5f80: 00009214 c7ecc4f4 00000000 c0114b40 00000002 c7864000 c0c04e28 c0c04e64
      [    3.060060] 5fa0: 4000406a 410fc075 00000000 00000000 c0c637d0 c7865fd0 c0107f94 c0107f84
      [    3.069157] 5fc0: 60000113 ffffffff
      [    3.073041] [<c01021cc>] (__irq_svc) from [<c0107f84>] (arch_cpu_idle+0x1c/0x38)
      [    3.081273] [<c0107f84>] (arch_cpu_idle) from [<c013de94>] (do_idle+0xd0/0x120)
      [    3.089410] [<c013de94>] (do_idle) from [<c013e180>] (cpu_startup_entry+0x18/0x20)
      [    3.097837] [<c013e180>] (cpu_startup_entry) from [<40102bec>] (0x40102bec)
      [    3.105599] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
      E 1 条回复 最后回复 回复 引用 分享 0
      • Moved from MR Series by  YuzukiTsuru YuzukiTsuru
        柚木 鉉 LV 9 最后由 编辑
        默认是sd卡启动,修改env.cfg和sys_config.fex使用nand启动,主要是env.cfg,使用mtd设备
        W 1 条回复 最后回复 回复 引用 分享 0
          wxgd2017 LV 5 @YuzukiTsuru 最后由 YuzukiTsuru 编辑
          请问下怎么改,以下内容为env.cfg内容,谢谢
          #kernel command arguments
          earlyprintk=sunxi-uart,0x02500000
          initcall_debug=0
          console=ttyS0,115200
          nand_root=/dev/ubiblock0_5
          mmc_root=/dev/mmcblk0p5
          nor_root=/dev/mtdblock5
          mtd_name=sys
          rootfstype=squashfs
          root_partition=rootfs
          boot_partition=boot
          init=/sbin/init
          loglevel=8
          cma=0M
          mac=
          wifi_mac=
          bt_mac=
          specialstr=
          keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
          dsp0_partition=dsp0
          #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
          setargs_nand=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
          setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
          setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
          setargs_nor=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nor_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
          #nand command syntax: sunxi_flash read address partition_name read_bytes
          #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
          boot_dsp0=sunxi_flash read 45000000 ${dsp0_partition};bootr 45000000 0 0
          boot_normal=sunxi_flash read 41000000 ${boot_partition};bootm 41000000
          boot_recovery=sunxi_flash read 45000000 recovery;bootm 45000000
          boot_fastboot=fastboot
          #uboot system env config
          bootdelay=2
          #default bootcmd, will change at runtime according to key press
          #default nand boot
          bootcmd=run setargs_mmc boot_normal
            柚木 鉉 LV 9 最后由 编辑
            bootcmd=run setargs_nand boot_normal
              emperg LV 4 @wxgd2017 最后由 编辑
              @wxgd2017 除了env这些要改,buildroot config文件系统部分也要改。你可以对照d1s的nand buidroot来改
                wxgd2017 LV 5 @YuzukiTsuru 最后由 编辑
                @yuzukitsuru 试了也没用
                  柚木 鉉 LV 9 @wxgd2017 最后由 编辑
                  @wxgd2017 看一下报错
                    柚木 鉉 LV 9 @emperg 最后由 编辑
                    @emperg tina还有buildroot吗
                      柚木 鉉 LV 9 最后由 编辑
                      T113默认的是ubi,之前没注意
                      initcall_debug=0
                      nand_root=/dev/mtdblock3
                      mtd_name=sys
                      rootfstype=squashfs
                      boot_partition=boot
                      init=/sbin/init
                      loglevel=8
                      cma=0M
                      mac=
                      wifi_mac=
                      bt_mac=
                      specialstr=
                      dsp0_partition=dsp0
                      bootdelay=2
                      #default nand boot
                        wxgd2017 LV 5 @YuzukiTsuru 最后由 whycan 编辑
                          @wxgd2017 试试我上面发的那个cfg
                            用了你的这个env.cfg,也不行
                            U-Boot 2018.05 (Apr 02 2022 - 06:28:13 +0000) Allwinner Technology
                            [00.302]CPU:   Allwinner Family
                            [00.305]Model: sun8iw20
                            [00.307]DRAM:  128 MiB
                            [00.310]Relocation Offset is: 04ea5000
                            [00.338]secure enable bit: 0
                            [00.341]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                            [00.347]gic: sec monitor mode
                            [00.350]flash init start
                            [00.352]workmode = 0,storage type = 0
                            sspi->base_addr = 0x4025000, the SPI control register:
                            [VER] 0x4025000 = 0x00010001, [GCR] 0x4025004 = 0x00000083, [TCR] 0x4025008 = 0x00000184
                            [ICR] 0x4025010 = 0x00000f00, [ISR] 0x4025014 = 0x00000032, [FCR] 0x4025018 = 0x00200020
                            [FSR] 0x402501c = 0x00000000, [WCR] 0x4025020 = 0x00000000, [CCR] 0x4025024 = 0x00000002
                            [SDC] 0x4025028 = 0x00002000, [BCR] 0x4025030 = 0x00000000, [TCR] 0x4025034 = 0x00000000
                            [BCC] 0x4025038 = 0x20000000, [DMA] 0x4025088 = 0x000000e5
                            [00.398]sunxi-spinand-phy: not detect any munufacture from id table
                            [00.405]sunxi-spinand-phy: get spi-nand Model from fdt fail
                            [00.410]sunxi-spinand-phy: get phy info from fdt fail
                            device nand0 <nand>, # parts = 4
                             #: name		size		offset		mask_flags
                             0: boot0               0x00100000	0x00000000	1
                             1: uboot               0x00300000	0x00100000	1
                             2: secure_storage      0x00100000	0x00400000	1
                             3: sys                 0x07b00000	0x00500000	0
                            active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
                            defaults:
                            mtdids  : nand0=nand
                            mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
                            [00.611]ubi0: attaching mtd4
                            [00.723]ubi0: scanning is finished
                            [00.730]ubi0: attached mtd4 (name "sys", size 123 MiB)
                            [00.734]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                            [00.741]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                            [00.747]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                            [00.753]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
                            [00.758]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
                            [00.765]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                            [00.773]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
                            [00.781]sunxi flash init ok
                            [00.784]line:703 init_clocks
                            [00.787]drv_disp_init
                            request pwm success, pwm7:pwm7:0x2000c00.
                            [00.800]drv_disp_init finish
                            [00.802]boot_gui_init:start
                            [00.805]set disp.dev2_output_type fail. using defval=0
                            [00.811]boot_gui_init:finish
                            partno erro : can't find partition bootloader
                            54 bytes read in 0 ms
                            [00.924]bmp_name=bootlogo.bmp size 38454
                            38454 bytes read in 3 ms (12.2 MiB/s)
                            [00.992]LCD open finish
                            [01.031]Loading Environment from SUNXI_FLASH... OK
                            [01.054]Item0 (Map) magic is bad
                            secure storage read widevine fail
                            [01.060]secure storage read widevine fail with:-1
                            secure storage read ec_key fail
                            [01.067]secure storage read ec_key fail with:-1
                            secure storage read ec_cert1 fail
                            [01.074]secure storage read ec_cert1 fail with:-1
                            secure storage read ec_cert2 fail
                            [01.082]secure storage read ec_cert2 fail with:-1
                            secure storage read ec_cert3 fail
                            [01.089]secure storage read ec_cert3 fail with:-1
                            secure storage read rsa_key fail
                            [01.097]secure storage read rsa_key fail with:-1
                            secure storage read rsa_cert1 fail
                            [01.104]secure storage read rsa_cert1 fail with:-1
                            secure storage read rsa_cert2 fail
                            [01.112]secure storage read rsa_cert2 fail with:-1
                            secure storage read rsa_cert3 fail
                            [01.119]secure storage read rsa_cert3 fail with:-1
                            [01.124]out of usb burn from boot: not need burn key
                            partno erro : can't find partition private
                            [01.156]update bootcmd
                            [01.170]change working_fdt 0x46a64e70 to 0x46a44e70
                            [01.190]update dts
                            geth_sys_init:624: get node 'gmac0' error
                            geth_sys_init fail!
                            [01.197]Board Net Initialization Failed
                            [01.201]No ethernet found.
                            Hit any key to stop autoboot:  0
                            [03.489]no vendor_boot partition is found
                            Android's image name: t113-mq
                            [03.501]Starting kernel ...
                            [    0.000000] Booting Linux on physical CPU 0x0
                            [    0.000000] Linux version 5.4.61 (easyboard@V3S) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #9 SMP PREEMPT Wed Apr 13 13:01:21 UTC 2022
                            [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
                            [    0.000000] CPU: div instructions available: patching division code
                            [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                            [    0.000000] OF: fdt: Machine model: sun8iw20
                            [    0.000000] printk: bootconsole [earlycon0] enabled
                            [    0.000000] Memory policy: Data cache writealloc
                            [    0.000000] On node 0 totalpages: 32512
                            [    0.000000]   Normal zone: 256 pages used for memmap
                            [    0.000000]   Normal zone: 0 pages reserved
                            [    0.000000]   Normal zone: 32512 pages, LIFO batch:7
                            [    0.000000] psci: probing for conduit method from DT.
                            [    0.000000] psci: PSCIv1.0 detected in firmware.
                            [    0.000000] psci: Using standard PSCI v0.2 function IDs
                            [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
                            [    0.000000] psci: SMC Calling Convention v1.0
                            [    0.000000] percpu: Embedded 15 pages/cpu s30796 r8192 d22452 u61440
                            [    0.000000] pcpu-alloc: s30796 r8192 d22452 u61440 alloc=15*4096
                            [    0.000000] pcpu-alloc: [0] 0 [0] 1
                            [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32256
                            [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=ubi0_5 rootfstype=squashfs init=/sbin/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:UDISK@ubi0_6: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05(04/02/2022-06:28:13) mbr_offset=1032192 disp_reserve=1536000,0x46ae8000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
                            [    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
                            [    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
                            [    0.000000] Memory: 114172K/130048K available (7168K kernel code, 353K rwdata, 1900K rodata, 1024K init, 177K bss, 15876K reserved, 0K cma-reserved)
                            [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
                            [    0.000000] rcu: Preemptible hierarchical RCU implementation.
                            [    0.000000] 	Tasks RCU enabled.
                            [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                            [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                            [    0.000000] random: get_random_bytes called from start_kernel+0x254/0x3d8 with crng_init=0
                            [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
                            [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
                            [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
                            [    0.008018] Switching to timer-based delay loop, resolution 41ns
                            [    0.014201] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                            [    0.023961] Console: colour dummy device 80x30
                            [    0.028441] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                            [    0.038822] pid_max: default: 32768 minimum: 301
                            [    0.043565] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                            [    0.050912] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                            [    0.059278] CPU: Testing write buffer coherency: ok
                            [    0.064521] /cpus/cpu@0 missing clock-frequency property
                            [    0.069850] /cpus/cpu@1 missing clock-frequency property
                            [    0.075196] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                            [    0.081458] Setting up static identity map for 0x40100000 - 0x40100060
                            [    0.088137] rcu: Hierarchical SRCU implementation.
                            [    0.093419] smp: Bringing up secondary CPUs ...
                            [    0.099198] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                            [    0.099359] smp: Brought up 1 node, 2 CPUs
                            [    0.109175] SMP: Total of 2 processors activated (96.00 BogoMIPS).
                            [    0.115372] CPU: All CPU(s) started in SVC mode.
                            [    0.120486] devtmpfs: initialized
                            [    0.136208] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                            [    0.144417] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                            [    0.154281] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
                            [    0.161228] pinctrl core: initialized pinctrl subsystem
                            [    0.167875] NET: Registered protocol family 16
                            [    0.173154] DMA: preallocated 256 KiB pool for atomic coherent allocations
                            [    0.220731] rtc_ccu: sunxi ccu init OK
                            [    0.226688] ccu: sunxi ccu init OK
                            [    0.230558] r_ccu: sunxi ccu init OK
                            [    0.286854] iommu: Default domain type: Translated
                            [    0.292027] sunxi iommu: irq = 24
                            [    0.296521] SCSI subsystem initialized
                            [    0.300636] usbcore: registered new interface driver usbfs
                            [    0.306276] usbcore: registered new interface driver hub
                            [    0.311704] usbcore: registered new device driver usb
                            [    0.316957] mc: Linux media interface: v0.10
                            [    0.321330] videodev: Linux video capture interface: v2.00
                            [    0.328304] sunxi-msgbox-amp 3003000.msgbox: invalid resource
                            [    0.335113] Advanced Linux Sound Architecture Driver Initialized.
                            [    0.341980] Bluetooth: Core ver 2.22
                            [    0.345639] NET: Registered protocol family 31
                            [    0.350087] Bluetooth: HCI device and connection manager initialized
                            [    0.356678] Bluetooth: HCI socket layer initialized
                            [    0.361583] Bluetooth: L2CAP socket layer initialized
                            [    0.366694] Bluetooth: SCO socket layer initialized
                            [    0.371962] pwm module init!
                            [    0.376269] ths test int keyboard for ONE_CHANNEL
                            [    0.381298] input: sunxi-keyboard as /devices/virtual/input/input0
                            [    0.389043] clocksource: Switched to clocksource arch_sys_counter
                            [    0.404565] sun8iw20-pinctrl pio: initialized sunXi PIO driver
                            [    0.425441] thermal_sys: Registered thermal governor 'user_space'
                            [    0.425449] thermal_sys: Registered thermal governor 'power_allocator'
                            [    0.432326] NET: Registered protocol family 2
                            [    0.444032] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                            [    0.452474] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                            [    0.460199] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                            [    0.467269] TCP: Hash tables configured (established 1024 bind 1024)
                            [    0.473773] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                            [    0.480368] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                            [    0.487572] NET: Registered protocol family 1
                            [    0.493351] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
                            [    0.501677] spi spi0: spi0 supply spi not found, using dummy regulator
                            [    0.508404] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
                            [    0.514629] sunxi_spi_resource_get()2189 - Failed to get sample mode
                            [    0.521016] sunxi_spi_resource_get()2194 - Failed to get sample delay
                            [    0.527474] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
                            [    0.535884] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
                            [    0.542320] spi spi0: chipselect 0 already in use
                            [    0.547037] spi_master spi0: spi_device register error /soc@3000000/spi@4025000/spi_board@0
                            [    0.555444] spi_master spi0: Failed to create SPI device for /soc@3000000/spi@4025000/spi_board@0
                            [    0.564372] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8868000, irq 42
                            [    0.574378] Initialise system trusted keyrings
                            [    0.579165] workingset: timestamp_bits=30 max_order=15 bucket_order=0
                            [    0.593804] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                            [    0.627599] Key type asymmetric registered
                            [    0.631731] Asymmetric key parser 'x509' registered
                            [    0.636637] io scheduler mq-deadline registered
                            [    0.641276] io scheduler kyber registered
                            [    0.645391] atomic64_test: passed
                            [    0.650466] [DISP]disp_module_init
                            [    0.654520] disp 5000000.disp: Adding to iommu group 0
                            [    0.660369] [DISP] disp_init,line:2329:
                            [    0.660375] smooth display screen:0 type:1 mode:4
                            [    0.685529] display_fb_request,fb_id:0
                            [    0.694593] Freeing logo buffer memory: 1500K
                            [    0.699571] disp_al_manager_apply ouput_type:1
                            [    0.704297] [DISP] lcd_clk_config,line:731:
                            [    0.704309] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
                            [    0.704309]      clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
                            [    0.709888] [DISP]disp_module_init finish
                            [    0.724737] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
                            [    0.730234] sunxi_sid_init()551 - insmod ok
                            [    0.741084] pwm-regulator: supplied by regulator-dummy
                            [    0.748600] uart uart0: get regulator failed
                            [    0.752946] uart uart0: uart0 supply uart not found, using dummy regulator
                            [    0.760212] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
                            [    0.768108] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
                            [    0.776191] printk: console [ttyS0] enabled
                            [    0.785073] printk: bootconsole [earlycon0] disabled
                            [    0.796421] uart uart2: get regulator failed
                            [    0.801280] uart uart2: uart2 supply uart not found, using dummy regulator
                            [    0.809364] uart2: ttyS2 at MMIO 0x2500800 (irq = 35, base_baud = 1500000) is a SUNXI
                            [    0.818839] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
                            [    0.827924] uart uart3: get regulator failed
                            [    0.832743] uart uart3: uart3 supply uart not found, using dummy regulator
                            [    0.840747] uart3: ttyS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
                            [    0.850646] misc dump reg init
                            [    0.856739] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
                            [    0.863990] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
                            [    0.871964] sunxi-spinand-phy: not detect any munufacture from id table
                            [    0.879372] sunxi-spinand-phy: get spi-nand Model from fdt fail
                            [    0.885986] sunxi-spinand-phy: get phy info from fdt fail
                            [    0.892019] sunxi-spinand-phy: not detect munufacture from fdt
                            [    0.898705] sunxi-spinand-phy: detect munufacture from id table: Dosilicon
                            [    0.906399] sunxi-spinand-phy: detect spinand id: ffff71e5 ffffffff
                            [    0.913409] sunxi-spinand-phy: ========== arch info ==========
                            [    0.919923] sunxi-spinand-phy: Model:               DS35X1GAXXX
                            [    0.926532] sunxi-spinand-phy: Munufacture:         Dosilicon
                            [    0.932947] sunxi-spinand-phy: DieCntPerChip:       1
                            [    0.938584] sunxi-spinand-phy: BlkCntPerDie:        1024
                            [    0.944515] sunxi-spinand-phy: PageCntPerBlk:       64
                            [    0.950259] sunxi-spinand-phy: SectCntPerPage:      4
                            [    0.955888] sunxi-spinand-phy: OobSizePerPage:      64
                            [    0.961624] sunxi-spinand-phy: BadBlockFlag:        0x1
                            [    0.967454] sunxi-spinand-phy: OperationOpt:        0x7
                            [    0.973288] sunxi-spinand-phy: MaxEraseTimes:       65000
                            [    0.979329] sunxi-spinand-phy: EccFlag:             0x0
                            [    0.985152] sunxi-spinand-phy: EccType:             2
                            [    0.990799] sunxi-spinand-phy: EccProtectedType:    3
                            [    0.996428] sunxi-spinand-phy: ========================================
                            [    1.003818] sunxi-spinand-phy:
                            [    1.007315] sunxi-spinand-phy: ========== physical info ==========
                            [    1.014215] sunxi-spinand-phy: TotalSize:    128 M
                            [    1.019587] sunxi-spinand-phy: SectorSize:   512 B
                            [    1.024926] sunxi-spinand-phy: PageSize:     2 K
                            [    1.030099] sunxi-spinand-phy: BlockSize:    128 K
                            [    1.035438] sunxi-spinand-phy: OOBSize:      64 B
                            [    1.040691] sunxi-spinand-phy: ========================================
                            [    1.048071] sunxi-spinand-phy:
                            [    1.051580] sunxi-spinand-phy: ========== logical info ==========
                            [    1.058379] sunxi-spinand-phy: TotalSize:    128 M
                            [    1.063728] sunxi-spinand-phy: SectorSize:   512 B
                            [    1.069077] sunxi-spinand-phy: PageSize:     4 K
                            [    1.074229] sunxi-spinand-phy: BlockSize:    256 K
                            [    1.079584] sunxi-spinand-phy: OOBSize:      128 B
                            [    1.084930] sunxi-spinand-phy: ========================================
                            [    1.092440] sunxi-spinand-phy: block lock register: 0x00
                            [    1.098500] sunxi-spinand-phy: feature register: 0x11
                            [    1.104158] sunxi-spinand-phy: sunxi physic nand init end
                            [    1.110675] Creating 4 MTD partitions on "sunxi_mtd_nand":
                            [    1.116800] 0x000000000000-0x000000100000 : "boot0"
                            [    1.130195] 0x000000100000-0x000000400000 : "uboot"
                            [    1.138620] random: fast init done
                            [    1.160210] 0x000000400000-0x000000500000 : "secure_storage"
                            [    1.180182] 0x000000500000-0x000008000000 : "sys"
                            [    1.637231] random: crng init done
                            [    1.690747] libphy: Fixed MDIO Bus: probed
                            [    1.695984] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
                            [    1.705089] sunxi gmac driver's version: 1.0.0
                            [    1.710290] gmac-power0: NULL
                            [    1.713599] gmac-power1: NULL
                            [    1.716927] gmac-power2: NULL
                            [    1.720342] rtl8363nb_vb_init->575 rtk8363 init=====
                            [    1.725888] rtk_switch_probe->1011 flyranchao data = 0x0 regValue = 0x0===
                            [    1.733590] rtk switch init failed!
                            [    1.738553] Failed to alloc md5
                            [    1.742156] eth0: Use random mac address
                            [    1.746872] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                            [    1.754215] sunxi-ehci: EHCI SUNXI driver
                            [    1.759140] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                            [    1.766060] sunxi-ohci: OHCI SUNXI driver
                            [    1.771231] usbcore: registered new interface driver uas
                            [    1.777244] usbcore: registered new interface driver usb-storage
                            [    1.784051] usbcore: registered new interface driver ums-alauda
                            [    1.790770] usbcore: registered new interface driver ums-cypress
                            [    1.797526] usbcore: registered new interface driver ums-datafab
                            [    1.804314] usbcore: registered new interface driver ums_eneub6250
                            [    1.811284] usbcore: registered new interface driver ums-freecom
                            [    1.818034] usbcore: registered new interface driver ums-isd200
                            [    1.824711] usbcore: registered new interface driver ums-jumpshot
                            [    1.831583] usbcore: registered new interface driver ums-karma
                            [    1.838144] usbcore: registered new interface driver ums-onetouch
                            [    1.845042] usbcore: registered new interface driver ums-realtek
                            [    1.851821] usbcore: registered new interface driver ums-sddr09
                            [    1.858488] usbcore: registered new interface driver ums-sddr55
                            [    1.865172] usbcore: registered new interface driver ums-usbat
                            [    1.871757] usbcore: registered new interface driver idmouse
                            [    1.878919] sunxi_gpadc_init,2113, success
                            [    1.883883] sunxi_gpadc_setup: get channel scan data failed
                            [    1.890407] input: sunxi-gpadc0 as /devices/virtual/input/input1
                            [    1.899590] sunxi-rtc 7090000.rtc: registered as rtc0
                            [    1.905360] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:34 UTC (34)
                            [    1.914364] sunxi-rtc 7090000.rtc: sunxi rtc probed
                            [    1.920288] i2c /dev entries driver
                            [    1.924307] IR NEC protocol handler initialized
                            [    1.929833] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
                            [    1.938773] sunxi_ir_startup: get ir protocol failed
                            [    1.938793] (NULL device *): deviceless supply  not found, using dummy regulator
                            [    1.952707] Registered IR keymap rc_map_sunxi
                            [    1.957732] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
                            [    1.966436] rc rc0: lirc_dev: driver sunxi-rc-recv registered at minor = 0, raw IR receiver, no transmitter
                            [    1.977545] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
                            [    1.987851] sunxi cedar version 1.1
                            [    1.991988] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
                            [    1.998248] VE: sunxi_cedar_probe power-domain init!!!
                            [    2.004006] VE: install start!!!
                            [    2.004006]
                            [    2.009607] VE: cedar-ve the get irq is 43
                            [    2.009607]
                            [    2.016062] VE: ve_debug_proc_info:1d4e605e, data:6f2b805c, lock:ab2f5335
                            [    2.016062]
                            [    2.025321] VE: install end!!!
                            [    2.025321]
                            [    2.030387] VE: sunxi_cedar_probe
                            [    2.035683] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                            [    2.044844] Bluetooth: HCI UART driver ver 2.3
                            [    2.049829] Bluetooth: HCI UART protocol H4 registered
                            [    2.055558] Bluetooth: HCI UART protocol BCSP registered
                            [    2.061494] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
                            [    2.068707] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
                            [    2.075089] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
                            [    2.081622] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
                            [    2.081622]
                            [    2.090270] [XR_BT_LPM] bluesleep_probe: uart_index(1)
                            [    2.098422] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-05-12 11:02)
                            [    2.108356] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
                            [    2.114553] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
                            [    2.120907] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
                            [    2.127316] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
                            [    2.133751] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
                            [    2.140271] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
                            [    2.146777] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
                            [    2.153292] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
                            [    2.159835] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
                            [    2.169258] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                            [    2.180378] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                            [    2.200479] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                            [    2.224679] sunxi-mmc 4021000.sdmmc: detmode:manually by software
                            [    2.232236] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                            [    2.240154] usbcore: registered new interface driver usbhid
                            [    2.250160] usbhid: USB HID core driver
                            [    2.251332] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                            [    2.254466] exFAT: Version 1.3.0
                            [    2.269681] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
                            [    2.280818] usbcore: registered new interface driver snd-usb-audio
                            [    2.289929] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
                            [    2.289929]
                            [    2.307078] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
                            [    2.318481] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
                            [    2.327918] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
                            [    2.337742] [SNDCODEC][sunxi_card_init][583]:card init finished
                            [    2.344838] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
                            [    2.356050] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input3
                            [    2.368324] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
                            [    2.376790] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
                            [    2.385328] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
                            [    2.389136] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
                            [    2.401305] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                            [    2.409551] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.1.257: id:sunxi,dsp-msgbox new channel: 0x1 -> 0x101!
                            [    2.413069] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                            [    2.424220] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.1.257: rpmsg hifi[0] client driver is probed
                            [    2.445639] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                            [    2.458409] mmc0: new high speed SDIO card at address 0001
                            [    2.459313] NET: Registered protocol family 10
                            [    2.471584] Segment Routing with IPv6
                            [    2.475801] NET: Registered protocol family 17
                            [    2.480980] Bluetooth: RFCOMM TTY layer initialized
                            [    2.486444] Bluetooth: RFCOMM socket layer initialized
                            [    2.492246] Bluetooth: RFCOMM ver 1.11
                            [    2.496477] 8021q: 802.1Q VLAN Support v1.8
                            [    2.502041] Registering SWP/SWPB emulation handler
                            [    2.507779] Loading compiled-in X.509 certificates
                            [    2.513723] fs-verity: Initialized fs-verity
                            [    2.538490] twi twi3: twi3 supply twi not found, using dummy regulator
                            [    2.546779] sunxi_i2c_probe()2266 - [i2c3] probe success
                            [    2.590365] get ehci0-controller wakeup-source is fail.
                            [    2.596346] sunxi ehci0-controller don't init wakeup source
                            [    2.602732] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c797b0, 0x:c94ef000, irq_no:3c
                            [    2.614811] [sunxi-ehci0]: Not init ehci0
                            [    2.619730] get ohci0-controller wakeup-source is fail.
                            [    2.625716] sunxi ohci0-controller don't init wakeup source
                            [    2.632020] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c79a40
                            [    2.641707] [sunxi-ohci0]: Not init ohci0
                            [    2.646594] get ehci1-controller wakeup-source is fail.
                            [    2.652589] sunxi ehci1-controller don't init wakeup source
                            [    2.658871] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c79cd0, 0x:c94f9000, irq_no:3e
                            [    2.671162] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
                            [    2.684666] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
                            [    2.691960] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
                            [    2.701809] sunxi-ehci 4200000.ehci1-controller: irq 62, io mem 0x04200000
                            [    2.739060] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
                            [    2.747779] hub 1-0:1.0: USB hub found
                            [    2.752081] hub 1-0:1.0: 1 port detected
                            [    2.757346] get ohci1-controller wakeup-source is fail.
                            [    2.763400] sunxi ohci1-controller don't init wakeup source
                            [    2.769681] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c79f60
                            [    2.779628] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
                            [    2.792002] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
                            [    2.799289] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
                            [    2.809154] sunxi-ohci 4200400.ohci1-controller: irq 63, io mem 0x04200400
                            [    2.883960] hub 2-0:1.0: USB hub found
                            [    2.888231] hub 2-0:1.0: 1 port detected
                            [    2.894610] ubi0: attaching mtd3
                            [    3.165367] ubi0: scanning is finished
                            [    3.178903] ubi0: attached mtd3 (name "sys", size 123 MiB)
                            [    3.185169] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                            [    3.192928] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                            [    3.200569] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                            [    3.208391] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
                            [    3.215147] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
                            [    3.223271] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                            [    3.232704] ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
                            [    3.243091] ubi0: background thread "ubi_bgt0d" started, PID 1075
                            [    3.251222] block ubiblock0_5: created from ubi0:5(rootfs)
                            [    3.257931] sun8iw20-pinctrl pio: pin PB6 already requested by 2502c00.twi; cannot claim for pio:38
                            [    3.268144] sun8iw20-pinctrl pio: pin-38 (pio:38) status -22
                            [    3.274503] ERR: id gpio_request failed
                            [    3.281094] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                            [    3.292353] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                            [    3.299835] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                            [    3.309079] clk: Not disabling unused clocks
                            [    3.309531] cfg80211: failed to load regulatory.db
                            [    3.314299] ALSA device list:
                            [    3.323103]   #0: audiocodec
                            [    3.326377] alloc_fd: slot 0 not NULL!
                            [    3.331019] ubi0_5: Can't open blockdev
                            [    3.335339] VFS: Cannot open root device "ubi0_5" or unknown-block(0,0): error -2
                            [    3.343797] Please append a correct "root=" boot option; here are the available partitions:
                            [    3.353225] 1f00            1024 mtdblock0
                            [    3.353228]  (driver?)
                            [    3.360583] 1f01            3072 mtdblock1
                            [    3.360586]  (driver?)
                            [    3.367930] 1f02            1024 mtdblock2
                            [    3.367932]  (driver?)
                            [    3.375289] 1f03          125952 mtdblock3
                            [    3.375292]  (driver?)
                            [    3.382709] fe00          102564 ubiblock0_5
                            [    3.382712]  (driver?)
                            [    3.390265] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                            [    3.399538] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #9
                            [    3.406174] Hardware name: Generic DT based system
                            [    3.411566] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
                            [    3.420258] [<c010a870>] (show_stack) from [<c0799760>] (dump_stack+0x7c/0x98)
                            [    3.428365] [<c0799760>] (dump_stack) from [<c011956c>] (panic+0x104/0x3d8)
                            [    3.436179] [<c011956c>] (panic) from [<c0b01270>] (mount_block_root+0x254/0x2fc)
                            [    3.444577] [<c0b01270>] (mount_block_root) from [<c0b0141c>] (prepare_namespace+0x84/0x178)
                            [    3.454046] [<c0b0141c>] (prepare_namespace) from [<c07adc60>] (kernel_init+0x8/0x10c)
                            [    3.462931] [<c07adc60>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
                            [    3.471419] Exception stack(0xc7825fb0 to 0xc7825ff8)
                            [    3.477084] 5fa0:                                     00000000 00000000 00000000 00000000
                            [    3.486258] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                            [    3.495432] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
                            [    3.502856] CPU1: stopping
                            [    3.505891] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #9
                            [    3.512527] Hardware name: Generic DT based system
                            [    3.517904] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
                            [    3.526593] [<c010a870>] (show_stack) from [<c0799760>] (dump_stack+0x7c/0x98)
                            [    3.534697] [<c0799760>] (dump_stack) from [<c010c648>] (handle_IPI+0xcc/0x168)
                            [    3.542901] [<c010c648>] (handle_IPI) from [<c0367a24>] (gic_handle_irq+0x70/0x78)
                            [    3.551396] [<c0367a24>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
                            [    3.559787] Exception stack(0xc7865f80 to 0xc7865fc8)
                            [    3.565454] 5f80: 00010ac8 c7ecc4f4 00000000 c0114b40 00000002 c7864000 c0c04e28 c0c04e64
                            [    3.574629] 5fa0: 4000406a 410fc075 00000000 00000000 c0c637d0 c7865fd0 c0107f94 c0107f84
                            [    3.583800] 5fc0: 60000013 ffffffff
                            [    3.587715] [<c01021cc>] (__irq_svc) from [<c0107f84>] (arch_cpu_idle+0x1c/0x38)
                            [    3.596016] [<c0107f84>] (arch_cpu_idle) from [<c013de94>] (do_idle+0xd0/0x120)
                            [    3.604216] [<c013de94>] (do_idle) from [<c013e180>] (cpu_startup_entry+0x18/0x20)
                            [    3.612709] [<c013e180>] (cpu_startup_entry) from [<40102bec>] (0x40102bec)
                            [    3.620530] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
                              用了,也不行
                                柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
                                initcall_debug=0
                                rootfstype=squashfs
                                init=/sbin/init
                                loglevel=8
                                cma=0M
                                mac=
                                wifi_mac=
                                bt_mac=
                                specialstr=
                                dsp0_partition=dsp0
                                setargs=earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mtdblock3  init=/sbin/init partitions=ext4 cma=8M  gpt=1
                                bootdelay=2
                                bootcmd=run setargs boot_normal
                                实在不行请联系FAE,我这边没有物料无法测试
                                  wxgd2017 LV 5 最后由 编辑
                                  破案了,根文件系统要求squashfs,默认配置是ext4格式文件系统,make menuconfig改成squashfs,同时禁用ext4,就可以了
                                  Z 2 条回复 最后回复 回复 引用 分享 2
                                    zhangheyang LV 3 @wxgd2017 最后由 编辑
                                    @wxgd2017
                                    哥哥能详细点说一下吗?
                                    env中何配置的也上传一下。
                                      wxgd2017 LV 5 @zhangheyang 最后由 编辑
                                      @zhangheyang
                                      initcall_debug=0
                                      mtd_name=sys
                                      rootfstype=squashfs
                                      boot_partition=boot
                                      init=/sbin/init
                                      loglevel=8
                                      cma=0M
                                      mac=
                                      wifi_mac=
                                      bt_mac=
                                      specialstr=
                                      dsp0_partition=dsp0
                                      bootdelay=2
                                      #default nand boot
                                        zhangheyang LV 3 最后由 编辑
                                        还改了哪些配置呢?对着TINA手册上的哪些不行。
                                        要取消UBI吗?有些选项与手册上对不上。
                                          柚木 鉉 LV 9 @zhangheyang 最后由 编辑
                                          @zhangheyang 把文件系统改成squashfs就行了,我都忘了这事
                                            zhangheyang LV 3 @YuzukiTsuru 最后由 编辑
                                            好像不是,我不记得改了哪些,原来也到了与楼主一样的哪一步。
                                            后来又不记得改了哪些,回不去了。
                                            重新下载,只改文件系统,不行,烧不进去的。
                                              @wxgd2017
                                              能否直接上传一个固件,我先试一下。
                                                @zhangheyang 串口号和pin脚说下
                                                  @wxgd2017
                                                  是芒果的MQ- Dual
                                                  串口是PE2,PE3
                                                  TKS
                                                    @zhangheyang tina_t113-mq_uart0.img
                                                    uart0 PE2 PE3
                                                      @wxgd2017
                                                      用哥柯的env配置报Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
                                                         2.254331] /dev/root: Can't open blockdev
                                                      [    2.259034] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
                                                      [    2.267980] Please append a correct "root=" boot option; here are the available partitions:
                                                      [    2.277364] 1f00          131072 mtdblock0
                                                      [    2.277367]  (driver?)
                                                      [    2.284704] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                                                      [    2.293968] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #7
                                                      [    2.300598] Hardware name: Generic DT based system
                                                      [    2.305986] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
                                                      [    2.314672] [<c010a870>] (show_stack) from [<c0739040>] (dump_stack+0x7c/0x98)
                                                      [    2.322772] [<c0739040>] (dump_stack) from [<c011956c>] (panic+0x104/0x3d8)
                                                      [    2.330580] [<c011956c>] (panic) from [<c0b01270>] (mount_block_root+0x254/0x2fc)
                                                      [    2.338970] [<c0b01270>] (mount_block_root) from [<c0b014d0>] (prepare_namespace+0x138/0x178)
                                                      [    2.348528] [<c0b014d0>] (prepare_namespace) from [<c074d540>] (kernel_init+0x8/0x10c)
                                                      [    2.357405] [<c074d540>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
                                                      [    2.365885] Exception stack(0xc7825fb0 to 0xc7825ff8)
                                                      [    2.371545] 5fa0:                                     00000000 00000000 00000000 00000000
                                                      [    2.380711] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                                                      [    2.389876] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
                                                      [    2.397296] CPU0: stopping
                                                      [    2.400330] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #7
                                                      [    2.406960] Hardware name: Generic DT based system
                                                      [    2.412334] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
                                                      [    2.421015] [<c010a870>] (show_stack) from [<c0739040>] (dump_stack+0x7c/0x98)
                                                      [    2.429112] [<c0739040>] (dump_stack) from [<c010c648>] (handle_IPI+0xcc/0x168)
                                                      [    2.437307] [<c010c648>] (handle_IPI) from [<c02faefc>] (gic_handle_irq+0x70/0x78)
                                                      [    2.445793] [<c02faefc>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
                                                      [    2.454176] Exception stack(0xc0c01f40 to 0xc0c01f88)
                                                      [    2.459838] 1f40: 00000eb8 c7ebd4f4 00000000 c0114b40 00000001 c0c00000 c0c04e28 c0c04e64
                                                      [    2.469005] 1f60: c0c58000 c7ffc580 c0b2d0c0 00000000 c0c627d0 c0c01f90 c0107f94 c0107f84
                                                      [    2.478168] 1f80: 60000013 ffffffff
                                                      [    2.482078] [<c01021cc>] (__irq_svc) from [<c0107f84>] (arch_cpu_idle+0x1c/0x38)
                                                      [    2.490371] [<c0107f84>] (arch_cpu_idle) from [<c013de94>] (do_idle+0xd0/0x120)
                                                      [    2.498565] [<c013de94>] (do_idle) from [<c013e180>] (cpu_startup_entry+0x18/0x20)
                                                      [    2.507051] [<c013e180>] (cpu_startup_entry) from [<c0b00c64>] (start_kernel+0x348/0x3d8)
                                                      [    2.516218] [<c0b00c64>] (start_kernel) from [<00000000>] (0x0)
                                                      [    2.522863] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                                                      直接用哥哥固件,一直卡在Trying to connect to SWUpdate...
                                                      这可能是另一个问题。
                                                      [    6.595399] RTW: rtl8723ds v5.10.1-33-g2b795d825.20210322_beta
                                                      [    6.608510] read descriptors
                                                      [    6.610150] RTW: build time: Apr 18 2022 15:04:14
                                                      [    6.611772] read strings
                                                      [    6.626566] RTW: rtl8723ds BT-Coex version = COEX20200103-3535
                                                      [    6.651471] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                                                      [    6.785367] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                                                      [    6.792178] RTW: ----- platform_wifi_power_on sdc_id: 1
                                                      [    6.798153] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                      [    6.809293] RTW: rtw_inetaddr_notifier_register
                                                      [    6.815290] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                                      [    6.822907] RTW: module init ret=0
                                                      [    6.840863] xt_time: kernel timezone is -0000
                                                      [    6.845755] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                      kmodloader done
                                                      [    6.885300] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                      [    6.913103] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                      [    6.927418] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
                                                      [    6.959002] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                                      [    6.971833] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                                      [    6.983700] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                                                      [    6.997286] mmc0: new high speed SDIO card at address 0001
                                                        @zhangheyang
                                                        sw可能和wifi模块有关,我的不是麻雀的8189
                                                          @wxgd2017
                                                          仅改文件系统可能不行。。。
                                                          target\allwinner
                                                          device\config
                                                          能否压缩分享一下。。。
                                                            @zhangheyang
                                                            所有打印信息发来看看
                                                              @wxgd2017
                                                              [04.332]Starting kernel ...
                                                              [    0.000000] Linux version 5.4.61 (easyboard@V3S) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #56 SMP PREEMPT Wed Apr 20 14:13:16 UTC 2022
                                                              [    0.000000] cma: Reserved 16 MiB at 0x47000000
                                                              [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/sbin/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:UDISK@ubi0_6: cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05(04/02/2022-06:28:13) mbr_offset=1032192 disp_reserve=1536000,0x46ae8000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
                                                              [    0.000000] Memory: 97764K/130048K available (7168K kernel code, 347K rwdata, 1876K rodata, 1024K init, 174K bss, 15900K reserved, 16384K cma-reserved)
                                                              [    0.014192] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                                                              [    0.023963] Console: colour dummy device 80x30
                                                              [    0.028452] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                                                              [    0.038825] pid_max: default: 32768 minimum: 301
                                                              [    0.050903] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                                              [    0.059280] CPU: Testing write buffer coherency: ok
                                                              [    0.064538] /cpus/cpu@0 missing clock-frequency property
                                                              [    0.069868] /cpus/cpu@1 missing clock-frequency property
                                                              [    0.075214] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                                              [    0.081472] Setting up static identity map for 0x40100000 - 0x40100060
                                                              [    0.088165] rcu: Hierarchical SRCU implementation.
                                                              [    0.093440] smp: Bringing up secondary CPUs ...
                                                              [    0.099214] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                                              [    0.099372] smp: Brought up 1 node, 2 CPUs
                                                              [    0.109184] SMP: Total of 2 processors activated (96.00 BogoMIPS).
                                                              [    0.115381] CPU: All CPU(s) started in SVC mode.
                                                              [    0.120545] devtmpfs: initialized
                                                              [    0.136651] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                                                              [    0.144844] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                                              [    0.154717] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
                                                              [    0.162305] pinctrl core: initialized pinctrl subsystem
                                                              [    0.168973] NET: Registered protocol family 16
                                                              [    0.175231] DMA: preallocated 256 KiB pool for atomic coherent allocations
                                                              [    0.223763] rtc_ccu: sunxi ccu init OK
                                                              [    0.229765] ccu: sunxi ccu init OK
                                                              [    0.233730] r_ccu: sunxi ccu init OK
                                                              [    0.292935] iommu: Default domain type: Translated
                                                              [    0.298754] sunxi iommu: irq = 24
                                                              [    0.303268] SCSI subsystem initialized
                                                              [    0.307373] usbcore: registered new interface driver usbfs
                                                              [    0.313639] usbcore: registered new interface driver hub
                                                              [    0.319109] usbcore: registered new device driver usb
                                                              [    0.324356] mc: Linux media interface: v0.10
                                                              [    0.328733] videodev: Linux video capture interface: v2.00
                                                              [    0.335943] sunxi-msgbox-amp 3003000.msgbox: invalid resource
                                                              [    0.342826] Advanced Linux Sound Architecture Driver Initialized.
                                                              [    0.349736] Bluetooth: Core ver 2.22
                                                              [    0.353386] NET: Registered protocol family 31
                                                              [    0.357826] Bluetooth: HCI device and connection manager initialized
                                                              [    0.364459] Bluetooth: HCI socket layer initialized
                                                              [    0.369350] Bluetooth: L2CAP socket layer initialized
                                                              [    0.374537] Bluetooth: SCO socket layer initialized
                                                              [    0.379776] pwm module init!
                                                              [    0.384087] ths test int keyboard for ONE_CHANNEL
                                                              [    0.389143] input: sunxi-keyboard as /devices/virtual/input/input0
                                                              [    0.396865] clocksource: Switched to clocksource arch_sys_counter
                                                              [    0.412595] sun8iw20-pinctrl pio: initialized sunXi PIO driver
                                                              [    0.432830] thermal_sys: Registered thermal governor 'user_space'
                                                              [    0.432837] thermal_sys: Registered thermal governor 'power_allocator'
                                                              [    0.439567] NET: Registered protocol family 2
                                                              [    0.451074] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                                                              [    0.459476] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                                                              [    0.467176] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                                                              [    0.474237] TCP: Hash tables configured (established 1024 bind 1024)
                                                              [    0.480709] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                                                              [    0.487289] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                                                              [    0.494444] NET: Registered protocol family 1
                                                              [    0.500245] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
                                                              [    0.508554] spi spi0: spi0 supply spi not found, using dummy regulator
                                                              [    0.515295] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
                                                              [    0.521510] sunxi_spi_resource_get()2189 - Failed to get sample mode
                                                              [    0.527911] sunxi_spi_resource_get()2194 - Failed to get sample delay
                                                              [    0.534362] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
                                                              [    0.542780] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
                                                              [    0.549293] spi spi0: chipselect 0 already in use
                                                              [    0.554004] spi_master spi0: spi_device register error /soc@3000000/spi@4025000/spi_board@0
                                                              [    0.562399] spi_master spi0: Failed to create SPI device for /soc@3000000/spi@4025000/spi_board@0
                                                              [    0.571374] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8827000, irq 41
                                                              [    0.581448] Initialise system trusted keyrings
                                                              [    0.586120] workingset: timestamp_bits=30 max_order=15 bucket_order=0
                                                              [    0.601130] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                                              [    0.636507] Key type asymmetric registered
                                                              [    0.640662] Asymmetric key parser 'x509' registered
                                                              [    0.645568] io scheduler mq-deadline registered
                                                              [    0.650260] io scheduler kyber registered
                                                              [    0.654396] atomic64_test: passed
                                                              [    0.659511] [DISP]disp_module_init
                                                              [    0.663557] disp 5000000.disp: Adding to iommu group 0
                                                              [    0.669553] [DISP] disp_init,line:2329:
                                                              [    0.669560] smooth display screen:0 type:1 mode:4
                                                              [    0.694681] display_fb_request,fb_id:0
                                                              [    0.703826] Freeing logo buffer memory: 1500K
                                                              [    0.708816] disp_al_manager_apply ouput_type:1
                                                              [    0.713547] [DISP] lcd_clk_config,line:731:
                                                              [    0.713558] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
                                                              [    0.713558]      clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
                                                              [    0.717475] [DISP]disp_module_init finish
                                                              [    0.718182] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
                                                              [    0.735335] sunxi_sid_init()551 - insmod ok
                                                              [    0.750523] pwm-regulator: supplied by regulator-dummy
                                                              [    0.758091] uart uart0: get regulator failed
                                                              [    0.762379] uart uart0: uart0 supply uart not found, using dummy regulator
                                                              [    0.769638] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
                                                              [    0.777549] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
                                                              [    0.785531] printk: console [ttyS0] enabled
                                                              [    0.794405] printk: bootconsole [earlycon0] disabled
                                                              [    0.805707] uart uart2: get regulator failed
                                                              [    0.810575] uart uart2: uart2 supply uart not found, using dummy regulator
                                                              [    0.818644] uart2: ttyS2 at MMIO 0x2500800 (irq = 35, base_baud = 1500000) is a SUNXI
                                                              [    0.828098] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
                                                              [    0.837149] uart uart3: get regulator failed
                                                              [    0.841951] uart uart3: uart3 supply uart not found, using dummy regulator
                                                              [    0.849950] uart3: ttyS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
                                                              [    0.859820] misc dump reg init
                                                              [    0.865042] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
                                                              [    0.872299] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
                                                              [    0.879631] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
                                                              [    0.887029] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
                                                              [    0.893542] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
                                                              [    0.900462] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
                                                              [    0.908167] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
                                                              [    0.915975] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
                                                              [    0.924067] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
                                                              [    0.931752] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
                                                              [    0.938505] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
                                                              [    0.946017] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
                                                              [    0.955303] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
                                                              [    0.962560] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
                                                              [    0.970475] sunxi-spinand-phy: not detect any munufacture from id table
                                                              [    0.977888] sunxi-spinand-phy: get spi-nand Model from fdt fail
                                                              [    0.984486] sunxi-spinand-phy: get phy info from fdt fail
                                                              [    0.990567] sunxi-spinand-phy: not detect munufacture from fdt
                                                              [    0.997274] sunxi-spinand-phy: detect munufacture from id table: Mxic
                                                              [    1.004467] sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
                                                              [    1.011468] sunxi-spinand-phy: ========== arch info ==========
                                                              [    1.017987] sunxi-spinand-phy: Model:               MX35LF1GE4AB
                                                              [    1.024681] sunxi-spinand-phy: Munufacture:         Mxic
                                                              [    1.030615] sunxi-spinand-phy: DieCntPerChip:       1
                                                              [    1.036242] sunxi-spinand-phy: BlkCntPerDie:        1024
                                                              [    1.042176] sunxi-spinand-phy: PageCntPerBlk:       64
                                                              [    1.047910] sunxi-spinand-phy: SectCntPerPage:      4
                                                              [    1.053544] sunxi-spinand-phy: OobSizePerPage:      64
                                                              [    1.059278] sunxi-spinand-phy: BadBlockFlag:        0x1
                                                              [    1.065099] sunxi-spinand-phy: OperationOpt:        0x7
                                                              [    1.070942] sunxi-spinand-phy: MaxEraseTimes:       65000
                                                              [    1.076968] sunxi-spinand-phy: EccFlag:             0x2
                                                              [    1.082796] sunxi-spinand-phy: EccType:             4
                                                              [    1.088433] sunxi-spinand-phy: EccProtectedType:    3
                                                              [    1.094067] sunxi-spinand-phy: ========================================
                                                              [    1.101446] sunxi-spinand-phy:
                                                              [    1.104942] sunxi-spinand-phy: ========== physical info ==========
                                                              [    1.111845] sunxi-spinand-phy: TotalSize:    128 M
                                                              [    1.117196] sunxi-spinand-phy: SectorSize:   512 B
                                                              [    1.122540] sunxi-spinand-phy: PageSize:     2 K
                                                              [    1.127701] sunxi-spinand-phy: BlockSize:    128 K
                                                              [    1.133067] sunxi-spinand-phy: OOBSize:      64 B
                                                              [    1.138320] sunxi-spinand-phy: ========================================
                                                              [    1.145689] sunxi-spinand-phy:
                                                              [    1.149202] sunxi-spinand-phy: ========== logical info ==========
                                                              [    1.155991] sunxi-spinand-phy: TotalSize:    128 M
                                                              [    1.161345] sunxi-spinand-phy: SectorSize:   512 B
                                                              [    1.166681] sunxi-spinand-phy: PageSize:     4 K
                                                              [    1.171840] sunxi-spinand-phy: BlockSize:    256 K
                                                              [    1.177195] sunxi-spinand-phy: OOBSize:      128 B
                                                              [    1.182531] sunxi-spinand-phy: ========================================
                                                              [    1.190066] sunxi-spinand-phy: block lock register: 0x00
                                                              [    1.196111] sunxi-spinand-phy: feature register: 0x11
                                                              [    1.201784] sunxi-spinand-phy: sunxi physic nand init end
                                                              [    1.208295] Creating 4 MTD partitions on "sunxi_mtd_nand":
                                                              [    1.214438] 0x000000000000-0x000000100000 : "boot0"
                                                              [    1.228007] 0x000000100000-0x000000400000 : "uboot"
                                                              [    1.236121] random: fast init done
                                                              [    1.242482] sunxi-spinand-phy: phy blk 20 is bad
                                                              [    1.257988] 0x000000400000-0x000000500000 : "secure_storage"
                                                              [    1.277995] 0x000000500000-0x000008000000 : "sys"
                                                              [    1.394674] sunxi-spinand-phy: phy blk 327 is bad
                                                              [    1.626848] random: crng init done
                                                              [    1.670583] libphy: Fixed MDIO Bus: probed
                                                              [    1.675948] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                                                              [    1.683280] sunxi-ehci: EHCI SUNXI driver
                                                              [    1.688224] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                                                              [    1.695141] sunxi-ohci: OHCI SUNXI driver
                                                              [    1.700306] usbcore: registered new interface driver uas
                                                              [    1.706314] usbcore: registered new interface driver usb-storage
                                                              [    1.713136] usbcore: registered new interface driver ums-alauda
                                                              [    1.719830] usbcore: registered new interface driver ums-cypress
                                                              [    1.726618] usbcore: registered new interface driver ums-datafab
                                                              [    1.733394] usbcore: registered new interface driver ums_eneub6250
                                                              [    1.740378] usbcore: registered new interface driver ums-freecom
                                                              [    1.747151] usbcore: registered new interface driver ums-isd200
                                                              [    1.753821] usbcore: registered new interface driver ums-jumpshot
                                                              [    1.760690] usbcore: registered new interface driver ums-karma
                                                              [    1.767283] usbcore: registered new interface driver ums-onetouch
                                                              [    1.774145] usbcore: registered new interface driver ums-realtek
                                                              [    1.780944] usbcore: registered new interface driver ums-sddr09
                                                              [    1.787624] usbcore: registered new interface driver ums-sddr55
                                                              [    1.794306] usbcore: registered new interface driver ums-usbat
                                                              [    1.800892] usbcore: registered new interface driver idmouse
                                                              [    1.808067] sunxi_gpadc_init,2113, success
                                                              [    1.812961] sunxi_gpadc_setup: get channel scan data failed
                                                              [    1.819529] input: sunxi-gpadc0 as /devices/virtual/input/input1
                                                              [    1.828691] sunxi-rtc 7090000.rtc: registered as rtc0
                                                              [    1.834486] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:36:05 UTC (2165)
                                                              [    1.843677] sunxi-rtc 7090000.rtc: sunxi rtc probed
                                                              [    1.849611] i2c /dev entries driver
                                                              [    1.853631] IR NEC protocol handler initialized
                                                              [    1.859163] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
                                                              [    1.868145] sunxi_ir_startup: get ir protocol failed
                                                              [    1.868164] (NULL device *): deviceless supply  not found, using dummy regulator
                                                              [    1.882079] Registered IR keymap rc_map_sunxi
                                                              [    1.887133] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
                                                              [    1.895814] rc rc0: lirc_dev: driver sunxi-rc-recv registered at minor = 0, raw IR receiver, no transmitter
                                                              [    1.906955] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
                                                              [    1.917309] sunxi cedar version 1.1
                                                              [    1.921397] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
                                                              [    1.927715] VE: sunxi_cedar_probe power-domain init!!!
                                                              [    1.933450] VE: install start!!!
                                                              [    1.933450]
                                                              [    1.939042] VE: cedar-ve the get irq is 42
                                                              [    1.939042]
                                                              [    1.945475] VE: ve_debug_proc_info:ba1192bf, data:ff169ed6, lock:ab012c41
                                                              [    1.945475]
                                                              [    1.954738] VE: install end!!!
                                                              [    1.954738]
                                                              [    1.959803] VE: sunxi_cedar_probe
                                                              [    1.965091] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                                                              [    1.974260] Bluetooth: HCI UART driver ver 2.3
                                                              [    1.979297] Bluetooth: HCI UART protocol H4 registered
                                                              [    1.985025] Bluetooth: HCI UART protocol BCSP registered
                                                              [    1.990960] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
                                                              [    1.998187] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
                                                              [    2.004537] Bluetooth: get gpio bt_hostwake failed
                                                              [    2.009938] sunxi-btlpm: probe of soc@3000000:btlpm@0 failed with error -22
                                                              [    2.019802] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-05-12 11:02)
                                                              [    2.029733] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
                                                              [    2.035929] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
                                                              [    2.042256] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
                                                              [    2.048684] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
                                                              [    2.055090] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
                                                              [    2.061610] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
                                                              [    2.068124] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
                                                              [    2.074633] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
                                                              [    2.081174] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
                                                              [    2.090742] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              [    2.101893] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                                              [    2.122011] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              [    2.146208] sunxi-mmc 4021000.sdmmc: detmode:manually by software
                                                              [    2.153868] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
                                                              [    2.161542] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
                                                              [    2.161691] usbcore: registered new interface driver usbhid
                                                              [    2.168439] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              [    2.174666] usbhid: USB HID core driver
                                                              [    2.189380] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              [    2.190494] exFAT: Version 1.3.0
                                                              [    2.204209] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
                                                              [    2.207905] usbcore: registered new interface driver snd-usb-audio
                                                              [    2.213403] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
                                                              [    2.221100] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
                                                              [    2.221100]
                                                              [    2.227199] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
                                                              [    2.243035] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
                                                              [    2.250491] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
                                                              [    2.261040] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
                                                              [    2.267333] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                                                              [    2.276468] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
                                                              [    2.296269] [SNDCODEC][sunxi_card_init][583]:card init finished
                                                              [    2.303427] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
                                                              [    2.314503] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input3
                                                              [    2.326584] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
                                                              [    2.334891] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
                                                              [    2.343418] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
                                                              [    2.346887] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
                                                              [    2.359691] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.1.257: id:sunxi,dsp-msgbox new channel: 0x1 -> 0x101!
                                                              [    2.370871] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.1.257: rpmsg hifi[0] client driver is probed
                                                              [    2.382857] NET: Registered protocol family 10
                                                              [    2.388986] Segment Routing with IPv6
                                                              [    2.393192] NET: Registered protocol family 17
                                                              [    2.398387] Bluetooth: RFCOMM TTY layer initialized
                                                              [    2.403836] Bluetooth: RFCOMM socket layer initialized
                                                              [    2.409673] Bluetooth: RFCOMM ver 1.11
                                                              [    2.413883] 8021q: 802.1Q VLAN Support v1.8
                                                              [    2.419417] Registering SWP/SWPB emulation handler
                                                              [    2.425143] Loading compiled-in X.509 certificates
                                                              [    2.430887] fs-verity: Initialized fs-verity
                                                              [    2.455603] twi twi3: twi3 supply twi not found, using dummy regulator
                                                              [    2.463877] sunxi_i2c_probe()2266 - [i2c3] probe success
                                                              [    2.508221] get ehci0-controller wakeup-source is fail.
                                                              [    2.514139] sunxi ehci0-controller don't init wakeup source
                                                              [    2.520469] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c775b0, 0x:c9437000, irq_no:3b
                                                              [    2.532406] [sunxi-ehci0]: Not init ehci0
                                                              [    2.537296] get ohci0-controller wakeup-source is fail.
                                                              [    2.543210] sunxi ohci0-controller don't init wakeup source
                                                              [    2.549460] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c77840
                                                              [    2.559052] [sunxi-ohci0]: Not init ohci0
                                                              [    2.563897] get ehci1-controller wakeup-source is fail.
                                                              [    2.569828] sunxi ehci1-controller don't init wakeup source
                                                              [    2.576047] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c77ad0, 0x:c9441000, irq_no:3d
                                                              [    2.588227] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
                                                              [    2.601592] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
                                                              [    2.608811] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
                                                              [    2.618689] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
                                                              [    2.646888] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
                                                              [    2.655537] hub 1-0:1.0: USB hub found
                                                              [    2.659771] hub 1-0:1.0: 1 port detected
                                                              [    2.665037] get ohci1-controller wakeup-source is fail.
                                                              [    2.670993] sunxi ohci1-controller don't init wakeup source
                                                              [    2.677211] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c77d60
                                                              [    2.687068] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
                                                              [    2.699317] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
                                                              [    2.706533] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
                                                              [    2.716389] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
                                                              [    2.791758] hub 2-0:1.0: USB hub found
                                                              [    2.795972] hub 2-0:1.0: 1 port detected
                                                              [    2.802328] ubi0: attaching mtd3
                                                              [    3.110128] ubi0: scanning is finished
                                                              [    3.124941] ubi0: attached mtd3 (name "sys", size 123 MiB)
                                                              [    3.131068] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                                                              [    3.138722] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                                                              [    3.146271] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                                                              [    3.154020] ubi0: good PEBs: 491, bad PEBs: 1, corrupted PEBs: 0
                                                              [    3.160701] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
                                                              [    3.168734] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                                                              [    3.178028] ubi0: available PEBs: 0, total reserved PEBs: 491, PEBs reserved for bad PEB handling: 19
                                                              [    3.188297] ubi0: background thread "ubi_bgt0d" started, PID 1090
                                                              [    3.196335] block ubiblock0_5: created from ubi0:5(rootfs)
                                                              [    3.203022] sun8iw20-pinctrl pio: pin PB6 already requested by 2502c00.twi; cannot claim for pio:38
                                                              [    3.213122] sun8iw20-pinctrl pio: pin-38 (pio:38) status -22
                                                              [    3.219428] ERR: id gpio_request failed
                                                              [    3.225974] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                                              [    3.237180] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                                              [    3.244464] clk: Not disabling unused clocks
                                                              [    3.249354] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                                                              [    3.256903] ALSA device list:
                                                              [    3.258991] cfg80211: failed to load regulatory.db
                                                              [    3.262216]   #0: audiocodec
                                                              [    3.270779] alloc_fd: slot 0 not NULL!
                                                              [    3.278794] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
                                                              [    3.288980] devtmpfs: mounted
                                                              [    3.293971] Freeing unused kernel memory: 1024K
                                                              [    3.357022] Run /sbin/init as init process
                                                              [    3.641317] init: Console is alive
                                                              [    3.645360] init: - watchdog -
                                                              [    3.648929] init: - preinit -
                                                              formating /dev/by-name/UDISK to ubifs
                                                              [    4.383840] mount_root: mounting /dev/root
                                                              [    4.390819] mount_root: loading kmods from internal overlay
                                                              [    4.549523] block: attempting to load /etc/config/fstab
                                                              [    4.576707] UBIFS (ubi0:6): Mounting in unauthenticated mode
                                                              [    4.583179] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 1138
                                                              [    4.757621] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "UDISK"
                                                              [    4.765762] UBIFS (ubi0:6): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
                                                              [    4.776833] UBIFS (ubi0:6): FS size: 5677056 bytes (5 MiB, 22 LEBs), journal size 2322433 bytes (2 MiB, 8 LEBs)
                                                              [    4.788062] UBIFS (ubi0:6): reserved for root: 0 bytes (0 KiB)
                                                              [    4.794547] UBIFS (ubi0:6): media format: w4/r0 (latest is w5/r0), UUID 6321B968-F554-4428-85F7-D97329C4D0DF, small LPT model
                                                              [    4.814242] mount_root: switched to extroot
                                                              [    4.824725] procd: - early -
                                                              [    4.828126] procd: - watchdog -
                                                              [    4.994428] procd: - watchdog -
                                                              [    4.998260] procd: - ubus -
                                                              [    5.001916] procd (1): /proc/1280/oom_adj is deprecated, please use /proc/1280/oom_score_adj instead.
                                                              [    5.157847] procd: - init -
                                                              Please press Enter to activate this console.
                                                              [    5.434589] fuse: init (API version 7.31)
                                                              [    6.215511] file system registered
                                                              [    6.306083] configfs-gadget 4100000.udc-controller: failed to start g1: -19
                                                              [    6.583572] read descriptors
                                                              [    6.586898] read strings
                                                              [    6.618361] RTW: module init start
                                                              [    6.622153] RTW: rtl8723ds v5.10.1-33-g2b795d825.20210322_beta
                                                              [    6.628883] RTW: build time: Apr 18 2022 15:04:14
                                                              [    6.634112] RTW: rtl8723ds BT-Coex version = COEX20200103-3535
                                                              [    6.650798] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                                                              [    6.807915] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                                                              [    6.814118] RTW: ----- platform_wifi_power_on sdc_id: 1
                                                              [    6.826940] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              [    6.838062] RTW: rtw_inetaddr_notifier_register
                                                              [    6.843448] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                                                              [    6.851098] RTW: module init ret=0
                                                              [    6.868215] xt_time: kernel timezone is -0000
                                                              [    6.873112] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              kmodloader done
                                                              [    6.911722] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              [    6.935321] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                                                              [    6.963473] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
                                                              [    6.996973] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                                              [    7.027059] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                                                              [    7.047160] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                                                              [    7.078015] mmc0: new high speed SDIO card at address 0001
        你发的是我提供的固件吧,你提供下你的固件打印信息
        用本贴另一朋友提供的配置OK了。
        柚木 鉉 LV 9 最后由 编辑
        https://github.com/Tina-Linux/tina-t113-mangopi-sbc
        覆盖下就行了
