【免签NDA直接下】D1 Tina SDK v1.0正式释放!深入了解RISC-V的每一个DNA!
D1 Tina SDK v1.0正式发布!
年装机量超千万的嵌入式系统,基于Linux 5.4内核,专门为智能硬件产品深度定制,全志深耕6年,被国内外多家IoT巨头选用,现在全部释放了!不用签NDA,注册即下,快过玩页游!
源码下载方法见:
https://d1.docs.allwinnertech.com/study/study_2getsdk/下源码请到:
https://open.allwinnertech.com/#/login?cas=true
datasheet & user manual is ready !
更多文档,正在路上!Kirin@RISCV:~/workspace/tina_v1.0$ source build/envsetup.sh Setup env done! Please run lunch next. Kirin@RISCV:~/workspace/tina_v1.0$ lunch You're building on Linux Lunch menu... pick a combo: 1. d1_nezha_min-tina 2. d1_nezha-tina Which would you like?: 2 ============================================ TINA_BUILD_TOP=/home/kirin/workspace/tina_v1.0 TINA_TARGET_ARCH=riscv TARGET_PRODUCT=d1_nezha TARGET_PLATFORM=d1 TARGET_BOARD=d1-nezha TARGET_PLAN=nezha TARGET_BUILD_VARIANT=tina TARGET_BUILD_TYPE=release TARGET_KERNEL_VERSION=5.4 TARGET_UBOOT=u-boot-2018 TARGET_CHIP=sun20iw1p1 ============================================ Kirin@RISCV:~/workspace/tina_v1.0$ make -j64 //编译
(注意lunch的时候选2-d1_nezha-tina是完整系统,1那个带mini的意思是最小系统,很多Tina的功能都没有)
按照提示在运行repo init的时候报如下错误,请问如何解决呀?
@yqszxx 是不是忘了添加公钥?
@kunyao 不是的,repo启动文件是可以正常clone的
@kunyao 我也遇到了同样的问题.公钥是添加了的,如果公钥没添加的话,连repo这个工具都下载不了.
mod@mod tina-d1-open $ repo init -u ssh://LogPI@sdk.allwinnertech.com/git_repo/D1_Tina_Open/manifest.git -b master -m tina-d1-open.xml Get ssh://LogPI@sdk.allwinnertech.com/git_repo/repo.git remote: Counting objects: 4032, done. remote: Compressing objects: 100% (1262/1262), done. remote: Total 4032 (delta 2733), reused 3932 (delta 2709) 接收对象中: 100% (4032/4032), 978.00 KiB | 5.15 MiB/s, 完成. 处理 delta 中: 100% (2733/2733), 完成. 来自 ssh://sdk.allwinnertech.com/git_repo/repo * [新分支] master -> origin/master * [新标签] v1.0 -> v1.0 * [新标签] v1.0.1 -> v1.0.1 * [新标签] v1.0.2 -> v1.0.2 * [新标签] v1.0.3 -> v1.0.3 * [新标签] v1.0.4 -> v1.0.4 * [新标签] v1.0.5 -> v1.0.5 * [新标签] v1.0.6 -> v1.0.6 * [新标签] v1.0.7 -> v1.0.7 * [新标签] v1.0.8 -> v1.0.8 * [新标签] v1.0.9 -> v1.0.9 * [新标签] v1.1 -> v1.1 * [新标签] v1.10.0 -> v1.10.0 * [新标签] v1.10.1 -> v1.10.1 * [新标签] v1.10.2 -> v1.10.2 * [新标签] v1.10.3 -> v1.10.3 * [新标签] v1.10.4 -> v1.10.4 * [新标签] v1.11.0 -> v1.11.0 * [新标签] v1.11.1 -> v1.11.1 * [新标签] v1.12.0 -> v1.12.0 * [新标签] v1.12.1 -> v1.12.1 * [新标签] v1.12.10 -> v1.12.10 * [新标签] v1.12.11 -> v1.12.11 * [新标签] v1.12.12 -> v1.12.12 * [新标签] v1.12.13 -> v1.12.13 * [新标签] v1.12.14 -> v1.12.14 * [新标签] v1.12.15 -> v1.12.15 * [新标签] v1.12.16 -> v1.12.16 * [新标签] v1.12.17 -> v1.12.17 * [新标签] v1.12.18 -> v1.12.18 * [新标签] v1.12.19 -> v1.12.19 * [新标签] v1.12.2 -> v1.12.2 * [新标签] v1.12.20 -> v1.12.20 * [新标签] v1.12.21 -> v1.12.21 * [新标签] v1.12.22 -> v1.12.22 * [新标签] v1.12.23 -> v1.12.23 * [新标签] v1.12.24 -> v1.12.24 * [新标签] v1.12.25 -> v1.12.25 * [新标签] v1.12.26 -> v1.12.26 * [新标签] v1.12.27 -> v1.12.27 * [新标签] v1.12.28 -> v1.12.28 * [新标签] v1.12.29 -> v1.12.29 * [新标签] v1.12.3 -> v1.12.3 * [新标签] v1.12.3.1 -> v1.12.3.1 * [新标签] v1.12.30 -> v1.12.30 * [新标签] v1.12.30.1 -> v1.12.30.1 * [新标签] v1.12.31 -> v1.12.31 * [新标签] v1.12.32 -> v1.12.32 * [新标签] v1.12.33 -> v1.12.33 * [新标签] v1.12.34 -> v1.12.34 * [新标签] v1.12.35 -> v1.12.35 * [新标签] v1.12.36 -> v1.12.36 * [新标签] v1.12.37 -> v1.12.37 * [新标签] v1.12.4 -> v1.12.4 * [新标签] v1.12.5 -> v1.12.5 * [新标签] v1.12.6 -> v1.12.6 * [新标签] v1.12.7 -> v1.12.7 * [新标签] v1.12.8 -> v1.12.8 * [新标签] v1.12.9 -> v1.12.9 * [新标签] v1.2 -> v1.2 * [新标签] v1.3 -> v1.3 * [新标签] v1.3.1 -> v1.3.1 * [新标签] v1.3.2 -> v1.3.2 * [新标签] v1.4 -> v1.4 * [新标签] v1.4.1 -> v1.4.1 * [新标签] v1.4.2 -> v1.4.2 * [新标签] v1.4.3 -> v1.4.3 * [新标签] v1.4.4 -> v1.4.4 * [新标签] v1.5 -> v1.5 * [新标签] v1.5.1 -> v1.5.1 * [新标签] v1.6 -> v1.6 * [新标签] v1.6.1 -> v1.6.1 * [新标签] v1.6.10 -> v1.6.10 * [新标签] v1.6.10.1 -> v1.6.10.1 * [新标签] v1.6.10.2 -> v1.6.10.2 * [新标签] v1.6.2 -> v1.6.2 * [新标签] v1.6.3 -> v1.6.3 * [新标签] v1.6.4 -> v1.6.4 * [新标签] v1.6.5 -> v1.6.5 * [新标签] v1.6.6 -> v1.6.6 * [新标签] v1.6.7 -> v1.6.7 * [新标签] v1.6.7.1 -> v1.6.7.1 * [新标签] v1.6.7.2 -> v1.6.7.2 * [新标签] v1.6.7.3 -> v1.6.7.3 * [新标签] v1.6.7.4 -> v1.6.7.4 * [新标签] v1.6.7.5 -> v1.6.7.5 * [新标签] v1.6.8 -> v1.6.8 * [新标签] v1.6.8.1 -> v1.6.8.1 * [新标签] v1.6.8.10 -> v1.6.8.10 * [新标签] v1.6.8.11 -> v1.6.8.11 * [新标签] v1.6.8.2 -> v1.6.8.2 * [新标签] v1.6.8.3 -> v1.6.8.3 * [新标签] v1.6.8.4 -> v1.6.8.4 * [新标签] v1.6.8.5 -> v1.6.8.5 * [新标签] v1.6.8.6 -> v1.6.8.6 * [新标签] v1.6.8.7 -> v1.6.8.7 * [新标签] v1.6.8.8 -> v1.6.8.8 * [新标签] v1.6.8.9 -> v1.6.8.9 * [新标签] v1.6.9 -> v1.6.9 * [新标签] v1.6.9.1 -> v1.6.9.1 * [新标签] v1.6.9.2 -> v1.6.9.2 * [新标签] v1.6.9.3 -> v1.6.9.3 * [新标签] v1.6.9.4 -> v1.6.9.4 * [新标签] v1.6.9.5 -> v1.6.9.5 * [新标签] v1.6.9.6 -> v1.6.9.6 * [新标签] v1.6.9.7 -> v1.6.9.7 * [新标签] v1.6.9.8 -> v1.6.9.8 * [新标签] v1.7 -> v1.7 * [新标签] v1.7.1 -> v1.7.1 * [新标签] v1.7.2 -> v1.7.2 * [新标签] v1.7.3 -> v1.7.3 * [新标签] v1.7.3.1 -> v1.7.3.1 * [新标签] v1.7.4 -> v1.7.4 * [新标签] v1.7.4.1 -> v1.7.4.1 * [新标签] v1.7.4.2 -> v1.7.4.2 * [新标签] v1.7.4.3 -> v1.7.4.3 * [新标签] v1.7.5 -> v1.7.5 * [新标签] v1.7.6 -> v1.7.6 * [新标签] v1.7.6.1 -> v1.7.6.1 * [新标签] v1.7.7 -> v1.7.7 * [新标签] v1.7.7.1 -> v1.7.7.1 * [新标签] v1.7.7.2 -> v1.7.7.2 * [新标签] v1.7.7.3 -> v1.7.7.3 * [新标签] v1.7.7.4 -> v1.7.7.4 * [新标签] v1.7.7.5 -> v1.7.7.5 * [新标签] v1.7.7.6 -> v1.7.7.6 * [新标签] v1.7.8 -> v1.7.8 * [新标签] v1.7.8.1 -> v1.7.8.1 * [新标签] v1.7.8.2 -> v1.7.8.2 * [新标签] v1.8.0 -> v1.8.0 * [新标签] v1.8.1 -> v1.8.1 * [新标签] v1.8.2 -> v1.8.2 * [新标签] v1.9.0 -> v1.9.0 * [新标签] v1.9.1 -> v1.9.1 * [新标签] v1.9.2 -> v1.9.2 * [新标签] v1.9.3 -> v1.9.3 * [新标签] v1.9.4 -> v1.9.4 * [新标签] v1.9.5 -> v1.9.5 * [新标签] v1.9.6 -> v1.9.6 warning: 'ssh://LogPI@sdk.allwinnertech.com/git_repo/repo.git' does not look like a git-repo repository, is REPO_URL set correctly? Get ssh://LogPI@sdk.allwinnertech.com/git_repo/D1_Tina_Open/manifest.git fatal: '/git_repo/D1_Tina_Open/manifest.git' does not appear to be a git repository fatal: 无法读取远程仓库。 请确认您有正确的访问权限并且仓库存在。
@yqszxx 有开发者遇到同样的问题了,可能是部分服务器的问题,正在处理中
@mwang 打扰了,已经解决了
@mwang 在 【免签NDA直接下】D1 Tina SDK v1.0正式释放!深入了解RISC-V的每一个DNA! 中说:
@mwang 打扰了,已经解决了
请问怎么解决的呢,可以给后面的小伙伴参考参考呢。
您好,我想问一下,d1-h(1g)这个开发版,初始系统可以直接用吗,还是必须得编译源码,进行烧录呀
@chen_bopk 在 【免签NDA直接下】D1 Tina SDK v1.0正式释放!深入了解RISC-V的每一个DNA! 中说:
出厂的就能直接用
@kirin hello 使用repo 构建时发现有如下问题请问有什么建议?
- [new tag] v1.7.7.6 -> v1.7.7.6
- [new tag] v1.7.8 -> v1.7.8
- [new tag] v1.7.8.1 -> v1.7.8.1
- [new tag] v1.7.8.2 -> v1.7.8.2
- [new tag] v1.8.0 -> v1.8.0
- [new tag] v1.8.1 -> v1.8.1
- [new tag] v1.8.2 -> v1.8.2
- [new tag] v1.9.0 -> v1.9.0
- [new tag] v1.9.1 -> v1.9.1
- [new tag] v1.9.2 -> v1.9.2
- [new tag] v1.9.3 -> v1.9.3
- [new tag] v1.9.4 -> v1.9.4
- [new tag] v1.9.5 -> v1.9.5
- [new tag] v1.9.6 -> v1.9.6
warning: 'ssh://mumula@sdk.allwinnertech.com/git_repo/repo.git' does not look like a git-repo repository, is REPO_URL set correctly?
Get ssh://mumula@sdk.allwinnertech.com/git_repo/D1_Tina_Open/manifest.git
remote: Counting objects: 3, done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 3 (delta 0), reused 0 (delta 0)
From ssh://sdk.allwinnertech.com/git_repo/D1_Tina_Open/manifest - [new branch] master -> origin/master
fatal: manifest 'tina-d1-open.xml' not available
fatal: manifest tina-d1-open.xml not found
@mumula 使用tina-d1-h.xml下载新版本的
@yuzukitsuru 编译报错
flock: /mnt/nfs/tina-da-open/tmp/.root-copy.flock: Bad file descriptor
make[3]: *** [/mnt/nfs/tina-da-open/out/d1-h-nezha_min/staging_dir/target/rootfs/stamp/.libc_installed] Error 65
make[2]: *** [package/libs/toolchain/compile] Error 2
make[1]: *** [/mnt/nfs/tina-da-open/out/d1-h-nezha_min/staging_dir/target/stamp/.package_compile] Error 2
make: *** [world] Error 2 -
@mumula 不要在nfs里编译
@yuzukitsuru 好的
非常感谢另外我想知道全志D1哪吒板
mcycle的时钟评率是多少?
