    麻雀 MQ-Dual (双核A7版本内置128M运存) ,准备测试
    10
    23
    16913
    • mangogeek
      mangogeek LV 8 最后由 编辑
        坐 等 上 架 !
          DOT小文哥 LV 8 最后由 编辑
          坐 等 上 架 !
            zxyUser LV 4 最后由 编辑
            坐等Tina的SDK
            • mangogeek
              https://item.taobao.com/item.htm?id=534118595612 先卖为敬😊 当天发货
                whycan晕哥 LV 9 @mangogeek 最后由 编辑
                @mangogeek
                • mangogeek
                  T113_PG8_PG9_COM3_log.txt
                  默认SDK编译出来console-uart跑到了PG8,PG9上去,还没来得及改传到这里:
                  [19]HELLO! BOOT0 is starting!
                  [22]BOOT0 commit : 2c94b33
                  [25]set pll start
                  [31]periph0 has been enabled
                  [34]set pll end
                  [35][pmu]: bus read error
                  [38]board init ok
                  [39]enable_jtag
                  [41]ZQ value = 0x32***********
                  [44]get_pmu_exist() = -1
                  [47]ddr_efuse_type: 0xa
                  [50][AUTO DEBUG] single rank and full DQ!
                  [54]ddr_efuse_type: 0xa
                  [57][AUTO DEBUG] rank 0 row = 13
                  [60][AUTO DEBUG] rank 0 bank = 8
                  [64][AUTO DEBUG] rank 0 page size = 2 KB
                  [68]DRAM BOOT DRIVE INFO: V0.24
                  [71]DRAM CLK = 792 MHz
                  [73]DRAM Type = 3 (2:DDR2,3:DDR3)
                  [76]DRAMC read ODT  off.
                  [79]DRAM ODT value: 0x42.
                  [81]ddr_efuse_type: 0xa
                  [84]DRAM SIZE =128 M
                  [86]PLL_DDR_CTRL_REG:0xf8004100
                  [89]DRAM_CLK_REG:0xc0000000
                  [97]DRAM simple test OK.
                  [99]rtc standby flag is 0x0, super standby flag is 0x0
                  [105]dram size =128
                  [107]card no is 0
                  [109]sdcard 0 line count 4
                  [111][mmc]: mmc driver ver 2021-03-22 20:20
                  [121][mmc]: Wrong media type 0x0
                  [124][mmc]: ***Try SD card 0***
                  [133][mmc]: DS26/SDR12 4 bit
                  [136][mmc]: 25000000 Hz
                  [138][mmc]: 30474 MB
                  [140][mmc]: ***SD/MMC 0 init OK!!!***
                  [286]Loading boot-pkg Succeed(index=0).
                  [289]Entry_name        = u-boot
                  [296]Entry_name        = optee
                  [300]Entry_name        = dtb
                  [303]mmc not para
                  [305]Jump to second Boot.
                  M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:11                       UTC 2021 arm
                  U-Boot 2018.05-g5b4bafa (Oct 18 2021 - 01:53:36 +0000) Allwinner Technology
                  [00.361]CPU:   Allwinner Family
                  [00.364]Model: sun8iw20
                  [00.366]DRAM:  128 MiB
                  [00.369]Relocation Offset is: 04ec5000
                  [00.396]secure enable bit: 0
                  [00.399]smc_tee_inform_fdt failed with: -65526[00.403]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300                      Mhz
                  [00.409]gic: sec monitor mode
                  [00.412]flash init start
                  [00.414]workmode = 0,storage type = 1
                  [00.417][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
                  [00.423][mmc]: get sdc_type fail and use default host:tm1.
                  [00.429][mmc]: can't find node "mmc0",will add new node
                  [00.433][mmc]: fdt err returned <no error>
                  [00.437][mmc]: Using default timing para
                  [00.441][mmc]: SUNXI SDMMC Controller Version:0x50310
                  [00.459][mmc]: card_caps:0x3000000a
                  [00.462][mmc]: host_caps:0x3000003f
                  [00.465][mmc]: sd set card speed failed
                  [00.469][mmc]: sd set card speed failed
                  [00.473]sunxi flash init ok
                  [00.475]line:703 init_clocks
                  [00.478]drv_disp_init
                  [00.493]drv_disp_init finish
                  [00.496]boot_gui_init:start
                  [00.498]set disp.dev2_output_type fail. using defval=0
                  [00.504]boot_gui_init:finish
                  [00.523]bmp_name=bootlogo.bmp size 1152054
                  1152054 bytes read in 97 ms (11.3 MiB/s)
                  [00.645]Loading Environment from SUNXI_FLASH... OK
                  [00.678]Item0 (Map) magic is bad
                  [00.681]the secure storage item0 copy0[00.685]LCD open finish
                   magic is bad
                  [00.692]Item0 (Map) magic is bad
                  [00.695]the secure storage item0 copy1 magic is bad
                  [00.700]Item0 (Map) magic is bad
                  [00.706]secure storage read widevine fail with:-1
                  [00.713]secure storage read ec_key fail with:-1
                  [00.720]secure storage read ec_cert1 fail with:-1
                  [00.728]secure storage read ec_cert2 fail with:-1
                  [00.735]secure storage read ec_cert3 fail with:-1
                  [00.742]secure storage read rsa_key fail with:-1
                  [00.750]secure storage read rsa_cert1 fail with:-1
                  [00.757]secure storage read rsa_cert2 fail with:-1
                  [00.765]secure storage read rsa_cert3 fail with:-1
                  [00.770]usb burn from boot
                  delay time 0
                  weak:otg_phy_config
                  [00.781]usb prepare ok
                  [00.949]usb sof ok
                  [00.951]usb probe ok
                  [00.953]usb setup ok
                  set address 0x10
                  set address 0x10 ok
                  [03.957]do_burn_from_boot usb : have no handshake
                  List file under ULI/factory
                  [03.968]update part info
                  [03.971]update bootcmd
                  [03.974]change working_fdt 0x44884e70 to 0x44864e70
                  [03.992]update dts
                  [05.554]no vendor_boot partition is found
                  [05.574]Starting kernel ...
                  [05.577][mmc]: MMC Device 2 not found
                  [05.580][mmc]: mmc 2 not find, so not exit
                  [    0.000000] Linux version 5.4.61 (book@virtual-machine) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 2                      0160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Fri Mar 11 02:33:55 UTC 2022
                  [    0.000000] cma: Reserved 16 MiB at 0x47000000
                  • mangogeek
                    longan_MQ-Dual_uart0_pe2_pe3_rgb800480.7z
                    点屏固件(串口0,PE2,PE3。RGB方式)
                    无触摸
                    mangogeek A 2 条回复 最后回复 回复 引用 分享 0
                    • mangogeek
                      mangogeek LV 8 @mangogeek 最后由 编辑
                      双核的,舒夫斯基
                      • X
                        xjavr LV 3 最后由 编辑
                        rd, 有没有sdk?
                          mstempin LV 4 最后由 编辑
                          有关 Aliexpress 上 MQ Dual 可用性的任何消息?
                            DOT小文哥 LV 8 @mstempin 最后由 编辑
                            @mstempin 在 麻雀 MQ-Dual (双核A7版本内置128M运存) ,准备测试 中说:
                            百问网的速卖通上好像有卖?
                            是要在法国购买吗?
                            M 1 条回复 最后回复 回复 引用 分享 0
                              mstempin LV 4 @xiaowenge 最后由 编辑
                              @xiaowenge
                              是的!淘宝买不到
                              • mangogeek
                                估计也就这几天了,Dual和Pro会同时上架
                                  y97788 LV 5 最后由 编辑
                                  你好,我在调试WiFi时碰到了问题,使用longan的SDK包,然后看板子的WiFi芯片是RTL8189FS,自己移植好了驱动,在不接上RGB显示屏(电阻触摸)时,WiFi使用一切正常。但是接上了RGB屏幕后,WiFi连接热点时,调试串口终端卡住了,无法接收调试命令。但是用ssh连接,可以进入终端操作。
                                  现在的问题就是接上RGB显示屏就会有这个问题,系统调试终端卡住,导致后面一些服务也无法正常加载。
                                  请问下,是否RGB LCD 电路跟WiFi模块电路存在冲突了?还是我哪里配置有问题
                                  whycan mangogeek 2 条回复 最后回复 回复 引用 分享 0
                                    whycan晕哥 LV 9 @y97788 最后由 编辑
                                    @y97788
                                    没有冲突,而且麻雀的RGB屏是单向数据传输,系统无需知道屏是否接上。
                                    建议先换一根电源线。
                                    Y 1 条回复 最后回复 回复 引用 分享 0
                                      y97788 LV 5 @whycan 最后由 编辑
                                      @whycan 感谢回复,确实是电源问题,接上电脑USB上就有这个问题,接手机用的那个电源适配器则没问题,是否因为电流不够的原因?
                                        @y97788
                                        强行解释一吓,估计是瞬间电流过大,导致电源电压拉低,最终板子异常。
                                        • mangogeek
                                          mangogeek LV 8 @y97788 最后由 编辑
                                          @y97788 液晶屏的3.3V几乎没电流,主要耗电5V上会拉出300mA左右。RTL模块拉的是3.3V但最终都落到usb那边。
                                          换个口试试。
                                              a892755772 LV 5 @mangogeek 最后由 编辑
                                              @mangogeek 您好 想问下你这个longan_MQ-Dual_uart0_pe2_pe3_rgb800480 是在哪个基础上编译的 我想弄个480X272的。【t113 SDK】上编译的显示不出来 【buildroot-d1x-t113-main】上编译的 显示一条条线段
                                              • G
                                                gonboy LV 5 最后由 编辑
                                                是否有驱动 oV2640, 或 ov5640 的 修改方法。
                                                用官方的代码,默认编译,无法成功
                                                  awwwwa LV 8 @gonboy 最后由 编辑
                                                  @gonboy 换这个帖子里的驱动,芒果仓库里的摄像头驱动用不了的
                                                  D1-H (MQ-Pro)驱动 OV5640 摄像头
                                                  https://bbs.aw-ol.com/topic/4017/share/1
