    tina 2.0 d1s 的一些问题
    8477
      柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
      问题一:
      tina 2.0 d1s 编译后 adb 无法使用,根本找不到这个设备
      板子输入adbd之后报错
      问题二:
      修改sys_partition.fex的rootfs大小后发现无法启动
      [    2.256587][   T13] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    2.267116][    T1] ALSA device list:
      [    2.271203][    T1]   #0: audiocodec
      [    2.275266][   T13] cfg80211: failed to load regulatory.db
      [    2.281453][    T1] alloc_fd: slot 0 not NULL!
      [    2.291093][    T1] [EXFAT] trying to mount...
      [    2.297370][    T1] VFS: Cannot open root device "mmcblk0p5" or unknown-block (179,5): error -5
      [    2.307115][    T1] Please append a correct "root=" boot option; here are the available partitions:
      [    2.317332][    T1] b300        15267840 mmcblk0
      [    2.317337][    T1]  driver: mmcblk
      [    2.326562][    T1]   b301             252 mmcblk0p1 a0085546-4166-744a-a353-fca9272b8e45
      [    2.326568][    T1]
      [    2.338198][    T1]   b302             252 mmcblk0p2 a0085546-4166-744a-a353-fca9272b8e46
      [    2.338203][    T1]
      [    2.349780][    T1]   b303             252 mmcblk0p3 a0085546-4166-744a-a353-fca9272b8e47
      [    2.349784][    T1]
      [    2.361391][    T1]   b304           10240 mmcblk0p4 a0085546-4166-744a-a353-fca9272b8e48
      [    2.361396][    T1]
      [    2.372992][    T1]   b305          600000 mmcblk0p5 a0085546-4166-744a-a353-fca9272b8e49
      [    2.372996][    T1]
      [    2.384603][    T1]   b306           11200 mmcblk0p6 a0085546-4166-744a-a353-fca9272b8e4a
      [    2.384608][    T1]
      [    2.396185][    T1]   b307            5120 mmcblk0p7 a0085546-4166-744a-a353-fca9272b8e4b
      [    2.396188][    T1]
      [    2.407788][    T1]   103:00000   14602636 mmcblk0p8 a0085546-4166-744a-a353-fca9272b8e4c
      [    2.407793][    T1]
      [    2.419373][    T1] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
      [    2.429553][    T1] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #139
      [    2.436915][    T1] Call Trace:
      [    2.440427][    T1] [<ffffffe00002512c>] walk_stackframe+0x0/0x98
      [    2.447214][    T1] [<ffffffe0000252e4>] show_stack+0x2a/0x34
      [    2.453616][    T1] [<ffffffe000443b52>] dump_stack+0x20/0x28
      [    2.460016][    T1] [<ffffffe0000296ee>] panic+0xee/0x274
      [    2.466029][    T1] [<ffffffe000000ef6>] mount_block_root+0x214/0x27a
      [    2.473202][    T1] [<ffffffe000000fe2>] mount_root+0x86/0x90
      [    2.479599][    T1] [<ffffffe000001134>] prepare_namespace+0x148/0x152
      [    2.486868][    T1] [<ffffffe000000b58>] kernel_init_freeable+0x166/0x198
      [    2.494434][    T1] [<ffffffe000454704>] kernel_init+0x12/0xee
      [    2.500929][    T1] [<ffffffe000023e98>] ret_from_exception+0x0/0xc
      [    2.507911][    T1] Rebooting in 5 seconds..
        jmhh247 LV 6 最后由 编辑
        问题1:
        tina2.0默认是host,配置成device就可以用adb:
        root@TinaLinux:/sys/devices/platform/soc@3000000/soc@3000000:usbc0@0# echo usb_device > otg_role
        [  171.811945]
        [  171.811945] rmmod_host_driver
        [  171.811945]
        [  171.818656] [ehci0-controller]: sunxi_usb_disable_ehci
        [  171.824447] [sunxi-ehci0]: remove, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe00068f870
        [  171.835017] sunxi-ehci 4101000.ehci0-controller: remove, state 4
        [  171.841807] usb usb3: USB disconnect, device number 1
        [  171.848923] sunxi-ehci 4101000.ehci0-controller: USB bus 3 deregistered
        [  171.856575] [ohci0-controller]: sunxi_usb_disable_ohci
        [  171.862342] [sunxi-ohci0]: remove, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe00068fc38
        [  171.872942] sunxi-ohci 4101400.ohci0-controller: remove, state 4
        [  171.879839] usb usb4: USB disconnect, device number 1
        [  171.886915] sunxi-ohci 4101400.ohci0-controller: USB bus 4 deregistered
        [  171.894459]
        [  171.894459] insmod_device_driver
        [  171.894459]
        root@TinaLinux:/sys/devices/platform/soc@3000000/soc@3000000:usbc0@0# [  172.056247] sunxi_set_cur_vol_work()397 WARN: get power supply failed
        [  172.143194] android_work: sent uevent USB_STATE=CONNECTED
        [  172.175406] configfs-gadget gadget: high-speed config #1: c
        [  172.182249] read descriptors
        [  172.185496] read strings
        [  172.188699] android_work: sent uevent USB_STATE=DISCONNECTED
        [  172.350399] sunxi_set_cur_vol_work()397 WARN: get power supply failed
        [  172.436947] android_work: sent uevent USB_STATE=CONNECTED
        [  172.468031] configfs-gadget gadget: high-speed config #1: c
        [  172.474438] android_work: sent uevent USB_STATE=CONFIGURED
        [  197.178135] random: crng init done
          今天起床重新编译了一下全部好了
          所以调程序要看老黄历
            DOT小文哥 LV 8 @YuzukiTsuru 最后由 编辑
            @yuzukitsuru 在 tina 2.0 d1s 的一些问题 中说:
            今天起床重新编译了一下全部好了
            所以调程序要看老黄历
            应该是太阳黑子扰动寄存器意外翻转造成的
              jmhh247 LV 6 最后由 编辑
              用SDK2.0发现在内核启动时,usb驱动加载很让人迷惑:
              先加载device,再卸载device;然后加载host,这个流程合理吗
              [    5.805827] insmod_device_driver
              [    6.645776] rmmod_device_driver
              [    6.666849] insmod_host_driver
              [    5.527816] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
              ------run rc.final file-----
              [    5.805827]
              [    5.805827]
              [    5.813094] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
              [    5.897168] file system registered
              [    5.945396] configfs-gadget 4100000.udc-controller: failed to start g1: -19
              [    6.015167] read descriptors
              [    6.018693] read strings
              [    6.176876] sunxi_set_cur_vol_work()397 WARN: get power supply failed
              [    6.263348] android_work: sent uevent USB_STATE=CONNECTED
              [    6.344424] configfs-gadget gadget: high-speed config #1: c
              [    6.350842] android_work: sent uevent USB_STATE=CONFIGURED
              [    6.645776]
              [    6.645776]
              [    6.652603] rmmod_device_driver()222 WARN: get power supply failed
              [    6.659652] android_work: sent uevent USB_STATE=DISCONNECTED
              [    6.666849]
              [    6.666849]
              [    6.673555] [ehci0-controller]: sunxi_usb_enable_ehci
              [    6.679372] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe00068f870, 0x:ffffffd00406f000, irq_no:2e
              [    6.692996] hci: sunxi_insmod_ehci()601 WARN: get supply failed
              [    6.699755] sunxi-ehci 4101000.ehci0-controller: 4101000.ehci0-controller supply hci not found, using dummy regulator
              [    6.712193] sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
              [    6.719482] sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 3
              [    6.729453] sunxi-ehci 4101000.ehci0-controller: irq 46, io mem 0x04101000
              [    6.765779] sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
              [    6.774939] hub 3-0:1.0: USB hub found
              [    6.779358] hub 3-0:1.0: 1 port detected
              [    6.787299] [ohci0-controller]: sunxi_usb_enable_ohci
              [    6.792959] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe00068fc38
              [    6.803541] hci: sunxi_insmod_ohci()265 WARN: get supply failed
              [    6.810240] sunxi-ohci 4101400.ohci0-controller: 4101400.ohci0-controller supply hci not found, using dummy regulator
              [    6.822761] sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
              [    6.830114] sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 4
              [    6.839936] sunxi-ohci 4101400.ohci0-controller: irq 47, io mem 0x04101400
              [    6.921086] hub 4-0:1.0: USB hub found
              [    6.925367] hub 4-0:1.0: 1 port detected
              host_chose finished!
              nice: can't execute '/usr/bin/story_ota_bin': No such file or directory
              ------run profile file-----
              root@TinaLinux:/#
                柚木 鉉 LV 9 @jmhh247 最后由 编辑
                @jmhh247 我摆烂了, usb_port_type = <0x0>;
                J 1 条回复 最后回复 回复 引用 分享 0
                  jmhh247 LV 6 @YuzukiTsuru 最后由 编辑
                  @yuzukitsuru 这个我之前试过,但是没起作用,找时间再试试😂
                    @jmhh247
                    &usbc0 {
                    	device_type = "usbc0";
                    	usb_detect_type = <0x1>;
                    	usb_detect_mode = <0>;
                    	usb_id_gpio = <&pio PB 6 GPIO_ACTIVE_HIGH>; /*unused */
                    	enable-active-high;
                    	usb_det_vbus_gpio = <&pio PB 2 GPIO_ACTIVE_HIGH>;/*unused */
                    	usb_wakeup_suspend = <0>;
                    	usb_serial_unique = <0>;
                    	rndis_wceis = <1>;
                    &ehci0 {
                    &ohci0 {
                    &usbc1 {
                    	device_type = "usbc1";
                    	usb_port_type = <1>;
                    	sb_detect_type = <1>;
                    	usb_regulator_io = "nocare";
                    &ehci1 {
                    &ohci1 {
                      jmhh247 LV 6 最后由 编辑
                      我从别人分享的网盘下的sdk2.0,可能是个假的tina。😂
                      改了dts也不行,
                      发现target/allwinner/d1s-nezha/busybox-init-base-files/etc/init.d/rc.final里面,最后就是要加载host:
                      if [ x${boot_partition} == xboot ];then
                      	amixer cset name="Headphone Switch" 1
                      	cat /sys/devices/platform/soc@3000000/soc@3000000:usbc0@0/usb_host
                      	nice -n -20 /usr/bin/story_bin &
                      	export swu_software=$(fw_printenv -n swu_software 2>/dev/null)
                      	export swu_mode=$(fw_printenv -n swu_mode 2>/dev/null)
                      	nice -n -20 /usr/bin/story_ota_bin &
                      fi
                      注释掉usb_host这行,发现启动不太稳定,有时候启动不了。
                      老哥能发个完整的启动log看看吗,麻雀的
                        @jmhh247
                        [304]HELLO! BOOT0 is starting!
                        [307]BOOT0 commit : 88480af
                        U-Boot 2018.05-g24521d6-dirty-config-dirty (Mar 28 2022 - 18:12:53 +0800) Allwinner Technology
                        [00.386]DRAM:  64 MiB
                        [00.389]Relocation Offset is: 01ee7000
                        [00.393]secure enable bit: 0
                        [00.396]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                        [00.402]flash init start
                        [00.404]workmode = 0,storage type = 1
                        [00.408][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
                        [00.413][mmc]: get sdc_type fail and use default host:tm1.
                        [00.419][mmc]: can't find node "mmc0",will add new node
                        [00.424][mmc]: fdt err returned <no error>
                        [00.428][mmc]: Using default timing para
                        [00.432][mmc]: SUNXI SDMMC Controller Version:0x50310
                        [00.449][mmc]: card_caps:0x3000000a
                        [00.452][mmc]: host_caps:0x3000003f
                        [00.455]sunxi flash init ok
                        [00.458]line:703 init_clocks
                        [00.461]drv_disp_init
                        [00.473]drv_disp_init finish
                        [00.476]boot_gui_init:start
                        [00.479]set disp.dev2_output_type fail. using defval=0
                        [00.695]boot_gui_init:finish
                        [00.705]=====================LCD_INIT
                        54 bytes read in 5 ms (9.8 KiB/s)
                        [01.001]bmp_name=bootlogo.bmp size 38454
                        38454 bytes read in[01.018]LCD open finish
                         8 ms (4.6 MiB/s)
                        [01.056]Loading Environment from SUNXI_FLASH... OK
                        [01.078]out of usb burn from boot: not need burn key
                        [01.105]Item0 (Map) magic is bad
                        [01.108]the secure storage item0 copy0 magic is bad
                        [01.134]Item0 (Map) magic is bad
                        [01.137]the secure storage item0 copy1 magic is bad
                        [01.141]Item0 (Map) magic is bad
                        root_partition is rootfs
                        set root to /dev/mmcblk0p5
                        [01.159]update part info
                        [01.165]update bootcmd
                        [01.171]change working_fdt 0x42aa6da0 to 0x42a86da0
                        [01.201]update dts
                        noncached_alloc(): addr = 0x42b91080
                        noncached_alloc(): addr = 0x42b910c0
                        noncached_alloc(): addr = 0x42b91100
                        noncached_alloc(): addr = 0x42b91940
                        geth_sys_init fail!
                        [01.222]Board Net Initialization Failed
                        [01.225]No ethernet found.
                        Hit any key to stop autoboot:  2 ... 1 ... 0
                        [03.572]no vendor_boot partition is found
                        Android's image name: d1s-yuzuki_nezha
                        Detect comp none
                        [03.589]
                        Starting kernel ...
                        [03.592][mmc]: MMC Device 2 not found
                        [03.595][mmc]: mmc 2 not find, so not exit
                        [    0.000000][    T0] Linux version 5.4.61 (yuzuki@YuzukiOMEN) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #146 PREEMPT Tue Mar 29 03:29:50 UTC 2022
                        [    0.000000][    T0] Zone ranges:
                        [    0.000000][    T0]   DMA32    [mem 0x0000000040000000-0x0000000043ffffff]
                        [    0.000000][    T0]   Normal   empty
                        [    0.000000][    T0] Movable zone start for each node
                        [    0.000000][    T0] Early memory node ranges
                        [    0.000000][    T0]   node   0: [mem 0x0000000040000000-0x0000000043ffffff]
                        [    0.000000][    T0] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
                        [    0.000000][    T0] On node 0 totalpages: 16384
                        [    0.000000][    T0]   DMA32 zone: 224 pages used for memmap
                        [    0.000000][    T0]   DMA32 zone: 0 pages reserved
                        [    0.000000][    T0]   DMA32 zone: 16384 pages, LIFO batch:3
                        [    0.000000][    T0] elf_hwcap is 0x20112d
                        [    0.000000][    T0] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
                        [    0.000000][    T0] pcpu-alloc: [0] 0
                        [    0.000000][    T0] Built 1 zonelists, mobility grouping on.  Total pages: 16160
                        [    0.000000][    T0] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:recovery@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty-config-dirty(03/28/
                        [    0.000000][    T0] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                        [    0.000000][    T0] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
                        [    0.000000][    T0] Sorting __ex_table...
                        [    0.000000][    T0] mem auto-init: stack:off, heap alloc:off, heap free:off
                        [    0.000000][    T0] Memory: 56412K/65536K available (4557K kernel code, 408K rwdata, 1745K rodata, 144K init, 230K bss, 9124K reserved, 0K cma-reserved)
                        [    0.000000][    T0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
                        [    0.000000][    T0] rcu: Preemptible hierarchical RCU implementation.
                        [    0.000000][    T0] 	Tasks RCU enabled.
                        [    0.000000][    T0] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                        [    0.000000][    T0] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
                        [    0.000000][    T0] plic: mapped 200 interrupts with 1 handlers for 2 contexts.
                        [    0.000000][    T0] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
                        [    0.000000][    T0] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
                        [    0.000005][    T0] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
                        [    0.000026][    T0] riscv_timer_clockevent depends on broadcast, but no broadcast function available
                        [    0.000372][    T0] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                        [    0.000979][    T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                        [    0.001001][    T0] pid_max: default: 32768 minimum: 301
                        [    0.001180][    T0] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
                        [    0.001202][    T0] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
                        [    0.003237][    T1] ASID allocator initialised with 65536 entries
                        [    0.003431][    T1] rcu: Hierarchical SRCU implementation.
                        [    0.004161][    T1] devtmpfs: initialized
                        [    0.022175][    T1] random: get_random_u32 called from bucket_table_alloc.isra.27+0x10a/0x12c with crng_init=0
                        [    0.023107][    T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                        [    0.023144][    T1] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
                        [    0.023302][    T1] pinctrl core: initialized pinctrl subsystem
                        [    0.024500][    T1] NET: Registered protocol family 16
                        [    0.025272][    T1] DMA: preallocated 256 KiB pool for atomic allocations
                        [    0.025948][    T1] cpuidle: using governor menu
                        [    0.069336][    T1] rtc_ccu: sunxi ccu init OK
                        [    0.077557][    T1] clock: sunxi ccu init OK
                        [    0.078646][    T1] clock: sunxi ccu init OK
                        [    0.115882][    T1] iommu: Default domain type: Translated
                        [    0.116102][    T1] sunxi iommu: irq = 4
                        [    0.117394][    T1] SCSI subsystem initialized
                        [    0.117600][    T1] usbcore: registered new interface driver usbfs
                        [    0.117711][    T1] usbcore: registered new interface driver hub
                        [    0.117847][    T1] usbcore: registered new device driver usb
                        [    0.118016][    T1] videodev: Linux video capture interface: v2.00
                        [    0.118921][    T1] Advanced Linux Sound Architecture Driver Initialized.
                        [    0.119658][    T1] pwm module init!
                        [    0.121567][    T1] g2d 5410000.g2d: Adding to iommu group 0
                        [    0.122140][    T1] G2D: rcq version initialized.major:252
                        [    0.122996][    T1] clocksource: Switched to clocksource riscv_clocksource
                        [    0.138313][    T1] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
                        [    0.141953][    T1] NET: Registered protocol family 2
                        [    0.142874][    T1] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
                        [    0.142930][    T1] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
                        [    0.142949][    T1] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
                        [    0.142964][    T1] TCP: Hash tables configured (established 512 bind 512)
                        [    0.143236][    T1] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                        [    0.143286][    T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                        [    0.143569][    T1] NET: Registered protocol family 1
                        [    0.146562][    T1] workingset: timestamp_bits=62 max_order=14 bucket_order=0
                        [    0.156058][    T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                        [    0.156325][    T1] ntfs: driver 2.1.32 [Flags: R/W].
                        [    0.177005][    T1] io scheduler mq-deadline registered
                        [    0.177022][    T1] io scheduler kyber registered
                        [    0.178287][    T1] [DISP]disp_module_init
                        [    0.178928][    T1] disp 5000000.disp: Adding to iommu group 0
                        [    0.179642][    T1] [DISP] disp_init,line:2386:
                        [    0.179648][    T1] smooth display screen:0 type:1 mode:4
                        [    0.219187][    T1] display_fb_request,fb_id:0
                        [    0.224799][    T1] Freeing logo buffer memory: 504K
                        [    0.225341][   T13] disp_al_manager_apply ouput_type:1
                        [    0.225503][   T13] [DISP] lcd_clk_config,line:732:
                        [    0.225516][   T13] disp 0, clk: pll(192000000),clk(192000000),dclk(8000000) dsi_rate(8000000)
                        [    0.225516][   T13]      clk real:pll(288000000),clk(288000000),dclk(72000000) dsi_rate(150000000)
                        [    0.226073][    T1] [DISP]disp_module_init finish
                        [    0.226992][    T1] sunxi_sid_init()551 - insmod ok
                        [    0.228543][    T1] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
                        [    0.229138][    T1] uart uart0: get regulator failed
                        [    0.229170][    T1] uart uart0: uart0 supply uart not found, using dummy regulator
                        [    0.229500][    T1] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
                        [    0.229533][    T1] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
                        [    0.956668][    T1] printk: console [ttyS0] enabled
                        [    0.963072][    T1] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
                        [    0.975292][    T1] uart uart1: get regulator failed
                        [    0.980845][    T1] uart uart1: uart1 supply uart not found, using dummy regulator
                        [    0.989715][    T1] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
                        [    0.999993][    T1] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
                        [    1.012150][    T1] uart uart3: get regulator failed
                        [    1.017808][    T1] uart uart3: uart3 supply uart not found, using dummy regulator
                        [    1.026622][    T1] uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
                        [    1.037505][    T1] misc dump reg init
                        [    1.042639][    T1] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
                        [    1.050667][    T1] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
                        [    1.059051][    T1] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
                        [    1.067202][    T1] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
                        [    1.075396][    T1] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
                        [    1.082672][    T1] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
                        [    1.090446][    T1] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
                        [    1.099101][    T1] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
                        [    1.108107][    T1] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
                        [    1.116623][    T1] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
                        [    1.124197][    T1] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
                        [    1.132939][    T1] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
                        [    1.141408][    T1] [ADDR_MGT] addr_mgt_probe: success.
                        [    1.148326][    T1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                        [    1.156489][    T1] sunxi-ehci: EHCI SUNXI driver
                        [    1.162300][    T1] get ehci0-controller wakeup-source is fail.
                        [    1.169063][    T1] sunxi ehci0-controller don't init wakeup source
                        [    1.176095][    T1] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0006db4a0, 0x:ffffffd004071000, irq_no:2e
                        [    1.190420][    T1] [sunxi-ehci0]: Not init ehci0
                        [    1.196129][    T1] get ehci1-controller wakeup-source is fail.
                        [    1.202841][    T1] sunxi ehci1-controller don't init wakeup source
                        [    1.209939][    T1] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0006dbc30, 0x:ffffffd004075000, irq_no:31
                        [    1.224247][    T1] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
                        [    1.237513][    T1] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
                        [    1.250466][    T1] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
                        [    1.258578][    T1] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
                        [    1.269213][    T1] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
                        [    1.303052][    T1] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
                        [    1.312782][    T1] hub 1-0:1.0: USB hub found
                        [    1.317885][    T1] hub 1-0:1.0: 1 port detected
                        [    1.324173][    T1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                        [    1.331837][    T1] sunxi-ohci: OHCI SUNXI driver
                        [    1.337734][    T1] get ohci0-controller wakeup-source is fail.
                        [    1.344513][    T1] sunxi ohci0-controller don't init wakeup source
                        [    1.351541][    T1] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0006db868
                        [    1.362725][    T1] [sunxi-ohci0]: Not init ohci0
                        [    1.368400][    T1] get ohci1-controller wakeup-source is fail.
                        [    1.375236][    T1] sunxi ohci1-controller don't init wakeup source
                        [    1.382229][    T1] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0006dbff8
                        [    1.393465][    T1] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
                        [    1.406761][    T1] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
                        [    1.419782][    T1] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
                        [    1.427839][    T1] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
                        [    1.438913][    T1] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
                        [    1.518148][    T1] hub 2-0:1.0: USB hub found
                        [    1.523255][    T1] hub 2-0:1.0: 1 port detected
                        [    1.530028][    T1] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
                        [    1.543479][    T1] sunxi-rtc 7090000.rtc: registered as rtc0
                        [    1.550010][    T1] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:05 UTC (5)
                        [    1.559684][    T1] sunxi-rtc 7090000.rtc: sunxi rtc probed
                        [    1.566464][    T1] i2c /dev entries driver
                        [    1.571202][    T1] IR NEC protocol handler initialized
                        [    1.579926][    T1] uvcvideo: Unable to create debugfs directory
                        [    1.586889][    T1] usbcore: registered new interface driver uvcvideo
                        [    1.594112][    T1] USB Video Class driver (1.1.1)
                        [    1.599450][    T1] sunxi cedar version 1.1
                        [    1.604427][    T1] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
                        [    1.611489][    T1] VE: install start!!!
                        [    1.611489][    T1]
                        [    1.618656][    T1] VE: cedar-ve the get irq is 6
                        [    1.618656][    T1]
                        [    1.626540][    T1] VE: install end!!!
                        [    1.626540][    T1]
                        [    1.633358][    T1] VE: sunxi_cedar_probe
                        [    1.640255][    T1] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                        [    1.651046][    T1] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
                        [    1.658025][    T1] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
                        [    1.665200][    T1] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
                        [    1.672380][    T1] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
                        [    1.679587][    T1] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
                        [    1.686929][    T1] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
                        [    1.694239][    T1] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
                        [    1.701511][    T1] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
                        [    1.709641][    T1] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.721552][    T1] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
                        [    1.742484][    T1] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.767535][    T1] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
                        [    1.774403][   T13] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.787557][    T1] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                        [    1.798478][    T1] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
                        [    1.805554][    T1] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
                        [    1.812687][    T1] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
                        [    1.819928][   T13] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.832318][    T1] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
                        [    1.839532][    T1] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
                        [    1.846958][    T1] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
                        [    1.854342][    T1] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
                        [    1.861667][    T1] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
                        [    1.869052][    T1] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
                        [    1.878572][   T13] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.891692][    T1] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.903785][    T1] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                        [    1.913869][   T13] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.926264][    T1] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.951375][    T1] sunxi-mmc 4021000.sdmmc: detmode:manually by software
                        [    1.960035][    C0] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                        [    1.968134][    T1] ashmem: initialized
                        [    1.972452][    C0] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                        [    1.980144][    T5] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    1.992533][    T1] exFAT: Version 1.3.0
                        [    2.000133][    T5] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                        [    2.012538][   T13] mmc0: host does not support reading read-only switch, assuming write-enable
                        [    2.024648][    T1] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
                        [    2.024648][    T1]
                        [    2.043560][    T1] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
                        [    2.055301][   T13] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                        [    2.068096][    T1] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
                        [    2.077043][    C0] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        [    2.084740][   T13] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                        [    2.097162][    C0] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        [    2.105571][    C0] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        [    2.113401][   T13] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                        [    2.125822][    C0] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                        [    2.133390][    T5] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                        [    2.145792][    T1] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
                        [    2.152307][    T1] [SNDCODEC][sunxi_card_init][583]:card init finished
                        [    2.162483][    T1] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
                        [    2.173211][   T13] mmc0: new high speed SDHC card at address b368
                        [    2.181531][   T13] mmcblk0: mmc0:b368 NCard 14.6 GiB
                        [    2.188544][    T1] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
                        [    2.204504][    T1] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
                        [    2.214262][   T13]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
                        [    2.221595][    T1] NET: Registered protocol family 10
                        [    2.231653][    T1] Segment Routing with IPv6
                        [    2.236917][    T1] NET: Registered protocol family 17
                        [    2.244942][   T13] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
                        [    2.261028][   T13] sunxi-i2c sunxi-i2c2: probe success
                        [    2.272285][    T1] clk: Not disabling unused clocks
                        [    2.278409][   T13] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                        [    2.288941][    T1] ALSA device list:
                        [    2.293103][    T1]   #0: audiocodec
                        [    2.297104][    T1] alloc_fd: slot 0 not NULL!
                        [    2.302698][   T13] cfg80211: failed to load regulatory.db
                        [    2.323152][    T1] EXT4-fs (mmcblk0p5): mounted filesystem without journal. Opts: (null)
                        [    2.332399][    T1] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
                        [    2.342216][    T1] devtmpfs: mounted
                        [    2.346554][    T1] Freeing unused kernel memory: 144K
                        [    2.352278][    T1] This architecture does not have kernel memory protection.
                        [    2.360319][    T1] Run /pseudo_init as init process
                        mount: mounting /dev/by-name/rootfs_data on /overlay failed: Invalid argument
                        Mount Failed: formating /dev/by-name/rootfs_data to ext4 ...
                        /pseudo_init: line 395: mkfs.ext4: not found
                        [    2.742162][   T91] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
                        /etc/init.d/rcS: line 136: mkfs.ext4: not found
                        [    2.863138][   T13] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:1
                        [    2.930690][  T111]
                        [    2.930690][  T111] insmod_host_driver
                        [    2.930690][  T111]
                        [    2.943946][  T111] [ehci0-controller]: sunxi_usb_enable_ehci
                        [    2.951019][  T111] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0006db4a0, 0x:ffffffd004071000, irq_no:2e
                        [    2.969093][  T111] hci: sunxi_insmod_ehci()601 WARN: get supply failed
                        [    2.977013][  T111] sunxi-ehci 4101000.ehci0-controller: 4101000.ehci0-controller supply hci not found, using dummy regulator
                        [    2.993559][  T111] sunxi-ehci 4101000.ehci0-controller: EHCI Host Controller
                        [    3.001596][  T111] sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 3
                        [    3.017937][  T111] sunxi-ehci 4101000.ehci0-controller: irq 46, io mem 0x04101000
                        [    3.063121][  T111] sunxi-ehci 4101000.ehci0-controller: USB 2.0 started, EHCI 1.00
                        [    3.084293][  T111] hub 3-0:1.0: USB hub found
                        [    3.089334][  T111] hub 3-0:1.0: 1 port detected
                        [    3.104790][  T111] [ohci0-controller]: sunxi_usb_enable_ohci
                        [    3.111203][  T111] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0006db868
                        [    3.143768][  T111] hci: sunxi_insmod_ohci()265 WARN: get supply failed
                        [    3.151165][  T111] sunxi-ohci 4101400.ohci0-controller: 4101400.ohci0-controller supply hci not found, using dummy regulator
                        [    3.199530][  T111] sunxi-ohci 4101400.ohci0-controller: OHCI Host Controller
                        [    3.217544][  T111] sunxi-ohci 4101400.ohci0-controller: new USB bus registered, assigned bus number 4
                        [    3.237039][  T111] sunxi-ohci 4101400.ohci0-controller: irq 47, io mem 0x04101400
                        [    3.245503][    C0] random: fast init done
                        [    3.311816][  T133] file system registered
                        [    3.332762][  T111] hub 4-0:1.0: USB hub found
                        [    3.343198][  T111] hub 4-0:1.0: 1 port detected
                        [    3.363111][   T59]
                        [    3.363111][   T59] rmmod_host_driver
                        [    3.363111][   T59]
                        [    3.372039][   T59] [ehci0-controller]: sunxi_usb_disable_ehci
                        [    3.401325][   T59] [sunxi-ehci0]: remove, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0006db4a0
                        [    3.415632][  T113] configfs-gadget 4100000.udc-controller: failed to start g1: -19
                        sh: write error: No such device[    3.445531][   T59] sunxi-ehci 4101000.ehci0-controller: remove, state 4
                        [    3.503131][   T59] usb usb3: USB disconnect, device number 1
                          _    _                       _        ____   _____
                         | |  | | Powered by OpenWRT  | |      / __ \ / ____|
                         | |  | |_ __  _   _ ___  ___ | | __ _| |  | | (___
                         | |  | | '_ \| | | / __|/ _ \| |/ _` | |  | |\___ \
                         | |__| | | | | |_| \__ \ (_) | | (_| | |__| |____) |
                          \____/|_| |_|\__,_|___/\___/|_|\__,_|\____/|_____/
                        ----------------------[    3.539688][   T59] sunxi-ehci 4101000.ehci0-controller: USB bus 3 deregistered
                         Yuzuki UnusolaOS (v1.0, Tina: 61CC0487)
                        [    3.563240][  T153] read descriptors
                        [    3.567245][  T153] read strings
                        [    3.582720][   T59] [ohci0-controller]: sunxi_usb_disable_ohci
                        [    3.589634][   T59] [sunxi-ohci0]: remove, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0006db868
                        [    3.609221][   T59] sunxi-ohci 4101400.ohci0-controller: remove, state 4
                        [    3.618260][   T59] usb usb4: USB disconnect, device number 1
                        [    3.626411][   T59] sunxi-ohci 4101400.ohci0-controller: USB bus 4 deregistered
                        root@TinaLinux:/# [    3.635799][   T59]
                        [    3.635799][   T59] insmod_device_driver
                        [    3.635799][   T59]
                        [    3.646861][   T59] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
                        [    3.659712][   T59] device_chose finished 139!
                        [    3.813980][   T13] sunxi_set_cur_vol_work()397 WARN: get power supply failed
                        [    3.895639][   T13] android_work: sent uevent USB_STATE=CONNECTED
                        [    3.930050][    C0] configfs-gadget gadget: high-speed config #1: c
                        [    3.937220][   T13] android_work: sent uevent USB_STATE=CONFIGURED
                        root@TinaLinux:/#
                          jmhh247 LV 6 最后由 编辑
                          好的,时间后面中括号的T是黑科技吗,我的没有这个
                          [    3.415632][  T1]
                            @jmhh247 是kernel hacking的选项,不用管他
