    谁跑过D1a的core_mark分数吗,我这里有T113的跑分,想来对比下
    5
    15
    7448
      smiletiger LV 6 最后由 xiaowenge 编辑
      2K performance run parameters for coremark.
      CoreMark Size    : 666
      Total ticks      : 12751
      Total time (secs): 12
      Iterations/Sec   : 4166
      Iterations       : 50000
      Compiler version : GCC6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512]
      Compiler flags   :
      Memory location  : STACK
      seedcrc          : 0xe9f5
      [0]crclist       : 0xe714
      [0]crcmatrix     : 0x1fd7
      [0]crcstate      : 0x8e3a
      [0]crcfinal      : 0xa14c
      Correct operation validated. See README.md for run and reporting rules.
      CoreMark 1.0 : 4166 / GCC6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512]  / STACK
      另外我想问一下,我使用smp和不使用,跑分是一样的,这个smp到底是怎么用的啊,是不是没啥用,在rtt里面建立任务的时候会自动分配cpu还是需要人为去指定
      或者能不能一个任务两个核一起来用,
      另外在附上memory_perf的分数
      MemoryPerf version 1.0.0
      Copyright (c) 2022 SummerGift (summergift2019@gmail.com)
      Licensed under the MIT License version.
      Memory performance testing start...
      address: 0x40100000, length: 0x100000, iterations: 200
      Data length : 209 MB.
      8-bit write speed test begin.
      [2022-04-18 15:41:26.787]# RECV ASCII>
      Spend time : 0.223000 s.
      8-bit write speed: 940.426880 M/s.
      8-bit read speed test begin.
      [2022-04-18 15:41:27.346]# RECV ASCII>
      Spend time : 0.559000 s.
      8-bit Read speed: 375.161346 M/s.
      16-bit write speed test begin.
      [2022-04-18 15:41:27.472]# RECV ASCII>
      Spend time : 0.111000 s.
      16-bit write speed: 1889.326050 M/s.
      16-bit read speed test begin.
      [2022-04-18 15:41:27.802]# RECV ASCII>
      Spend time : 0.328000 s.
      16-bit Read speed: 639.375610 M/s.
      32-bit write speed test begin.
      [2022-04-18 15:41:27.896]# RECV ASCII>
      Spend time : 0.091000 s.
      32-bit Write speed: 2304.562744 M/s.
      32-bit read speed test begin.
      [2022-04-18 15:41:28.067]# RECV ASCII>
      Spend time : 0.160000 s.
      32-bit Read speed: 1310.719971 M/s.
      Memory performance completed.
      有没有大神拿其他片子来对比一下,这个a7到底什么水平啊
      aozima 1 条回复 最后回复 回复 引用 分享 0
        caozilong LV 5 最后由 编辑
        A7 大概1.6个DMIPS/MHZ,平均下来每个clk执行1.6条指令,和谷歌标称的A7 1.9 DMIPS/Mhz差别不大,中间可能有编译器优化,运行环境不同引入的差别。
        • aozima
          aozima LV 7 @smiletiger 最后由 编辑
          或者能不能一个任务两个核一起来用,
          默认会自动分配吧,也可以绑定。你这跑分,可以改下代码,同时跑2份core_mark看看部分。
          S 1 条回复 最后回复 回复 引用 分享 0
            smiletiger LV 6 @aozima 最后由 编辑
            @aozima 怎么同时跑两份啊,我用的是你移植的rtt,smp部分不太懂,启动第二个核心的时候那个时钟tick要不要开启啊,你那边的代码里面注释掉了定时器,
            aozima 2 条回复 最后回复 回复 引用 分享 0
            • aozima
              @smiletiger 你要测性能的话要开启的,我那个代码是从qemu那边复制过来的,要重新适配T113才行,你可以试试加上心跳。
              • aozima
                @smiletiger 注意下,那个移植里面,不光第2核的心跳没启动,0核的心跳也没启动呢。
                  @aozima 我已经开启了cpu1的心跳,
                  cpu2的心跳不开启的话cpu2不能参与任务调度吗,但是我用rt_thread_control(tid, RT_THREAD_CTRL_BIND_CPU, (void *)1);这个绑定cpu是可以正常调度的呀
                    柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
                    Linux TinaLinux 5.4.61 #265 PREEMPT Mon Apr 18 15:41:13 UTC 2022 riscv64 GNU/Linux
                    CoreMark Size    : 666
                    Total ticks      : 13456
                    Total time (secs): 13.456000
                    Iterations/Sec   : 2972.651605
                    Iterations       : 40000
                    Compiler version : GCC8.1.0
                    Compiler flags   : -O2   -lrt
                    Memory location  : Please put data memory location here
                                            (e.g. code in flash, data on heap etc)
                    seedcrc          : 0xe9f5
                    [0]crclist       : 0xe714
                    [0]crcfinal      : 0x25b5
                    CoreMark 1.0 : 2972.651605 / GCC8.1.0 -O2   -lrt / Heap
                    MemoryPerf 不知道能不能在RV上跑,没测试
                    S 2 条回复 最后回复 回复 引用 分享 0
                    • aozima
                      @smiletiger 没心跳只是与时间相关的不正常,主动让出不受影响。
                      建议把cpu1的心跳也开起来吧,期待!
                        smiletiger LV 6 @YuzukiTsuru 最后由 编辑
                        @yuzukitsuru 请问你这个是f133的分数吗 或者是d1或者d1s吗,这个core-Mark在linux下和rtthread下面跑分是不是不一样啊,我优化了一下代码下载可以跑到4170了
                        CoreMark Size : 666
                        Total ticks : 11990
                        Total time (secs): 11.990000
                        Iterations/Sec : 4170.141785
                        Iterations : 50000
                        Compiler flags :
                        seedcrc : 0xe9f5
                        [0]crclist : 0xe714
                        CoreMark 1.0 : 4170.141785 / GCC6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512] / STACK
                        msh />
                          @yuzukitsuru 又随手跑了一下 Dhrystones
                          dhrystone_test
                          Dhrystone Benchmark, Version 2.1 (Language: C)
                          Program compiled without 'register' attribute
                          Execution starts, 32000000 runs through Dhrystone
                          [2022-04-19 11:07:53.418]# RECV ASCII>
                          Execution ends
                          Final values of the variables used in the benchmark:
                          Int_Glob: 5
                          should be: 5
                          Bool_Glob: 1
                          should be: 1
                          Ch_1_Glob: A
                          should be: A
                          Ch_2_Glob: B
                          should be: B
                          Arr_1_Glob[8]: 7
                          should be: 7
                          Arr_2_Glob[8][7]: 32000010
                          should be: Number_Of_Runs + 10
                          Ptr_Glob->
                          Ptr_Comp: 1073951700
                          should be: (implementation-dependent)
                          Discr: 0
                          should be: 0
                          Enum_Comp: 2
                          should be: 2
                          Int_Comp: 17
                          should be: 17
                          Str_Comp: DHRYSTONE PROGRAM, SOME STRING
                          should be: DHRYSTONE PROGRAM, SOME STRING
                          Next_Ptr_Glob->
                          should be: (implementation-dependent), same as above
                          Discr: 0
                          should be: 0
                          Enum_Comp: 1
                          should be: 1
                          Int_Comp: 18
                          should be: 18
                          Str_Comp: DHRYSTONE
                          [2022-04-19 11:07:53.538]# RECV ASCII>
                          Int_1_Loc: 5
                          should be: 5
                          Int_2_Loc: 13
                          should be: 13
                          Int_3_Loc: 7
                          should be: 7
                          Enum_Loc: 1
                          should be: 1
                          Str_1_Loc: DHRYSTONE PROGRAM, 1'ST STRING
                          should be: DHRYSTONE PROGRAM, 1'ST STRING
                          Str_2_Loc: DHRYSTONE PROGRAM, 2'ND STRING
                          should be: DHRYSTONE PROGRAM, 2'ND STRING
                          Microseconds for one run through Dhrystone: 0
                          Dhrystones per Second: 4484933
                          VAX MIPS rating: 2552
                          msh />
                          因为一直在纠结用f133还是t113,在两者之间徘徊,所以才想测试一下性能,以便决定以后用哪个
                            柚木 鉉 LV 9 @smiletiger 最后由 编辑
                            @smiletiger 这个是F133-B的分数,我估计跟平台应该有关
                            • Randolph
                              Randolph LV 6 最后由 q1215200171 编辑
                              麻雀D1s跑的,优化等级o3
                                smiletiger LV 6 @Randolph 最后由 编辑
                                @randolph 谢谢大家提供的数据,我实际测试下来发现t113s3优势非常大,我来跑rtt+awtk t113s3开启smp模式可以丝滑跑120帧,但是f133只能跑60帧,而且60帧还不稳定,不知道是riscv64的开发环境刚出来没优化好还是其他问题,
                                  @aozima 大神能讲解一下smp方面的rtt问题吗,我现在只开启了一个定时器,然后rtconfig里面定义了RT_USING_SMP,然后跑gui发现非常丝滑,
                                  我把RT_USING_SMP这个定义关闭了在跑gui发现非常卡了
                                  然后我想着不是还有一个定时器没有开启吗,我就在void secondary_cpu_c_start(void)
                                  int timer_irq_number;
                                  timer_irq_number = 92;
                                  rt_hw_vector_init();
                                  rt_hw_spin_lock(&_cpus_lock);
                                  arm_gic_cpu_init(0, platform_get_gic_cpu_base());
                                  // arm_gic_set_cpu(0, timer_irq_number, 0x2); // timer1
                                  // timer1_init();
                                  //rt_hw_interrupt_install(timer_irq_number, rt_hw_timer1_isr, RT_NULL, "tick1");
                                  //rt_hw_interrupt_umask(timer_irq_number);
                                  rt_system_scheduler_start();
                                  这里把定时器2也开启了,现在发现之前开启的那个定时器1中断不进去了,进去的都是定时器2的中断,gui的任务夜跑不起来了,也就是说我在second cpu里面在开启一个定时器就不正常了,找了资料说smp需要开启2个定时器,为什么我这里开启2个定时器之后,前面那个定时器中断进不去了呢,然后我把second cpu的定时器关闭,性能上也达到了双核的提升了呀,因为我如果禁止smp,那么性能比较差的明显的,我现在迷糊了,定时器到底要不要开启2个,能否讲解一下这方面的疑惑,非常感谢
                                  • Referenced by  A abcdef
