    全志a83t,h8不能引导求助
    5030
    • Steve
      Steve LV 3 最后由 编辑
      如题,使用uboot源码编译获得的u-boot-with-spl.bin写入emmc或sd卡8k的位置上无法引导,同时,编译获得的二进制文件可以使用sunxi-fel的uboot命令在板子上面运行,使用emmc原本的引导程序,上电输出hello boot0 is starting 这段程序执行完后跳到u-boot-2011版本继续执行引导内核的任务
        有没有什么报错信息,或者截图?
        Steve 2 条回复 最后回复 回复 引用 分享 0
        • Steve
          Steve LV 3 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 将uboot-2018烧写到emmc过后,上电直接进fel模式,用sunxi-fel启动uboot-2018功能一切正常,能识别各种设备,包括emmc,但是用2018年版本后的uboot,就不能正常识别emmc了,用的defconfig是cubietruck_plus的
          • Steve
            @yuzukitsuru
            HELLO! BOOT0 is starting!
            boot0 version : 4.0.0
            boot0 commit : 8ed29e2e331aff49cfcfb8c34edb3e7691fbf09b
            rtc[1] value = 0x00010000
            rtc[2] value = 0x00020000
            rtc[3] value = 0x00030000
            DRAM DRIVE INFO: V1.40
            DRAM normal_mode value: 00000001
            rsb_send_initseq: rsb clk 400Khz -> 3Mhz
            PMU: AXP81X
            ddr voltage = 1500 mv
            ID CHECK VERSION: V0.3
            ic use default id
            using axp AXP818
            DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
            DRAM CLK =672 MHZ
            DRAM zq value: 00003bfb
            dram size =1024
            card boot number = 2
            card no is 2
            sdcard 2 line count 8
            [mmc]: mmc driver ver 2015-04-13 16:05:39
            [mmc]: ***Try SD card 2***
            [mmc]: mmc 2 cmd 8 err 00000100
            [mmc]: mmc 2 send if cond failed
            [mmc]: mmc 2 cmd 55 err 00000100
            [mmc]: mmc 2 send app cmd failed
            [mmc]: ***Try MMC card 2***
            [mmc]: mmc re-update_phase
            [mmc]: 8bit ddr!!!
            [mmc]: MMC ver 4.0
            [mmc]: SD/MMC Card: 8bit, capacity: 7456MB
            [mmc]: vendor: Man 0090014a Snr a152b9a5
            [mmc]: product: H8G4a
            [mmc]: revision: 9.2
            [mmc]: ***SD/MMC 2 init OK!!!***
            sdcard 2 init ok
            The size of uboot is 000f4000.
            sum=8d878146
            src_sum=8d878146
            set_mmc_para,sdly 50M 0
            set_mmc_para,sdly 25M 0
            Succeed in loading uboot from sdmmc flash.
            Ready to disable icache.
            Jump to secend Boot.
            [      0.262]MODE
            U-Boot 2011.09-rc1-00000-g8ed29e2-dirty (Jul 08 2017 - 11:36:38) Allwinner Technology
            这是原机程序启动的一些串口信息
            U-Boot SPL 2018.11 (Dec 15 2021 - 22:15:16 +0800)
            DRAM: 1024 MiB
            Trying to boot from FEL
            U-Boot 2018.11 (Dec 15 2021 - 22:15:16 +0800) Allwinner Technology
            CPU:   Allwinner A83T (SUN8I 1673)
            Model: Cubietech Cubietruck Plus
            I2C:   ready
            DRAM:  1 GiB
            MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
            Loading Environment from FAT... Unable to use mmc 1:1... In:    serial
            Out:   serial
            Err:   serial
            Net:   No ethernet found.
            starting USB...
            USB0:   A charger is plugged into the OTG: Port not available.
            USB1:   USB EHCI 1.00
            USB2:   USB EHCI 1.00
            scanning bus 0 for devices... 1 USB Device(s) found
            scanning bus 1 for devices... EHCI timed out on TD - token=0x80008d80
                  USB device not accepting new address (error=22)
                   scanning usb for storage devices... 0 Storage Device(s) found
            => mmcinfo
            Card did not respond to voltage select!
            => mmc dev 1
            switch to partitions #0, OK
            mmc1(part 0) is current device
            => mmcinfo
            Device: SUNXI SD/MMC
            Manufacturer ID: 90
            OEM: 14a
            Bus Speed: 52000000
            Mode : MMC High Speed (52MHz)
            Rd Block Len: 512
            MMC version 5.1
            High Capacity: Yes
            Capacity: 7.3 GiB
            Bus Width: 8-bit
            Erase Group Size: 512 KiB
            HC WP Group Size: 4 MiB
            User Capacity: 7.3 GiB WRREL
            Boot Capacity: 4 MiB ENH
            RPMB Capacity: 4 MiB ENH
            这是我自己编译的uboot2018版本使用sunxi-fel工具启动时的串口信息
            • G
              gamecss LV 2 最后由 编辑
              想问一下dalao A83T平台的sdk在哪里找啊?想给老平板搞个新一点的安卓但是网上只能找到5.1.1 r13,编译出来一堆bug
