    【WhyCan YuzukiHD联合出品】R11 86 面板
    A Series
    9
    17
    12170
      柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
        原理图:SCH_R11_86_Panel_2022-05-10.pdf
        Gerber:4509cffe-4971-4f8b-bbf7-65970f8d6d11-Gerber_PCB1_2022-06-18.zip
        立创EDA专业版工程文件:cf5cf19a-e977-4e9f-be5b-988c5bbf3709-ProProject_R11+86Panel_2022-06-18.zip
        适配了 Kernel: 5.4.180 U-Boot 2022.01
        SDK: https://github.com/YuzukiHD/Buildroot-YuzukiSBC
        SDK开发文档:https://yuzukihd.gloomyghost.com/Buildroot-YuzukiSBC/#/
        选择yuzukihd_r11_86panel_defconfig
        • U
          ubuntu LV 7 最后由 编辑
          坐等原理图PCB和SDK
            jiangh LV 3 最后由 编辑
            那么问题来了,屏幕从哪来呢
              测试驱动屏幕
                屏幕是在UBOOT进行初始化的,初始化代码:
                #ifndef _LCD_PANEL_INIT_H_
                #define _LCD_PANEL_INIT_H_
                #include <asm/gpio.h>
                #include <asm/arch/gpio.h>
                #define DELAYBIT 10
                #define YS_LOG(fmt, arg...)        \
                	do {        \
                		printf(fmt, ##arg);        \
                	} while (0)
                #define YS_DBG(fmt, arg...) YS_LOG("[Yuzuki LCD sSPI] " fmt, ##arg)
                #define st7701s_spi_sdi_0 gpio_direction_output(LCD_MOSI, 0)
                #define st7701s_spi_sdi_1 gpio_direction_output(LCD_MOSI, 1)
                #define st7701s_spi_scl_0 gpio_direction_output(LCD_CLK, 0)
                #define st7701s_spi_scl_1 gpio_direction_output(LCD_CLK, 1)
                int LCD_RST; // PG10
                int LCD_MOSI; // PG11
                int LCD_CLK; // PG12
                int LCD_BL; // PG12
                void lcd_delay_ms(int ms)
                	unsigned long long delay = ms * 1000 * 20;
                	while (delay--)
                		asm volatile("nop");
                void sunxi_lcd_delay_us(int us)
                	unsigned long long delay = 100 * us;
                	while (delay--)
                int SPI_Init(void)
                	int ret;
                	LCD_RST = sunxi_name_to_gpio("PG10");
                	if (LCD_RST < 0) {
                		YS_DBG("Error invalid LCD RST pin: PG, err %d\n", LCD_RST);
                		return LCD_RST;
                	ret = gpio_request(LCD_RST, "LCD_RST");
                	if (ret) {
                		YS_DBG("Error invalid LCD_RST pin: PG, err %d\n", LCD_RST);
                		return ret;
                	YS_DBG("PG10 --> LCD_RST request OK\n");
                	LCD_MOSI = sunxi_name_to_gpio("PG11");
                	if (LCD_MOSI < 0) {
                		YS_DBG("Error invalid LCD_MOSI pin: PG, err %d\n", LCD_MOSI);
                		return LCD_MOSI;
                	ret = gpio_request(LCD_MOSI, "LCD_MOSI");
                	if (ret) {
                		return ret;
                	YS_DBG("PG11 --> LCD_MOSI request OK\n");
                	LCD_CLK = sunxi_name_to_gpio("PG12");
                	if (LCD_CLK < 0) {
                		YS_DBG("Error invalid LCD_CLK pin: PG, err %d\n", LCD_CLK);
                		return LCD_CLK;
                	ret = gpio_request(LCD_CLK, "LCD_CLK");
                	if (ret) {
                		return ret;
                	YS_DBG("PG12 --> LCD_CLK request OK\n");
                	LCD_BL = sunxi_name_to_gpio("PB4");
                	if (LCD_BL < 0) {
                		YS_DBG("Error invalid LCD_CLK pin: PG, err %d\n", LCD_BL);
                		return LCD_BL;
                	ret = gpio_request(LCD_BL, "LCD_BL");
                	if (ret) {
                		YS_DBG("Error invalid LCD_BL pin: PG, err %d\n", LCD_BL);
                		return ret;
                	YS_DBG("PB4 --> LCD_BL request OK\n");
                	gpio_direction_output(LCD_RST, 1);
                	gpio_direction_output(LCD_MOSI, 1);
                	gpio_direction_output(LCD_CLK, 1);
                void LCD_WRITE_DATA(unsigned int value)
                	unsigned int i;
                	st7701s_spi_sdi_1;
                	st7701s_spi_scl_0;
                	sunxi_lcd_delay_us(10);
                	st7701s_spi_scl_1;
                	for (i = 0; i < 8; i++) {
                		if (value & 0x80)
                			st7701s_spi_sdi_1;
                			st7701s_spi_sdi_0;
                		value <<= 1;
                		st7701s_spi_scl_0;
                		st7701s_spi_scl_1;
                void LCD_WRITE_COMMAND(unsigned int value)
                	unsigned int i;
                	st7701s_spi_sdi_0;
                	st7701s_spi_scl_0;
                	st7701s_spi_scl_1;
                		if (value & 0x80)
                			st7701s_spi_sdi_1;
                			st7701s_spi_sdi_0;
                		st7701s_spi_scl_0;
                		st7701s_spi_scl_1;
                		value <<= 1;
                void LCD_Init(void)
                	YS_DBG("LCD Panel ST7701s init\n");
                	SPI_Init();
                	lcd_delay_ms(1000);
                	gpio_direction_output(LCD_RST, 0);
                	lcd_delay_ms(120);
                	lcd_delay_ms(120);
                	LCD_WRITE_COMMAND(0xFF);
                	LCD_WRITE_DATA(0x77);
                	LCD_WRITE_DATA(0x01);
                	LCD_WRITE_DATA(0x00);
                	LCD_WRITE_DATA(0x10);
                	LCD_WRITE_COMMAND(0xC0);
                	LCD_WRITE_DATA(0x3B);
                	LCD_WRITE_COMMAND(0xC1);
                	LCD_WRITE_DATA(0x0D);
                	LCD_WRITE_DATA(0x02);
                	LCD_WRITE_COMMAND(0xC2);
                	LCD_WRITE_DATA(0x21);
                	LCD_WRITE_DATA(0x08);
                	LCD_WRITE_COMMAND(0xCD);
                	LCD_WRITE_DATA(0x18); //0F 08-OK  D0-D18
                	LCD_WRITE_COMMAND(0xB0);
                	LCD_WRITE_DATA(0x11);
                	LCD_WRITE_DATA(0x0E);
                	LCD_WRITE_DATA(0x06);
                	LCD_WRITE_DATA(0x07);
                	LCD_WRITE_DATA(0x22);
                	LCD_WRITE_DATA(0x04);
                	LCD_WRITE_DATA(0x12);
                	LCD_WRITE_DATA(0x0F);
                	LCD_WRITE_DATA(0xAA);
                	LCD_WRITE_DATA(0x31);
                	LCD_WRITE_COMMAND(0xB1);
                	LCD_WRITE_DATA(0x19);
                	LCD_WRITE_DATA(0xA9);
                	LCD_WRITE_DATA(0x32);
                	LCD_WRITE_DATA(0x60);
                	LCD_WRITE_DATA(0x30);
                	LCD_WRITE_COMMAND(0xB2);
                	LCD_WRITE_DATA(0x87);
                	LCD_WRITE_COMMAND(0xB3);
                	LCD_WRITE_DATA(0x80);
                	LCD_WRITE_COMMAND(0xB5);
                	LCD_WRITE_DATA(0x49);
                	LCD_WRITE_COMMAND(0xB7);
                	LCD_WRITE_DATA(0x85);
                	LCD_WRITE_COMMAND(0xB8);
                	LCD_WRITE_DATA(0x78);
                	lcd_delay_ms(20);
                	LCD_WRITE_COMMAND(0xE0);
                	LCD_WRITE_DATA(0x1B);
                	LCD_WRITE_COMMAND(0xE1);
                	LCD_WRITE_DATA(0xA0);
                	LCD_WRITE_DATA(0x44);
                	LCD_WRITE_COMMAND(0xE2);
                	LCD_WRITE_DATA(0xED);
                	LCD_WRITE_DATA(0xEC);
                	LCD_WRITE_COMMAND(0xE3);
                	LCD_WRITE_COMMAND(0xE4);
                	LCD_WRITE_COMMAND(0xE5);
                	LCD_WRITE_DATA(0x0A);
                	LCD_WRITE_DATA(0xE9);
                	LCD_WRITE_DATA(0xD8);
                	LCD_WRITE_DATA(0x0C);
                	LCD_WRITE_DATA(0xEB);
                	LCD_WRITE_DATA(0xEF);
                	LCD_WRITE_COMMAND(0xE6);
                	LCD_WRITE_COMMAND(0xE7);
                	LCD_WRITE_COMMAND(0xE8);
                	LCD_WRITE_DATA(0x09);
                	LCD_WRITE_DATA(0xE8);
                	LCD_WRITE_DATA(0x0B);
                	LCD_WRITE_DATA(0xEA);
                	LCD_WRITE_DATA(0xEE);
                	LCD_WRITE_COMMAND(0xEB);
                	LCD_WRITE_DATA(0xE4);
                	LCD_WRITE_DATA(0x88);
                	LCD_WRITE_DATA(0x40);
                	LCD_WRITE_COMMAND(0xEC);
                	LCD_WRITE_DATA(0x3C);
                	LCD_WRITE_COMMAND(0xED);
                	LCD_WRITE_DATA(0xAB);
                	LCD_WRITE_DATA(0x89);
                	LCD_WRITE_DATA(0x76);
                	LCD_WRITE_DATA(0x54);
                	LCD_WRITE_DATA(0xFF);
                	LCD_WRITE_DATA(0x20);
                	LCD_WRITE_DATA(0x45);
                	LCD_WRITE_DATA(0x67);
                	LCD_WRITE_DATA(0x98);
                	LCD_WRITE_DATA(0xBA);
                	LCD_WRITE_COMMAND(0x3A);
                	LCD_WRITE_DATA(0x66);
                	LCD_WRITE_COMMAND(0x36);
                	LCD_WRITE_COMMAND(0x21);
                	LCD_WRITE_COMMAND(0x11);
                	lcd_delay_ms(120);
                	LCD_WRITE_COMMAND(0x29);
                	lcd_delay_ms(120);
                #endif // _LCD_PANEL_INIT_H_
                G 1 条回复 最后回复 回复 引用 分享 0
                • G
                  gregrgr LV 5 @YuzukiTsuru 最后由 编辑
                  @yuzukitsuru SPI刷屏 FPS能到多少
                    柚木 鉉 LV 9 @gregrgr 最后由 YuzukiTsuru 编辑
                    @gregrgr SPI初始化屏幕,设置屏幕参数模式,然后让屏幕进入RGB模式,使用RGB666刷屏.当然你也可以让屏幕进MIPI模式用MIPI刷。不是SPI刷屏,那不得慢死。测试刷720p的屏幕可以到60fps
                      终于等到了你!
                      A D 2 条回复 最后回复 回复 引用 分享 0
                        a32425262 LV 3 @whycan 最后由 编辑
                        @whycan 壳子哪里买的
                          douzi LV 2 @whycan 最后由 编辑
                          @whycan 有多余的板子吗?我也想玩
                            whycan晕哥 LV 9 @douzi 最后由 编辑
                            @douzi
                            目前我手里没有多余的,您可以自己打板焊接。
                            D 1 条回复 最后回复 回复 引用 分享 0
                              @whycan 打板和焊接都没问题,问题是就只有原理图我还得画板子,太慢了。
                              你那有PCB制板文件吗?
                                接上电源,显示屏正常,可是CP2104串口居然没有显示,折腾半天发现R67直接改成0R终于正常了.
                                E 1 条回复 最后回复 回复 引用 分享 0
                                • E
                                  emperg LV 4 @whycan 最后由 编辑
                                  @whycan 这个uboot初始化spi的代码要在uboot的哪个文件调用呢
                                    柚木 鉉 LV 9 @emperg 最后由 编辑
                                    @emperg
                                    H 1 条回复 最后回复 回复 引用 分享 0
                                      hle999 LV 1 @YuzukiTsuru 最后由 编辑
                                      @yuzukitsuru 发下屏的购买连接
                                      • Moved from 创龙科技专区 by  xiaowenge xiaowenge
