    T113-S3 ARM 及 DSP Benchmark
    7
    11
    12244
      yao0718 LV 3 最后由 YuzukiTsuru 编辑
      ARM 双核SMP ,系统 rtems5,主频 1.08G
       [/] # coremark
      2K performance run parameters for coremark.
      CoreMark Size    : 666
      Total ticks      : 12680
      Total time (secs): 12.680000
      Iterations/Sec   : 3154.574132
      Iterations       : 40000
      Compiler version : GCC7.5.0 20191114 (RTEMS 5, RSB 5.not_released, Newlib 7947581)
      Compiler flags   : -O2
      Memory location  : Please put data memory location here
                              (e.g. code in flash, data on heap etc)
      seedcrc          : 0xe9f5
      [0]crclist       : 0xe714
      [0]crcmatrix     : 0x1fd7
      [0]crcstate      : 0x8e3a
      [0]crcfinal      : 0x25b5
      Correct operation validated. See README.md for run and reporting rules.
      CoreMark 1.0 : 3154.574132 / GCC7.5.0 20191114 (RTEMS 5, RSB 5.not_released, Newlib 7947581) -O2 / Heap
       [/] # dhry 10000000
      Dhrystone Benchmark, Version 2.1 (Language: C)
      Program compiled without 'register' attribute
      Execution starts, 10000000 runs through Dhrystone
      Execution ends
      Final values of the variables used in the benchmark:
      Int_Glob:            5
              should be:   5
      Bool_Glob:           1
              should be:   1
      Ch_1_Glob:           A
              should be:   A
      Ch_2_Glob:           B
              should be:   B
      Arr_1_Glob[8]:       7
              should be:   7
      Arr_2_Glob[8][7]:    10000010
              should be:   Number_Of_Runs + 10
      Ptr_Glob->
        Ptr_Comp:          1080941968
              should be:   (implementation-dependent)
        Discr:             0
              should be:   0
        Enum_Comp:         2
              should be:   2
        Int_Comp:          17
              should be:   17
        Str_Comp:          DHRYSTONE PROGRAM, SOME STRING
              should be:   DHRYSTONE PROGRAM, SOME STRING
      Next_Ptr_Glob->
              should be:   (implementation-dependent), same as above
        Discr:             0
              should be:   0
        Enum_Comp:         1
              should be:   1
        Int_Comp:          18
              should be:   18
      Int_1_Loc:           5
              should be:   5
      Int_2_Loc:           13
              should be:   13
      Int_3_Loc:           7
              should be:   7
      Enum_Loc:            1
              should be:   1
      Str_1_Loc:           DHRYSTONE PROGRAM, 1'ST STRING
              should be:   DHRYSTONE PROGRAM, 1'ST STRING
      Str_2_Loc:           DHRYSTONE PROGRAM, 2'ND STRING
              should be:   DHRYSTONE PROGRAM, 2'ND STRING
      Microseconds for one run through Dhrystone:    0.3
      Dhrystones per Second:                      3527884.4
      DMIPS:                                      2007.90
       [/] # linpack 100
      Rolled Double Precision Linpack Benchmark - PC Version in 'C/C++'
      Compiler     rtems arm-rtems5-gcc 7.5.0 20191114
      Optimisation -O2
      norm resid      resid           machep         x[0]-1          x[n-1]-1
         1.7    7.41628980e-14   2.22044605e-16  -1.49880108e-14  -1.89848137e-14
      Times are reported for matrices of order          100
      1 pass times for array with leading dimension of  201
            dgefa      dgesl      total     Mflops       unit      ratio
          0.00519    0.00016    0.00535     128.35     0.0156     0.0955
      Calculating matgen overhead
             100 times   0.04 seconds
            1000 times   0.37 seconds
            2000 times   0.74 seconds
            4000 times   1.48 seconds
            8000 times   2.96 seconds
           16000 times   5.92 seconds
      Overhead for 1 matgen      0.00037 seconds
      Calculating matgen/dgefa passes for 5 seconds
             100 times   0.55 seconds
             200 times   1.09 seconds
             400 times   2.18 seconds
             800 times   4.36 seconds
            1600 times   8.72 seconds
      Passes used        917
      Times for array with leading dimension of 201
          0.00508    0.00016    0.00524     131.12     0.0153     0.0935
          0.00508    0.00016    0.00524     131.11     0.0153     0.0935
          0.00508    0.00016    0.00524     131.13     0.0153     0.0935
      Average                               131.12
      Calculating matgen2 overhead
      Times for array with leading dimension of 200
          0.00508    0.00016    0.00523     131.22     0.0152     0.0934
          0.00508    0.00016    0.00523     131.21     0.0152     0.0935
      Average                               131.21
      Rolled Double  Precision      131.12 Mflops
      **hifi4 dsp  ,主频600M,系统 freertos**
      Execution ends
      Int_Glob:            5
              should be:   5
      Bool_Glob:           1
              should be:   1
      Ch_1_Glob:           A
              should be:   A
      Ch_2_Glob:           B
              should be:   B
      Arr_1_Glob[8]:       7
              should be:   7
      Ptr_Glob->
        Ptr_Comp:          933400000
        Discr:             0
              should be:   0
        Enum_Comp:         2
              should be:   2
        Int_Comp:          17
              should be:   17
      Next_Ptr_Glob->
        Ptr_Comp:          933400000
        Discr:             0
              should be:   0
        Enum_Comp:         1
              should be:   1
        Int_Comp:          18
              should be:   18
      Int_1_Loc:           5
              should be:   5
      Int_2_Loc:           13
              should be:   13
      Int_3_Loc:           7
              should be:   7
      Enum_Loc:            1
              should be:   1
      Microseconds for one run through Dhrystone:    0.8
      Dhrystones per Second:                      1243935.8
      DMIPS:                                      707.99
      Compiler     xtensa hifi4 dsp xtensa-elf-gcc 10.2
      Optimisation -O2
          0.07600    0.00300    0.07900       8.69     0.2301     1.4107
             100 times   0.43 seconds
             200 times   0.85 seconds
             400 times   1.70 seconds
             800 times   3.41 seconds
            1600 times   6.81 seconds
      Overhead for 1 matgen      0.00426 seconds
             100 times   8.05 seconds
      Passes used         62
          0.07621    0.00231    0.07851       8.75     0.2287     1.4021
      Average                                 8.75
          0.07629    0.00231    0.07860       8.74     0.2289     1.4035
          0.07627    0.00232    0.07860       8.74     0.2289     1.4035
      Average                                 8.74
      Rolled Double  Precision        8.74 Mflops
      CoreMark Size    : 666
      Total ticks      : 16258
      Total time (secs): 16.258000
      Iterations/Sec   : 1414.688154
      Iterations       : 23000
      Compiler version : GCC10.2.0
      Memory location  : STACK
      seedcrc          : 0xe9f5
      [0]crclist       : 0xe714
      [0]crcfinal      : 0xd340
      CoreMark 1.0 : 1414.688154 / GCC10.2.0 -O2 / STACK
      目前hifi dsp采用的自编译的gcc编译器,采用R528 SDK提供的指令集,对linpack的跑分存疑,谁有candence explore能否跑个分比对下,谢谢
      Q 1 条回复 最后回复 回复 引用 分享 1
      • aozima
        aozima LV 7 最后由 编辑
        这个赞!
        dsp的gcc可以拿来玩吗?只有基本指令还是有部分DSP指令?
          yao0718 LV 3 最后由 编辑
          玩没问题,可以直接链接xcc的库文件(包含在R528的SDK中),这样可以解决math库中TIE指令和SIMD的问题,,用GCC直接编译的newlib的math库没有SIMD指令,具体版权问题需要咨询全志SDK中的二进制库文件在GCC中使用是否侵权
            yao0718 LV 3 最后由 编辑
            xtensa-hifidsp-gcc.tar.bz2
            仅用于学习及研究目的,不提供任何保证,商业用途请联系全志购买candence explore
            C库的头文件已经被替换为SDK中XCLIB的头文件,如要使用newlib请自行重新编译安装newlib
            A 1 条回复 最后回复 回复 引用 分享 1
            • aozima
              aozima LV 7 最后由 编辑
              好耶,又可以学习新知识了!
              • U
                Unturned3 LV 6 最后由 编辑
                请问大佬是怎么把 rtems 搬到 T113 上去的?
                  yao0718 LV 3 最后由 编辑
                  自己写个RTEMS的bsp就可以了,大部分驱动在freebsd中有,稍微修改下添加到libbsd中可以直接工作
                  • Q
                    qq1847123212 LV 3 @yao0718 最后由 编辑
                    @yao0718 提供的这个环境,是直接带工具链的吗?有没有简易的使用说明?
                      adaofu01 LV 2 @yao0718 最后由 编辑
                      @yao0718 个人用途的HIFI4 DSP GCC是怎么搞到的?联系candence还是联系全志?
                        柚木 鉉 LV 9 @adaofu01 最后由 编辑
                        @adaofu01 人家大佬自己搓的
                        • audiomonster
                          audiomonster LV 3 最后由 编辑
                          @yuzukitsuru 全志
