    busybox-init 改为 procd-init 报错
      mhcsoft LV 5 最后由 编辑
      全志F133 Tina sdk 由 busybox-init 改为 procd-init 升级后开机报错如下:
      碰到过并解决了这个问题得童靴吗。
      sunxi-audio-card 20340a0.sounddaudio2: use dummy codec for simple card.
      sunxi-audio-card 20340a0.sounddaudio2: snd-soc-dummy-dai <-> 2034000.daudio mapping ok
      sun8iw20-pinctrl 2000000.pinctrl: pin PB6 already requested by 2034000.daudio; cannot claim for 2000000.pinctrl:38
      sun8iw20-pinctrl 2000000.pinctrl: pin-38 (2000000.pinctrl:38) status -22
      ERR: id gpio_request failed
      cfg80211: Loading compiled-in X.509 certificates for regulatory database
      cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      ALSA device list:
        #0: audiocodec
        #1: snddaudio2
      alloc_fd: slot 0 not NULL!
      EXT4-fs (mmcblk0p5): mounted filesystem without journal. Opts: (null)
      VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
      devtmpfs: mounted
      Freeing unused kernel memory: 172K
      This architecture does not have kernel memory protection.
      Run /sbin/init as init process
      can't run '/etc/init.d/rcS': No such file or directory
      Please press Enter to activate trandom: fast init done
      can't open /dev/tts/0: No such file or directory
        柚木 鉉 LV 9 @mhcsoft 最后由 编辑
        @mhcsoft 配置下inittab里的绑定,busybox和procd不太一样
        M 1 条回复 最后回复 回复 引用 分享 0
          mhcsoft LV 5 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 嗯,改了一堆menuconfig 配置可以了
