    淘宝抓了只烂麻雀-mq
    5
    10
    6722
      mhcsoft LV 5 最后由 编辑
      淘宝买的小麻雀到了,可是飞不起来!
      自己调试发现wifi不通,搜不到网络
      用论坛上晕哥的固件也不行,仔细看打印发现问题所在。
      [   30.588715] FF
      [   30.590681] FF
      [   30.594518] RTL871X: 0x1f0:
      [   30.594523] FF
      [   30.597730] FF
      [   30.599673] FF
      [   30.601639] FF
      [   30.603619] FF
      [   30.605567] FF
      [   30.607512] FF
      [   30.609457] FF
      [   30.611402] FF
      [   30.613714] FF
      [   30.615664] FF
      [   30.617608] FF
      [   30.619553] FF
      [   30.621498] FF
      [   30.623476] FF
      [   30.625445] FF
      [   30.629236]
      [   30.630970] RTL871X: rtw_read_efuse_from_file /system/etc/wifi/wifi_efuse_8189fs.map is not readable
      [   30.641259] RTL871X: ERROR invalid phy efuse and read from file fail, will use driver default!!
      [   30.651061] RTL871X: EEPROM ID(0xffff) is invalid!!
      [   30.656614] RTL871X: rtw_read_macaddr_from_file /data/wifimac.txt is not readable
      [   30.665086] RTL871X: [A] 2G G00 CCK-1T base:34 from IC_DEF
      [   30.671230] RTL871X: [A] 2G G01 CCK-1T base:34 from IC_DEF
      [   30.677405] RTL871X: [A] 2G G02 CCK-1T base:34 from IC_DEF
      [   30.683591] RTL871X: [A] 2G G03 CCK-1T base:34 from IC_DEF
      [   30.689705] RTL871X: [A] 2G G04 CCK-1T base:34 from IC_DEF
      [   30.695900] RTL871X: [A] 2G G05 CCK-1T base:34 from IC_DEF
      [   30.702015] RTL871X: [A] 2G G00 BW40-1S base:39 from IC_DEF
        wifi_efuse_8189fs.map is not readable 传说中的efuse被冲了?
        whycan M 2 条回复 最后回复 回复 引用 分享 0
          whycan晕哥 LV 9 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru
          还有这事😧 😧 😧
            allspace123 LV 4 最后由 编辑
            请问这说的是MQ-Dual吗?
            M 1 条回复 最后回复 回复 引用 分享 0
              @whycan 听好多大佬说会这样
                mhcsoft LV 5 @YuzukiTsuru 最后由 编辑
                @yuzukitsuru 确实被冲了,听说螃蟹残电启动容易出这个问题
                  mhcsoft LV 5 @allspace123 最后由 编辑
                  • mangogeek
                    mangogeek LV 8 @mhcsoft 最后由 编辑
                    @mhcsoft 固件传上来,然后板子在淘宝申请换货就行。
                    bj这两天封了,周一处理
                      mhcsoft LV 5 @mangogeek 最后由 编辑
                      @mangogeek tina_d1s-mq_uart0.img
                        mhcsoft LV 5 最后由 编辑
                        淘宝买了几块 8189fs 模块,通过风枪换上去 ,现在wifi模块已经正常了
