    R528LVDS接口输出怎么配置,在设备树里面配置了,感觉没有效果呀?
    5
    14
    11547
      wyljkl LV 7 最后由 whycan 编辑
      &disp {
      	dev0_output_mode         = <1>;
      	fb0_format               = <10>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_backlight       = <50>;
      	lcd_if              = <3>;
      	lcd_x               = <800>;
      	lcd_y               = <600>;
      	lcd_width           = <150>;
      	lcd_height          = <94>;
      	lcd_dclk_freq       = <40>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_pol         = <1>;
      	lcd_pwm_max_limit   = <255>;
      	/*lcd_bl_en           = <&pio PD 20 GPIO_ACTIVE_HIGH>;*/
      	lcd_hbp             = <46>;
      	lcd_ht              = <1501>;
      	lcd_hspw            = <10>;
      	lcd_vbp             = <23>;
      	lcd_vt              = <1270>;
      	lcd_vspw            = <5>;
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <1>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <0>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	pinctrl-0 = <&lvds0_pins_a>;
      	pinctrl-1 = <&lvds0_pins_b>;
      麻烦各位帮忙看看,感谢
      Goodwill1945 1 条回复 最后回复 回复 引用 分享 0
      • Goodwill1945
        Goodwill1945 LV 3 @wyljkl 最后由 编辑
        @wyljkl 解决了老哥?当时点亮了不?我也在搞R528
        W 1 条回复 最后回复 回复 引用 分享 0
          wyljkl LV 7 @Goodwill1945 最后由 编辑
          @goodwill1945 当时整亮了,硬件问题,但是现在好久了,也没在之前的公司了。
          这是当时的lcd配置,你可以参考一下,:
          &lcd0 {
          lcd_used = <1>;
          			lcd_if              = <3>;
          			lcd_x               = <800>;
          			lcd_y               = <600>;
          			lcd_width           = <150>;
          			lcd_height          = <94>;
          			lcd_pwm_used        = <1>;
          			lcd_pwm_ch          = <7>;
          			lcd_pwm_pol         = <1>;
          			lcd_hbp             = <46>;
          			lcd_ht              = <1501>;
          			lcd_hspw            = <10>;
          			lcd_vbp             = <23>;
          			lcd_vt              = <1270>;
          			lcd_vspw            = <5>;
                                      lcd_lvds_if         = <0>;
          			lcd_frm             = <1>;
          			lcd_gamma_en        = <0>;
          			lcd_cmap_en         = <0>;
          			deu_mode            = <0>;
          			smart_color         = <90>;
          Goodwill1945 3 条回复 最后回复 回复 引用 分享 0
          • Goodwill1945
            @wyljkl 感谢回复,除了设备树还要改别的不?
            • Goodwill1945
              @wyljkl 公司名字我肯定能猜对,有兴趣私聊下不?
              • Goodwill1945
                @wyljkl 看你交接文档受益良多,祝前程似锦。我只改设备树是点不亮的。不过现在也不做这个了无所谓了
                xiaowenge W 2 条回复 最后回复 回复 引用 分享 0
                  DOT小文哥 LV 8 @Goodwill1945 最后由 编辑
                  @goodwill1945 在 R528LVDS接口输出怎么配置,在设备树里面配置了,感觉没有效果呀? 中说:
                  哈哈哈,这居然都遇到了,圈子好小
                  • Goodwill1945
                    Goodwill1945 LV 3 @xiaowenge 最后由 编辑
                    @xiaowenge 哈哈, r528资料太少,网上一搜就这点东西。萌新坐了一个月的牢终于解放了
                      HQEmbed LV 6 最后由 编辑
                      R528跟T113差不多,基本参考它就行。
                      LVDS好搞,如果参数不行,把分辨率改了后,直接用以前OK的时序先顶上调调看。
                      • Goodwill1945
                        Goodwill1945 LV 3 @HQEmbed 最后由 编辑
                        @hqembed RGB屏幕换成LVDS只需要修改设备树吗?我的设备树参数是对的但就是点不亮,不知道是不是tina-linux有什么别的机制还是有什么Bug,文档里也没说
                          HQEmbed LV 6 最后由 whycan 编辑
                          对的,改default_lcd就行了,我贴几个验证过的lvds屏你参考下
                          /* lvds 1280x400
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_backlight       = <255>;	//166mA*255/166mA = 255
                          	lcd_if              = <3>;
                          	lcd_x               = <1280>;
                          	lcd_y               = <400>;
                          	lcd_width           = <179>;
                          	lcd_height          = <56>;
                          	lcd_dclk_freq       = <38>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_pwm_freq        = <20000>;
                          	lcd_pwm_pol         = <1>;	//1:negative
                          	lcd_bl_en = <&pio PE 17 GPIO_ACTIVE_HIGH>;
                          	lcd_hbp             = <21>;
                          	lcd_ht              = <1364>;
                          	lcd_hspw            = <1>;
                          	lcd_vbp             = <46>;
                          	lcd_vt              = <469>;
                          	lcd_vspw            = <1>;
                          	lcd_lvds_if         = <0>;
                          	lcd_lvds_colordepth = <0>;	//0:8bit 1:6bit
                          /* lvds 1024x600 8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_if              = <3>;
                          	lcd_x               = <1024>;
                          	lcd_y               = <600>;
                          	lcd_width           = <176>;
                          	lcd_height          = <99>;
                          	lcd_dclk_freq       = <51>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <164>;
                          	lcd_ht              = <1344>;
                          	lcd_hspw            = <4>;
                          	lcd_vbp             = <15>;
                          	lcd_vt              = <635>;
                          	lcd_vspw            = <4>;
                          	lcd_lvds_if         = <0>;
                          /* lvds 1024x768 8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_backlight       = <0>;	//130mA*255/166mA = 200
                          	lcd_if              = <3>;
                          	lcd_x               = <1024>;
                          	lcd_y               = <768>;
                          	lcd_width           = <162>;
                          	lcd_height          = <121>;
                          	lcd_dclk_freq       = <65>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <162>;
                          	lcd_ht              = <1344>;
                          	lcd_hspw            = <4>;
                          	lcd_vbp             = <26>;
                          	lcd_vt              = <806>;
                          	lcd_vspw            = <4>;
                          	lcd_lvds_if         = <0>;
                          /* lvds 800x1280 8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_backlight       = <135>;	//88mA*255*166mA = 135
                          	lcd_if              = <3>;
                          	lcd_x               = <800>;
                          	lcd_y               = <1280>;
                          	lcd_width           = <135>;
                          	lcd_height          = <216>;
                          	lcd_dclk_freq       = <68>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <40>;
                          	lcd_ht              = <860>;
                          	lcd_hspw            = <20>;
                          	lcd_vbp             = <24>;
                          	lcd_vt              = <1330>;
                          	lcd_vspw            = <4>;
                          	lcd_lvds_if         = <0>;
                          /* LVDS 1280x800 8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_if              = <3>;
                          	lcd_x               = <1280>;
                          	lcd_y               = <800>;
                          	lcd_width           = <150>;
                          	lcd_height          = <94>;
                          	lcd_dclk_freq       = <71>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <20>;
                          	lcd_ht              = <1418>;
                          	lcd_hspw            = <10>;
                          	lcd_vbp             = <10>;
                          	lcd_vt              = <814>;
                          	lcd_vspw            = <5>;
                          	lcd_lvds_if         = <0>;
                          /* LVDS 1280x720 8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_backlight       = <255>;	//166mA*255*166mA = 255
                          	lcd_if              = <3>;
                          	lcd_x               = <1280>;
                          	lcd_y               = <720>;
                          	lcd_width           = <176>;
                          	lcd_height          = <99>;
                          	lcd_dclk_freq       = <64>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <32>;
                          	lcd_ht              = <1340>;
                          	lcd_hspw            = <5>;
                          	lcd_vbp             = <38>;
                          	lcd_vt              = <792>;
                          	lcd_vspw            = <5>;
                          	lcd_lvds_if         = <0>;
                          /* lvds 1366x768 6bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_if              = <3>;
                          	lcd_x               = <1366>;
                          	lcd_y               = <768>;
                          	lcd_width           = <344>;
                          	lcd_height          = <193>;
                          	lcd_dclk_freq       = <69>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <80>;
                          	lcd_ht              = <1478>;
                          	lcd_hspw            = <32>;
                          	lcd_vbp             = <12>;
                          	lcd_vt              = <782>;
                          	lcd_vspw            = <4>;
                          	lcd_lvds_if         = <0>;
                          	lcd_lvds_colordepth = <1>;	//0:8bit 1:6bit
                          	lcd_frm             = <1>;	//1:enable rgb666 dither
                          /* lvds 1920x360 2x8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_if              = <3>;
                          	lcd_x               = <1920>;
                          	lcd_y               = <360>;
                          	lcd_width           = <597>;
                          	lcd_height          = <112>;
                          	lcd_dclk_freq       = <148>;	//Double
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <40>;
                          	lcd_ht              = <2200>;
                          	lcd_hspw            = <20>;
                          	lcd_vbp             = <15>;
                          	lcd_vt              = <1125>;
                          	lcd_vspw            = <5>;
                          	lcd_lvds_if         = <1>;	//0:single lvds 1:dual lvds
                          /* lvds 1920x720 2x8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_if              = <3>;
                          	lcd_x               = <1920>;
                          	lcd_y               = <720>;
                          	lcd_width           = <292>;
                          	lcd_height          = <109>;
                          	lcd_dclk_freq       = <90>;	//Double
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <40>;
                          	lcd_ht              = <1980>;
                          	lcd_hspw            = <20>;
                          	lcd_vbp             = <15>;
                          	lcd_vt              = <745>;
                          	lcd_vspw            = <5>;
                          	lcd_lvds_mode       = <1>;	//0:NS mode; 1:JEIDA mode  1 for C123HAX02.2
                          /* lvds 1920x1080 2x6bit 2x8bit
                          &lcd0 {
                          	lcd_used            = <1>;
                          	lcd_if              = <3>;
                          	lcd_x               = <1920>;
                          	lcd_y               = <1080>;
                          	lcd_width           = <344>;
                          	lcd_height          = <193>;
                          	lcd_dclk_freq       = <142>;
                          	lcd_pwm_used        = <1>;
                          	lcd_pwm_ch          = <7>;
                          	lcd_hbp             = <142>;
                          	lcd_ht              = <2142>;
                          	lcd_hspw            = <32>;
                          	lcd_vbp             = <11>;
                          	lcd_vt              = <1100>;
                          	lcd_vspw            = <6>;
                          	lcd_frm             = <0>;	//1:enable rgb666 dither
                          Goodwill1945 L 2 条回复 最后回复 回复 引用 分享 0
                          • Goodwill1945
                            @hqembed 谢谢大佬👍
                              @goodwill1945 不是吧,有这么巧的吗,如果确实是的,那我留下了调试笔记,照着来问题不大的呢,r528走之前LVDS是整完了的。
                                liuxingkeji LV 5 @HQEmbed 最后由 编辑
                                @hqembed 试了两个参数,亮了两个屏,参数应该都是准的,厉害
