    D1-H 使用内置FANOUT REFCLK 24M时钟扫到卡但是无法下载固件
    9430
      柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
      [   15.763263][   15.763263] ======== XRADIO WIFI OPEN ========
      [   15.770569][   15.770569] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [   15.779230][   15.779230] [XRADIO] Allocated hw_priv @ (____ptrval____)
      [   15.788116][   15.788116] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [   15.806534][   15.806534] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [   16.158083][   16.158083] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.170922][   16.170922] [XRADIO] Detect SDIO card 1
      [   16.181998][   16.181998] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   16.209670][   16.209670] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.233815][   16.233815] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.252653][   16.252653] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.279628][   16.279628] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   16.293081][   16.293081] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   16.306785][   16.306785] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [   16.324944][   16.324944] mmc2: new high speed SDIO card at address 0001
      [   16.343747][   16.343747] [SBUS] XRadio Device:sdio clk=50000000
      [   16.360502][   16.360502] [XRADIO] XRADIO_HW_REV 1.0 detected.
      [   16.483883][   16.483883] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
      [   16.593457][   16.593457] [XRADIO] Bootloader complete
      [   17.138413][   17.138413] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [   17.571269][   17.571269] [XRADIO_ERR] xradio_firmware: wait for download completion failed. Read: 0xFFFFFFFF
      [   17.594485][   17.594485] [XRADIO_ERR] xradio_load_firmware: can't download firmware.
      [   17.603764][   17.603764] [XRADIO_ERR] xradio_load_firmware failed(-110).
      [   17.613037][   17.613037] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [   17.748248][   17.748248] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   17.756403][   17.756403] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   17.764552][   17.764552] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   17.772665][   17.772665] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   17.781030][   17.781030] mmc2: card 0001 removed
      [   17.786530][   17.786530] [XRADIO] Remove SDIO card 1
      [   17.792516][   17.792516] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   17.828132][   17.828132] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   17.849201][   17.849201] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   17.859197][   17.859197] xradio_core_init failed (-110)!
      [   17.878141][   17.878141] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   17.904007][   17.904007] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      [   17.913008][   17.913008] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      [   17.921267][   17.921267] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   17.937887][   17.937887] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   17.953800][   17.953800] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   17.963051][   17.963051] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   17.972010][   17.972010] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   17.980988][   17.980988] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   17.989171][   17.989171] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   18.009905][   18.009905] xt_time: kernel timezone is -0000
      [   18.032430][   18.032430] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
      [   19.788243][   19.788243] ======== XRADIO WIFI OPEN ========
      [   19.795187][   19.795187] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [   19.803393][   19.803393] [XRADIO] Allocated hw_priv @ (____ptrval____)
      [   19.813200][   19.813200] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [   19.840210][   19.840210] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [   20.050260][   20.050260] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.062758][   20.062758] [XRADIO] Detect SDIO card 1
      [   20.073213][   20.073213] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   20.093157][   20.093157] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.119383][   20.119383] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.135394][   20.135394] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.159295][   20.159295] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   20.172219][   20.172219] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   20.185470][   20.185470] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [   20.199392][   20.199392] mmc2: new high speed SDIO card at address 0001
      [   20.207730][   20.207730] [SBUS] XRadio Device:sdio clk=50000000
      [   20.223252][   20.223252] [XRADIO] XRADIO_HW_REV 1.0 detected.
      [   20.273703][   20.273703] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
      [   20.315910][   20.315910] [XRADIO] Bootloader complete
      [   21.014043][   21.014043] [XRADIO_ERR] xradio_firmware: wait for download completion failed. Read: 0xFFFFFFFF
      [   21.025220][   21.025220] [XRADIO_ERR] xradio_load_firmware: can't download firmware.
      [   21.034002][   21.034002] [XRADIO_ERR] xradio_load_firmware failed(-110).
      [   21.042814][   21.042814] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [   21.163655][   21.163655] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   21.171759][   21.171759] [XRADIO] Remove SDIO card 1
      [   21.171775][   21.171775] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   21.185540][   21.185540] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   21.193670][   21.193670] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 7, RTO !!
      [   21.202023][   21.202023] mmc2: card 0001 removed
      [   21.213388][   21.213388] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   21.231535][   21.231535] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.244107][   21.244107] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   21.254279][   21.254279] xradio_core_init failed (-110)!
      [   21.263169][   21.263169] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.299296][   21.299296] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      [   21.308775][   21.308775] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      [   21.317076][   21.317076] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      kmodloader done
      [   21.377217][   21.377217] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   21.405391][   21.405391] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   21.414360][   21.414360] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   21.423298][   21.423298] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   21.432228][   21.432228] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [   21.440382][   21.440382] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          量了一下好像内置REFCLK_OUT没有输出,但是我这个探头电容很大,可能会导致这个问题
            whycan晕哥 LV 9 @YuzukiTsuru 最后由 编辑
            @yuzukitsuru
            error 110: timeout
            降频试一试?
              柚木 鉉 LV 9 @whycan 最后由 YuzukiTsuru 编辑
              @whycan
              降速了好像也没有用
              io绑错了
              [   19.052197] ======== XRADIO WIFI OPEN ========
              [   19.057744] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
              [   19.064598] [XRADIO] Allocated hw_priv @ (____ptrval____)
              [   19.072289] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
              [   19.097764] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
              [   19.307190] sunxi_hosts[1] should not be null
              [   19.307197] [XRADIO] Detect SDIO card 1
              [   21.361925] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
              [   21.469153] sunxi_hosts[1] should not be null
              [   21.469161] [XRADIO] Remove SDIO card 1
              [   21.488339] [SBUS_ERR] sdio probe timeout!
              [   21.492954] [XRADIO_ERR] sbus_sdio_init failed
              [   21.499076] xradio_core_init failed (-110)!
                @yuzukitsuru
                示波器量下有没有24Mhz了,没有的话就找个有源晶振试一试。
                  柚木 鉉 LV 9 @whycan 最后由 编辑
                  @whycan
                  找了一个好的板子拆了晶振是这样的
                  root@TinaLinux:/lib/modules/5.4.61# insmod xr829.ko
                  [XRADIO_ERR] debugfs isnot initialized
                  [XRADIO] Allocated hw_priv @ 00000000e2194bdf
                  mmc1: new high speed SDIO card at address 0001
                  [XRADIO_ERR] xradio_load_firmware: Wait for wakeup:device is not responding.
                  [XRADIO_ERR] Device will restart at 1 times!
                  sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                  mmc1: card 0001 removed
                  [XRADIO_ERR] Device will restart at 2 times!
                  [XRADIO_ERR] Device will restart at 3 times!
                  ^C[XRADIO_ERR] xradio_load_firmware: Wait for wakeup:device is not responding.
                  [XRADIO_ERR] Device will restart at 4 times!
                  [XRADIO_ERR] xradio_register_bh failed(-4).
                  ^Csunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                  xradio_core_init failed (-4)!
                  sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                  sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    正常情况
                    [XRADIO] Allocated hw_priv @ 0000000035532399
                    [XRADIO] Firmware completed.
                    [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
                    [XRADIO] Firmware Startup Done.
                    [XRADIO_WRN] enable Multi-Rx!
                    ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
                      解决了,示波器测量发现过充,电阻解决
                      [   15.077675] ======== XRADIO WIFI OPEN ========
                      [   15.086009] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
                      [   15.093245] [XRADIO] Allocated hw_priv @ (____ptrval____)
                      [   15.101203] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                      [   15.119168] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                      [   15.289156] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
                      [   15.427605] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                      [   15.439043] [XRADIO] Detect SDIO card 1
                      [   15.461469] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                      [   15.491817] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                      [   15.525136] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                      [   15.540610] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                      [   15.567424] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                      [   15.579332] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                      [   15.591648] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                      [   15.605149] mmc2: new high speed SDIO card at address 0001
                      [   15.613632] [SBUS] XRadio Device:sdio clk=50000000
                      [   15.621530] [XRADIO] XRADIO_HW_REV 1.0 detected.
                      [   15.772529] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
                      [   15.927766] [XRADIO] Bootloader complete
                      [   16.099634] [XRADIO] Firmware completed.
                      [   16.105809] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
                      [   16.124345] [XRADIO] Firmware Startup Done.
                      [   16.129480] [XRADIO_WRN] enable Multi-Rx!
                      [   16.139231] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
                      [   16.169753] xt_time: kernel timezone is -0000
                        Apollo5520 LV 5 @YuzukiTsuru 最后由 编辑
                        @yuzukitsuru 你好,我现在调试xr829接d1-h 的 J2 REFCLK-OUT时钟输出脚,跟这个帖子里面的错误信息是一样的下载固件失败,现在用示波器也测不到cpu有24M时钟信号输出。(用外部24M晶振功能测试是好的)
                        后来你调好的时候有用示波器测到cpu有时钟信号输出吗?
                        软件dts文件里面是否需要做修改开启?
                        最后是串的多大的电阻?
                        谢谢!!
                          柚木 鉉 LV 9 @Apollo5520 最后由 编辑
                          @apollo5520 用1k电阻接地了
                            @yuzukitsuru 加了电阻还是不行,依旧测不到CPU有24M时钟输出信号,还有其他地方需要修改吗?
                              @apollo5520 测不到信号就不是这个问题了,加载驱动的时候默认会打开dxco。我那个问题是信号噪音过大的问题
