    f133 0.8 sdk代码编译报错
    6210
    • K
      kiwin LV 2 最后由 YuzukiTsuru 编辑
      f133 0.8 sdk编译报错如下(请问是否和服务器环境有关):
      编译环境:Ubuntu20.04
      make[4]: Entering directory '/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/compile_dir/host/cmake-3.4.3/Bootstrap.cmk'
      g++   -I/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/compile_dir/host/cmake-3.4.3/Bootstrap.cmk -I/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/compile_dir/host/cmake-3.4.3/Source   -I/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/compile_dir/host/cmake-3.4.3/Bootstrap.cmk  cmake.o cmakemain.o cmcmd.o cmCommandArgumentLexer.o cmCommandArgumentParser.o cmCommandArgumentParserHelper.o cmCommonTargetGenerator.o cmCPackPropertiesGenerator.o cmDefinitions.o cmDepends.o cmDependsC.o cmDocumentationFormatter.o cmPolicies.o cmProperty.o cmPropertyMap.o cmPropertyDefinition.o cmPropertyDefinitionMap.o cmMakeDepend.o cmMakefile.o cmExportFileGenerator.o cmExportInstallFileGenerator.o cmExportTryCompileFileGenerator.o cmExportSet.o cmExportSetMap.o cmExternalMakefileProjectGenerator.o cmGeneratorExpressionEvaluationFile.o cmGeneratedFileStream.o cmGeneratorTarget.o cmGeneratorExpressionContext.o cmGeneratorExpressionDAGChecker.o cmGeneratorExpressionEvaluator.o cmGeneratorExpressionLexer.o cmGeneratorExpressionNode.o cmGeneratorExpressionParser.o cmGeneratorExpression.o cmGlobalCommonGenerator.o cmGlobalGenerator.o cmInstallDirectoryGenerator.o cmLocalCommonGenerator.o cmLocalGenerator.o cmInstalledFile.o cmInstallGenerator.o cmInstallExportGenerator.o cmInstallFilesGenerator.o cmInstallScriptGenerator.o cmInstallTargetGenerator.o cmScriptGenerator.o cmSourceFile.o cmSourceFileLocation.o cmState.o cmSystemTools.o cmTestGenerator.o cmVersion.o cmFileTimeComparison.o cmGlobalUnixMakefileGenerator3.o cmLocalUnixMakefileGenerator3.o cmMakefileExecutableTargetGenerator.o cmMakefileLibraryTargetGenerator.o cmMakefileTargetGenerator.o cmMakefileUtilityTargetGenerator.o cmOutputConverter.o cmOSXBundleGenerator.o cmNewLineStyle.o cmBootstrapCommands1.o cmBootstrapCommands2.o cmCommandsForBootstrap.o cmTarget.o cmTest.o cmCustomCommand.o cmCustomCommandGenerator.o cmCacheManager.o cmListFileCache.o cmComputeLinkDepends.o cmComputeLinkInformation.o cmOrderDirectories.o cmComputeTargetDepends.o cmComputeComponentGraph.o cmExprLexer.o cmExprParser.o cmExprParserHelper.o cmListFileLexer.o Directory.o EncodingCXX.o FStream.o Glob.o RegularExpression.o SystemTools.o EncodingC.o ProcessUNIX.o String.o System.o Terminal.o -o cmake
      /usr/bin/ld: cmListFileLexer.o: relocation R_X86_64_32S against `.rodata' can not be used when making a PIE object; recompile with -fPIE
      /usr/bin/ld: ProcessUNIX.o: relocation R_X86_64_32 against `.rodata' can not be used when making a PIE object; recompile with -fPIE
      /usr/bin/ld: Terminal.o: relocation R_X86_64_32 against `.rodata' can not be used when making a PIE object; recompile with -fPIE
      collect2: error: ld returned 1 exit status
      make[4]: *** [Makefile:2: cmake] Error 1
      make[4]: Leaving directory '/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/compile_dir/host/cmake-3.4.3/Bootstrap.cmk'
      Error when bootstrapping CMake:
      Problem while running make
      Log of errors: /homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/compile_dir/host/cmake-3.4.3/Bootstrap.cmk/cmake_bootstrap.log
      make[3]: *** [Makefile:29: /homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/compile_dir/host/cmake-3.4.3/.configured] Error 9
      make[3]: Leaving directory '/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/tools/cmake'
      make[2]: *** [tools/Makefile:135: tools/cmake/compile] Error 2
      make[2]: Leaving directory '/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133'
      make[1]: *** [tools/Makefile:133: /homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/out/f133-evb1/staging_dir/target/stamp/.tools_install_yyyynyyynyyyyyyynnnyyyyyyyyyyynnyyyyyyyynyyynyyyyy] Error 2
      make[1]: Leaving directory '/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133'
      make: *** [/homeb/xiaoyuan.cai/sdk/allwinner/tina/f133/build/toplevel.mk:306: world] Error 2
      [2]   Done                    $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      [3]+  Done                    $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      #### make failed to build some targets (05:34 (mm:ss)) ####
      YuzukiTsuru whycan 2 条回复 最后回复 回复 引用 分享 0
        柚木 鉉 LV 9 @kiwin 最后由 YuzukiTsuru 编辑
        @kiwin
        感觉是HOST版本太高了,看看踩坑记录
        推荐 Ubuntu 16.04
        【加精】在Ubuntu21.04中编译Tina SDKV1.01 版本 踩坑记录
        https://bbs.aw-ol.com/topic/102/share/1
        K 1 条回复 最后回复 回复 引用 分享 0
        • K
          kiwin LV 2 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 我在同样的环境下编译哪吒的tina-D1-H sdk 1.0的版本是没问题的。
            柚木 鉉 LV 9 @kiwin 最后由 编辑
            @kiwin 那就可能是因为0.8版本sdk的bug了,换2.0版本的sdk吧
            • K
              @yuzukitsuru 2.0也编不过,比较怀疑是服务器环境问题
                @kiwin 有可能
                  whycan晕哥 LV 9 @kiwin 最后由 编辑
                  @kiwin
                  是不是 make -j4
                  试一试 make
                    柚木 鉉 LV 9 @whycan 最后由 编辑
                    @whycan
                    连接时报错,应该不是缺库
