    求教,关于LicheeRV 86 Panel在tina2.0配置lcd的问题
    6
    21
    15085
      lbuque LV 4 最后由 编辑
      设备树修改如下:
      project device/config/chips/d1-h/
      diff --git a/configs/nezha/linux-5.4/board.dts b/configs/nezha/linux-5.4/board.dts
      index 963aa17..fb8d344 100755
      --- a/configs/nezha/linux-5.4/board.dts
      +++ b/configs/nezha/linux-5.4/board.dts
      @@ -6,7 +6,6 @@
       /dts-v1/;
      -/memreserve/ 0x42000000 0x100000;  /* dsp used 1MB */
       #include "sun20iw1p1.dtsi"
      @@ -15,7 +14,6 @@
       	aliases {
       		dsp0 = &dsp0;
       		dsp0_gpio_int= &dsp0_gpio_int;
      -		gmac0 = &gmac0;
       	dsp0: dsp0 {
      @@ -31,7 +29,7 @@
       	reg_vdd_cpu: vdd-cpu {
      -		pwms = <&pwm 0 5000 1>;
      +		pwms = <&pwm 0 5000 0>;
       		regulator-name = "vdd_cpu";
      @@ -47,7 +45,15 @@
      -		gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
      +		enable-active-high;
      +	reg_3v3: vdd_3v3 {
      +		compatible = "regulator-fixed";
      +		regulator-name = "vdd_3v3";
      +		regulator-min-microvolt = <3300000>;
      +		regulator-max-microvolt = <3300000>;
      +		regulator-enable-ramp-delay = <1000>;
       		enable-active-high;
      @@ -234,62 +240,42 @@
       	gmac_pins_a: gmac@0 {
      -		       "PE4", "PE5", "PE6", "PE7",
      -		       "PE8", "PE9", "PE10", "PE11",
      -		       "PE12", "PE13", "PE14", "PE15";
      +				"PE4", "PE5", "PE6", "PE7",
      +				"PE8", "PE9";
       		function = "gmac0";
      -		muxsel = <8>; /* for uboot driver */
       		drive-strength = <10>;
       	gmac_pins_b: gmac@1 {
      +				"PE8", "PE9";
       		function = "gpio_in";
       	dmic_pins_a: dmic@0 {
       		/* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
      -		pins = "PE17", "PB11", "PB10", "PD17";
      +		pins = "PE17", "PB11";
       		function = "dmic";
       		drive-strength = <20>;
       		bias-disable;
       	dmic_pins_b: dmic@1 {
       		function = "io_disabled";
       		bias-disable;
       	daudio0_pins_a: daudio0@0 {
      -		/* MCLK, BCLK, LRCK */
      -		pins = "PE17", "PE16", "PE15";
      +		pins = "PE17", "PE16", "PE15", "PE14", "PE13";
       		function = "i2s0";
       		bias-disable;
      -	daudio0_pins_b: daudio0@1 {
      -		/* DIN0 */
      -		pins = "PE14";
      -		function = "i2s0_din";
      -		drive-strength = <20>;
      -		bias-disable;
      -	daudio0_pins_c: daudio0@2 {
      -		/* DOUT0 */
      -		pins = "PE13";
      -		function = "i2s0_dout";
      -		bias-disable;
      -	daudio0_pins_d: daudio0_sleep@0 {
      +	daudio0_pins_b: daudio0_sleep@0 {
      @@ -297,30 +283,13 @@
       	daudio1_pins_a: daudio1@0 {
      -		/* MCLK, LRCK, BCLK */
      -		pins = "PG11", "PG12", "PG13";
      +		pins = "PG11", "PG12", "PG13", "PG14", "PG15";
       		function = "i2s1";
       		bias-disable;
      -	daudio1_pins_b: daudio1@1 {
      -		/* DIN0 */
      -		pins = "PG14";
      -		function = "i2s1_din";
      -		bias-disable;
      -	daudio1_pins_c: daudio1@2 {
      -		/* DOUT0 */
      -		pins = "PG15";
      -		function = "i2s1_dout";
      -		bias-disable;
      -	daudio1_pins_d: daudio1_sleep@0 {
      +	daudio1_pins_b: daudio1_sleep@0 {
      @@ -374,7 +343,7 @@
       	spi0_pins_a: spi0@0 {
      -		pins = "PC2", "PC4", "PC5"; /* clk, mosi, miso */
      +		pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
       		function = "spi0";
       		muxsel = <2>;
      @@ -385,7 +354,7 @@
       		function = "spi0";
       		muxsel = <2>;
      -		bias-pull-up;   /* cs, hold, wp should be pulled up */
      +		bias-pull-up;   /* only CS should be pulled up */
       	spi0_pins_c: spi0@2 {
      @@ -396,16 +365,16 @@
       	spi1_pins_a: spi1@0 {
      -		pins = "PD11", "PD12", "PD13"; /* clk, mosi, miso */
      +		pins = "PD11", "PD12", "PD13","PD14", "PD15"; /*clk mosi miso hold wp*/
       		function = "spi1";
       	spi1_pins_b: spi1@1 {
      -		pins = "PD10", "PD14", "PD15";
      +		pins = "PD10";
       		function = "spi1";
      +		bias-pull-up;   // only CS should be pulled up
       	spi1_pins_c: spi1@2 {
      @@ -447,9 +416,9 @@
       	pwm2_pin_b: pwm2@1 {
       		pins = "PD18";
      -		function = "gpio_out";
      +		function = "gpio_in";
       	pwm7_pin_a: pwm7@0 {
       		pins = "PD22";
       		function = "pwm7";
      @@ -461,7 +430,6 @@
       		pins = "PD22";
       	s_cir0_pins_a: s_cir@0 {
       		pins = "PB12";
      @@ -486,6 +454,45 @@
       		pins = "PB0";
      +	rgb18_20_pins_a: rgb18_20@0 {
      +		pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      +				"PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      +				"PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      +				"PD18", "PD19", "PD20", "PD21";
      +		function = "lcd0";
      +		drive-strength = <20>;
      +		bias-disable;
      +	rgb18_20_pins_b: rgb18_20@1 {
      +		function = "io_disabled";
      +		bias-disable;
      +	rgb18_10_pins_a: rgb18_10@0 {
      +		drive-strength = <10>;
      +		bias-disable;
      +	rgb18_10_pins_b: rgb18_10@1 {
      +		bias-disable;
       &uart0 {
      @@ -510,11 +517,11 @@
       &uart3 {
      -	compatible = "allwinner,sun20iw1-dsp-uart";
      +	/*compatible = "allwinner,sun20iw1-dsp-uart";*/
       	pinctrl-0 = <&uart3_pins_a>;
       	pinctrl-1 = <&uart3_pins_a>;
      -	status = "okay";
      +	status = "disabled";
       &soc {
      @@ -557,12 +564,12 @@
       		chip_en;
       		power_en;
      -		pinctrl-0 = <&wlan_pins_a>;
      -		pinctrl-names = "default";
       		status        = "okay";
       		wlan: wlan@0 {
      +			pinctrl-0 = <&wlan_pins_a>;
      +			pinctrl-names = "default";
       			clock-names = "32k-fanout1";
       			wlan_busnum    = <0x1>;
      @@ -578,6 +585,8 @@
       		bt: bt@0 {
       			/*bt_power_num = <0x01>;*/
      @@ -590,13 +599,13 @@
      -	btlpm: btlpm@0 {
      +	/*btlpm: btlpm@0 {
       		uart_index  = <0x1>;
       		bt_wake     = <&pio PG 16 GPIO_ACTIVE_HIGH>;
       		bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
       		status      = "okay";
       	addr_mgt: addr_mgt@0 {
      @@ -826,8 +835,8 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
       	pcm_lrck_period = <0x80>;
       	slot_width_select = <0x20>;
      -	pinctrl-0       = <&daudio0_pins_a &daudio0_pins_b &daudio0_pins_c>;
      -	pinctrl-1       = <&daudio0_pins_d>;
      +	pinctrl-0       = <&daudio0_pins_a>;
      +	pinctrl-1       = <&daudio0_pins_b>;
       	pinctrl_used	= <0x0>;
      @@ -861,8 +870,8 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
      -	pinctrl-0       = <&daudio1_pins_a &daudio1_pins_b &daudio1_pins_c>;
      -	pinctrl-1       = <&daudio1_pins_d>;
      +	pinctrl-0       = <&daudio1_pins_a>;
      +	pinctrl-1       = <&daudio1_pins_b>;
      @@ -930,12 +939,10 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
       &usbc0 {
       	device_type = "usbc0";
      -	usb_port_type = <0x2>;
      +	usb_port_type = <0x0>;
       	usb_detect_type = <0x1>;
       	usb_detect_mode = <0>;
      -	usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
       	enable-active-high;
      -	usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
       	usb_wakeup_suspend = <0>;
       	usb_serial_unique = <0>;
      @@ -997,43 +1004,20 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
       	dma-names = "tx", "rx";
      -	/* pcf8574-usage:
      -	 * only use gpio0~7, 0 means PP0.
      -	 * pin set:
      -	 * gpios = <&pcf8574 0 GPIO_ACTIVE_LOW>;
      -	 * interrupt set:
      -	 * interrupt-parent = <&pcf8574>;
      -	 * interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
      -	pcf8574: gpio@38 {
      -		compatible = "nxp,pcf8574";
      -		reg = <0x38>;
      -		gpio_base = <2020>;
      -		gpio-controller;
      -		#gpio-cells = <2>;
      -		interrupt-controller;
      -		#interrupt-cells = <2>;
      -		interrupt-parent = <&pio>;
      -		interrupts = <PB 2 IRQ_TYPE_EDGE_FALLING>;
      +	focaltech@48{
      +		compatible = "focaltech,fts";
      +		reg = <0x48>;
      +		interrupt-parent = <&pio>;
      +		interrupts = <PG 14 IRQ_TYPE_LEVEL_LOW>;
      +		focaltech,reset-gpio = <&pio PG 15 GPIO_ACTIVE_HIGH>;
      +		focaltech,irq-gpio = <&pio PG 14 IRQ_TYPE_LEVEL_LOW>;
      +		focaltech,max-touch-number = <2>;
      +		focaltech,display-coords =  <0 0 480 480>;
      +		focaltech,reg_vdd = <&reg_3v3>;
      +		focaltech,reg_avdd = <&reg_3v3>;
      -	ctp@14 {
      -		compatible = "allwinner,goodix";
      -		device_type = "ctp";
      -		reg = <0x14>;
      -		status = "disabled";
      -		ctp_name = "gt9xxnew_ts";
      -		ctp_twi_id = <0x2>;
      -		ctp_twi_addr = <0x14>;
      -		ctp_screen_max_x = <0x320>;
      -		ctp_screen_max_y = <0x500>;
      -		ctp_revert_x_flag = <0x0>;
      -		ctp_revert_y_flag = <0x1>;
      -		ctp_exchange_x_y_flag = <0x0>;
      -		ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
      -		ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
       &twi3 {
      @@ -1045,14 +1029,12 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
       &gmac0 {
      -	phy-mode = "rgmii";
      +	phy-mode = "rmii";
       	use_ephy25m = <1>;
       	pinctrl-0 = <&gmac_pins_a>;
       	pinctrl-1 = <&gmac_pins_b>;
       	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
      -	tx-delay = <3>; /*2~4*/
      -	rx-delay = <0>;
      @@ -1064,7 +1046,7 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
       	spi_slave_mode = <0>;
       	spi0_cs_number = <1>;
      -        spi0_cs_bitmap = <1>;
      +	spi0_cs_bitmap = <1>;
       	spi-nand@0 {
      @@ -1083,21 +1065,9 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
       	pinctrl-1 = <&spi1_pins_c>;
      -	spi1_cs_number = <1>;
      -	spi1_cs_bitmap = <1>;
      -	spi_dbi_enable = <1>;
       	spi_board1@0 {
      -		device_type = "spi-dbi";
      -		compatible = "sunxi,spidbi";
      -		spi-max-frequency = <0x5f5e100>;
      -		reg = <0x0>;
      -		spi-rx-bus-width = <0x4>;
      -		spi-tx-bus-width = <0x4>;
      -		status = "okay";
      -	/* spi_board1@0 {
       		device_type = "spi_board1";
       		compatible = "rohm,dh2228fv";
      @@ -1105,7 +1075,7 @@ tvd_row*tvd_column is the total tvd channel number to be used in multichannel mo
       &ledc {
      @@ -1279,57 +1249,50 @@ pull up or pull down(default 0), driver level(default 1), data>
       &lcd0 {
      -	lcd_used            = <1>;
      -	lcd_driver_name     = "tft08006";
      -	lcd_backlight       = <100>;
      -	lcd_if              = <4>;
      -	lcd_x               = <800>;
      -	lcd_y               = <1280>;
      -	lcd_width           = <52>;
      -	lcd_height          = <52>;
      -	lcd_dclk_freq       = <70>;
      -	lcd_pwm_used        = <1>;
      -	lcd_pwm_ch          = <2>;
      -	lcd_pwm_freq        = <1000>;
      -	lcd_pwm_pol         = <0>;
      -	lcd_pwm_max_limit   = <255>;
      -	lcd_hbp             = <32>;
      -	lcd_ht              = <868>;
      -	lcd_hspw            = <4>;
      -	lcd_vbp             = <12>;
      -	lcd_vt              = <1311>;
      -	lcd_vspw            = <4>;
      -	lcd_dsi_if          = <0>;
      -	lcd_dsi_lane        = <4>;
      -	lcd_lvds_if         = <0>;
      -	lcd_lvds_colordepth = <0>;
      -	lcd_lvds_mode       = <0>;
      -	lcd_frm             = <0>;
      -	lcd_hv_clk_phase    = <0>;
      -	lcd_hv_sync_polarity= <0>;
      -	lcd_io_phase        = <0x0000>;
      -	lcd_gamma_en        = <0>;
      +	lcd_used        = <1>;
      +	lcd_driver_name = "st7701s_rgb";
      +	lcd_if          = <0>;
      +	lcd_hv_if       = <0>;
      +	lcd_width       = <70>;
      +	lcd_height      = <72>;
      +	lcd_x           = <480>;
      +	lcd_y           = <480>;
      +	lcd_dclk_freq   = <19>;
      +	lcd_hbp         = <60>;
      +	lcd_ht          = <612>;
      +	lcd_hspw        = <12>;
      +	lcd_vbp         = <18>;
      +	lcd_vt          = <520>;
      +	lcd_vspw        = <4>;
      +	lcd_backlight   = <50>;
      +	lcd_pwm_used    = <1>;
      +	lcd_pwm_ch      = <7>;
      +	lcd_pwm_freq    = <20000>;
      +	lcd_pwm_pol     = <1>;
       	lcd_bright_curve_en = <0>;
      -	lcd_cmap_en         = <0>;
      -	lcd_fsync_en        = <0>;
      -	lcd_fsync_act_time  = <1000>;
      -	lcd_fsync_dis_time  = <1000>;
      -	lcd_fsync_pol       = <0>;
      -	deu_mode            = <0>;
      -	lcdgamma4iep        = <22>;
      -	smart_color         = <90>;
      -	lcd_gpio_0 =  <&pio PG 13 GPIO_ACTIVE_HIGH>;
      -	pinctrl-0 = <&dsi4lane_pins_a>;
      -	pinctrl-1 = <&dsi4lane_pins_b>;
      +	lcd_frm         = <1>;
      +	lcd_io_phase    = <0x0000>;
      +	lcd_gamma_en    = <0>;
      +	lcd_cmap_en     = <0>;
      +	lcd_hv_clk_phase= <0>;
      +	lcd_hv_sync_polarity= <0>;
      +	lcd_rb_swap          = <0>;
      +	lcd_power       = "vcc-lcd";
      +	lcd_pin_power   = "vcc-pd";
      +	lcd_gpio_0      = <&pio PG 13 GPIO_ACTIVE_HIGH>;
      +	lcd_gpio_1      = <&pio PE 14 GPIO_ACTIVE_HIGH>;
      +	lcd_gpio_2      = <&pio PE 12 GPIO_ACTIVE_HIGH>;
      +	lcd_gpio_3      = <&pio PE 15 GPIO_ACTIVE_HIGH>;
      +	pinctrl-0       = <&rgb18_pins_a>;
      +	pinctrl-1       = <&rgb18_pins_b>;
       &hdmi {
       	hdmi_used = <1>;
       	hdmi_power_cnt = <0>;
      @@ -1357,14 +1320,12 @@ pull up or pull down(default 0), driver level(default 1), data>
       &pwm7 {
       	pinctrl-0 = <&pwm7_pin_a>;
       	pinctrl-1 = <&pwm7_pin_b>;
       &rtp {
      @@ -1399,61 +1360,4 @@ pull up or pull down(default 0), driver level(default 1), data>
       	pinctrl-0 = <&ir1_pins_a>;
       	pinctrl-1 = <&ir1_pins_b>;
      -/* &lcd_fb0 {
      -	lcd_used = <1>;
      -	lcd_driver_name = "kld35512";
      -	lcd_if = <1>;
      -	lcd_dbi_if = <4>;
      -	lcd_data_speed = <60>;
      -	lcd_spi_bus_num = <1>;
      -	lcd_x = <320>;
      -	lcd_y = <480>;
      -	lcd_pixel_fmt = <10>;
      -	lcd_dbi_fmt = <2>;
      -	lcd_rgb_order = <0>;
      -	lcd_width = <60>;
      -	lcd_height = <95>;
      -	lcd_pwm_ch = <7>;
      -	lcd_pwm_freq = <5000>;
      -	lcd_pwm_pol = <1>;
      -	lcd_frm = <1>;
      -	lcd_gamma_en = <1>;
      -	fb_buffer_num = <2>;
      -	lcd_fps = <40>;
      -	lcd_dbi_te = <1>;
      -	lcd_dbi_clk_mode = <1>;
      -	lcd_gpio_0 = <&pio PC 0 GPIO_ACTIVE_HIGH>;
      -	status = "okay";
      -/* &lcd_fb0 {
      -	lcd_used = <1>;
      -	lcd_driver_name = "kld2844b";
      -	lcd_if = <1>;
      -	lcd_dbi_if = <4>;
      -	lcd_x = <240>;
      -	lcd_y = <320>;
      -	lcd_width = <60>;
      -	lcd_pwm_ch = <7>;
      -	lcd_pixel_fmt = <0>;
      -	lcd_dbi_fmt = <3>;
      -	lcd_frm = <1>;
      -	lcd_dbi_te = <1>;
      -	lcd_fps = <60>;
      -	status = "okay";
      \ No newline at end of file
      diff --git a/configs/nezha/linux-5.4/config-5.4 b/configs/nezha/linux-5.4/config-5.4
      index 87ab49e..d91578d 100644
      --- a/configs/nezha/linux-5.4/config-5.4
      +++ b/configs/nezha/linux-5.4/config-5.4
      @@ -1368,6 +1368,7 @@ CONFIG_XR829_WLAN=m
       # CONFIG_SPARD_WLAN_SUPPORT is not set
       # CONFIG_BCMDHD is not set
       # CONFIG_AIC_WLAN_SUPPORT is not set
      +# CONFIG_RTL8723DS is not set
       # CONFIG_MAC80211_HWSIM is not set
       # CONFIG_USB_NET_RNDIS_WLAN is not set
       # CONFIG_VIRT_WIFI is not set
      diff --git a/configs/nezha/sys_config.fex b/configs/nezha/sys_config.fex
      index d52f3c1..a9b354e 100755
      --- a/configs/nezha/sys_config.fex
      +++ b/configs/nezha/sys_config.fex
      @@ -23,7 +23,7 @@ debug_mode  = 8
       ;storage_type   = boot medium, 0-nand, 1-sd, 2-emmc, 3-nor, 4-emmc3, 5-spinand -1(defualt)auto scan
       [target]
      -storage_type    = 5
      +storage_type    = 1
      diff --git a/configs/nezha/uboot-board.dts b/configs/nezha/uboot-board.dts
      index 81a521e..1efc8a6 100644
      --- a/configs/nezha/uboot-board.dts
      +++ b/configs/nezha/uboot-board.dts
      @@ -42,7 +42,7 @@
       &pwm2_pin_b {
       	pins = "PD18";
       	muxsel = <0>;
       &pwm2 {
      @@ -261,57 +261,49 @@
       &lcd0 {
      -	lcd_used            = <1>;
      -	lcd_if              = <4>;
      -	lcd_x               = <800>;
      -	lcd_y               = <1280>;
      -	lcd_width           = <52>;
      -	lcd_pwm_ch          = <2>;
      -	lcd_hbp             = <32>;
      -	lcd_ht              = <868>;
      -	lcd_hspw            = <4>;
      -	lcd_vbp             = <12>;
      -	lcd_vt              = <1311>;
      -	lcd_vspw            = <4>;
      -	lcd_dsi_if          = <0>;
      -	lcd_frm             = <0>;
      +	lcd_used        = <1>;
      +	lcd_if          = <0>;
      +	lcd_hv_if       = <0>;
      +	lcd_width       = <70>;
      +	lcd_x           = <480>;
      +	lcd_y           = <480>;
      +	lcd_hbp         = <60>;
      +	lcd_ht          = <612>;
      +	lcd_hspw        = <12>;
      +	lcd_vbp         = <18>;
      +	lcd_vt          = <520>;
      +	lcd_vspw        = <4>;
      +	lcd_pwm_ch      = <7>;
      -	deu_mode            = <0>;
      +	lcd_frm         = <1>;
       &hdmi {
       	hdmi_used = <1>;
      @@ -343,4 +335,4 @@
       	eink = &eink;
       	spi0 = &spi0;
      project lichee/linux-5.4/
      diff --git a/drivers/net/wireless/Kconfig b/drivers/net/wireless/Kconfig
      index 7e788946e..4c02b14b4 100644
      --- a/drivers/net/wireless/Kconfig
      +++ b/drivers/net/wireless/Kconfig
      @@ -52,6 +52,8 @@ source "drivers/net/wireless/xr819s/Kconfig"
       source "drivers/net/wireless/uwe5622/Kconfig"
       source "drivers/net/wireless/bcmdhd/Kconfig"
       source "drivers/net/wireless/aic8800/Kconfig"
      +source "drivers/net/wireless/rtl8723ds/Kconfig"
      +# source "drivers/net/wireless/rtl8189fs/Kconfig"
       config PCMCIA_RAYCS
       	tristate "Aviator/Raytheon 2.4GHz wireless support"
      diff --git a/drivers/net/wireless/Makefile b/drivers/net/wireless/Makefile
      index 269cb635d..644069b49 100644
      --- a/drivers/net/wireless/Makefile
      +++ b/drivers/net/wireless/Makefile
      @@ -32,6 +32,8 @@ obj-$(CONFIG_VIRT_WIFI)	+= virt_wifi.o
       obj-$(CONFIG_XR829_WLAN)   += xr829/
       obj-$(CONFIG_XR819S_WLAN)   += xr819s/
      +obj-$(CONFIG_RTL8723DS) += rtl8723ds/
      +# obj-$(CONFIG_RTL8189FS) += rtl8189fs/
       obj-$(CONFIG_SPARD_WLAN_SUPPORT) += uwe5622/
       obj-$(CONFIG_BCMDHD) += bcmdhd/
       obj-$(CONFIG_AIC_WLAN_SUPPORT) += aic8800/
      设备树修改参考了https://github.com/Tina-Linux/tina-d1x-lichee-rv和sipeed提供的licheerv_d1_compile。
      使用以下命令
      cat /sys/kernel/debug/pinctrl/2000000.pinctrl/pinmux-pins
      发现lcd的io均没有进行初始化
      是否遗漏某些地方配置不当或者设备树修改错误了?
        请贴出完整 board.dts 文件
          lbuque LV 4 @whycan 最后由 编辑
          @whycan 附上完整的board.dts
           * Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
           * fpga support.
          /dts-v1/;
          	compatible = "allwinner,d1-h", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
          	aliases {
          		dsp0 = &dsp0;
          	dsp0: dsp0 {
          		compatible = "allwinner,sun20iw1-dsp";
          	dsp0_gpio_int: dsp0_gpio_int {
          		compatible = "allwinner,sun20iw1-dsp-gpio-int";
          		pin-group = "PB", "PC", "PD", "PE";
          		regulator-ramp-delay = <25>;
          		regulator-always-on;
          		regulator-boot-on;
          	reg_usb1_vbus: usb1-vbus {
          		regulator-name = "usb1-vbus";
          		enable-active-high;
          	reg_3v3: vdd_3v3 {
          		enable-active-high;
          &CPU0 {
          	cpu-supply = <&reg_vdd_cpu>;
          &pio {
          	sdc0_pins_a: sdc0@0 {
          				 "PF3", "PF4", "PF5";
          		allwinner,function = "sdc0";
          		allwinner,muxsel = <2>;
          		allwinner,drive = <3>;
          		allwinner,pull = <1>;
          		function = "sdc0";
          		drive-strength = <30>;
          		bias-pull-up;
          		power-source = <3300>;
          	sdc0_pins_b: sdc0@1 {
          		function = "sdc0";
          		bias-pull-up;
          		power-source = <1800>;
          	sdc0_pins_c: sdc0@2 {
          	/* TODO: add jtag pin */
          	sdc0_pins_d: sdc0@3 {
          		pins = "PF2", "PF4";
          		function = "uart0";
          		bias-pull-up;
          	sdc0_pins_e: sdc0@4 {
          		pins = "PF0", "PF1", "PF3",
          			"PF5";
          		function = "jtag";
          		bias-pull-up;
          	sdc1_pins_a: sdc1@0 {
          		pins = "PG0", "PG1", "PG2",
          		       "PG3", "PG4", "PG5";
          		function = "sdc1";
          		bias-pull-up;
          	sdc1_pins_b: sdc1@1 {
          	sdc2_pins_a: sdc2@0 {
          				 "PC5", "PC6", "PC7";
          		allwinner,function = "sdc2";
          		allwinner,muxsel = <3>;
          		function = "sdc2";
          		bias-pull-up;
          	sdc2_pins_b: sdc2@1 {
          	wlan_pins_a:wlan@0 {
          		pins = "PG11";
          		function = "clk_fanout1";
          	uart0_pins_a: uart0_pins@0 {  /* For nezha board */
          		pins = "PB8", "PB9";
          		function = "uart0";
          		bias-pull-up;
          	uart0_pins_b: uart0_pins@1 {  /* For nezha board */
          		function = "uart1";
          		bias-pull-up;
          		pins = "PC0", "PC1";
          		function = "uart2";
          		bias-pull-up;
          		pins = "PD10", "PD11";
          		function = "uart3";
          		muxsel = <5>;
          		bias-pull-up;
          	twi0_pins_a: twi0@0 {
          		function = "twi0";
          	twi0_pins_b: twi0@1 {
          	twi1_pins_a: twi1@0 {
          		pins = "PB4", "PB5";
          		function = "twi1";
          	twi1_pins_b: twi1@1 {
          	twi2_pins_a: twi2@0 {
          		pins = "PB0", "PB1";
          		function = "twi2";
          	twi2_pins_b: twi2@1 {
          	twi3_pins_a: twi3@0 {
          		pins = "PB6", "PB7";
          		function = "twi3";
          	twi3_pins_b: twi3@1 {
          				"PE8", "PE9";
          		function = "gmac0";
          				"PE8", "PE9";
          		function = "dmic";
          		bias-disable;
          		bias-disable;
          		function = "i2s0";
          		bias-disable;
          		bias-disable;
          		function = "i2s1";
          		bias-disable;
          		bias-disable;
          	daudio2_pins_a: daudio2@0 {
          		pins = "PB7", "PB5", "PB6";
          		function = "i2s2";
          		bias-disable;
          	daudio2_pins_b: daudio2@1 {
          		/* I2S_PIN: DOUT0 */
          		pins = "PB4";
          		function = "i2s2_dout";
          		bias-disable;
          	daudio2_pins_c: daudio2@2 {
          		/* I2S_PIN: DIN0 */
          		pins = "PB3";
          		function = "i2s2_din";
          		bias-disable;
          		pins = "PB7", "PB5", "PB6", "PB4", "PB3";
          		bias-disable;
          	spdif_pins_a: spdif@0 {
          		/* SPDIF_PIN: SPDIF_OUT */
          		pins = "PB0";
          		function = "spdif";
          		bias-disable;
          	spdif_pins_b: spdif_sleep@0 {
          		pins = "PB0";
          		bias-disable;
          		function = "spi0";
          		muxsel = <2>;
          	spi0_pins_b: spi0@1 {
          		pins = "PC3", "PC7", "PC6";
          		function = "spi0";
          		muxsel = <2>;
          		muxsel = <0>;
          		function = "spi1";
          		pins = "PD10";
          		function = "spi1";
          	ledc_pins_a: ledc@0 {
          		pins = "PC0";
          		function = "ledc";
          	ledc_pins_b: ledc@1 {
          		pins = "PC0";
          	pwm0_pin_a: pwm0@0 {
          		pins = "PD16";
          		function = "pwm0";
          		bias-pull-up;
          	pwm0_pin_b: pwm0@1 {
          		pins = "PD16";
          		bias-disable;
          	pwm2_pin_a: pwm2@0 {
          		pins = "PD18";
          		function = "pwm2";
          		bias-pull-up;
          		pins = "PD18";
          		pins = "PD22";
          		function = "pwm7";
          		bias-pull-up;
          	pwm7_pin_b: pwm7@1 {
          		pins = "PD22";
          		pins = "PB12";
          		function = "ir";
          		bias-pull-up;
          	s_cir0_pins_b: s_cir@1 {
          		pins = "PB12";
          	ir1_pins_a: ir1@0 {
          		pins = "PB0";
          		function = "ir";
          		bias-pull-up;
          	ir1_pins_b: ir1@1 {
          		pins = "PB0";
          		function = "lcd0";
          		bias-disable;
          		bias-disable;
          		function = "lcd0";
          		bias-disable;
          		bias-disable;
          &uart0 {
          	pinctrl-0 = <&uart0_pins_a>;
          	pinctrl-1 = <&uart0_pins_b>;
          &uart1 {
          	pinctrl-0 = <&uart1_pins_a>;
          	pinctrl-1 = <&uart1_pins_b>;
          &uart2 {
          	pinctrl-0 = <&uart2_pins_a>;
          	pinctrl-1 = <&uart2_pins_b>;
          &uart3 {
          &soc {
          	card0_boot_para@2 {
          		reg = <0x0 0x2 0x0 0x0>;
          		card_ctrl = <0x0>;
          		card_high_speed = <0x1>;
          		card_line = <0x4>;
          		pinctrl-0 = <&sdc0_pins_a>;
          	card2_boot_para@3 {
          		reg = <0x0 0x3 0x0 0x0>;
          		card_ctrl = <0x2>;
          		card_line = <0x4>;
          		pinctrl-0 = <&sdc2_pins_a>;
          		/*sdc_ex_dly_used = <0x2>;*/
          		sdc_io_1v8 = <0x1>;
          		/*sdc_type = "tm4";*/
          		sdc_ex_dly_used = <2>;
          		/*sdc_tm4_win_th = <8>;*/
          	rfkill: rfkill@0 {
          		chip_en;
          		power_en;
          		status        = "okay";
          		wlan: wlan@0 {
          			/*interrupt-parent = <&pio>;
          			wakeup-source;
          		bt: bt@0 {
          			/*bt_io_vol = <3300000>;*/
          			/*bt_power_vol = <330000>;*/
          			bt_rst_n      = <&pio PG 18 GPIO_ACTIVE_LOW>;
          			status        = "okay";
          	/*btlpm: btlpm@0 {
          		uart_index  = <0x1>;
          		status      = "okay";
          		type_addr_wifi = <0x0>;
          		type_addr_bt   = <0x0>;
          		type_addr_eth  = <0x0>;
          		status         = "okay";
          &sdc2 {
          	non-removable;
          	bus-width = <4>;
          	mmc-ddr-1_8v;
          	mmc-hs200-1_8v;
          	no-sdio;
          	no-sd;
          	ctl-spec-caps = <0x308>;
          	cap-mmc-highspeed;
          	sunxi-power-save-mode;
          	sunxi-dis-signal-vol-sw;
          	mmc-bootpart-noacc;
          	max-frequency = <150000000>;
          	/*emmc io vol 3.3v*/
          	/*emmc io vol 1.8v*/
          &sdc0 {
          	bus-width = <4>;
          	/*non-removable;*/
          	/*broken-cd;*/
          	cd-inverted;
          	/*data3-detect;*/
          	cd-used-24M;
          	cap-sd-highspeed;
          	/*sd-uhs-sdr50;*/
          	/*sd-uhs-ddr50;*/
          	/*sd-uhs-sdr104;*/
          	no-sdio;
          	no-mmc;
          	/*sunxi-dis-signal-vol-sw;*/
          	ctl-spec-caps = <0x8>;
          &sdc1 {
          	bus-width = <4>;
          	no-mmc;
          	no-sd;
          	cap-sd-highspeed;
          	/*sd-uhs-sdr12*/
          	/*sd-uhs-sdr25;*/
          	/*sd-uhs-sdr50;*/
          	/*sd-uhs-ddr50;*/
          	/*sd-uhs-sdr104;*/
          	/*sunxi-power-save-mode;*/
          	cap-sdio-irq;
          	keep-power-in-suspend;
          	ignore-pm-notify;
          tvd configuration
                                 mode,mean enable)
          &tvd {
          	tvd_sw          = <1>;
          	tvd_interface   = <0>;
          	tvd_format      = <0>;
          	tvd_system      = <1>;
          	tvd_row         = <1>;
          	tvd_column      = <1>;
          	tvd_channel0_en = <1>;
          	tvd_channel1_en = <0>;
          	tvd_channel2_en = <0>;
          	tvd_channel3_en = <0>;
          	/*tvd_power0      = "dc1sw"*/
          	/*tvd_power1      = "eldo3"*/
          &tvd0 {
          /* Audio Driver modules */
          &sunxi_rpaf_dsp0 {
          &codec {
          	mic1gain 	= <0x13>;
          	mic2gain 	= <0x13>;
          	mic3gain 	= <0x13>;
          	adcdrc_cfg 	= <0x0>;
          	adchpf_cfg 	= <0x1>;
          	dacdrc_cfg 	= <0x0>;
          	dachpf_cfg 	= <0x0>;
          	/* Volume about */
          	digital_vol 	= <0x00>;
          	lineout_vol 	= <0x1a>;
          	headphonegain	= <0x03>;
          	/* Pa enabled about */
          	pa_level 	= <0x01>;
          	pa_pwr_level 	= <0x01>;
          	pa_msleep_time 	= <0x78>;
          	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>; */
          	/* regulator about */
          &sndcodec {
          	hp_detect_case	= <0x01>;
          	jack_enable	= <0x01>;
          &dummy_cpudai {
          	/* CMA config about */
          	playback_cma	= <128>;
          	capture_cma	= <256>;
          &dmic {
          &sounddmic {
          &dmic_codec {
           * tdm_config		0 --> pcm
           *			1 --> i2s
           * mclk_div		0 --> not output
           *			1 --> HDMI audio type
          &daudio0 {
          	mclk_div 	= <0x01>;
          	frametype 	= <0x00>;
          	tdm_config 	= <0x01>;
          	sign_extend 	= <0x00>;
          	msb_lsb_first 	= <0x00>;
          &sounddaudio0 {
          		/* sound-dai = <&ac108>; */
          &daudio1 {
          	mclk_div 	= <0x01>;
          	frametype 	= <0x00>;
          &sounddaudio1 {
          &daudio2 {
          	mclk_div 	= <0x00>;
          	frametype 	= <0x00>;
          	tx_data_mode 	= <0x00>;
          	rx_data_mode 	= <0x00>;
          	pcm_lrck_period = <0x20>;
          	asrc_function_en  = <0x00>;
          	/*pinctrl-0       = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>;*/
          	/*pinctrl-1       = <&daudio2_pins_d>;*/
          	/* HDMI audio, no need pin */
          	pinctrl-0;
          	pinctrl-1;
          	daudio_type	= <0x1>;
          &hdmiaudio {
          &sounddaudio2 {
          	simple-audio-card,name = "sndhdmi";
          		sound-dai = <&hdmiaudio>;
          &spdif {
          &soundspdif {
          &usbc0 {
          	enable-active-high;
          	rndis_wceis = <1>;
          &ehci0 {
          &ohci0 {
          &usbc1 {
          	device_type = "usbc1";
          	usb_regulator_io = "nocare";
          &ehci1 {
          &ohci1 {
          &twi0 {
          	clock-frequency = <400000>;
          	pinctrl-0 = <&twi0_pins_a>;
          	pinctrl-1 = <&twi0_pins_b>;
          	eeprom@50 {
          		compatible = "atmel,24c16";
          		reg = <0x50>;
          &twi1 {
          	pinctrl-0 = <&twi1_pins_a>;
          	pinctrl-1 = <&twi1_pins_b>;
          &twi2 {
          	pinctrl-0 = <&twi2_pins_a>;
          	pinctrl-1 = <&twi2_pins_b>;
          	dmas = <&dma 45>, <&dma 45>;
          	focaltech@48{
          		reg = <0x48>;
          &twi3 {
          	pinctrl-0 = <&twi3_pins_a>;
          	pinctrl-1 = <&twi3_pins_b>;
          &gmac0 {
          	phy-mode = "rmii";
          	use_ephy25m = <1>;
          &spi0 {
          	pinctrl-1 = <&spi0_pins_c>;
          	spi-nand@0 {
          		compatible = "spi-nand";
          		spi-max-frequency=<0x5F5E100>;
          		reg = <0x0>;
          		spi-rx-bus-width=<0x04>;
          		spi-tx-bus-width=<0x04>;
          		status="disabled";
          &spi1 {
          	spi_board1@0 {
          		reg = <0x0>;
          &ledc {
          	pinctrl-0 = <&ledc_pins_a>;
          	pinctrl-1 = <&ledc_pins_b>;
          	led_count = <12>;
          	output_mode = "GRB";
          	reset_ns = <84>;
          	t1h_ns = <800>;
          	t1l_ns = <320>;
          	t0h_ns = <300>;
          	t0l_ns = <800>;
          	wait_time0_ns = <84>;
          	wait_time1_ns = <84>;
          	wait_data_time_ns = <600000>;
          	status	= "okay";
          &keyboard0 {
          	key0 = <210 0x160>;
          	wakeup-source;
          disp init configuration
          set fbX_height to lcd_x)
                             in display.
          &disp {
          	/*VCC-LCD*/
          	/*VCC-DSI*/
          	/*VCC-PD*/
          ;lcd0 configuration
          ;Pin setting for gpio:
          ;fsync setting, pulse to csi
          &lcd0 {
          	lcd_used        = <1>;
          	lcd_if          = <0>;
          	lcd_hv_if       = <0>;
          	lcd_width       = <70>;
          	lcd_height      = <72>;
          	lcd_x           = <480>;
          	lcd_y           = <480>;
          	lcd_hbp         = <60>;
          	lcd_ht          = <612>;
          	lcd_hspw        = <12>;
          	lcd_vbp         = <18>;
          	lcd_vt          = <520>;
          	lcd_vspw        = <4>;
          	lcd_pwm_used    = <1>;
          	lcd_pwm_ch      = <7>;
          	lcd_pwm_pol     = <1>;
          	lcd_frm         = <1>;
          	lcd_gamma_en    = <0>;
          	lcd_cmap_en     = <0>;
          	lcd_rb_swap          = <0>;
          &hdmi {
          	hdmi_used = <1>;
          	hdmi_cts_compatibility = <1>;
          	hdmi_hdcp_enable = <1>;
          	hdmi_hdcp22_enable = <0>;
          	hdmi_cec_support = <1>;
          	hdmi_cec_super_standby = <0>;
          	ddc_en_io_ctrl = <0>;
          	power_io_ctrl = <0>;
          &pwm0 {
          	pinctrl-0 = <&pwm0_pin_a>;
          	pinctrl-1 = <&pwm0_pin_b>;
          &pwm2 {
          	pinctrl-0 = <&pwm2_pin_a>;
          	pinctrl-1 = <&pwm2_pin_b>;
          &pwm7 {
          &rtp {
          	allwinner,ts-attached;
          &gpadc {
          	channel_num = <2>;
          	channel_select = <3>;
          	channel_data_select = <3>;
          	channel_compare_select = <3>;
          	channel_cld_select = <3>;
          	channel_chd_select = <3>;
          &s_cir0 {
          	pinctrl-0 = <&s_cir0_pins_a>;
          	pinctrl-1 = <&s_cir0_pins_b>;
          &ir1 {
            是这个 rgb18_20_pins_a 吗?
            但是 LCD0 用得是这个: rgb18_pins_a
            L 2 条回复 最后回复 回复 引用 分享 0
              lbuque LV 4 最后由 编辑
              好像是因为没在linux源码仓库添加st7701_rgb的驱动。
              先试试加上st7701_rgb的驱动
                @whycan 其实用的是sun20iw1p1.dtsi里面的rgb18_pins_a
                  lbuque LV 4 最后由 q1215200171 编辑
                  附上uboot的dts
                   * Allwinner Technology CO., Ltd. sun20iw1p1 soc board.
                   * soc board support.
                  &platform {
                  	eraseflag   = <1>;
                  	next_work   = <3>;
                  	debug_mode  = <1>;
                  &target {
                  	boot_clock = <1008>;	/*CPU boot frequency, Unit: MHz*/
                  	storage_type = <0xffffffff>; /*boot medium, 0-nand, 1-card0, 2-card2, -1(defualt)auto scan*/
                  	burn_key = <0>;		/*1:support burn key; 0:not support burn key*/
                  	dragonboard_test = <0>;	/*1:support card boot dragonboard; 0:not support card boot dragonboard*/
                  &charger0 {
                  	pmu_safe_vol = <3500>;
                  &twi6 {
                  	clock-frequency = <200000>;
                  	pinctrl-0 = <&s_twi0_pins_a>;
                  	no_suspend = <1>;
                  	twi_drv_used = <1>;
                  &pwm2_pin_a {
                  	pins = "PD18";
                  	function = "pwm2";
                  	muxsel = <5>;
                  	bias-pull-up;
                  &pwm2_pin_b {
                  	pins = "PD18";
                  	muxsel = <0>;
                  &pwm2 {
                  &pwm7_pin_a {
                  	pins = "PD22";
                  	function = "pwm7";
                  	muxsel = <5>;
                  	bias-pull-up;
                  &pwm7_pin_b {
                  	pins = "PD22";
                  	muxsel = <0>;
                  &pwm7 {
                  &sdc0_pins_a {
                  	function = "sdc0";
                  	bias-pull-up;
                  &sdc0_pins_b {
                  	function = "sdc0";
                  	bias-pull-up;
                  &sdc0_pins_c {
                  &sdc2_pins_a {
                  	function = "sdc2";
                  	bias-pull-up;
                  &sdc2_pins_b {
                  &nand0_pins_a {
                  	allwinner,pins = "PC0", "PC1", "PC2", "PC5",
                  			 "PC8", "PC9", "PC10", "PC11",
                  			 "PC12", "PC13", "PC14", "PC15",
                  			 "PC16";
                  	allwinner,pname= "nand0_we", "nand0_ale","nand0_cle", "nand0_nre",
                  			 "nand0_d0", "nand0_d1", "nand0_d2", "nand0_d3",
                  			 "nand0_d4", "nand0_d5", "nand0_d6", "nand0_d7",
                  			 "nand0_ndqs";
                  	allwinner,function = "nand0";
                  	allwinner,drive = <1>;
                  	allwinner,pull = <0>;
                  &nand0_pins_b {
                  	allwinner,pins = "PC4", "PC6", "PC03", "PC07";
                  	allwinner,pname= "nand0_ce0", "nand0_rb0", "nand0_ce1", "nand0_rb1";
                  	allwinner,pull = <1>;	/* only RB&CE should be pulled up */
                  &nand0_pins_c {
                  	allwinner,pins = "PC0", "PC1", "PC2", "PC3",
                  			 "PC4", "PC5", "PC6", "PC7",
                  			 "PC16";
                  	allwinner,muxsel = <7>;
                  &card0_boot_para {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
                  	/* reg = <0x0 0x2 0x0 0x0>;  [> Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value <] */
                  	card_ctrl = <0x0>;
                  	card_line = <0x4>;
                  &card2_boot_para {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
                  	/* reg = <0x0 0x3 0x0 0x0>;  [> Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value <] */
                  	card_ctrl = <0x2>;
                  	card_line = <0x4>;
                  &gpio_bias {  /* Avoid dtc compiling warnings. @TODO: Developer should modify this to the actual value */
                  	device_type = "gpio_bias";
                  &nand0 {
                  	compatible = "allwinner,sun20iw1-nand";
                  	device_type = "nand0";
                  	//reg = <0x0 0x04011000 0x0 0x1000>;/* nand0 */
                  	pinctrl-0 = <&nand0_pins_a &nand0_pins_b>;
                  	pinctrl-1 = <&nand0_pins_c>;
                  	nand0_regulator1 = "vcc-nand";
                  	nand0_regulator2 = "none";
                  	nand0_cache_level = <0x55aaaa55>;
                  	nand0_flush_cache_num = <0x55aaaa55>;
                  	nand0_capacity_level = <0x55aaaa55>;
                  	nand0_id_number_ctl = <0x55aaaa55>;
                  	nand0_print_level = <0x55aaaa55>;
                  	nand0_p0 = <0x55aaaa55>;
                  	nand0_p1 = <0x55aaaa55>;
                  	nand0_p2 = <0x55aaaa55>;
                  	nand0_p3 = <0x55aaaa55>;
                  	chip_code = "sun20iw1";
                  &disp {
                  	/*VCC-LCD*/
                  	/*VCC-DSI*/
                  	/*VCC-PD*/
                  &lcd0 {
                  	lcd_used        = <1>;
                  	lcd_if          = <0>;
                  	lcd_hv_if       = <0>;
                  	lcd_width       = <70>;
                  	lcd_height      = <72>;
                  	lcd_x           = <480>;
                  	lcd_y           = <480>;
                  	lcd_hbp         = <60>;
                  	lcd_ht          = <612>;
                  	lcd_hspw        = <12>;
                  	lcd_vbp         = <18>;
                  	lcd_vt          = <520>;
                  	lcd_vspw        = <4>;
                  	lcd_pwm_used    = <1>;
                  	lcd_pwm_ch      = <7>;
                  	lcd_pwm_pol     = <1>;
                  	lcd_frm         = <1>;
                  	lcd_gamma_en    = <0>;
                  	lcd_cmap_en     = <0>;
                  &hdmi {
                  	hdmi_used = <1>;
                  &aliases {
                  	nand0 = &nand0;
                  	twi6 = &twi6;
                  	pwm = &pwm;
                  	pwm0 = &pwm0;
                  	pwm1 = &pwm1;
                  	pwm2 = &pwm2;
                  	pwm3 = &pwm3;
                  	pwm4 = &pwm4;
                  	pwm5 = &pwm5;
                  	pwm6 = &pwm6;
                  	pwm7 = &pwm7;
                  	disp = &disp;
                  	hdmi = &hdmi;
                  	lcd0 = &lcd0;
                  	lcd1 = &lcd1;
                  	eink = &eink;
                  	spi0 = &spi0;
                    lbuque LV 4 最后由 编辑
                    附上log
                    [34]HELLO! BOOT0 is starting!
                    [37]BOOT0 commit : 88480af
                    [39]set pll start
                    [41]periph0 has been enabled
                    [44]set pll end
                    [45][pmu]: bus read error
                    [48]board init ok
                    [50]get_pmu_exist() = -1
                    [52]ddr_efuse_type: 0x0
                    [54]trefi:7.8ms
                    [56][AUTO DEBUG] single rank and full DQ!
                    [60]ddr_efuse_type: 0x0
                    [63]trefi:7.8ms
                    [65][AUTO DEBUG] rank 0 row = 15
                    [68][AUTO DEBUG] rank 0 bank = 8
                    [71][AUTO DEBUG] rank 0 page size = 2 KB
                    [75]DRAM BOOT DRIVE INFO: V0.33
                    [78]DRAM CLK = 792 MHz
                    [80]DRAM Type = 3 (2:DDR2,3:DDR3)
                    [83]DRAMC ZQ value: 0x7b7bfb
                    [86]DRAM ODT value: 0x42.
                    [88]ddr_efuse_type: 0x0
                    [91]DRAM SIZE =512 M
                    [93]dram_tpr4:0x0
                    [95]PLL_DDR_CTRL_REG:0xf8004100
                    [98]DRAM_CLK_REG:0xc0000000
                    [100][TIMING DEBUG] MR2= 0x18
                    [105]DRAM simple test OK.
                    [107]dram size =512
                    [109]card no is 0
                    [110]sdcard 0 line count 4
                    [113][mmc]: mmc driver ver 2021-04-2 16:45
                    [122][mmc]: Wrong media type 0x0
                    [125][mmc]: ***Try SD card 0***
                    [134][mmc]: HSSDR52/SDR25 4 bit
                    [137][mmc]: 50000000 Hz
                    [139][mmc]: 59638 MB
                    [141][mmc]: ***SD/MMC 0 init OK!!!***
                    [195]Loading boot-pkg Succeed(index=0).
                    [198]Entry_name        = opensbi
                    [201]Entry_name        = u-boot
                    [205]Entry_name        = dtb
                    [207]mmc not para
                    [209]Jump to second Boot.
                    OpenSBI auto-t113-linux-V0.8-2-g053d088
                            |_|
                    Platform Max HARTs     : 1
                    Current Hart           : 0
                    Runtime SBI Version    : 0.2
                    MIDELEG : 0x0000000000000222
                    MEDELEG : 0x000000000000b1ff
                    PMP3    : 0x0000000000020000-0x0000000000027fff (A,?
                    U-Boot 2018.05-g24521d6-dirty-config-dirty (Jul 19 2022 - 14:31:38 +0800) Allwinner Technology
                    [00.296]DRAM:  512 MiB
                    [00.298]Relocation Offset is: 1dee7000
                    [00.302]secure enable bit: 0
                    [00.305]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                    [00.311]flash init start
                    [00.313]workmode = 0,storage type = 1
                    [00.317][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
                    [00.322][mmc]: get sdc_type fail and use default host:tm1.
                    [00.328][mmc]: can't find node "mmc0",will add new node
                    [00.333][mmc]: fdt err returned <no error>
                    [00.337][mmc]: Using default timing para
                    [00.341][mmc]: SUNXI SDMMC Controller Version:0x50310
                    [00.358][mmc]: card_caps:0x3000000a
                    [00.361][mmc]: host_caps:0x3000003f
                    [00.364]sunxi flash init ok
                    [00.367]line:703 init_clocks
                    [00.370]drv_disp_init
                    [00.386]drv_disp_init finish
                    [00.389]boot_gui_init:start
                    [00.392]set disp.dev2_output_type fail. using defval=0
                    [00.398]boot_gui_init:finish
                    [00.418]=====================LCD_panel_init
                    54 bytes read in 3 ms (17.6 KiB/s)
                    [00.652]bmp_name=bootlogo.bmp size 3072054
                    [00.743]=====================LCD_bl_open
                    [00.747]LCD open finish
                    3072054 bytes read in 145 ms (20.2 MiB/s)
                    no support big size bmp[800x1280] on fb[480x480]
                    [00.813]show bmp on fb failed !-1
                    [00.849]Loading Environment from SUNXI_FLASH... OK
                    [00.871]out of usb burn from boot: not need burn key
                    [00.897]Item0 (Map) magic is bad
                    [00.900]the secure storage item0 copy0 magic is bad
                    [00.926]Item0 (Map) magic is bad
                    [00.929]the secure storage item0 copy1 magic is bad
                    [00.934]Item0 (Map) magic is bad
                    root_partition is rootfs
                    set root to /dev/mmcblk0p5
                    [00.951]update part info
                    [00.956]update bootcmd
                    [00.962]change working_fdt 0x5eaa6da0 to 0x5ea86da0
                    [00.993]update dts
                    noncached_alloc(): addr = 0x5ebf4080
                    noncached_alloc(): addr = 0x5ebf40c0
                    noncached_alloc(): addr = 0x5ebf4100
                    noncached_alloc(): addr = 0x5ebf4940
                    geth_sys_init fail!
                    [01.013]Board Net Initialization Failed
                    [01.017]No ethernet found.
                    dsp0:uart config fail
                    dsp0:gpio init config fail
                    dsp0:sharespace config fail
                    dsp0 version is r528-tina-v1.0.0-release-37-g735b6b4-dirty
                    DSP0 start ok, img length 254860, booting from 0x400660
                    [01.311]no vendor_boot partition is found
                    Android's image name: d1-h-nezha
                    Detect comp gzip
                    [01.562]
                    Starting kernel ...
                    [01.564][mmc]: MMC Device 2 not found
                    [01.568][mmc]: mmc 2 not find, so not exit
                    [    0.000000] Linux version 5.4.61 (lewin@mint0) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #55 PREEMPT Tue Jul 19 06:40:47 UTC 2022
                    [    0.000000] cma: Reserved 8 MiB at 0x000000005f800000
                    [    0.000000] Zone ranges:
                    [    0.000000]   DMA32    [mem 0x0000000040000000-0x000000005fffffff]
                    [    0.000000]   node   0: [mem 0x0000000040000000-0x000000005fffffff]
                    [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
                    [    0.000000] On node 0 totalpages: 131072
                    [    0.000000]   DMA32 zone: 1792 pages used for memmap
                    [    0.000000]   DMA32 zone: 131072 pages, LIFO batch:31
                    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129280
                    [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty-config-dirty(07/19/2022-14:31:38) mbr_offset=1556480
                    [    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
                    [    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
                    [    0.000000] Memory: 497212K/524288K available (6335K kernel code, 589K rwdata, 2134K rodata, 184K init, 260K bss, 18884K reserved, 8192K cma-reserved)
                    [    0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
                    [    0.000023] riscv_timer_clockevent depends on broadcast, but no broadcast function available
                    [    0.000315] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                    [    0.000933] Console: colour dummy device 80x25
                    [    0.000969] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                    [    0.000985] pid_max: default: 32768 minimum: 301
                    [    0.001155] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
                    [    0.001174] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
                    [    0.002739] ASID allocator initialised with 65536 entries
                    [    0.002892] rcu: Hierarchical SRCU implementation.
                    [    0.003500] devtmpfs: initialized
                    [    0.016833] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
                    [    0.017708] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                    [    0.017738] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
                    [    0.018119] pinctrl core: initialized pinctrl subsystem
                    [    0.019368] NET: Registered protocol family 16
                    [    0.021189] DMA: preallocated 256 KiB pool for atomic allocations
                    [    0.021790] cpuidle: using governor menu
                    [    0.064443] rtc_ccu: sunxi ccu init OK
                    [    0.070747] clock: sunxi ccu init OK
                    [    0.071591] clock: sunxi ccu init OK
                    [    0.103615] iommu: Default domain type: Translated
                    [    0.103782] sunxi iommu: irq = 4
                    [    0.104861] SCSI subsystem initialized
                    [    0.105199] usbcore: registered new interface driver usbfs
                    [    0.105277] usbcore: registered new interface driver hub
                    [    0.105378] usbcore: registered new device driver usb
                    [    0.105555] mc: Linux media interface: v0.10
                    [    0.105623] videodev: Linux video capture interface: v2.00
                    [    0.106649] sunxi-msgbox-amp 3003000.msgbox: invalid resource
                    [    0.107438] Advanced Linux Sound Architecture Driver Initialized.
                    [    0.108048] Bluetooth: Core ver 2.22
                    [    0.108155] NET: Registered protocol family 31
                    [    0.108165] Bluetooth: HCI device and connection manager initialized
                    [    0.108185] Bluetooth: HCI socket layer initialized
                    [    0.108200] Bluetooth: L2CAP socket layer initialized
                    [    0.108236] Bluetooth: SCO socket layer initialized
                    [    0.108521] pwm module init!
                    [    0.110061] g2d 5410000.g2d: Adding to iommu group 0
                    [    0.110613] G2D: rcq version initialized.major:250
                    [    0.111287] input: sunxi-keyboard as /devices/virtual/input/input0
                    [    0.112676] clocksource: Switched to clocksource riscv_clocksource
                    [    0.125220] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
                    [    0.140333] thermal_sys: Registered thermal governor 'user_space'
                    [    0.140338] thermal_sys: Registered thermal governor 'power_allocator'
                    [    0.140850] NET: Registered protocol family 2
                    [    0.141602] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
                    [    0.141642] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
                    [    0.141702] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
                    [    0.141749] TCP: Hash tables configured (established 4096 bind 4096)
                    [    0.141882] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                    [    0.141921] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                    [    0.142154] NET: Registered protocol family 1
                    [    0.144666] Initialise system trusted keyrings
                    [    0.144878] workingset: timestamp_bits=62 max_order=17 bucket_order=0
                    [    0.152646] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                    [    0.173667] Key type asymmetric registered
                    [    0.173681] Asymmetric key parser 'x509' registered
                    [    0.173701] io scheduler mq-deadline registered
                    [    0.173711] io scheduler kyber registered
                    [    0.173730] atomic64_test: passed
                    [    0.174922] [DISP]disp_module_init
                    [    0.175459] disp 5000000.disp: Adding to iommu group 0
                    [    0.176070] [DISP] disp_init,line:2386:
                    [    0.176075] smooth display screen:0 type:1 mode:4
                    [    0.199450] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
                    [    0.199713] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
                    [    0.210471] panel name: default_lcd
                    [    0.210486] panel name: st7701s
                    [    0.210493] panel name: st7701s_rgb
                    [    0.210509] panel name: tft08006
                    [    0.210516] panel name: super_lcd_driver
                    [    0.210546] display_fb_request,fb_id:0
                    [    0.219823] Freeing logo buffer memory: 900K
                    [    0.220267] disp_al_manager_apply ouput_type:1
                    [    0.220383] [DISP] lcd_clk_config,line:732:
                    [    0.220395] disp 0, clk: pll(114000000),clk(114000000),dclk(19000000) dsi_rate(114000000)
                    [    0.220395]      clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
                    [    0.220774] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
                    [    0.221687] [DISP]disp_module_init finish
                    [    0.222541] sunxi_sid_init()551 - insmod ok
                    [    0.223182] pwm-regulator: supplied by regulator-dummy
                    [    0.230218] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
                    [    0.230603] uart uart0: get regulator failed
                    [    0.230630] uart uart0: uart0 supply uart not found, using dummy regulator
                    [    0.230986] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
                    [    0.231012] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
                    [    1.032118] printk: console [ttyS0] enabled
                    [    1.037725] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
                    [    1.049176] uart uart1: get regulator failed
                    [    1.054043] uart uart1: uart1 supply uart not found, using dummy regulator
                    [    1.062088] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
                    [    1.072007] misc dump reg init
                    [    1.076326] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
                    [    1.083611] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
                    [    1.091210] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
                    [    1.098557] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
                    [    1.106001] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
                    [    1.112528] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
                    [    1.119490] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
                    [    1.127257] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
                    [    1.135153] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
                    [    1.143326] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
                    [    1.150956] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
                    [    1.157763] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
                    [    1.165332] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
                    [    1.173601] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
                    [    1.181143] [ADDR_MGT] addr_mgt_probe: success.
                    [    1.187527] libphy: Fixed MDIO Bus: probed
                    [    1.192090] CAN device driver interface
                    [    1.197274] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
                    [    1.208574] sunxi gmac driver's version: 1.0.0
                    [    1.213793] gmac-power0: NULL
                    [    1.217102] gmac-power1: NULL
                    [    1.220434] gmac-power2: NULL
                    [    1.225067] Failed to alloc md5
                    [    1.228604] eth0: Use random mac address
                    [    1.233419] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                    [    1.240730] sunxi-ehci: EHCI SUNXI driver
                    [    1.245834] get ehci0-controller wakeup-source is fail.
                    [    1.251762] sunxi ehci0-controller don't init wakeup source
                    [    1.258108] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000935390, 0x:ffffffd004079000, irq_no:2e
                    [    1.271680] [sunxi-ehci0]: Not init ehci0
                    [    1.276576] get ehci1-controller wakeup-source is fail.
                    [    1.282534] sunxi ehci1-controller don't init wakeup source
                    [    1.288861] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000935758, 0x:ffffffd00407d000, irq_no:31
                    [    1.302437] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
                    [    1.315015] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
                    [    1.327263] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
                    [    1.334571] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
                    [    1.344427] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
                    [    1.372722] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
                    [    1.381431] hub 1-0:1.0: USB hub found
                    [    1.385761] hub 1-0:1.0: 1 port detected
                    [    1.390931] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                    [    1.397948] sunxi-ohci: OHCI SUNXI driver
                    [    1.403045] get ohci0-controller wakeup-source is fail.
                    [    1.409009] sunxi ohci0-controller don't init wakeup source
                    [    1.415308] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000935ee8
                    [    1.425743] [sunxi-ohci0]: Not init ohci0
                    [    1.430544] get ohci1-controller wakeup-source is fail.
                    [    1.436564] sunxi ohci1-controller don't init wakeup source
                    [    1.442857] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0009362b0
                    [    1.453322] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
                    [    1.465860] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
                    [    1.478175] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
                    [    1.485477] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
                    [    1.496300] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
                    [    1.577683] hub 2-0:1.0: USB hub found
                    [    1.581916] hub 2-0:1.0: 1 port detected
                    [    1.587419] usbcore: registered new interface driver uas
                    [    1.593632] usbcore: registered new interface driver usb-storage
                    [    1.600434] usbcore: registered new interface driver ums-alauda
                    [    1.607217] usbcore: registered new interface driver ums-cypress
                    [    1.614073] usbcore: registered new interface driver ums-datafab
                    [    1.620868] usbcore: registered new interface driver ums_eneub6250
                    [    1.627908] usbcore: registered new interface driver ums-freecom
                    [    1.634764] usbcore: registered new interface driver ums-isd200
                    [    1.641472] usbcore: registered new interface driver ums-jumpshot
                    [    1.648424] usbcore: registered new interface driver ums-karma
                    [    1.655083] usbcore: registered new interface driver ums-onetouch
                    [    1.661989] usbcore: registered new interface driver ums-realtek
                    [    1.668845] usbcore: registered new interface driver ums-sddr09
                    [    1.675603] usbcore: registered new interface driver ums-sddr55
                    [    1.682302] usbcore: registered new interface driver ums-usbat
                    [    1.689431] sunxi_gpadc_init,2151, success
                    [    1.696246] sunxi-rtc 7090000.rtc: registered as rtc0
                    [    1.702024] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T18:51:30 UTC (67890)
                    [    1.711365] sunxi-rtc 7090000.rtc: sunxi rtc probed
                    [    1.717356] i2c /dev entries driver
                    [    1.721340] IR NEC protocol handler initialized
                    [    1.727161] sunxi cedar version 1.1
                    [    1.731356] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
                    [    1.737693] VE: install start!!!
                    [    1.737693]
                    [    1.743259] VE: cedar-ve the get irq is 6
                    [    1.743259]
                    [    1.749613] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
                    [    1.749613]
                    [    1.761235] VE: install end!!!
                    [    1.761235]
                    [    1.766339] VE: sunxi_cedar_probe
                    [    1.771641] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                    [    1.780833] Bluetooth: HCI UART driver ver 2.3
                    [    1.785876] Bluetooth: HCI UART protocol H4 registered
                    [    1.791622] Bluetooth: HCI UART protocol BCSP registered
                    [    1.797594] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
                    [    1.807626] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                    [    1.817633] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
                    [    1.823892] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
                    [    1.830224] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
                    [    1.836686] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
                    [    1.843149] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
                    [    1.849670] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
                    [    1.856223] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
                    [    1.862783] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
                    [    1.869722] sunxi-mmc 4020000.sdmmc: Got CD GPIO
                    [    1.875273] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
                    [    1.881947] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    1.893124] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
                    [    1.913264] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    1.937668] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
                    [    1.943421] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    1.955684] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
                    [    1.965790] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
                    [    1.972039] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
                    [    1.978448] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
                    [    1.984922] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    1.996519] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
                    [    2.002984] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
                    [    2.009505] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
                    [    2.016158] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
                    [    2.022752] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
                    [    2.029353] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
                    [    2.038413] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    2.050797] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    2.062011] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                    [    2.070947] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    2.082552] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    2.106920] sunxi-mmc 4021000.sdmmc: detmode:manually by software
                    [    2.114619] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                    [    2.121435] random: fast init done
                    [    2.125711] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
                    [    2.136697] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                    [    2.143630] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    2.155468] sunxi_led_probe()1749 - start
                    [    2.160136] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
                    [    2.170170] sunxi_register_led_classdev()1483 - led_classdev start
                    [    2.178459] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [    2.191959] mmc0: host does not support reading read-only switch, assuming write-enable
                    [    2.202488] sunxi_led_probe()1845 - finish
                    [    2.207771] usbcore: registered new interface driver usbhid
                    [    2.214108] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                    [    2.225714] usbhid: USB HID core driver
                    [    2.230167] rpmsg_client_dsp_standby 3003000.msgbox.sunxi,dsp-power-msgbox.512.256: new channel: 0x200 -> 0x100!
                    [    2.241531] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [    2.248457] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                    [    2.260110] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [    2.267756] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [    2.274730] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                    [    2.286380] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [    2.293224] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                    [    2.305406] usbcore: registered new interface driver snd-usb-audio
                    [    2.316077] sunxi-daudio 2034000.daudio: regulator missing or invalid
                    [    2.323463] mmc0: new high speed SDXC card at address b368
                    [    2.330911] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
                    [    2.330911]
                    [    2.348920] mmcblk0: mmc0:b368 NCard 58.2 GiB
                    [    2.355990] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
                    [    2.367631] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
                    [    2.376012]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
                    [    2.382366] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
                    [    2.394883] [SNDCODEC][sunxi_card_init][583]:card init finished
                    [    2.403777] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
                    [    2.415084] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
                    [    2.427194] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
                    [    2.435461] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
                    [    2.444011] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
                    [    2.453076] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
                    [    2.464658] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
                    [    2.476683] NET: Registered protocol family 10
                    [    2.483173] Segment Routing with IPv6
                    [    2.487465] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
                    [    2.495006] NET: Registered protocol family 17
                    [    2.500061] can: controller area network core (rev 20170425 abi 9)
                    [    2.507161] NET: Registered protocol family 29
                    [    2.512171] can: raw protocol (rev 20170425)
                    [    2.516974] can: broadcast manager protocol (rev 20170425 t)
                    [    2.523359] can: netlink gateway (rev 20190810) max_hops=1
                    [    2.529802] Bluetooth: RFCOMM TTY layer initialized
                    [    2.535385] Bluetooth: RFCOMM socket layer initialized
                    [    2.541192] Bluetooth: RFCOMM ver 1.11
                    [    2.546439] Loading compiled-in X.509 certificates
                    [    2.554161] HDMI 2.0 driver init start!
                    [    2.558496] boot_hdmi=false
                    [    2.561673] ERROR: pinctrl_get for HDMI2.0 DDC fail
                    [    2.568735] HDMI2.0 module init end
                    [    2.598596] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
                    [    2.614460] sunxi-i2c sunxi-i2c2: probe success
                    [    2.623249] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
                    [    2.633448] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
                    [    2.643639] debugfs: Directory '2034000.daudio' with parent 'sndhdmi' already present!
                    [    2.654320] sunxi-audio-card 20340a0.sounddaudio2: 20340a4.hdmiaudio <-> 2034000.daudio mapping ok
                    [    2.666120] get det_vbus is fail, -84
                    [    2.670204] get id is fail, -84
                    [    2.675067] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                    [    2.685997] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                    [    2.693628] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                    [    2.703338] clk: Not disabling unused clocks
                    [    2.708125] ALSA device list:
                    [    2.711444]   #0: audiocodec
                    [    2.714786] cfg80211: failed to load regulatory.db
                    [    2.720224]   #1: snddmic
                    [    2.723211]   #2: sndhdmi
                    [    2.726163] alloc_fd: slot 0 not NULL!
                    [    2.738783] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
                    [    2.752289] devtmpfs: mounted
                    [    2.755883] Freeing unused kernel memory: 184K
                    [    2.760863] This architecture does not have kernel memory protection.
                    [    2.768162] Run /sbin/init as init process
                    [    3.173129] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:3
                    [    3.463374] init: Console is alive
                    [    3.467475] init: - watchdog -
                    [    3.471019] init: - preinit -
                    [    3.764555]
                    [    3.764555] insmod_device_driver
                    [    3.764555]
                    [    3.850887] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
                    [    3.864648] device_chose finished 139!
                    [    3.901635] random: procd: uninitialized urandom read (4 bytes read)
                    formating /dev/by-name/UDISK to ext4
                    /etc/preinit: line 1: mkfs.ext4: not found
                    [    4.708354] mount_root: mounting /dev/root
                    [    4.714028] mount_root: loading kmods from internal overlay
                    [    4.847549] block: attempting to load /etc/config/fstab
                    [    4.874699] block: extroot: device not present, retrying in 5 seconds
                    [    6.462711] hdmi_hpd_sys_config_release
                    [    9.977010] block: extroot: cannot find device UDISK
                    [    9.994357] procd: - early -
                    [    9.997794] procd: - watchdog -
                    [   10.038017] random: procd: uninitialized urandom read (4 bytes read)
                    [   10.405018] procd: - watchdog -
                    [   10.408840] procd: - ubus -
                    [   10.412605] procd (1): /proc/115/oom_adj is deprecated, please use /proc/115/oom_score_adj instead.
                    [   10.492992] random: ubusd: uninitialized urandom read (4 bytes read)
                    [   10.673319] random: ubusd: uninitialized urandom read (4 bytes read)
                    [   10.711807] procd: - init -
                    [   11.942826] fuse: init (API version 7.31)
                    [   12.103643] file system registered
                    [   12.269745] usbcore: registered new interface driver uvcvideo
                    [   12.283758] configfs-gadget 4100000.udc-controller: failed to start g1: -19
                    [   12.299687] USB Video Class driver (1.1.1)
                    [   12.672908] read descriptors
                    [   12.676160] read strings
                    [   14.928657] ======== XRADIO WIFI OPEN ========
                    [   14.934590] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
                    [   14.941754] [XRADIO] Allocated hw_priv @ (____ptrval____)
                    [   14.949305] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                    [   14.966950] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                    [   15.236848] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   15.250220] [XRADIO] Detect SDIO card 1
                    [   15.262866] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                    [   15.282783] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   15.313405] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   15.328617] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   15.352616] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                    [   15.364501] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                    [   15.376755] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                    [   15.389686] mmc1: new high speed SDIO card at address 0001
                    [   15.397062] [SBUS] XRadio Device:sdio clk=50000000
                    [   15.404282] [XRADIO] XRADIO_HW_REV 1.0 detected.
                    [   15.513467] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
                    [   15.611083] [XRADIO] Bootloader complete
                    [   20.877195] [XRADIO_ERR] xradio_firmware: Timeout waiting for FIFO.
                    [   20.884324] [XRADIO_ERR] xradio_load_firmware: can't download firmware.
                    [   20.891736] [XRADIO_ERR] xradio_load_firmware failed(-110).
                    [   20.899256] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
                    [   21.018853] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   21.025639] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   21.032389] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   21.039163] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   21.046188] mmc1: card 0001 removed
                    [   21.050241] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                    [   21.061591] [XRADIO] Remove SDIO card 1
                    [   21.077537] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   21.088757] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                    [   21.103845] xradio_core_init failed (-110)!
                    [   21.108968] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   21.146303] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                    [   21.154041] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                    [   21.160876] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   21.179328] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   21.191051] xt_time: kernel timezone is -0000
                    [   21.204984] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [   21.212543] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [   21.220132] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [   21.227718] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [   21.234503] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                    [   21.246720] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
                    [   22.527620] ======== XRADIO WIFI OPEN ========
                    [   22.533224] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
                    [   22.540007] [XRADIO] Allocated hw_priv @ (____ptrval____)
                    [   22.552787] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
                    [   22.575991] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
                    [   22.783256] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   22.794387] [XRADIO] Detect SDIO card 1
                    [   22.802821] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                    [   22.822748] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   22.847646] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   22.862263] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   22.884874] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                    [   22.896490] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                    [   22.908375] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                    [   22.920908] mmc1: new high speed SDIO card at address 0001
                    [   22.927920] [SBUS] XRadio Device:sdio clk=50000000
                    [   22.942837] [XRADIO] XRADIO_HW_REV 1.0 detected.
                    [   22.993264] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
                    [   23.032628] [XRADIO] Bootloader complete
                    [   28.041823] [XRADIO_ERR] xradio_firmware: Timeout waiting for FIFO.
                    [   28.048932] [XRADIO_ERR] xradio_load_firmware: can't download firmware.
                    [   28.056478] [XRADIO_ERR] xradio_load_firmware failed(-110).
                    [   28.064044] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
                    [   28.182833] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   28.189574] [XRADIO] Remove SDIO card 1
                    [   28.189590] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   28.200632] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   28.207411] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
                    [   28.214429] mmc1: card 0001 removed
                    [   28.218483] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                    [   28.241464] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   28.252755] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                    [   28.263892] xradio_core_init failed (-110)!
                    [   28.272792] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   28.306349] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                    [   28.314154] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                    [   28.320990] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   28.336182] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                    [   28.360200] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    kmodloader done
                    [   28.370678] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [   28.378356] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [   28.386394] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                    [   28.434655] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                    [   31.136964] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
                    [   33.122757] usb1-vbus: disabling
                    [   33.126538] vdd_3v3: disabling
                    [   43.200273] random: crng init done
                    [   43.204070] random: 6 urandom warning(s) missed due to ratelimiting
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                    root@TinaLinux:/# cat /sys/class/d
                    devlink/  disp/     dma/
                    root@TinaLinux:/# cat /sys/kernel/debug/
                    asoc/               dma_buf/            mmc0/               sunxi_leds/
                    bdi/                enc_test/           mmc1/               suspend_stats
                    block/              extfrag/            mtd/                ubi/
                    bluetooth/          fault_around_bytes  pinctrl/            ubifs/
                    clear_warn_once     gpio                pm_qos/             usb/
                    clk/                hid/                pwm                 wakeup_sources
                    device_component/   ieee80211/          regmap/
                    devices_deferred    ion/                regulator/
                    dispdbg/            memblock/           sleep_time
                    root@TinaLinux:/# cat /sys/kernel/debug/p
                    pinctrl/  pm_qos/   pwm
                    root@TinaLinux:/# cat /sys/kernel/debug/pinctrl/2000000.pinctrl/pin
                    pinconf-groups    pingroups         pinmux-pins
                    pinconf-pins      pinmux-functions  pins
                    root@TinaLinux:/# cat /sys/kernel/debug/pinctrl/2000000.pinctrl/pinmux-pins
                    Pinmux settings per pin
                    Format: pin (name): mux_owner|gpio_owner (strict) hog?
                    pin 32 (PB0): device 2502800.twi function gpio_in group PB0
                    pin 33 (PB1): device 2502800.twi function gpio_in group PB1
                    pin 34 (PB2): UNCLAIMED
                    pin 35 (PB3): UNCLAIMED
                    pin 36 (PB4): UNCLAIMED
                    pin 37 (PB5): UNCLAIMED
                    pin 38 (PB6): UNCLAIMED
                    pin 39 (PB7): UNCLAIMED
                    pin 40 (PB8): device 2500000.uart function uart0 group PB8
                    pin 41 (PB9): device 2500000.uart function uart0 group PB9
                    pin 42 (PB10): UNCLAIMED
                    pin 43 (PB11): device 2031000.dmic function io_disabled group PB11
                    pin 44 (PB12): UNCLAIMED
                    pin 64 (PC0): device 2008000.ledc function ledc group PC0
                    pin 65 (PC1): UNCLAIMED
                    pin 66 (PC2): UNCLAIMED
                    pin 67 (PC3): UNCLAIMED
                    pin 68 (PC4): UNCLAIMED
                    pin 69 (PC5): UNCLAIMED
                    pin 70 (PC6): UNCLAIMED
                    pin 71 (PC7): UNCLAIMED
                    pin 96 (PD0): UNCLAIMED
                    pin 97 (PD1): UNCLAIMED
                    pin 98 (PD2): UNCLAIMED
                    pin 99 (PD3): UNCLAIMED
                    pin 100 (PD4): UNCLAIMED
                    pin 101 (PD5): UNCLAIMED
                    pin 102 (PD6): UNCLAIMED
                    pin 103 (PD7): UNCLAIMED
                    pin 104 (PD8): UNCLAIMED
                    pin 105 (PD9): UNCLAIMED
                    pin 106 (PD10): UNCLAIMED
                    pin 107 (PD11): UNCLAIMED
                    pin 108 (PD12): UNCLAIMED
                    pin 109 (PD13): UNCLAIMED
                    pin 110 (PD14): UNCLAIMED
                    pin 111 (PD15): UNCLAIMED
                    pin 112 (PD16): UNCLAIMED
                    pin 113 (PD17): UNCLAIMED
                    pin 114 (PD18): UNCLAIMED
                    pin 115 (PD19): UNCLAIMED
                    pin 116 (PD20): UNCLAIMED
                    pin 117 (PD21): UNCLAIMED
                    pin 118 (PD22): UNCLAIMED
                    pin 128 (PE0): device 4500000.eth function gmac0 group PE0
                    pin 129 (PE1): device 4500000.eth function gmac0 group PE1
                    pin 130 (PE2): device 4500000.eth function gmac0 group PE2
                    pin 131 (PE3): device 4500000.eth function gmac0 group PE3
                    pin 132 (PE4): device 4500000.eth function gmac0 group PE4
                    pin 133 (PE5): device 4500000.eth function gmac0 group PE5
                    pin 134 (PE6): device 4500000.eth function gmac0 group PE6
                    pin 135 (PE7): device 4500000.eth function gmac0 group PE7
                    pin 136 (PE8): device 4500000.eth function gmac0 group PE8
                    pin 137 (PE9): device 4500000.eth function gmac0 group PE9
                    pin 138 (PE10): UNCLAIMED
                    pin 139 (PE11): UNCLAIMED
                    pin 140 (PE12): UNCLAIMED
                    pin 141 (PE13): UNCLAIMED
                    pin 142 (PE14): UNCLAIMED
                    pin 143 (PE15): UNCLAIMED
                    pin 144 (PE16): GPIO 2000000.pinctrl:144
                    pin 145 (PE17): device 2031000.dmic function io_disabled group PE17
                    pin 160 (PF0): device 4020000.sdmmc function sdc0 group PF0
                    pin 161 (PF1): device 4020000.sdmmc function sdc0 group PF1
                    pin 162 (PF2): device 4020000.sdmmc function sdc0 group PF2
                    pin 163 (PF3): device 4020000.sdmmc function sdc0 group PF3
                    pin 164 (PF4): device 4020000.sdmmc function sdc0 group PF4
                    pin 165 (PF5): device 4020000.sdmmc function sdc0 group PF5
                    pin 166 (PF6): GPIO 2000000.pinctrl:166
                    pin 192 (PG0): device 4021000.sdmmc function gpio_in group PG0
                    pin 193 (PG1): device 4021000.sdmmc function gpio_in group PG1
                    pin 194 (PG2): device 4021000.sdmmc function gpio_in group PG2
                    pin 195 (PG3): device 4021000.sdmmc function gpio_in group PG3
                    pin 196 (PG4): device 4021000.sdmmc function gpio_in group PG4
                    pin 197 (PG5): device 4021000.sdmmc function gpio_in group PG5
                    pin 198 (PG6): device 2500400.uart function uart1 group PG6
                    pin 199 (PG7): device 2500400.uart function uart1 group PG7
                    pin 200 (PG8): device 2500400.uart function uart1 group PG8
                    pin 201 (PG9): device 2500400.uart function uart1 group PG9
                    pin 202 (PG10): GPIO 2000000.pinctrl:202
                    pin 203 (PG11): UNCLAIMED
                    pin 204 (PG12): GPIO 2000000.pinctrl:204
                    pin 205 (PG13): UNCLAIMED
                    pin 206 (PG14): UNCLAIMED
                    pin 207 (PG15): UNCLAIMED
                    pin 208 (PG16): UNCLAIMED
                    pin 209 (PG17): UNCLAIMED
                    pin 210 (PG18): GPIO 2000000.pinctrl:210
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                    root@TinaLinux:/#
                      lbuque LV 4 @whycan 最后由 编辑
                      @whycan 即使改成了rgb18_20_pins_a ,也没能将io初始化
                        anruliu LV 6 @lbuque 最后由 编辑
                        @lbuque lcd rgb gpio是在你们屏驱动st7701s_rgb中调用sunxi_lcd_pin_cfg(sel, 1);初始化的,可以跟下调用流程
                          感觉你的 st7701s_rgb.c 没有编译,你看下
                          find . -name st7701s_rgb.o
                            @whycan
                            编译进去了
                              lbuque LV 4 @anruliu 最后由 编辑
                              连这个printk都没有打印,好像都没有进入probe
                                https://github.com/Tina-Linux/tina-d1x-lichee-rv
                                参考这里
                                  lbuque LV 4 @YuzukiTsuru 最后由 编辑
                                  @yuzukitsuru 使用你的仓库,编译不通过
                                  也尝试针对你仓库的代码,修改以下文件
                                  tina-d1-h/device/config/chips/d1-h/configs/nezha/linux-5.4/board.dts
                                  tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/Makefile
                                  tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/Kconfig
                                  tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c
                                  tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.h
                                  tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/st7701s_rgb.c
                                  tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/st7701s_rgb.h
                                  结果 lcd的io也是没有初始化
                                    @lbuque 开机过程中在uboot初始化lcd后,kernel是不是走lcd初始化流程的,进入内核后,休眠唤醒一下lcd,看看pin脚状态有没有变化
                                    mount -t debugfs none /sys/kernel/debug
                                    cd /sys/kernel/debug/dispdbg
                                    //休眠
                                    echo suspend > command; echo disp0 > name; echo 1 > start
                                    //唤醒
                                    echo resume > command; echo disp0 > name; echo 1 > start
                                    L M 2 条回复 最后回复 回复 引用 分享 0
                                      @anruliu 感谢你的回复!
                                      使用你提供的指令,lcd部分管脚配置成功了。lcd_gpio_0、lcd_gpio_1、lcd_gpio_2、lcd_gpio_3,这四个gpio没有初始化正常。
                                      以下是执行唤醒lcd的log
                                      lcd的显示情况如下:
                                        lbuque LV 4 最后由 编辑
                                        1. 将uboot-board.dts的lcd注释掉,colorbar不在闪屏。
                                        2. lcd_gpio_0、lcd_gpio_1、lcd_gpio_2、lcd_gpio_3,依旧没能初始化。原因未知。
                                        目前显示效果如下:
                                        以下是完整的patch, 在tina v2.0验证成功。
                                        Index: tina-d1-h/device/config/chips/d1-h/configs/nezha/linux-5.4/board.dts
                                        --- tina-d1-h.orig/device/config/chips/d1-h/configs/nezha/linux-5.4/board.dts
                                        +++ tina-d1-h/device/config/chips/d1-h/configs/nezha/linux-5.4/board.dts
                                        @@ -15,7 +15,6 @@
                                         	aliases {
                                         		dsp0 = &dsp0;
                                         		dsp0_gpio_int= &dsp0_gpio_int;
                                        -		gmac0 = &gmac0;
                                         	dsp0: dsp0 {
                                        @@ -31,7 +30,7 @@
                                         	reg_vdd_cpu: vdd-cpu {
                                        -		pwms = <&pwm 0 5000 1>;
                                        +		pwms = <&pwm 0 5000 0>;
                                         		regulator-name = "vdd_cpu";
                                        @@ -47,7 +46,15 @@
                                        -		gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
                                        +		enable-active-high;
                                        +	reg_3v3: vdd_3v3 {
                                        +		compatible = "regulator-fixed";
                                        +		regulator-name = "vdd_3v3";
                                        +		regulator-min-microvolt = <3300000>;
                                        +		regulator-max-microvolt = <3300000>;
                                        +		regulator-enable-ramp-delay = <1000>;
                                         		enable-active-high;
                                        @@ -58,8 +65,7 @@
                                         &pio {
                                         	sdc0_pins_a: sdc0@0 {
                                        -		allwinner,pins = "PF0", "PF1", "PF2",
                                        -				 "PF3", "PF4", "PF5";
                                        +		allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
                                         		allwinner,function = "sdc0";
                                         		allwinner,muxsel = <2>;
                                         		allwinner,drive = <3>;
                                        @@ -74,8 +80,7 @@
                                         	sdc0_pins_b: sdc0@1 {
                                        -		pins = "PF0", "PF1", "PF2",
                                        +		pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
                                         		function = "sdc0";
                                         		drive-strength = <30>;
                                         		bias-pull-up;
                                        @@ -83,8 +88,7 @@
                                         	sdc0_pins_c: sdc0@2 {
                                         		function = "gpio_in";
                                        @@ -97,8 +101,7 @@
                                         	sdc0_pins_e: sdc0@4 {
                                        -		pins = "PF0", "PF1", "PF3",
                                        -			"PF5";
                                        +		pins = "PF0", "PF1", "PF3", "PF5";
                                         		function = "jtag";
                                         		drive-strength = <10>;
                                         		bias-pull-up;
                                        @@ -106,36 +109,31 @@
                                         	sdc1_pins_a: sdc1@0 {
                                        -		pins = "PG0", "PG1", "PG2",
                                        -		       "PG3", "PG4", "PG5";
                                        +		pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5";
                                         		function = "sdc1";
                                         		bias-pull-up;
                                         	sdc1_pins_b: sdc1@1 {
                                         	sdc2_pins_a: sdc2@0 {
                                        -		allwinner,pins = "PC2", "PC3", "PC4",
                                        -				 "PC5", "PC6", "PC7";
                                        +		allwinner,pins = "PC2", "PC3", "PC4", "PC5", "PC6", "PC7";
                                         		allwinner,function = "sdc2";
                                         		allwinner,muxsel = <3>;
                                        -		pins = "PC2", "PC3", "PC4",
                                        +		pins = "PC2", "PC3", "PC4", "PC5", "PC6", "PC7";
                                         		function = "sdc2";
                                         		bias-pull-up;
                                         	sdc2_pins_b: sdc2@1 {
                                        @@ -234,62 +232,42 @@
                                         	gmac_pins_a: gmac@0 {
                                        -		       "PE4", "PE5", "PE6", "PE7",
                                        -		       "PE8", "PE9", "PE10", "PE11",
                                        -		       "PE12", "PE13", "PE14", "PE15";
                                        +				"PE4", "PE5", "PE6", "PE7",
                                        +				"PE8", "PE9";
                                         		function = "gmac0";
                                        -		muxsel = <8>; /* for uboot driver */
                                         	gmac_pins_b: gmac@1 {
                                        +				"PE8", "PE9";
                                         	dmic_pins_a: dmic@0 {
                                         		/* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
                                        -		pins = "PE17", "PB11", "PB10", "PD17";
                                        +		pins = "PE17", "PB11";
                                         		function = "dmic";
                                         		drive-strength = <20>;
                                         		bias-disable;
                                         	dmic_pins_b: dmic@1 {
                                         		bias-disable;
                                         	daudio0_pins_a: daudio0@0 {
                                        -		/* MCLK, BCLK, LRCK */
                                        -		pins = "PE17", "PE16", "PE15";
                                        +		pins = "PE17", "PE16", "PE15", "PE14", "PE13";
                                         		function = "i2s0";
                                         		bias-disable;
                                        -	daudio0_pins_b: daudio0@1 {
                                        -		/* DIN0 */
                                        -		pins = "PE14";
                                        -		function = "i2s0_din";
                                        -		drive-strength = <20>;
                                        -		bias-disable;
                                        -	daudio0_pins_c: daudio0@2 {
                                        -		/* DOUT0 */
                                        -		pins = "PE13";
                                        -		function = "i2s0_dout";
                                        -		bias-disable;
                                        -	daudio0_pins_d: daudio0_sleep@0 {
                                        +	daudio0_pins_b: daudio0_sleep@0 {
                                        @@ -297,30 +275,13 @@
                                         	daudio1_pins_a: daudio1@0 {
                                        -		/* MCLK, LRCK, BCLK */
                                        -		pins = "PG11", "PG12", "PG13";
                                        +		pins = "PG11", "PG12", "PG13", "PG14", "PG15";
                                         		function = "i2s1";
                                         		bias-disable;
                                        -	daudio1_pins_b: daudio1@1 {
                                        -		/* DIN0 */
                                        -		pins = "PG14";
                                        -		function = "i2s1_din";
                                        -		bias-disable;
                                        -	daudio1_pins_c: daudio1@2 {
                                        -		/* DOUT0 */
                                        -		pins = "PG15";
                                        -		function = "i2s1_dout";
                                        -		bias-disable;
                                        -	daudio1_pins_d: daudio1_sleep@0 {
                                        +	daudio1_pins_b: daudio1_sleep@0 {
                                        @@ -374,7 +335,7 @@
                                         	spi0_pins_a: spi0@0 {
                                        -		pins = "PC2", "PC4", "PC5"; /* clk, mosi, miso */
                                        +		pins = "PC2", "PC4", "PC5","PC7", "PC6"; /*clk mosi miso hold wp*/
                                         		function = "spi0";
                                         		muxsel = <2>;
                                        @@ -385,7 +346,7 @@
                                         		function = "spi0";
                                         		muxsel = <2>;
                                        -		bias-pull-up;   /* cs, hold, wp should be pulled up */
                                        +		bias-pull-up;   /* only CS should be pulled up */
                                         	spi0_pins_c: spi0@2 {
                                        @@ -396,16 +357,16 @@
                                         	spi1_pins_a: spi1@0 {
                                        -		pins = "PD11", "PD12", "PD13"; /* clk, mosi, miso */
                                        +		pins = "PD11", "PD12", "PD13","PD14", "PD15"; /*clk mosi miso hold wp*/
                                         		function = "spi1";
                                         	spi1_pins_b: spi1@1 {
                                        -		pins = "PD10", "PD14", "PD15";
                                        +		pins = "PD10";
                                         		function = "spi1";
                                        +		bias-pull-up;   // only CS should be pulled up
                                         	spi1_pins_c: spi1@2 {
                                        @@ -447,9 +408,9 @@
                                         	pwm2_pin_b: pwm2@1 {
                                         		pins = "PD18";
                                        -		function = "gpio_out";
                                        +		function = "gpio_in";
                                         	pwm7_pin_a: pwm7@0 {
                                         		pins = "PD22";
                                         		function = "pwm7";
                                        @@ -461,7 +422,6 @@
                                         		pins = "PD22";
                                         	s_cir0_pins_a: s_cir@0 {
                                         		pins = "PB12";
                                        @@ -486,6 +446,45 @@
                                         		pins = "PB0";
                                        +	rgb18_20_pins_a: rgb18_20@0 {
                                        +		pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
                                        +				"PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
                                        +				"PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
                                        +				"PD18", "PD19", "PD20", "PD21";
                                        +		function = "lcd0";
                                        +		drive-strength = <20>;
                                        +		bias-disable;
                                        +	rgb18_20_pins_b: rgb18_20@1 {
                                        +		function = "io_disabled";
                                        +		bias-disable;
                                        +	rgb18_10_pins_a: rgb18_10@0 {
                                        +		drive-strength = <10>;
                                        +		bias-disable;
                                        +	rgb18_10_pins_b: rgb18_10@1 {
                                        +		bias-disable;
                                         &uart0 {
                                        @@ -510,11 +509,11 @@
                                         &uart3 {
                                        -	compatible = "allwinner,sun20iw1-dsp-uart";
                                        +	/*compatible = "allwinner,sun20iw1-dsp-uart";*/
                                         	pinctrl-0 = <&uart3_pins_a>;
                                         	pinctrl-1 = <&uart3_pins_a>;
                                        -	status = "okay";
                                        +	status = "disabled";
                                         &soc {
                                        @@ -557,12 +556,12 @@
                                         		chip_en;
                                         		power_en;
                                        -		pinctrl-0 = <&wlan_pins_a>;
                                        -		pinctrl-names = "default";
                                         		status        = "okay";
                                         		wlan: wlan@0 {
                                        +			pinctrl-0 = <&wlan_pins_a>;
                                        +			pinctrl-names = "default";
                                         			clock-names = "32k-fanout1";
                                         			wlan_busnum    = <0x1>;
                                        @@ -578,6 +577,8 @@
                                         		bt: bt@0 {
                                         			/*bt_power_num = <0x01>;*/
                                        @@ -590,13 +591,13 @@
                                        -	btlpm: btlpm@0 {
                                        +	/*btlpm: btlpm@0 {
                                         		uart_index  = <0x1>;
                                         		bt_wake     = <&pio PG 16 GPIO_ACTIVE_HIGH>;
                                         		bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
                                         		status      = "okay";
                                         	addr_mgt: addr_mgt@0 {
                                        @@ -750,7 +751,7 @@ tvd_row*tvd_column is the total tvd chan
                                         	mic2gain 	= <0x13>;
                                         	mic3gain 	= <0x13>;
                                        -        /* 0x1:DAP_HP_EN; 0x2:DAP_SPK_EN; 0x3:DAP_HPSPK_EN */
                                        +	/* 0x1:DAP_HP_EN; 0x2:DAP_SPK_EN; 0x3:DAP_HPSPK_EN */
                                         	adcdrc_cfg 	= <0x0>;
                                         	adchpf_cfg 	= <0x1>;
                                         	dacdrc_cfg 	= <0x0>;
                                        @@ -826,8 +827,8 @@ tvd_row*tvd_column is the total tvd chan
                                         	pcm_lrck_period = <0x80>;
                                         	slot_width_select = <0x20>;
                                        -	pinctrl-0       = <&daudio0_pins_a &daudio0_pins_b &daudio0_pins_c>;
                                        -	pinctrl-1       = <&daudio0_pins_d>;
                                        +	pinctrl-0       = <&daudio0_pins_a>;
                                        +	pinctrl-1       = <&daudio0_pins_b>;
                                         	pinctrl_used	= <0x0>;
                                        @@ -853,18 +854,18 @@ tvd_row*tvd_column is the total tvd chan
                                         &daudio1 {
                                        -	mclk_div 	= <0x01>;
                                        -	frametype 	= <0x00>;
                                        -	tdm_config 	= <0x01>;
                                        -	sign_extend 	= <0x00>;
                                        -	msb_lsb_first 	= <0x00>;
                                        -	pcm_lrck_period = <0x80>;
                                        +	mclk_div          = <0x01>;
                                        +	frametype         = <0x00>;
                                        +	tdm_config        = <0x01>;
                                        +	sign_extend       = <0x00>;
                                        +	msb_lsb_first     = <0x00>;
                                        +	pcm_lrck_period   = <0x80>;
                                        -	pinctrl-names   = "default", "sleep";
                                        -	pinctrl-0       = <&daudio1_pins_a &daudio1_pins_b &daudio1_pins_c>;
                                        -	pinctrl-1       = <&daudio1_pins_d>;
                                        -	pinctrl_used	= <0x0>;
                                        -	status = "disabled";
                                        +	pinctrl-names     = "default", "sleep";
                                        +	pinctrl-0         = <&daudio1_pins_a>;
                                        +	pinctrl-1         = <&daudio1_pins_b>;
                                        +	pinctrl_used      = <0x0>;
                                         &sounddaudio1 {
                                        @@ -930,12 +931,10 @@ tvd_row*tvd_column is the total tvd chan
                                         &usbc0 {
                                         	device_type = "usbc0";
                                        -	usb_port_type = <0x2>;
                                        +	usb_port_type = <0x0>;
                                         	usb_detect_type = <0x1>;
                                         	usb_detect_mode = <0>;
                                        -	usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
                                         	enable-active-high;
                                        -	usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
                                         	usb_wakeup_suspend = <0>;
                                         	usb_serial_unique = <0>;
                                        @@ -997,43 +996,20 @@ tvd_row*tvd_column is the total tvd chan
                                         	dma-names = "tx", "rx";
                                        -	/* pcf8574-usage:
                                        -	 * only use gpio0~7, 0 means PP0.
                                        -	 * pin set:
                                        -	 * gpios = <&pcf8574 0 GPIO_ACTIVE_LOW>;
                                        -	 * interrupt set:
                                        -	 * interrupt-parent = <&pcf8574>;
                                        -	 * interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
                                        -	pcf8574: gpio@38 {
                                        -		compatible = "nxp,pcf8574";
                                        -		reg = <0x38>;
                                        -		gpio_base = <2020>;
                                        -		gpio-controller;
                                        -		#gpio-cells = <2>;
                                        -		interrupt-controller;
                                        -		#interrupt-cells = <2>;
                                        -		interrupt-parent = <&pio>;
                                        -		interrupts = <PB 2 IRQ_TYPE_EDGE_FALLING>;
                                        +	focaltech@48{
                                        +		compatible = "focaltech,fts";
                                        +		reg = <0x48>;
                                        +		interrupt-parent = <&pio>;
                                        +		interrupts = <PG 14 IRQ_TYPE_LEVEL_LOW>;
                                        +		focaltech,reset-gpio = <&pio PG 15 GPIO_ACTIVE_HIGH>;
                                        +		focaltech,irq-gpio = <&pio PG 14 IRQ_TYPE_LEVEL_LOW>;
                                        +		focaltech,max-touch-number = <2>;
                                        +		focaltech,display-coords =  <0 0 480 480>;
                                        +		focaltech,reg_vdd = <&reg_3v3>;
                                        +		focaltech,reg_avdd = <&reg_3v3>;
                                        -	ctp@14 {
                                        -		compatible = "allwinner,goodix";
                                        -		device_type = "ctp";
                                        -		reg = <0x14>;
                                        -		ctp_name = "gt9xxnew_ts";
                                        -		ctp_twi_id = <0x2>;
                                        -		ctp_twi_addr = <0x14>;
                                        -		ctp_screen_max_x = <0x320>;
                                        -		ctp_screen_max_y = <0x500>;
                                        -		ctp_revert_x_flag = <0x0>;
                                        -		ctp_revert_y_flag = <0x1>;
                                        -		ctp_exchange_x_y_flag = <0x0>;
                                        -		ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
                                        -		ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
                                         &twi3 {
                                        @@ -1045,14 +1021,12 @@ tvd_row*tvd_column is the total tvd chan
                                         &gmac0 {
                                        -	phy-mode = "rgmii";
                                        +	phy-mode = "rmii";
                                         	use_ephy25m = <1>;
                                         	pinctrl-0 = <&gmac_pins_a>;
                                         	pinctrl-1 = <&gmac_pins_b>;
                                         	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
                                        -	tx-delay = <3>; /*2~4*/
                                        -	rx-delay = <0>;
                                        @@ -1064,7 +1038,7 @@ tvd_row*tvd_column is the total tvd chan
                                         	spi_slave_mode = <0>;
                                         	spi0_cs_number = <1>;
                                        -        spi0_cs_bitmap = <1>;
                                        +	spi0_cs_bitmap = <1>;
                                         	spi-nand@0 {
                                        @@ -1083,21 +1057,9 @@ tvd_row*tvd_column is the total tvd chan
                                         	pinctrl-1 = <&spi1_pins_c>;
                                        -	spi1_cs_number = <1>;
                                        -	spi1_cs_bitmap = <1>;
                                        -	spi_dbi_enable = <1>;
                                         	spi_board1@0 {
                                        -		device_type = "spi-dbi";
                                        -		compatible = "sunxi,spidbi";
                                        -		spi-max-frequency = <0x5f5e100>;
                                        -		reg = <0x0>;
                                        -		spi-rx-bus-width = <0x4>;
                                        -		spi-tx-bus-width = <0x4>;
                                        -		status = "okay";
                                        -	/* spi_board1@0 {
                                         		device_type = "spi_board1";
                                         		compatible = "rohm,dh2228fv";
                                        @@ -1105,7 +1067,7 @@ tvd_row*tvd_column is the total tvd chan
                                         &ledc {
                                        @@ -1279,55 +1241,54 @@ pull up or pull down(default 0), driver
                                         &lcd0 {
                                        -	lcd_used            = <1>;
                                        +	lcd_used             = <1>;
                                        +	lcd_driver_name      = "st7701s_rgb";
                                        +	lcd_if               = <0>;
                                        +	lcd_hv_if            = <0>;
                                        -	lcd_driver_name     = "tft08006";
                                        -	lcd_backlight       = <100>;
                                        -	lcd_if              = <4>;
                                        -	lcd_x               = <800>;
                                        -	lcd_y               = <1280>;
                                        -	lcd_width           = <52>;
                                        -	lcd_height          = <52>;
                                        -	lcd_dclk_freq       = <70>;
                                        -	lcd_pwm_used        = <1>;
                                        -	lcd_pwm_ch          = <2>;
                                        -	lcd_pwm_freq        = <1000>;
                                        -	lcd_pwm_pol         = <0>;
                                        -	lcd_pwm_max_limit   = <255>;
                                        -	lcd_hbp             = <32>;
                                        -	lcd_ht              = <868>;
                                        -	lcd_hspw            = <4>;
                                        -	lcd_vbp             = <12>;
                                        -	lcd_vt              = <1311>;
                                        -	lcd_vspw            = <4>;
                                        -	lcd_dsi_if          = <0>;
                                        -	lcd_dsi_lane        = <4>;
                                        -	lcd_lvds_if         = <0>;
                                        -	lcd_lvds_colordepth = <0>;
                                        -	lcd_lvds_mode       = <0>;
                                        -	lcd_frm             = <0>;
                                        -	lcd_hv_clk_phase    = <0>;
                                        -	lcd_hv_sync_polarity= <0>;
                                        -	lcd_io_phase        = <0x0000>;
                                        -	lcd_gamma_en        = <0>;
                                        -	lcd_bright_curve_en = <0>;
                                        -	lcd_cmap_en         = <0>;
                                        -	lcd_fsync_en        = <0>;
                                        -	lcd_fsync_act_time  = <1000>;
                                        -	lcd_fsync_dis_time  = <1000>;
                                        -	lcd_fsync_pol       = <0>;
                                        -	deu_mode            = <0>;
                                        -	lcdgamma4iep        = <22>;
                                        -	smart_color         = <90>;
                                        -	lcd_gpio_0 =  <&pio PG 13 GPIO_ACTIVE_HIGH>;
                                        -	pinctrl-0 = <&dsi4lane_pins_a>;
                                        -	pinctrl-1 = <&dsi4lane_pins_b>;
                                        +	lcd_width            = <70>;
                                        +	lcd_height           = <72>;
                                        +	lcd_x                = <480>;
                                        +	lcd_y                = <480>;
                                        +	lcd_dclk_freq        = <19>;
                                        +	lcd_hbp              = <60>;
                                        +	lcd_ht               = <612>;
                                        +	lcd_hspw             = <12>;
                                        +	lcd_vbp              = <18>;
                                        +	lcd_vt               = <520>;
                                        +	lcd_vspw             = <4>;
                                        +	lcd_backlight        = <50>;
                                        +	lcd_pwm_used         = <1>;
                                        +	lcd_pwm_ch           = <7>;
                                        +	lcd_pwm_freq         = <20000>;
                                        +	lcd_pwm_pol          = <1>;
                                        +	lcd_bright_curve_en  = <0>;
                                        +	lcd_frm              = <1>;
                                        +	lcd_io_phase         = <0x0000>;
                                        +	lcd_gamma_en         = <0>;
                                        +	lcd_cmap_en          = <0>;
                                        +	lcd_hv_clk_phase     = <0>;
                                        +	lcd_hv_sync_polarity = <0>;
                                        +	lcd_rb_swap          = <0>;
                                        +	lcd_power            = "vcc-lcd";
                                        +	lcd_pin_power        = "vcc-pd";
                                        +	lcd_gpio_0           = <&pio PG 13 GPIO_ACTIVE_HIGH>;
                                        +	lcd_gpio_1           = <&pio PE 14 GPIO_ACTIVE_HIGH>;
                                        +	lcd_gpio_2           = <&pio PE 12 GPIO_ACTIVE_HIGH>;
                                        +	lcd_gpio_3           = <&pio PE 15 GPIO_ACTIVE_HIGH>;
                                        +	lcd_gpio_0           = <&pio PG 13 1 1 1 1>;
                                        +	lcd_gpio_1           = <&pio PE 14 1 1 1 1>;
                                        +	lcd_gpio_2           = <&pio PE 12 1 1 1 1>;
                                        +	lcd_gpio_3           = <&pio PE 15 1 1 1 1>;
                                        +	pinctrl-0            = <&rgb18_pins_a>;
                                        +	pinctrl-1            = <&rgb18_pins_b>;
                                        +	status               = "okay";
                                         &hdmi {
                                        @@ -1357,14 +1318,12 @@ pull up or pull down(default 0), driver
                                         &pwm7 {
                                         	pinctrl-0 = <&pwm7_pin_a>;
                                         	pinctrl-1 = <&pwm7_pin_b>;
                                         &rtp {
                                        @@ -1400,60 +1359,3 @@ pull up or pull down(default 0), driver
                                         	pinctrl-1 = <&ir1_pins_b>;
                                        -/* &lcd_fb0 {
                                        -	lcd_used = <1>;
                                        -	lcd_driver_name = "kld35512";
                                        -	lcd_if = <1>;
                                        -	lcd_dbi_if = <4>;
                                        -	lcd_data_speed = <60>;
                                        -	lcd_spi_bus_num = <1>;
                                        -	lcd_x = <320>;
                                        -	lcd_y = <480>;
                                        -	lcd_pixel_fmt = <10>;
                                        -	lcd_dbi_fmt = <2>;
                                        -	lcd_rgb_order = <0>;
                                        -	lcd_width = <60>;
                                        -	lcd_height = <95>;
                                        -	lcd_pwm_ch = <7>;
                                        -	lcd_pwm_freq = <5000>;
                                        -	lcd_pwm_pol = <1>;
                                        -	lcd_frm = <1>;
                                        -	lcd_gamma_en = <1>;
                                        -	fb_buffer_num = <2>;
                                        -	lcd_fps = <40>;
                                        -	lcd_dbi_te = <1>;
                                        -	lcd_dbi_clk_mode = <1>;
                                        -	lcd_gpio_0 = <&pio PC 0 GPIO_ACTIVE_HIGH>;
                                        -	status = "okay";
                                        -/* &lcd_fb0 {
                                        -	lcd_used = <1>;
                                        -	lcd_driver_name = "kld2844b";
                                        -	lcd_if = <1>;
                                        -	lcd_dbi_if = <4>;
                                        -	lcd_x = <240>;
                                        -	lcd_y = <320>;
                                        -	lcd_width = <60>;
                                        -	lcd_pwm_ch = <7>;
                                        -	lcd_pixel_fmt = <0>;
                                        -	lcd_dbi_fmt = <3>;
                                        -	lcd_frm = <1>;
                                        -	lcd_dbi_te = <1>;
                                        -	lcd_fps = <60>;
                                        -	status = "okay";
                                        Index: tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/Makefile
                                        --- tina-d1-h.orig/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/Makefile
                                        +++ tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/Makefile
                                        @@ -45,6 +45,7 @@ disp-$(CONFIG_LCD_SUPPORT_LH219WQ1) += l
                                         disp-$(CONFIG_LCD_SUPPORT_ST7789V) += lcd/st7789v.o
                                         disp-$(CONFIG_LCD_SUPPORT_ST7796S) += lcd/st7796s.o
                                         disp-$(CONFIG_LCD_SUPPORT_ST7701S) += lcd/st7701s.o
                                        +disp-$(CONFIG_LCD_SUPPORT_ST7701S_RGB) += lcd/st7701s_rgb.o
                                         disp-$(CONFIG_LCD_SUPPORT_WTL096601G03) += lcd/wtl096601g03.o
                                         disp-$(CONFIG_LCD_SUPPORT_T30P106) += lcd/t30p106.o
                                         disp-$(CONFIG_LCD_SUPPORT_TO20T20000) += lcd/to20t20000.o
                                        Index: tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/Kconfig
                                        --- tina-d1-h.orig/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/Kconfig
                                        +++ tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/Kconfig
                                        @@ -103,6 +103,12 @@ config LCD_SUPPORT_ST7701S
                                         	---help---
                                         		If you want to support ST7701S panel for display driver, select it.
                                        +config LCD_SUPPORT_ST7701S_RGB
                                        +	bool "LCD support ST7701S RGB panel"
                                        +	default n
                                        +	---help---
                                        +		If you want to support ST7701S_RGB panel for display driver, select it.
                                         config LCD_SUPPORT_T30P106
                                         	bool "LCD support T30P106 panel"
                                         	default n
                                        @@ -210,4 +216,3 @@ config LCD_SUPPORT_K080_IM2HYL802R_800X1
                                         	default y
                                         	---help---
                                         		If you want to support K080_IM2HYL802R_800X1280 panel for display driver, select it.
                                        Index: tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c
                                        --- tina-d1-h.orig/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c
                                        +++ tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c
                                        @@ -80,6 +80,9 @@ struct __lcd_panel *panel_array[] = {
                                         #ifdef CONFIG_LCD_SUPPORT_ST7701S
                                         	&st7701s_panel,
                                        +#ifdef CONFIG_LCD_SUPPORT_ST7701S_RGB
                                        +	&st7701s_rgb_panel,
                                        +#endif
                                         #ifdef CONFIG_LCD_SUPPORT_T30P106
                                         	&t30p106_panel,
                                        @@ -136,6 +139,7 @@ void lcd_set_panel_funs(void)
                                         	int i;
                                         	for (i = 0; panel_array[i] != NULL; i++) {
                                        +		printk("panel name: %s\n", panel_array[i]->name);
                                         		sunxi_lcd_set_panel_funs(panel_array[i]->name,
                                         					 &panel_array[i]->func);
                                        Index: tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.h
                                        --- tina-d1-h.orig/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.h
                                        +++ tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.h
                                        @@ -125,6 +125,9 @@ extern struct __lcd_panel st7796s_panel;
                                         extern struct __lcd_panel st7701s_panel;
                                        +extern struct __lcd_panel st7701s_rgb_panel;
                                        +#endif
                                         extern struct __lcd_panel t30p106_panel;
                                        Index: tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/st7701s_rgb.c
                                        --- /dev/null
                                        +++ tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/st7701s_rgb.c
                                        @@ -0,0 +1,517 @@
                                        + * drivers/video/fbdev/sunxi/disp2/disp/lcd/st7701s_rgb.c
                                        + * Copyright (c) 2018-2021 Allwinnertech Co., Ltd.
                                        + * Author: zepan <zepan@sipeed.com>
                                        + * This software is licensed under the terms of the GNU General Public
                                        + * License version 2, as published by the Free Software Foundation, and
                                        + * may be copied, distributed, and modified under those terms.
                                        + * This program is distributed in the hope that it will be useful,
                                        + * but WITHOUT ANY WARRANTY; without even the implied warranty of
                                        + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                                        + * GNU General Public License for more details.
                                        +&lcd0 {
                                        +	lcd_used            = <1>;
                                        +	lcd_backlight       = <100>;
                                        +	lcd_if              = <2>;
                                        +	lcd_x               = <480>;
                                        +	lcd_y               = <480>;
                                        +	lcd_width           = <70>;
                                        +	lcd_dclk_freq       = <30>;
                                        +	lcd_pwm_ch          = <7>;
                                        +	lcd_pwm_freq        = <19000>;
                                        +	lcd_pwm_pol         = <0>;
                                        +	lcd_pwm_max_limit   = <255>;
                                        +	lcd_hbp             = <60>;
                                        +	lcd_ht              = <612>;
                                        +	lcd_hspw            = <12>;
                                        +	lcd_vbp             = <18>;
                                        +	lcd_vt              = <520>;
                                        +	lcd_vspw            = <4>;
                                        +	lcd_dsi_if          = <0>;
                                        +	lcd_dsi_lane        = <4>;
                                        +	lcd_lvds_if         = <0>;
                                        +	lcd_lvds_colordepth = <0>;
                                        +	lcd_lvds_mode       = <0>;
                                        +	lcd_frm             = <0>;
                                        +	lcd_hv_sync_polarity= <0>;
                                        +	lcd_fsync_en        = <0>;
                                        +	lcd_fsync_act_time  = <1000>;
                                        +	lcd_fsync_dis_time  = <1000>;
                                        +	lcd_fsync_pol       = <0>;
                                        +	deu_mode            = <0>;
                                        +	lcdgamma4iep        = <22>;
                                        +	smart_color         = <90>;
                                        +	lcd_gpio_0 = <&pio PG 13 GPIO_ACTIVE_HIGH>;RST
                                        +	lcd_gpio_1 = <&pio PE 14 GPIO_ACTIVE_HIGH>;CS
                                        +	lcd_gpio_2 = <&pio PE 12 GPIO_ACTIVE_HIGH>;SDA
                                        +	lcd_gpio_3 = <&pio PE 15 GPIO_ACTIVE_HIGH>;SCK
                                        +#include "st7701s_rgb.h"
                                        +#include "default_panel.h"
                                        +//s32 sunxi_lcd_gpio_set_value(u32 screen_id, u32 io_index, u32 value)
                                        +#define st7701s_spi_scl_1   sunxi_lcd_gpio_set_value(0, 3, 1)
                                        +#define st7701s_spi_scl_0   sunxi_lcd_gpio_set_value(0, 3, 0)
                                        +#define st7701s_spi_sdi_1   sunxi_lcd_gpio_set_value(0, 2, 1)
                                        +#define st7701s_spi_sdi_0   sunxi_lcd_gpio_set_value(0, 2, 0)
                                        +#define st7701s_spi_cs_1    sunxi_lcd_gpio_set_value(0, 1, 1)
                                        +#define st7701s_spi_cs_0    sunxi_lcd_gpio_set_value(0, 1, 0)
                                        +#define st7701s_spi_reset_1 sunxi_lcd_gpio_set_value(0, 0, 1)
                                        +#define st7701s_spi_reset_0 sunxi_lcd_gpio_set_value(0, 0, 0)
                                        +static void LCD_power_on(u32 sel);
                                        +static void LCD_power_off(u32 sel);
                                        +static void LCD_bl_open(u32 sel);
                                        +static void LCD_bl_close(u32 sel);
                                        +static void LCD_panel_init(u32 sel);
                                        +static void LCD_panel_exit(u32 sel);
                                        +static void LCD_cfg_panel_info(struct panel_extend_para *info)
                                        +	u32 i = 0, j = 0;
                                        +	u32 items;
                                        +	u8 lcd_gamma_tbl[][2] = {
                                        +		/* {input value, corrected value} */
                                        +		{0, 0},
                                        +		{15, 15},
                                        +		{30, 30},
                                        +		{45, 45},
                                        +		{60, 60},
                                        +		{75, 75},
                                        +		{90, 90},
                                        +		{105, 105},
                                        +		{120, 120},
                                        +		{135, 135},
                                        +		{150, 150},
                                        +		{165, 165},
                                        +		{180, 180},
                                        +		{195, 195},
                                        +		{210, 210},
                                        +		{225, 225},
                                        +		{240, 240},
                                        +		{255, 255},
                                        +	u32 lcd_cmap_tbl[2][3][4] = {
                                        +			{LCD_CMAP_G0, LCD_CMAP_B1, LCD_CMAP_G2, LCD_CMAP_B3},
                                        +			{LCD_CMAP_B0, LCD_CMAP_R1, LCD_CMAP_B2, LCD_CMAP_R3},
                                        +			{LCD_CMAP_R0, LCD_CMAP_G1, LCD_CMAP_R2, LCD_CMAP_G3},
                                        +			{LCD_CMAP_B3, LCD_CMAP_G2, LCD_CMAP_B1, LCD_CMAP_G0},
                                        +			{LCD_CMAP_R3, LCD_CMAP_B2, LCD_CMAP_R1, LCD_CMAP_B0},
                                        +			{LCD_CMAP_G3, LCD_CMAP_R2, LCD_CMAP_G1, LCD_CMAP_R0},
                                        +	items = sizeof(lcd_gamma_tbl) / 2;
                                        +	for (i = 0; i < items - 1; i++) {
                                        +		u32 num = lcd_gamma_tbl[i + 1][0] - lcd_gamma_tbl[i][0];
                                        +		for (j = 0; j < num; j++) {
                                        +			u32 value = 0;
                                        +			value = lcd_gamma_tbl[i][1] + ((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1]) * j) / num;
                                        +			info->lcd_gamma_tbl[lcd_gamma_tbl[i][0] + j] = (value << 16) + (value << 8) + value;
                                        +	info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) + (lcd_gamma_tbl[items - 1][1] << 8) + lcd_gamma_tbl[items - 1][1];
                                        +	memcpy(info->lcd_cmap_tbl, lcd_cmap_tbl, sizeof(lcd_cmap_tbl));
                                        +static s32 LCD_open_flow(u32 sel)
                                        +    printk("=====================LCD_open_flow\n");
                                        +	/* open lcd power, and delay 50ms */
                                        +	LCD_OPEN_FUNC(sel, LCD_power_on, 20);
                                        +	/* open lcd power, than delay 200ms */
                                        +	LCD_OPEN_FUNC(sel, LCD_panel_init, 20);
                                        +	/* open lcd controller, and delay 100ms */
                                        +	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 100);
                                        +	/* open lcd backlight, and delay 0ms */
                                        +	LCD_OPEN_FUNC(sel, LCD_bl_open, 0);
                                        +	return 0;
                                        +static s32 LCD_close_flow(u32 sel)
                                        +	/* close lcd backlight, and delay 0ms */
                                        +	LCD_CLOSE_FUNC(sel, LCD_bl_close, 0);
                                        +	/* close lcd controller, and delay 0ms */
                                        +	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
                                        +	LCD_CLOSE_FUNC(sel, LCD_panel_exit, 200);
                                        +	/* close lcd power, and delay 500ms */
                                        +	LCD_CLOSE_FUNC(sel, LCD_power_off, 500);
                                        +	return 0;
                                        +	printk("=====================LCD_power_on\n");
                                        +	/* config lcd_power pin to open lcd power0 */
                                        +	sunxi_lcd_power_enable(sel, 0);
                                        +	sunxi_lcd_pin_cfg(sel, 1);
                                        +	sunxi_lcd_pin_cfg(sel, 0);
                                        +	/* config lcd_power pin to close lcd power0 */
                                        +	sunxi_lcd_power_disable(sel, 0);
                                        +	printk("=====================LCD_bl_open\n");
                                        +	sunxi_lcd_pwm_enable(sel);
                                        +	sunxi_lcd_backlight_enable(sel);
                                        +	/* config lcd_bl_en pin to close lcd backlight */
                                        +	sunxi_lcd_backlight_disable(sel);
                                        +	sunxi_lcd_pwm_disable(sel);
                                        +//three line 9bit mode
                                        +static void LCD_WRITE_DATA(u32 value)
                                        +	u32 i;
                                        +	st7701s_spi_cs_0;
                                        +	st7701s_spi_sdi_1;
                                        +	st7701s_spi_scl_0;
                                        +	sunxi_lcd_delay_us(10);
                                        +	st7701s_spi_scl_1;
                                        +	for (i = 0; i < 8; i++) {
                                        +		if (value & 0x80)
                                        +		else
                                        +			st7701s_spi_sdi_0;
                                        +		value <<= 1;
                                        +	st7701s_spi_cs_1;
                                        +static void LCD_WRITE_COMMAND(u32 value)
                                        +	u32 i;
                                        +	st7701s_spi_cs_0;
                                        +		if (value & 0x80)
                                        +		else
                                        +		value <<= 1;
                                        +	st7701s_spi_cs_1;
                                        +	printk("=====================LCD_panel_init\n");
                                        +	LCD_WRITE_COMMAND(0xFF);
                                        +	LCD_WRITE_DATA(0x77);
                                        +	LCD_WRITE_DATA(0x01);
                                        +	LCD_WRITE_DATA(0x00);
                                        +	LCD_WRITE_DATA(0x10);
                                        +	LCD_WRITE_COMMAND(0xC0);
                                        +	LCD_WRITE_DATA(0x3B);
                                        +	LCD_WRITE_COMMAND(0xC1);
                                        +	LCD_WRITE_DATA(0x0D);
                                        +	LCD_WRITE_DATA(0x02);
                                        +	LCD_WRITE_COMMAND(0xC2);
                                        +	LCD_WRITE_DATA(0x21);
                                        +	LCD_WRITE_DATA(0x08);
                                        +	// RGB Interface Setting
                                        +	// LCD_WRITE_COMMAND(0xC3);
                                        +	// LCD_WRITE_DATA(0x02);
                                        +	LCD_WRITE_COMMAND(0xCD);
                                        +	LCD_WRITE_DATA(0x18);//0F 08-OK  D0-D18
                                        +	LCD_WRITE_COMMAND(0xB0);
                                        +	LCD_WRITE_DATA(0x11);
                                        +	LCD_WRITE_DATA(0x0E);
                                        +	LCD_WRITE_DATA(0x06);
                                        +	LCD_WRITE_DATA(0x07);
                                        +	LCD_WRITE_DATA(0x22);
                                        +	LCD_WRITE_DATA(0x04);
                                        +	LCD_WRITE_DATA(0x12);
                                        +	LCD_WRITE_DATA(0x0F);
                                        +	LCD_WRITE_DATA(0xAA);
                                        +	LCD_WRITE_DATA(0x31);
                                        +	LCD_WRITE_COMMAND(0xB1);
                                        +	LCD_WRITE_DATA(0x19);
                                        +	LCD_WRITE_DATA(0xA9);
                                        +	LCD_WRITE_DATA(0x32);
                                        +	LCD_WRITE_DATA(0x60);
                                        +	LCD_WRITE_DATA(0x30);
                                        +	LCD_WRITE_COMMAND(0xB2);
                                        +	LCD_WRITE_DATA(0x87);
                                        +	LCD_WRITE_COMMAND(0xB3);
                                        +	LCD_WRITE_DATA(0x80);
                                        +	LCD_WRITE_COMMAND(0xB5);
                                        +	LCD_WRITE_DATA(0x49);
                                        +	LCD_WRITE_COMMAND(0xB7);
                                        +	LCD_WRITE_DATA(0x85);
                                        +	LCD_WRITE_COMMAND(0xB8);
                                        +	LCD_WRITE_DATA(0x78);
                                        +	sunxi_lcd_delay_ms(20);
                                        +	LCD_WRITE_COMMAND(0xE0);
                                        +	LCD_WRITE_DATA(0x1B);
                                        +	LCD_WRITE_COMMAND(0xE1);
                                        +	LCD_WRITE_DATA(0xA0);
                                        +	LCD_WRITE_DATA(0x44);
                                        +	LCD_WRITE_COMMAND(0xE2);
                                        +	LCD_WRITE_DATA(0xED);
                                        +	LCD_WRITE_DATA(0xEC);
                                        +	LCD_WRITE_COMMAND(0xE3);
                                        +	LCD_WRITE_COMMAND(0xE4);
                                        +	LCD_WRITE_COMMAND(0xE5);
                                        +	LCD_WRITE_DATA(0x0A);
                                        +	LCD_WRITE_DATA(0xE9);
                                        +	LCD_WRITE_DATA(0xD8);
                                        +	LCD_WRITE_DATA(0x0C);
                                        +	LCD_WRITE_DATA(0xEB);
                                        +	LCD_WRITE_DATA(0xEF);
                                        +	LCD_WRITE_COMMAND(0xE6);
                                        +	LCD_WRITE_COMMAND(0xE7);
                                        +	LCD_WRITE_COMMAND(0xE8);
                                        +	LCD_WRITE_DATA(0x09);
                                        +	LCD_WRITE_DATA(0xE8);
                                        +	LCD_WRITE_DATA(0x0B);
                                        +	LCD_WRITE_DATA(0xEA);
                                        +	LCD_WRITE_DATA(0xEE);
                                        +	LCD_WRITE_COMMAND(0xEB);
                                        +	LCD_WRITE_DATA(0xE4);
                                        +	LCD_WRITE_DATA(0x88);
                                        +	LCD_WRITE_DATA(0x40);
                                        +	LCD_WRITE_COMMAND(0xEC);
                                        +	LCD_WRITE_DATA(0x3C);
                                        +	LCD_WRITE_COMMAND(0xED);
                                        +	LCD_WRITE_DATA(0xAB);
                                        +	LCD_WRITE_DATA(0x89);
                                        +	LCD_WRITE_DATA(0x76);
                                        +	LCD_WRITE_DATA(0x54);
                                        +	LCD_WRITE_DATA(0xFF);
                                        +	LCD_WRITE_DATA(0x20);
                                        +	LCD_WRITE_DATA(0x45);
                                        +	LCD_WRITE_DATA(0x67);
                                        +	LCD_WRITE_DATA(0x98);
                                        +	LCD_WRITE_DATA(0xBA);
                                        +	LCD_WRITE_COMMAND(0x3A);
                                        +	LCD_WRITE_DATA(0x66);
                                        +	LCD_WRITE_COMMAND(0x36);
                                        +	LCD_WRITE_COMMAND(0x21);
                                        +	LCD_WRITE_COMMAND(0x11);
                                        +	sunxi_lcd_delay_ms(120);
                                        +	LCD_WRITE_COMMAND(0x29);
                                        +	return;
                                        +	return;
                                        +/* sel: 0:lcd0; 1:lcd1 */
                                        +static s32 LCD_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
                                        +	return 0;
                                        +struct __lcd_panel st7701s_rgb_panel = {
                                        +	/* panel driver name, must mach the lcd_drv_name in sys_config.fex */
                                        +	.name = "st7701s_rgb",
                                        +	.func = {
                                        +		.cfg_panel_info = LCD_cfg_panel_info,
                                        +		.cfg_open_flow = LCD_open_flow,
                                        +		.cfg_close_flow = LCD_close_flow,
                                        +		.lcd_user_defined_func = LCD_user_defined_func,
                                        \ No newline at end of file
                                        Index: tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/st7701s_rgb.h
                                        --- /dev/null
                                        +++ tina-d1-h/lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/lcd/st7701s_rgb.h
                                        @@ -0,0 +1,18 @@
                                        + * Allwinner SoCs display driver.
                                        + * Copyright (C) 2021 Sipeed.
                                        + * This file is licensed under the terms of the GNU General Public
                                        + * License version 2.  This program is licensed "as is" without any
                                        + * warranty of any kind, whether express or implied.
                                        +#ifndef __ST7701S_RGB_PANEL_H__
                                        +#define __ST7701S_RGB_PANEL_H__
                                        +#include "panels.h"
                                        +#endif
                                        Index: tina-d1-h/device/config/chips/d1-h/configs/nezha/linux-5.4/config-5.4
                                        --- tina-d1-h.orig/device/config/chips/d1-h/configs/nezha/linux-5.4/config-5.4
                                        +++ tina-d1-h/device/config/chips/d1-h/configs/nezha/linux-5.4/config-5.4
                                        @@ -2517,6 +2517,7 @@ CONFIG_LCD_SUPPORT_HE0801A068=y
                                         # CONFIG_LCD_SUPPORT_ST7789V is not set
                                         # CONFIG_LCD_SUPPORT_ST7796S is not set
                                         # CONFIG_LCD_SUPPORT_ST7701S is not set
                                        +CONFIG_LCD_SUPPORT_ST7701S_RGB=y
                                         # CONFIG_LCD_SUPPORT_T30P106 is not set
                                         # CONFIG_LCD_SUPPORT_TO20T20000 is not set
                                         # CONFIG_LCD_SUPPORT_FRD450H40014 is not set
                                        Index: tina-d1-h/device/config/chips/d1-h/configs/nezha/uboot-board.dts
                                        --- tina-d1-h.orig/device/config/chips/d1-h/configs/nezha/uboot-board.dts
                                        +++ tina-d1-h/device/config/chips/d1-h/configs/nezha/uboot-board.dts
                                        @@ -42,7 +42,7 @@
                                         &pwm2_pin_b {
                                         	pins = "PD18";
                                         	muxsel = <0>;
                                         &pwm2 {
                                        @@ -260,57 +260,50 @@
                                         &lcd0 {
                                        -	lcd_used            = <1>;
                                        +	lcd_used        = <1>;
                                        -	lcd_if              = <4>;
                                        -	lcd_x               = <800>;
                                        -	lcd_y               = <1280>;
                                        -	lcd_width           = <52>;
                                        -	lcd_pwm_ch          = <2>;
                                        -	lcd_hbp             = <32>;
                                        -	lcd_ht              = <868>;
                                        -	lcd_hspw            = <4>;
                                        -	lcd_vbp             = <12>;
                                        -	lcd_vt              = <1311>;
                                        -	lcd_vspw            = <4>;
                                        -	lcd_dsi_if          = <0>;
                                        -	lcd_frm             = <0>;
                                        +	lcd_if          = <0>;
                                        +	lcd_hv_if       = <0>;
                                        +	lcd_width       = <70>;
                                        +	lcd_x           = <480>;
                                        +	lcd_y           = <480>;
                                        +	lcd_hbp         = <60>;
                                        +	lcd_ht          = <612>;
                                        +	lcd_hspw        = <12>;
                                        +	lcd_vbp         = <18>;
                                        +	lcd_vt          = <520>;
                                        +	lcd_vspw        = <4>;
                                        +	lcd_pwm_ch      = <7>;
                                        -	deu_mode            = <0>;
                                        +	lcd_frm         = <1>;
                                        +	lcd_hv_clk_phase= <0>;
                                         &hdmi {
                                         	hdmi_used = <1>;
                                        请使用quilt应用该patch
                                        M 1 条回复 最后回复 回复 引用 分享 0
                                          ming899 LV 3 @anruliu 最后由 编辑
                                          @anruliu 为什么开机不显示,休眠唤醒一下就能显示呢?请问这个问题要到哪里查?
                                          T 1 条回复 最后回复 回复 引用 分享 0
                                            ming899 LV 3 @lbuque 最后由 编辑
                                            @lbuque 这样也是只能休眠唤醒之后能正常显示吧?开机默认能正常显示吗?
                                            • T
                                              tsmnkj LV 3 @ming899 最后由 编辑
                                              @ming899 官方的视频教程提到tina sdk uboot 开启lcd的显示,内核就不走开屏流程了,进内核后可以休眠唤醒打开屏
