    d1s下的overlays挂载问题,提示“No such device”
    8
    7826
      casojie LV 5 最后由 编辑
      D1S 无法挂载overlays,开机打印如下
      Starting kernel ...
      [01.717][mmc]: mmc exit start
      [01.736][mmc]: mmc 2 exit ok
      mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such device
      Mount Failed: formating /dev/by-name/rootfs_data to ext4 ...
      mke2fs 1.46.4 (18-Aug-2021)
      Didn't found ubi volume "env"
      Cannot open /dev/ubi0: No such file or directory
      Didn't found ubi volume "env-redund"
      mkdir: can't create directory '/overlay/upper': Read-only file system
      mkdir: can't create directory '/overlay/workdir': Read-only file system
      mount: mounting overlayfs:/overlay on /mnt failed: No such file or directory
      mount: mounting /proc on /mnt/proc failed: No such file or directory
      pivot_root: No such file or directory
      mount: mounting /rom/dev on /dev failed: No such file or directory
      mount: mounting /rom/tmp on /tmp failed: No such file or directory
      mount: mounting /rom/sys on /sys failed: No such file or directory
      mount: mounting /rom/overlay on /overlay failed: No such file or directory
      ------run rc.final file-----
      ifconfig: SIOCGIFFLAGS: No such device
      host_chose finished!
      nice: can't execute '/usr/bin/story_ota_bin': No such file or directory
      device_chose finished!
      在贴吧也搜索到类似的问题,都是修改base-file里的文件,但是我是使用的busybox-init, 都找不到对应的fstat文件,感觉分区设置好像有问题,太蔡了,求大哥指点,以下pack的log
      jie.cao@umr940:~/f133A/f133$ pack
      PACK_CHIP         sun20iw1p1
      PACK_PLATFORM     tina
      PACK_BOARD        f133-evb1
      PACK_KERN
      PACK_DEBUG        uart0
      PACK_SIG          none
      PACK_SECURE       none
      PACK_MODE         normal
      PACK_FUNC         android
      PACK_PROGRAMMER   none
      PACK_TAR_IMAGE    none
      PACK_TOPDIR       /homeB/jie.cao/f133A/f133
      No kernel param, parse it from f133
      copying tools file
      copying configs file
      storage_type value is 2
      rm /homeB/jie.cao/f133A/f133/out/f133-evb1/image/sys_partition_nor.fex
      rm /homeB/jie.cao/f133A/f133/out/f133-evb1/image/image_nor.cfg
      copying boot resource
      copying boot file
      make user resource for : /homeB/jie.cao/f133A/f133/out/f133-evb1/image/sys_partition.fex
      handle partition user-res
      no user resource partitions
      APP_PART_DOWNLOAD_FILE = /homeB/jie.cao/f133A/f133/out/f133-evb1/image/app.fex
      Need size of filesystem
      no data resource partitions
      don't build dtbo ...
      update_chip
      sboot file Path=/homeB/jie.cao/f133A/f133/out/f133-evb1/image/sboot.bin
      script file Path=/homeB/jie.cao/f133A/f133/out/f133-evb1/image/sys_config.bin
      update:unable to open sboot file
      script update sboot ok
      pack boot package
      content_count=3
      packing for tina linux
      normal
      mbr count = 4
      partitation file Path=/homeB/jie.cao/f133A/f133/out/f133-evb1/image/sys_partition.bin
      mbr_name file Path=/homeB/jie.cao/f133A/f133/out/f133-evb1/image/sunxi_mbr.fex
      download_name file Path=/homeB/jie.cao/f133A/f133/out/f133-evb1/image/dlinfo.fex
      mbr size = 16384
      mbr magic softw411
      disk name=boot-resource
      disk name=env
      disk name=env-redund
      disk name=boot
      disk name=rootfs
      disk name=recovery
      disk name=rootfs_data
      this is not a partition key
      update_for_part_info 0
      crc 0 = 9632c2e2
      crc 1 = 38f93bf
      crc 2 = 66396619
      crc 3 = f3843744
      gpt_head->header_crc32 = 0xac1db3f8
      GPT----part num 8---
      gpt_entry: 128
      gpt_header: 92
      GPT:boot-resource: 12000         121f7
      GPT:env         : 121f8         123ef
      GPT:env-redund  : 123f0         125e7
      GPT:boot        : 125e8         157e7
      GPT:rootfs      : 157e8         229e7
      GPT:recovery    : 229e8         27767
      GPT:rootfs_data : 27768         29f67
      GPT:UDISK       : 29f68         ffffffde
      update gpt file ok
      update mbr file ok
      temp = 20
      mbr count = 4 total_sectors = 15269888 logic_offset = 40960
      mbr size = 16384
      mbr magic softw411
      disk name=env
      disk name=boot
      disk name=rootfs
      disk name=recovery
      crc 0 = 9632c2e2
      crc 1 = 38f93bf
      crc 2 = 66396619
      crc 3 = f3843744
      gpt_head->header_crc32 = 0x36191a6a
      gpt_entry: 128
      gpt_header: 92
      GPT:UDISK       : 29f68         e8ffde
      update gpt file ok
      update mbr file ok
        [mbr]
        mbr_size  : 16384 Kbyte
        partition_name  : boot-resource
        partition_size  : 504
        boot-resource.fex size : 80K byte
        partition_name  : env
        downloadfile  : env.fex
        env.fex size : 128K byte
        partition_name  : env-redund
        partition_size  : 12800
        downloadfile  : boot.fex
        boot.fex -> /homeB/jie.cao/f133A/f133/out/f133-evb1/boot.img
        boot.img size : 5.8M byte
        partition_name  : rootfs
        partition_size  : 53760
        downloadfile  : rootfs.fex
        rootfs.fex -> /homeB/jie.cao/f133A/f133/out/f133-evb1/rootfs.img
        rootfs.img size : 16M byte
        partition_name  : recovery
        partition_size  : 19840
        partition_name  : rootfs_data
        partition_size  : 10240
      /homeB/jie.cao/f133A/f133/out/host/bin/
      Begin Parse sys_partion.fex
      FilePath: boot-resource.fex
      FileLength=14000Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FileLength=20000Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FilePath: boot.fex
      FileLength=5b4800Add partion rootfs.fex ROOTFS_FEX000000
      FilePath: rootfs.fex
      FileLength=fc0000BuildImg 0
      ----------image is for nand/emmc----------
      S 1 条回复 最后回复 回复 引用 分享 0
        suncw LV 4 @casojie 最后由 编辑
        @casojie
        overlayfs挂载失败是因为分区没有格式化,分区挂载失败,只读文件系统没法创建必要的文件夹,最终导致overlayfs挂载失败的吧
        这个帖子里好像有挂载的方法
        芒果d1h用sd卡烧录后创建文件夹一直Read-only file system
          casojie LV 5 @suncw 最后由 编辑
          @suncw 我不是很明白,根目录下是有overlay文件夹的,它应该不需要创建文件夹了吧,而我也尝试手动挂载,也是提示
          root@TinaLinux:/# mount -t ext4 -o sync,data=journal /dev/by-name/rootfs_data /o
          verlay/
          mount: mounting /dev/by-name/rootfs_data on /overlay/ failed: No such device
          我也尝试执行
          root@TinaLinux:/# mkfs.ext4 /dev/by-name/rootfs_data
          /dev/by-name/rootfs_data contains a ext4 file system
          	created on Thu Jan  1 08:07:28 1970
          Proceed anyway? (y,N) y
          Discarding device blocks: done
          Creating filesystem with 5120 1k blocks and 1280 inodes
          Allocating group tables: done
          Writing inode tables: done
          Creating journal (1024 blocks): done
          Writing superblocks and filesystem accounting information: done
          仍然不行,唉
            @casojie
            overlayfs挂载除了overlay文件夹还要依赖其他文件夹,比如upper、workdir。光看根目录下是有overlay文件夹可能不行。。。。。。
            帖子里提到的将根文件系统改为ext4格式和修改代码两种方式应该都可以正常挂载
            或者您要是想手动格式的话,也可以在电脑上进行格式化,找u盘最后一个分区进行格式化
            类似mkfs.ext4 /dev/sbd8
            设备上格式化应该也可以,但是可能不能自动挂载,可能需要重启一下
              @suncw 抱歉,我还是不明白,我的设备是emmc存储,mkfs.ext4 在板子上是可以正常使用的,看完后我还是不知道应该怎么做,而且我使用的是busybox-init 对应的以下fsata文件都没有
              T 1 条回复 最后回复 回复 引用 分享 0
              • T
                TEVET LV 7 @casojie 最后由 编辑
                @casojie
                是使用了 rootfs_data 是否有这个 partition 呢
                检查一下sys_partition.fex 吧,贴上来看看
                报错提示你没有这个 /dev/by-name/rootfs_data ,极可能是 sys_partition.fex 没有这个分区信息。
                你要自己加一下 ,如下,size 可以自己改
                [partition]
                name = rootfs_data
                size = 25600
                user_type = 0x8000
                  casojie LV 5 @TEVET 最后由 编辑
                  @tevet 前几天解决了,谢谢回复
                  K 1 条回复 最后回复 回复 引用 分享 0
                  • K
                    kjlsai LV 2 @casojie 最后由 编辑
                    @casojie 请问是怎么解决的
