    芒果派mq-r t113启动异常
    4170
      hydfxy LV 5 最后由 编辑
      Dears,
      有没遇到芒果派mq-r t113启动异常的,第一次接触全志,按照https://github.com/mangopi-sbc/Tina-Linux 下载后修改为板子才有的uart3口后一直进不到系统,有能帮看下是哪里问题吗
      code_text
      log如下
      [145]HELLO! BOOT0 is starting!
      [148]BOOT0 commit : be0c4b8-dirty
      [    0.000000] Linux version 5.4.61 (t113@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #5 SMP PREEMPT Mon Aug 8 11:13:45 UTC 2022
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 rootdelay=2 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g2a1965a-dirty(07/10/2022-02:50:57) mbr_offset=1032192 disp_reserve=1536000,0x43f06000 androidboot.dramsize=128
      [    0.000000] Memory: 107108K/131072K available (5120K kernel code, 277K rwdata, 1424K rodata, 1024K init, 1162K bss, 19868K reserved, 4096K cma-reserved)
      [    0.008016] Switching to timer-based delay loop, resolution 41ns
      [    0.014211] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023915] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.034272] pid_max: default: 32768 minimum: 301
      [    0.039009] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.046332] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.054674] CPU: Testing write buffer coherency: ok
      [    0.059875] /cpus/cpu@0 missing clock-frequency property
      [    0.065199] /cpus/cpu@1 missing clock-frequency property
      [    0.070546] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.076694] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.083349] rcu: Hierarchical SRCU implementation.
      [    0.088540] smp: Bringing up secondary CPUs ...
      [    0.094153] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.094269] smp: Brought up 1 node, 2 CPUs
      [    0.104098] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.110285] CPU: All CPU(s) started in SVC mode.
      [    0.115352] devtmpfs: initialized
      [    0.129454] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.137571] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.147665] pinctrl core: initialized pinctrl subsystem
      [    0.153782] NET: Registered protocol family 16
      [    0.159690] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.196468] rtc_ccu: sunxi ccu init OK
      [    0.202506] ccu: sunxi ccu init OK
      [    0.206325] r_ccu: sunxi ccu init OK
      [    0.228684] iommu: Default domain type: Translated
      [    0.233723] sunxi iommu: irq = 24
      [    0.237993] SCSI subsystem initialized
      [    0.241901] usbcore: registered new interface driver usbfs
      [    0.247488] usbcore: registered new interface driver hub
      [    0.252885] usbcore: registered new device driver usb
      [    0.258708] Advanced Linux Sound Architecture Driver Initialized.
      [    0.265521] pwm module init!
      [    0.269667] g2d 5410000.g2d: Adding to iommu group 0
      [    0.275009] G2D: rcq version initialized.major:252
      [    0.280568] clocksource: Switched to clocksource arch_sys_counter
      [    0.295011] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.304250] NET: Registered protocol family 2
      [    0.309179] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.317599] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.325315] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.332419] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.338866] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.345446] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.352641] NET: Registered protocol family 1
      [    0.357947] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.368250] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.374968] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
      [    0.381112] sunxi_spi_resource_get()2154 - Failed to get sample mode
      [    0.387482] sunxi_spi_resource_get()2159 - Failed to get sample delay
      [    0.393937] sunxi_spi_resource_get()2163 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.402366] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
      [    0.408618] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base c881f000, irq 39
      [    0.418242] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.428851] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.434873] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.468793] io scheduler mq-deadline registered
      [    0.473364] io scheduler kyber registered
      [    0.478387] [DISP]disp_module_init
      [    0.482345] disp 5000000.disp: Adding to iommu group 0
      [    0.487998] [DISP] parser_disp_init_para,line:1430:
      [    0.488002] of_property_read fb0_width fail
      [    0.497127] [DISP] disp_init,line:2386:
      [    0.497132] smooth display screen:0 type:1 mode:4
      [    0.521913] display_fb_request,fb_id:0
      [    0.527975] Freeing logo buffer memory: 1500K
      [    0.532878] disp_al_manager_apply ouput_type:1
      [    0.537714] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.540887] [DISP]disp_module_init finish
      [    0.552700] sunxi_sid_init()551 - insmod ok
      [    0.558041] misc dump reg init
      [    0.562261] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    0.572321] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    0.578808] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.585350] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.591976] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    0.597819] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    0.604039] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    0.610970] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=131 assert=1
      [    0.618028] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    0.627993] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    0.635262] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    0.642109] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    0.648145] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    0.654900] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      [    0.661993] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [    0.668469] [ADDR_MGT] addr_mgt_probe: success.
      [    0.673299] dma-buf: Running sanitycheck
      [    0.677287] dma-buf: Running dma_fence
      [    0.681112] sizeof(dma_fence)=48
      [    0.684464] dma-buf: Running dma_fence/sanitycheck
      [    0.689277] dma-buf: Running dma_fence/test_signaling
      [    0.694382] dma-buf: Running dma_fence/test_add_callback
      [    0.699696] dma-buf: Running dma_fence/test_late_add_callback
      [    0.705502] dma-buf: Running dma_fence/test_rm_callback
      [    0.710765] dma-buf: Running dma_fence/test_late_rm_callback
      [    0.716443] dma-buf: Running dma_fence/test_status
      [    0.721258] dma-buf: Running dma_fence/test_error
      [    0.725972] dma-buf: Running dma_fence/test_wait
      [    0.730604] dma-buf: Running dma_fence/test_wait_timeout
      [    0.770581] dma-buf: Running dma_fence/test_stub
      [    0.775228] dma-buf: Running dma_fence/race_signal_callback
      [    0.850579] thread_signal_callback[0] completed 35828 passes, 45 misses
      [    0.857230] thread_signal_callback[1] completed 35818 passes, 36 misses
      [    0.930591] thread_signal_callback[0] completed 41228 passes, 41225 misses
      [    0.937500] thread_signal_callback[1] completed 41216 passes, 41215 misses
      [    0.944906] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
      [    0.951449] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      [    0.962044] random: fast init done
      [    1.237596] random: crng init done
      [    1.950614] sunxi-spinand-phy: read id failed : -110
      [    1.955618] spi-nand: probe of spi0.0 failed with error -110
      [    1.961427] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.967952] sunxi-ehci: EHCI SUNXI driver
      [    1.972467] get ehci1-controller wakeup-source is fail.
      [    1.977798] sunxi ehci1-controller don't init wakeup source
      [    1.983403] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0a61480, 0x:c8837000, irq_no:3b
      [    1.994155] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    2.005346] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    2.016234] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    2.022773] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    2.031674] sunxi-ehci 4200000.ehci1-controller: irq 59, io mem 0x04200000
      [    2.060599] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    2.068395] hub 1-0:1.0: USB hub found
      [    2.072208] hub 1-0:1.0: 1 port detected
      [    2.076729] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    2.082970] sunxi-ohci: OHCI SUNXI driver
      [    2.087466] get ohci1-controller wakeup-source is fail.
      [    2.092835] sunxi ohci1-controller don't init wakeup source
      [    2.098430] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0a61710
      [    2.107088] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    2.118256] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    2.129233] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    2.135747] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    2.144576] sunxi-ohci 4200400.ohci1-controller: irq 60, io mem 0x04200400
      [    2.225382] hub 2-0:1.0: USB hub found
      [    2.229181] hub 2-0:1.0: 1 port detected
      [    2.233817] i2c /dev entries driver
      [    2.237395] sunxi cedar version 1.1
      [    2.241142] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    2.246790] VE: sunxi_cedar_probe power-domain init!!!
      [    2.251971] VE: install start!!!
      [    2.251971]
      [    2.256904] VE: cedar-ve the get irq is 40
      [    2.256904]
      [    2.262744] VE: ve_debug_proc_info:c502209a, data:ffd1d6ed, lock:e9d92362
      [    2.262744]
      [    2.271052] VE: install end!!!
      [    2.271052]
      [    2.275591] VE: sunxi_cedar_probe
      [    2.280790] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    2.289686] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.295260] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    2.300934] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.306671] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    2.312439] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    2.318298] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    2.324178] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    2.330019] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    2.336294] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    2.341125] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    2.347036] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.356989] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    2.376336] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.399503] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    2.404616] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.415454] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    2.424418] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    2.425483] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.429981] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    2.446017] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    2.451807] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    2.457578] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    2.457585] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.464725] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.473805] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    2.489997] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    2.495847] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    2.501719] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    2.510113] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.520124] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    2.539488] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.558016] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.562489] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    2.572188] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.572880] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.582538] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.592992] exFAT: Version 1.3.0
      [    2.606581] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    2.608554] sun8iw20-pinctrl 2000000.pinctrl: pin PG18 already requested by 2000000.pinctrl:210; cannot claim for 2036000.spdif
      [    2.617182] mmc0: new high speed SDHC card at address aaaa
      [    2.628752] sun8iw20-pinctrl 2000000.pinctrl: pin-210 (2036000.spdif) status -22
      [    2.635014] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
      [    2.641694] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 210 (PG18) from group PG18  on device 2000000.pinctrl
      [    2.657242] sunxi-spdif 2036000.spdif: Error applying setting, reverse things back
      [    2.664928] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.664934] sunxi-spdif: probe of 2036000.spdif failed with error -22
      [    2.665515] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    2.677114] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [    2.682895] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    2.682895]
      [    2.701512] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.715320]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    2.725634] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.732035] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    2.740618] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    2.750663] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    2.761447] mmc1: new high speed SDIO card at address 0001
      [    2.768893] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    2.782313] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    2.788685] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    2.798506] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    2.809255] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    2.816825] NET: Registered protocol family 10
      [    2.821326] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    2.828759] Segment Routing with IPv6
      [    2.832578] NET: Registered protocol family 17
      [    2.837462] Registering SWP/SWPB emulation handler
      [    2.856753] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    2.865677] sunxi-i2c sunxi-i2c2: probe success
      [    2.871284] sun8iw20-pinctrl 2000000.pinctrl: pin PG18 already requested by 2000000.pinctrl:210; cannot claim for 2036000.spdif
      [    2.882858] sun8iw20-pinctrl 2000000.pinctrl: pin-210 (2036000.spdif) status -22
      [    2.890281] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 210 (PG18) from group PG18  on device 2000000.pinctrl
      [    2.901301] sunxi-spdif 2036000.spdif: Error applying setting, reverse things back
      [    2.908905] sunxi-spdif: probe of 2036000.spdif failed with error -22
      [    2.917242] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
      [    2.925378] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
      [    2.934494] get ehci0-controller wakeup-source is fail.
      [    2.939839] sunxi ehci0-controller don't init wakeup source
      [    2.945508] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a60f60, 0x:c88a4000, irq_no:39
      [    2.956220] [sunxi-ehci0]: Not init ehci0
      [    2.960549] get ohci0-controller wakeup-source is fail.
      [    2.965903] sunxi ohci0-controller don't init wakeup source
      [    2.971514] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0a611f0
      [    2.980119] [sunxi-ohci0]: Not init ohci0
        earlycon关闭后启用uart驱动,但是uart驱动挂了,输出到其他uart上了
        H 1 条回复 最后回复 回复 引用 分享 0
          hydfxy LV 5 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 您好,这种问题是哪里设定有误嘛,需要哪里改可否帮忙说下
            hydfxy LV 5 最后由 编辑
            相关配置文件如上,可否有帮忙看下的evb1.rar
