    【求助】LCD RGB18 部分引脚被占用应该如何释放
      dyd2022 LV 3 最后由 编辑
      这个是rgb18的引脚定义:
      			rgb18_pins_a: rgb18@0 {
      				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      					"PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      					"PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      				function = "lcd0";
      				drive-strength = <30>;
      				bias-disable;
      在系统启动时LCD驱动程序报错如下:主要是因为PD19引脚被占用导致引脚申请失败
      [    5.809429] [DISP]disp_module_init
      [    5.814103] disp 5000000.disp: Adding to iommu group 0
      [    5.845304] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
      [    5.855057] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
      [    5.875786] display_fb_request,fb_id:0
      [    5.886234] [DISP] Fb_copy_boot_fb,line:1443:
      [    5.886240] no boot_fb0
      [    5.894393] disp_al_manager_apply ouput_type:0
      [    5.900737] [DISP]disp_module_init finish
      [    5.905298] [DISP] lcd_clk_config,line:732:
      [    5.905310] disp 0, clk: pll(114000000),clk(114000000),dclk(19000000) dsi_rate(114000000)
      [    5.905310]      clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
      [    5.963933] =====================LCD_open_flow
      [    5.968892] =====================LCD_power_on
      [    5.974983] sun8iw20-pinctrl 2000000.pinctrl: pin PD19 already requested by 2000000.pinctrl:115; cannot claim for 1c0c000.lcd0
      [    6.031543] sun8iw20-pinctrl 2000000.pinctrl: pin-115 (1c0c000.lcd0) status -22
      [    6.039701] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 115 (PD19) from group PD19  on device 2000000.pinctrl
      [    6.091538] platform 1c0c000.lcd0: Error applying setting, reverse things back
      [    6.099618] [DISP] disp_sys_pin_set_state,line:395:
      [    6.099622] pinctrl_select_state(active) for allwinner,sunxi-lcd0 fail
      [    6.181549] =====================LCD_panel_init
      这个是进入系统后打印的引脚信息:
      root@TinaLinux:/# cat /sys/kernel/debug/pinctrl/2000000.pinctrl/pinmux-pins
      Pinmux settings per pin
      Format: pin (name): mux_owner|gpio_owner (strict) hog?
      pin 32 (PB0): device 2502800.twi function gpio_in group PB0
      pin 33 (PB1): device 2502800.twi function gpio_in group PB1
      pin 34 (PB2): UNCLAIMED
      pin 35 (PB3): UNCLAIMED
      pin 36 (PB4): UNCLAIMED
      pin 37 (PB5): UNCLAIMED
      pin 38 (PB6): UNCLAIMED
      pin 39 (PB7): UNCLAIMED
      pin 40 (PB8): device 2500000.uart function uart0 group PB8
      pin 41 (PB9): device 2500000.uart function uart0 group PB9
      pin 42 (PB10): device 2031000.dmic function io_disabled group PB10
      pin 43 (PB11): device 2031000.dmic function io_disabled group PB11
      pin 44 (PB12): UNCLAIMED
      pin 64 (PC0): device 2008000.ledc function ledc group PC0
      pin 65 (PC1): UNCLAIMED
      pin 66 (PC2): UNCLAIMED
      pin 67 (PC3): UNCLAIMED
      pin 68 (PC4): UNCLAIMED
      pin 69 (PC5): UNCLAIMED
      pin 70 (PC6): UNCLAIMED
      pin 71 (PC7): UNCLAIMED
      pin 96 (PD0): UNCLAIMED
      pin 97 (PD1): UNCLAIMED
      pin 98 (PD2): UNCLAIMED
      pin 99 (PD3): UNCLAIMED
      pin 100 (PD4): UNCLAIMED
      pin 101 (PD5): UNCLAIMED
      pin 102 (PD6): UNCLAIMED
      pin 103 (PD7): UNCLAIMED
      pin 104 (PD8): UNCLAIMED
      pin 105 (PD9): UNCLAIMED
      pin 106 (PD10): UNCLAIMED
      pin 107 (PD11): UNCLAIMED
      pin 108 (PD12): UNCLAIMED
      pin 109 (PD13): UNCLAIMED
      pin 110 (PD14): UNCLAIMED
      pin 111 (PD15): UNCLAIMED
      pin 112 (PD16): UNCLAIMED
      pin 113 (PD17): UNCLAIMED
      pin 114 (PD18): UNCLAIMED
      pin 115 (PD19): GPIO 2000000.pinctrl:115
      pin 116 (PD20): GPIO 2000000.pinctrl:116
      pin 117 (PD21): GPIO 2000000.pinctrl:117
      pin 118 (PD22): UNCLAIMED
      pin 128 (PE0): UNCLAIMED
      pin 129 (PE1): UNCLAIMED
      pin 130 (PE2): UNCLAIMED
      pin 131 (PE3): UNCLAIMED
      pin 132 (PE4): UNCLAIMED
      pin 133 (PE5): UNCLAIMED
      pin 134 (PE6): UNCLAIMED
      pin 135 (PE7): UNCLAIMED
      pin 136 (PE8): UNCLAIMED
      pin 137 (PE9): UNCLAIMED
      pin 138 (PE10): UNCLAIMED
      pin 139 (PE11): UNCLAIMED
      pin 140 (PE12): UNCLAIMED
      pin 141 (PE13): UNCLAIMED
      pin 142 (PE14): device 2031000.dmic function io_disabled group PE14
      pin 143 (PE15): UNCLAIMED
      pin 144 (PE16): UNCLAIMED
      pin 145 (PE17): device 2031000.dmic function io_disabled group PE17
      pin 160 (PF0): device 4020000.sdmmc function sdc0 group PF0
      pin 161 (PF1): device 4020000.sdmmc function sdc0 group PF1
      pin 162 (PF2): device 4020000.sdmmc function sdc0 group PF2
      pin 163 (PF3): device 4020000.sdmmc function sdc0 group PF3
      pin 164 (PF4): device 4020000.sdmmc function sdc0 group PF4
      pin 165 (PF5): device 4020000.sdmmc function sdc0 group PF5
      pin 166 (PF6): GPIO 2000000.pinctrl:166
      pin 192 (PG0): device 4021000.sdmmc function gpio_in group PG0
      pin 193 (PG1): device 4021000.sdmmc function gpio_in group PG1
      pin 194 (PG2): device 4021000.sdmmc function gpio_in group PG2
      pin 195 (PG3): device 4021000.sdmmc function gpio_in group PG3
      pin 196 (PG4): device 4021000.sdmmc function gpio_in group PG4
      pin 197 (PG5): device 4021000.sdmmc function gpio_in group PG5
      pin 198 (PG6): device 2500400.uart function uart1 group PG6
      pin 199 (PG7): device 2500400.uart function uart1 group PG7
      pin 200 (PG8): device 2500400.uart function uart1 group PG8
      pin 201 (PG9): device 2500400.uart function uart1 group PG9
      pin 202 (PG10): GPIO 2000000.pinctrl:202
      pin 203 (PG11): device soc@3000000:rfkill@0 function clk_fanout1 group PG11
      pin 204 (PG12): GPIO 2000000.pinctrl:204
      pin 205 (PG13): UNCLAIMED
      pin 206 (PG14): UNCLAIMED
      pin 207 (PG15): UNCLAIMED
      pin 208 (PG16): GPIO 2000000.pinctrl:208
      pin 209 (PG17): GPIO 2000000.pinctrl:209
      pin 210 (PG18): GPIO 2000000.pinctrl:210
      打印信息没显示PD19、PD20、PD21三个引脚是被哪个设备占用了,dts文件里除了rgb使用了PD19、PD20、PD21,别的地方都没再使用
      文件:lichee/linux-5.4/arch/riscv/boot/dts/sunxi/sun20iw1p1.dtsi
       * Allwinner Technology CO., Ltd. sun20iw1p1 platform.
      /memreserve/ 0x41fc0000 0x020000;  /* opensbi */
      #include <dt-bindings/clock/sun8iw20-ccu.h>
      #include <dt-bindings/clock/sun8iw20-r-ccu.h>
      #include <dt-bindings/clock/sun8iw20-rtc.h>
      #include <dt-bindings/reset/sun8iw20-ccu.h>
      #include <dt-bindings/reset/sun8iw20-r-ccu.h>
      #include <dt-bindings/gpio/gpio.h>
      #include <dt-bindings/interrupt-controller/irq.h>
      #include <dt-bindings/gpio/sun4i-gpio.h>
      #include <dt-bindings/thermal/thermal.h>
      	model = "sun20iw1p1";
      	compatible = "allwinner,sun20iw1p1";
      	#address-cells = <2>;
      	#size-cells = <2>;
      	aliases {
      		serial0 = &uart0;
      		serial1 = &uart1;
      		serial2 = &uart2;
      		serial3 = &uart3;
      		serial4 = &uart4;
      		serial5 = &uart5;
      		spi0 = &spi0;
      		spi1 = &spi1;
      		twi0 = &twi0;
      		twi1 = &twi1;
      		twi2 = &twi2;
      		twi3 = &twi3;
      		mmc2 = &sdc2;
      		pwm0 = &pwm0;
      		pwm1 = &pwm1;
      		pwm2 = &pwm2;
      		pwm3 = &pwm3;
      		pwm4 = &pwm4;
      		pwm5 = &pwm5;
      		pwm6 = &pwm6;
      		pwm7 = &pwm7;
      		ir0 = &s_cir0;
      		ir1 = &ir1;
      		mmc0 = &sdc0;
      		ve0 = &ve;
      		tvd = &tvd;
      		tvd0 = &tvd0;
      	chosen {
      		bootargs = "console=ttyS0,115200n8 debug loglevel=7,initcall_debug=1 init=/init earlycon=sbi";
      		stdout-path = "serial0:115200n8";
      		linux,initrd-start = <0x42000000>;
      		linux,initrd-end   = <0x43000000>;
      	cpus {
      		#address-cells = <1>;
      		#size-cells = <0>;
      		timebase-frequency = <24000000>;
      		idle-states {
      			CPU_SLEEP: cpu-sleep {
      				compatible = "riscv,idle-state";
      				local-timer-stop;
      				entry-latency-us = <59>;
      				exit-latency-us = <59>;
      				min-residency-us = <5000>;
      		CPU0: cpu@0 {
      			device_type = "cpu";
      			reg = <0>;
      			compatible = "riscv";
      			riscv,isa = "rv64imafdcvsu";
      		/*	riscv,priv-major = <1>;*/
      		/*	riscv,priv-minor = <10>;*/
      			mmu-type = "riscv,sv39";
      			clocks = <&ccu CLK_RISCV>;
      			clock-frequency = <24000000>;
      			operating-points-v2 = <&cpu_opp_table>;
      			cpu-idle-states = <&CPU_SLEEP>;
      			#cooling-cells = <2>;
      	/*		d-cache-size = <0x8000>;*/
      	/*		d-cache-line-size = <32>;*/
      			CPU0_intc: interrupt-controller {
      				#interrupt-cells = <1>;
      				interrupt-controller;
      				compatible = "riscv,cpu-intc";
      	dram: dram {
      		device_type = "dram";
      		compatible = "allwinner,dram";
      		clocks = <&ccu CLK_PLL_DDR0>;
      		clock-names = "pll_ddr";
      	memory@40000000 {
      		device_type = "memory";
      		reg = <0x0 0x40000000 0x0 0x8000000>;
      	dump_reg: dump_reg@20000 {
      		compatible = "allwinner,sunxi-dump-reg";
      		reg = <0x0 0x00020000 0x0 0x0004>;
      		/* 0x00020000: dump_reg test addr, 0x0004: dump_reg test size */
      	cpu_opp_table: cpu-opp-table {
      		compatible = "allwinner,sun50i-operating-points";
      		nvmem-cells = <&speedbin_efuse>, <&cpubin_efuse>;
      		nvmem-cell-names = "speed", "bin";
      		opp-shared;
      		opp@1008000000 {
      			opp-hz = /bits/ 64 <1008000000>;
      			clock-latency-ns = <244144>; /* 8 32k periods */
      			opp-microvolt-a0 = <1100000>;
      			opp-microvolt-a1 = <950000>;
      			opp-microvolt-b1 = <950000>;
      			opp-supported-hw = <0x1>;
      	dcxo24M: dcxo24M_clk {
      		#clock-cells = <0>;
      		compatible = "fixed-clock";
      		clock-output-names = "dcxo24M";
      	rc_16m: rc16m_clk {
      		#clock-cells = <0>;
      		clock-frequency = <16000000>;
      		clock-accuracy = <300000000>;
      		clock-output-names = "rc-16m";
      	ext_32k: ext32k_clk {
      		#clock-cells = <0>;
      		clock-frequency = <32768>;
      		clock-output-names = "ext-32k";
      	reg_pio1_8: pio-18 {
      		regulator-name = "pio-18";
      		regulator-min-microvolt = <1800000>;
      		regulator-max-microvolt = <1800000>;
      	reg_pio3_3: pio-33 {
      		regulator-name = "pio-33";
      	thermal-zones {
      		cpu_thermal_zone {
      			polling-delay-passive = <500>;
      			polling-delay = <1000>;
      			thermal-sensors = <&ths 0>;
      			sustainable-power = <1200>;
      			cpu_trips: trips {
      				cpu_threshold: trip-point@0 {
      					temperature = <70000>;
      					type = "passive";
      					hysteresis = <0>;
      				cpu_target: trip-point@1 {
      					temperature = <90000>;
      					type = "passive";
      					hysteresis = <0>;
      				cpu_crit: cpu_crit@0 {
      					temperature = <110000>;
      					type = "critical";
      					hysteresis = <0>;
      			cooling-maps {
      				map0 {
      					trip = <&cpu_target>;
      					cooling-device = <&CPU0
      					THERMAL_NO_LIMIT
      					THERMAL_NO_LIMIT>;
      					contribution = <1024>;
      	mmu_aw: iommu@2010000 {
      		compatible = "allwinner,sunxi-iommu";
      		reg = <0x0 0x02010000 0x0 0x1000>;
      		interrupts-extended = <&plic0 80 IRQ_TYPE_LEVEL_HIGH>;
      		interrupt-names = "iommu-irq";
      		clocks = <&ccu CLK_BUS_IOMMU>;
      		clock-names = "iommu";
      		#iommu-cells = <2>;
      	soc: soc@3000000 {
      		#size-cells = <2>;
      		compatible = "simple-bus";
      		ranges;
      		sram_ctrl: sram_ctrl@3000000 {
      			compatible = "allwinner,sram_ctrl";
      			reg = <0x0 0x3000000 0 0x16C>;
      			soc_ver {
      				offset = <0x24>;
      				mask = <0x7>;
      				shift = <0>;
      				ver_a = <0x18590000>;
      				ver_b = <0x18590002>;
      				ver_d = <0x18590003>;
      			soc_id {
      				offset = <0x200>;
      				mask = <0x1>;
      				shift = <22>;
      			soc_bin {
      				offset = <0x0>;
      				mask = <0x3ff>;
      				shift = <0x0>;
      		rtc_ccu: rtc_ccu@7090000 {
      			compatible = "allwinner,sun20iw1-rtc-ccu";
      			device_type = "rtc-ccu";
      			reg = <0x0 0x07090000 0x0 0x320>;  /* The same as rtc */
      			#clock-cells = <1>;
      		ccu: clock@2001000 {
      			compatible = "allwinner,sun20iw1-ccu";
      			reg = <0x0 0x02001000 0x0 0x1000>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>;
      			clock-names = "hosc", "losc", "iosc";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		r_ccu: clock@7010000 {
      			compatible = "allwinner,sun20iw1-r-ccu";
      			reg = <0x0 0x07010000 0x0 0x240>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>,
      				 <&ccu CLK_PLL_PERIPH0>;
      			clock-names = "hosc", "losc", "iosc", "pll-periph0";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		plic0: interrupt-controller@10000000 {
      			compatible = "riscv,plic0";
      			#interrupt-cells = <2>;
      			reg = <0x0 0x10000000 0x0 0x4000000>;
      			interrupts-extended = <&CPU0_intc 0xffffffff &CPU0_intc 9>;
      			reg-names = "control";
      			riscv,max-priority = <7>;
      			riscv,ndev=<200>;
      		uart0: uart@2500000 {
      			compatible = "allwinner,sun20i-uart";
      			device_type = "uart0";
      			reg = <0x0 0x02500000 0x0 0x400>;
      			interrupts-extended = <&plic0 18 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART0>;
      			clock-names = "uart0";
      			sunxi,uart-fifosize = <64>;
      			uart0_port = <0>;
      			uart0_type = <2>;
      		uart1: uart@2500400 {
      			device_type = "uart1";
      			reg = <0x0 0x02500400 0x0 0x400>;
      			interrupts-extended = <&plic0 19 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,uart-fifosize = <256>;
      			clocks = <&ccu CLK_BUS_UART1>;
      			clock-names = "uart1";
      			uart1_port = <1>;
      			uart1_type = <4>;
      			status = "disabled";
      		uart2: uart@2500800 {
      			device_type = "uart2";
      			reg = <0x0 0x02500800 0x0 0x400>;
      			interrupts-extended = <&plic0 20 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART2>;
      			clock-names = "uart2";
      			resets = <&ccu RST_BUS_UART2>;
      			uart2_port = <2>;
      			uart2_type = <4>;
      		uart3: uart@2500c00 {
      			device_type = "uart3";
      			reg = <0x0 0x02500c00 0x0 0x400>;
      			interrupts-extended = <&plic0 21 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART3>;
      			clock-names = "uart3";
      			resets = <&ccu RST_BUS_UART3>;
      			uart3_port = <3>;
      			uart3_type = <4>;
      		uart4: uart@2501000 {
      			device_type = "uart4";
      			reg = <0x0 0x02501000 0x0 0x400>;
      			interrupts-extended = <&plic0 22 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART4>;
      			clock-names = "uart4";
      			resets = <&ccu RST_BUS_UART4>;
      			uart4_port = <4>;
      			uart4_type = <2>;
      		uart5: uart@2501400 {
      			device_type = "uart5";
      			reg = <0x0 0x02501400 0x0 0x400>;
      			interrupts-extended = <&plic0 23 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART5>;
      			clock-names = "uart5";
      			resets = <&ccu RST_BUS_UART5>;
      			uart5_port = <5>;
      			uart5_type = <2>;
      		cryptoengine: ce@03040000 {
      			compatible = "allwinner,sunxi-ce";
      			device_name = "ce";
      			reg = <0x0 0x03040000 0x0 0xa0>, /* non-secure space */
      			      <0x0 0x03040800 0x0 0xa0>; /* secure space */
      			interrupts-extended = <&plic0 68 IRQ_TYPE_EDGE_RISING>, /*non-secure*/
      				   <&plic0 69 IRQ_TYPE_EDGE_RISING>; /* secure*/
      			clock-frequency = <400000000>; /* 400MHz */
      			clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>, <&ccu CLK_MBUS_CE>,
      					<&ccu CLK_PLL_PERIPH0_2X>;
      			clock-names = "bus_ce", "ce_clk", "mbus_ce", "pll_periph0_2x";
      			resets = <&ccu RST_BUS_CE>;
      		s_cir0: s_cir@7040000 {
      			compatible = "allwinner,s_cir";
      			reg = <0x0 0x07040000 0x0 0x400>;
      			interrupts-extended = <&plic0 167 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_APB0_BUS_IRRX>, <&dcxo24M>, <&r_ccu CLK_R_APB0_IRRX>;
      			clock-names = "bus", "pclk", "mclk";
      			resets = <&r_ccu RST_R_APB0_BUS_IRRX>;
      			supply = "";
      			supply_vol = "";
      		ir1: ir@2003000 {
      			compatible = "allwinner,irtx";
      			reg = <0x0 0x02003000 0x0 0x400>;
      			interrupts-extended = <&plic0 35 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_IR_TX>, <&dcxo24M>, <&ccu CLK_IR_TX>;
      			resets = <&ccu RST_BUS_IR_TX>;
      		di: deinterlace@5400000 {
      			compatible = "allwinner,sunxi-deinterlace";
      			reg = <0x0 0x05400000 0x0 0x0000ffff>;
      			interrupts-extended = <&plic0 104 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_DI>,
      				 <&ccu CLK_BUS_DI>,
      			clock-names = "clk_di",
      				      "pll_periph",
      				      "clk_bus_di";
      			resets = <&ccu RST_BUS_DI>;
      			reset-names = "rst_bus_di";
      			assigned-clocks = <&ccu CLK_DI>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>;
      			assigned-clock-rates = <300000000>;
      			iommus = <&mmu_aw 4 1>;
      		gmac0: eth@4500000 {
      			compatible = "allwinner,sunxi-gmac";
      			reg = <0x0 0x04500000 0x0 0x10000>,
      			      <0x0 0x03000030 0x0 0x4>;
      			interrupts-extended = <&plic0 62 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "gmacirq";
      			clocks = <&ccu CLK_BUS_EMAC0>, <&ccu CLK_EMAC0_25M>;
      			clock-names = "gmac", "ephy";
      			resets = <&ccu RST_BUS_EMAC0>;
      			device_type = "gmac0";
      			pinctrl-0 = <&gmac_pins_a>;
      			pinctrl-1 = <&gmac_pins_b>;
      			phy-mode = "rgmii";
      			use_ephy25m = <1>;
      			tx-delay = <7>;
      			rx-delay = <31>;
      			phy-rst = <&pio PA 14 GPIO_ACTIVE_LOW>;
      			gmac-power0;
      			gmac-power1;
      			gmac-power2;
      		rtc: rtc@7090000 {
      			compatible = "allwinner,sun20iw1-rtc";
      			device_type = "rtc";
      			wakeup-source;
      			interrupts-extended = <&plic0 160 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_AHB_BUS_RTC>, <&rtc_ccu CLK_RTC_SPI>, <&rtc_ccu CLK_RTC_1K>;
      			clock-names = "r-ahb-rtc", "rtc-spi", "rtc-1k";
      			resets = <&r_ccu RST_R_AHB_BUS_RTC>;
      			gpr_cur_pos = <6>;
      		dma: dma-controller@3002000 {
      			compatible = "allwinner,sun8i-riscv-dma";
      			reg = <0x0 0x03002000 0x0 0x1000>;
      			interrupts-extended = <&plic0 66 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>;
      			clock-names = "bus", "mbus";
      			resets = <&ccu RST_BUS_DMA>;
      			dma-channels = <8>;
      			dma-requests = <48>;
      			#dma-cells = <1>;
      		soc_timer0: timer@2050000 {
      			compatible = "allwinner,sun4i-a10-timer";
      			device_type = "soc_timer";
      			reg = <0x0 0x02050000 0x0 0xA0>;
      			interrupts-extended = <&plic0 75 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&dcxo24M>;
      		wdt: watchdog@6011000 {
      			compatible = "allwinner,sun20i-wdt";
      			reg = <0x0 0x06011000 0x0 0x20>;
      			interrupts-extended = <&plic0 147 IRQ_TYPE_LEVEL_HIGH>;
      		mbus0:mbus-comtroller@3102000 {
      			compatible = "allwinner,sun8i-mbus";
      			reg = <0x0 0x03102000 0x0 0x1000>;
      			#mbus-cells = <1>;
      		pmu: pmu {
      			compatible = "riscv,c910_pmu";
      		ilde: idle {
      			compatible = "riscv,idle";
      		pio: pinctrl@2000000 {
      			compatible = "allwinner,sun20iw1-pinctrl";
      			reg = <0x0 0x02000000 0x0 0x500>;
      			interrupts-extended = <&plic0 85 IRQ_TYPE_LEVEL_HIGH>,
      				     <&plic0 87 IRQ_TYPE_LEVEL_HIGH>,
      				     <&plic0 89 IRQ_TYPE_LEVEL_HIGH>,
      				     <&plic0 91 IRQ_TYPE_LEVEL_HIGH>,
      				     <&plic0 93 IRQ_TYPE_LEVEL_HIGH>,
      				     <&plic0 95 IRQ_TYPE_LEVEL_HIGH>;
      			device_type = "pio";
      			clocks = <&ccu CLK_APB0>, <&dcxo24M>, <&rtc_ccu CLK_OSC32K>;
      			clock-names = "apb", "hosc", "losc";
      			gpio-controller;
      			#gpio-cells = <3>;
      			#interrupt-cells = <3>;
      			#size-cells = <0>;
      			vcc-pf-supply = <&reg_pio1_8>;
      			vcc-pfo-supply = <&reg_pio3_3>;
      			test_pins_a: test_pins@0 {
      				allwinner,pins = "PB0", "PB1";
      				allwinner,function = "test";
      				allwinner,muxsel = <0x7>;
      				allwinner,drive = <1>;
      				allwinner,pull = <1>;
      			test_pins_b: test_pins@1 {
      				function = "io_disabled";
      				allwinner,muxsel = <0xF>;
      			gmac_pins_a: gmac@0 {
      				pins = "PA0", "PA1", "PA2", "PA3",
      						 "PA4", "PA5", "PA6", "PA7",
      						 "PA8", "PA10", "PA11", "PA12",
      						 "PA13", "PA17", "PA18", "PA28",
      						 "PA29", "PA30", "PA31";
      				function = "gmac0";
      				drive-strength = <10>;
      			gmac_pins_b: gmac@1 {
      				function = "gpio_in";
      			ir1_pins_a: ir1@0 {  /* For FPGA board */
      				pins = "PG11";
      				function = "ir1";
      			csi_mclk0_pins_a: csi_mclk0@0 {
      				pins = "PE3";
      				function = "csi0";
      			csi_mclk0_pins_b: csi_mclk0@1 {
      				pins = "PE3";
      			csi0_pins_a: csi0@0 {
      				pins = "PE2", "PE0", "PE1", "PE4", "PE5",
      						 "PE6", "PE7", "PE8", "PE9", "PE10", "PE11";
      				function = "ncsi0";
      			csi0_pins_b: csi0@1 {
      			lvds0_pins_a: lvds0@0 {
      				pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      				function = "lvds0";
      				bias-disable;
      			lvds0_pins_b: lvds0@1 {
      				bias-disable;
      			rgb24_pins_a: rgb24@0 {
      				pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      					"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      					"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      				function = "lcd0";
      				bias-disable;
      			rgb24_pins_b: rgb24@1 {
      				bias-disable;
      				function = "lcd0";
      				bias-disable;
      			rgb18_pins_b: rgb18@1 {
      				bias-disable;
      			dsi2lane_pins_a: dsi2lane@0 {
      				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5";
      				function = "dsi";
      				bias-disable;
      			dsi2lane_pins_b: dsi2lane@1 {
      				bias-disable;
      			dsi4lane_pins_a: dsi4lane@0 {
      				function = "dsi";
      				bias-disable;
      			dsi4lane_pins_b: dsi4lane@1 {
      				bias-disable;
      		spi0: spi@4025000 {
      			#size-cells = <0>;
      			compatible = "allwinner,sun20i-spi";
      			device_type = "spi0";
      			reg = <0x0 0x04025000 0x0 0x300>;
      			interrupts-extended = <&plic0 31 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI0>, <&ccu CLK_BUS_SPI0>;
      			clock-names = "pll", "mod", "bus";
      			resets = <&ccu RST_BUS_SPI0>;
      			spi0_cs_number = <1>;
      			spi0_cs_bitmap = <1>;
      			dmas = <&dma 22>, <&dma 22>;
      			dma-names = "tx", "rx";
      		spi1: spi@4026000 {
      			#size-cells = <0>;
      			reg = <0x0 0x04026000 0x0 0x1000>;
      			interrupts-extended = <&plic0 32 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI1>, <&ccu CLK_BUS_SPI1>;
      			resets = <&ccu RST_BUS_SPI1>;
      			spi1_cs_number = <1>;
      			spi1_cs_bitmap = <1>;
      			dmas = <&dma 23>, <&dma 23>;
      		twi0: twi@2502000 {
      			#size-cells = <0>;
      			compatible = "allwinner,sun20i-twi";
      			device_type = "twi0";
      			reg = <0x0 0x02502000 0x0 0x400>;
      			interrupts-extended= <&plic0 25 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C0>;
      			resets = <&ccu RST_BUS_I2C0>;
      			clock-names = "bus";
      			clock-frequency = <400000>;
      			dmas = <&dma 43>, <&dma 43>;
      		twi1: twi@2502400 {
      			#size-cells = <0>;
      			device_type = "twi1";
      			reg = <0x0 0x02502400 0x0 0x400>;
      			interrupts-extended= <&plic0 26 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C1>;
      			resets = <&ccu RST_BUS_I2C1>;
      			clock-frequency = <200000>;
      			dmas = <&dma 44>, <&dma 44>;
      		twi2: twi@2502800 {
      			#size-cells = <0>;
      			device_type = "twi2";
      			reg = <0x0 0x02502800 0x0 0x400>;
      			interrupts-extended = <&plic0 27 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C2>;
      			resets = <&ccu RST_BUS_I2C2>;
      			clock-frequency = <100000>;
      			dmas = <&dma 45>, <&dma 45>;
      		twi3: twi@2502c00 {
      			#size-cells = <0>;
      			device_type = "twi3";
      			reg = <0x0 0x02502c00 0x0 0x400>;
      			interrupts-extended = <&plic0 28 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C3>;
      			resets = <&ccu RST_BUS_I2C3>;
      			dmas = <&dma 46>, <&dma 46>;
      		ledc: ledc@2008000 {
      			#size-cells = <0>;
      			interrupts-extended = <&plic0 36 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "ledcirq";
      			dmas = <&dma 42>, <&dma 42>;
      			dma-names = "rx", "tx";
      			resets = <&ccu RST_BUS_LEDC>;
      			reset-names = "ledc_reset";
      			status = "disable";
      		pwm: pwm@2000c00 {
      			#pwm-cells = <0x3>;
      			compatible = "allwinner,sunxi-pwm";
      			reg = <0x0 0x02000c00 0x0 0x3ff>;
      			clocks = <&ccu CLK_BUS_PWM>;
      			resets = <&ccu RST_BUS_PWM>;
      			pwm-number = <8>;
      			pwm-base = <0x0>;
      			sunxi-pwms = <&pwm0>, <&pwm1>, <&pwm2>, <&pwm3>, <&pwm4>,
      				<&pwm5>, <&pwm6>, <&pwm7>;
      		keyboard0: keyboard@2009800 {
      			compatible = "allwinner,keyboard_1350mv";
      			reg = <0x0 0x02009800 0x0 0x400>;
      			interrupts-extended = <&plic0 77 IRQ_TYPE_EDGE_RISING>;
      			clocks = <&ccu CLK_BUS_LRADC>;
      			resets = <&ccu RST_BUS_LRADC>;
      			key_cnt = <5>;
      			key0 = <210 115>;
      			key1 = <410 114>;
      			key2 = <590 139>;
      			key3 = <750 28>;
      			key4 = <880 172>;
      		sid@3006000 {
      			compatible = "allwinner,sun20iw1p1-sid", "allwinner,sunxi-sid";
      			reg = <0x0 0x03006000 0 0x1000>;
      			#size-cells = <1>;
      			chipid {
      				reg = <0x0 0>;
      				offset = <0x200>;
      				size = <0x10>;
      			oem {
      				reg = <0x0 0>;
      				offset = <0x238>;
      				size = <0x8>;
      			secure_status {
      				reg = <0x0 0>;
      				offset = <0x210>;
      				size = <0x4>;
      			speedbin_efuse: speedbin@00 {
      				reg = <0x00 2>;
      			cpubin_efuse: cpubin@28 {
      				reg = <0x28 2>;
      			ths_calib: calib@14 {
      				reg = <0x14 8>;
      		gpadc: gpadc@2009000 {
      		       compatible = "allwinner,sunxi-gpadc";
      		       reg = <0x0 0x02009000 0x0 0x400>;
      		       interrupts-extended = <&plic0 73 IRQ_TYPE_LEVEL_HIGH>;
      		       clocks = <&ccu CLK_BUS_GPADC>;
      		       resets = <&ccu RST_BUS_GPADC>;
      		ths: ths@02009400 {
      			compatible = "allwinner,sun20iw1p1-ths";
      			reg = <0x0 0x02009400 0x0 0x400>;
      			clocks = <&ccu CLK_BUS_THS>;
      			resets = <&ccu RST_BUS_THS>;
      			nvmem-cells = <&ths_calib>;
      			nvmem-cell-names = "calibration";
      			#thermal-sensor-cells = <1>;
      		tpadc: tpadc@2009c00 {
      			compatible = "allwinner,tp_key";
      			reg = <0x0 0x02009c00 0x0 0x400>;
      			interrupts-extended = <&plic0 78 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_TPADC>, <&ccu CLK_BUS_TPADC>;
      			clock-names = "mod", "bus";
      			clock-frequency = <1000000>;
      			resets = <&ccu RST_BUS_TPADC>;
      		rtp:rtp@2009c00 {
      			compatible = "allwinner,sun8i-ts";
      		/* codec addr: 0x02030000, the others is invalid to avoid build warining */
      		codec:codec@2030000 {
      			#sound-dai-cells = <0>;
      			compatible = "allwinner,sunxi-internal-codec";
      			reg = <0x0 0x02030000 0x0 0x34c>;
      			clocks = <&ccu CLK_PLL_AUDIO0>,
      				 <&ccu CLK_PLL_AUDIO1_DIV5>,
      				 <&ccu CLK_AUDIO_DAC>,
      				 <&ccu CLK_AUDIO_ADC>,
      				 <&ccu CLK_BUS_AUDIO_CODEC>;
      			clock-names = "pll_audio0", "pll_audio1_div5",
      				      "audio_clk_dac", "audio_clk_adc",
      				      "audio_clk_bus";
      			resets = <&ccu RST_BUS_AUDIO_CODEC>;
      			rx_sync_en  = <0x00>;
      			device_type = "codec";
      		dummy_cpudai:dummy_cpudai@203034c {
      			compatible = "allwinner,sunxi-dummy-cpudai";
      			reg = <0x0 0x0203034c 0x0 0x4>;
      			tx_fifo_size    = <128>;
      			rx_fifo_size    = <256>;
      			dac_txdata      = <0x02030020>;
      			adc_txdata      = <0x02030040>;
      			playback_cma    = <128>;
      			capture_cma     = <256>;
      			device_type = "cpudai";
      			dmas = <&dma 7>, <&dma 7>;
      		sndcodec:sound@2030340 {
      			compatible = "allwinner,sunxi-codec-machine";
      			reg = <0x0 0x02030340 0x0 0x4>;
      			interrupts-extended = <&plic0 41 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,audio-codec = <&codec>;
      			sunxi,cpudai-controller = <&dummy_cpudai>;
      			device_type = "sndcodec";
      		sunxi_rpaf_dsp0:rpaf-dsp@203034c {
      			compatible = "allwinner,rpaf-dsp0";
      			device_type = "sunxi_rpaf_dsp0";
      			dsp_id = <0x0>;
      		/* dmic addr: 0x02031000, the others is invalid to avoid build warining */
      		dmic:dmic@2031000{
      			compatible = "allwinner,sunxi-dmic";
      			reg = <0x0 0x02031000 0x0 0x50>;
      				 <&ccu CLK_DMIC>,
      				 <&ccu CLK_BUS_DMIC>;
      			clock-names = "pll_audio", "dmic", "dmic_bus";
      			resets = <&ccu RST_BUS_DMIC>;
      			dmas		= <&dma 8>;
      			dma-names	= "rx";
      			interrupts-extended = <&plic0 40 IRQ_TYPE_LEVEL_HIGH>;
      			clk_parent	= <0x1>;
      			data_vol	= <0xB0>;
      			rx_chmap	= <0x76543210>;
      			device_type = "dmic";
      		dmic_codec:sound@2031050{
      			compatible = "dmic-codec";
      			reg = <0x0 0x02031050 0x0 0x4>;
      			num-channels = <8>;
      		sounddmic:sounddmic@2031060 {
      			reg = <0x0 0x02031060 0x0 0x4>;
      			compatible = "sunxi,simple-audio-card";
      			simple-audio-card,name = "snddmic";
      			simple-audio-card,capture_only;
      			simple-audio-card,cpu {
      				sound-dai = <&dmic>;
      			simple-audio-card,codec {
      				sound-dai = <&dmic_codec>;
      		/* daudio0 addr: 0x02032000, the others is invalid to avoid build warining */
      		daudio0:daudio@2032000 {
      			compatible = "allwinner,sunxi-daudio";
      			reg = <0x0 0x02032000 0x0 0xa0>;
      				 <&ccu CLK_I2S0>,
      				 <&ccu CLK_BUS_I2S0>;
      			clock-names = "pll_audio", "i2s0", "i2s0_bus";
      			resets = <&ccu RST_BUS_I2S0>;
      			dmas		= <&dma 3>, <&dma 3>;
      			interrupts-extended = <&plic0 42 IRQ_TYPE_LEVEL_HIGH>;
      			sign_extend		= <0x00>;
      			tx_data_mode		= <0x00>;
      			rx_data_mode		= <0x00>;
      			msb_lsb_first		= <0x00>;
      			pcm_lrck_period		= <0x80>;
      			slot_width_select	= <0x20>;
      			frametype		= <0x00>;
      			tdm_config		= <0x01>;
      			tdm_num			= <0x00>;
      			mclk_div		= <0x00>;
      			clk_parent		= <0x01>;
      			capture_cma		= <128>;
      			tx_num			= <4>;
      			tx_chmap1		= <0x76543210>;
      			tx_chmap0		= <0xFEDCBA98>;
      			rx_num			= <4>;
      			rx_chmap3		= <0x03020100>;
      			rx_chmap2		= <0x07060504>;
      			rx_chmap1		= <0x0B0A0908>;
      			rx_chmap0		= <0x0F0E0D0C>;
      			asrc_function_en	= <0x00>;
      			device_type = "daudio0";
      		sounddaudio0: sounddaudio0@20320a0 {
      			reg = <0x0 0x020320a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio0";
      				sound-dai = <&daudio0>;
      		/* daudio1 addr: 0x02033000, the others is invalid to avoid build warining */
      		daudio1:daudio@2033000 {
      			reg = <0x0 0x02033000 0x0 0xa0>;
      				 <&ccu CLK_I2S1>,
      				 <&ccu CLK_BUS_I2S1>;
      			clock-names = "pll_audio", "i2s1", "i2s1_bus";
      			resets = <&ccu RST_BUS_I2S1>;
      			dmas		= <&dma 4>, <&dma 4>;
      			interrupts-extended = <&plic0 43 IRQ_TYPE_LEVEL_HIGH>;
      			frametype		= <0x00>;
      			tdm_num			= <0x01>;
      			mclk_div		= <0x00>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio1";
      		sounddaudio1: sounddaudio1@20330a0 {
      			reg = <0x0 0x020330a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio1";
      				sound-dai = <&daudio1>;
      		/* daudio2 addr: 0x02034000, the others is invalid to avoid build warining */
      		daudio2:daudio@2034000 {
      			reg = <0x0 0x02034000 0x0 0xa0>;
      				 <&ccu CLK_I2S2>,
      				 <&ccu CLK_BUS_I2S2>,
      				 <&ccu CLK_PLL_AUDIO0_4X>,
      				 <&ccu CLK_I2S2_ASRC>;
      			resets = <&ccu RST_BUS_I2S2>;
      			dmas		= <&dma 5>, <&dma 5>;
      			interrupts-extended = <&plic0 44 IRQ_TYPE_LEVEL_HIGH>;
      			frametype		= <0x00>;
      			tdm_num			= <0x02>;
      			mclk_div		= <0x01>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio2";
      		sounddaudio2: sounddaudio2@20340a0 {
      			reg = <0x0 0x020340a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio2";
      				sound-dai = <&daudio2>;
      		hdmiaudio: hdmiaudio@20340a4 {
      			reg = <0x0 0x020340a4 0x0 0x4>;
      			compatible = "allwinner,sunxi-hdmiaudio";
      		/* spdif addr: 0x02036000, the others is invalid to avoid build warining */
      		spdif:spdif@2036000 {
      			compatible = "allwinner,sunxi-spdif";
      			reg = <0x0 0x02036000 0x0 0x58>;
      			clocks = <&ccu CLK_PLL_AUDIO0_4X>,
      				 <&ccu CLK_SPDIF_TX>,
      				 <&ccu CLK_BUS_SPDIF>,
      				 <&ccu CLK_PLL_AUDIO1>,
      				 <&ccu CLK_SPDIF_RX>;
      			clock-names = "pll_audio0", "spdif", "spdif_bus",
      				      "pll_audio1", "pll_audio1_div5",
      				      "pll_periph","spdif_rx";
      			resets = <&ccu RST_BUS_SPDIF>;
      			dmas		= <&dma 2>, <&dma 2>;
      			clk_parent	= <0x1>;
      			rx_sync_en      = <0>;
      			device_type = "spdif";
      		soundspdif:soundspdif@2036040 {
      			reg = <0x0 0x02036040 0x0 0x4>;
      			simple-audio-card,name = "sndspdif";
      				 sound-dai = <&spdif>;
      				 /*snd-soc-dummy*/
      		g2d: g2d@5410000 {
      			compatible = "allwinner,sunxi-g2d";
      			reg = <0x0 0x05410000 0x0 0x3ffff>;
      /*			interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;*/
      			interrupts-extended = <&plic0 105 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_G2D>, <&ccu CLK_G2D>, <&ccu CLK_MBUS_G2D>;
      			clock-names = "bus", "g2d", "mbus_g2d";
      			resets = <&ccu RST_BUS_G2D>;
      			iommus = <&mmu_aw 3 1>;
      		disp: disp@5000000 {
      			compatible = "allwinner,sunxi-disp";
      			reg = <0x0 0x05000000 0x0 0x3fffff>,	/* de0 */
      			      <0x0 0x05460000 0x0 0xfff>,	/*display_if_top*/
      			      <0x0 0x05461000 0x0 0xfff>,	/* tcon-lcd0 */
      			      <0x0 0x05470000 0x0 0xfff>,	/* tcon-tv */
      			      <0x0 0x05450000 0x0 0x1fff>;	/* dsi0*/
      /*			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,tcon-lcd0
      				     <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,tcon-tv
      				     <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;dsi*/
      			interrupts-extended = <&plic0 106 IRQ_TYPE_LEVEL_HIGH>,
      					      <&plic0 107 IRQ_TYPE_LEVEL_HIGH>,
      					      <&plic0 108 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_DE0>,
      				 <&ccu CLK_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DPSS_TOP0>,
      				 <&ccu CLK_MIPI_DSI>,
      				 <&ccu CLK_BUS_MIPI_DSI>,
      				 <&ccu CLK_TCON_LCD0>,
      				 <&ccu CLK_TCON_TV>,
      				 <&ccu CLK_BUS_TCON_LCD0>,
      				 <&ccu CLK_BUS_TCON_TV>,
      				 <&ccu CLK_BUS_MIPI_DSI>;
      			clock-names = "clk_de0",
      					"clk_de1",
      					"clk_bus_de0",
      					"clk_bus_de1",
      					"clk_bus_dpss_top0",
      					"clk_bus_dpss_top1",
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0",
      					"clk_tcon0",
      					"clk_tcon1",/*tcon-tv actually*/
      					"clk_bus_tcon0",
      					"clk_bus_tcon1",/*tcon-tv actually*/
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0";
      			resets = <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DPSS_TOP0>,
      				 <&ccu RST_BUS_MIPI_DSI>,
      				 <&ccu RST_BUS_TCON_LCD0>,
      				 <&ccu RST_BUS_TCON_TV>,
      				 <&ccu RST_BUS_LVDS0>;
      			reset-names = "rst_bus_de0",
      					"rst_bus_de1",
      					"rst_bus_dpss_top0",
      					"rst_bus_dpss_top1",
      					"rst_bus_mipi_dsi0",
      					"rst_bus_tcon0",
      					"rst_bus_tcon1",
      					"rst_bus_lvds0";
      			assigned-clocks = <&ccu CLK_DE0>,
      			<&ccu CLK_TCON_TV>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>,
      			<&ccu CLK_PLL_VIDEO0_4X>,
      			<&ccu CLK_PLL_VIDEO1_4X>;
      			assigned-clock-rates = <300000000>,
      			<150000000>,
      			<0>,
      			<0>;
      			boot_disp = <0>;
      			boot_disp1 = <0>;
      			boot_disp2 = <0>;
      			fb_base = <0>;
      			iommus = <&mmu_aw 2 0>;
                   ve: ve@1c0e000 {
                         compatible = "allwinner,sunxi-cedar-ve";
                         reg = <0x0 0x01c0e000 0x0 0x1000>,
                               <0x0 0x03000000 0x0 0x10>,
                               <0x0 0x03001000 0x0 0x1000>;
                         interrupts-extended = <&plic0 82 IRQ_TYPE_LEVEL_HIGH>;
                         clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, <&ccu CLK_MBUS_VE>;
                         clock-names = "bus_ve", "ve", "mbus_ve";
                         resets = <&ccu RST_BUS_VE>;
                         iommus = <&mmu_aw 0 1>;
      		msgbox: msgbox@0601f000 {
      			compatible = "sunxi,msgbox-amp";
      			reg = <0x0 0x03003000 0x0 0x1000>,
      			      <0x0 0x01701000 0x0 0x1000>,
      			      <0x0 0x0601f000 0x0 0x1000>;
      			interrupts-extended = <&plic0 144 IRQ_TYPE_LEVEL_HIGH>,
      					<&plic0 102 IRQ_TYPE_LEVEL_HIGH>,
      					<&plic0 140 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_MSGBOX2>;
      			rpmsg_id = "sunxi,dsp-msgbox","sunxi,dsp-power-msgbox";
      			resets = <&ccu RST_BUS_MSGBOX2>;
      			reset-names = "rst";
      			msgbox_amp_counts = <3>;
      			msgbox_amp_local = <2>;
      			rpmsg_amp_remote-0 = <1>;
      			rpmsg_read_channel-0 = <2>;
      			rpmsg_write_channel-0 = <2>;
      			rpmsg_amp_remote-1 = <1>;
      			rpmsg_read_channel-1 = <0>;
      			rpmsg_write_channel-1 = <0>;
      		lcd0: lcd0@1c0c000 {
      			compatible = "allwinner,sunxi-lcd0";
      			reg = <0x0 0x1c0c000 0x0 0x0>;  /* Fake registers to avoid dtc compiling warnings */
      			pinctrl-names = "active","sleep";
      		sdc2: sdmmc@4022000 {
      			device_type = "sdc2";
      			interrupts-extended = <&plic0 58 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC2>,
      				 <&ccu CLK_BUS_MMC2>;
      			resets = <&ccu RST_BUS_MMC2>;
      			pinctrl-0 = <&sdc2_pins_a>;
      			pinctrl-1 = <&sdc2_pins_b>;
      			bus-width = <4>;
      			req-page-count = <2>;
      			cap-mmc-highspeed;
      			cap-cmd23;
      			mmc-cache-ctrl;
      			non-removable;
      			/*max-frequency = <200000000>;*/
      			max-frequency = <50000000>;
      			cap-erase;
      			mmc-high-capacity-erase-size;
      			no-sdio;
      			no-sd;
      			/*-- speed mode --*/
      			/*sm0: DS26_SDR12*/
      			/*sm1: HSSDR52_SDR25*/
      			/*sm2: HSDDR52_DDR50*/
      			/*sm3: HS200_SDR104*/
      			/*sm4: HS400*/
      			/*-- frequency point --*/
      			/*f0: CLK_400K*/
      			/*f1: CLK_25M*/
      			/*f2: CLK_50M*/
      			/*f3: CLK_100M*/
      			/*f4: CLK_150M*/
      			/*f5: CLK_200M*/
      			sdc_tm4_sm0_freq0 = <0>;
      			sdc_tm4_sm0_freq1 = <0>;
      			sdc_tm4_sm1_freq1 = <0>;
      			sdc_tm4_sm2_freq1 = <0>;
      			sdc_tm4_sm4_freq0_cmd = <0>;
      			sdc_tm4_sm4_freq1_cmd = <0>;
      			/*vmmc-supply = <&reg_3p3v>;*/
      			/*vqmc-supply = <&reg_3p3v>;*/
      			/*vdmc-supply = <&reg_3p3v>;*/
      			/*vmmc = "vcc-card";*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			/*sunxi-power-save-mode;*/
      		sdc0: sdmmc@4020000 {
      			device_type = "sdc0";
      			reg = <0x0 0x04020000 0x0 0x1000>;
      			interrupts-extended = <&plic0 56 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC0>,
      				 <&ccu CLK_BUS_MMC0>;
      			resets = <&ccu RST_BUS_MMC0>;
      			pinctrl-names = "default","mmc_1v8","sleep","uart_jtag";
      			pinctrl-0 = <&sdc0_pins_a>;
      			pinctrl-1 = <&sdc0_pins_b>;
      			pinctrl-2 = <&sdc0_pins_c>;
      			pinctrl-3 = <&sdc0_pins_d &sdc0_pins_e>;
      			bus-width = <4>;
      			/*non-removable;*/
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PF 6 GPIO_ACTIVE_LOW>;*/
      			/* vmmc-supply = <&reg_3p3v>;*/
      			/* vqmc-supply = <&reg_3p3v>;*/
      			/* vdmc-supply = <&reg_3p3v>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			cap-wait-while-busy;
      			no-sdio;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*cap-sdio-irq;*/
      			/*keep-power-in-suspend;*/
      			/*ignore-pm-notify;*/
      			/*sunxi-dly-400k = <1 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr4  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0>;*/
      			/*sunxi-dly-104M  = <1 0 0 0>;*/
      			/*sunxi-dly-208M  = <1 0 0 0>;*/
      			/*sunxi-dly-104M-ddr  = <1 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0>;*/
      		sdc1: sdmmc@4021000 {
      			device_type = "sdc1";
      			reg = <0x0 0x04021000 0x0 0x1000>;
      			interrupts-extended = <&plic0 57 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC1>,
      				 <&ccu CLK_BUS_MMC1>;
      			resets = <&ccu RST_BUS_MMC1>;
      			pinctrl-0 = <&sdc1_pins_a>;
      			pinctrl-1 = <&sdc1_pins_b>;
      			bus-width = <4>;
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PG 6 6 1 2 0>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*sd-uhs-sdr104;*/
      			/*cap-sdio-irq;*/
      			/*sunxi-dly-400k = <1 0 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0 0>;*/
      			sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0 0>;*/
      			sunxi-dly-104M  = <1 0 0 0 1>;
      			/*sunxi-dly-208M  = <1 1 0 0 0>;*/
      			sunxi-dly-208M  = <1 0 0 0 1>;
      			/*sunxi-dly-104M-ddr  = <1 0 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0 0>;*/
      		hdmi: hdmi@5500000 {
      			compatible = "allwinner,sunxi-hdmi";
      			reg = <0x0 0x05500000 0x0 0xfffff>;
      			interrupts-extended = <&plic0 93 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_HDMI>,
      				<&ccu CLK_HDMI_24M>,
      				<&ccu CLK_HDMI_CEC>,
      				<&ccu CLK_TCON_TV>;
      			clock-names = "clk_bus_hdmi",
      					"clk_ddc",
      					"clk_cec",
      					"clk_tcon_tv";
      			resets = <&ccu RST_BUS_HDMI_SUB>,
      				<&ccu RST_BUS_HDMI_MAIN>;
      			reset-names = "rst_bus_sub",
      				      "rst_bus_main";
      			assigned-clocks = <&ccu CLK_HDMI_CEC>;
      			assigned-clock-parents = <&ccu CLK_HDMI_CEC_32K>;
      			assigned-clock-rates = <0>;
      		usbc0:usbc0@0 {
      			device_type = "usbc0";
      			compatible = "allwinner,sunxi-otg-manager";
      			usb_port_type = <2>;
      			usb_detect_type = <1>;
      			usb_id_gpio;
      			usb_det_vbus_gpio;
      			usb_regulator_io = "nocare";
      			usb_wakeup_suspend = <0>;
      			usb_luns = <3>;
      			usb_serial_unique = <0>;
      			rndis_wceis = <1>;
      		udc:udc-controller@0x04100000 {
      			compatible = "allwinner,sunxi-udc";
      			reg = <0x0 0x04100000 0x0 0x1000>, /*udc base*/
      			      <0x0 0x00000000 0x0 0x100>; /*sram base*/
      			interrupts-extended = <&plic0 45 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OTG>;
      			clock-names = "bus_otg";
      			resets = <&ccu RST_BUS_OTG>, <&ccu RST_USB_PHY0>;
      			reset-names = "otg", "phy";
      		ehci0:ehci0-controller@0x04101000 {
      			compatible = "allwinner,sunxi-ehci0";
      			reg = <0x0 0x04101000 0x0 0xFFF>, /*hci0 base*/
      			      <0x0 0x00000000 0x0 0x100>, /*sram base*/
      			      <0x0 0x04100000 0x0 0x1000>; /*otg base*/
      			interrupts-extended = <&plic0 46 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI0>;
      			clock-names = "bus_hci";
      			resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_USB_PHY0>;
      			reset-names = "hci", "phy";
      			hci_ctrl_no = <0>;
      		ohci0:ohci0-controller@0x04101400 {
      			compatible = "allwinner,sunxi-ohci0";
      			reg = <0x0 0x04101400 0x0 0xFFF>, /*hci0 base*/
      			interrupts-extended = <&plic0 47 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>;
      			clock-names = "bus_hci", "ohci";
      			resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_USB_PHY0>;
      			hci_ctrl_no = <0>;
      		usbc1:usbc1@0 {
      			device_type = "usbc1";
      			status = "disable";
      		ehci1:ehci1-controller@0x04200000 {
      			compatible = "allwinner,sunxi-ehci1";
      			reg = <0x0 0x04200000 0x0 0xFFF>, /*ehci1 base*/
      			interrupts-extended = <&plic0 49 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI1>;
      			resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		ohci1:ohci1-controller@0x04200400 {
      			compatible = "allwinner,sunxi-ohci1";
      			reg = <0x0 0x04200400 0x0 0xFFF>, /*ohci1 base*/
      			interrupts-extended = <&plic0 50 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI1>, <&ccu CLK_USB_OHCI1>;
      			resets = <&ccu RST_BUS_OHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		pwm0: pwm0@2000c10 {
      			compatible = "allwinner,sunxi-pwm0";
      			reg = <0x0 0x02000c10 0x0 0x4>;
      			reg_base = <0x02000c00>;
      		pwm1: pwm1@2000c11 {
      			compatible = "allwinner,sunxi-pwm1";
      			reg = <0x0 0x02000c11 0x0 0x4>;
      		pwm2: pwm2@2000c12 {
      			compatible = "allwinner,sunxi-pwm2";
      			reg = <0x0 0x02000c12 0x0 0x4>;
      		pwm3: pwm3@2000c13 {
      			compatible = "allwinner,sunxi-pwm3";
      			reg = <0x0 0x02000c13 0x0 0x4>;
      		pwm4: pwm4@2000c14 {
      			compatible = "allwinner,sunxi-pwm4";
      			reg = <0x0 0x02000c14 0x0 0x4>;
      		pwm5: pwm5@2000c15 {
      			compatible = "allwinner,sunxi-pwm5";
      			reg = <0x0 0x02000c15 0x0 0x4>;
      		pwm6: pwm6@2000c16 {
      			compatible = "allwinner,sunxi-pwm6";
      			reg = <0x0 0x02000c16 0x0 0x4>;
      		pwm7: pwm7@2000c17 {
      			compatible = "allwinner,sunxi-pwm7";
      			reg = <0x0 0x02000c17 0x0 0x4>;
      		lcd_fb0: lcd_fb0@0 {
      			compatible = "allwinner,sunxi-lcd_fb0";
      		vind0: vind@5800800 {
      			#size-cells = <2>;
      			ranges;
      			device_id = <0>;
      			csi_top = <336000000>;
      			csi_isp = <327000000>;
      				<0x0 0x05800000 0x0 0x800>;
      			clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
      				<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
      				<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
      					"csi_bus", "csi_mbus";
      			resets = <&ccu RST_BUS_CSI>;
      			reset-names = "csi_ret";
      			pinctrl-names = "mclk0-default", "mclk0-sleep";
      			pinctrl-0 = <&csi_mclk0_pins_a>;
      			pinctrl-1 = <&csi_mclk0_pins_b>;
      			csi0: csi@5801000{
      				reg = <0x0 0x05801000 0x0 0x1000>;
      				interrupts-extended = <&plic0 116 IRQ_TYPE_LEVEL_HIGH>;
      				pinctrl-0 = <&csi0_pins_a>;
      				pinctrl-1 = <&csi0_pins_b>;
      				device_id = <0>;
      				iommus = <&mmu_aw 1 1>;
      			isp0: isp@5809410 {
      				reg = <0x0 0x05809410 0x0 0x10>;
      				device_id = <0xfe>;
      			isp1: isp@5809420 {
      				reg = <0x0 0x05809420 0x0 0x10>;
      				device_id = <0xff>;
      			scaler0: scaler@5809430 {
      				reg = <0x0 0x05809430 0x0 0x10>;
      				device_id = <0xfe>;
      			scaler1: scaler@5809440 {
      				reg = <0x0 0x05809440 0x0 0x10>;
      				device_id = <0xff>;
      			actuator0: actuator@5809450 {
      				device_type = "actuator0";
      				reg = <0x0 0x05809450 0x0 0x10>;
      				actuator0_slave = <0x18>;
      				actuator0_af_pwdn = <>;
      			flash0: flash@5809460 {
      				device_type = "flash0";
      				reg = <0x0 0x05809460 0x0 0x10>;
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				flash0_flvdd_vol = <>;
      				device_id = <0>;
      			sensor0: sensor@5809470 {
      				device_type = "sensor0";
      				sensor0_mname = "ov5640";
      				sensor0_twi_cci_id = <2>;
      				sensor0_twi_addr = <0x78>;
      				sensor0_mclk_id = <0>;
      				sensor0_pos = "rear";
      				sensor0_isp_used = <0>;
      				sensor0_fmt = <0>;
      				sensor0_stby_mode = <0>;
      				sensor0_vflip = <0>;
      				sensor0_hflip = <0>;
      				sensor0_iovdd-supply = <>;
      				sensor0_iovdd_vol = <>;
      				sensor0_avdd-supply = <>;
      				sensor0_avdd_vol = <>;
      				sensor0_dvdd-supply = <>;
      				sensor0_dvdd_vol = <>;
      				sensor0_power_en = <>;
      				sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
      				sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
      				sensor0_sm_vs = <>;
      				flash_handle = <&flash0>;
      				act_handle = <&actuator0>;
      				device_id = <0>;
      				status	= "okay";
      			sensor1: sensor@5809480 {
      				reg = <0x0 0x05809480 0x0 0x10>;
      				device_type = "sensor1";
      				sensor1_mname = "ov5647";
      				sensor1_twi_cci_id = <3>;
      				sensor1_twi_addr = <0x6c>;
      				sensor1_mclk_id = <1>;
      				sensor1_pos = "front";
      				sensor1_isp_used = <0>;
      				sensor1_fmt = <0>;
      				sensor1_stby_mode = <0>;
      				sensor1_vflip = <0>;
      				sensor1_hflip = <0>;
      				sensor1_iovdd-supply = <>;
      				sensor1_iovdd_vol = <>;
      				sensor1_avdd-supply = <>;
      				sensor1_avdd_vol = <>;
      				sensor1_dvdd-supply = <>;
      				sensor1_dvdd_vol = <>;
      				sensor1_power_en = <>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				device_id = <1>;
      				status	= "okay";
      			vinc0: vinc@5809000 {
      				device_type = "vinc0";
      				interrupts-extended = <&plic0 111 IRQ_TYPE_LEVEL_HIGH>;
      				vinc0_csi_sel = <0>;
      				vinc0_mipi_sel = <0xff>;
      				vinc0_isp_sel = <0>;
      				vinc0_tdm_rx_sel = <0xff>;
      				vinc0_rear_sensor_sel = <0>;
      				vinc0_front_sensor_sel = <0>;
      				vinc0_sensor_list = <0>;
      				device_id = <0>;
      			vinc1: vinc@5809200 {
      				device_type = "vinc1";
      				reg = <0x0 0x05809200 0x0 0x200>;
      				interrupts-extended = <&plic0 112 IRQ_TYPE_LEVEL_HIGH>;
      				vinc1_csi_sel = <0>;
      				vinc1_mipi_sel = <0xff>;
      				vinc1_isp_sel = <1>;
      				vinc1_tdm_rx_sel = <0xff>;
      				vinc1_rear_sensor_sel = <0>;
      				vinc1_front_sensor_sel = <0>;
      				vinc1_sensor_list = <0>;
      				device_id = <1>;
      		tvd: tvd@05c00000 {
      			compatible = "allwinner,sunxi-tvd";
      			reg = <0x0 0x05c00000 0x0 0x00010000>;/*tvd_top*/
      			interrupts-extended = <&plic0 123 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_TVD_TOP>,
      			<&ccu CLK_MBUS_TVIN>;
      			clock-names = "clk_bus_tvd_top",
      			"clk_mbus_tvd";
      			resets = <&ccu RST_BUS_TVD_TOP>;
      			reset-names = "rst_bus_tvd_top";
      			tvd-number = <1>;
      			tvds = <&tvd0>;
      		tvd0: tvd0@05c01000 {
      			compatible = "allwinner,sunxi-tvd0";
      			reg = <0x0 0x05c01000 0x0 0x00010000>;
      			clocks = <&ccu CLK_TVD>,
      			<&ccu CLK_BUS_TVD>;
      			clock-names = "clk_tvd0","clk_bus_tvd0";
      			resets = <&ccu RST_BUS_TVD>;
      			reset-names = "rst_bus_tvd0";
      			assigned-clocks = <&ccu CLK_TVD>;
      			assigned-clock-parents = <&ccu CLK_PLL_VIDEO1>;
      			tvd_used = <1>;
      			tvd_if = <0>;
      文件:device/config/chips/d1-h/configs/nezha/linux-5.4/board.dts
       * Allwinner Technology CO., Ltd. sun20iw1p1 fpga.
       * fpga support.
      /dts-v1/;
      /memreserve/ 0x42000000 0x100000;  /* dsp used 1MB */
      #include "sun20iw1p1.dtsi"
      	compatible = "allwinner,d1-h", "arm,sun20iw1p1", "allwinner,sun20iw1p1";
      	aliases {
      		dsp0 = &dsp0;
      		dsp0_gpio_int= &dsp0_gpio_int;
      		gmac0 = &gmac0;
      	dsp0: dsp0 {
      		compatible = "allwinner,sun20iw1-dsp";
      	dsp0_gpio_int: dsp0_gpio_int {
      		compatible = "allwinner,sun20iw1-dsp-gpio-int";
      		pin-group = "PB", "PC", "PD", "PE";
      	reg_vdd_cpu: vdd-cpu {
      		pwms = <&pwm 0 5000 1>;
      		regulator-name = "vdd_cpu";
      		regulator-ramp-delay = <25>;
      		regulator-always-on;
      		regulator-boot-on;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      &CPU0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	wlan_pins_a:wlan@0 {
      		pins = "PG11";
      		function = "clk_fanout1";
      	uart0_pins_a: uart0_pins@0 {  /* For nezha board */
      		pins = "PB8", "PB9";
      		function = "uart0";
      		bias-pull-up;
      	uart0_pins_b: uart0_pins@1 {  /* For nezha board */
      		function = "uart1";
      		bias-pull-up;
      		pins = "PC0", "PC1";
      		function = "uart2";
      		bias-pull-up;
      		pins = "PD10", "PD11";
      		function = "uart3";
      		muxsel = <5>;
      		bias-pull-up;
      	twi0_pins_a: twi0@0 {
      		function = "twi0";
      	twi0_pins_b: twi0@1 {
      	twi1_pins_a: twi1@0 {
      		pins = "PB4", "PB5";
      		function = "twi1";
      	twi1_pins_b: twi1@1 {
      	twi2_pins_a: twi2@0 {
      		function = "twi2";
      	twi2_pins_b: twi2@1 {
      	twi3_pins_a: twi3@0 {
      		pins = "PB6", "PB7";
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      		       "PE4", "PE5", "PE6", "PE7",
      		       "PE8", "PE9", "PE10", "PE11",
      		       "PE12", "PE13", "PE14", "PE15";
      		function = "gmac0";
      		muxsel = <8>; /* for uboot driver */
      	dmic_pins_a: dmic@0 {
      		/* DMIC_PIN: CLK, DATA0, DATA1, DATA2 */
      		pins = "PE17", "PB11", "PB10", "PE14";
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		/* MCLK, BCLK, LRCK */
      		pins = "PE17", "PE16", "PE15";
      		function = "i2s0";
      		bias-disable;
      	daudio0_pins_b: daudio0@1 {
      		/* DIN0 */
      		pins = "PE14";
      		function = "i2s0_din";
      		bias-disable;
      	daudio0_pins_c: daudio0@2 {
      		/* DOUT0 */
      		pins = "PE13";
      		function = "i2s0_dout";
      		bias-disable;
      	daudio0_pins_d: daudio0_sleep@0 {
      		bias-disable;
      	daudio1_pins_a: daudio1@0 {
      		/* MCLK, LRCK, BCLK */
      		pins = "PG11", "PG12", "PG13";
      		function = "i2s1";
      		bias-disable;
      	daudio1_pins_b: daudio1@1 {
      		/* DIN0 */
      		pins = "PG14";
      		function = "i2s1_din";
      		bias-disable;
      	daudio1_pins_c: daudio1@2 {
      		/* DOUT0 */
      		pins = "PG15";
      		function = "i2s1_dout";
      		bias-disable;
      	daudio1_pins_d: daudio1_sleep@0 {
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		pins = "PB7", "PB5", "PB6";
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2@1 {
      		/* I2S_PIN: DOUT0 */
      		pins = "PB4";
      		function = "i2s2_dout";
      		bias-disable;
      	daudio2_pins_c: daudio2@2 {
      		/* I2S_PIN: DIN0 */
      		pins = "PB3";
      		function = "i2s2_din";
      		bias-disable;
      		pins = "PB7", "PB5", "PB6", "PB4", "PB3";
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PB0";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PB0";
      		bias-disable;
      	spi0_pins_a: spi0@0 {
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_b: spi0@1 {
      		pins = "PC3", "PC7", "PC6";
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_c: spi0@2 {
      		muxsel = <0>;
      	spi1_pins_a: spi1@0 {
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		function = "spi1";
      	spi1_pins_c: spi1@2 {
      	ledc_pins_a: ledc@0 {
      		pins = "PC0";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PC0";
      	pwm0_pin_a: pwm0@0 {
      		pins = "PD16";
      		function = "pwm0";
      		bias-pull-up;
      	pwm0_pin_b: pwm0@1 {
      		pins = "PD16";
      		bias-disable;
      	pwm2_pin_a: pwm2@0 {
      		pins = "PD18";
      		function = "pwm2";
      		bias-pull-up;
      	pwm2_pin_b: pwm2@1 {
      		pins = "PD18";
      		function = "gpio_out";
      	pwm7_pin_a: pwm7@0 {
      		pins = "PD22";
      		function = "pwm7";
      		bias-pull-up;
      	pwm7_pin_b: pwm7@1 {
      		pins = "PD22";
      	s_cir0_pins_a: s_cir@0 {
      		pins = "PB12";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir@1 {
      		pins = "PB12";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart2 {
      	pinctrl-0 = <&uart2_pins_a>;
      	pinctrl-1 = <&uart2_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_a>;
      &soc {
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      		chip_en;
      		power_en;
      		pinctrl-0 = <&wlan_pins_a>;
      		pinctrl-names = "default";
      		status        = "okay";
      		wlan: wlan@0 {
      			clock-names = "32k-fanout1";
      			wlan_busnum    = <0x1>;
      			/*interrupt-parent = <&pio>;
      			wakeup-source;
      		bt: bt@0 {
      			/*bt_power_num = <0x01>;*/
      			/*bt_io_vol = <3300000>;*/
      			/*bt_power_vol = <330000>;*/
      			bt_rst_n      = <&pio PG 18 GPIO_ACTIVE_LOW>;
      			status        = "okay";
      	btlpm: btlpm@0 {
      		uart_index  = <0x1>;
      		bt_wake     = <&pio PG 16 GPIO_ACTIVE_HIGH>;
      		bt_hostwake = <&pio PG 17 GPIO_ACTIVE_HIGH>;
      		status      = "okay";
      	addr_mgt: addr_mgt@0 {
      		type_addr_wifi = <0x0>;
      		type_addr_bt   = <0x0>;
      		type_addr_eth  = <0x0>;
      		status         = "okay";
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	no-sdio;
      	no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-dis-signal-vol-sw;
      	mmc-bootpart-noacc;
      	max-frequency = <150000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &sdc0 {
      	bus-width = <4>;
      	/*non-removable;*/
      	/*broken-cd;*/
      	cd-inverted;
      	/*data3-detect;*/
      	cd-used-24M;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	/*sunxi-dis-signal-vol-sw;*/
      	ctl-spec-caps = <0x8>;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	cap-sdio-irq;
      	ignore-pm-notify;
      tvd configuration
                             mode,mean enable)
      &tvd {
      	tvd_sw          = <1>;
      	tvd_interface   = <0>;
      	tvd_format      = <0>;
      	tvd_system      = <1>;
      	tvd_row         = <1>;
      	tvd_column      = <1>;
      	tvd_channel0_en = <1>;
      	tvd_channel1_en = <0>;
      	tvd_channel2_en = <0>;
      	tvd_channel3_en = <0>;
      	/*tvd_power0      = "dc1sw"*/
      	/*tvd_power1      = "eldo3"*/
      &tvd0 {
      /* Audio Driver modules */
      &sunxi_rpaf_dsp0 {
      &codec {
      	mic1gain 	= <0x13>;
      	mic2gain 	= <0x13>;
      	mic3gain 	= <0x13>;
      	adcdrc_cfg 	= <0x0>;
      	adchpf_cfg 	= <0x1>;
      	dacdrc_cfg 	= <0x0>;
      	dachpf_cfg 	= <0x0>;
      	/* Volume about */
      	digital_vol 	= <0x00>;
      	lineout_vol 	= <0x1a>;
      	headphonegain	= <0x03>;
      	/* Pa enabled about */
      	pa_level 	= <0x01>;
      	pa_pwr_level 	= <0x01>;
      	pa_msleep_time 	= <0x78>;
      	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>; */
      	/* regulator about */
      &sndcodec {
      	hp_detect_case	= <0x01>;
      	jack_enable	= <0x01>;
      &dummy_cpudai {
      	/* CMA config about */
      &dmic {
      &sounddmic {
      &dmic_codec {
       * tdm_config		0 --> pcm
       *			1 --> i2s
       * mclk_div		0 --> not output
       *			1 --> HDMI audio type
      &daudio0 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	pinctrl-0       = <&daudio0_pins_a &daudio0_pins_b &daudio0_pins_c>;
      	pinctrl-1       = <&daudio0_pins_d>;
      	pinctrl_used	= <0x0>;
      &sounddaudio0 {
      		/* sound-dai = <&ac108>; */
      &daudio1 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	pinctrl-0       = <&daudio1_pins_a &daudio1_pins_b &daudio1_pins_c>;
      	pinctrl-1       = <&daudio1_pins_d>;
      &sounddaudio1 {
      &daudio2 {
      	mclk_div 	= <0x00>;
      	frametype 	= <0x00>;
      	pcm_lrck_period = <0x20>;
      	/*pinctrl-0       = <&daudio2_pins_a &daudio2_pins_b &daudio2_pins_c>;*/
      	/*pinctrl-1       = <&daudio2_pins_d>;*/
      	/* HDMI audio, no need pin */
      	pinctrl-0;
      	pinctrl-1;
      	daudio_type	= <0x1>;
      &hdmiaudio {
      &sounddaudio2 {
      	simple-audio-card,name = "sndhdmi";
      		sound-dai = <&hdmiaudio>;
      &spdif {
      &soundspdif {
      &usbc0 {
      	usb_port_type = <0x2>;
      	usb_detect_type = <0x1>;
      	usb_detect_mode = <0>;
      	usb_id_gpio = <&pio PD 21 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	usb_det_vbus_gpio = <&pio PD 20 GPIO_ACTIVE_HIGH>;
      	rndis_wceis = <1>;
      &ehci0 {
      &ohci0 {
      &usbc1 {
      &ehci1 {
      &ohci1 {
      &twi0 {
      	pinctrl-0 = <&twi0_pins_a>;
      	pinctrl-1 = <&twi0_pins_b>;
      	eeprom@50 {
      		compatible = "atmel,24c16";
      		reg = <0x50>;
      &twi1 {
      	pinctrl-0 = <&twi1_pins_a>;
      	pinctrl-1 = <&twi1_pins_b>;
      &twi2 {
      	pinctrl-0 = <&twi2_pins_a>;
      	pinctrl-1 = <&twi2_pins_b>;
      	/* pcf8574-usage:
      	 * pin set:
      	 * interrupt set:
      	pcf8574: gpio@38 {
      		compatible = "nxp,pcf8574";
      		reg = <0x38>;
      		gpio_base = <2020>;
      		gpio-controller;
      		#gpio-cells = <2>;
      	ctp@14 {
      		device_type = "ctp";
      		reg = <0x14>;
      		ctp_name = "gt9xxnew_ts";
      		ctp_twi_id = <0x2>;
      		ctp_twi_addr = <0x14>;
      		ctp_screen_max_x = <0x320>;
      		ctp_screen_max_y = <0x500>;
      		ctp_revert_x_flag = <0x0>;
      		ctp_revert_y_flag = <0x1>;
      		ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
      		ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
      &twi3 {
      	pinctrl-0 = <&twi3_pins_a>;
      	pinctrl-1 = <&twi3_pins_b>;
      &gmac0 {
      	phy-mode = "rgmii";
      	use_ephy25m = <1>;
      	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
      	tx-delay = <3>; /*2~4*/
      	rx-delay = <0>;
      	status = "disable";
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<0x5F5E100>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="disabled";
      &spi1 {
      	pinctrl-1 = <&spi1_pins_c>;
      	spi_dbi_enable = <1>;
      	spi_board1@0 {
      		device_type = "spi-dbi";
      		compatible = "sunxi,spidbi";
      		reg = <0x0>;
      		spi-rx-bus-width = <0x4>;
      		spi-tx-bus-width = <0x4>;
      	/* spi_board1@0 {
      		device_type = "spi_board1";
      		compatible = "rohm,dh2228fv";
      		reg = <0x0>;
      &ledc {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <12>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <320>;
      	t0h_ns = <300>;
      	t0l_ns = <800>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      	status	= "okay";
      &keyboard0 {
      	key0 = <210 0x160>;
      	wakeup-source;
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      &disp {
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	lcd_used        = <1>;
      	lcd_driver_name = "st7701s_rgb";
      	lcd_if          = <0>;
      	lcd_hv_if       = <0>;
      	lcd_width       = <53>;
      	lcd_height      = <53>;
      	lcd_x           = <480>;
      	lcd_y           = <480>;
      	lcd_dclk_freq   = <19>;
      	lcd_hbp         = <60>;
      	lcd_ht          = <612>;
      	lcd_hspw        = <12>;
      	lcd_vbp         = <18>;
      	lcd_vt          = <520>;
      	lcd_vspw        = <4>;
      	lcd_backlight   = <100>;
      	lcd_pwm_used    = <1>;
      	lcd_pwm_ch      = <7>;
      	lcd_pwm_freq    = <1000>;
      	lcd_pwm_pol     = <1>;
      	lcd_bright_curve_en = <0>;
      	lcd_frm         = <1>;
      	lcd_io_phase    = <0x0000>;
      	lcd_gamma_en    = <0>;
      	lcd_cmap_en     = <0>;
      	lcd_hv_clk_phase= <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_rb_swap          = <0>;
      	lcd_power       = "vcc-lcd";
      	lcd_pin_power   = "vcc-pd";
      	lcd_gpio_0      = <&pio PG 13 GPIO_ACTIVE_HIGH>;
      	lcd_gpio_1      = <&pio PE 15 GPIO_ACTIVE_HIGH>;
      	lcd_gpio_2      = <&pio PE 12 GPIO_ACTIVE_HIGH>;
      	lcd_gpio_3      = <&pio PE 16 GPIO_ACTIVE_HIGH>;
      	pinctrl-0       = <&rgb18_pins_a>;
      	pinctrl-1       = <&rgb18_pins_b>;
      &hdmi {
      	hdmi_used = <1>;
      	hdmi_power_cnt = <0>;
      	hdmi_cts_compatibility = <1>;
      	hdmi_hdcp_enable = <1>;
      	hdmi_hdcp22_enable = <0>;
      	hdmi_cec_support = <1>;
      	hdmi_cec_super_standby = <0>;
      	ddc_en_io_ctrl = <0>;
      	power_io_ctrl = <0>;
      &pwm0 {
      	pinctrl-0 = <&pwm0_pin_a>;
      	pinctrl-1 = <&pwm0_pin_b>;
      &pwm2 {
      	pinctrl-0 = <&pwm2_pin_a>;
      	pinctrl-1 = <&pwm2_pin_b>;
      &pwm7 {
      	pinctrl-0 = <&pwm7_pin_a>;
      	pinctrl-1 = <&pwm7_pin_b>;
      &rtp {
      	allwinner,ts-attached;
      &gpadc {
      	channel_num = <2>;
      	channel_select = <3>;
      	channel_data_select = <3>;
      	channel_compare_select = <3>;
      	channel_cld_select = <3>;
      	channel_chd_select = <3>;
      &s_cir0 {
      	pinctrl-0 = <&s_cir0_pins_a>;
      	pinctrl-1 = <&s_cir0_pins_b>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      	pinctrl-1 = <&ir1_pins_b>;
      /* &lcd_fb0 {
      	lcd_used = <1>;
      	lcd_driver_name = "kld35512";
      	lcd_if = <1>;
      	lcd_dbi_if = <4>;
      	lcd_data_speed = <60>;
      	lcd_spi_bus_num = <1>;
      	lcd_x = <320>;
      	lcd_y = <480>;
      	lcd_pixel_fmt = <10>;
      	lcd_dbi_fmt = <2>;
      	lcd_rgb_order = <0>;
      	lcd_width = <60>;
      	lcd_height = <95>;
      	lcd_pwm_used = <1>;
      	lcd_pwm_ch = <7>;
      	lcd_pwm_freq = <5000>;
      	lcd_pwm_pol = <1>;
      	lcd_frm = <1>;
      	lcd_gamma_en = <1>;
      	fb_buffer_num = <2>;
      	lcd_fps = <40>;
      	lcd_dbi_te = <1>;
      	lcd_dbi_clk_mode = <1>;
      	lcd_gpio_0 = <&pio PC 0 GPIO_ACTIVE_HIGH>;
      /* &lcd_fb0 {
      	lcd_used = <1>;
      	lcd_driver_name = "kld2844b";
      	lcd_if = <1>;
      	lcd_dbi_if = <4>;
      	lcd_x = <240>;
      	lcd_y = <320>;
      	lcd_width = <60>;
      	lcd_height = <95>;
      	lcd_pwm_used = <1>;
      	lcd_pwm_ch = <7>;
      	lcd_pwm_pol = <0>;
      	lcd_pixel_fmt = <0>;
      	lcd_dbi_fmt = <3>;
      	lcd_frm = <1>;
      	lcd_gamma_en = <1>;
      	lcd_dbi_te = <1>;
      	lcd_fps = <60>;
      求大佬指点这个可能是被哪个设备占用了,或者有什么方法能找到被占用的地方🙏
        柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
        你要不要再找找?我帮你找到了一个
        D 1 条回复 最后回复 回复 引用 分享 0
          dyd2022 LV 3 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 非常感谢,没仔细看,按 PD19 搜了没搜到,没想到是分开写的😂
