    R329系统启动阻塞问题求救
    A Series
    5631
    • R
      ROIDMI LV 4 最后由 xiaowenge 编辑
      U-Boot 2018.05-g6f0ec64 (Apr 27 2022 - 02:21:36 +0000) Allwinner Technology
      [00.317]CPU:   Allwinner Family
      [00.320]Model: sun50iw11
      I2C:   ready
      [00.444]DRAM:  256 MiB
      [00.447]Relocation Offset is: 0cefa000
      [00.470]secure enable bit: 0
      [00.473]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=0Mhz
      [00.479]gic: sec monitor mode
      [00.482]flash init start
      [00.484]workmode = 0,storage type = 0
      [BCC] 0x4025038 = 0x10000000, [DMA] 0x4025088 = 0x000000e5
      [00.536]sunxi-spinand-phy: not detect any munufacture from id table
      [00.543]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.548]sunxi-spinand-phy: get phy info from fdt fail
      device nand0 <nand>, # parts = 5
       3: pstore              0x00080000      0x00500000      1
       4: sys                 0x0fa80000      0x00580000      0
      defaults:
      mtdids  : nand0=nand
      mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,512k@5242880(pstore)ro,-(sys)
      [00.737]ubi0: attaching mtd5
      [00.933]ubi0: scanning is finished
      [00.940]ubi0: attached mtd5 (name "sys", size 250 MiB)
      [00.944]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.951]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.957]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.963]ubi0: good PEBs: 1002, bad PEBs: 0, corrupted PEBs: 0
      [00.968]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.975]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.983]ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 40
      [00.991]sunxi flash init ok
      [01.085]Loading Environment from SUNXI_FLASH... OK
      307254 bytes read in 15 ms (19.5 MiB/s)
      [01.128]Item0 (Map) magic is bad
      [01.130]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [01.142]usb prepare ok
      [01.349]usb sof ok
      [01.351]usb probe ok
      [01.353]usb setup ok
      set address 0x7
      set address 0x7 ok
      set address 0x8
      set address 0x8 ok
      [04.359]do_burn_from_boot usb : have no handshake
      [04.387]update bootcmd
      [04.404]update dts
      [04.623]no vendor_boot partition is found
      Android's image name: r329-evb5_pro_v1
      [04.865]Starting kernel ...
      [    0.000000] Linux version 4.9.191 (ubuntu@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #27 SMP PREEMPT Thu Sep 8 12:20:29 UTC 2022
      [    0.000000] Boot CPU: AArch64 Processor [410fd034]
      [    0.000000] bootconsole [earlycon0] enabled
      [    0.000000] disp reserve base 0x4eb556c0 ,size 0x4b036
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000043000000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@43000000, compatible id shared-dma-pool
      [    0.000000] Reserved memory: created DMA memory pool at 0x0000000043040000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@43040000, compatible id shared-dma-pool
      [    0.000000] cma: Reserved 24 MiB at 0x000000004d000000
      [    0.000000] On node 0 totalpages: 65075
      [    0.000000]   DMA zone: 1024 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 65075 pages, LIFO batch:15
      [    0.000000] psci: Trusted OS migration not required
      [    0.000000] percpu: Embedded 21 pages/cpu s46360 r8192 d31464 u86016
      [    0.000000] pcpu-alloc: s46360 r8192 d31464 u86016 alloc=21*4096
      [    0.000000] Detected VIPT I-cache on CPU0
      [    0.000000] CPU features: enabling workaround for ARM erratum 845719
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64051
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 initcall_debug=0 console=ttyS0,115200 loglevel=8 ubi.mtd=sys ubi.block=0,rootfs root=/dev/ubiblock0_5 init=/sbin/init rdinit=/rdinit rootfstype=squashfs partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:dsp1@ubi0_7:UDISK@ubi0_8: cma=24M mac_addr= wifi_mac= bt_mac= selinux=0 specialstr= snum=4c000c5960c1c7d1c0d androidboot.serialno=4c000c5960c1c7d1c0d androidboot.hardware=sun50iw11p1 boot_type=5 androidboot.boot_type=5 androidboot.secure_os_exist=0 gpt=1 uboot_message=2018.05-g6f0ec64(04/27/2022-02:21:36) mbr_offset=1032192 disp_reserve=307254,0x4eb556c0 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=256
      [    0.000000] PID hash table entries: 1024 (order: 1, 8192 bytes)
      [    0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
      [    0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
      [    0.000000] Memory: 213364K/260300K available (5822K kernel code, 486K rwdata, 1648K rodata, 384K init, 229K bss, 22360K reserved, 24576K cma-reserved)
      [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
      [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
      [    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008630000   (  5824 KB)
      [    0.000000]     .rodata : 0xffffff8008630000 - 0xffffff80087d0000   (  1664 KB)
      [    0.000000]       .init : 0xffffff80087d0000 - 0xffffff8008830000   (   384 KB)
      [    0.000000]       .data : 0xffffff8008830000 - 0xffffff80088a9808   (   487 KB)
      [    0.000000]        .bss : 0xffffff80088a9808 - 0xffffff80088e2cf4   (   230 KB)
      [    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
      [    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
      [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc010000000   (   256 MB)
      [    0.000000]  Build-time adjustment of leaf fanout to 64.
      [    0.000000] NR_IRQS:64 nr_irqs:64 0
      [    0.000000] clk r_dsp_cache0 not found in of_sunxi_periph_cpus_clk_setup
      [    0.000000] clk r_dsp_cache1 not found in of_sunxi_periph_cpus_clk_setup
      [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
      [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.008233] Console: colour dummy device 80x25
      [    0.012410] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
      [    0.022618] pid_max: default: 32768 minimum: 301
      [    0.027377] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
      [    0.033721] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
      [    0.041502] sched-energy: CPU device node has no sched-energy-costs
      [    0.046921] Invalid sched_group_energy for CPU0
      [    0.051402] CPU0: update cpu_capacity 1024
      [    0.067521] ASID allocator initialised with 32768 entries
      [    0.123755] Detected VIPT I-cache on CPU1
      [    0.123805] Invalid sched_group_energy for CPU1
      [    0.123808] CPU1: update cpu_capacity 1024
      [    0.123811] CPU1: Booted secondary processor [410fd034]
      [    0.123898] Brought up 2 CPUs
      [    0.139000] SMP: Total of 2 processors activated.
      [    0.143690] CPU features: detected feature: 32-bit EL0 Support
      [    0.149496] CPU features: detected feature: Kernel page table isolation (KPTI)
      [    0.158915] CPU: All CPU(s) started at EL1
      [    0.160773] alternatives: patching kernel code
      [    0.165331] Invalid sched_group_energy for CPU1
      [    0.169692] Invalid sched_group_energy for Cluster1
      [    0.174541] Invalid sched_group_energy for CPU0
      [    0.179048] Invalid sched_group_energy for Cluster0
      [    0.184368] devtmpfs: initialized
      [    0.214561] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.218692] futex hash table entries: 512 (order: 4, 65536 bytes)
      [    0.225810] atomic64_test: passed
      [    0.228018] pinctrl core: initialized pinctrl subsystem
      [    0.234297] NET: Registered protocol family 16
      [    0.238780] dump_class_init,857, success
      [    0.257772] cpuidle: using governor menu
      [    0.258394] vdso: 2 pages (1 code @ ffffff8008636000, 1 data @ ffffff8008834000)
      [    0.264589] DMA: preallocated 256 KiB pool for atomic allocations
      [    0.275701] sun50iw11p1-r-pinctrl r_pio: initialized sunXi PIO driver
      [    0.284183] sun50iw11p1-pinctrl pio: initialized sunXi PIO driver
      [    0.341956] pwm module init!
      [    0.346227] sunxi-pm debug v3.10
      [    0.346948] SCSI subsystem initialized
      [    0.347877] usbcore: registered new interface driver usbfs
      [    0.353140] usbcore: registered new interface driver hub
      [    0.358412] usbcore: registered new device driver usb
      [    0.363499] sunxi_i2c_adap_init()2649 - init
      [    0.368586] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.374665] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.381011] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
      [    0.387822] ion_heap_create: Invalid heap type 6
      [    0.392402] Advanced Linux Sound Architecture Driver Initialized.
      [    0.398846] Bluetooth: Core ver 2.22
      [    0.401768] NET: Registered protocol family 31
      [    0.406161] Bluetooth: HCI device and connection manager initialized
      [    0.412493] Bluetooth: HCI socket layer initialized
      [    0.417336] Bluetooth: L2CAP socket layer initialized
      [    0.422411] Bluetooth: SCO socket layer initialized
      [    0.431695] clocksource: Switched to clocksource arch_sys_counter
      [    0.444212] get androidboot.mode fail
      [    0.444903] NET: Registered protocol family 2
      [    0.447159] TCP established hash table entries: 16 (order: -5, 128 bytes)
      [    0.453463] TCP bind hash table entries: 16 (order: -4, 256 bytes)
      [    0.459512] TCP: Hash tables configured (established 16 bind 16)
      [    0.465551] UDP hash table entries: 256 (order: 1, 8192 bytes)
      [    0.471307] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
      [    0.477755] NET: Registered protocol family 1
      [    0.482684] sunxi_spi_probe()2152 - [spi0] SPI MASTER MODE
      [    0.487413] spi0 supply spi not found, using dummy regulator
      [    0.493041] sunxi_spi_request_gpio()1804 - [spi0] Pinctrl init spi0
      [    0.499261] sunxi_spi_clk_init()1854 - [spi0] mclk 100000000
      [    0.505538] sunxi_spi_probe()2225 - [spi0]: driver probe succeed, base ffffff8008060000, irq 245
      [    0.515968] workingset: timestamp_bits=61 max_order=16 bucket_order=0
      [    0.528992] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.532066] io scheduler noop registered
      [    0.533091] io scheduler deadline registered
      [    0.537720] io scheduler cfq registered (default)
      [    0.543140] [LCD_FB] lcd_fb_init,line:159:
      [    0.546030]
      [    0.554224] uart uart0: get regulator failed
      [    0.554281] uart0 supply uart not found, using dummy regulator
      [    0.558999] uart0: ttyS0 at MMIO 0x2500000 (irq = 244, base_baud = 1500000) is a SUNXI
      Vss▒{c+▒▒▒˛▒▒] sw_console_k▒VvFVvf▒
        c+#k
            [    0.574576] console [ttyS0] enabled
      [    0.578524] bootconsole [earlycon0] disabled
      [    0.587556] misc dump reg init
      [    0.594692] Unable to detect cache hierarchy for CPU 0
      [    0.601423] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
      [    0.608686] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211125
      [    0.616552] sunxi-spinand-phy: not detect any munufacture from id table
      [    0.623987] sunxi-spinand-phy: get spi-nand Model from fdt fail
      [    0.630628] sunxi-spinand-phy: get phy info from fdt fail
      [    0.636689] sunxi-spinand-phy: not detect munufacture from fdt
      [    0.643370] sunxi-spinand-phy: detect munufacture from id table: GD
      [    0.650408] sunxi-spinand-phy: detect spinand id: ffff52c8 ffffffff
      [    0.657438] sunxi-spinand-phy: ========== arch info ==========
      [    0.663984] sunxi-spinand-phy: Model:               GD5F2GQ5UEYIGR
      [    0.670918] sunxi-spinand-phy: Munufacture:         GD
      [    0.676684] sunxi-spinand-phy: DieCntPerChip:       1
      [    0.682351] sunxi-spinand-phy: BlkCntPerDie:        2048
      [    0.688311] sunxi-spinand-phy: PageCntPerBlk:       64
      [    0.694075] sunxi-spinand-phy: SectCntPerPage:      4
      [    0.699741] sunxi-spinand-phy: OobSizePerPage:      64
      [    0.705505] sunxi-spinand-phy: BadBlockFlag:        0x0
      [    0.711362] sunxi-spinand-phy: OperationOpt:        0x7
      [    0.717222] sunxi-spinand-phy: MaxEraseTimes:       50000
      [    0.723275] sunxi-spinand-phy: EccFlag:             0x1
      [    0.729137] sunxi-spinand-phy: EccType:             7
      [    0.734803] sunxi-spinand-phy: EccProtectedType:    2
      [    0.740467] sunxi-spinand-phy: ========================================
      [    0.747886] sunxi-spinand-phy:
      [    0.751399] sunxi-spinand-phy: ========== physical info ==========
      [    0.758331] sunxi-spinand-phy: TotalSize:    256 M
      [    0.763706] sunxi-spinand-phy: SectorSize:   512 B
      [    0.769077] sunxi-spinand-phy: PageSize:     2 K
      [    0.774258] sunxi-spinand-phy: BlockSize:    128 K
      [    0.779633] sunxi-spinand-phy: OOBSize:      64 B
      [    0.784909] sunxi-spinand-phy: ========================================
      [    0.792324] sunxi-spinand-phy:
      [    0.795847] sunxi-spinand-phy: ========== logical info ==========
      [    0.802681] sunxi-spinand-phy: TotalSize:    256 M
      [    0.808058] sunxi-spinand-phy: SectorSize:   512 B
      [    0.813433] sunxi-spinand-phy: PageSize:     4 K
      [    0.818614] sunxi-spinand-phy: BlockSize:    256 K
      [    0.823985] sunxi-spinand-phy: OOBSize:      128 B
      [    0.829359] sunxi-spinand-phy: ========================================
      [    0.836867] sunxi-spinand-phy: block lock register: 0x00
      [    0.842956] sunxi-spinand-phy: feature register: 0x11
      [    0.848632] sunxi-spinand-phy: sunxi physic nand init end
      [    0.855003] Creating 5 MTD partitions on "sunxi_mtd_nand":
      [    0.861167] 0x000000000000-0x000000100000 : "boot0"
      [    0.868340] 0x000000100000-0x000000400000 : "uboot"
      [    0.877856] 0x000000400000-0x000000500000 : "secure_storage"
      [    0.884510] random: fast init done
      [    0.889633] 0x000000500000-0x000000580000 : "pstore"
      [    0.896463] pstore_zone: registered pstore_blk as backend for kmsg(Oops,panic_write)
      [    0.905211] pstore: Registered pstore_blk as persistent store backend
      [    0.912445] mtd mtd3: Attached to MTD device 3
      [    0.917444] 0x000000580000-0x000010000000 : "sys"
      [    1.262145] random: crng init done
      [    1.292544] libphy: Fixed MDIO Bus: probed
      [    1.297433] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.305036] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.312331] usbcore: registered new interface driver uas
      [    1.318400] usbcore: registered new interface driver usb-storage
      [    1.325193] usbcore: registered new interface driver ums-alauda
      [    1.331888] usbcore: registered new interface driver ums-cypress
      [    1.338675] usbcore: registered new interface driver ums-datafab
      [    1.345464] usbcore: registered new interface driver ums_eneub6250
      [    1.352449] usbcore: registered new interface driver ums-freecom
      [    1.359240] usbcore: registered new interface driver ums-isd200
      [    1.365935] usbcore: registered new interface driver ums-jumpshot
      [    1.372832] usbcore: registered new interface driver ums-karma
      [    1.379429] usbcore: registered new interface driver ums-onetouch
      [    1.386338] usbcore: registered new interface driver ums-realtek
      [    1.393126] usbcore: registered new interface driver ums-sddr09
      [    1.399822] usbcore: registered new interface driver ums-sddr55
      [    1.406514] usbcore: registered new interface driver ums-usbat
      [    1.413166] usb_serial_number:20080411
      [    1.417952] sunxi_gpadc_init,1962, success
      [    1.423470] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.430380] sunxi-rtc rtc: RTC enabled
      [    1.434630] fix to hot reboot, save boot reason
      [    1.439952] i2c /dev entries driver
      [    1.444036] lirc_dev: IR Remote Control driver registered, major 247
      [    1.451168] IR NEC protocol handler initialized
      [    1.456257] IR RC5(x/sz) protocol handler initialized
      [    1.461922] IR LIRC bridge handler initialized
      [    1.467368] sunxi cedar version 0.1
      [    1.471492] google_vp9: sunxi google vp9 version 0.1
      [    1.478387] sunxi-wdt 20000a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.487457] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
      [    1.494796] Bluetooth: HCI UART protocol H4 registered
      [    1.500558] Bluetooth: HCI H4 protocol initialized
      [    1.505935] Bluetooth: HCI UART protocol (null) registered
      [    1.512097] Bluetooth: HCI Realtek H5 protocol initialized
      [    1.522471] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
      [    1.529894] bt_fdi debugfs_init
      [    1.536470] hidraw: raw HID events driver (C) Jiri Kosina
      [    1.542761] usbcore: registered new interface driver usbhid
      [    1.549027] usbhid: USB HID core driver
      [    1.556148] armchina aipu: AIPU KMD probe start...
      [    1.561552] armchina aipu: KMD version: release 3.0.11
      [    1.567328] armchina aipu: no interrupts-reg specified
      [    1.573508] armchina aipu: add new region failed
      [    1.578967] armchina: probe of aipu failed with error -22
      [    1.585435] Netfilter messages via NETLINK v0.30.
      [    1.590935] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
      [    1.597724] ctnetlink v0.93: registering with nfnetlink.
      [    1.603978] ip_tables: (C) 2000-2006 Netfilter Core Team
      [    1.610620] NET: Registered protocol family 10
      [    1.616666] NET: Registered protocol family 17
      [    1.621833] Bluetooth: RFCOMM TTY layer initialized
      [    1.627325] Bluetooth: RFCOMM socket layer initialized
      [    1.633114] Bluetooth: RFCOMM ver 1.11
      [    1.637334] 8021q: 802.1Q VLAN Support v1.8
      [    1.654035] cpu cpu1: opp_list_debug_create_link: Failed to create link
      [    1.661498] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
      [    1.673066] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1008000 KHz
      [    1.685740] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1104000 KHz
      [    1.699909] ubi0: attaching mtd4
      [    2.083797] ubi0: scanning is finished
      [    2.095039] ubi0: attached mtd4 (name "sys", size 250 MiB)
      [    2.101210] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [    2.108927] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [    2.116541] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [    2.124352] ubi0: good PEBs: 1002, bad PEBs: 0, corrupted PEBs: 0
      [    2.131186] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [    2.139288] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [    2.148659] ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 40
      [    2.159157] ubi0: background thread "ubi_bgt0d" started, PID 734
      [    2.170561] block ubiblock0_5: created from ubi0:5(rootfs)
      [    2.177039] sunxi-rtc rtc: setting system clock to 1970-01-02 09:27:02 UTC (120422)
      [    2.186565] ALSA device list:
      [    2.189903]   No soundcards found.
      [    2.196160] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
      [    2.205659] devtmpfs: mounted
      [    2.209249] Freeing unused kernel memory: 384K
      [    2.606356] init: Console is alive
      [    2.610370] init: - watchdog -
      [    2.613872] init: - preinit -
      /dev/by-name/UDISK already format by ubifs
      [    3.171681] mount_root: mounting /dev/root
      [    3.177140] mount_root: loading kmods from internal overlay
      [    3.276175] block: attempting to load /etc/config/fstab
      [    3.295311] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 779
      [    3.350739] UBIFS (ubi0:8): recovery needed
      [    3.512291] UBIFS (ubi0:8): recovery completed
      [    3.517337] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
      [    3.525540] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      [    3.536663] UBIFS (ubi0:8): FS size: 188633088 bytes (179 MiB, 731 LEBs), journal size 9420800 bytes (8 MiB, 37 LEBs)
      [    3.548559] UBIFS (ubi0:8): reserved for root: 0 bytes (0 KiB)
      [    3.555103] UBIFS (ubi0:8): media format: w4/r0 (latest is w4/r0), UUID 7F434AE4-A781-4053-8A82-96C402FFA2B6, small LPT model
      [    3.569973] block: extroot: UUID match (root: a69af1b8-64fb5e48-26223ddf-ba2addc3, overlay: a69af1b8-64fb5e48-26223ddf-ba2addc3)
      [    3.590813] mount_root: switched to extroot
      [    3.601299] procd: - early -
      [    3.604656] procd: - watchdog -
      [    3.739075] procd: - watchdog -
      [    3.742867] procd: - ubus -
      [    3.746520] procd (1): /proc/946/oom_adj is deprecated, please use /proc/946/oom_score_adj instead.
      [    3.849351] procd: - init -
      [    4.228067] fuse init (API version 7.26)
      [    4.243958] sunxi-rproc dsp0_rproc@0: assigned reserved memory node vdev0buffer@43000000
      [    4.256897]  remoteproc0: dsp0_rproc is available
      [    4.262631]  remoteproc0: Note: remoteproc is still under development and considered experimental.
      [    4.273243]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
      [    4.292064] find loop: 0
      [    4.296335] sunxi-rproc dsp1_rproc@0: assigned reserved memory node vdev0buffer@43040000
      [    4.308991]  remoteproc1: dsp1_rproc is available
      [    4.314730]  remoteproc1: Note: remoteproc is still under development and considered experimental.
      [    4.324898]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
      [    4.380298] file system registered
      [    4.389533]  remoteproc0: powering up dsp0_rproc
      [    4.394853]  remoteproc0: Booting fw image dsp0.bin, size 329064
      [    4.405679] virtio_rpmsg_bus virtio0: rpmsg host is online
      [    4.412831] xt_time: kernel timezone is -0000
      [    4.419930]  remoteproc0: registered virtio0 (type 7)
      [    4.425987] sunxi-rproc dsp0_rproc@0: daudio: frame_type does not exist
      kmodloader done[    4.437678] sunxi-rproc dsp0_rproc@0: daudio: daudio_type does not exist
      [    4.442521]  remoteproc1: powering up dsp1_rproc
      [    4.442534]  remoteproc1: Booting fw image dsp1.bin, size 370904
      [    4.442970] virtio_rpmsg_bus virtio1: rpmsg host is online
      [    4.442983]  remoteproc1: registered virtio1 (type 7)
      [    4.442990]  remoteproc1: between_dsps_vdevvring0 small than resource table require!
      [    4.442993]  remoteproc1: between_dsps_vdevvring1 small than resource table require!
      [    4.443260] sunxi-rproc dsp1_rproc@0: daudio: frame_type does not exist
      [    4.443265] sunxi-rproc dsp1_rproc@0: daudio: daudio_type does not exist
      [    4.443327] sunxi-rproc dsp1_rproc@0: daudio: frame_type does not exist
      [    4.443332] sunxi-rproc dsp1_rproc@0: daudio: daudio_type does not exist
      [    4.443474] sunxi-rproc dsp1_rproc@0: standby_param: vdd-pll does not exist
      [    4.444031]  remoteproc1: Booting remote process success
      [    4.444040]  remoteproc1: remote processor dsp1_rproc is now up
      [    4.553882] sunxi-rproc dsp0_rproc@0: daudio: frame_type does not exist
      [    4.563797] sunxi-rproc dsp0_rproc@0: daudio: daudio_type does not exist
      [    4.573585] sunxi-rproc dsp0_rproc@0: standby_param: vdd-pll does not exist
      [    4.581820]  remoteproc0: Booting remote process success
      [    4.589916]  remoteproc0: remote processor dsp0_rproc is now up
      [    4.612655] read descriptors
      [    4.616241] read strings
      [    4.680072] virtio_rpmsg_bus virtio1: creating channel sunxi,rpmsg_ctrl addr 0x400
      [    4.690122] virtio_rpmsg_bus virtio0: creating channel sunxi,rpmsg_ctrl addr 0x400
      [    4.731009] virtio_rpmsg_bus virtio0: creating channel rpbuf-service addr 0x401
      [    4.743973] virtio_rpmsg_bus virtio1: creating channel rpbuf-service addr 0x401
      系统启动到这里就停了,不继续执行了,请大神帮忙看看如何继续往下排查错误?
        柚木 鉉 LV 9 @roidmi 最后由 编辑
        @roidmi 看看关闭dsp后还会不会停下
        R 2 条回复 最后回复 回复 引用 分享 0
        • R
          ROIDMI LV 4 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 还是不行,依然执行不下去
          • R
            @yuzukitsuru
            [72744]fes begin commit:3fee797
            [72747]set pll start
            [72749]periph0 has been enabled
            [72753]set pll end
            [72754]board init ok
            [72756]beign to init dram
            [72759]the chip id is 0x3
            [72761]the chip id is 0x3
            [72764]the chip id is 0x3
            [72766]the chip id is 0x3
            [72768]the chip id is 0x3
            [72771]chip id check OK
            [72774][AUTO DEBUG] two rank and full DQ!
            [72778][AUTO DEBUG] DDR3 try success
            [72782][AUTO DEBUG] single rank and full DQ!
            [72787][AUTO DEBUG] rank 0 row = 14
            [72790][AUTO DEBUG] rank 0 bank = 8
            [72794][AUTO DEBUG] rank 0 page size = 2 KB
            [72798]DRAM BOOT DRIVE INFO: V0.20
            [72801]DRAM Type = 3 (2:DDR2,3:DDR3)
            [72804]DRAMC read ODT  off.
            [72807]DRAM ODT off.
            [72810]DRAM CLK = 774 MHz
            [72812]DRAM SIZE =256 M
            [72816]DRAM simple test OK.
            [72818]rtc[3] value = 0xf6f60006
            [72821]init dram ok
            [74.991]CPU:   Allwinner Family
            [74.994]Model: sun50iw11
            I2C:   ready
            [75.119]DRAM:  256 MiB
            [75.122]Relocation Offset is: 0cefa000
            [75.145]secure enable bit: 0
            [75.149]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=0Mhz
            [75.155]gic: normal mode
            [75.157]flash init start
            [75.159]workmode = 16,storage type = 0
            try card 0
            set card number 0
            get card number 0
            [75.167][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
            [75.180][mmc]: Is not Boot mode!
            [75.182][mmc]: SUNXI SDMMC Controller Version:0x50320
            [75.194][mmc]: ************Try SD card 0************
            [75.199][mmc]: mmc 0 cmd timeout 100 status 100
            [75.203][mmc]: smc 0 err, cmd 8,  RTO
            [75.206][mmc]: mmc 0 close bus gating and reset
            [75.211][mmc]: mmc 0 cmd timeout 100 status 100
            [75.215][mmc]: smc 0 err, cmd 55,  RTO
            [75.219][mmc]: mmc 0 close bus gating and reset
            [75.223][mmc]: ************Try MMC card 0************
            [75.232][mmc]: mmc 0 cmd timeout 100 status 100
            [75.236][mmc]: smc 0 err, cmd 1,  RTO
            [75.240][mmc]: mmc 0 close bus gating and reset
            [75.244][mmc]: Card did not respond to voltage select!
            [75.249][mmc]: ************SD/MMC 0 init error!************
            [75.254][mmc]: mmc init product failed
            MMC init failed
            try emmc fail
            [75.262]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
            [75.267]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
            [75.279]sunxi-spinand-phy: request spi0 gpio ok
            [75.283]sunxi-spinand-phy: request general tx dma channel ok!
            [75.288]sunxi-spinand-phy: request general rx dma channel ok!
            [75.294]sunxi-spinand-phy: set spic0 clk to 20 Mhz
            [75.298]sunxi-spinand-phy: init spic0 clk ok
            [75.344]sunxi-spinand-phy: not detect any munufacture from id table
            [75.351]sunxi-spinand-phy: get spi-nand Model from fdt fail
            [75.356]sunxi-spinand-phy: get phy info from fdt fail
            [75.361]sunxi-spinand-phy: not detect munufacture from fdt
            [75.366]sunxi-spinand-phy: detect munufacture from id table: GD
            [75.372]sunxi-spinand-phy: detect spinand id: ffff52c8 ffffffff
            [75.377]sunxi-spinand-phy: ========== arch info ==========
            [75.383]sunxi-spinand-phy: Model:               GD5F2GQ5UEYIGR
            [75.388]sunxi-spinand-phy: Munufacture:         GD
            [75.393]sunxi-spinand-phy: DieCntPerChip:       1
            [75.397]sunxi-spinand-phy: BlkCntPerDie:        2048
            [75.402]sunxi-spinand-phy: PageCntPerBlk:       64
            [75.406]sunxi-spinand-phy: SectCntPerPage:      4
            [75.411]sunxi-spinand-phy: OobSizePerPage:      64
            [75.415]sunxi-spinand-phy: BadBlockFlag:        0x0
            [75.420]sunxi-spinand-phy: OperationOpt:        0x7
            [75.424]sunxi-spinand-phy: MaxEraseTimes:       50000
            [75.429]sunxi-spinand-phy: EccFlag:             0x1
            [75.434]sunxi-spinand-phy: EccType:             7
            [75.438]sunxi-spinand-phy: EccProtectedType:    2
            [75.443]sunxi-spinand-phy: ========================================
            [75.448]sunxi-spinand-phy:
            [75.451]sunxi-spinand-phy: ========== physical info ==========
            [75.457]sunxi-spinand-phy: TotalSize:    256 M
            [75.461]sunxi-spinand-phy: SectorSize:   512 B
            [75.465]sunxi-spinand-phy: PageSize:     2 K
            [75.469]sunxi-spinand-phy: BlockSize:    128 K
            [75.473]sunxi-spinand-phy: OOBSize:      64 B
            [75.477]sunxi-spinand-phy: ========================================
            [75.483]sunxi-spinand-phy:
            [75.486]sunxi-spinand-phy: ========== logical info ==========
            [75.491]sunxi-spinand-phy: TotalSize:    256 M
            [75.495]sunxi-spinand-phy: SectorSize:   512 B
            [75.499]sunxi-spinand-phy: PageSize:     4 K
            [75.503]sunxi-spinand-phy: BlockSize:    256 K
            [75.508]sunxi-spinand-phy: OOBSize:      128 B
            [75.512]sunxi-spinand-phy: ========================================
            [75.519]sunxi-spinand-phy: set spic0 clk to 100 Mhz
            [75.523]sunxi-spinand-phy: block lock register: 0x00
            [75.528]sunxi-spinand-phy: feature register: 0x11
            [75.533]sunxi-spinand-phy: sunxi physic nand init end
            [75.538]Loading Environment from SUNXI_FLASH... OK
            [75.543]try to burn key
            [75.546]out of usb burn from boot: not boot mode
            sunxi work mode=0x10
            run usb efex
            delay time 2500
            weak:otg_phy_config
            usb init ok
            set address 0x10
            set address 0x10 ok
            set address 0x12
            set address 0x12 ok
            SUNXI_EFEX_ERASE_TAG
            erase_flag = 0x0
            origin_erase_flag = 0x0
            FEX_CMD_fes_verify_status
            FEX_CMD_fes_verify last err=0
            the 0 mbr table is ok
            the 1 mbr table is ok
            the 2 mbr table is ok
            the 3 mbr table is ok
            total mbr part 8
            part[0] classname :DISK
            part[0] addrlo    :0x1f8
            part[0] lenlo     :0x48d8
            part[0] user_type :32768
            part[0] keydata   :0
            part[0] ro        :0
            part[1] name      :env
            part[1] classname :DISK
            part[1] addrlo    :0x4ad0
            part[1] lenlo     :0x1f8
            part[1] user_type :32768
            part[1] keydata   :0
            part[1] ro        :0
            part[2] name      :env-redund
            part[2] classname :DISK
            part[2] addrlo    :0x4cc8
            part[2] lenlo     :0x1f8
            part[2] user_type :32768
            part[2] keydata   :0
            part[2] ro        :0
            part[3] name      :boot
            part[3] classname :DISK
            part[3] addrlo    :0x4ec0
            part[3] lenlo     :0x6078
            part[3] user_type :32768
            part[3] keydata   :0
            part[3] ro        :0
            part[4] name      :rootfs
            part[4] classname :DISK
            part[4] addrlo    :0xaf38
            part[4] lenlo     :0xe850
            part[4] user_type :32768
            part[4] keydata   :0
            part[4] ro        :0
            part[5] name      :dsp0
            part[5] classname :DISK
            part[5] addrlo    :0x19788
            part[5] lenlo     :0x9d8
            part[5] user_type :32768
            part[5] keydata   :0
            part[5] ro        :0
            part[6] name      :dsp1
            part[6] classname :DISK
            part[6] addrlo    :0x1a160
            part[6] lenlo     :0x9d8
            part[6] user_type :32768
            part[6] keydata   :0
            part[6] ro        :0
            part[7] name      :UDISK
            part[7] classname :DISK
            part[7] addrlo    :0x1ab38
            part[7] lenlo     :0x0
            part[7] user_type :0
            part[7] keydata   :0
            part[7] ro        :0
            total part: 9
            mbr 0, 1f8, 8000
            boot-resource 1, 48d8, 8000
            env 2, 1f8, 8000
            env-redund 3, 1f8, 8000
            boot 4, 6078, 8000
            rootfs 5, e850, 8000
            dsp0 6, 9d8, 8000
            dsp1 7, 9d8, 8000
            UDISK 8, 0, 0
            [78.924]erase blk 0 to blk 32
            need erase flash: 0
            [78.988]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,512k@5242880(pstore)ro,-(sys)
            defaults:
            mtdids  : nand0=nand
            [79.047]MTD info (5)
            [79.049]pagesize: 0x1000
            [79.051]blksize: 0x40000
            [79.053]num  offset     bytes      name
            [79.057]0    0x00000000 0x00100000 boot0
            [79.061]1    0x00100000 0x00300000 uboot
            [79.064]2    0x00400000 0x00100000 secure_storage
            [79.069]3    0x00500000 0x00080000 pstore
            [79.072]4    0x00580000 0x0fa80000 sys
            [79.076]ubi attach the last part of mtd device: NO.4
            [79.214]ubi0: attaching mtd5
            [79.411]ubi0: scanning is finished
            [79.418]ubi0: attached mtd5 (name "sys", size 250 MiB)
            [79.422]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [79.429]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [79.435]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [79.441]ubi0: good PEBs: 1002, bad PEBs: 0, corrupted PEBs: 0
            [79.447]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
            [79.453]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
            [79.461]ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 40
            no part need to protect user data
            [79.473]erase blk 0 to blk 32
            SUNXI_EFEX_MBR_TAG
            mbr size = 0x10000
            force mbr
            defaults:
            mtdids  : nand0=nand
            [79.584]MTD info (5)
            [79.586]pagesize: 0x1000
            [79.588]blksize: 0x40000
            [79.590]num  offset     bytes      name
            [79.594]0    0x00000000 0x00100000 boot0
            [79.598]1    0x00100000 0x00300000 uboot
            [79.601]2    0x00400000 0x00100000 secure_storage
            [79.606]3    0x00500000 0x00080000 pstore
            [79.609]4    0x00580000 0x0fa80000 sys
            [79.613]MBR info (unalign):
            [79.615]partno   addr       sects      type       name
            [79.620]0        0x00000000 0x000001f8 0x00000001 mbr
            [79.625]1        0x000001f8 0x000048d8 0x00008000 boot-resource
            [79.631]2        0x00004ad0 0x000001f8 0x00008000 env
            [79.635]3        0x00004cc8 0x000001f8 0x00008000 env-redund
            [79.641]4        0x00004ec0 0x00006078 0x00008000 boot
            [79.646]5        0x0000af38 0x0000e850 0x00008000 rootfs
            [79.651]6        0x00019788 0x000009d8 0x00008000 dsp0
            [79.656]7        0x0001a160 0x000009d8 0x00008000 dsp1
            [79.660]8        0x0001ab38 0x00000000 0x00000000 UDISK
            [79.665]ubi attach the last part of mtd device: NO.4
            [79.670]MBR info (align):
            [79.672]partno   addr       sects      type       name
            [79.677]0        0x00002c00 0x000001f8 0x00000001 mbr
            [79.682]1        0x00002df8 0x000048d8 0x00008000 boot-resource
            [79.688]2        0x000076d0 0x000001f8 0x00008000 env
            [79.692]3        0x000078c8 0x000001f8 0x00008000 env-redund
            [79.698]4        0x00007ac0 0x00006078 0x00008000 boot
            [79.703]5        0x0000db38 0x0000e850 0x00008000 rootfs
            [79.708]6        0x0001c388 0x000009d8 0x00008000 dsp0
            [79.712]7        0x0001cd60 0x000009d8 0x00008000 dsp1
            [79.717]8        0x0001d738 0x00000000 0x00000000 UDISK
            [79.722]ubi attach the last part of mtd device: NO.4
            [79.727]ubi attatch mtd, name: sys
            [79.730]ubi0: detaching mtd5
            [79.733]ubi0: mtd5 is detached
            [79.736]ubi0: attaching mtd5
            [79.932]ubi0: scanning is finished
            [79.939]ubi0: attached mtd5 (name "sys", size 250 MiB)
            [79.943]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [79.950]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [79.956]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [79.962]ubi0: good PEBs: 1002, bad PEBs: 0, corrupted PEBs: 0
            [79.968]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
            [79.974]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
            [79.982]ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 40
            [79.990]volume mbr existed, not create again
            [79.994]volume boot-resource existed, not create again
            [79.999]volume env existed, not create again
            [80.003]volume env-redund existed, not create again
            [80.008]volume boot existed, not create again
            [80.012]volume rootfs existed, not create again
            [80.016]volume dsp0 existed, not create again
            [80.020]volume dsp1 existed, not create again
            [80.024]volume UDISK existed, not create again
            [80.052]fill gap start: volume mbr sects 0x178
            [80.148]fill gap end: volume mbr
            [80.151]update partition map
            [80.154]logical area info: 958 258048 last_lba: 482831
            [80.162]logical area info: 958 258048 last_lba: 482831
            [80.170]logical area info: 958 258048 last_lba: 482831
            [80.178]logical area info: 958 258048 last_lba: 482831
            [80.185]logical area info: 958 258048 last_lba: 482831
            [80.193]logical area info: 958 258048 last_lba: 482831
            [80.201]logical area info: 958 258048 last_lba: 482831
            [80.209]logical area info: 958 258048 last_lba: 482831
            [80.217]logical area info: 958 258048 last_lba: 482831
            [80.225]logical area info: 958 258048 last_lba: 482831
            [80.233]logical area info: 958 258048 last_lba: 482831
            [80.241]logical area info: 958 258048 last_lba: 482831
            [80.249]logical area info: 958 258048 last_lba: 482831
            [80.257]logical area info: 958 258048 last_lba: 482831
            [80.265]logical area info: 958 258048 last_lba: 482831
            [80.272]logical area info: 958 258048 last_lba: 482831
            [80.280]logical area info: 958 258048 last_lba: 482831
            [80.288]logical area info: 958 258048 last_lba: 482831
            [80.296]logical area info: 958 258048 last_lba: 482831
            [80.304]logical area info: 958 258048 last_lba: 482831
            [80.312]logical area info: 958 258048 last_lba: 482831
            [80.320]logical area info: 958 258048 last_lba: 482831
            [80.328]logical area info: 958 258048 last_lba: 482831
            [80.336]logical area info: 958 258048 last_lba: 482831
            [80.344]logical area info: 958 258048 last_lba: 482831
            [80.352]logical area info: 958 258048 last_lba: 482831
            [80.360]logical area info: 958 258048 last_lba: 482831
            [80.367]logical area info: 958 258048 last_lba: 482831
            bootfile_mode=4
            SUNXI_EFEX_BOOT1_TAG
            boot1 size = 0xd8000, max size = 0x200000
            uboot size = 0xd8000
            storage type = 0
            [80.412]uboot blk range [8-32)
            [80.415]download uboot to block 8 (7 blocks) len 864K
            [80.620]download uboot to block 15 (7 blocks) len 864K
            [80.824]download uboot to block 22 (7 blocks) len 864K
            bootfile_mode=4
            SUNXI_EFEX_BOOT0_TAG
            boot0 size = 0xc000
            dram para[0] = 0
            dram para[1] = 3
            dram para[2] = bfb
            dram para[3] = 0
            dram para[4] = 10d2
            dram para[5] = 0
            dram para[6] = 1c70
            dram para[7] = 2
            dram para[8] = 18
            dram para[9] = 0
            dram para[10] = 4a2195
            dram para[11] = 2423190
            dram para[12] = 8b061
            dram para[13] = b4787896
            dram para[14] = 0
            dram para[15] = 48484848
            dram para[16] = 30000048
            dram para[17] = 1620121e
            dram para[18] = 0
            dram para[19] = 0
            dram para[20] = 0
            dram para[21] = 220000
            dram para[22] = 55
            dram para[23] = 14000100
            dram para[24] = 0
            dram para[25] = 0
            dram para[26] = 0
            dram para[27] = 0
            dram para[28] = 0
            dram para[29] = 0
            dram para[30] = 0
            dram para[31] = 0
            storage type = 0
            [81.103]download boot0 to block 0 len 48K
            [81.119]download boot0 to block 1 len 48K
            [81.135]download boot0 to block 2 len 48K
            [81.151]download boot0 to block 3 len 48K
            [81.167]download boot0 to block 4 len 48K
            [81.183]download boot0 to block 5 len 48K
            [81.199]download boot0 to block 6 len 48K
            [81.215]download boot0 to block 7 len 48K
            sunxi_efex_next_action=2
            exit usb
            next work 2
            SUNXI_UPDATE_NEXT_ACTION_REBOOT
            [49]HELLO! BOOT0 is starting!
            [52]BOOT0 commit : 3fee797
            [55]set pll start
            [57]periph0 has been enabled
            [60]set pll end
            [62]board init ok
            [64]rtc[3] value = 0xf6f60006
            [67]enable_jtag
            [68]the chip id is 0x3
            [71]the chip id is 0x3
            [73]the chip id is 0x3
            [75]the chip id is 0x3
            [78]the chip id is 0x3
            [80]chip id check OK
            [83][AUTO DEBUG] two rank and full DQ!
            [86][AUTO DEBUG] DDR3 try success
            [91][AUTO DEBUG] single rank and full DQ!
            [96][AUTO DEBUG] rank 0 row = 14
            [99][AUTO DEBUG] rank 0 bank = 8
            [102][AUTO DEBUG] rank 0 page size = 2 KB
            [106]DRAM BOOT DRIVE INFO: V0.20
            [110]DRAM Type = 3 (2:DDR2,3:DDR3)
            [113]DRAMC read ODT  off.
            [116]DRAM ODT off.
            [118]DRAM CLK = 774 MHz
            [121]DRAM SIZE =256 M
            [126]DRAM simple test OK.
            [129]dram size =256
            [132]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
            [137]block from 8 to 32
            [235]Check is correct.
            [237]dma 0x10818c int is not used yet
            [241]dma 0x10818c int is free, you do not need to free it again
            [247]Entry_name        = u-boot
            [254]Entry_name        = monitor
            [257]Entry_name        = dtb
            [261]Jump to second Boot.
            NOTICE:  BL3-1: v1.0(debug):6efeeb8
            NOTICE:  BL3-1: Built : 13:54:32, 2022-04-24
            NOTICE:  BL3-1 commit: 8
            ERROR:   Error initializing runtime service tspd_fast
            NOTICE:  BL3-1: Preparing for EL3 exit to normal world
            NOTICE:  BL3-1: Next image address = 0x43000000
            ▒OTICE:  BL3-1: Next image spsr = 0x1d3
            I2C:   ready
            defaults:
            mtdids  : nand0=nand
            [00.742]ubi0: attaching mtd5
            [00.942]ubi0: scanning is finished
            [00.948]ubi0: attached mtd5 (name "sys", size 250 MiB)
            [00.953]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [00.959]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [00.965]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [00.972]ubi0: good PEBs: 1002, bad PEBs: 0, corrupted PEBs: 0
            [00.977]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
            [00.984]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
            [00.991]ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 40
            [01.000]sunxi flash init ok
            [01.095]Loading Environment from SUNXI_FLASH... OK
            [01.138]Item0 (Map) magic is bad
            [01.141]usb burn from boot
            delay time 0
            weak:otg_phy_config
            [01.153]usb prepare ok
            [01.360]usb sof ok
            [01.362]usb probe ok
            [01.363]usb setup ok
            set address 0x13
            set address 0x13 ok
            set address 0x14
            set address 0x14 ok
            [04.369]do_burn_from_boot usb : have no handshake
            [04.397]update bootcmd
            [04.415]update dts
            [04.637]no vendor_boot partition is found
            [04.880]Starting kernel ...
            [    0.008221] Console: colour dummy device 80x25
            [    0.027375] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
            [    0.041501] sched-energy: CPU device node has no sched-energy-costs
            [    0.051401] CPU0: update cpu_capacity 1024
            [    0.123757] Detected VIPT I-cache on CPU1
            [    0.123807] Invalid sched_group_energy for CPU1
            [    0.123810] CPU1: update cpu_capacity 1024
            [    0.123813] CPU1: Booted secondary processor [410fd034]
            [    0.123899] Brought up 2 CPUs
            [    0.139002] SMP: Total of 2 processors activated.
            [    0.143692] CPU features: detected feature: 32-bit EL0 Support
            [    0.149498] CPU features: detected feature: Kernel page table isolation (KPTI)
            [    0.158924] CPU: All CPU(s) started at EL1
            [    0.160775] alternatives: patching kernel code
            [    0.165334] Invalid sched_group_energy for CPU1
            [    0.169694] Invalid sched_group_energy for Cluster1
            [    0.174543] Invalid sched_group_energy for CPU0
            [    0.179050] Invalid sched_group_energy for Cluster0
            [    0.184372] devtmpfs: initialized
            [    0.214563] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
            [    0.225818] atomic64_test: passed
            [    0.228020] pinctrl core: initialized pinctrl subsystem
            [    0.234304] NET: Registered protocol family 16
            [    0.238782] dump_class_init,857, success
            [    0.258391] vdso: 2 pages (1 code @ ffffff8008636000, 1 data @ ffffff8008834000)
            [    0.264595] DMA: preallocated 256 KiB pool for atomic allocations
            [    0.275706] sun50iw11p1-r-pinctrl r_pio: initialized sunXi PIO driver
            [    0.284171] sun50iw11p1-pinctrl pio: initialized sunXi PIO driver
            [    0.326758] pwm module init!
            [    0.330995] sunxi-pm debug v3.10
            [    0.331694] SCSI subsystem initialized
            [    0.332647] usbcore: registered new interface driver usbfs
            [    0.338015] usbcore: registered new interface driver hub
            [    0.343182] usbcore: registered new device driver usb
            [    0.348275] sunxi_i2c_adap_init()2649 - init
            [    0.353302] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
            [    0.359426] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
            [    0.365791] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
            [    0.372562] ion_heap_create: Invalid heap type 6
            [    0.377152] Advanced Linux Sound Architecture Driver Initialized.
            [    0.383602] Bluetooth: Core ver 2.22
            [    0.386538] NET: Registered protocol family 31
            [    0.390935] Bluetooth: HCI device and connection manager initialized
            [    0.397260] Bluetooth: HCI socket layer initialized
            [    0.402103] Bluetooth: L2CAP socket layer initialized
            [    0.407176] Bluetooth: SCO socket layer initialized
            [    0.416458] clocksource: Switched to clocksource arch_sys_counter
            [    0.428831] get androidboot.mode fail
            [    0.429526] NET: Registered protocol family 2
            [    0.431785] TCP established hash table entries: 16 (order: -5, 128 bytes)
            [    0.438072] TCP bind hash table entries: 16 (order: -4, 256 bytes)
            [    0.444136] TCP: Hash tables configured (established 16 bind 16)
            [    0.450178] UDP hash table entries: 256 (order: 1, 8192 bytes)
            [    0.455931] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
            [    0.462378] NET: Registered protocol family 1
            [    0.467269] sunxi_spi_probe()2152 - [spi0] SPI MASTER MODE
            [    0.472036] spi0 supply spi not found, using dummy regulator
            [    0.477662] sunxi_spi_request_gpio()1804 - [spi0] Pinctrl init spi0
            [    0.483883] sunxi_spi_clk_init()1854 - [spi0] mclk 100000000
            [    0.490164] sunxi_spi_probe()2225 - [spi0]: driver probe succeed, base ffffff8008060000, irq 245
            [    0.500534] workingset: timestamp_bits=61 max_order=16 bucket_order=0
            [    0.513559] squashfs: version 4.0 (2009/01/31) Phillip Lougher
            [    0.516629] io scheduler noop registered
            [    0.517658] io scheduler deadline registered
            [    0.522351] io scheduler cfq registered (default)
            [    0.527723] [LCD_FB] lcd_fb_init,line:159:
            [    0.530521]
            [    0.538648] uart uart0: get regulator failed
            [    0.538707] uart0 supply uart not found, using dummy regulator
            [    0.543396] uart0: ttyS0 at MMIO 0x2500000 (irq = 244, base_baud = 1500000) is a SUNXI
            Vss▒{c+▒▒▒˛▒▒] sw_console_▒k▒VV▒▒&6▒
             c+#k
                 [    0.558923] console [ttyS0] enabled
            [    0.562869] bootconsole [earlycon0] disabled
            [    0.571876] misc dump reg init
            [    0.579019] Unable to detect cache hierarchy for CPU 0
            [    0.585647] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
            [    0.592891] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211125
            [    0.600751] sunxi-spinand-phy: not detect any munufacture from id table
            [    0.608177] sunxi-spinand-phy: get spi-nand Model from fdt fail
            [    0.614821] sunxi-spinand-phy: get phy info from fdt fail
            [    0.620875] sunxi-spinand-phy: not detect munufacture from fdt
            [    0.627522] sunxi-spinand-phy: detect munufacture from id table: GD
            [    0.634557] sunxi-spinand-phy: detect spinand id: ffff52c8 ffffffff
            [    0.641587] sunxi-spinand-phy: ========== arch info ==========
            [    0.648129] sunxi-spinand-phy: Model:               GD5F2GQ5UEYIGR
            [    0.655073] sunxi-spinand-phy: Munufacture:         GD
            [    0.660836] sunxi-spinand-phy: DieCntPerChip:       1
            [    0.666500] sunxi-spinand-phy: BlkCntPerDie:        2048
            [    0.672456] sunxi-spinand-phy: PageCntPerBlk:       64
            [    0.678218] sunxi-spinand-phy: SectCntPerPage:      4
            [    0.683883] sunxi-spinand-phy: OobSizePerPage:      64
            [    0.689645] sunxi-spinand-phy: BadBlockFlag:        0x0
            [    0.695503] sunxi-spinand-phy: OperationOpt:        0x7
            [    0.701364] sunxi-spinand-phy: MaxEraseTimes:       50000
            [    0.707420] sunxi-spinand-phy: EccFlag:             0x1
            [    0.713279] sunxi-spinand-phy: EccType:             7
            [    0.718943] sunxi-spinand-phy: EccProtectedType:    2
            [    0.724607] sunxi-spinand-phy: ========================================
            [    0.732021] sunxi-spinand-phy:
            [    0.735545] sunxi-spinand-phy: ========== physical info ==========
            [    0.742475] sunxi-spinand-phy: TotalSize:    256 M
            [    0.747846] sunxi-spinand-phy: SectorSize:   512 B
            [    0.753217] sunxi-spinand-phy: PageSize:     2 K
            [    0.758393] sunxi-spinand-phy: BlockSize:    128 K
            [    0.763767] sunxi-spinand-phy: OOBSize:      64 B
            [    0.769041] sunxi-spinand-phy: ========================================
            [    0.776456] sunxi-spinand-phy:
            [    0.779973] sunxi-spinand-phy: ========== logical info ==========
            [    0.786810] sunxi-spinand-phy: TotalSize:    256 M
            [    0.792185] sunxi-spinand-phy: SectorSize:   512 B
            [    0.797559] sunxi-spinand-phy: PageSize:     4 K
            [    0.802734] sunxi-spinand-phy: BlockSize:    256 K
            [    0.808109] sunxi-spinand-phy: OOBSize:      128 B
            [    0.813481] sunxi-spinand-phy: ========================================
            [    0.820973] sunxi-spinand-phy: block lock register: 0x00
            [    0.827060] sunxi-spinand-phy: feature register: 0x11
            [    0.832737] sunxi-spinand-phy: sunxi physic nand init end
            [    0.839092] Creating 5 MTD partitions on "sunxi_mtd_nand":
            [    0.845256] 0x000000000000-0x000000100000 : "boot0"
            [    0.852404] 0x000000100000-0x000000400000 : "uboot"
            [    0.861944] 0x000000400000-0x000000500000 : "secure_storage"
            [    0.868650] random: fast init done
            [    0.873793] 0x000000500000-0x000000580000 : "pstore"
            [    0.880676] pstore_zone: registered pstore_blk as backend for kmsg(Oops,panic_write)
            [    0.889417] pstore: Registered pstore_blk as persistent store backend
            [    0.896654] mtd mtd3: Attached to MTD device 3
            [    0.901663] 0x000000580000-0x000010000000 : "sys"
            [    1.251107] random: crng init done
            [    1.281967] libphy: Fixed MDIO Bus: probed
            [    1.286825] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
            [    1.294399] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
            [    1.301669] usbcore: registered new interface driver uas
            [    1.307734] usbcore: registered new interface driver usb-storage
            [    1.314529] usbcore: registered new interface driver ums-alauda
            [    1.321229] usbcore: registered new interface driver ums-cypress
            [    1.328022] usbcore: registered new interface driver ums-datafab
            [    1.334819] usbcore: registered new interface driver ums_eneub6250
            [    1.341800] usbcore: registered new interface driver ums-freecom
            [    1.348591] usbcore: registered new interface driver ums-isd200
            [    1.355284] usbcore: registered new interface driver ums-jumpshot
            [    1.362182] usbcore: registered new interface driver ums-karma
            [    1.368768] usbcore: registered new interface driver ums-onetouch
            [    1.375676] usbcore: registered new interface driver ums-realtek
            [    1.382466] usbcore: registered new interface driver ums-sddr09
            [    1.389162] usbcore: registered new interface driver ums-sddr55
            [    1.395849] usbcore: registered new interface driver ums-usbat
            [    1.402500] usb_serial_number:20080411
            [    1.407256] sunxi_gpadc_init,1962, success
            [    1.412783] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
            [    1.419695] sunxi-rtc rtc: RTC enabled
            [    1.423936] fix to hot reboot, save boot reason
            [    1.429235] i2c /dev entries driver
            [    1.433322] lirc_dev: IR Remote Control driver registered, major 247
            [    1.440465] IR NEC protocol handler initialized
            [    1.445548] IR RC5(x/sz) protocol handler initialized
            [    1.451219] IR LIRC bridge handler initialized
            [    1.456628] sunxi cedar version 0.1
            [    1.460728] google_vp9: sunxi google vp9 version 0.1
            [    1.467592] sunxi-wdt 20000a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
            [    1.476647] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
            [    1.483979] Bluetooth: HCI UART protocol H4 registered
            [    1.489748] Bluetooth: HCI H4 protocol initialized
            [    1.495127] Bluetooth: HCI UART protocol (null) registered
            [    1.501285] Bluetooth: HCI Realtek H5 protocol initialized
            [    1.507645] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
            [    1.515048] bt_fdi debugfs_init
            [    1.521498] hidraw: raw HID events driver (C) Jiri Kosina
            [    1.527842] usbcore: registered new interface driver usbhid
            [    1.534113] usbhid: USB HID core driver
            [    1.540055] Netfilter messages via NETLINK v0.30.
            [    1.545584] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
            [    1.552397] ctnetlink v0.93: registering with nfnetlink.
            [    1.558649] ip_tables: (C) 2000-2006 Netfilter Core Team
            [    1.565294] NET: Registered protocol family 10
            [    1.571324] NET: Registered protocol family 17
            [    1.576520] Bluetooth: RFCOMM TTY layer initialized
            [    1.582012] Bluetooth: RFCOMM socket layer initialized
            [    1.587817] Bluetooth: RFCOMM ver 1.11
            [    1.592035] 8021q: 802.1Q VLAN Support v1.8
            [    1.608724] cpu cpu1: opp_list_debug_create_link: Failed to create link
            [    1.616157] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
            [    1.627727] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1008000 KHz
            [    1.640396] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1104000 KHz
            [    1.654546] ubi0: attaching mtd4
            [    2.036233] ubi0: scanning is finished
            [    2.047504] ubi0: attached mtd4 (name "sys", size 250 MiB)
            [    2.053672] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [    2.061382] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [    2.068986] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [    2.076787] ubi0: good PEBs: 1002, bad PEBs: 0, corrupted PEBs: 0
            [    2.083618] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
            [    2.091712] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
            [    2.101071] ubi0: available PEBs: 0, total reserved PEBs: 1002, PEBs reserved for bad PEB handling: 40
            [    2.111559] ubi0: background thread "ubi_bgt0d" started, PID 719
            [    2.122918] block ubiblock0_5: created from ubi0:5(rootfs)
            [    2.129369] sunxi-rtc rtc: setting system clock to 1970-01-04 09:30:52 UTC (293452)
            [    2.138888] ALSA device list:
            [    2.142221]   No soundcards found.
            [    2.148492] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
            [    2.157968] devtmpfs: mounted
            [    2.161564] Freeing unused kernel memory: 384K
            [    2.556029] init: Console is alive
            [    2.560037] init: - watchdog -
            [    2.563528] init: - preinit -
            [    3.124265] mount_root: mounting /dev/root
            [    3.129688] mount_root: loading kmods from internal overlay
            [    3.229236] block: attempting to load /etc/config/fstab
            [    3.248331] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 763
            [    3.304611] UBIFS (ubi0:8): recovery needed
            [    3.474140] UBIFS (ubi0:8): recovery completed
            [    3.479197] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
            [    3.487391] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
            [    3.498502] UBIFS (ubi0:8): FS size: 188633088 bytes (179 MiB, 731 LEBs), journal size 9420800 bytes (8 MiB, 37 LEBs)
            [    3.510388] UBIFS (ubi0:8): reserved for root: 0 bytes (0 KiB)
            [    3.516926] UBIFS (ubi0:8): media format: w4/r0 (latest is w4/r0), UUID 7F434AE4-A781-4053-8A82-96C402FFA2B6, small LPT model
            [    3.531740] block: extroot: UUID match (root: a69af1b8-64fb5e48-26223ddf-ba2addc3, overlay: a69af1b8-64fb5e48-26223ddf-ba2addc3)
            [    3.552531] mount_root: switched to extroot
            [    3.563043] procd: - early -
            [    3.566386] procd: - watchdog -
            [    3.704687] procd: - watchdog -
            [    3.708410] procd: - ubus -
            [    3.712058] procd (1): /proc/930/oom_adj is deprecated, please use /proc/930/oom_score_adj instead.
            [    3.814257] procd: - init -
            [    4.228876] fuse init (API version 7.26)
            [    4.254676] xt_time: kernel timezone is -0000
            kmodloader done
            [    4.371194] file system registered
            [    4.450333] read descriptors
            [    4.453704] read strings
              @roidmi 草,这不是阻塞了,是没有出终端,initab里设置一下命令行就行了
              • R
                • R
                  @yuzukitsuru 在 R329系统启动阻塞问题求救 中说:
                  谢谢老哥
