    A133 tplayerdemo 播放视频出错。。。
    6200
      memory LV 7 最后由 编辑
      DEBUG  : awplayer <CdxPluginLoadList:221>: have config 0 entry
      DEBUG  : awplayer <CdxPluginLoadList:222>: start to open plugin lib
      DEBUG  : awplayer <AwStreamInit:107>: aw stream init...
      DEBUG  : awplayer <AwStreamInit:150>: stream list size:8
      INFO   : awplayer <AwParserInit:441>: aw parser init...
      DEBUG  : awplayer <AwParserInit:560>: aw parser size:17
      * This program implements a simple player, you can type commands to control the player.
      * To show what commands supported, type 'help'.
      argc = 2,argv[0] = tplayerdemo,argv[1] = /mnt/UDISK/bhsj.mp4
      may be is one file:cut down suffix is:.mp4
      find the matched type:.mp4
      tag   : tina3.5
      branch: tina-dev
      DEBUG : tplayer <TPlayerCreate:198>: TPlayerCreate
      DEBUG  : awplayer <XPlayerCreate:236>: XPlayerCreate.
      DEBUG  : awplayer <LogVersionInfo:34>:
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> CedarX <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   : CedarX-2.8.0
      branch: master
      commit: 967535b8ff6a073cb4f38e85a4ae5fa6008014d8
      date  : Mon, 15 May 2017 01:30:22 +0000 (09:30 +0800)
      author:
      DEBUG : tsoundcontrol <TSoundDeviceCreate:147>: TinaSoundDeviceInit()
      DEBUG : tsoundcontrol <openSoundDevice:17>: openSoundDevice() in default style
      ALSA lib pcm_direct.c:1824:(_snd_pcm_direct_get_slave_ipc_offset) Invalid value for card
      ERROR : tsoundcontrol <openSoundDevice:24>: open audio device failed:No such file or directory, errno = 2
      DEBUG : tsoundcontrol <TSoundDeviceCreate:167>: open sound device fail
      ERROR : tplayer <TPlayerCreate:230>: sound device create fail,mPrivateData->mSoundCtrl is null
      WARNING: awplayer <XPlayerDestroy:341>: XPlayerDestroy
      WARNING: awplayer <XPlayerReset:991>: reset...
      DEBUG  : awplayer <PlayerStop:951>: ****** PlayerStop
      ERROR  : awplayer <PlayerStop:956>: invalid stop operation, player already in stopped status.
      can not create tplayer, quit.
      root@TinaLinux:/#
      D 1 条回复 最后回复 回复 引用 分享 0
        dream LV 6 @memory 最后由 编辑
        @memory 打印信息提示,打开声卡设备失败,可以往这个方向去查一下。
        whycan M 3 条回复 最后回复 回复 引用 分享 0
          memory LV 7 最后由 编辑
          添加文件: ~/.asoundrc:
          pcm.!default {
                  type hw
                  card 0
          ctl.!default {
                  type hw
                  card 0
          搞定了。
          • Moved from MR Series by  whycan whycan
            whycan晕哥 LV 9 @dream 最后由 whycan 编辑
              memory LV 7 @dream 最后由 编辑
              @dream
              谢谢, 可以了。
                @dream
                请教tplayerdemo 怎么按视频长宽比例显示,默认是全屏显示。
                  @memory 抱歉,我没用过 tplayerdemo 来播放视频,或许可以通过查阅这部分代码或配置文件可以找到解决方法。
