    请教spi1 st7789V怎么移植配置开机logo?
    9
    7961
      hy123456 LV 5 最后由 YuzukiTsuru 编辑
      硬件平台r528 ,tina 系统,u-boot-2018。用spi1 驱动一个st7789v的240*240的小屏。
      kernel现在已经可以显示logo.但是uboot 阶段一直不显示?请教一下具体怎么配置?
      还有请教uboot阶段系统运行开机logo的步骤?现在不知道怎么跟踪,不清楚问题出在那里?
      修改了一下内容,还是没有显示:
      1、tina-r528/lichee/brandy-2.0/u-boot-2018/include/configs$ vi sun20iw1p1.h
      增加了头文件
        #define CONFIG_VIDEO_LOGO
       #define CONFIG_VIDEO_BMP_LOGO
      2、tina-r528/device/config/chips/r528/configs/evb1$ vi uboot-board.dts
      设备树修改
         &lcd0 {
          lcd_used            = <1>;
          lcd_driver_name     = "st7789v";
          lcd_backlight       = <50>;
          lcd_if              = <0>;
          lcd_x               = <240>;
          lcd_y               = <240>;
          lcd_width           = <23>;
          lcd_height          = <23>;
          lcd_dclk_freq       = <19>;
          lcd_pwm_used        = <1>;
          lcd_pwm_ch          = <7>;
          lcd_pwm_pol         = <0>;
          lcd_hbp             = <120>;
          lcd_ht              = <850>;
          lcd_hspw            = <2>;
          lcd_vbp             = <13>;
          lcd_vt              = <293>;
          lcd_vspw            = <2>;
          lcd_lvds_if         = <0>;
          lcd_lvds_colordepth = <1>;
          lcd_lvds_mode       = <0>;
          lcd_frm             = <1>;
          lcd_hv_if           = <8>;
          lcd_hv_clk_phase    = <0>;
          lcd_hv_sync_polarity   = <0>;
          lcd_hv_srgb_seq     = <0>;
          lcd_gamma_en        = <0>;
          lcd_bright_curve_en = <1>;
          lcd_cmap_en         = <0>;
          deu_mode            = <0>;
          lcdgamma4iep        = <22>;
          smart_color         = <90>;
          //reset
          lcd_gpio_0          = <&pio PD 9 1 0 3 1>;
          //cs
          lcd_gpio_1          = <&pio PD 10 1 0 3 0>;
          //sda
          lcd_gpio_2          = <&pio PD 12 1 0 3 0>;
          //sck
          lcd_gpio_3          = <&pio PD 11 1 0 3 0>;
          //dc
          lcd_gpio_4          = <&pio PD 8 1 0 3 1>;
      //  pinctrl-0 = <&rgb24_pins_a>;
      //  pinctrl-1 = <&rgb24_pins_b>;
      3、tina-r528/lichee/brandy-2.0/u-boot-2018/arch/arm/dts$ vi sun8iw20p1-soc-system.dts
      增加SPi1 节点
      4、tina-r528/lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd$ vi st7789v.c
      修改驱动初始化
      5、menuconfig 选择st7789v。
        SPI 屏幕要取消勾选CONFIG_AW_PHY=y
        chinazhangdj H 2 条回复 最后回复 回复 引用 分享 0
        • chinazhangdj
          gouer LV 5 @YuzukiTsuru 最后由 编辑
          @yuzukitsuru 大佬的Rosetta屏幕搞完没有,能出个教程嘛,R328+ST7789不知道怎么搞哎😧
            hy123456 LV 5 @YuzukiTsuru 最后由 编辑
            @yuzukitsuru 您好,我把vi lichee/brandy-2.0/u-boot-2018/configs/sun8iw20p1_defconfig 中的CONFIG_AW_PHY=y 注释掉了。试了一下,还是不行。我看
            执行了show_bmp_on_fb
            [00.838]bmp_name=bootlogo.bmp size 172856
            172856 bytes read in 9 ms (18.3 MiB/s)
            fileaddr =43f3b040 ,filesize =172856
            HHHHHHHHHshow_bmp_on_fb:164
            HHHHHHHHHshow_bmp_on_fb:261
            [00.977]Loading Environment from SUNXI_FLASH... OK
              柚木 鉉 LV 9 @chinazhangdj 最后由 编辑
              @chinazhangdj 用fbtft驱动,配置io spi
                柚木 鉉 LV 9 @hy123456 最后由 编辑
                @hy123456 我感觉他已经显示了只是没有开屏,这个有什么影响吗
                H 1 条回复 最后回复 回复 引用 分享 0
                  @yuzukitsuru 现在就是logo 显示的有些慢,大约上电4s左右到kernel 启动后才能显示出来。
                  baiwen 1 条回复 最后回复 回复 引用 分享 0
                  • baiwen
                    100ask LV 6 @hy123456 最后由 编辑
                    @hy123456 6 为什么不尝试在uboot阶段就显示logo 再折腾一遍?
                      hy123456 LV 5 @baiwen 最后由 编辑
                      @allwinnertech 是的就是想在uboot 中配置好,但是没有成功。
